[资料] 谁应该使用4GD,Who should use 4GD?
2014-1-7 11:27:28 5820 1
发表于 2013-12-11 21:11:11 | 显示全部楼层 |阅读模式
4GD is intended primarily for industries with massive products such as the shipbuilding, aerospace and automotive
! w6 |4 @- a1 L& u: B6 Tindustries that have the following characteristics: 5 K# l6 V1 H1 V* }% n2 p' ~
●    The products are massive in scope, scaling to millions of components.
4 F- n: m3 L. d" ^6 W/ B, S: v●    Data needs to be organized in multiple hierarchical views without data duplication.
  K& s+ c' W5 @, j) G●    Requires many multi-disciplinary teams to collaborate and/or work in parallel.
' x  m; j3 u) k8 U2 M' Q4 [' \●    Design reuse must be facilitated, managed and controlled between product units or design models.
& Z. j7 A# o# R$ a& W7 R●    The products need to be maintained over long life cycles. 0 v% d  u8 z  e# }/ P, t
' o+ V1 |( N1 ~" k& j
3 y% H; m; ]% M6 J& _) \, T4GD is initially targeted for the shipbuilding industry in this release. Future releases plan to broaden its coverage to . C+ K. \/ N" x. }2 M/ K2 y
other industry sectors (automotive, aerospace, energy, machinery).
, @2 ?$ K& E! i/ {" E. M
8 P# L* K: n$ g+ ^
: R* H# K2 ^9 e& u5 d) s+ Z7 c
If your products do not fit these characteristics, then you should continue to use NX Assemblies to design your ) G& V8 w* A, M* `- K* P! ?
products. : `! _  ?) Z2 J) H3 {/ Z0 m
5 h1 T; Q" L/ [
版主
发表于 2014-1-7 11:27:28 | 显示全部楼层
翻译是:/ P9 l: y& }9 P7 Y! `' K* E, Z
4 gd的目的是主要针对行业巨大的产品,如造船、航空航天和汽车! E. ?  S! R$ W' ?+ V
行业具有以下特点:$ C4 F6 H0 n# Y$ v+ z/ C- z
●产品巨大的范围,扩展到数以百万计的组件。9 b* ~& ?3 l' `9 p1 \+ a. f. a
●数据需要组织在多个层次视图没有数据重复。1 i3 W* h# J$ v. S
●需要许多多学科团队协作和/或并行工作。. G- {8 O; `, {& f
●设计必须促进重用,产品单位或设计模型之间的管理和控制。& l. i) J/ f8 b# O& A
●产品需要维护长生命周期。
  g3 J. n" Q& F/ U" E
8 {4 `- X% ?( o9 K2 k) h% F4 gd最初针对这个版本的造船业。未来版本计划扩大其覆盖范围* c4 v* g* l8 h) j# Q' Z
其他行业(汽车、航空航天、能源、机械)。
" {  E; s5 }) j* z7 A  F3 X$ J8 O3 _
如果你的产品不符合这些特征,那么你应该继续使用NX总成设计
: M8 E; h2 [4 n5 ]5 z* Z. W! f产品。
