[交作业] 20150404第一节课作业
2015-4-10 20:55:38 2582 1
发表于 2015-4-10 14:09:07 | 显示全部楼层 |阅读模式
extern DllExport void ufcre( char *param, int *returnCode, int rlen )( v5 t. h7 ~. @
{  F2 e  c1 Q0 I, }/ f* p
    /* Initialize the API environment */; j: y7 r) S) S( m" o, X
    if( UF_CALL(UF_initialize()) ) " K. D- f$ f% d; Q5 |8 e: J& U
0 {! r8 n: ~7 U9 I        /* Failed to initialize */
1 I. Q  h  V+ t& I& f        return;
! C- Q5 }  q% k1 i) G9 H+ q    }: @' y  |8 O7 o  }5 G4 p% g
/* TODO: Add your application code here */
3 l- S% n5 j* m% K) y7 n! [& {        uc1601("新建部件文件规则:PlmhomeXXXXXX(Plmhome000000)",1);
; G* G9 h1 _) W- e' `1 `- R8 l
. Y  f$ z  X- A2 ?     /* Terminate the API environment */4 j( s( _* z, w
      UF_CALL(UF_terminate());
2 M+ U( X4 A1 w" ?( ^* a  q& u8 J* y}' V( T% ?5 ^! @$ s8 q% a
评分
参与人数 1PLM币 +3 收起 理由
mildcat + 3
查看全部评分
