Teamcenter ITK 开发有关常用的函数集合
2013-12-3 21:12:42 7382 1
发表于 2013-12-3 21:05:56 | 显示全部楼层 |阅读模式
, A0 D. y$ ?  P) Q2 S
6 ?) @, K2 X0 I3 y) G
Teamcenter ITK 开发有关Item 和 Item revision的函数集合9 O" L% N. s& H5 D$ ?' W6 z! `
' K5 G3 ?1 a( l# _# T
% d' {8 C7 M- I9 Q* m' H
# Q2 r  q& i: E4 T
7 o4 F2 l3 E& S$ Z# }5 b+ B% J
ITEM :和Item相关的函数:$ o& M0 C4 v( a4 `3 q+ S& x' t
- o$ Q' ]9 _5 L2 C
/ O1 ^1 t6 V/ x% _+ t! ~) w0 e4 V$ Y" S
ITEM_create_item
" t1 \5 V, ~6 E- m5 J2 B% C* j0 eITEM_find_item
2 l  }% T3 R% b( z, NITEM_attach_object
5 k, a9 O; S: P  w& Q# FITEM_ask_latest_rev, @$ S- ^5 I) o4 i. s0 p, R! w
ITEM_list_all_revs' w2 t6 ~8 s% H- J8 v/ M" Q
ITEM_list_attachs_of_type
% v) G6 Z& I2 `1 e+ M5 zITEM_list_all_attachments
: Z% F# z, r, ?. xITEM_ask_id
% n6 e% n! s5 X: K, A
; a4 ~. O6 ]5 Z. Z! FItem Revision : 和Item版本相关的函数+ |( i! z% v* n8 V' C6 h, j7 v
/ M/ u# n- z% \# P, s
+ @& I8 R4 r; A7 M3 ?: r
ITEM_create_rev
4 r) G+ z  t: d( p$ O$ IITEM_ask_rev_id
, J! j$ e4 L9 b/ a2 O) RITEM_ask_item_of_rev
; q7 n& r  \4 t- I$ G3 P; HITEM_attach_rev_object: n8 Q3 I6 b6 X0 ~4 @- ?
ITEM_list_rev_attachs_of_type $ {9 C; P1 @( \
ITEM_list_all_rev_attachments ( W- E0 b" S" ~* j* Z4 }& o1 G
ITEM_rev_list_all_bom_view_revs4 j( K# d: }, w8 B
2 `+ I$ l' x  l  m, e$ X# ]8 Z
: r$ M8 S0 y- m" m( O0 W
 楼主| 发表于 2013-12-3 21:12:42 | 显示全部楼层
3 h/ J" N! ]; _- y和Form相关的函数6 y# |9 X. a) t8 g( N+ C! G
% }$ s7 ?8 B2 |1 D0 |" ?+ `3 r
! d8 Y( r0 o3 S* X! x
FORM_create" r5 U: O" R1 r5 Y( I
FORM_describe9 i) n4 E$ s  k, U3 P% [
! ^6 w% ^1 T& _/ f0 H/ j
, i% f+ N7 k, J, m5 W5 ~( j5 t
和文件夹Folder创建相关函数/ y; R9 ^+ U9 f. C5 b
. ]; Y4 l) o5 |2 c% t% n4 r/ O2 K
  1. FL_create4 r  P5 f  j$ s! ], G
  2. (const char name[WSO_name_size_c+1], const char description[WSO_desc_size_c+1], tag_t *pfolder_tag)   b& b2 G! `* R! v2 e# J
  3. ) `8 a2 K( B5 b7 r, m4 f
  4. FL_insert 5 L# Z! K0 M' U* K" F7 Y- H) Y
  5. (tag_t folder_tag, tag_t workspaceobject_tag, int position)' B! G& K; v: G3 q1 ?6 k& u
  6. : Y+ b" q+ X; g  b+ ~
  7. FL_remove
    ' k; N0 w& {. J7 d' K
  8. (tag_t folder_tag, tag_t workspaceobject_tag)2 G9 D0 C. F+ {# A
  9. * H% j4 T8 Q3 x9 W1 i
  10. FL_copy
    5 O' q' @1 z; e9 t
  11. (tag_t folder_tag, const char new_folder_name[WSO_name_size_c+1], tag_t *new_folder_tag)+ h8 k4 o7 y( R* n* f
  12. ) D' s% d, ?' ?8 S4 _1 P2 A  ]
  13. FL_ask_size
    $ B3 m. V9 P7 G" ~. C
  14. (tag_t folder_tag, int *number_of_entries), U* Q- ]& R0 f" _
  15. % l* P* V$ x' H3 m
  16. FL_user_update_newstuff_folder 7 P6 i2 U2 H2 k* J* E
  17. (tag_t folder_tag)
    ( H3 j  z" t' Y) W& L
+ u5 d: l1 e6 Z/ J
& q6 D  [# v2 ^# M" h) W% W
% _* \. C1 ^+ Y( l/ S. x$ M  N
和AOM相关的函数0 Q- s( o+ W% n5 h2 {3 l
. }6 f. n% U& r2 A- B
修改一个AOM数据对象
- e5 a0 U) l! a# B* o1. get the object                AOM_load()
. h8 ^2 [# o# N& X0 l2. lock the object                AOM_lock()
4 Q- @" q/ H, J6 p3 S: t3. change the object        AOM_set_xxx()
5 c5 Z3 w: |, _' |9 T$ {* b$ t- q4. save the object        AOM_save()/ t* o; v! A" g( P! A+ M
5. unlock the object        AOM_unlock()  ^0 o" F( |1 K7 j4 A7 X# {1 F
9 d3 U+ l' g8 p% G7 W6 [) |
0 m+ }( w4 z- j) z1 H. E, ], T创建一个AOM数据对象
( ^& [9 a& O: U. d- U1. create the object
8 T2 V. @) ]2 p$ H* }2. save the object        AOM_save()' V( A) k; E: f5 N. t' p4 H# L1 D
3. unlock the object        AOM_unlock()
! [. a, T: ~2 n9 M, p1 V8 a6 {0 I& a! {
" n6 I+ _& p1 r  D5 q7 K' [5 l
删除一个AOM数据对象" a7 A% H' r+ s  ^; f; `* ~
1. get the object                AOM_load()6 K% k/ y$ f6 [, x# H2 `
2. lock for delete         AOM_lock_for_delete()7 n* \% o5 _$ h& P3 ~5 [$ a) x
3. delete the object        AOM_delete()
* n1 ?3 d9 C# J2 A! @+ C1 s# v2 t- P& U* ]: ^0 J
) m# V6 @* B1 K, x1 U9 P- t
8 w- a$ K% k: l1 y8 a
