[资料] 学习teamcenter,搞明白这些命令,你就毕业了
2020-2-5 16:17:09 20831 6
发表于 2014-8-25 13:30:34 | 显示全部楼层 |阅读模式
我把这些命令拉出来,感兴趣的去学学看。无论安装还是配置Teamcenter,实际都是使用这些命令在干活!
  B! q- Y) P- `1 N" q5 ], _# E. d$ A! K+ w" ]; v
4 {. n( \0 a& ^, D3 M+ ~action_handler.exe' m/ O, y9 s) ^$ m
validate_variant_rule.exe1 Q9 B8 M% N) d$ ~
validate_types.exe
: t; G( G) ^, T6 ucollect_garbage.exe
, E2 z: I# Z; `' Q. L9 x0 g: X2 C$ `clsutility.exe  m& `- N/ K/ ~. o
NXmgr_add_note_types.exe
' D% t3 L+ P) Z6 g" ?: ~& onxmgr_generate_appuid_upgrade_xml.exe
* \3 p; M3 I  o3 l0 F( yclips_dataset_upload.exe
2 y, X2 N) Q$ P- L  Q) c3 {nxmgr_modify_cli_in_files.exe5 D8 S0 Q& Y% M% a6 v2 \8 S+ ]$ L
nxmgr_upgrade_altrep_info.exe
# m7 c- r' q6 R) t) W5 [# x6 e$ unxmgr_upgrade_appuid.exe6 c* z: t# {  u) K! o0 ]" I0 }
nxmgr_upgrade_bvrsyncform.exe
( z  K5 {: ]+ T: ~/ tnxmgr_upgrade_transforms.exe3 c+ v5 a, O. p; Z
clear_process_stage_list.exe
  X% z, L# d. m3 t/ V% aobjio_importer.exe0 A" K& M1 l* K& d4 U7 ^; s
occ_uom_sync.exe
  a$ }1 t, e  I4 ~  X4 vclearlocks.exe, U. v' ?$ _0 r& ^, J0 k
ods.exe
3 X7 s- Q/ e8 E7 |/ @. p8 wclean_epm_objs.exe
$ e5 O7 B2 D( O% kclean_backpointer.exe
1 j9 t5 I/ |* h: R+ H) `2 n7 ?' ?( uclean_alias_objs.exe1 \; o* y( O  E+ D: T" {
pdx_export.exe
. b/ k: X  e+ ?0 Eperl.exe
. X- a/ H' ^; L* Scleanup_userinbox.exe0 d; X4 N6 o% I( \% ?0 `3 A
cleanup_recovery_table.exe3 ~- U3 e% D) M: w/ ^; O* W
perlglob.exe
0 C) e# U4 v1 p/ |3 @% Ocleanup_psdata.exe
9 e6 Y: ?7 [' c$ Scleanup_ic_objects.exe3 I; V* F; Z; ~8 y( v7 ~. z2 L! G
cleanupTCcalendar.exe
: T4 T" X; Y- q' gplmxml_export.exe
# F" E( A4 P# x1 ^: W$ G* l! vplmxml_import.exe
4 S6 G% m2 o; H, L3 Yplmxml_sync.exe
# `) e8 `. L$ m  yplmxml_tm_edit_xsl.exe7 w0 b+ ?5 T" A0 ~; o4 t; \
plm_report_consistency_analysis.exe8 J( r) }1 D0 m+ U; M9 W
plm_report_constraint_analysis.exe4 c% a/ i* W; W& w+ d' X$ S
plm_report_extract.exe
  M- y. b6 u7 upom_audit_manager.exe+ b: n$ [. ]1 [
pom_type_to_class.exe
* J2 Q" M& h6 J( U- Cpopulate_lou_occnotes.exe7 h1 Q9 t) M+ f* E2 ^+ O
portinst.exe; `# _  c; R5 Q' `2 d
portserv.exe
0 }  x: V. G) b+ B# p5 fpreallocated_tag_test.exe
0 S! s8 X1 p5 I3 s2 s- a3 tpreferences_manager.exe
  S3 ?2 r) _/ i: L2 i9 y$ Zpreferences_modification.exe
+ \% x# Z- j9 f$ G' r( l: ?7 @$ u5 ypreferences_upgrade.exe
. K* M, K2 p8 e6 p, qprocess_action_rules.exe
) B6 e8 k9 O7 y6 r% ~; X2 T7 svalidate_revrule_effectivity.exe
% u' T% y: S3 [% Zproxy_sync.exe" J1 s6 W) y9 n" L. k- }
check_volume_access.exe/ `" p+ I0 L8 k* z4 M6 R3 k
change_type_name.exe  p" X3 A5 O% c5 [) q
change_effectivity_mode.exe
/ X3 I2 [7 i: C$ \8 E# Sps_exportconfignxassembly.exe$ F+ i6 j8 r9 M2 L# Z0 ~* b# T2 _
ps_rename_bvrs.exe
$ a9 ]& G' F- n: z# r7 t4 ^% Yps_traverse.exe
. c2 a. Y! k: Cps_upload.exe
! L5 P( I* ^* KPULIST.EXE- [* e, ?% L2 _; t" z2 R% J
purge_baselined_item_revisions.exe& g  u" U/ N* _
purge_datasets.exe
0 ?) P+ Z+ s, M1 p7 [4 @$ o8 {2 }, Upurge_historical_revisions.exe# b% c2 z% r4 E+ V8 v" G
purge_invalid_subscriptions.exe( I- [) Q( i1 G$ F' V; @
purge_processes.exe6 W$ E+ a7 u. Z& d. Z5 ~
purge_volumes.exe
' ]" b1 U* c& A! i+ \( C" oqpl_convert_occs2tc.exe
! o6 q+ _: O  ]( ?qsearch_process_queue.exe" u; E( f5 ~1 I7 s3 d: y& s
query_scos.exe9 ]1 ~5 m+ n& B
query_xml.exe
6 D! p5 @9 x2 d/ M( W8 {! |* wrdv_context_download.exe( @+ N- H; h6 l
rdv_import_usage.exe5 I$ Q- a% {  A2 _7 Y, c
rdv_migrate_architecture.exe
: p2 W) L$ N1 g( ]5 M' trdv_migrate_part_solutions.exe
/ g4 {6 S+ \/ [4 J# Srdv_run_audit_report.exe  j- x, w3 f0 e9 s( O% a
rdv_set_default_variant_condition.exe
% O0 I4 u6 x# g8 K+ _2 cchange_datasets.exe% h2 s8 f' }1 [3 `% I! o
change_class_app.exe
/ _% T4 C% @+ V6 o$ ~7 S1 Mreencode_filenames.exe8 Z+ c6 F: v9 i! i5 F  E9 }
refile_info.exe8 n  G$ }' t6 f& ?& O
released_parts_collector.exe
7 {" t6 [+ f  a1 P! @) S  Nrelease_man.exe: j1 h. Q+ V9 I* O
rem_inv_consm.exe: G' L* M2 A# ^" C; i( l0 y' L
rename_meta_object_name.exe
: J1 [! u; t  q8 {! ^6 vreport.exe9 L" ]8 O0 X7 \& A" d% V2 n1 G
report_volume.exe
1 S" D0 V+ ?* N: c& U4 _- f% K4 orep_batch_report.exe
5 U& F0 B6 p* T( m) ?  freq_bulk_id_generation.exe
; T$ u! J. [& C- T8 h- s" mreq_convert_to_plaintext.exe
" S, @3 O4 @. |# t" K! s+ ereq_migrate_fulltext.exe6 ], x5 L" b- ^$ @
req_migrate_grm.exe
9 @( N+ \( `7 k2 U6 L% ureq_migrate_richtext.exe
! |/ J' d3 p! ?# q3 E4 s/ Jreq_perf_test.exe
' N6 y% E% ^* \: s& A; Wreset_user_home_folder.exe
9 ?# d  l0 q2 q3 Q) s2 z+ Z1 Lcfm_upgrade.exe! v0 F+ L, E0 O  a/ Z
res_upgrade_res.exe
/ e* V4 b5 x) I- E5 B; h8 N) Nreview_volumes.exe
3 _' p5 i. n4 G, xrevisioning_verifier.exe! ^/ [8 G! s% z) O. k8 r
revrule_upgrade.exe: R/ B" ?" [- j# E
rimp_bg.exe
% ^; D! Q; ~8 trole_util.exe
$ q" D' r0 R0 ?# Srpcinfo.exe( @: y: X; x: i* G' C# B/ p
cc_writer.exe
5 m: M' U4 `  g* xsb.exe
8 K  a& y7 K5 z3 \8 jsc.exe
' W  R" g% K+ @2 r2 Ischema.exe9 B  d# P( G1 H) A$ b# ^: T
schmgtwfd.exe. L* V- S9 r# p
schmgt_delete_utility.exe$ g5 N& {  T" R. k; P$ L; B
schmgt_upgrade_r8.exe
, |! H/ f' i3 O- Qschmgt_upgrade_r9.exe& `/ U0 o" _6 A
cae_validate_structuremap.exe
4 s) c$ ^2 W; q0 x- m! q0 bset_pmmserver_mode.exe
! k9 B9 s! \7 |& z  Jsfr_bg.exe
) i3 w/ F8 J! l; k, w( Ssfr_instances.exe* t# Q1 p& }. T) m1 g+ \' A( A
shared_server_metadata_cache_mgr.exe4 `' i: x7 P. U
sitcons_accountability_chk.exe: G# \7 D% ~. N( p3 t# S
sitcons_extract_shared_vols.exe
4 Q$ k5 d! L3 X5 Ositcons_fix_ixr.exe' [# Y1 J+ A4 Q8 X- e0 l
sitcons_gen_shared_vols.exe/ _* t8 g6 T) u  j
sitcons_gen_uidbatch.exe
- D1 [4 v3 Z: D5 Csitcons_replicate_mgr.exe
6 _; P: H- U4 J% m. {% [, `& Q: p4 \sitcons_user_folders.exe4 n, Y8 o" z- w: a9 ?4 w9 n
sitcons_xfer_owner_mgr.exe
! {1 _; @, @; ~# i2 V  Esite_util.exe# T, B8 R) Q0 f
smartuibldr_configure.exe
( R/ W, x. N' n: |smlutility.exe
8 J+ O4 I( `: ecae_simulation_process_import.exe
( t( t8 N3 b$ v6 lsort.exe
( E6 C" r  L3 {sps_make_folder.exe
; ]0 j) u0 R4 `) N) vcae_save_result_data.exe
+ x6 L! h( p* u9 u2 [2 N! m1 w. Qcae_notify_sim_process_results.exe$ Y& }  E0 F- [8 W) u' A
v9_resourcepool_upgrade.exe5 Q# w% b* x! Y3 P/ C
v9_epmtask_upgrade.exe
* H; _6 Y3 Y6 B# I- n$ fcae_migrate_datamap_definition.exe
: g: g: x3 Z: D& Gcae_migrate_atl_preferences.exe6 h0 j9 Y1 x/ k+ W: [
cae_geometry_fix.exe
: G/ d6 L! L4 E3 _cae_execute_structuremap.exe
7 Y+ i! W* O4 m. _' Ncae_execute_datamap.exe
5 W0 k/ b) x" u2 `* h, ?cae_execute_cae_accountability_check.exe
4 `" m! R- b( {) h0 Dcae_configure_dm_propertyset.exe
" \9 x, [0 W1 Y! X% h. _8 Ucae_analysis_fix.exe: h9 c' C8 ^; l- ?! o
business_rules_dtdxml2plmxml.exe
8 w& e& F9 A: F$ Pbusiness_model_updater.exe6 H4 o2 s9 @- G. I
business_model_extractor.exe
. S6 @; ]: Z+ y3 d4 Wbuild_fts_index.exe4 V# K& M) K* S" J1 a# u6 p
briefcase_validator.exe
# M. S5 v- {. O' I: K5 V/ `6 T( ?start_sco_dispatcher.exe
* I; q) E$ X7 K/ e- R" q; |bom_roll_up_report.exe* X# `  F) e6 Q4 B; K8 ^. E1 D
bom_expand.exe4 R& l* R" j8 I8 x2 U
step_export.exe+ ~% T4 I  t, \9 X' d- L
step_import.exe
3 b& d% m9 a( x% Ov10_processvariable_upgrade.exe8 s( v7 D4 M" E- y! o% I( B! I# Y3 Y
v10_allocation_upgrade.exe0 D1 T2 A6 Z( Z! s) F% F( x, n) \) y
v10_allocation_type_upgrade.exe
$ y" K# ]# ?! u2 Z7 `% C# tsubscmpl_attach_compliance_results.exe0 Q' i# v- g' z8 H+ y: W
subscmpl_import_templates.exe1 P) W' u4 D8 \3 o: @7 t% ^7 l- ]
subscmpl_validate_compliance_results.exe  e4 ?: u. }, T7 E1 V! C* [
subscriptionmgrd.exe2 Z7 l8 W" p$ R  C6 v" P9 v% ?& J
bomwriter.exe+ l/ }0 t( p( y* o# K5 r
swish-e.exe
$ I- w7 b( r1 k/ ~2 @2 hsync_form_util.exe% ?) z  `% o. t( K
sync_on_demand.exe
. {& d! d7 e- P1 _" @sync_product_apns.exe
2 q0 H; ~6 `2 i/ \sync_product_variant_data.exe
" D, D5 b$ w+ y5 Nbmide_schema.exe, ~& F# D! _! e+ Z
bmide_manage_templates.exe
# {: D* }- X* z* t$ cbmide_deployment_lock.exe
+ Z5 _7 M0 W. i3 xbatch_export_translate_import.exe8 t/ ^( }/ L6 c$ o. [
basetccalendar.exe
8 u4 d% N; o, l3 [backup_xmlinfo.exe
; S) u6 K8 C* y) rtao_imr.exe/ c% w1 s& o' C+ j7 P. r
backup_modes.exe' l5 S" E' U8 |+ R! w
tao_imr_activator.exe. \/ D* v3 f" m1 A- |7 ^! `- t6 d
audit_purge.exe
( Z. |! k2 o) o  l; `) _  m5 N; r+ p% _audit_archive.exe
# y+ L, m$ d& \( n' d0 nattribute_export.exe5 o* ?4 D; n& y% w1 _$ F0 A
tao_imr_locator.exe9 e& H! N/ A$ S1 ]/ p
async_invoker.exe* G+ Q% Y( [  ]! H" P6 q. i) u/ `
assy_jt_creator.exe
9 ?: ]% n' |( V8 eappr_working_scheduler.exe6 y2 q5 @( A0 W1 d# O
appr_update_supervisor.exe' p3 x! j. e& r6 p$ y
appr_update_console.exe- F7 S' S7 @, t) ^) r& Z1 s
appr_bg_update_scheduler.exe
0 ]- o9 j0 n! Q  m7 Cappr_bg_activities.exe- D  N9 z3 j) K" p4 h
apply_naming_rule.exe. g( G5 h6 Y. U
appearance_updater.exe
, z2 l0 ]- r* @+ Etask_monitor.exe! u9 b. U* D/ i$ T0 y3 X
taxonomy.exe
$ T7 H' {: G1 W# A9 z6 [4 G# ^9 iapn_medic.exe6 z1 F9 u* x* t6 J' Z
tcae_dbutils_background_util.exe- Q# R9 n3 k+ J! {
tcae_login_key.exe
/ Z* c* X; Z: A6 etcae_wrapper.exe
7 d$ L% |1 {9 Z: ?  k2 Fapiserver.exe
6 T: A9 R% u4 W0 ?& R4 B8 Aam_install_tree.exe
0 ?$ W5 _3 i2 d+ Ptcc_context_upload.exe
# k& ^3 X! Q9 ^tcexcel_import.exe
' |# o! O, v1 O  `6 h# e6 jupload_plmxml_struct.exe7 w8 |5 [1 t+ c: D- A% j+ L
TcFSCService.exe
3 S3 S5 R5 R: q" wupgrade_workflow.exe
  y+ Q4 d* _) T! S5 Vaie_install_datamodel_objs.exe
9 L/ Q2 d& T7 Paie_import_templates.exe
9 d5 w# g9 w; v" atcpublishalias_cleanup.exe
! o5 |' h) s& u% F. f2 ?8 Htcpublishzip_cleanup.exe
5 {" v4 c. N/ n. Itcserver.exe
$ q9 }8 H8 q) G  z) X1 _/ s% Oaie_clean_datamodel_objs.exe
# A9 J5 K$ z; |* |: ~aie_batch_import.exe6 _5 }# p. n: {0 U5 D
tcxml_clean_bomwin_records.exe% o$ Z8 L4 N# U4 s
tcxml_confirm_export.exe
! P7 U2 D8 A  A6 ^/ ~& n- `8 d) |tcxml_export.exe
3 D* M& ?! V3 r- Utcxml_gsid_verify.exe- K1 r6 L% @! U" N0 N* F
tcxml_import.exe
3 U6 Z6 D0 L* v' u4 c6 p0 mtcxml_import_validate.exe# c- }6 A7 r0 k" L& w& X
tcxml_validate.exe) p* A) Z* a: O& v  b) N; T4 m
tcxml_xfer_ownership.exe" Z' I4 a. z( F& ^5 A( d& p0 r! I: C
aie_batch_export.exe, t- y3 ~7 @5 q) z3 k
add_stx_templates.exe
' ^5 C+ F2 b& x2 ?tc_config_attr_mapping.exe
$ e/ _; c) Y* E9 V. Q+ `+ Eupgrade_vendor_preferences.exe
  a/ D; o1 i4 e$ m0 Dadd_specmgr_templates.exe0 s2 N4 V  q# @$ t
tc_erp_schema.exe
% d/ h4 D+ @9 q/ l8 f6 y. O2 Yadd_se_templates.exe
, ~6 }! E$ S" S& V+ O* ^4 Z' Ftc_mail_smtp.exe1 A# W# \' q$ S: Y
tc_nxclone_postprocess.exe
0 x$ G# H, ~2 ]$ c8 n$ I) Dtc_service.exe7 k. s0 Q/ v4 o* f' j9 l4 h( Z' p; T
tc_set_query_where_run.exe
5 u1 D+ g# W# Stc_strings.exe
+ E1 O7 M) h5 x0 }) Y% F+ i) Jadd_req_templates.exe
5 c- O" I, R/ r# E$ P% Y$ Uadd_mso_templates.exe/ o- a7 K5 d. E' Y8 a* L) Q
add_mds_templates.exe% k7 a- x0 I" x# U  J" [
tc_workflow_postprocess.exe' h* ]. N! ~* B
tess_server.exe
( d9 A& H* q' i2 a" M, E3 htest_req_import_export.exe+ v7 A* _* V: {) A
tracelink_migration_utility.exe
) Y3 A4 ~" O, P6 ~" r  }( y& Ttransfermode_purifier.exe
9 v$ ^) l7 W5 D) Yadd_gcs_occurrence_type.exe! @( N- E9 }1 q7 n
twp_test.exe" N" ]0 i$ ?8 J& {
upgrade_vendor_part.exe1 |, U2 M, S, \: \& m! l
upgrade_variants.exe
( h$ \) Y6 m# x/ f% h0 Y7 Radd_ecad_templates.exe
9 V2 m3 ]4 v. t, p. J+ p+ r" bunflatten_vla.exe
& e7 h' ?! I3 v1 Tuniq.exe
( W, a4 i* x6 S) dunmigrate_from_hsm.exe5 f7 }# M4 E: a. b
unzip.exe
7 n; e& z, ]- Z$ ^2 |update_adssourcedocref.exe4 V! V$ K- V/ h3 I( D
update_apprpathroot.exe3 f. }1 Y$ p3 e0 s( \9 h2 s
update_audit_pref.exe
& u7 Z& G1 W. Supdate_bomchanges.exe! n  {. F0 j* f1 j, n
update_class_property.exe
9 z- z/ s: K2 Y) v# hupdate_condition_on_modelobjects.exe
4 I+ y1 z3 O( |0 I1 b8 ~6 Uupdate_contracttypedref.exe) \( P7 T  ?! s+ f; w
update_gde_types.exe
6 X3 E) X- Z$ u+ Xupdate_isabstract_catagory.exe
( m! k3 p# d) ^8 G* v- E$ S3 iupdate_locationcode_from_owningorg.exe3 K- A0 c7 |3 [5 V
update_loggeddatetogmt.exe
, e2 i3 ?5 i) B4 j  `update_objecttype.exe
2 J/ `- C5 g4 ^8 s& k' J8 Nupdate_project_bom.exe
, n6 p$ m+ h0 ~9 y7 aupdate_project_data.exe' k9 {* E9 _. H0 ?
add_dm_template.exe: E" c) Q$ E; W! w9 z0 ?! w7 ^
upgrade_am.exe
+ q) R0 x: F$ U7 d  g$ lupgrade_ar.exe" ]) E4 q5 y5 j9 s6 J
upgrade_long.exe8 h, k; [" f7 s8 W/ B, X
upgrade_nx_cam_templates.exe
' ^2 Z# B1 S3 ?upgrade_pals.exe5 y  C; u9 A; c1 a) a  L; [
upgrade_parenttypefororphanelements.exe
, ~. C/ F% A  b( |2 r. Xupgrade_validation_objects.exe
" N& E& \" a; D! J( u( ^& g6 Pupgrade_productview.exe9 }: h! b5 B4 E' E7 J7 A
upgrade_rev_rules.exe
4 J1 u. x1 ^" d& g2 C( P" mada_util.exe
/ ~% Y$ w; e# a; ?7 g  w( Iupgrade_schedule_objects.exe
) d. q: H4 U" c9 b; g( T0 h" ~upgrade_to_group_hierarchy.exe
" L* f2 L7 }; t4 I6 K, x9 ~% b* V, Vupgrade_types.exe
; N5 i) S( f6 Y* [! W" A5 t
全部回复6
发表于 2014-11-25 21:58:29 | 显示全部楼层
it's so cool
发表于 2015-2-3 14:38:16 | 显示全部楼层
一定学习,太有帮助了
发表于 2015-6-18 22:05:08 | 显示全部楼层
支持大师,学习了
发表于 2016-6-19 16:29:49 | 显示全部楼层
很好,很强大
发表于 2019-6-13 12:37:34 | 显示全部楼层
看来离毕业还远得很
