Tecnomatix 14.0 operates with Oracle Enterprise edition, versions 12.1.0.2 and 11.2.0.4.1 F# }& P0 o: Q: c. Y
4 L6 z7 z8 G; j8 F; D6 E+ YTecnomatix versions 12 and up support Oracle version 12.1.0.2 - the server version should be the same as the client.; {; d2 ~' F" z" ^! R
- C Q% @/ j% M W$ g9 F+ M
Tecnomatix versions 12.1, 12.0TR1, 12, 11.1TR1,TR2,TR3 and 11.1 support Oracle version 11.2.0.4 - the server version should be the same as the client.: q7 ]" r: s4 r8 S' H/ _9 `- z
: r; y$ u! _) U+ f3 i
Tecnomatix version 11 supports Oracle version 11.2.0.3 - the server version should be the same as the client.: E/ \/ F0 d7 k' F' N, _5 ?$ n
E) Y) P, B5 B. b/ D* g
Tecnomatix version 10 supports Oracle version 10.2.0.5, 11.1.0.7 and 11.2.0.2 - the server version should be the same as the client with the exception of Oracle server 11.2.0.2 which is only certified to work with client 11.1.0.7 (client 11.2.0.2 is also supported, thoUGh not certified by some 3rd party components used in the eMServer)./ }3 f8 O. |' T4 C; E4 A
6 ~# p7 m G( C; J4 v$ _
Note: When installing the Oracle Client for eMServer-based applications, you should select the Administrator type.
# V* Y2 ] G9 ?
c/ q7 r4 f1 x0 w. c# CTecnomatix version 9.1.2 supports Oracle version 10.2.0.4, 11.1.0.7 and 11.2.0.1 - the server version should be the same as the client with the exception of Oracle server 11.2.0.1 which is only certified to work with client 11.1.0.7 (client 11.2.0.1 is also supported, though not certified by some 3rd party components used in the eMServer). Oracle paTCh #8932174 should be installed on top of the Oracle client 10.2.0.4 in order to prevent incorrect behavior of the applications.
0 i, w, s9 ~7 x c5 ^$ j4 F3 ^
( m5 a+ l- A! l) M5 B |
