UF_EVAL_ask_arc (view source)
Defined in: uf_eval.h
Returns the arc data of the evaluator of a circular curve or edge.
Originally released in V15.0
int UF_EVAL_ask_arc
UF_EVAL_p_t evaluator,
UF_EVAL_arc_p_t arc
| UF_EVAL_p_t | evaluator | Input | evaluator structure for the curve. This must be an arc, or an error will be returned. |
| UF_EVAL_arc_p_t | arc | Output | arc data |
UF_EVAL_ask_ellipse (view source)
Returns the ellipse data of the evaluator of an elliptical curve or
edge.
int UF_EVAL_ask_ellipse
UF_EVAL_ellipse_p_t ellipse
| UF_EVAL_p_t | evaluator | Input | evaluator structure for the curve. This must be an ellipse, or an error will be returned. |
| UF_EVAL_ellipse_p_t | ellipse | Output | ellipse data |
UF_EVAL_ask_hyperbola (view source)
Returns the hyperbola data of the evaluator of a hyperbolic curve.
There are no hyperbolic edges in NX.
int UF_EVAL_ask_hyperbola
UF_EVAL_hyperbola_p_t hyperbola
| UF_EVAL_p_t | evaluator | Input | evaluator structure for the curve. This must be a hyperbola, or an error will be returned. |
| UF_EVAL_hyperbola_p_t | hyperbola | Output | hyperbola data |
UF_EVAL_ask_limits (view source)
Returns the curve limits of the evaluator of a curve or edge.
int UF_EVAL_ask_limits
double limits [ 2 ]
| UF_EVAL_p_t | evaluator | Input | evaluator structure |
| double | limits [ 2 ] | Output | limits |
UF_EVAL_ask_line (view source)
Returns the line data of the evaluator of a linear curve or edge
int UF_EVAL_ask_line
UF_EVAL_line_p_t line
| UF_EVAL_p_t | evaluator | Input | evaluator structure of the curve. This must be a line, or an error will be returned. |
| UF_EVAL_line_p_t | line | Output | The data for this line. |
UF_EVAL_ask_parabola (view source)
Returns the parabola data from the evaluator of a parabolic curve.
There are no parabolic edges in NX.
int UF_EVAL_ask_parabola
UF_EVAL_parabola_p_t parabola
| UF_EVAL_p_t | evaluator | Input | evaluator structure for the curve. This must be a parabola, or an error will be returned. |
| UF_EVAL_parabola_p_t | parabola | Output | parabola data |
UF_EVAL_ask_spline (view source)
Returns the spline data of the evaluator of a spline curve or edge
int UF_EVAL_ask_spline
UF_EVAL_spline_p_t spline
| UF_EVAL_p_t | evaluator | Input | evaluator structure for the curve. This must be a spline, or an error will be returned. |
| UF_EVAL_spline_p_t | spline | Output | spline data |
UF_EVAL_ask_spline_control_pts (view source)
Returns the spline control points of the evaluator of a spline curve or
edge.
int UF_EVAL_ask_spline_control_pts
int * n_points,
double * * points
| int * | n_points | Output | count of control points |
| double * * | points | Output to UF_*free* | For each control point, four values are returned, ( wx, wy, xz, w ). This array must be freed by calling UF_free. |
UF_EVAL_ask_spline_knots (view source)
Returns the spline knots of the evaluator of a spline curve or edge.
int UF_EVAL_ask_spline_knots
int * n_knots,
double * * knots
| int * | n_knots | Output | count of knots in sequence |
| double * * | knots | Output to UF_*free* | knot sequence points, the parameter values for each knot point in the spline. This array must be freed by calling UF_free. These parameters are not normalized. |
UF_EVAL_copy (view source)
Copies the evaluator of an curve or edge.
Return copy of evaluator structure.
int UF_EVAL_copy
UF_EVAL_p_t * evaluator_copy
| UF_EVAL_p_t | evaluator | Input | Evaluator structure to copy |
| UF_EVAL_p_t * | evaluator_copy | Output to UF_*free* | Copy of the evaluator structure. This must be freed by calling UF_EVAL_free. |
UF_EVAL_evaluate (view source)
Evaluates a point or the derivatives of an evaluator of a curve or edge
int UF_EVAL_evaluate
int n_derivatives,
double parm,
double point [ 3 ] ,
double derivatives [ ]
| UF_EVAL_p_t | evaluator | Input | Evaluator structure for the curve. |
| int | n_derivatives | Input | number of derivative vectors |
| double | parm | Input | Parameter to evaluate the curve at. This parameter is not normalized. The parameter limits for a given curve can be found by calling UF_EVAL_ask_limits. |
| double | point [ 3 ] | Output | point on curve |
| double | derivatives [ ] | Output | Derivative vectors on the curve. The caller is responsible for providing space to return 3n_derivatives real numbers. |
UF_EVAL_evaluate_closest_point (view source)
Returns the closest parameter point on the curve or edge given a
specified reference point. Note that parameters returned are not
normalized.
int UF_EVAL_evaluate_closest_point
const double reference_point [ 3 ] ,
double * parm,
double closest_point [ 3 ]
| UF_EVAL_p_t | evaluator | Input | The evaluator structure of the curve. |
| const double | reference_point [ 3 ] | Input | The reference point |
| double * | parm | Output | The parameter of the closest point on the curve to the reference point. This parameter is not normalized. |
| double | closest_point [ 3 ] | Output | The closest point on the curve to the reference point. |
UF_EVAL_evaluate_unit_vectors (view source)
Evaluates a point or the unit vectors of an evaluator of a curve or edge.
int UF_EVAL_evaluate_unit_vectors
double parm,
double tangent [ 3 ] ,
double normal [ 3 ] ,
double binormal [ 3 ]
| UF_EVAL_p_t | evaluator | Input | The evaluator structure for the curve. |
| double | parm | Input | The parameter to evaluate at. Note that the parameter is not normalized. You can get the parameters for the given evaluator structure by calling UF_EVAL_ask_limits. |
| double | point [ 3 ] | Output | The point on the curve |
| double | tangent [ 3 ] | Output | The tangent to the curve at that point. |
| double | normal [ 3 ] | Output | The normal to the curve at that point. |
| double | binormal [ 3 ] | Output | The binormal to the curve at that point. |
UF_EVAL_free (view source)
Frees the evaluator of a curve or edge.
int UF_EVAL_free
| UF_EVAL_p_t | evaluator | Input | evalauator structure to be freed |
UF_EVAL_initialize (view source)
Initialize an evaluator structure.
Returns a pointer to the evaluator of a curve or edge. The evaluator
can be used to find points, derivatives and vectors of a curve or edge
at a given parameter value. No longer use
UF_CURVE_ask_curve_struct ( ),
UF_CURVE_ask_curve_struct_data ( ) and
UF_CURVE_free_curve_struct ( ).
Note that this API will approximate procedurally created edges (such as
edges created by intersecting two surfaces) with a spline to the current
Modeling distance tolerance.
int UF_EVAL_initialize
tag_t tag,
| tag_t | tag | Input | Object identifier of a curve or edge |
| UF_EVAL_p_t * | evaluator | Output to UF_*free* | Evaluator structure for this curve. It must be freed by calling UF_EVAL_free. |
UF_EVAL_initialize_2 (view source)
This API will not approximate procedurally created edges.
Originally released in NX7.0
int UF_EVAL_initialize_2
tag_t tag,
UF_EVAL_is_arc (view source)
Determines if the given evaluator is from a circular curve or edge.
int UF_EVAL_is_arc
logical * is_arc
| UF_EVAL_p_t | evaluator | Input | evaluator structure of the curve |
| logical * | is_arc | Output | TRUE if this is an arc, else FALSE |
UF_EVAL_is_ellipse (view source)
Determines if the evaluator is from an elliptical curve or edge
int UF_EVAL_is_ellipse
logical * is_ellipse
| UF_EVAL_p_t | evaluator | Input | evaluator structure of the curve. |
| logical * | is_ellipse | Output | TRUE if this is an ellipse, else FALSE |
UF_EVAL_is_equal (view source)
Determines if two evaluators are equal. This implies that the curve(s)
and/or edge(s) are equal.
int UF_EVAL_is_equal
UF_EVAL_p_t evaluator1,
UF_EVAL_p_t evaluator2,
logical * is_equal
| UF_EVAL_p_t | evaluator1 | Input | evaluator structure for the first curve |
| UF_EVAL_p_t | evaluator2 | Input | evaluator structure for the second curve |
| logical * | is_equal | Output | TRUE if the curves are equal, else FALSE |
UF_EVAL_is_hyperbola (view source)
Determines if the evaluator is from a hyperbolic curve. There are no
int UF_EVAL_is_hyperbola
logical * is_hyperbola
| logical * | is_hyperbola | Output | TRUE if the curve is a hyperbola, else FALSE |
UF_EVAL_is_line (view source)
Determines if the evaluator is from a linear curve or edge.
int UF_EVAL_is_line
logical * is_line
| logical * | is_line | Output | TRUE if this is a line, else FALSE |
UF_EVAL_is_parabola (view source)
Determines if the evaluator is from a parabolic curve. There are no
int UF_EVAL_is_parabola
logical * is_parabola
| logical * | is_parabola | Output | TRUE if the curve is a parabola, else FALSE |
UF_EVAL_is_periodic (view source)
Query if the input curve is periodic.
Determines if the evaluator is from a periodic curve or edge.
int UF_EVAL_is_periodic
logical * is_periodic
| UF_EVAL_p_t | evaluator | Input | evaluator structure for the curve. |
| logical * | is_periodic | Output | TRUE if the curve is periodic, else FALSE |
UF_EVAL_is_spline (view source)
Determines if the evaluator is from a spline curve or edge.
int UF_EVAL_is_spline
logical * is_spline
| logical * | is_spline | Output | TRUE if the curve is a spline, else FALSE |
UF_EVALSF_ask_face_uv_minmax (view source)
Defined in: uf_evalsf.h
Computes the u,v parameter space min, max of a face
int UF_EVALSF_ask_face_uv_minmax
UF_EVALSF_pc_t evaluator,
double uv_min_max [ 4 ]
| UF_EVALSF_pc_t | evaluator | Input | Address of evaluator structure |
| double | uv_min_max [ 4 ] | Output | [0] - umin [1] - umax [2] - vmin [3] - vmax |
UF_EVALSF_ask_minimum_face_dist (view source)
Returns the minimum distance parameter and point on the surface of a face
given a reference point.
The surface point is on the portion which is bounded by the edges of the face.
To find the closest point on the extended surface (not within bounding edges)
use UF_EVALSF_find_closest_point
int UF_EVALSF_ask_minimum_face_dist
const double point [ 3 ] ,
UF_EVALSF_pos3_p_t srf_pos3
| const double | point [ 3 ] | Input | Given point in absolute space |
| UF_EVALSF_pos3_p_t | srf_pos3 | Output | Address of point position on surface |
UF_EVALSF_evaluate (view source)
Evaluates a point and the derivatives of a face at the given parameter value.
UF_MODL_evaluate_face and UF_MODL_ask_face_props
Note that UF_EVALSF_evaluate may not properly handle parameter values
returned by UF_EVALSF_find_closest_point or similar functions for
surface types Blend or Trimmed B-surface. The above functions should be
called instead.
int UF_EVALSF_evaluate
int deriv_flag,
const double uv_pair [ 2 ] ,
UF_MODL_SRF_VALUE_p_t surf_eval
| int | deriv_flag | Input | order of the derivative to be computed: UF_MODL_EVAL - position UF_MODL_EVAL_DERIV1 - position and 1. partial UF_MODL_EVAL_DERIV2 - position, 1. and 2. partials UF_MODL_EVAL_DERIV3 - position, 1., 2. and 3. partials UF_MODL_EVAL_UNIT_NORMAL - position, 1. partials and unitized normal. UF_MODL_EVAL_NORMAL - position, 1. partials and the ununitized normal. UF_MODL_EVAL_ALL - position, normals and all the partials up to the third order. |
| const double | uv_pair [ 2 ] | Input | uv-parameter pair at which derivatives are to be computed. The parameter limits for a given face can be found by calling UF_EVALSF_ask_face_uv_minmax. |
| UF_MODL_SRF_VALUE_p_t | surf_eval | Output | Address of evaluation result structure containing position and derivatives: srf_pos[3] - position srf_du[3] - d/du srf_dv[3] - d/dv srf_unormal[3] - unit normal srf_d2u[3] - d2/du2 srf_dudv[3] - d2/dudv srf_d2v[3] - d2/dv2 srf_d3u[3] - d3/du3 srf_d2udv[3] - d3/du2dv srf_dud2v[3] - d3/dud2v srf_d3v[3] - d3/dv3 srf_normal[3] - d/du X d/dv |
UF_EVALSF_evaluate_array (view source)
Evaluates an array of points and derivatives of a face for a given array of parameter values.
Note that UF_EVALSF_evaluate_array may not properly handle parameter values
called instead.
int UF_EVALSF_evaluate_array
int deriv_flag,
int num_points,
const double uv_pairs [ ] ,
UF_MODL_SRF_VALUE_t surf_evals [ ]
| int | num_points | Input | number of points to evaluate |
| const double | uv_pairs [ ] | Input | num_points uv-parameter pairs The parameter limits for a given face can be found by calling UF_EVALSF_ask_face_uv_minmax. |
| UF_MODL_SRF_VALUE_t | surf_evals [ ] | Output | Address of array of evaluation results The caller must provide space of size = sizeof(UF_MODL_SRF_VALUE_t) num_points Each structure element contains: srf_pos[3] - position srf_du[3] - d/du srf_dv[3] - d/dv srf_unormal[3] - unit normal srf_d2u[3] - d2/du2 srf_dudv[3] - d2/dudv srf_d2v[3] - d2/dv2 srf_d3u[3] - d3/du3 srf_d2udv[3] - d3/du2dv srf_dud2v[3] - d3/dud2v srf_d3v[3] - d3/dv3 srf_normal[3] - d/du X d/dv |
UF_EVALSF_find_closest_point (view source)
Finds on the surface the closest point and uv-parameter pair to a given point.
Note that the returned point will be on the underlying surface
but may not be on the portion which is bounded by the edges
of the face.
Note that in some cases, there is a potential risk that the returned point might
be adjusted incorrectly where the underlying surface has an extended UV range.
Please use UF_EVALSF_find_closest_point_2 instead.
To find the closest point within bounding edges, use
int UF_EVALSF_find_closest_point
UF_EVALSF_find_closest_point_2 (view source)
of the face.
int UF_EVALSF_find_closest_point_2
UF_EVALSF_free (view source)
Frees the evaluator of a face
int UF_EVALSF_free
UF_EVALSF_p_t * evaluator
| UF_EVALSF_p_t * | evaluator | Output | address of evaluator pointer |
UF_EVALSF_initialize (view source)
Initializes a face evaluator structure
int UF_EVALSF_initialize
tag_t face_tag,
| tag_t | face_tag | Input | Object identifier of a face |
| UF_EVALSF_p_t * | evaluator | Output to UF_*free* | Evaluator structure for this face. It must be freed by calling UF_EVALFS_free. |
UF_EVALSF_initialize_2 (view source)
Initializes a face evaluator structure with correct parameter mapping
int UF_EVALSF_initialize_2
tag_t face_tag,
