[安装] 关闭teamcenter两层2-tier启动时候CORBA IMR窗口的方法
2020-2-8 09:55:18 1706 0
发表于 2020-2-8 09:55:18 | 显示全部楼层 |阅读模式
$ r, h$ x3 {3 I- ^. y3 _8 A1 i
关闭Teamcenter两层2-tier启动时候TAO窗口的方法
& n9 a- W# B- H9 X* k  C) k+ @" e( ~! o  o# _4 ?5 |
If you start NX in a Teamcenter two-tier environment from a command prompt (not launched from the Teamcenter client), then it starts a command prompt window to start the CORBA IMR Services, which is where the TCserver process is started.
! L; ~, Z- \/ V/ g7 R
4 I! t+ i! e! f. u' L- Q
0 G7 ^" s0 Z' i7 Q
You can turn off the command prompt window by setting the following:
  • UGII_APISERVER_WINDOW_STARTUP=NOWINDOW
    1 M+ u9 t" l7 W- y6 E" R
Or you can start the window minimized by setting the following:
  • UGII_APISERVER_WINDOW_STARTUP=MIN
    9 D* W5 s1 `3 a2 H+ m) t4 q9 O
/ H: W5 D; Y8 x( C/ t5 q; r
