uc6460 (view source)
Defined in: uf_layout.h
Create a layout. view_names must be dimensioned to the number of views
(or greater) specified in option layout_style. If any array value of view_names
is blank, the default view for that position is used. The first view
becomes the work view. The default views are:
layout_style Default Views
1 Top
2 Front, Right
3 Top, Front
4 Top, Front, TFR-ISO, Right
5 TFR-TRI, Left, Top, Front, TFR-ISO, Right
Return Code
0 = OK
1 = View Does Not Exist
2 = Invalid View Name
12 = Invalid Layout Name
14 = Layout Already Exists
31 = Invalid Scale
32 = Invalid Scale Option
33 = Invalid Layout Style
34 = A sketch view may not exist in a layout
more than one time.
35 = Operation Not Allowed In Drafting
int uc6460
const char * layout_name,
int layout_style,
const char view_names [ ] [ UF_OBJ_NAME_BUFSIZE ] ,
int scale_option,
double scale
| const char * | layout_name | Input | Layout Name (UF_OBJ_NAME_NCHARS char max) |
| int | layout_style | Input | Layout Style 1 = Single View 2 = Side By Side 3 = Upper And Lower 4 = Four Views 5 = Six Views |
| const char | view_names [ ] [ UF_OBJ_NAME_BUFSIZE ] | Input | View Names (UF_OBJ_NAME_NCHARS char max) "" = Default Views |
| int | scale_option | Input | Scale Option 1 = Retrieve As Saved 2 = Fit All Views 3 = Apply Scale parameter To All Views |
| double | scale | Input | View Scale (If scale_option=3) |
uc6462 (view source)
Read view borders in a layout. Border values range from 0,0 (bottom-left
corner of the layout) to 1,1 (top-right corner of the layout).
Return Code
0 = OK
10 = View Not On Layout
11 = Layout Does Not Exist
19 = No Current Layout
int uc6462
const char * view_name,
double * border
| const char * | layout_name | Input | Layout Name (UF_OBJ_NAME_NCHARS char max) "" = Current Layout |
| const char * | view_name | Input | View Name (UF_OBJ_NAME_NCHARS char max) "" = Work View |
| double * | border | Output | View Borders On Layout (4 element array) [0] Left Border [1] Bottom Border [2] Right Border [3] Top Border |
uc6463 (view source)
Set view borders in a layout. The borders argument is any two diagonal
corners (X1,Y1,X2,Y2) of the view on the layout. The values range from
0,0 (bottom-left corner of the layout) to 1,1 (top-right corner of the layout).
Return Code
0 = OK
3 = Cannot Modify View On Drawing
31 = Invalid View Border
32 = Invalid Border Option
int uc6463
const int option,
const double * borders
| const int | option | Input | Border Option 0 = Use View Borders In borders parameter 1 = Reserved For Future Use |
| const double * | borders | Input | View Borders On Layout (4 element array) [0] Left Border [1] Bottom Border [2] Right Border [3] Top Border |
uc6464 (view source)
Replace view in layout. If the layout_name parameter is blank, the current
layout is updated. If the old_view_name parameter is blank, the work view is
replaced. If the new_view_name parameter is blank, the view is duplicated on
the layout. If both old_view_name and new_view_name are blank, the work
view is updated. If the work view is replaced, the new view becomes
the work view.
Return Code
0 = OK
4 = Can Not Replace View On Drawing
10 = Old View Not In Layout
19 = Drafting Layout Not Valid
23 = Current Drawing Contains Work View
more than one time.
int uc6464
const char * old_view_name,
const char * new_view_name
| const char * | old_view_name | Input | Old View Name (UF_OBJ_NAME_NCHARS char max) "" = Work View |
| const char * | new_view_name | Input | New View Name (UF_OBJ_NAME_NCHARS char max) "" = Work View |
uc6466 (view source)
Read current layout name and work view name.
int uc6466
char cr1 [ UF_OBJ_NAME_BUFSIZE ] ,
char cr2 [ UF_OBJ_NAME_BUFSIZE ]
| char | cr1 [ UF_OBJ_NAME_BUFSIZE ] | Output | Layout Name |
| char | cr2 [ UF_OBJ_NAME_BUFSIZE ] | Output | Work View Name |
uc6467 (view source)
Save the current layout. The new_name parameter is the name to use when you
save the layout. If new_name is blank, the current layout name is used. A new
layout is created if new_name specifies a new name and a layout of
that name does not exist. An error is returned if new_name specifies a
new name and a layout with that name already exists.
Return Code
0 = OK
14 = New Layout Already Exists
int uc6467
const char * new_name
| const char * | new_name | Input | Name To Save Layout (UF_OBJ_NAME_NCHARS char max) "" = Use Current Name |
uc6468 (view source)
Retrieve a layout. The view_scale parameter must be positive. In addition,
you cannot retrieve a layout if all of its views were deleted.
Return Code
0 = OK
13 = Layout Has No Views
31 = Invalid Scale
int uc6468
const int option,
const double view_scale
| const int | option | Input | Scale Option 1 = Retrieve As Saved 2 = Fit All Views 3 = Apply view_scale To All Views |
| const double | view_scale | Input | View Scale (If option=3) |
uc6469 (view source)
Delete a layout. You cannot delete the current layout, any
canned layout, or the GFEM post layout.
Return Code
0 = OK
13 = Can Not Delete Canned Layout
14 = Can Not Delete Current Layout
15 = Can Not Delete GFEM Post Layout
int uc6469
uc6470 (view source)
Rename a layout. If old_name is blank, the current layout is renamed. A
canned layout cannot be renamed.
Return Code
0 = OK
11 = Old Layout Does Not Exist
13 = Can Not Rename Canned Layout
int uc6470
const char * old_name,
| const char * | old_name | Input | Old Layout Name (UF_OBJ_NAME_NCHARS char max) "" = Current Layout |
| const char * | new_name | Input | New Layout Name (UF_OBJ_NAME_NCHARS char max) |
uc6471 (view source)
Cycle layouts in the work part. This routine cycles the displayed part and
returns one layout name per cycle. To start the cycle, set ca1 to the null
string ("") before calling uc6471. The first layout name is returned in ca1.
The next call returns the second layout name in ca1. When ca1 returns with a
blank, all layout names have been returned.
NOTE: The cycle can continue even if the layout named in ca1 is
deleted during the cycle.
Return Code
0 = OK
int uc6471
char ca1 [ UF_OBJ_NAME_BUFSIZE ]
| char | ca1 [ UF_OBJ_NAME_BUFSIZE ] | Input / Output | Layout Name On input the last layout name found. "" will start cycling. On output the next layout name found. "" will be returned when the cycle is done. |
uc6472 (view source)
Read the number of views in a layout.
Return Code
0 = OK
int uc6472
int * number_of_views
| int * | number_of_views | Output | Number Of Views In Layout |
uc6473 (view source)
This routine cycles the layout and returns one view name per cycle. To
start the cycle, set ca2 to an empty string("") before calling uc6473. The
first view name returns in ca2. The next call returns the second view name
in ca2. When ca2 returns with an empty string, all view names have been
returned.
Return Code
0 = OK
int uc6473
char * cp1,
char ca2 [ UF_OBJ_NAME_BUFSIZE ]
| char * | cp1 | Input | Layout Name (UF_OBJ_NAME_NCHARS char max) "" = Current Layout |
| char | ca2 [ UF_OBJ_NAME_BUFSIZE ] | Input / Output | View Name On input the last view name found. Pass in "" to start cycling. On output the next view name found, "" when the cycle is complete. |
