查看: 1968|回复: 0
[二次开发源码] NX加工CAM二次开发源码分享: 选择一个加工程式
发表于 2021-6-5 22:31:07 | 显示全部楼层 |阅读模式
# R7 m$ a* N- B; @# [
NX加工CAM二次开发源码分享: 选择一个加工程式" D( g9 J# {, r4 t3 b
  m. F: ^1 [% q4 U0 r9 E注意MaskTriple 的设置即可 0 P$ [. x! ~. W, G" O
+ g* ]8 D3 g) d$ y/ I; g& F: i public static Operation select_an_operation(string prompt)9 ~9 U+ t' ~, E7 d, z
8 U, \8 d, W1 u- p0 u/ C1 l; m9 V        TaggedObject selobj = null;
; y% M0 h7 I/ q/ X) w9 g        Point3d cursor = default(Point3d);
5 n5 X$ f. a9 i" Y4 o/ t        Selection.MaskTriple[] ops =8 f' ]& i6 L# I+ J4 d! j3 x, T* @3 R
            { new Selection.MaskTriple(UFConstants.UF_machining_operation_type, + z# P2 h7 r" O0 g0 Q; }
                UFConstants.UF_all_subtype, 0) };
/ y& C' S, ~; X- U  _' ~3 w+ @, x2 `" }2 Q4 h& W/ O, X
        Selection.Response resp =6 S7 {( t' V) w( D( f- h
            UI.GetUI().SelectionManager.SelectTaggedObject(prompt, "Select an Operation",+ ?6 H$ S$ @5 _; y3 [
            Selection.SelectionScope.WorkPart,/ P0 i! j$ u  c5 J' Y
            Selection.SelectionAction.ClearAndEnableSpecific,  O4 q/ i4 R3 j
            false, false, ops, out selobj, out cursor);8 O4 P+ v0 D% g5 W# E2 [( d3 ]- H
6 C2 W+ d9 V& P) \# ~/ y+ j. x/ Z        return (Operation)selobj;
3 e# q. o# J1 {" c# E5 r        }
0 U# U# }' O0 W+ O+ \9 {3 r6 w  U' V9 Y+ Z) l, d
