[TC问题解决方案] 148. teamcenter导出和导入整个组织架构orgnization的方法
2018-3-13 17:40:37 3166 0
发表于 2018-3-13 17:40:37 | 显示全部楼层 |阅读模式
You can export Organization via TEM6 N4 [% n1 K0 r6 l' g
Step 1: Launch TEM9 F9 k  N4 u7 a! n
Step 2: Select "Perform maintenance on an existing configuration"
- b7 I2 S3 \/ f+ K: bStep 3: Select your TC version, then select Next button ( R8 |6 b! m; D& K/ ?3 C+ [
Step 4: Select "Manage Administration Data"
+ y0 t7 O; G! q  gStep 5: Under "Export Administration Data", Select "Full export", and then
1 J7 m4 x- {* J; w( [click next
! |- M4 [, P2 _1 U2 X4 VStep 6: In "Full Administration Data Export", select Organization, and click ' t# j% U5 T( Q1 K* {3 Y( x
next
% E( ~% f# g9 \' VStep 7: Enter DBA userid and password& u# A- Y3 h) b" ]( i3 z
Step 8: Logs will include the location of administration_data.zip file7 w6 r3 H$ ^) f+ i8 q3 ?: G
+ I( ]. S6 Y+ Q: c
. ?2 C7 b7 [' t1 e0 v
For Import the organization in another system.
/ c& Y8 v; ?* s8 uRepute Step 1 to 4! [1 U, v; V9 e, M4 @5 ~. x
Step 5: Under Import Administration Data select "Import" (it is recommended to
+ h4 b! _* a' K' v' w7 Y: Uunselect "ignore package validation")
+ k: y# F% L# bStep 6: Select the zip file what was created during the Export of organization.
5 G1 z5 r; D6 a" x7 b1 f4 w+ MStep 7: Select one of the Merge options., `+ K$ O, C, K8 ?! s
Step 8: Enter DBA userid and password, click next" x) D/ i7 n3 {1 D5 \" X( R* _
Step 9: Start the process
1 G1 B; ]$ E) L) Z9 v
