[资料] How to create a reusable Logic Block for Process Simulate?
2018-9-13 16:45:10 3764 1
发表于 2017-4-24 15:41:05 | 显示全部楼层 |阅读模式
2. How to create a reusable Logic Block for Process Simulate?- G6 N% }" L' k, l: O7 j( z
Symptom
' ~* p) h% C  }User has a logic block designed as a template that they wish to reuse in another study.
' s8 w+ i2 a# L' ?% C- F8 jSolution
7 r) }  o4 b# i% s* d  a* C7 }A logic block is just a resource. You can grab the cojt folder and insert it into another
2 r5 C. \/ S1 g6 `) j. @' Hstudy just like any other component. It usually includes a jt file and a gmplc.xml file for
) ?+ ?# z& b1 |/ f( W- ythe logic.( p  C- I% ?8 K4 ~
You might need to delete the tunedata.xml and run "define component type" on it, but( y; L5 s4 I' \" X. z
after that insert component will introduce it into any new study.0 g* }% o( W& ]- D9 z2 g) `9 f1 O8 X
The only thing missing will be the signals connected to the LB, which is study* U; |: N4 V4 N) h* R+ }
information, and must be reconnected manually or throUGh the Connection Mapping tool.
9 \0 q! e) d% h9 q. i" M: `
发表于 2018-9-13 16:45:10 | 显示全部楼层
????这是什么意思
