' H% Q! H$ E( Y; c
+ ^0 `& r' R3 M$ j" w6 c4 c
$ n( o. Z# j6 A% \
[mw_shl_code=bash,true]Start an NX command shell and set the following variables:
6 ~+ W7 t2 u6 `- C7 r
7 C! K$ N9 ~: S" b/ \8 f; ~ set FMS_HOME=<path to TCcs>% S) o* R6 \. {) S7 O6 B
set UGII_UGMGR_COMMUNICATION=HTTP q. {# P$ S! S2 A. o G0 a
set UGII_UGMGR_HTTP_URL=http://<servername>:<port>/path+ f8 O, a2 ]$ F; L2 K9 G7 K# R
* f: t9 |% w, {: e- uIf you are unsure of the URL run the Configuration Manager in TEM to perform 4 z: }2 ?, P/ }5 h0 s c
maintenance on your existing 4-tier configuration. Choose Modify 4-tier
8 U: U* A5 x. K5 \, o4 q6 Gserver settings to list the URI of the server. Enter this path for the
; Q8 g$ n, F4 v1 {variable.! t* T0 E/ U1 o- d* Y/ Z
G& b" L+ x- z( v8 U5 POptional: At this point you can verify that NX starts and is communicating
8 m# r5 m2 o. p; t( D( t- Owith TC by entering the following command: ugraf -pim=yes -u=<username>
, I9 I6 c8 R7 {% e; z-p=<password> -g=<group>. Close the NX session.4 M2 h/ v9 Z: r* X. C
& {, j& g) x# r" P* h* YTo execute the ugtopv command you can either set the PVTRANSUI_DIR as per the
8 a. I/ ?% T% s; N, eugii_env_ug.dat, or change your directory to the pvtrans directory prior to
! _7 q4 I4 L4 Z5 C5 B! Q" e* Brunning the command.
( T* a+ Q4 |. a) t! [: [* Y( o1 D& ]+ z+ y! x$ Q, c
set PVTRANSUI_DIR=%UGII_BASE_DIR%\pvtrans ^8 a4 r6 X( }- O9 t
+ M( Q$ e2 z. U' @5 E7 B" U6 HFinally, enter the ugtopv command: ugtopv @DB/<item>/<rev> -pim=yes -u -p -g[/mw_shl_code]0 a" C; }! y: M, U1 a2 h
