uc5800 (view source)
Defined in: uf_assem.h
uc5800 create component by retrieval
Note: No Metric/English auto-scaling will be done.
int uc5800
const char * cp1,
const char * cp2,
const char * cp3,
double * rp4,
int ip5,
tag_t * nr6
| const char * | cp1 | Input | Component name |
| const char * | cp2 | Input | Component part fspec with extensions |
| const char * | cp3 | Input | Reference set name |
| double * | rp4 | Input | Component information (1 - 9) component orientation matrix (10-12) component origin (13) component scale - obsolete |
| int | ip5 | Input | Layer Mode 0 = retrieve on original layers 1 = retrieve on work layer |
| tag_t * | nr6 | Output | Component entity ID |
uc5801 (view source)
uc5801 read component data
void uc5801
tag_t np1,
char cr2 [ UF_CFI_MAX_FILE_NAME_BUFSIZE ] ,
char cr3 [ MAX_FSPEC_BUFSIZE ] ,
char cr4 [ UF_OBJ_NAME_BUFSIZE ] ,
double * rr5,
int * ir6
| tag_t | np1 | Input | Component entity id |
| char | cr2 [ UF_CFI_MAX_FILE_NAME_BUFSIZE ] | Output | Component name |
| char | cr3 [ MAX_FSPEC_BUFSIZE ] | Output | Component part name |
| char | cr4 [ UF_OBJ_NAME_BUFSIZE ] | Output | Component reference set name |
| double * | rr5 | Output | Component orientation information (1 - 9) component orientation matrix (10-12) component origin (13) component scale - obsolete |
| int * | ir6 | Output | Computational date and times (1-2) component entity (3-4) component part note: entity will be current date/time part will be the beginning of NX time |
uc5802 (view source)
uc5802 edit component data
void uc5802
tag_t np1,
const char * cp2,
const char * cp3,
double * rp4
| const char * | cp2 | Input | Component part name |
| double * | rp4 | Input | Rigid motion information (1-9) rigid motion matrix (10-12) rigid motion translation (13) component scale obsolete |
uc5810 (view source)
Creates a reference set.
int uc5810
const char * cp1,
double * rp2,
tag_t np3 [ ] ,
int ip4,
tag_t * nr5
| const char * | cp1 | Input | Reference set name (30 char max) |
| double * | rp2 | Input | [0] - [8] - Reference Set Orientation Matrix [9] - [11] - Reference Set Origin |
| tag_t | np3 [ ] | Input | Array of reference set member object identifier's |
| int | ip4 | Input | Number Of object identifier's In np3 |
| tag_t * | nr5 | Output | Reference set object identifier |
uc5811 (view source)
Returns reference set name, orientation matrix, and origin.
int uc5811
tag_t np1,
char cr2 [ UF_OBJ_NAME_BUFSIZE ] ,
double * rr3
| tag_t | np1 | Input | Reference set object identifier |
| char | cr2 [ UF_OBJ_NAME_BUFSIZE ] | Output | |
| double * | rr3 | Output | 12 element array: [0] - [8] - Reference Set Orientation Matrix [9]-[11] - Reference Set Origin |
uc5812 (view source)
Edits reference set name, origin, and orientation matrix.
int uc5812
tag_t np1,
const char * cp2,
double * rp3
| const char * | cp2 | Input | Reference set name (UF_OBJ_NAME_NCHARS characters max) |
| double * | rp3 | Input | 12 element array: [0] - [8] - Reference Set Orientation Matrix [9] - [11] - Reference Set Origin |
uc5816 (view source)
uc5816 create component by filing
int uc5816
const char * cp1,
const char * cp2,
const char * cp3,
double * rp4,
tag_t * np5,
int ip6,
tag_t * na7
| const char * | cp2 | Input | Component part fpsec |
| const char * | cp3 | Input | Reference set name 0 = all of part |
| double * | rp4 | Input | Component information (1-9) component orientation matrix (10-12) component origin |
| tag_t * | np5 | Input | Array of entity id's to add to component |
| int | ip6 | Input | Count of entity ids in previous argument |
| tag_t * | na7 | Input / Output | Component entity ID Input: 0 = file component <>0 = component eid to refile Output: component entity id if created by filing |
uc5818 (view source)
Do a Where-Used List on a Component Part. This operation only finds
component instances in archived parts (on disk).
Error Code:
< 0 = Error
0 = No Error
9 = Option Not Available
21 = No Files Found
int uc5818
const char * cp1,
const char * cp2
| const char * | cp1 | Input | Component Part Name |
| const char * | cp2 | Input | Root Directory To Search (100 char max) |
uf5804 (view source)
uf5804 read component member
void uf5804
tag_t * np1,
int * ip2,
tag_t * nr3
| tag_t * | np1 | Input | Component entity id |
| int * | ip2 | Input | Member instance to read |
| tag_t * | nr3 | Output | Component member entity id |
UF_ASSEM_activate_sequence (view source)
Activate the specified sequence. The active sequence is the default sequence
displayed in the sequence navigator (if running in internal mode).
If this function is called outside the sequencing environment (i.e.
UF_ASSEM_initialize_sequence has not been called before) then this will
return the last sequence that was active in the NX session.
Initially released in V18.0
assemblies
int UF_ASSEM_activate_sequence
tag_t sequence
| tag_t | sequence | Input | The sequence to be activated |
UF_ASSEM_add_part_to_assembly (view source)
Adds an instance of a part to a parent part. If the part is not loaded,
it is loaded into the current session. The instance is added to the parts
list according to the setting of the parts_list switch (see
UF_ASSEM_ask_assem_options and UF_ASSEM_options_s). The user allocated
structure error_status is filled with the names and associated error codes
of the loaded parts. The allocated arrays must be freed with UF_free and
UF_free_string_array.
If refset_name is a NULL pointer or a zero-length string, the entire part is
used. If instance_name is a NULL pointer or a zero-length string, the instance
is unnamed.
assemblies
int UF_ASSEM_add_part_to_assembly
tag_t parent_part,
const char * part,
const char * refset_name,
const char * instance_name,
double origin [ 3 ] ,
double csys_matrix [ 6 ] ,
int layer,
tag_t * instance,
UF_PART_load_status_t * error_status
| tag_t | parent_part | Input | tag of part to add instance to |
| const char * | part | Input | name of part to instance. The part name can include a directory path. This can not exceed MAX_FSPEC_NCHARS characters. |
| const char * | refset_name | Input | Name of reference set to use from component parts. The refset_name cannot exceed UF_OBJ_NAME_NCHARS characters, cannot include a directory path, and should not have a file extension. |
| const char * | instance_name | Input | Name of new instance The instance_name cannot exceed UF_OBJ_NAME_NCHARS characters, cannot include a directory path, and should not have a file extension. |
| double | origin [ 3 ] | Input | Position in <parent_part> where the instance is to be created |
| double | csys_matrix [ 6 ] | Input | Orientation of the instance |
| int | layer | Input | -1 Means use the original layers. 0 Means use the work layer 1-255 Means use the specified layer. |
| tag_t * | instance | Output | Tag of the new instance in the work part |
| UF_PART_load_status_t * | error_status | Output to UF_*free* | User allocted structure consisting of names and associated error codes. The allocated arrays must be freed with UF_free_string_array and UF_free. See the description of the UF_PART_load_status_t structure for details on freeing this structure. |
UF_ASSEM_add_ref_set_members (view source)
Adds an array of members to the reference set passed in.
Original release was in V14.0.
assemblies
int UF_ASSEM_add_ref_set_members
tag_t ref_set,
int member_count,
tag_t * ref_set_members
| tag_t | ref_set | Input | Tag of the reference set to add to. |
| int | member_count | Input | The number of new members to add. |
| tag_t * | ref_set_members | Input | Array of the new members to add. |
UF_ASSEM_add_sequencing_view (view source)
Add a view to the list of views used to display sequencing.
This should called after UF_ASSEM_initialize_sequencing_keep_layout().
Then user can keep their view layout and views of this layout into additional view
set. After that the animation of play a motion sequence will show in these
additional views.
Initially released in NX 8.5.1
assemblies
int UF_ASSEM_add_sequencing_view
tag_t view
| tag_t | view | Input | The tag of view to add. |
UF_ASSEM_add_to_cset (view source)
Allows you to add a component to an existing component set.
You can add the component at the single level (level = FALSE),
where only the given component is added to the set. Or, you can add
the component at all levels (level = TRUE), where all the child
components of the given component are also implicitly added to the
set. This means that if subsequently, the component has components
added or removed, the change is also reflected in the component set.
assemblies
int UF_ASSEM_add_to_cset
tag_t cset,
tag_t component,
logical level
| tag_t | cset | Input | Object identifier of component set |
| tag_t | component | Input | Object identifier of component to be added |
| logical | level | Input | Include child components switch |
UF_ASSEM_apply_to_cset (view source)
This routine allows you to apply the given function to each member of
the given component set and, if relevant, to all the members
component children.
assemblies
int UF_ASSEM_apply_to_cset
tag_t cset,
UF_ASSEM_cset_fn_t fn,
void * app_data
| UF_ASSEM_cset_fn_t | fn | Input | Pointer to required function type |
| void * | app_data | Input / Output | Pointer to any application data or NULL |
UF_ASSEM_apply_to_cset_members (view source)
Allows you to apply the given function to each, explicit member of the
given component set. If you want to apply the function to the children
of each member too, see UF_ASSEM_apply_to_cset.
assemblies
int UF_ASSEM_apply_to_cset_members
tag_t cset,
void * app_data
UF_ASSEM_ask_active_arrangement (view source)
Returns the Active Assembly Arrangement for a given
part. This is the Assembly Arrangement which would
take effect for it if that part were made the
Displayed Part.
Error code - use UF_get_fail_message to obtain the
corresponding error message
This function is supported for both Internal and
External execution.
Initially released in NX2.
int UF_ASSEM_ask_active_arrangement
tag_t part,
tag_t * arrangement
| tag_t | part | Input | The part to query |
| tag_t * | arrangement | Output | The Active Assembly Arrangement for that part |
UF_ASSEM_ask_active_sequence (view source)
Returns the sequence that is currently active in the session.
int UF_ASSEM_ask_active_sequence
tag_t * sequence
| tag_t * | sequence | Output | The active sequence in the session |
UF_ASSEM_ask_all_comp_cset (view source)
Allows you to return the system component set which contains
(implicitly) all the components in the given part.
int UF_ASSEM_ask_all_comp_cset
tag_t part,
tag_t * cset
| tag_t | part | Input | Object identifier of a part |
| tag_t * | cset | Output | Object identifier of component set found |
UF_ASSEM_ask_all_part_occ_children (view source)
Asks for a list of all part occurrences under a given part occurrence, including
suppressed part occurrence children.
Returns the count of part occurrences in the list.
int UF_ASSEM_ask_all_part_occ_children
tag_t part_occur,
tag_t * * child_part_occs
| tag_t | part_occur | Input | Tag of part occurrence to query for children |
| tag_t * * | child_part_occs | Output to UF_*free* | Array of tags of child part occurrences. The allocated list of tags must be freed with UF_free when it is no longer needed. |
UF_ASSEM_ask_arrangements_in_part (view source)
Returns all the Assembly Arrangements in a part.
External execution.
int UF_ASSEM_ask_arrangements_in_part
tag_t part,
int * n_arrangements,
tag_t * * arrangements
| int * | n_arrangements | Output | The number of Assembly Arrangements returned |
| tag_t * * | arrangements | Output to UF_*free* | The returned Assembly Arrangements |
UF_ASSEM_ask_arrays_in_part (view source)
Returns a list of the component arrays defined by a given part.
int UF_ASSEM_ask_arrays_in_part
tag_t part_tag,
int * num_arrays,
tag_t * * array_tags
| tag_t | part_tag | Input | Tag of part being queried. |
| int * | num_arrays | Output | The number of arrays in the part. |
| tag_t * * | array_tags | Output to UF_*free* | Dynamically allocated array of array tags. This must be freed by calling UF_free. |
UF_ASSEM_ask_arrays_of_inst (view source)
Returns a list of the arrays which contain a given instance.
int UF_ASSEM_ask_arrays_of_inst
tag_t instance,
int * num_arrays,
tag_t * * arrays
| tag_t | instance | Input | Tag of instance being queried. |
| int * | num_arrays | Output | The number of arrays which contain "instance_tag". |
| tag_t * * | arrays | Output to UF_*free* | Dynamically allocated array of array tags. This must be freed by the caller using UF_free. |
UF_ASSEM_ask_assem_load_options (view source)
Returns the current settings of the assembly options into the options
structure supplied by the user. For NX12 and later.
int UF_ASSEM_ask_assem_load_options
UF_ASSEM_load_options_t * options
UF_ASSEM_ask_assem_options (view source)
int UF_ASSEM_ask_assem_options
UF_ASSEM_options_t * options
UF_ASSEM_ask_auto_add_new_comps (view source)
Ask whether new components will be added to the specified reference set
automatically or not.
External execution.
Initially released in NX3.
int UF_ASSEM_ask_auto_add_new_comps
tag_t ref_set,
logical * add_new_comps
| tag_t | ref_set | Input | The reference set |
| logical * | add_new_comps | Output | Whether new components are to be added automatically |
UF_ASSEM_ask_bodies_of_assembly_cut (view source)
Ask the target and tool bodies for the assembly cut.
External execution.
int UF_ASSEM_ask_bodies_of_assembly_cut
tag_t frec,
int * n_target_bodies,
tag_t * * target_body_tags,
int * n_tool_bodies,
tag_t * * tool_body_tags
| tag_t | frec | Input | The assembly cut tag |
| int * | n_target_bodies | Output | Number of target bodies |
| tag_t * * | target_body_tags | Output to UF_*free* | Target bodies |
| int * | n_tool_bodies | Output | Number of tool bodies |
| tag_t * * | tool_body_tags | Output to UF_*free* | Tool bodies |
UF_ASSEM_ask_child_of_instance (view source)
Returns the tag of the child part of an instance. Returns NULL_TAG
if the child part of an instance is unloaded.
Returns tag of child part
tag_t UF_ASSEM_ask_child_of_instance
tag_t instance
| tag_t | instance | Input | Tag of instance to query for child part |
UF_ASSEM_ask_comp_explosion (view source)
Returns the explosion status and explosion transform of this particular
part occurrence. A part occurrence also inherits the explosion transforms of
its parents. This is intended to supplement UF_ASSEM_ask_component_data
used on instances.
int UF_ASSEM_ask_comp_explosion
tag_t explosion,
tag_t component,
UF_ASSEM_expl_status_p_t status,
double transform [ 4 ] [ 4 ]
| tag_t | explosion | Input | The explosion to query |
| tag_t | component | Input | The component (its part occurrence) |
| UF_ASSEM_expl_status_p_t | status | Output | The exploded status of the part occurrence. This can be one of the following enumerated constants: UF_ASSEM_unexploded UF_ASSEM_exploded UF_ASSEM_revert_exploded |
| double | transform [ 4 ] [ 4 ] | Output | If status = UF_ASSEM_exploded, a 4x4 non-distorting transform (see UF_ASSEM_ask_component_data for more information). |
UF_ASSEM_ask_comp_position (view source)
Returns the total absolute transform of the component in the given
explosion. This is intended to replace the transform returned by
UF_ASSEM_ask_component_data when used on part occurrences.
int UF_ASSEM_ask_comp_position
tag_t explosion,
tag_t component,
| double | transform [ 4 ] [ 4 ] | Output | a 4x4 non-distorting transform (see UF_ASSEM_ask_component_data for more information). |
UF_ASSEM_ask_component_data (view source)
Returns data about an instance or a part occurrence. The instance_name
output is always the name of the instance, even when a part occurrence is
passed to the function. Note that the names of the part occurrence and its
corresponding instance can be different. The refset_name can be different
between a part occurrence and its instance. The full 9 elements of the
csys_matrix are returned. The full transformation matrix is also
returned. The transformation matrix is the 4x4 matrix that combines
the origin and CSYS-matrix into a single matrix.
The format of the 4x4 transform is that the elements:
transform[0][0], transform[0][1], transform[0][2]
transform[1][0], transform[1][1], transform[1][2]
transform[2][0], transform[2][1], transform[2][2]
form a 3x3 orthnormal rotation matrix, the elements :
transform[0][3]
transform[1][3]
transform[2][3]
represent a (X, Y, Z) translation in the units of the part containing the
component, element
transform[3][3]
is always set to 1.0, and the remaining elements are always set to 0.0.
CAUTION: If the reference set of the component you are asking for
data on is set to "Entire Part", the string returned by
UF_ASSEM_ask_component_data for refset_name (third argument)
is "None".
int UF_ASSEM_ask_component_data
tag_t component,
char part_name [ MAX_FSPEC_BUFSIZE ] ,
char refset_name [ UF_OBJ_NAME_BUFSIZE ] ,
char instance_name [ UF_CFI_MAX_FILE_NAME_BUFSIZE ] ,
double csys_matrix [ 9 ] ,
| tag_t | component | Input | Tag of instance or part occurrence |
| char | part_name [ MAX_FSPEC_BUFSIZE ] | Output | Name of part |
| char | refset_name [ UF_OBJ_NAME_BUFSIZE ] | Output | Name of the reference set in use |
| char | instance_name [ UF_CFI_MAX_FILE_NAME_BUFSIZE ] | Output | name of instance |
| double | origin [ 3 ] | Output | Position of component |
| double | csys_matrix [ 9 ] | Output | Coordinate System Matrix |
| double | transform [ 4 ] [ 4 ] | Output | Transformation Matrix |
UF_ASSEM_ask_cost_of_sequence (view source)
Asks the cost for the given sequence. The time for the sequence
is an aggregate of the time for each of the steps in the assembly sequence.
int UF_ASSEM_ask_cost_of_sequence
tag_t sequence,
double * cost
| tag_t | sequence | Input | The tag of the given sequence |
| double * | cost | Output | The cost of the sequence |
UF_ASSEM_ask_cost_of_step (view source)
Asks the cost of the given step
int UF_ASSEM_ask_cost_of_step
tag_t step,
double * cost
| tag_t | step | Input | The tag of the given step |
| double * | cost | Output | The cost of the step |
UF_ASSEM_ask_current_frame (view source)
Get the current playback frame for the specified sequence. This is equivalent
to the value displayed in the "current frame" combo box in the Sequencing UI:
when the sequence duration is N frames, the current frame is an integer in the
inclusive range 0 to N.
Example: a sequence has two motion steps, whose durations are 5 and 7.
Frame 0 represents the very beginning of the sequence; frame 5 represents the
positions of the components after the first step has completed but before the
second step has begun; frame 12 represents the very end of the sequence.
If the specified sequence is not the active sequence, return 0, as this would
be the current frame if the sequence were made active.
Initially released in NX 8.0.1
assemblies
int UF_ASSEM_ask_current_frame
tag_t sequence,
int * current_frame
| tag_t | sequence | Input | The tag of the sequence |
| int * | current_frame | Output | The current playback frame of the sequence. |
UF_ASSEM_ask_current_step (view source)
Returns the current step in the given assembly sequence.
It is now possible that the playback can be stopped in the middle of a sequence
step (i.e. a sequence step is still in progress). If this is the case this function
will return the sequence step that is currently in progress.
If this function is called outside the sequencing environment then this will
return the first step of the given sequence since that is the step that would be
played first if that sequence was made active.
int UF_ASSEM_ask_current_step
tag_t sequence,
tag_t * step
| tag_t | sequence | Input | Tag of the sequence |
| tag_t * | step | Output | The step that will be played back next |
UF_ASSEM_ask_default_arrangement (view source)
Returns the Default Assembly Arrangement for a given
used by a new parent assembly if this part were added
to that parent as a new component.
External execution.
int UF_ASSEM_ask_default_arrangement
tag_t part,
tag_t * arrangement
| tag_t * | arrangement | Output | The Default Assembly Arrangement for that part |
UF_ASSEM_ask_default_ref_sets (view source)
Returns the current list of default reference sets. The names of the
reference sets are returned in the order they appear in the load
options dialog (and the order in which they are applied).
UF_ASSEM_set_default_ref_sets for setting these defaults.
Original release was in V13.0.
int UF_ASSEM_ask_default_ref_sets
int * n_ref_sets,
char * * * default_ref_sets
| int * | n_ref_sets | Output | The number of default reference sets. |
| char * * * | default_ref_sets | Output to UF_*free* | An ordered array of reference set names indicating the default reference sets currently in use. This is returned in allocated memory and should be freed using UF_free_string_array. |
UF_ASSEM_ask_deformable_definition (view source)
int UF_ASSEM_ask_deformable_definition
tag_t part,
tag_t * deformable_feature
UF_ASSEM_ask_deformable_definition_data (view source)
Inquire routine to obtain the data for the deformable feature.
int UF_ASSEM_ask_deformable_definition_data
tag_t deformable_feature_tag,
UF_ASSEM_deform_data_p_t deform_data
UF_ASSEM_ask_deformed_definition_data (view source)
Inquire routine to obtain the data for the deformed feature.
int UF_ASSEM_ask_deformed_definition_data
tag_t deformed_feature_tag,
UF_ASSEM_deformed_definition_data_p_t deformed_data
UF_ASSEM_ask_displayed_deformation_of_part_occ (view source)
Ask for the current deformed feature for the part occurrence in the context of the
current display part.
int UF_ASSEM_ask_displayed_deformation_of_part_occ
tag_t part_occ,
tag_t * deformed_feature
UF_ASSEM_ask_exploded_object (view source)
In normal circumstances, a dimension or other annotation which is
attached to an object, even in an exploded view, stays in the real
position of that object. When attaching such annotation to an object in
an exploded view, the new_object tag given by this function should be
used instead of the normal tag.
Please note that the behavior of an annotation attached to the
unexploded object in an exploded view is not guaranteed to be
consistent, and indeed may be considered erroneous in some cases.
The function is designed to be as resilient as possible, as is
demonstrated by the example.
int UF_ASSEM_ask_exploded_object
tag_t explosion,
tag_t old_object,
tag_t * new_object
| tag_t | explosion | Input | The tag of the explosion used in the view to which you wish to place the annotation. |
| tag_t | old_object | Input | The normal tag for the object. |
| tag_t * | new_object | Output | The tag of the exploded version, or the original tag in all cases where there is no exploded version. |
UF_ASSEM_ask_explosion_vector (view source)
Returns the suggested explosion vector for the component (the
direction in which it appears to be explodable), derived from mating
conditions. An error is returned if the component is not mated or not
properly constrained by the mating conditions.
int UF_ASSEM_ask_explosion_vector
tag_t component,
double vector [ 3 ]
| tag_t | component | Input | the tag of a part occurrence not instance |
| double | vector [ 3 ] | Output | The suggested explosion vector derived from mating conditions in absolute coordinates. |
UF_ASSEM_ask_explosions (view source)
Asks for all the explosions in a part file
Initially released into NX3.0
int UF_ASSEM_ask_explosions
tag_t part_tag,
int* n_explosions,
tag_t* * explosion_tags
| tag_t | part_tag | Input | The tag of the part for which to get the explosions. |
| int* | n_explosions | Output | Number of explosions. |
| tag_t* * | explosion_tags | Output to UF_*free* | The tags of the explosions in this part. This array must be freed by the caller using UF_free. |
UF_ASSEM_ask_hidden_comps (view source)
Return an array of the components hidden in the given view.
int UF_ASSEM_ask_hidden_comps
tag_t view,
tag_p_t* components,
int* count
| tag_t | view | Input | The view you are seeking informaton on |
| tag_p_t* | components | Output to UF_*free* | The components which are erased in the view. This array must be freed by the caller using UF_free. |
| int* | count | Output | The number of component tags in the array. |
UF_ASSEM_ask_inst_of_part_occ (view source)
Returns the instance tag of a part occurrence.
Instance tag of part occurrence
tag_t UF_ASSEM_ask_inst_of_part_occ
tag_t part_occur
| tag_t | part_occur | Input | Tag of part occurrence to query for instance. |
UF_ASSEM_ask_instance_intent (view source)
Returns intent data of an instance. The caller must allocate the
UF_ASSEM_instance_intent_t structure, and pass the pointer to that
structure to this routine. The routine then fills the structure
with data, which includes dynamically allocated data.
int UF_ASSEM_ask_instance_intent
tag_t instance,
UF_ASSEM_instance_intent_p_t instance_intent
| tag_t | instance | Input | Object identifier of the instance |
| UF_ASSEM_instance_intent_p_t | instance_intent | Output to UF_*free* | Data of the intent. The caller must free data inside this structure by calling UF_ASSEM_free_instance_intent when the structure is no longer needed. |
UF_ASSEM_ask_instance_of_name (view source)
Return the tag of the instance which has the given name, below the parent
part (one level only).
Tag of named instance
tag_t UF_ASSEM_ask_instance_of_name
tag_t parent_part,
| tag_t | parent_part | Input | Tag of parent part |
| const char * | instance_name | Input | Name of instance to obtain tag for; must be no longer than UF_OBJ_NAME_NCHARS characters. |
UF_ASSEM_ask_iset_array_data (view source)
Returns information about an ISET Component array in the
"array_data" structure and a dynamically allocated array of tags.
For rectangular arrays, the components in the list are as follows:
Figure. Rectangular Array Component List
int UF_ASSEM_ask_iset_array_data
tag_t array,
UF_ASSEM_iset_array_data_p_t array_data,
tag_t * * components
| tag_t | array | Input | Tag of array. |
| UF_ASSEM_iset_array_data_p_t | array_data | Output to UF_*free* | Pointer to data structure which is to be filled with array parameters. Use UF_free to deallocate memory. |
| tag_t * * | components | Output to UF_*free* | Tags of components. Use UF_free to deallocate memory. |
UF_ASSEM_ask_last_filter (view source)
Returns the last used filter stored for the given part tag. The output is either
a filter tag or a cset tag, but could never be both at the same time. Both output
arguments may return a null tag if there is no filter or component set matching
the stored filter name in the given part file.
If a filter tag is returned, you may use UF_FLTR_evaluate_filter for each of
the part occurrences in your assembly to check whether it needs to be loaded or
not. If a cset tag is returned, you may use UF_PART_open_cset to open that
component set directly.
External execution.
int UF_ASSEM_ask_last_filter
tag_t part,
tag_t * filter_tag,
tag_t * cset_tag
| tag_t | part | Input | Tag of the input part |
| tag_t * | filter_tag | Output | Tag of last filter used to open the part |
| tag_t * | cset_tag | Output | Tag of last cset used to open the part |
UF_ASSEM_ask_mc_array_data (view source)
Returns information about a Master Component array in the
For 2D linear arrays, the component list is laid out as follows:
int UF_ASSEM_ask_mc_array_data
tag_t array,
UF_ASSEM_mc_array_data_p_t array_data,
| UF_ASSEM_mc_array_data_p_t | array_data | Output | Pointer to data structure which is to be filled with array parameters. The caller is responsible for freeing the array_name member by calling UF_free. |
UF_ASSEM_ask_name_of_arrangement (view source)
Returns the name of the given Assembly Arrangement.
External execution.
int UF_ASSEM_ask_name_of_arrangement
tag_t arrangement,
char * * name
| tag_t | arrangement | Input | The Assembly Arrangement to query |
| char * * | name | Output to UF_*free* | The name of the given Assembly Arrangement |
UF_ASSEM_ask_occs_of_entity (view source)
Asks for all of the occurrences of object in all part occurrences in the
session.
Returns the count of the object occurrences.
int UF_ASSEM_ask_occs_of_entity
tag_t object,
tag_t * * occurrences
| tag_t | object | Input | Tag of object to query for occurrences |
| tag_t * * | occurrences | Output to UF_*free* | Array of tags of occurrences. The occurrences array must be freed with UF_free when it is no longer needed. |
UF_ASSEM_ask_occs_of_part (view source)
Asks for tags of all part occurrences of "part" under the assembly of
"parent_part."
Returns the count of part occurrences.
int UF_ASSEM_ask_occs_of_part
tag_t parent_part,
tag_t part,
tag_t * * part_occs
| tag_t | parent_part | Input | Tag of parent part to query. If parent_part is NULL, uses the current displayed part. |
| tag_t | part | Input | Tag of part with occurrences |
| tag_t * * | part_occs | Output to UF_*free* | Array of part occurrence tags. The part_occs array must be freed with UF_free when it is no longer needed. |
UF_ASSEM_ask_orientation (view source)
Returns the origin and orientation of a reference set.
int UF_ASSEM_ask_orientation
tag_t ref_set_tag,
double orientation [ 9 ]
| tag_t | ref_set_tag | Input | Reference set tag whose orientation and origin are wanted. |
| double | origin [ 3 ] | Output | Array to store the origin of the reference set in. |
| double | orientation [ 9 ] | Output | Array to store the reference set's orientation in. |
UF_ASSEM_ask_parent_component (view source)
Return the tag of the part_occurrence, or v9 component, containing the
occurrence. The occurrence can be either an entity occurrence,
v9 component or a part occurrence.
int UF_ASSEM_ask_parent_component
tag_t occur,
tag_t * parent
| tag_t | occur | Input | Occurrence object to be accessed |
| tag_t * | parent | Output | Parent object returned (or NULL_TAG if there is not a parent object) |
UF_ASSEM_ask_parent_of_instance (view source)
Returns the tag of the parent part of an instance.
Parent part tag
tag_t UF_ASSEM_ask_parent_of_instance
tag_t instance
| tag_t | instance | Input | Tag of instance to query for parent |
UF_ASSEM_ask_part_name_of_child (view source)
Returns the part name of the child part of an instance. If the child
part is loaded, this function is equivalent to
UF_PART_ask_part_name. If the child part is unloaded, then this
function returns the filename of the child part using the current search
options. This file name may then be given to UF_PART_open, or
UF_PART_open_quiet, to open the child part. Alternatively, you can
use the function UF_ASSEM_ensure_child_loaded to load child part in
the context of the current assembly.
int UF_ASSEM_ask_part_name_of_child
tag_t instance,
char part_fspec [ MAX_FSPEC_BUFSIZE ]
| char | part_fspec [ MAX_FSPEC_BUFSIZE ] | Output | Part name of child part of instance |
UF_ASSEM_ask_part_occ_children (view source)
Asks for a list of part occurrences under a given part occurrence.
Internal and External. Please note that this routine will not
return part occurrence children that are suppressed. Suppressed
part occurrences are, by default, not visible in the assembly.
To get a list of all part occurrence children, including
suppressed ones, please use UF_ASSEM_ask_all_part_occ_children.
int UF_ASSEM_ask_part_occ_children
tag_t part_occur,
UF_ASSEM_ask_part_occ_of_inst (view source)
Returns the tag of the part occurrence corresponding to the instance
and the parent part occurrence. A NULL_TAG passed as the
"parent_part_occ" specifies the displayed part.
Returns tag of part occurrence
tag_t UF_ASSEM_ask_part_occ_of_inst
tag_t parent_part_occ,
tag_t instance
| tag_t | parent_part_occ | Input | Tag of parent part occurrence |
| tag_t | instance | Input | Tag of instance |
UF_ASSEM_ask_part_occ_suppress_state (view source)
Determines if the given part occurrence is suppressed, or if one of the
part occurrences that contains the given part occurrence is suppressed. Part
occurrences that are suppressed, or that have one of their parents suppressed,
int UF_ASSEM_ask_part_occ_suppress_state
tag_t part_occ,
logical * suppressed,
logical * parent_suppressed
| tag_t | part_occ | Input | The tag of the part occurrence to query. |
| logical * | suppressed | Output | True if the given part occurrence is suppressed. |
| logical * | parent_suppressed | Output | True if any parent part occurrence of the given part occurrence is suppressed. May be NULL if the caller is not interested in determining the suppress state of the part occurrence |
UF_ASSEM_ask_part_occs_of_inst (view source)
Asks for all of the part occurrences associated with an instance.
Returns the count of part occurrences. When a -1 is returned then
the tag is not valid or another error occurred. Zero means there
were no occurrences of the instance.
int UF_ASSEM_ask_part_occs_of_inst
tag_t instance,
tag_t * * part_occs
| tag_t | instance | Input | Tag of instance to query for part occurrences |
| tag_t * * | part_occs | Output to UF_*free* | Allocated array of tags of part occurrences. The part_occs array must be freed with UF_free when it is no longer needed. |
UF_ASSEM_ask_part_occurrence (view source)
Returns the tag of the part_occurrence containing the "occurrence."
"occurrence" can be either an object occurrence or a part occurrence.
Returns tag of part occurrence.
tag_t UF_ASSEM_ask_part_occurrence
tag_t occurrence
| tag_t | occurrence | Input | Tag of object/part occurrence |
UF_ASSEM_ask_part_occurrence_of_step (view source)
Returns the part occurrences impacted by given sequence step
int UF_ASSEM_ask_part_occurrence_of_step
tag_t step,
int * num_part_occs,
tag_t * * part_occs
| tag_t | step | Input | The step to be queried. |
| int * | num_part_occs | Output | Number of part occurrences referenced by the step. |
| tag_t * * | part_occs | Output to UF_*free* | The part occurrences referenced by the step. The array must be UF_free'd |
UF_ASSEM_ask_prototype_of_occ (view source)
Returns the tag of the prototype object if "occurrence" is an object
occurrence tag. Returns the part tag of the part if occurrence is a part
occurrence tag. Returns NULL_TAG if the prototype object of the
occurrence is unloaded. Returns NULL_TAG if a call is made with a
part occurrence of a part which is not loaded.
Before a body/face/edge is promoted, its occurrence points to the prototype in
the component. After a body/face/edge is promoted, a new prototype is created
and the occurrence is changed so that it points to the new prototype (promoted
prototype). The promoted prototype and the promoted body are one and the same.
Therefore, if you query a promoted body for its prototype with
UF_ASSEM_ask_prototype_of_occ, it returns the tag of the promoted body.
You can go from a base body/face/edge to the corresponding promoted
body/face/edge using UF_MODL_prom_map_object_up. Similarly, you can go from a
promoted body/face/edge to the corresponding base body/face/edge using
UF_MODL_prom_map_object_down. Both routines work with prototypes only.
tag_t UF_ASSEM_ask_prototype_of_occ
tag_t occurrence
| tag_t | occurrence | Input | Tag of part occurrence or object occurrence |
UF_ASSEM_ask_ref_set_data (view source)
Returns all the information associated with a reference set. The array
of reference set members requires freeing by the caller.
int UF_ASSEM_ask_ref_set_data
tag_t ref_set,
char ref_set_name [ UF_OBJ_NAME_BUFSIZE ] ,
double matrix [ 9 ] ,
int * num_members,
tag_p_t * members
| tag_t | ref_set | Input | Reference set tag whose data is required. |
| char | ref_set_name [ UF_OBJ_NAME_BUFSIZE ] | Output | The reference set's name. |
| double | origin [ 3 ] | Output | Array containing the reference set's origin. |
| double | matrix [ 9 ] | Output | Array containing the reference set's orientation. |
| int * | num_members | Output | Number of elements in the reference set. |
| tag_p_t * | members | Output to UF_*free* | Array of elements in the reference set. Use UF_free to deallocate memory when done. |
UF_ASSEM_ask_ref_set_members (view source)
Returns an allocated array of the members of a reference set.
Starting with NX7.5, this function now returns the lightweight facets along
with the solids for the reference set.
int UF_ASSEM_ask_ref_set_members
tag_t ref_set,
int * ret_count,
tag_p_t * members
| tag_t | ref_set | Input | Reference set tag whose members are wanted. |
| int * | ret_count | Output | The number of members of the reference set. |
| tag_p_t * | members | Output to UF_*free* | Array of the members of the reference set. Use UF_free to deallocate memory when done. |
UF_ASSEM_ask_ref_sets (view source)
Returns all the reference sets to which the specified reference set
member belongs. This array must be freed by the caller.
int UF_ASSEM_ask_ref_sets
tag_t ref_set_member,
int * num_ref_sets,
tag_p_t * ref_sets
| tag_t | ref_set_member | Input | Tag whose reference sets are wanted. |
| int * | num_ref_sets | Output | The number of reference sets that member is in. |
| tag_p_t * | ref_sets | Output to UF_*free* | Array of the reference sets to which the member belongs. Use UF_free to deallocate memory. |
UF_ASSEM_ask_root_part_occ (view source)
Returns the tag of the root part occurrence, given the tag of a part. This
part occurrence is the top of the part occurrence tree for the part. You
can use this function with UF_ASSEM_ask_part_occ_children to
traverse the part occurrence tree for a part.
Tag of root part occurrence. Returns a NULL_TAG if there is
no root part occurrence (e.g. part with no components).
tag_t UF_ASSEM_ask_root_part_occ
tag_t part
| tag_t | part | Input | Tag of part |
UF_ASSEM_ask_save_trueshape (view source)
Returns a logical indicating whether the saving of true shape data is currently
enabled.
int UF_ASSEM_ask_save_trueshape
logical * save_trueshape_data
| logical * | save_trueshape_data | Output | Logical indicating whether the saving of true shape data is currently enabled. (TRUE = save true shape data, FALSE = do not save true shape data) |
UF_ASSEM_ask_search_directories (view source)
Ask for the list of the search directories.
int UF_ASSEM_ask_search_directories
int * count,
char * * * dir_list,
logical * * sub_dir
| int * | count | Output | The number of directories in the list. |
| char * * * | dir_list | Output to UF_*free* | A pointer to an allocated array of "count" pointers to allocated character strings containing the directory names. The array of character strings must be freed with UF_free_string_array. |
| logical * * | sub_dir | Output to UF_*free* | A pointer to an allocated array of "count" logicals. Each logical is TRUE if the subdirectories of the corresponding directory should be searched, or FALSE if the subdirectories should not be searched. The array must be freed with UF_free. |
UF_ASSEM_ask_sequence_description (view source)
Asks the description assigned to the given sequence.
int UF_ASSEM_ask_sequence_description
tag_t sequence,
char * * desc
| char * * | desc | Output to UF_*free* | The description of the sequence, null terminated. The returned string must be UF_free'd |
UF_ASSEM_ask_sequence_duration (view source)
Asks the total duration in playback frames for an entire sequence. The
duration is defined as (last frame number) - (first frame number), so a
sequence whose duration is N has frame numbers in the inclusive range 0 to N.
assemblies
int UF_ASSEM_ask_sequence_duration
tag_t sequence,
int * duration
| int * | duration | Output | The duration, in playback frames, of the sequence. |
UF_ASSEM_ask_sequence_name (view source)
Asks the name of the given sequence.
int UF_ASSEM_ask_sequence_name
tag_t sequence,
char * * name
| char * * | name | Output to UF_*free* | The name of the sequence, null terminated. The returned string must be UF_free'd |
UF_ASSEM_ask_sequence_type (view source)
Returns the type of sequence.
Initially released in NX 3.0
int UF_ASSEM_ask_sequence_type
tag_t sequence,
int * seq_type
| int * | seq_type | Output | The sequence type. One of the constants UF_ASSEM_ASSEMBLE_SEQUENCE UF_ASSEM_DISASSEMBLE_SEQUENCE UF_ASSEM_OPERATIONAL_SEQUENCE UF_ASSEM_UNKNOWN_SEQUENCE_TYPE |
UF_ASSEM_ask_sequences_in_part (view source)
Asks the sequences in the given part.
int UF_ASSEM_ask_sequences_in_part
tag_t part,
int * num_sequences,
tag_t * * sequences
| tag_t | part | Input | The tag of the given part |
| int * | num_sequences | Output | Number of sequences |
| tag_t * * | sequences | Output to UF_*free* | The tags of the sequences. The user must free this array using UF_free when done using the data. |
UF_ASSEM_ask_stable_id_of_instance (view source)
Returns the stable id of the given instance.
If the instance has a stable id then this routine will return a character pointer
to an allocated copy of the stable id otherwise it will return NULL.
The stable id is a stable revision independent identifier for the parent
child relationships between assemblies and their components.
This function is primarily for use in managed mode (TCIN) where the stable id
is assigned when the instance is first created.
The character pointer should be freed by the user by calling UF_free.
assemblies
int UF_ASSEM_ask_stable_id_of_instance
tag_t instance_tag,
char * * stable_id
| tag_t | instance_tag | Input | Tag of the instance. |
| char * * | stable_id | Output to UF_*free* | Stable Id of the instance. This pointer should be freed by the user by calling UF_free. |
UF_ASSEM_ask_step_duration (view source)
Asks the duration in playback frames of the given step. The duration is
defined as (last frame number) - (first frame number).
Example: if frame 6 represents the positions of the components just before a
motion step, and frame 15 represents their positions just after the step, the
duration of the step is 9.
assemblies
int UF_ASSEM_ask_step_duration
tag_t step,
int * duration
| tag_t | step | Input | The tag of the step |
| int * | duration | Output | The duration, in frames, of the step. |
UF_ASSEM_ask_step_element_durations (view source)
Asks the durations, measured in playback frames, of the step elements making
up a given step. The returned array is NULL if the step has no elements.
assemblies
int UF_ASSEM_ask_step_element_durations
tag_t step,
int * num_durations,
int * * durations
| int * | num_durations | Output | Number of returned durations |
| int * * | durations | Output to UF_*free* | The durations of the step elements. The user must free this array using UF_free when done using the data. |
UF_ASSEM_ask_step_increment (view source)
Asks the step increment of the given sequence.
int UF_ASSEM_ask_step_increment
tag_t sequence,
int * increment
| int * | increment | Output | The step increment for the sequence |
UF_ASSEM_ask_step_number (view source)
Asks a step number for the given step. The step number indicates the position
of the step in the sequence, and is automatically generated and maintained by
the sequence.
int UF_ASSEM_ask_step_number
tag_t step,
int * ask_step_number
| int * | ask_step_number | Output | Step number of the given step |
UF_ASSEM_ask_step_type (view source)
Asks the type of the given step.
int UF_ASSEM_ask_step_type
tag_t step,
int * step_type
| int * | step_type | Output | The step type. One of the constants UF_ASSEM_ASSEMBLE_STEP UF_ASSEM_DISASSEMBLE_STEP UF_ASSEM_CAMERA_STEP UF_ASSEM_MOTION_STEP UF_ASSEM_SNAPSHOT_STEP |
UF_ASSEM_ask_steps (view source)
Asks the steps of the given sequence.
int UF_ASSEM_ask_steps
tag_t sequence,
int * num_steps,
tag_t * * steps
| int * | num_steps | Output | Number of steps |
| tag_t * * | steps | Output to UF_*free* | The tags of the steps. The user must free this array using UF_free when done using the data. |
UF_ASSEM_ask_steps_of_part_occ (view source)
Returns the steps in the given sequence that reference the specified part
occurrence
int UF_ASSEM_ask_steps_of_part_occ
tag_t sequence,
tag_t part_occ,
int * num_steps,
tag_t * * steps
| tag_t | part_occ | Input | The part occurrence whose steps are required |
| int * | num_steps | Output | Number of steps that reference the part occurrence |
| tag_t * * | steps | Output to UF_*free* | The steps that reference the given part occurrence. The array must be UF_free'd |
UF_ASSEM_ask_suppress_state (view source)
Determines if the given instance is suppressed.
int UF_ASSEM_ask_suppress_state
tag_t instance,
| tag_t | instance | Input | The tag of the instance to query. |
| logical * | suppressed | Output | True if the given instance is suppressed. |
UF_ASSEM_ask_suppression_exp (view source)
Returns the expression a given instance is dependent on for suppress state. This
will return NULL_TAG if the given instance has no suppression expression.
int UF_ASSEM_ask_suppression_exp
tag_t instance,
tag_t * exp
| tag_t | instance | Input | The tag of the instance to get suppression expression for. |
| tag_t * | exp | Output | Expression used to control suppression for the given instance. |
UF_ASSEM_ask_time_of_sequence (view source)
Asks the time for the given sequence. The time for the sequence
int UF_ASSEM_ask_time_of_sequence
tag_t sequence,
double * time
| double * | time | Output | The time taken for the sequence |
UF_ASSEM_ask_time_of_step (view source)
Asks the time taken for the given step.
int UF_ASSEM_ask_time_of_step
tag_t step,
double * time
| double * | time | Output | The time taken for the step |
UF_ASSEM_ask_transform_of_occ (view source)
Asks the 4x4 transform matrix of an object occurrence or part
occurrence.
int UF_ASSEM_ask_transform_of_occ
tag_t occurrence,
| tag_t | occurrence | Input | Tag of occurrence to query for transform matrix. |
| double | transform [ 4 ] [ 4 ] | Output | Transformation matrix for occurrence |
UF_ASSEM_ask_type_of_array (view source)
Returns the type of an array. The system uses one of the defined
constants in UF_ASSEM_MC_ARRAY or UF_ASSEM_ISET_ARRAY.
int UF_ASSEM_ask_type_of_array
tag_t array,
int * type
| tag_t | array | Input | Tag of array being queried. |
| int * | type | Output | Type of array. |
UF_ASSEM_ask_unprocessed_partoccs (view source)
Given an assembly sequence tag, this function will return the components that
have not yet been processed in the assembly sequence.
int UF_ASSEM_ask_unprocessed_partoccs
tag_t sequence,
int * num_unprocessed_partoccs,
tag_t * * unprocessed_partoccs
| int * | num_unprocessed_partoccs | Output | Number of unprocessed part occurrences |
| tag_t * * | unprocessed_partoccs | Output to UF_*free* | Tags of unprocessed part occurrences. The array must be freed using UF_free |
UF_ASSEM_ask_used_arrangement (view source)
Returns the Used Assembly Arrangement for a given
component. This is the Assembly Arrangement which
is used to represent that component in the parent
part of that component.
External execution.
int UF_ASSEM_ask_used_arrangement
tag_t component,
tag_t * arrangement
| tag_t | component | Input | The component to query |
| tag_t * | arrangement | Output | The Used Assembly Arrangement for that component |
UF_ASSEM_ask_view_explosion (view source)
Get an explosion used in a view. Outputs the tag of the explosion
which is displayed in the view, or a NULL_TAG if the view is
displaying the real assembly.
int UF_ASSEM_ask_view_explosion
tag_t view,
tag_t * explosion
| tag_t | view | Input | The tag of the view about which to enquire |
| tag_t * | explosion | Output | The explosion used in the view, or NULL_TAG if the view is showing the real assembly positions (has no explosion associated with it). |
UF_ASSEM_ask_work_occurrence (view source)
Returns the work occurrence of the work part.
Returns the tag of the work occurrence. Returns a
NULL_TAG if there is no current work part, or if
the work part occurrence is the displayed part.
tag_t UF_ASSEM_ask_work_occurrence
UF_ASSEM_ask_work_part (view source)
Returns the part tag of the current work part.
Returns the tag of the current work part, else
returns a NULL_TAG if there is no current work
part.
tag_t UF_ASSEM_ask_work_part
UF_ASSEM_capture_arrangement_from_current_sequence (view source)
Captures an arrangement of the current sequence playback positions
and assemble/disassemble states. The disassemble states will be represented
as part occurrence specific suppressions.
Any positioning or suppression will be done as assembly level overrides (where
the assembly is the part owning the sequence).
There are situations where an arrangement can be captured, but with some
warnings. The warnings will be returned in the list of warnings. The warnings
are standard NX error codes. Their description can be obtained with UF_get_fail_message.
The nature of the warning may indicate that not all positions could be represented
in the arrangement (usually a consequence of mating conditions and assembly constraints
that are active in the assembly while mating conditions and assembly constraints had been
disabled in the sequence). Similarly, it may not always be possible to suppress the
required components on the assembly level since in sequencing you can "disassemble" a
subassembly's geometry without "disassembling" all its child components.
Sequencing must have initialized before this function can be called.
Initially released in NX5.0
assemblies
int UF_ASSEM_capture_arrangement_from_current_sequence
const char * arrangement_name,
tag_t* arrangement,
int* warnings_count,
int* * warnings
| const char * | arrangement_name | Input | The name of the arrangement |
| tag_t* | arrangement | Output | The created arrangement |
| int* | warnings_count | Output | The number of warnings |
| int* * | warnings | Output to UF_*free* | List of warning codes. Must be freed with UF_free |
UF_ASSEM_capture_arrangement_from_current_sequence_extended (view source)
in the arrangement (usually a consequence of mating constraints that are active
in the assembly while mating constraints had been disabled in the sequence). Optionally,
mating constraints may be ignored during arrangement capture if desired. Similarly, it
may not always be possible to suppress the required components on the assembly level
since in sequencing you can "disassemble" a subassemlby's geometry without
Initially released in NX8.5
assemblies
int UF_ASSEM_capture_arrangement_from_current_sequence_extended
logical ignore_constraints,
tag_t* arrangement,
int* * warnings
| logical | ignore_constraints | Input | Whether to ignore assembly constraints |
UF_ASSEM_check_array_status (view source)
Performs an update validity check on a component array. If the array
can be updated, then this function returns 0. If the array check fails,
then this function returns an error code. Use UF_get_fail_message to
capture the error string. Some possible errors that can occur are as
follows:
"Array is suppressed."
"Array template is unloaded."
"Array master is unloaded."
"Array template is not mated to a valid feature instance."
"Array size expression is invalid."
assemblies
int UF_ASSEM_check_array_status
tag_t array
| tag_t | array | Input | Tag of array to check. |
UF_ASSEM_convert_prev16_aligns (view source)
Converts the specified PreV16 Align constraints to Distance constraints.
This function will attempt to adjust the offset distance of the constraint
to maintain the existing behaviour of the constraint - in some cases it
might negate the offset expression. A list of messages is returned which
describes any reasons why constraints could not be converted or could not
update afterwards.
External execution.
Initially released in NX3.0.4 MP1.
int UF_ASSEM_convert_prev16_aligns
int n_aligns_to_convert,
const UF_ASSEM_prev16_align_t * aligns_to_convert,
int * n_messages,
UF_ASSEM_prev16_align_t * * messages
| int | n_aligns_to_convert | Input | The number of constraints to convert |
| const UF_ASSEM_prev16_align_t * | aligns_to_convert | Input | The constraints to convert (array of length n_aligns_to_convert) |
| int * | n_messages | Output | The number of messages returned. |
| UF_ASSEM_prev16_align_t * * | messages | Output to UF_*free* | The returned messages (of length n_messages) Freed by UF_ASSEM_free_prev16_aligns |
UF_ASSEM_copy_explosion (view source)
Copies the explosion transforms from one (sub)assembly to an
equivalent (sub)assembly. The destination may be in the same
explosion as the source, or it may be another explosion in the same
part, or it may be an explosion in a different part altogether.
assemblies
int UF_ASSEM_copy_explosion
tag_t source_explosion,
tag_t source_component,
tag_t destination_explosion,
tag_t destination_component
| tag_t | source_explosion | Input | The tag of the explosion from which to copy transforms. |
| tag_t | source_component | Input | Either NULL_TAG, in which case the whole explosion is copied, or a component (part occurrence) tag indicating the portion of the explosion to be copied. |
| tag_t | destination_explosion | Input | The tag of the explosion which the source explosion should be copied into. |
| tag_t | destination_component | Input | Either NULL_TAG, in which case the whole explosion is over-written, or a component (part occurrence) tag indicating a portion of the explosion to be over-written (in either case, the tag must represent the same componenrt part as the source_component argument). |
UF_ASSEM_count_ents_in_part_occ (view source)
Count the number of entity occurrences associated with a part occurrence.
Number of object occurrences
int UF_ASSEM_count_ents_in_part_occ
tag_t part_occur
| tag_t | part_occur | Input | Tag of part occurrence |
UF_ASSEM_count_objs_in_comp (view source)
Given a part occurrence tag or v9 component type as input argument
this routine gets the count of members for a given component.
int UF_ASSEM_count_objs_in_comp
tag_t comp_tag,
int * returned_count
| tag_t | comp_tag | Input | Source component |
| int * | returned_count | Output | Count of members in source component |
UF_ASSEM_count_ref_sets_in (view source)
Counts the number of links from an object to the reference sets that
contain it.
The number of links from the object to the
reference sets that contain it. This value is >= 0.
int UF_ASSEM_count_ref_sets_in
tag_t object
| tag_t | object | Input | Object Identifier (can be an occurrence) |
UF_ASSEM_create_assembly_cut (view source)
Create an assembly cut feature in a part.
External execution.
assemblies
int UF_ASSEM_create_assembly_cut
tag_t part,
logical blank_tool_bodies,
int n_target_body_occs,
tag_t * target_body_occs,
int n_tool_bodies,
tag_t * tool_bodies,
tag_t * acut_tag
| tag_t | part | Input | The part in which the assembly cut is created |
| logical | blank_tool_bodies | Input | To keep tool bodies displayed after the cut |
| int | n_target_body_occs | Input | The number of body occurrences |
| tag_t * | target_body_occs | Input | The target body occurrences |
| int | n_tool_bodies | Input | The number of tools |
| tag_t * | tool_bodies | Input | The tool bodies or body occurrences |
| tag_t * | acut_tag | Output | The assembly cut feature tag |
UF_ASSEM_create_component_part (view source)
Defined in: uf_assem.h
Create a new part, moves selected objects to it, then adds an instance
of it to the parent part. Any other transferrable objects upon which
the given objects depend are also moved into the component.
The instance will be added to the parts-list according to the setting of
the global switch, see UF_ASSEM_ask_assem_options.
CAUTION: Object occurrences and part occurrences cannot be moved into a
component.
If an object depends upon another object which is not transferable,
then that object is not moved into the component and a return value
of UF_PART_warn_objects_not_copied is returned. The operation
continues though, and any other requested transferable objects are
still moved into the component. This situation can arise because a
drafting object is not transferred if its associated geometry is not
transferred.
If any other error occurs, the operation does not succeed and the
appropriate error code is returned.
V11.0 modified to retain feature parameters in the transferred objects.
assemblies
int UF_ASSEM_create_component_part
tag_t parent_part,
const char * new_part_name,
int units,
int layer,
int n_objects,
tag_t * objects,
tag_t * instance
| const char * | new_part_name | Input | Name of new component part |
| const char * | refset_name | Input | Name of reference set; must be no longer than UF_OBJ_NAME_NCHARS characters. |
| const char * | instance_name | Input | Name of instance to add to parent part; must be no longer than UF_OBJ_NAME_NCHARS characters. |
| int | units | Input | 1 = MM 2 = Inches |
| int | layer | Input | -1 = original 0 = use work layer 1-255 = use specified layer |
| double | origin [ 3 ] | Input | Position in parent part where the instance is to be created. |
| int | n_objects | Input | Number of objects in the "objects" array. |
| tag_t * | objects | Input | Pointer to an array of tags of objects that should be moved to the new component part. |
| tag_t * | instance | Output | Tag of instance |
UF_ASSEM_create_constrained_iset_array (view source)
Creates an ISET array, based on the parameters in the "array_data"
structure. The template component must already be constrained to one
element of the ISET. This differs from UF_ASSEM_create_iset_array
in that it works with assembly constraints rather than mating conditions.
assemblies
int UF_ASSEM_create_constrained_iset_array
tag_t * array
UF_ASSEM_create_cset (view source)
Creates a component set in the given part with the given name which
can not be NULL. The output of this routine is the tag of the newly
created, empty component set.
assemblies
int UF_ASSEM_create_cset
tag_t part,
const char * name,
tag_t * object
| tag_t | part | Input | Part where component set is created |
| const char * | name | Input | Name to be given to component set |
| tag_t * | object | Output | Object identifier of created component set |
UF_ASSEM_create_deformable_part (view source)
Creates a deformable definition for the part occurrence given in the current work part.
assemblies
int UF_ASSEM_create_deformable_part
UF_ASSEM_deform_data_p_t data,
UF_ASSEM_create_explosion (view source)
Creates an explosion in the specified display part; the components in
the assembly are initially at their real assembly positions, and the
explosion is initially not used in any views.
assemblies
int UF_ASSEM_create_explosion
tag_t display_part_tag,
const char* explosion_name,
tag_p_t explosion_tag
| tag_t | display_part_tag | Input | The tag of the display part in which to create the explosion |
| const char* | explosion_name | Input | A name for the explosion; this must be a valid NX name value, as well as not being used by any existing explosion in the display part. |
| tag_p_t | explosion_tag | Output | The tag of the created explosion (or NULL_TAG on error) |
UF_ASSEM_create_iset_array (view source)
structure. The template component must already be mated to one
assemblies
int UF_ASSEM_create_iset_array
tag_t * array
UF_ASSEM_create_mc_array (view source)
Creates a Master Component array in the work part, based on the
parameters in the "array_data" structure.
assemblies
int UF_ASSEM_create_mc_array
tag_t * array
UF_ASSEM_create_ref_set (view source)
Creates a reference set at the coordinates specified, with the given
name, orientation, and members.
assemblies
int UF_ASSEM_create_ref_set
const char * ref_set_name,
tag_t * ref_set_members,
int num_members,
tag_t * ref_set_tag
| const char * | ref_set_name | Input | Name of the new reference set. Must be no longer than UF_OBJ_NAME_NCHARS characters. |
| double | origin [ 3 ] | Input | The origin coordinates of the reference set. |
| double | matrix [ 9 ] | Input | The orientation matrix of the reference set. |
| tag_t * | ref_set_members | Input | num_members Array of members of the new reference set. |
| int | num_members | Input | The number of members in the members array. |
| tag_t * | ref_set_tag | Output | The tag of the newly created reference set. |
UF_ASSEM_create_sequence (view source)
Creates an empty assembly sequence.
UF_ASSEM_initialize_sequencing must be called before calling this function.
Initially released in V18.0
assemblies
int UF_ASSEM_create_sequence
char * name,
tag_t part,
tag_t * sequence
| char * | name | Input | The name of the sequence |
| tag_t | part | Input | The part to create the sequence in |
| tag_t * | sequence | Output | The tag of the newly created sequence |
UF_ASSEM_create_step (view source)
Creates a step in the given sequence.
A part occurrence may have more than one step in the sequence, if it is
to be assembled or disassembled more than once.
assemblies
int UF_ASSEM_create_step
tag_t sequence,
tag_t part_occurrence,
int step_type,
double time,
double cost,
char * description,
tag_t insert_at_step,
tag_t * step
| tag_t | sequence | Input | The sequence in which the step needs to be created |
| tag_t | part_occurrence | Input | The part occurrence being sequenced |
| int | step_type | Input | The type of the step. One of the constants UF_ASSEM_ASSEMBLE_STEP or UF_ASSEM_DISASSEMBLE_STEP only |
| double | time | Input | The time of the step. The time is a user defined number. |
| double | cost | Input | The cost of the step. The time is a user defined number. |
| char * | description | Input | The description of the step. May be NULL, if the user does not want to assign a description at this point. |
| tag_t | insert_at_step | Input | The step that this step is to be inserted after. May be NULL_TAG, in which case the new step is added at the beginning of the sequence |
| tag_t * | step | Output | The tag of the newly created step. May be NULL_TAG if no step was created - an error code describing the reason is returned. |
UF_ASSEM_create_typed_sequence (view source)
Creates a typed sequence.
assemblies
int UF_ASSEM_create_typed_sequence
const char * name,
int sequence_type,
tag_t part,
tag_t * sequence
| const char * | name | Input | The name of the sequence |
| int | sequence_type | Input | The type of sequence to be created. One of the constants UF_ASSEM_ASSEMBLE_SEQUENCE UF_ASSEM_DISASSEMBLE_SEQUENCE UF_ASSEM_OPERATIONAL_SEQUENCE |
UF_ASSEM_cycle_ents_in_part_occ (view source)
Cycles the object occurrences in a part occurrence.
Returns object occurrence tag. Returns NULL_TAG after last
object cycles.
tag_t UF_ASSEM_cycle_ents_in_part_occ
tag_t part_occur,
tag_t object_occur
| tag_t | object_occur | Input | Tag of object occurrence. Pass the previous object tag in to the routine (starting with NULL_TAG to initialize), and the routine cycles the next object tag. |
UF_ASSEM_cycle_inst_of_part (view source)
Cycles the instances in a part which is the parent of the instances.
Returns the next instance tag. Returns a NULL_TAG after the
last object cycles through.
tag_t UF_ASSEM_cycle_inst_of_part
tag_t part,
tag_t instance
| tag_t | part | Input | Tag of parent part to instances |
| tag_t | instance | Input | Pass the previous instance tag into the routine (starting with NULL_TAG to initialize), and the routine cycles to the next instance tag. |
UF_ASSEM_cycle_objs_in_comp (view source)
Cycles the occurrenced members in the source component. Start cycle
with a NULL_TAG in member and cycle ends when NULL_TAG is
returned in member.
int UF_ASSEM_cycle_objs_in_comp
tag_t component,
tag_t * member
| tag_t | component | Input | Source component |
| tag_t * | member | Input / Output | Current member from source component |
UF_ASSEM_deform_part (view source)
Creates a deformed part occurrence in the current work part.
assemblies
int UF_ASSEM_deform_part
UF_ASSEM_deform_part_data_p_t deform_data,
UF_ASSEM_deform_part_warnings_p_t deform_warnings
UF_ASSEM_delete_array (view source)
Deletes an array. Either removes all of the components except the
array template or only removes the array and leaves all of the
components. Components which are master components of other
arrays cannot be deleted.
assemblies
int UF_ASSEM_delete_array
tag_t array,
logical delete_all
| tag_t | array | Input | Tag of array being deleted. |
| logical | delete_all | Input | Delete all flag: TRUE = Deletes all components in the array except the array template. FALSE = Deletes the array but not the components in the array. |
UF_ASSEM_delete_explosion (view source)
Deletes the specified explosion; the explosion may not be used in any
views when this is done. All data concerning the explosion of
individual components is lost.
assemblies
int UF_ASSEM_delete_explosion
tag_t explosion
| tag_t | explosion | Input | The tag of the explosion to delete. |
UF_ASSEM_delete_sequence (view source)
Deletes an assembly sequence.
assemblies
int UF_ASSEM_delete_sequence
tag_t sequence
UF_ASSEM_delete_step (view source)
Deletes a step from its assembly sequence.
assemblies
int UF_ASSEM_delete_step
tag_t step
UF_ASSEM_edit_assembly_cut (view source)
Edit an assembly cut feature in a part.
Error code - use UF_get_fail_message to obtain the
corresponding error message
This function is supported for both Internal and
External execution.
assemblies
int UF_ASSEM_edit_assembly_cut
tag_t frec_tag,
int n_target_bodies,
tag_t * target_body_tags,
int n_tool_bodies,
tag_t * tool_body_tags,
| tag_t | frec_tag | Input | The assembly cut tag |
| int | n_target_bodies | Input | Number of target bodies |
| tag_t * | target_body_tags | Input | Target body occurrences |
| int | n_tool_bodies | Input | Number of tool bodies |
| tag_t * | tool_body_tags | Input | Tool body occurrences |
| logical | blank_tool_bodies | Input | Blank the display of the tool bodies |
UF_ASSEM_edit_iset_array (view source)
Edits a ISET Component array, by applying the parameters in the
CAUTION: Neither the dimensions nor the feature_iset tag can be
edited. To change the size of the array, you should edit the feature
ISET that the array is based on, by using UF_MODL_ask_circular_iset_parms or
UF_MODL_ask_linear_iset_parms to find the expressions that control
the ISET, and then edit these expressions.
assemblies
int UF_ASSEM_edit_iset_array
tag_t array,
UF_ASSEM_edit_mc_array (view source)
Edits a Master Component array, by applying the parameters in the
CAUTION: to edit the size and offset of the array, it is only necessary
to edit the relevant expressions.
assemblies
int UF_ASSEM_edit_mc_array
tag_t array,
UF_ASSEM_edit_ref_set_data (view source)
Modifies the specified reference set with a new origin and/or
orientation. To change the name of the reference set, use the
UF_OBJ_set_name routine.
Original release was in V14.0.
assemblies
int UF_ASSEM_edit_ref_set_data
tag_t ref_set_tag,
double origin [ 3 ] ,
double matrix [ 9 ]
| tag_t | ref_set_tag | Input | Reference set tag whose orientation and origin are to be changed. |
| double | origin [ 3 ] | Input | Array of coordinates for the reference set's new origin. |
| double | matrix [ 9 ] | Input | Matrix Array for the reference set's new orientation. |
UF_ASSEM_ensure_child_loaded (view source)
Ensures that the child part of an instance is loaded. If the load of a
child fails, then the load_status is filled out as it is for other load
functions.
int UF_ASSEM_ensure_child_loaded
tag_t instance,
UF_PART_load_status_t * load_status
| tag_t | instance | Input | Tag of parent part to instances |
| UF_PART_load_status_t * | load_status | Output to UF_*free* | See the UF_PART_load_status_t structure definition. The allocated structure is filled with the names and associated error codes of any parts that did not load correctly. The allocated arrays must be freed with UF_free_string_array and UF_free. |
UF_ASSEM_eval_instance_intent (view source)
Evaluates intent data of an instance and optionally applies the result.
assemblies
int UF_ASSEM_eval_instance_intent
tag_t * instance,
logical apply_result,
UF_ASSEM_instance_status_p_t instance_status
| tag_t * | instance | Input / Output | Object identifier of the instance. Note that the instance tag is not currently modified; but it may be modified in the future (hence, its designation as an I/O parameter). |
| logical | apply_result | Input | Apply result flag. |
| UF_ASSEM_instance_status_p_t | instance_status | Output | Status of the instance. |
UF_ASSEM_explode_component (view source)
Explode a component by a given transform. This is combined with
exploded position of the component's parent and the component's
normal transform to give the resultant exploded position.
assemblies
int UF_ASSEM_explode_component
tag_t explosion,
| tag_t | explosion | Input | The explosion in which to modify the component |
| tag_t | part_occurrence | Input | the tag of a part occurrence not instance |
| double | transform [ 4 ] [ 4 ] | Input | a 4x4 non-distorting transform (see UF_ASSEM_ask_component_data for more information). |
UF_ASSEM_find_immed_old_comps (view source)
Ask for a list of immediate old style components. Only components of
the given part are returned. This routine may be used to determine if
the given part contains pre-V10 assemblies that may be upgraded
(i.e., if n_immediate_components > 0 then the part contains
pre-V10 components).
CAUTION: "Immediate" components are those direct components in
the work part and does not include components of a subassembly of
the work part. "Old" signifies that the components are pre-V10 style
components.
int UF_ASSEM_find_immed_old_comps
tag_t part,
tag_t * * immediate_components,
int * n_immediate_components
| tag_t | part | Input | Tag of part to query for old components. |
| tag_t * * | immediate_components | Output to UF_*free* | Allocated array of tags of immediate old style components. This array must be freed by calling UF_free. |
| int * | n_immediate_components | Output | number of pre-v10 components |
UF_ASSEM_find_occurrence (view source)
Return the tag of the object occurrence in the given part,
corresponding to the object_prototype.
Returns tag of object occurrence or NULL_TAG if object is not found.
tag_t UF_ASSEM_find_occurrence
tag_t part_occur,
tag_t object_prototype
| tag_t | object_prototype | Input | Tag of object prototype |
UF_ASSEM_find_prev16_aligns_to_check (view source)
Finds PreV16 Align constraints which need converting to Distance constraints
so their behaviour will remain stable.
External execution.
int UF_ASSEM_find_prev16_aligns_to_check
tag_t part_tag,
logical recurse,
int * n_aligns_to_check,
UF_ASSEM_prev16_align_t * * aligns_to_check
| tag_t | part_tag | Input | The part in which to search |
| logical | recurse | Input | Whether to search in all components (true) or just in this part (false) |
| int * | n_aligns_to_check | Output | The number of found constraints |
| UF_ASSEM_prev16_align_t * * | aligns_to_check | Output to UF_*free* | The found constraints (array of length n_aligns_to_check) Freed by UF_ASSEM_free_prev16_aligns |
UF_ASSEM_free_deform_warnings_data (view source)
Free the deform part warnings structure
Initially released in NX2
assemblies
int UF_ASSEM_free_deform_warnings_data
UF_ASSEM_deform_part_warnings_p_t warnings
UF_ASSEM_free_instance_intent (view source)
Frees intent data returned from UF_ASSEM_ask_instance_intent.
assemblies
int UF_ASSEM_free_instance_intent
UF_ASSEM_free_prev16_aligns (view source)
Frees the memory consumed by the array of UF_ASSEM_prev16_align_t objects
returned by UF_ASSEM_find_prev16_aligns_to_check and UF_ASSEM_convert_prev16_aligns.
The memory for the array will be freed along with all data referenced by all
members of the array.
External execution.
int UF_ASSEM_free_prev16_aligns
int n_aligns,
UF_ASSEM_get_occ_in_work_occ (view source)
Return the part occurrence tag in the context of the work occurrence
int UF_ASSEM_get_occ_in_work_occ
tag_t part_occ,
tag_t * occ_in_work
UF_ASSEM_get_ref_set_inst (view source)
Returns the object identifier of the reference set (specified by
reference set "number") that contains the object. The object can be
an occurrence.
Object Identifier of the numbered reference set
that contains the object. NULL_TAG is returned when the
object does not belong to any reference sets or if it
has less than number links.
tag_t UF_ASSEM_get_ref_set_inst
tag_t object,
int number
| tag_t | object | Input | Object Identifier (object can be an occurrence) |
| int | number | Input | The number of the reference set to which the object belongs (e.g. 1 is the first reference set it belongs to, 2 is the second reference set, etc.). |
UF_ASSEM_hide_component (view source)
Hide the given component in the given view. The effect is analagous
to moving the component to a layer which is invisible in the view.
assemblies
int UF_ASSEM_hide_component
tag_t component,
tag_t view
| tag_t | view | Input | The view from which to hide the component |
UF_ASSEM_ignore_part_occ (view source)
Ignores the given part occurrence in the sequence.
Ignored part occurrences are not marked processed, and are no longer considered valid
candidates for assembly or disassembly.
assemblies
int UF_ASSEM_ignore_part_occ
tag_t sequence,
tag_t part_occ
| tag_t | sequence | Input | The tag of the given sequence |
| tag_t | part_occ | Input | The part occurrence to be ignored |
UF_ASSEM_init_deform_part_data (view source)
Initializes a deformed part data structure.
assemblies
int UF_ASSEM_init_deform_part_data
UF_ASSEM_deform_part_data_p_t deform_part
UF_ASSEM_initialize_sequencing (view source)
Initializes the sequencing environment.
Must be called before any sequencing playback type Open API function can be called.
Note that the user interface layout may change upon initializing the sequencing task
environment.
assemblies
int UF_ASSEM_initialize_sequencing
UF_ASSEM_initialize_sequencing_keep_layout (view source)
User can keep their current layout when active a sequence.
Initially released in NX 8.5.1
assemblies
int UF_ASSEM_initialize_sequencing_keep_layout
UF_ASSEM_is_component_ngc (view source)
Queries whether the input component is a non-geometric component (NGC)
or not.
Returns TRUE if component_tag is a NGC, FALSE otherwise.
External execution.
Initially released in NX6.0.
logical UF_ASSEM_is_component_ngc
tag_t component_tag
| tag_t | component_tag | Input | the occurence or instance tag |
UF_ASSEM_is_ignored (view source)
Determines if the given part occurrence is marked to be ignored in the
given sequence
int UF_ASSEM_is_ignored
tag_t sequence,
tag_t part_occ,
logical * ignored
| tag_t | part_occ | Input | Tag of the part occurrence |
| logical * | ignored | Output | True if the part occurrence is ignored in the sequence, false otherwise. |
UF_ASSEM_is_member_of_cset (view source)
Allows you to lookup the given component in the given component
set.
int UF_ASSEM_is_member_of_cset
tag_t cset,
tag_t component,
logical * result
| tag_t | cset | Input | Object identifier of a component set |
| tag_t | component | Input | Object identifier of component to be looked up |
| logical * | result | Output | TRUE if component found, otherwise FALSE |
UF_ASSEM_is_occurrence (view source)
Determines whether an object is an object/part occurrence or a
prototype object.
TRUE = if object occurrence or a part occurrence.
FALSE = if object is a prototype object.
logical UF_ASSEM_is_occurrence
tag_t entity
| tag_t | entity | Input | Tag of object |
UF_ASSEM_is_part_deformable (view source)
logical UF_ASSEM_is_part_deformable
tag_t part
UF_ASSEM_is_part_occurrence (view source)
Determines whether a given tag is a part occurrence.
TRUE = if tag is a part occurrence.
FALSE = if tag is not a part occurrence.
logical UF_ASSEM_is_part_occurrence
tag_t occurrence
| tag_t | occurrence | Input | Tag of occurrence |
UF_ASSEM_is_preassembled (view source)
Determines if the given part occurrence is preassembled in the
given sequence
int UF_ASSEM_is_preassembled
tag_t sequence,
tag_t part_occ,
logical * preassembled
| logical * | preassembled | Output | True if the part occurrence is preassembled in the sequence, false otherwise. |
UF_ASSEM_is_ref_set_member (view source)
Queries whether the specified tag is a member of any reference sets.
int UF_ASSEM_is_ref_set_member
tag_t potential_member,
logical * member_flag
| tag_t | potential_member | Input | Tag to test for reference set membership. |
| logical * | member_flag | Output | TRUE if object is in a reference set. |
UF_ASSEM_make_current_step (view source)
Plays back the sequence up to the given step. The given step is not itself played
back - it becomes the step that will be played back next.
assemblies
int UF_ASSEM_make_current_step
tag_t step
| tag_t | step | Input | Tag of the step that will be made current |
UF_ASSEM_move_step (view source)
Moves a step to a different location in it's sequence.
assemblies
int UF_ASSEM_move_step
tag_t step_to_be_moved,
| tag_t | step_to_be_moved | Input | The tag of the step being moved |
| tag_t | insert_at_step | Input | The step to be inserted before. May be null in which case the step is moved to the end of the sequence |
UF_ASSEM_occ_is_in_work_part (view source)
Checks if the part occurrence is in the current work part.
int UF_ASSEM_occ_is_in_work_part
tag_t part_occ,
logical * is_in_work
| tag_t | part_occ | Input | The tag of the part occurrence to check. |
| logical * | is_in_work | Output | TRUE if the part occurrence is in the current work part, FALSE if it is not. |
UF_ASSEM_part_is_descendant (view source)
Queries whether a descendent part is a descendent of a parent part.
The descendent does not have to be a direct child of the parent. This
routine returns a value of TRUE if the same part is given to both
arguments.
Returns TRUE if descendent_part is a descendent
of parent_part, FALSE otherwise.
logical UF_ASSEM_part_is_descendant
tag_t parent_part,
tag_t descendent_part
| tag_t | descendent_part | Input | Tag of descendent part |
UF_ASSEM_playback_animate_to_frame (view source)
Playback a frame-by-frame animation of the specified sequence, from the
current frame to a target frame. The specified sequence will become the
active sequence.
The meaning of the target_frame parameter is equivalent to the "current frame"
combo box in the Sequencing UI. When the sequence duration is N frames, the
target_frame parameter may range from 0 to N inclusive.
The animation speed can be increased by skipping frames. The frame_skip must
be >= 0; when the frame_skip is 0, every frame is drawn.
Internal and External. Please note that in v18, playback
is only implemented as a change of display state. The playback functions
are probably meaningful only in the internal user function environment.
Initially released in NX 8.0.1
assemblies
int UF_ASSEM_playback_animate_to_frame
tag_t sequence,
int target_frame,
int frame_skip
| tag_t | sequence | Input | The sequence to be played back |
| int | target_frame | Input | the frame to stop at |
| int | frame_skip | Input | how many frames to advance at a time |
UF_ASSEM_playback_seek_to_frame (view source)
Seek to a specified playback frame in the given sequence. The sequence will
be advanced to the target frame immediately, without any playback animation.
The specified sequence will become the active sequence.
assemblies
int UF_ASSEM_playback_seek_to_frame
tag_t sequence,
int target_frame
| tag_t | sequence | Input | The tag of the sequence |
UF_ASSEM_playback_sequence (view source)
Playback the given assembly sequence, using the playback_command.
The playback command is one of the enumerated constants
UF_ASSEM_seq_step_forward: step forward until next changed frame
UF_ASSEM_seq_step_backward: step backward until next changed frame
UF_ASSEM_seq_play_forward: fast-forward to end of sequence
UF_ASSEM_seq_play_backward: rewind to start of sequence
Each sequence step has a duration, measured in frames. The step_forward
and step_backward modes of this function advance the sequence frame-by-frame,
with one exception: frames where no motion occurs are skipped.
(For example: assemble and disassemble steps may have durations larger than
one frame, but this function will advance through their entire duration with
one call. Motion steps, on the other hand, will be stepped through
frame-by-frame, because components move between every frame.)
If "Stop Before Collision" has been enabled in the NX UI, then
the step_forward/step_backward modes will not advance to the next frame
if this would cause a collision.
To detect how many frames the sequence has been advanced after a call to
this function, call UF_ASSEM_ask_current_frame before and after
playback and compare the values returned.
assemblies
int UF_ASSEM_playback_sequence
tag_t sequence,
int playback_command
| int | playback_command | Input | One of the enumerated constants UF_ASSEM_seq_step_forward |
UF_ASSEM_preassemble_partocc (view source)
Preassembles the given part occurrence in the sequence. Part occurrences must be
preassembled (or assembled in the sequence) before they can be considered
for disassembly.
The preassembled set can be used to define the initial state of the
assembly sequence.
assemblies
int UF_ASSEM_preassemble_partocc
tag_t sequence,
tag_t part_occ
| tag_t | part_occ | Input | The part occurrence to be preassembled |
UF_ASSEM_register_animation_callback (view source)
Register the customer-supplied callback function .
This callback function will called at end of each frame when play a motion sequence synchronously.
eg.UF_ASSEM_playback_animate_to_frame.
User also can register a user data with this callback function. This user data will be passed as parameter
when this callback function called.
assemblies
int UF_ASSEM_register_animation_callback
UF_ASSEM_animation_callback_f_t callback,
void * user_data
UF_ASSEM_remove_from_cset (view source)
Allows you to remove a component from an existing component set.
It is not an error to attempt to remove a component from a set that is
not a member of that set.
assemblies
int UF_ASSEM_remove_from_cset
tag_t cset,
tag_t component
| tag_t | cset | Input | Object identifier of component set |
| tag_t | component | Input | Object identifier of component to be removed |
UF_ASSEM_remove_ignored (view source)
Removes the given part occurrence from the ignored set of the given
sequence.
assemblies
int UF_ASSEM_remove_ignored
tag_t sequence,
tag_t part_occ
| tag_t | part_occ | Input | The part occurrence to be removed from the ignored set |
UF_ASSEM_remove_instance (view source)
Removes an instance from an assembly part.
assemblies
int UF_ASSEM_remove_instance
tag_t instance
| tag_t | instance | Input | Tag of instance to remove. |
UF_ASSEM_remove_preassembled (view source)
Removes the given part occurrence from the preassembled set of the given
sequence.
assemblies
int UF_ASSEM_remove_preassembled
tag_t sequence,
tag_t part_occ
| tag_t | part_occ | Input | The part occurrence to be removed from the preassembled set |
UF_ASSEM_remove_ref_set_members (view source)
Removes an array of members from the specified reference set.
assemblies
int UF_ASSEM_remove_ref_set_members
tag_t ref_set,
int member_count,
| tag_t | ref_set | Input | Tag of the reference set to remove members from. |
| int | member_count | Input | The number of members to remove |
| tag_t * | ref_set_members | Input | Array of the members to remove. |
UF_ASSEM_remove_sequencing_view (view source)
Remove a view from the list of views used to display sequencing.
This should called after user called the UF_ASSEM_add_sequencing_view() that added views.
assemblies
int UF_ASSEM_remove_sequencing_view
tag_t view
| tag_t | view | Input | The tag of view to remove. |
UF_ASSEM_rename_instance (view source)
Renames an instance from an assembly part. Note that this changes the
instance name, but not the name of the corresponding part occurrence and
not the object name referred to by UF_OBJ_ask_name.
V15.0 change: This function was modified to return an integer error
code which can be passed into UF_get_fail_message.
assemblies
int UF_ASSEM_rename_instance
tag_t instance,
const char * new_name
| tag_t | instance | Input | Tag of instance to rename. |
| const char * | new_name | Input | New name for instance; must be no longer than UF_OBJ_NAME_NCHARS characters. |
UF_ASSEM_replace_refset (view source)
Replace the reference set used by one or more instances or part
occurrences held in the target_tags array. If an instance is specified,
all part occurrences of that instance will use the new reference set.
This routine only works for immediate children of the work part.
If new_refset_name is a NULL pointer or a zero-length string, the
entire part is used. If it is the string "Empty", then none of the part
is displayed.
int UF_ASSEM_replace_refset
int count,
tag_t * target_tags,
const char * new_refset_name
| int | count | Input | Count of part occurrences |
| tag_t * | target_tags | Input | count Array of instance and/or part occurrence tags |
| const char * | new_refset_name | Input | Name of new reference set; must be no longer than UF_OBJ_NAME_NCHARS characters. |
UF_ASSEM_reposition_instance (view source)
Reposition an existing instance to a new position/orientation.
assemblies
int UF_ASSEM_reposition_instance
tag_t instance,
double new_origin [ 3 ] ,
double new_csys_matrix [ 6 ]
| tag_t | instance | Input | tag of instance to reposition |
| double | new_origin [ 3 ] | Input | New orientation of the instance |
| double | new_csys_matrix [ 6 ] | Input | New coordinate system matrix |
UF_ASSEM_reposition_part_occurrence (view source)
Transforms the given part occurrence by the given delta transform, in
the context of the owning-assembly of the part occurrence. The option
is used to control what happens if the given part occ can't be
transformed (because the required explicit override does not exist).
assemblies
int UF_ASSEM_reposition_part_occurrence
tag_t part_occ,
double xform [ 4 ] [ 4 ] ,
UF_ASSEM_level_option_t option
| tag_t | part_occ | Input | The tag of the part occurrence you wish to transform. |
| double | xform [ 4 ] [ 4 ] | Input | A 4x4 delta transform matrix in terms of the displayed part. |
| UF_ASSEM_level_option_t | option | Input | If the given part occurrence can't be transformed, the option determines what happens next. UF_ASSEM_use_strict_level - the operation will fail and return UF_ASSEM_err_operation_requires_override UF_ASSEM_use_existing_level - the operation will instead transform the corresponding part occurrence at the nearest level down in the assembly where an appropriate override exists. If none exists then the instance will be transformed. UF_ASSEM_establish_override - the operation will create an override in the part of the given part occurrence and then perform the transform. |
UF_ASSEM_restore_load_options (view source)
Restores the load options as recorded in the specified load options
file. The file should be in the format of the standard load_options.def
file, although there is no requirement to name the file
"load_options.def".
If NULL is passed in place of the specified file, this function restores
the `load_options.def' file in the current directory if it exists.
If the file passed in does not contain a complete set of load options
settings, the ones that are specified are changed and the others are
left unchanged.
Return code:
0 = No error
1 = The file passed in does not exist or is unreadable
2 = The file passed is not a valid load options file
n = Error code
int UF_ASSEM_restore_load_options
const char * load_options_file
| const char * | load_options_file | Input | The load options file that should be restored. |
UF_ASSEM_restore_work_part_context_quietly (view source)
Restores the previous work part context as returned by UF_ASSEM_set_work_part_context_quietly
and frees previous_work_part_context. After a call to this routine, previous_work_part_context
will be NULL.
int UF_ASSEM_restore_work_part_context_quietly
UF_ASSEM_work_part_context_p_t* previous_work_part_context
| UF_ASSEM_work_part_context_p_t* | previous_work_part_context | Input / Output | The work part context returned by UF_ASSEM_set_work_part_context_quietly. Will automatically be freed by this function. |
UF_ASSEM_revert_explode_comp (view source)
Explodes a component back to its normal assembly position. In
general, exploding a component causes its own components to move
with it. This function sets the component such that it always (and
associatively) retains its real position.
Exploding or unexploding the component loses this setting, and it
then explodes from the explosion position given by its parents in the
assembly.
assemblies
int UF_ASSEM_revert_explode_comp
tag_t explosion,
tag_t component
| tag_t | component | Input | the tag of a part occurrence not instance |
UF_ASSEM_set_active_arrangement (view source)
Sets which is the Active Assembly Arrangement in its part. (The part is
deduced from the given arrangement.) This is the Assembly Arrangement
which would take effect for it if that part were made the Displayed Part.
If it is currently the displayed part, then the component positions will
be updated immediately as appropriate.
Initially released in NX2.
assemblies
int UF_ASSEM_set_active_arrangement
tag_t arrangement
| tag_t | arrangement | Input | The new Active Assembly Arrangement |
UF_ASSEM_set_assem_load_options (view source)
Set the current settings of the assembly options. To assure that your
program continues to work correctly with future versions of Open
API, we recommend that you call UF_ASSEM_ask_assem_load_options to
initialize your options structure before setting the values you desire to
set/modify. New options may be added to the UF_ASSEM_load_options_s
structure in the future. For NX12 and later.
int UF_ASSEM_set_assem_load_options
UF_ASSEM_load_options_t * options
UF_ASSEM_set_assem_options (view source)
API, we recommend that you call UF_ASSEM_ask_assem_options to
set/modify. New options may be added to the UF_ASSEM_options_s
int UF_ASSEM_set_assem_options
UF_ASSEM_options_t * options
UF_ASSEM_set_auto_add_new_comps (view source)
Set whether new components will be added to the specified reference set
automatically or not.
External execution.
assemblies
int UF_ASSEM_set_auto_add_new_comps
tag_t ref_set,
logical add_new_comps
| tag_t | ref_set | Input | The reference set |
| logical | add_new_comps | Input | Whether new components are to be added automatically |
UF_ASSEM_set_cost_of_step (view source)
Assign a cost to the given step
assemblies
int UF_ASSEM_set_cost_of_step
tag_t step,
double assign_cost
| tag_t | step | Input | The tag of the given step |
| double | assign_cost | Input | The cost to be assigned to the step |
UF_ASSEM_set_default_arrangement (view source)
Set the Default Assembly Arrangement for its
part. (The part is deduced from the given arrangement.)
This is the Assembly Arrangement which would
used by a new parent assembly if this part were added
to that parent as a new component. No components are
repositioned as a result of calling this function.
External execution.
assemblies
int UF_ASSEM_set_default_arrangement
tag_t arrangement
| tag_t | arrangement | Input | The new Default Assembly Arrangement for its part |
UF_ASSEM_set_default_ref_sets (view source)
Applies the specified reference sets as the defaults in the order supplied.
The default reference sets must have "As Saved", "Entire Part" and
"Empty" in the list. If any of these are not specified in the supplied
list, they are added to the end of the list in that order.
Original release was in V13.0.
int UF_ASSEM_set_default_ref_sets
int n_ref_sets,
char * * default_ref_sets
| int | n_ref_sets | Input | The number of default reference sets being set. |
| char * * | default_ref_sets | Input | An ordered array of reference set names indicating the default reference sets. |
UF_ASSEM_set_instance_intent (view source)
Assigns intent data to an instance.
assemblies
int UF_ASSEM_set_instance_intent
tag_t instance,
UF_ASSEM_instance_intent_p_t instance_intent
UF_ASSEM_set_ref_set_by_cset (view source)
Changes the reference set representing each component to a
reference set of the given name. If no reference set exists with that
name then the component is left as it was.
int UF_ASSEM_set_ref_set_by_cset
tag_t cset,
const char * cname
| tag_t | cset | Input | Set of components to set reference set for |
| const char * | cname | Input | Name of reference set to represent each component by. The entire part reference set can be set by entering "None" as the reference set name. |
UF_ASSEM_set_save_trueshape (view source)
Set the save true shape data option to the input value
int UF_ASSEM_set_save_trueshape
logical save_trueshape_data
| logical | save_trueshape_data | Input | Flag indicating whether true shape data should be saved. (TRUE = save true shape data, FALSE = do not save true shape data) |
UF_ASSEM_set_search_directories (view source)
Sets the list of the search directories. You must call
UF_ASSEM_set_assem_options to enable the use of search
directories.
This function may return the following non-standard error codes:
1 if at least one of the directories was bad
2 if all the directories were bad
All other error codes can be processed using UF_get_fail_message.
int UF_ASSEM_set_search_directories
int count,
char * * dir_list,
logical sub_dir [ ]
| int | count | Input | The number of directories in the list. |
| char * * | dir_list | Input | An array of "count" pointers to character strings containing the directory names. |
| logical | sub_dir [ ] | Input | An array of "count" logicals. Each logical is TRUE if the subdirectories of the corresponding directory should be searched, or FALSE if the subdirectories should not be searched. |
UF_ASSEM_set_sequence_description (view source)
Sets the description of the given sequence.
assemblies
int UF_ASSEM_set_sequence_description
tag_t sequence,
char * desc
| char * | desc | Input | The description to be assigned to the sequence |
UF_ASSEM_set_sequence_name (view source)
Sets the name of the given sequence.
assemblies
int UF_ASSEM_set_sequence_name
tag_t sequence,
char * name
UF_ASSEM_set_step_increment (view source)
Sets the step increment of the given sequence. By default, the step increment
for a newly created sequence is 10.
assemblies
int UF_ASSEM_set_step_increment
tag_t sequence,
int increment
| int | increment | Input | The step increment for the sequence |
UF_ASSEM_set_suppression_exp (view source)
Assigns an expression to control the suppress state of the given instance.
assemblies
int UF_ASSEM_set_suppression_exp
tag_t instance,
const char * exp_string,
tag_t * exp_tag
| tag_t | instance | Input | The tag of the instance to assign the suppression expression for. |
| const char * | exp_string | Input | Expression string to use. If the expression already exists in the instance's part, then that expression will be used. You can use UF_MODL_ask_exp_tag_string to get the expression string for an existing expression. |
| tag_t * | exp_tag | Output | Expression tag for the given expression string. |
UF_ASSEM_set_time_of_step (view source)
Assign a time to the given step
assemblies
int UF_ASSEM_set_time_of_step
tag_t step,
double assign_time
| double | assign_time | Input | The time to be assigned to the step |
UF_ASSEM_set_used_arrangement (view source)
Sets the Used Assembly Arrangement for a given
part of that component. The positions of the
components beneath the given component are updated
as appropriate.
External execution.
assemblies
int UF_ASSEM_set_used_arrangement
tag_t component,
tag_t arrangement
| tag_t | component | Input | The component to modify |
| tag_t | arrangement | Input | The new Used Assembly Arrangement for that Component |
UF_ASSEM_set_view_explosion (view source)
Sets the explosion used in a view; the view may already have an
explosion in which case it is replaced. Drafting view-dependent
geometry such as dimensions and silhouettes is appropriately adjusted
or marked for update. "explosion" may be NULL_TAG, in which
case the view is reset to having no explosion if one was in use.
assemblies
int UF_ASSEM_set_view_explosion
tag_t view,
tag_t explosion
| tag_t | view | Input | The view which should be associated with (and therefore display) the given explosion. |
| tag_t | explosion | Input | The explosion to use. |
UF_ASSEM_set_work_occurrence (view source)
Set the work part and work occurrence to part_occur. This routine sets
just the work part, not the displayed part. If you set the work part
to a partially loaded part, the system finishes loading the part.
int UF_ASSEM_set_work_occurrence
tag_t part_occur
UF_ASSEM_set_work_part (view source)
Sets the work part to a different part. If part is NULL_TAG, the work
part is set to the displayed part. This routine sets just the work part,
not the displayed part. This routine only modifies the work part in an
assembly. If not working in an assembly, use UF_PART_set_display_part.
If there is more than one occurrence in the displayed part, the first one
is chosen. If you set the work part to a partially loaded part, the
In V16.0 this function was changed to no longer perform an update.
If an update is required, the calling program must now specifically
call UF_MODL_update.
int UF_ASSEM_set_work_part
tag_t part
| tag_t | part | Input | Tag of part to be set as work part. |
UF_ASSEM_set_work_part_context_quietly (view source)
Sets the work part to a different part quietly. Setting the work part quietly
sets the work part without updating the display or any other parts of the NX user
interface in an interactive NX session.
By doing this, objects can be created in other than the current work part
(which most Open API routines currently rely on).
This routine is primarily designed to temporarily change the work part to a component
in the current displayed assembly without updating NX display or NX user interface to reflect
the new work part. Another use case is to open a part without displaying by calling UF_PART_open_quiet,
and then setting it as the work part quietly with this routine.
This routine will return an error if the given part is not already fully loaded.
This routine should be used with great care and the previous work part context
should be restored immediately with UF_ASSEM_restore_work_part_context_quietly,
using the previous_work_part_context output by this routine.
Between the call to this function and UF_ASSEM_restore_work_part_context_quietly it is not
expected that the display part changes.
This routine does not expect the root and work part that are active at the time it is called
to become invalid before UF_ASSEM_restore_work_part_context_quietly is called.
A call to UF_ASSEM_restore_work_part_context_quietly will free the output previous_work_part_context.
Warning:
This routine can be used when necessary to perform operations in parts which are
not the work part. The function should always be called in conjunction with
UF_ASSEM_restore_work_part_context_quietly. Call UF_ASSEM_set_work_part_context_quietly
before the desired operation is performed and then call UF_ASSEM_restore_work_part_context_quietly
immediately after the operation has been performed.
Actions that cannot be performed interactively are not supported with this routine.
Avoid using this function with the Advanced Simulation application, when a drawing sheet is displayed,
or any application that does not support situations where the work part is different from the display part.
int UF_ASSEM_set_work_part_context_quietly
tag_t part_tag,
| tag_t | part_tag | Input | The tag of the part to become the new work part |
| UF_ASSEM_work_part_context_p_t* | previous_work_part_context | Output to UF_*free* | The previous work part context at the time this routine was called (NX should be reset to this immediately after completing the context sensitive operations.) |
UF_ASSEM_show_component (view source)
Unhide the given component in the given view.
assemblies
int UF_ASSEM_show_component
tag_t component,
tag_t view
| tag_t | view | Input | The view in which to un-hide the component |
UF_ASSEM_substitute_component (view source)
Replaces the part used by an instance with a new part. The instance to
be replaced must be an instance of the work part. This operation is
equivalent to deleting the instance and creating a new one so that the
old instance tag is no longer valid after a call to this routine. Instead,
the tag of the new instance is returned.
assemblies
int UF_ASSEM_substitute_component
tag_t * instance,
const char * new_part_version,
const char * new_comp_name,
const char * new_refset_name,
int layer,
| tag_t * | instance | Input / Output | Pointer to tag of instance |
| const char * | new_part_version | Input | Name of new component part version |
| const char * | new_comp_name | Input | Name of new component; must be no longer than UF_OBJ_NAME_NCHARS characters. |
UF_ASSEM_suppress_array (view source)
Suppress a component array so that it no longer updates. Note that
the appearance of the array does not change.
assemblies
int UF_ASSEM_suppress_array
tag_t array
| tag_t | array | Input | Tag of array to be suppressed. |
UF_ASSEM_suppress_instances (view source)
Suppresses the given instances. This function returns the first error code
found in the failures array, or 0 if there were no errors.
assemblies
int UF_ASSEM_suppress_instances
int n_instances,
tag_t instances [ ] ,
int failures [ ]
| int | n_instances | Input | The number of instances to suppress. |
| tag_t | instances [ ] | Input | The tags of the instances to suppress. |
| int | failures [ ] | Output | Failure codes for each instance (0 if no failure) |
UF_ASSEM_terminate_sequencing (view source)
Terminates the sequencing environment.
Must be called when no further sequencing operations are intended.
Initially released in NX 3.0
assemblies
int UF_ASSEM_terminate_sequencing
UF_ASSEM_unexplode_component (view source)
Unexplodes a component by setting the explosion transform of a
component to NULL. The new position of the component in the
explosion is the position of its parent plus its normal assembly
transform.
assemblies
int UF_ASSEM_unexplode_component
tag_t explosion,
| tag_t | part_occurrence | Input | The component (its part occurrence) |
UF_ASSEM_unset_suppression_exp (view source)
Removes the dependency on an expression for the given instance's suppress state.
assemblies
int UF_ASSEM_unset_suppression_exp
tag_t instance
| tag_t | instance | Input | The tag of the instance to remove suppression by expression from. |
UF_ASSEM_unsuppress_array (view source)
Unsuppress a component array so that it updates.
assemblies
int UF_ASSEM_unsuppress_array
tag_t array
| tag_t | array | Input | Tag of array to unsuppress. |
UF_ASSEM_unsuppress_instances (view source)
Unsuppresses the given instances. This function returns the first error code
assemblies
int UF_ASSEM_unsuppress_instances
int n_instances,
int failures [ ]
UF_ASSEM_update_component_group (view source)
Updates the input component group if present on the input part.
External execution.
Initially released in NX8.0.
adv_assemblies
int UF_ASSEM_update_component_group
const tag_t part_tag,
const char* component_group_name,
logical do_update_structure
| const tag_t | part_tag | Input | part whose component group is to be updated |
| const char* | component_group_name | Input | name of component group which is to be updated |
| logical | do_update_structure | Input | whether to update the structure before updating the component group |
UF_ASSEM_upgrade_to_instances (view source)
Upgrade the components in an assembly in a part to use instances. If
upgrade fails, then upgrade_status contains failure codes for each
component that failed to upgrade.
Returns TRUE if successful; otherwise returns FALSE.
assemblies
logical UF_ASSEM_upgrade_to_instances
tag_t part,
int n_components,
tag_t * components,
logical recurse,
logical create_component,
UF_ASSEM_upgrade_status_t * upgrade_status
| tag_t | part | Input | Tag of part containing components to be upgraded |
| int | n_components | Input | Number of components in the "components" array |
| tag_t * | components | Input | n_components Array of old style components to be upgraded |
| logical | recurse | Input | TRUE = recurse thru listed components upgrading their subassemblies; FALSE = only upgrade components listed |
| logical | create_component | Input | FALSE = look for v10 part in memory and disk and update with part if found; otherwise fail to upgrade component TRUE = Try above, if part not found create part in current directory and move geometry to it |
| UF_ASSEM_upgrade_status_t * | upgrade_status | Output to UF_*free* | Contains failure code for each component that failed to upgrade. Structure arrays must be freed with UF_free. |
UF_ASSEM_use_alternate (view source)
be modified must be an instance of the work part.
Assuming that the old and new parts have been defined as alternates,
the substitution maintains any mating conditions which involve the old
part. See the Alternates section of the Assemblies User Manual.
This function can be called in exactly the same way as
UF_ASSEM_substitute_component except that it is not possible to
change the component's layer using this option. Note, however, that
the instance tag is not changed by this function.
assemblies
int UF_ASSEM_use_alternate
tag_t* instance,
const char * new_part,
| tag_t* | instance | Input | Pointer to tag of instance |
| const char * | new_part | Input | Name of the new part to use in place of the old part |
| const char * | new_comp_name | Input | New name of the component; must be no longer than UF_OBJ_NAME_NCHARS characters. |
| const char * | new_refset_name | Input | Name of reference set to use; must be no longer than UF_OBJ_NAME_NCHARS characters. |
UF_ASSEM_where_is_part_used (view source)
Asks for the list of parent part tags that have the requested part as an
immediate child in the current session. A parent part appears in the
returned array once for each time it is a parent of the given part. So
given wheel in auto you would see axle twice.
CAUTION: Do not confuse this command with the "where-used" function.
Return the number of parent parts found.
int UF_ASSEM_where_is_part_used
tag_t part,
tag_t * * parent_parts
| tag_t | part | Input | Tag of child part for query |
| tag_t * * | parent_parts | Output to UF_*free* | Allocated array of tags of parent parts. The parent_parts array must be freed with UF_free when it is no longer needed. |
UF_ASSEM_where_used_report (view source)
Displays a where used report to the listing device for the given
component filename. A list of files and corresponding error codes are
allocated and returned in the load_status structure for any files that
could not be processed successfully.
This function will not work in NXManager mode. An error is not returned
and there will be no results returned in load_status structure.
int UF_ASSEM_where_used_report
const char * comp_name,
const char * dir,
int search_opt,
logical do_all_levels,
| const char * | comp_name | Input | Component file name. This should be the simple name without a directory path. |
| const char * | dir | Input | specified directory if search_opt = 2 |
| int | search_opt | Input | search options 0 = use search directories 1 = use component directory 2 = use <dir> |
| logical | do_all_levels | Input | report all levels of the assembly tree in which a component is found |
