查看: 802|回复: 0
[资料] 比较全的NX二次开发入口函数定义,支持C# .net C++等
发表于 2026-5-1 16:40:09 | 显示全部楼层 |阅读模式
& \! ]; n' F# b4 H
+ x1 O, {: b- i
% b* M0 ~, f0 J0 m& }
注意启动设置环境变量 !2 V& k; }% U3 b
# f* T/ ~6 W: V( W9 R( ~
NX Event
User Exit Environment Variable
C/C++ Entry Point
.NET Entry Point (VB, C#)
Java Entry Point
Python Entry Point
Execute Custom Program (initialization)
N/A
ufusr
Main
main
main
Execute Custom Program (after init)
N/A
ufusr_ask_unload
GetUnloadOption
getUnloadOption
N/A
Unload Program
N/A
ufusr_clean_up
UnloadLibrary
onUnload
N/A
Open Part
USER_RETRIEVE
ufget
ufget
ufget
ufget
New Part
USER_CREATE
ufcre
ufcre
ufcre
ufcre
Save Part
USER_FILE
ufput
ufput
ufput
ufput
Save Part As
USER_SAVEAS
ufsvas
ufsvas
ufsvas
ufsvas
Import Part
USER_MERGE
ufmrg
ufmrg
ufmrg
ufmrg
Execute GRIP Program
USER_GRIP
ufgrp
ufgrp
ufgrp
ufgrp
Add Existing Part
USER_RCOMP
ufrcp
ufrcp
ufrcp
ufrcp
Export Part
USER_FCOMP
uffcp
uffcp
uffcp
uffcp
Component Where-used
USER_WHERE_USED
ufusd
ufusd
ufusd
ufusd
Plot File
USER_PLOT
ufplt
ufplt
ufplt
ufplt
2D Analysis Using Curves
USER_AREAPROPCRV
uf2da
uf2da
uf2da
uf2da
User Defined Symbols
USER_UDSYMBOL
ufuds
ufuds
ufuds
ufuds
Open CLSF
USER_CLS_OPEN
ufclso
ufclso
ufclso
ufclso
Save CLSF
USER_CLS_SAVE
ufclss
ufclss
ufclss
ufclss
Rename CLSF
USER_CLS_RENAME
ufclsr
ufclsr
ufclsr
ufclsr
Generate CLF
USER_CL_GEN
ufclg
ufclg
ufclg
ufclg
Postprocess CLSF
USER_POST
ufpost
ufpost
ufpost
ufpost
Create Component
USER_CCOMP
ufccp
ufccp
ufccp
ufccp
Change Displayed Part
USER_CDISP
ufcdp
ufcdp
ufcdp
ufcdp
Change Work Part
USER_CWORK
ufcwp
ufcwp
ufcwp
ufcwp
Remove Component
USER_DCOMP
ufdcp
ufdcp
ufdcp
ufdcp
Reposition Component
USER_MCOMP
ufmcp
ufmcp
ufmcp
ufmcp
Substitute Component Out
USER_SCOMP1
ufscpo
ufscpo
ufscpo
ufscpo
Substitute Component In
USER_SCOMP2
ufscpi
ufscpi
ufscpi
ufscpi
Open Spreadsheet
USER_SPRD_OPN
ufspop
ufspop
ufspop
ufspop
Close Spreadsheet
USER_SPRD_CLO
ufspcl
ufspcl
ufspcl
ufspcl
Update Spreadsheet
USER_SPRD_UPD
ufspup
ufspup
ufspup
ufspup
Finish Updating Spreadsheet
USER_SPRD_UPF
ufspuf
ufspuf
ufspuf
ufspuf
Replace Reference Set
USER_RRSET
ufrrs
ufrrs
ufrrs
ufrrs
Rename Component
USER_NCOMP
ufncp
ufncp
ufncp
ufncp
NX Startup
USER_STARTUP
ufsta
Startup
startup
startup
Access Genius Library Management System
USER_GENIUS
ufgen
ufgen
ufgen
ufgen
Execute DebUG GRIP
USER_GRIPDEBUG
ufgrpd
ufgrpd
ufgrpd
ufgrpd
Execute User Function
USER_UFUNC
ufufun
ufufun
ufufun
ufufun
Initialize new operation
USER_CREATE_OPER
ufnopr
ufnopr
ufnopr
ufnopr
CAM Startup
USER_CAM_STARTUP
ufcams
ufcams
ufcams
ufcams
0 r+ M8 v$ Q4 J/ b' {; r
