【Aras二次开发】如何添加确实的命名空间
2018-8-1 14:05:15 2361 0
发表于 2018-8-1 14:05:15 | 显示全部楼层 |阅读模式
, F+ C8 u4 U* B* z1 [$ b9 {
( c" {/ v4 d2 Q4 H: R; n
. r5 e& g1 W4 z  g0 \# |6 ZTechnique  + \6 M% ~; N+ ?& u# J
Edit the method-config.xml file located in the Server folder for the Aras Innovator 3 R3 X! H) O$ z( Z/ e8 _  g
install.  Search for the  <Template>  tag for the language you are using and include any 4 R) q6 I7 N2 ~- `. T" Z
additional namespaces you need by adding additional "using" lines.
) J# C6 \; S0 m2 ]& Z% `<Template name="CSharp" line_number_offset="19">
; o: K. o  A" W4 e & v; U$ `7 m+ w$ X
using System.Text; ( R( O+ _$ Y7 p$ k
; ^0 i( `+ {5 y
// Now you can use the System.Text.UTF8Encoding method in your Method. $ y6 Z3 c/ T; z( e' X9 E& u2 C
byte[] info = new UTF8Encoding(true).GetBytes(this.dom.InnerXml);  : g; t; E: u! l  R0 s+ d' G) p
" m$ J. k7 _# i8 z, \. \
