[TC问题解决方案] 97. 如何解决NX 继承报错: Router error: Cannot connect to or start t...
2015-11-5 14:18:04 7525 0
发表于 2015-11-5 14:18:04 | 显示全部楼层 |阅读模式
- h& U: Z+ J6 ?. _' T9 Z. h& E# Y4 y- c7 |1 T) q: m
* t8 W) {& S! I" _+ e; }97. 如何解决NX 继承报错: Router error: Cannot connect to or start the application' M$ u( i' F  Z0 e3 X5 d
UG/Manager V27.0"
0 ?# \3 b$ R" i! t7 i& `9 V- g6 Q. B
0 [0 Z( `3 P3 d8 b1 g* J2 x
& z2 L% S5 v; C5 u! o6 z
5 L  ^! ~* y, J2 T. H
3 Q+ g: q. T7 L$ o1 n# ESymptom+ t+ c7 H" q* O+ @) O0 T. y! k
9 E6 q, F( a2 g& c) `0 W( Y5 aHow can you resolve “Router error: Cannot connect to or start the application
9 _7 V8 d8 d7 s- ?6 uUG/Manager V27.0"1 ~4 n' F, x8 Q
, N8 n* z0 v% t9 G/ b
+ j1 M" j; O: V: E- }7 {9 w5 J6 H
The problem was found to be in /ugs/installed_programs.dat which has the9 s! @& b" C7 b- c2 _% L$ S
following entry for NX9:" j( n- ]1 I& W/ z0 R/ _
: r3 {- w' F, _4 ]6 u6 M
0 ]+ {0 a- _' z3 s& z2 A
[HKEY_LOCAL_MACHINE\Software\Unigraphics Solutions\Installed Applications]; |# ]0 @1 c# n" W, a" ~
"Unigraphics V27"="/appls/ugs090/ugii/ugii"* X- g: J. V$ F9 s  M1 B% w
$ x) F9 }" A( K; ?1 c1 Q
! M# _3 W  M2 G
It should have been " Unigraphics V27.0"
3 _8 U7 _7 T' a) [Hardware/Software Configuration- b8 v" p9 w) |% F# b& ?8 P' E
SuSE Linux 11.1
6 {3 z( h, G9 Q) xTC10.1.4
& g% q. q* n. f1 J* d% fNX9.0.3
' ]( l! W0 U) BSolution
) o8 N2 H5 L+ c& n( s  SEdit /ugs/installed_programs.dat, add .0 to "Unigraphics V27"( \$ v+ Y/ F3 r" }& I+ @% b5 c8 Y
It should look like example below:
- ]/ d0 {2 n) \' a6 i9 Y3 [' K7 N, y0 \" N6 M. D
( }: T# O' s- H8 v
[HKEY_LOCAL_MACHINE\Software\Unigraphics Solutions\Installed Applications]4 a, G& t" L) H% t1 d- O9 l9 \
"Unigraphics V27.0"="/appls/ugs090/ugii/ugii"- s$ ^5 |2 V- d6 \
* b  i; {& x0 G2 ]0 k' c3 Y
