Catia V5R26 CAA二次开发 Rade,CAA下载分享
2018-10-12 07:27:27 22507 92
发表于 2018-4-9 12:20:06 | 显示全部楼层 |阅读模式
( `% |. h. ?$ H0 S0 ^, M. d6 _/ `5 h% Z8 @
  i3 N) `7 m/ D9 B 捕获.PNG
/ Y* v6 `6 H* j, v/ o2 ~* b6 K' Y' G; |4 Q* J/ z2 Y, g+ N
5 q- v- Z; x1 W" f, o& k) q
2 ^' P0 O$ T; Z2 ~3 E
& I$ \  x8 v! S- g2 K5 e
* x- E! p9 O& [; T. m
许可证联系 QQ  939801026, 200RMB, 本人也是买的!!' ?- V4 Y2 s1 n! I. N
9 K' G3 d1 U/ C
; C/ Q. G7 m9 @6 c5 G2 @
; z8 r3 H# P0 R2 T+ r
全部回复93
 楼主| 发表于 2018-4-9 21:23:02 | 显示全部楼层
安装方法
# w0 d* b% y- F. Q( @3 n5 p% @) ?6 B: j" G5 I1 R2 C
7. Install VS 2012$ T4 i5 s7 `1 h% D- \
( G: n  W+ @/ C8. Install VS 2012 SP4
4 Q  r6 g9 N1 e2 X" r8 ?
  O' w, \: y) [! o$ k/ q9. Install R25 RADE- w& j1 I! |, Z+ K
) |2 X; M' H# i' y4 f8 ^( e' Q% S--> Use a path without any spaces; for example C:\ProgramFiles\DS\B25RADE
& c& [, A  F/ Y/ M9 b/ |$ ]/ @- ~! M8 L; F9 e3 ~- \: x- W
--> For the environment, the suggested default path is OK but creat the directory first. It does not seem to be built automatically.
( n/ G7 j% t4 `# h4 r) l
  A8 S0 [/ h. B" O1 d3 v10. Run the program C:\ProgramFiles\DS\B25RADE\intel_a\code\bin\3DSOpenNativeAppExt2012.vsix
- T% L# @8 ?% T- c
+ _3 Q) f) D0 y7 x9 n% K--> Install the application7 ~  p8 ?. X  ?& W& Z' m
% t) c; f2 h% l11. Run the program  C:\ProgramFiles\DS\B25RADE\intel_a\code\bin\CATVBTSetup.exe- G; @6 @5 U8 @% S- F
" w; r5 J# C1 e: k" Q$ ~
--> Click the check box for IBM/Rational tools
9 t5 H! O; k+ R7 ^& ?* W
: ]7 t- `, v1 U& A$ z$ f--> Select all the options
0 f1 e  G  Z) K# M, `. Z4 L( z
/ Q; e0 A3 x3 n- e: a9 \, X0 `--> Go
5 w' [5 N7 |4 z3 G, ~6 }! ?! C) Z9 \: C- |9 Q0 U) h' \
12. Start Visual Studio 2012
& l1 o  Z5 r- v+ P; s' p# ?  `+ n# @6 n3 ^4 }* V3 @/ B7 _9 v3 Z
--> The options panel should be displayed
- b% k' e5 J5 B8 J+ \/ L+ l  D* I) |1 D, k/ s& }8 T2 O( V
--> Enter the path to tck_init.bat which should be C:\ProgramFiles\DS\B25RADE\intel_a\code\command\tck_init.bat
; b4 r8 i1 _$ V1 _9 z* r. |+ F0 O! T$ y; _% X6 |+ c6 o6 p' s8 m, r* I; w
13. Restart Visual Studio 2012/ t4 k2 O7 J+ p! Q
4 n/ s# `) U/ ]/ G7 u
--> The tools should now be available.   a5 n5 Q. c% L6 [* G( b
发表于 2018-4-11 06:07:55 | 显示全部楼层
有这个资源吗2 R4 s4 I2 q5 M, ?5 s1 x
我的第一个程序运行成功了,但是显示不正常
发表于 2018-6-3 12:42:53 | 显示全部楼层
GOODBOY,I LOOK AT YOU
发表于 2018-6-13 16:27:41 | 显示全部楼层
R26 caa都出来了?
发表于 2018-8-27 08:44:09 | 显示全部楼层
回复看看是什么
发表于 2018-10-12 07:27:27 | 显示全部楼层
就是它最新版了
