[资料] NX12 废弃的建模功能,注意看看哦,开发能避免就避免了
2018-6-18 18:01:36 2281 0
发表于 2018-6-18 18:01:36 | 显示全部楼层 |阅读模式
4 m1 g2 x& O" ^( S7 Z( ~# T7 R# XCommands being retired in NX 12
/ ^9 T6 J8 Q- Z: XThe following commands have been dropped from the product line in NX 12 and are no longer: F# s! U" B: J
available:8 o& k$ R; F) K& N+ t4 x! M" K
• Emboss Sheet. J2 M6 r6 c$ V" ^0 H# B" X
• Move Defining Point0 p. @9 A4 ]7 H; K
• Move Pole
1 V' v- N$ Y) }: w• Isoparametric Trim/Divide2 y  D; w% [- z6 ~+ Q* G
8 ?' c7 h) f' {1 ^
Commands to be retired in a future release of NX& v7 T( I4 a  X2 V, \
The following commands will be retired in a future release of NX and are now hidden so that
  n+ x3 @( Y, y0 G6 |  G& KCommand Finder will no longer list them.
0 t3 V; A- o2 ~8 u$ o  p• Join Curve$ @5 i/ J8 H- f5 S+ Z% O) P$ g
• StreTCh Curve
7 `8 ?7 Z+ u9 y% Y$ C* f% S4 V/ D• Fillet Sheet& ~: D. G# k2 n- Y8 J& Y+ y  n
• Spline—It is recommended to use Studio Spline or Fit Curve, Type = Fit Spline instead of the legacy Spline command.. Z7 Q+ G% Q6 s1 b3 Z: w
; I5 f6 f" S2 \. l/ T5 o- a+ w! G. \& fThese commands are hidden in the menu bar menu and removed from any ribbon, toolbar, shortcut4 X  k% ]( |; k% o
menu, and radial toolbar. Until they are retired, these commands can be broUGht back into NX using2 c, r; Y, c# g5 M, C& [  `9 T1 c
the Customize command, where they will appear with “(to be retired)” appended to their names./ C( x( R5 G! C
; E& V5 B, `3 T, i4 g2 G
