[TC问题解决方案] 149. 如何更改TC_DATA指向
2018-3-13 17:47:15 2652 0
发表于 2018-3-13 17:47:15 | 显示全部楼层 |阅读模式
$ I9 ~7 C' y, |# Y/ t
' q, w: H$ l, P0 r8 M9 x5 ?4 U4 I  h& ~
) W1 ^  R5 l. |- T
The best option is to change this value throUGh the Teamcenter Environment
8 c& l1 O. Z0 B  I3 FManager (TEM).
2 O7 V6 `# [# P* Q. R
9 t: r* u. m. }# U7 W0 K1. Launch TEM (%TC_ROOT%\install\tem.bat)6 w, J% y7 F) h( j
2. Select "Configuration Manager" --> Next
7 d4 J5 y8 Q2 t" o! T  O( b3. Now, select, "Perform Maintenance on an existing configuration" --> Next/ d  J: l  a# S; ~2 x: l
4. Next5 K  E8 i! e9 d; L6 l! y# u
5. Select, "Modify 2-tier Server Settings" --> Next  J' \6 H  U8 @' R8 I* H1 O
6. Replace the existing TC_DATA directory with the new one.2 J1 n0 m. b; n7 [, g* G
) w) ^" \4 U" [
