[TC问题解决方案] 98.如何修改teamcenter启动时候的画面?
2015-11-5 14:52:06 3894 0
发表于 2015-11-5 14:52:06 | 显示全部楼层 |阅读模式
: j: ~9 y/ f" {% H8 _' h- l
98.如何修改Teamcenter启动时候的画面?
, `$ o0 ]  g* T% c3 y! H5 ZSymptom1 S1 f& k4 G. t$ |
" f- w: i4 K  f8 J/ X  NHow do I change the splash screen for Rich Client (RAC)?
$ g- P5 W6 z  h0 S) dHardware/Software Configuration
- S9 R! g& S# N; V, QFamily: TEAMCENTER
- Q$ h1 ]& d1 J, p5 d$ wApplication: CORE_FUNCTIONS4 w1 Z$ Z  d+ s
Function: ITEMS( h3 W5 v4 [4 J) {" \  ~/ {
Subfunction:
' v, H) B% t" I0 L' pRelease: V10.1.4.0" s* S5 [9 _4 ~& G4 N
Solution3 M/ S% V$ P8 Y2 F! Q  K
The splash screen bitmap is controlled by line:9 A$ Y6 t( A( U9 E* o
7 q" f+ g9 I7 ]- v
6 l3 u. c# X$ f1 U9 @$ Vosgi.splashPath=platform\:/base/plUGins/com.teamcenter.rac.aifrcp) F3 H6 }- T9 e
0 q' R4 i& ^1 {1 ~
$ }1 _# y: B) lin the %TC_ROOT%\portal\configuration\config.ini file.% d0 a7 ~* b+ V/ _2 {
' ^, o+ H* e% Q
; H- `. c9 V$ L! V3 f
You can update the splash.bmp file in
- d6 a" R0 U. I. a3 aportal/plugins/com.teamcenter.rac.aifrcp_<version>.jar or update the . p" v0 e: Y. }4 `
config.ini to point to your own .jar that that contains a splash.bmp file.  x7 e' h* s) h& z/ d8 q0 L  P
! H* n. Y/ S/ Z' U
