PROBLEM:, H* I& k7 I4 ~
- M3 o9 w" I# @$ L2 K
Java 7 update breaks the NX9.0, NX8.5 and NX8.0 NX Documentation search& M# E3 `; x. X% }# K9 l
function.. B0 d s) P% h+ X% X8 L1 p" ~
; V( Z8 S1 m" k' X
REMEDY:
& L/ @3 q. I7 N, s
! e0 X8 M. _% M" K' o9 y& V6 h) @ The provided UGDOC fix has been developed for Java 7 Update 65 and 67- Z/ B3 D( F; S$ s5 y
with NX9.0 UGDOC, NX8.5 UGDOC and NX8.0 UGDOC.
! N; {! J3 X2 V w' B . S2 D: M. ~, g) Z6 m0 c
To verify the installed Java version:9 A% z; L. T7 O- _0 U" \
. c2 O S. n" Y& s! J/ N1 p
Open Control Panel . F' E( e4 \: O
Set 'View By:' to either 'Small Icon' or 'Large Icon'. \7 ]6 _" R' G) E
Select 'Programs and Features'- C$ u6 b2 {9 _6 B* B- r8 e3 w
) x) S, H& A0 o! {; d1 B+ q In the list of installed products, look for Java entries:
* S V" E% R7 ~; N2 y, C+ K , j1 P4 U! z9 Y
Java 7 Update 65 or 67: i6 ?- g3 Z! S; C) I. g! y
Java 7 Update 65 or 67 (64-bit)$ y7 ?( J, K1 r( F$ Q
) k4 k! e3 s$ k: M7 p, q
If the Java installation is different than those listed above, please
6 \& y1 c1 X: l& A! Z+ @ remove the older Java versions and install Java 7 Update 67 from the
1 W, l6 N8 _ b6 T: R' `4 t2 f: L) f following link:5 ~, e( U; m7 [! U2 q
1 V/ F2 U5 T( C http://www.java.com/en/download/manual.jsp3 y. S/ Z# Y& n% H
1 Q! U- Q @, b7 N9 a" E, H6 ]* K ===========================================================================
0 O+ A4 b* \; M/ I8 m0 W
) L: \& V- b4 `4 l7 H5 F 1. Log on to the GTAC Web site at:7 }- n& L+ k% n3 K o7 \
# O8 d/ k3 e) H: Z! g
http://support.industrysoftware.automation.siemens.com/gtac.shtml
- l5 `$ @1 E# A: o4 \ ; W) Z1 g+ Q# W& I9 X1 } \; n
2. Select 'Download and Upload files'.
/ Q2 }5 R* B( i( ^/ Q% l5 c9 @
% Y2 \; f" p$ Y$ [. d; D( h 3. Select 'Download files'. $ [: S" @ Q4 G. h. M/ n
. c4 J* h% K7 |' @ k 4. Login with your WebKey account., o0 D2 L( U$ x7 r# ~/ |) J
0 V: }+ n3 a3 R5 J3 z
5. On the 'Product Updates' row, select the pull down menu and ' R* D, _! u6 W. f9 ]" e
use 'NX/Unigraphics NX'8 ]% ]- Q$ t' [0 s& j
6 X" ]# z& l4 u" e4 B: Q 6. Select 'ugdoc'.
8 Y$ Z( T4 e) B; F! F+ Y `
6 E1 D1 {; o5 Z1 c0 e 6 {7 w( v- i0 ?. P
NOTE: - {8 p5 h s$ A3 D
3 g5 S* o! S6 ?+ U A9 k1 ^
There are different sections for NX9.0, NX8.5 and NX8.0.
. P! }3 ]% g# y3 X1 y( ^, } Please read the appropriate section.
! j1 A# r/ R" c+ D
h4 C! K+ H! I9 Y/ M) z/ r5 A ====================================
3 V$ X9 U' ]$ f For NX9.0 and Java 7 Update 65 or 67
) A* ^7 `! }# F% b! I1 X ====================================8 V6 e# {1 Q1 r
9 B. _2 J3 u9 G4 V3 I. g5 _( c
1. Select 'nx9'& V1 y9 V$ p; u* Y
4 j+ w) ~$ g" T0 k' W
2. Select 'qagent'1 I; S% q+ _0 t4 M8 k
% `' O; M: Z; {0 l, i1 L
3. Download nx85_nx9_java7_u65_u67.zip.
" o* x& n3 o% p: W( d) S* O* a
2 v3 B! y5 w/ R# ? 4. Close all browser windows.
9 Z* o. ?! {" v8 H
9 \& f0 h$ D5 o3 V2 B7 L, V 5. Extract the content of nx85_nx9_java7_u65_u67.zip to a
7 @' `% t C; r temporary location. H9 T8 } v' V* I# q' h
9 f* l- {. A4 h. O7 ]' {) G
Copy the content to the following locations:
+ p; m: z! F6 v, S% u) D( p8 R2 k " J' t# `% z9 {, t
- C:\Program Files\Siemens\NX 9.0\UGDOC\html_files\nx_help\
( P6 s) |6 V7 [, | R+ i - C:\Program Files\Siemens\NX 9.0\REL_INFO\release_notes\english
k# t. r$ y' R - C:\Program Files\Siemens\NX 9.0\REL_INFO\whatsnew\english- u% G( y8 G2 Y/ M/ @# v# u; L
! B3 S; a J4 b8 b 6. If the NX API Manuals are installed, complete the following:
0 ]4 [& ~8 o% L: O5 _9 C5 S' b
/ _2 Q' n8 @( u: r' d Copy the extracted content to the following locations:& ~# Q# d( r2 q0 O5 M8 ^
/ E8 P$ q5 N' v% a - C:\Program Files\Siemens\NX 9.0\UGDOC\html_files\nx_api\
4 M- _! @) B% o9 s& [( [, }( g3 x / a2 E6 @4 }; t( f, r& N+ U" E
2 r0 y( `: N6 S6 Z% W* h! h5 ~1 p
====================================) P, k' U( R( [6 r: S
For NX8.5 and Java 7 Update 65 or 67
) a X4 _ R: N' Y8 T% A, F9 V" d% Y ====================================
1 A: U) m" d% t0 U: u$ Z! r
2 J9 x( [: U! \- L9 C 1. Select 'nx85'.
1 }) d1 ]0 K3 h- a9 A
; T$ g) [ f0 S: R# N ~( j 2. Select 'qagent'3 k- v F; C% O; F3 j3 g
1 b, ?. U A) G/ N$ F5 u0 p) x( ]
3. Download nx85_nx9_java7_u65_u67.zip.; ?" ^% ~% }% h4 }
# i% w2 M; C7 g! V w+ b
4. Close all browser windows.- Z; M) L0 ~4 B# q8 O6 C) p1 {
5 o% }1 _; g; K7 `7 f
5. Extract the content of nx85_nx9_java7_u65_u67.zip to a7 v; k$ {4 v; ~5 q! ?
temporary location.
. A. a( w2 n% q ) l0 H- t/ E5 c2 y p" l# A' x- Q
% D5 T/ `6 ~" g+ r9 [2 g) o8 ] ! [; o6 R2 E3 M4 Y! a. M1 T
- C:\Program Files\Siemens\NX 8.5\UGDOC\html_files\nx_help\
6 }, K( m/ n7 x - C:\Program Files\Siemens\NX 8.5\REL_INFO\release_notes\english
5 p9 z; ]% C" \, h! G+ v - C:\Program Files\Siemens\NX 8.5\REL_INFO\whatsnew\english
! e( M/ A2 W: h$ p# `, k0 M- a+ x 1 U0 H' A- |. ? B8 {
6. If the NX API Manuals are installed, complete the following:0 Z }# j" z) l& ?, T% ]
2 S& D* m* O3 p6 I+ L4 L( P
% M% q* i: e7 ^7 y- F8 F9 M# o5 h 8 ?( X" g1 e& ]0 v, P5 H: |
- C:\Program Files\Siemens\NX 8.5\UGDOC\html_files\nx_api\
; C l# o7 ^+ p- d" w8 t2 ] K
! R! V2 {3 {$ g; M" F& ~0 G$ O * e- j' F! C8 K5 d; A) R( j" ^% g2 G9 x
====================================- H& y5 M6 X$ B0 I
For NX8.0 and Java 7 Update 65 or 67+ N. Q7 p3 f" ^
$ \ a9 w/ n/ `% P0 n# z4 H: o " B- e R8 }8 Q- N2 }& Y
1. Select 'nx8'
* q! R* J, C# Y! j 1 j# O! E- E; u6 W
2. Select 'qagent'; X1 Y8 F8 u8 @4 B0 J& z- [
& K- i8 G6 }, J" j% ]5 b! x
3. Download nx8_java7_u65_u67.zip.5 z/ }, `7 f# p8 f! e
5 j& j1 \- h4 y" V* U
4 d8 ^5 g: Q. f$ \$ R, s + e s9 d1 q5 T) K7 h/ B! `& D7 A: Z
5. Extract the content of nx8_java7_u65_u67.zip to a2 x# o8 R# o5 C6 }$ v
temporary location.& B: V8 u I, k6 A
7 M# Q& _( P3 A1 ]5 c9 ?; { Copy the content to the following locations:& R' k% I& T2 J# { I9 x0 u
: S1 m5 u! v. m8 ?* g7 z - C:\Program Files\Siemens\NX 8.0\UGDOC\html_files\nx_help\) }1 f. ~: D- D3 M/ A
- C:\Program Files\Siemens\NX 8.0\REL_INFO\release_notes\english
* I! @$ N- G' E4 W* l - C:\Program Files\Siemens\NX 8.0\REL_INFO\whatsnew\english |
