UF_SO_ask_3_scalars_of_point (view source)
Defined in: uf_so.h
Find the x, y and z values of a smart point.
int UF_SO_ask_3_scalars_of_point
tag_t so_point,
tag_t scalars [ 3 ]
| tag_t | so_point | Input | Tag of the smart point |
| tag_t | scalars [ 3 ] | Output | Array that holds the three scalars |
UF_SO_ask_assy_ctxt_part_occ (view source)
Defined in: uf_so.h
Given a to_part_occ for the assy_context xform, get the corresponding
from_part_occ (i.e. one that is part of the same assembly part occ
tree). The to_part_occ must be one whose prototype part contains the
assy_context xform. Returns an error if given a non-assy_context
xform object.
Original release was in V14.0.
int UF_SO_ask_assy_ctxt_part_occ
const tag_t assy_context_xform,
const tag_t to_part_occ,
tag_p_t from_part_occ
| const tag_t | assy_context_xform | Input | Tag of assy_context transform |
| const tag_t | to_part_occ | Input | to_part_occ giving assy context. |
| tag_p_t | from_part_occ | Output | from_part_occ corresponding to given to_part_occ. |
UF_SO_ask_children (view source)
Defined in: uf_so.h
Asks smart object children of object.
Original Release was in V15.0.
int UF_SO_ask_children
const tag_t object,
int options,
int * n_children,
tag_p_t * children
| const tag_t | object | Input | Tag of object on which to inquire smart object children. |
| int | options | Input | What kind of children (bit mask) UF_SO_ASK_SO_CHILDREN - Ask referencing smart objects. UF_SO_ASK_CHILDREN_RECURSIVELY - Ask referencing objects recursively. UF_SO_ASK_FEATURE_CHILDREN - Ask referencing features. UF_SO_ASK_ALL_CHILDREN - Ask all referencing features. |
| int * | n_children | Output | number of childen |
| tag_p_t * | children | Output to UF_*free* | Smart object children of object. This array must be freed by calling UF_free. |
UF_SO_ask_direction_of_axis (view source)
Defined in: uf_so.h
Returns direction of axis.
Original Release was in V13.0.
int UF_SO_ask_direction_of_axis
const tag_t axis,
double direction [ 3 ]
| const tag_t | axis | Input | Tag of axis |
| double | direction [ 3 ] | Output | Value of axis direction |
UF_SO_ask_direction_of_dirr (view source)
Defined in: uf_so.h
Returns the value of direction.
int UF_SO_ask_direction_of_dirr
const tag_t direction,
double dir [ 3 ]
| const tag_t | direction | Input | Tag of direction |
| double | dir [ 3 ] | Output | Value of direction |
UF_SO_ask_dirr_on_surf (view source)
Defined in: uf_so.h
Inquire a direction on surface smart object.
Originally released in V18.0.
int UF_SO_ask_dirr_on_surf
tag_t direction,
UF_SO_dirr_on_surf_data_p_t dirr_on_surf_data
| tag_t | direction | Input | object id of the direction on surface |
| UF_SO_dirr_on_surf_data_p_t | dirr_on_surf_data | Output | pointer to Open API data structure for direction on surface |
UF_SO_ask_display_marker_of_point (view source)
Defined in: uf_so.h
Returns the display marker type for a point
Original Release was in V16.0.
int UF_SO_ask_display_marker_of_point
tag_t point,
UF_DISP_poly_marker_t * disp_marker
UF_SO_ask_double_of_scalar (view source)
Defined in: uf_so.h
Returns value of a scalar.
int UF_SO_ask_double_of_scalar
const tag_t scalar,
double * dbl
| const tag_t | scalar | Input | Tag of scalar |
| double * | dbl | Output | Value of scalar |
UF_SO_ask_exp_of_scalar (view source)
Defined in: uf_so.h
Returns the expression of the smart scalar object which was created
with UF_SO_create_scalar_exp.
int UF_SO_ask_exp_of_scalar
const tag_t scalar,
tag_p_t exp
UF_SO_ask_matrix_of_xform (view source)
Defined in: uf_so.h
Returns matrix of transform.
int UF_SO_ask_matrix_of_xform
tag_t xform,
double matrix [ 16 ]
| tag_t | xform | Input | Tag of transform |
| double | matrix [ 16 ] | Output | 4 x 4 transform matrix |
UF_SO_ask_offset_curve_cvtr (view source)
Defined in: uf_so.h
Inquire a curvature on curve smart offset object.
int UF_SO_ask_offset_curve_cvtr
tag_t curvature,
UF_SO_offset_curve_cvtr_data_p_t offset_curve_cvtr_data
| tag_t | curvature | Input | object id of the smart offset for curvature on curve |
| UF_SO_offset_curve_cvtr_data_p_t | offset_curve_cvtr_data | Output | pointer to Open API data structure for curvature on curve |
UF_SO_ask_offset_of_offset (view source)
Defined in: uf_so.h
Returns offset vector of specified offset object.
int UF_SO_ask_offset_of_offset
const tag_t offset,
double offset_vec [ 3 ]
| const tag_t | offset | Input | Tag of offset |
| double | offset_vec [ 3 ] | Output | Value of offset |
UF_SO_ask_offset_surf_cvtr (view source)
Defined in: uf_so.h
Inquire a curvature on surface smart offset object.
int UF_SO_ask_offset_surf_cvtr
tag_t curvature,
UF_SO_offset_surf_cvtr_data_p_t offset_surf_cvtr_data
| tag_t | curvature | Input | object id of the smart offset for curvature on surface |
| UF_SO_offset_surf_cvtr_data_p_t | offset_surf_cvtr_data | Output | pointer to Open API data structure for curvature on surface |
UF_SO_ask_parent_status (view source)
Defined in: uf_so.h
Returns the parent status for the specified smart object.
See
parent status bit masks
int UF_SO_ask_parent_status
const tag_t so,
int * parent_status
| const tag_t | so | Input | Tag of smart object |
| int * | parent_status | Output | Status of parent |
UF_SO_ask_parents (view source)
Defined in: uf_so.h
Asks parents of smart object. Note that the following abbreviations or
terms are used in the descriptions.
lwos = Light weight ocurrences. These are not referenced but are
selectable and are displayable.
hwos = Heavy weight ocurrences. These are referenced and have
data.
stub = References an object in another part file that is not loaded.
int UF_SO_ask_parents
const tag_t so,
int options,
int * n_parents,
tag_p_t * parents
| const tag_t | so | Input | Tag of smart object on which to inquire parents |
| int | options | Input | What kind of parents (bit mask) UF_SO_ASK_EXP_PARENTS - Ask refernced expressions. UF_SO_ASK_SO_PARENTS - Ask referenced smart objects. UF_SO_ASK_WIREFRAME_PARENTS - Ask referenced wire frame geometry (hwos). UF_SO_ASK_ALL_PARENTS - Ask referenced objects including lwos and stubs. UF_SO_ASK_PARENTS_RECURSIVELY - Ask referenced objects recursively. UF_SO_ASK_UNLOADED_PARENTS - Return unloaded parents. |
| int * | n_parents | Output | Number of parents |
| tag_p_t * | parents | Output to UF_*free* | Parents of smart object |
UF_SO_ask_point_of_axis (view source)
Defined in: uf_so.h
Returns point of axis.
int UF_SO_ask_point_of_axis
const tag_t axis,
double point [ 3 ]
| double | point [ 3 ] | Output | Value of axis point |
UF_SO_ask_point_of_xform (view source)
Defined in: uf_so.h
Returns point of transform.
int UF_SO_ask_point_of_xform
const tag_t xform,
double point [ 3 ]
| const tag_t | xform | Input | Tag of transform |
| double | point [ 3 ] | Output | Value of transform point |
UF_SO_ask_scale_of_xform (view source)
Defined in: uf_so.h
Returns scale of transform.
int UF_SO_ask_scale_of_xform
tag_t xform,
double * scale
| double * | scale | Output | Value of transform scale |
UF_SO_ask_spline (view source)
Defined in: uf_so.h
Inquire a general smart spline object.
int UF_SO_ask_spline
tag_t spline,
UF_SO_spline_data_p_t spline_data
| tag_t | spline | Input | object id of the smart spline |
| UF_SO_spline_data_p_t | spline_data | Output | pointer to Open API data structure for general spline |
UF_SO_ask_update_error_code (view source)
Defined in: uf_so.h
Returns the smart object update error code.
int UF_SO_ask_update_error_code
tag_t so,
int * update_error_code
| int * | update_error_code | Output | Status of parent |
UF_SO_ask_visibility_option (view source)
Defined in: uf_so.h
Returns the visibility option for the specified smart object.
int UF_SO_ask_visibility_option
const tag_t so,
UF_SO_visibility_option_p_t visibility_option
UF_SO_ask_x_direction_of_xform (view source)
Defined in: uf_so.h
Returns x-direction of transform.
int UF_SO_ask_x_direction_of_xform
tag_t xform,
double x_direction [ 3 ]
| double | x_direction [ 3 ] | Output | Value of transform X direction |
UF_SO_ask_y_direction_of_xform (view source)
Defined in: uf_so.h
Returns y-direction of transform.
int UF_SO_ask_y_direction_of_xform
tag_t xform,
double y_direction [ 3 ]
| double | y_direction [ 3 ] | Output | Value of transform Y direction |
UF_SO_ask_z_direction_of_xform (view source)
Defined in: uf_so.h
Returns z-direction of transform.
int UF_SO_ask_z_direction_of_xform
tag_t xform,
double z_direction [ 3 ]
| double | z_direction [ 3 ] | Output | Value of transform Z direction |
UF_SO_create_arc_center_2_pnts (view source)
Defined in: uf_so.h
Creates a smart arc via center and two points.
int UF_SO_create_arc_center_2_pnts
const tag_t object_in_part,
const UF_SO_update_option_t update_option,
const tag_t points [ 3 ] ,
tag_p_t arc
UF_SO_create_arc_radius_angles (view source)
Defined in: uf_so.h
Creates a smart arc via transformation, radius, and angles. To obtain
the transformation tag use any of the UF_SO_create_xform_
routines. The radius and angles are scalars; use any of the
UF_SO_create_scalar_ routines to get tags for these scalars.
int UF_SO_create_arc_radius_angles
const tag_t xform,
const tag_t radius,
const tag_t angles [ 2 ] ,
tag_p_t arc
UF_SO_create_arc_three_points (view source)
Defined in: uf_so.h
Creates a smart arc through three points.
int UF_SO_create_arc_three_points
tag_p_t arc
UF_SO_create_arc_xform_2_points (view source)
Defined in: uf_so.h
Creates a smart arc via two points and a transform. The arc always
lies on the xy plane of the xform. The two points are projected onto
the xy plane to give start and end points for the arc.
Original Release was in V14.0.
int UF_SO_create_arc_xform_2_points
const tag_t xform,
const tag_t points [ 2 ] ,
tag_p_t arc
UF_SO_create_axis_doubles (view source)
Defined in: uf_so.h
Creates a double axis.
int UF_SO_create_axis_doubles
const double point [ 3 ] ,
const double direction [ 3 ] ,
tag_p_t axis
| const tag_t | object_in_part | Input | Tag of object in part |
| const UF_SO_update_option_t | update_option | Input | Update option |
| const double | point [ 3 ] | Input | Axis point |
| const double | direction [ 3 ] | Input | Axis direction |
| tag_p_t | axis | Output | Pointer to tag of axis |
UF_SO_create_axis_extract (view source)
Defined in: uf_so.h
Creates a smart axis via extract axis with optional transformation.
int UF_SO_create_axis_extract
const tag_t axis,
const tag_t xform,
tag_p_t axis2
UF_SO_create_axis_point_dir (view source)
Defined in: uf_so.h
Creates a point/direction axis.
int UF_SO_create_axis_point_dir
const tag_t point,
tag_p_t axis
UF_SO_create_bcurve_thru_points (view source)
Defined in: uf_so.h
Create a smart b-spline curve through points
int UF_SO_create_bcurve_thru_points
int num_of_points,
tag_p_t points,
double * point_parameters,
int degree,
int periodic,
tag_t start_slope,
tag_t end_slope,
int start_slope_type,
int end_slope_type,
tag_p_t bcurve
| UF_SO_update_option_t | update_option | Input | update option |
| int | num_of_points | Input | Number of points used to define the B-spline |
| tag_p_t | points | Input | Array of points |
| double * | point_parameters | Input | Array of user-specified parameters for points. The array length should be num_of_points for non-periodic curve and num_of_points+1 for periodic curves. The parameters need to start from 0.0 and be monotonically increasing; however, they need not to be normalized. Pass in NULL to use the default chord-length parametrization. |
| int | degree | Input | Degree of the B-spline curve |
| int | periodic | Input | Curve type - 0 = non-periodic and 1 = Periodic. |
| tag_t | start_slope | Input | Tag of a point whose coordinates are used as the start slope of a non-periodic cubic bcurve. |
| tag_t | end_slope | Input | Tag of a point whose coordinates are used as the end slope of a non-periodic cubic bcurve. |
| int | start_slope_type | Input | Start slope type of a non-periodic cubic bcurve. The available slope types are: -1 = no slope 0 = auto slope 1 = use only direction of slope 2 = use both direction and magnitude of slope |
| int | end_slope_type | Input | End slope type of a non-periodic cubic bcurve. The available slope types are the same as above. |
| tag_p_t | bcurve | Output | The smart B-spline |
UF_SO_create_curve_extract (view source)
Defined in: uf_so.h
Creates a smart curve via extract curve with optional transformation.
int UF_SO_create_curve_extract
const tag_t curve1,
const int type,
const int subtype,
const tag_t xform,
tag_p_t curve2
UF_SO_create_dirr_axis_of_conic (view source)
Defined in: uf_so.h
Creates direction via axis of conic.
int UF_SO_create_dirr_axis_of_conic
const tag_t conic,
const logical flip,
tag_p_t direction
UF_SO_create_dirr_doubles (view source)
Defined in: uf_so.h
Creates a double direction.
int UF_SO_create_dirr_doubles
tag_p_t dirr
UF_SO_create_dirr_doubles_pnt (view source)
Defined in: uf_so.h
Create a double direction. The user defined real point of the
double direction is used for display.
int UF_SO_create_dirr_doubles_pnt
tag_p_t dirr
| const tag_t | object_in_part | Input | Object in the part to create the double direction in. |
| const UF_SO_update_option_t | update_option | Input | update option |
| const double | point [ 3 ] | Input | real point of direction |
| const double | direction [ 3 ] | Input | real direction vector |
| tag_p_t | dirr | Output | Double direction object that was created. |
UF_SO_create_dirr_extract (view source)
Defined in: uf_so.h
Creates direction via extract direction with optional transformation.
int UF_SO_create_dirr_extract
const tag_t dir,
const tag_t xform,
tag_p_t direction
UF_SO_create_dirr_line (view source)
Defined in: uf_so.h
Creates direction of line.
int UF_SO_create_dirr_line
const tag_t line,
const logical flip,
tag_p_t direction
UF_SO_create_dirr_normal_to_surface_point (view source)
Defined in: uf_so.h
Creates a direction normal to a surface at a given point on that surface.
int UF_SO_create_dirr_normal_to_surface_point
const tag_t face,
const tag_t point,
const logical flip,
tag_p_t direction
UF_SO_create_dirr_on_curve (view source)
Defined in: uf_so.h
Creates a direction on a curve using t value.
Note: This function can not be used to compute the normal for a line or
a spline made from two points. This is due to the fact that lines
have no associated csys so there is no unique normal.
int UF_SO_create_dirr_on_curve
const tag_t curve,
const tag_t t,
const UF_SO_dirr_on_curve_option_t option,
const logical flip,
tag_p_t direction
UF_SO_create_dirr_on_surf (view source)
Defined in: uf_so.h
Create a direction on surface smart object.
int UF_SO_create_dirr_on_surf
UF_SO_dirr_on_surf_data_p_t dirr_on_surf_data,
tag_t * direction
UF_SO_create_dirr_plane (view source)
Defined in: uf_so.h
Creates direction of plane.
int UF_SO_create_dirr_plane
const tag_t plane,
const logical flip,
tag_p_t direction
UF_SO_create_dirr_surface_axis (view source)
Defined in: uf_so.h
Creates direction via axis of surface.
int UF_SO_create_dirr_surface_axis
const tag_t conic,
const logical flip,
tag_p_t direction
UF_SO_create_dirr_two_dirs (view source)
Defined in: uf_so.h
Creates a direction via two directions. The output direction is
the cross product of the two input directions.
int UF_SO_create_dirr_two_dirs
const tag_t directions [ 2 ] ,
tag_p_t direction
UF_SO_create_dirr_two_points (view source)
Defined in: uf_so.h
Creates a smart direction via two points.
int UF_SO_create_dirr_two_points
tag_p_t dirr
UF_SO_create_line_two_points (view source)
Defined in: uf_so.h
Creates a smart line between two points.
int UF_SO_create_line_two_points
tag_p_t line
UF_SO_create_offset_3_scalars (view source)
Defined in: uf_so.h
Creates a smart offset using three smart scalars.
int UF_SO_create_offset_3_scalars
tag_t xyz [ 3 ] ,
tag_p_t offset
UF_SO_create_offset_curve_cvtr (view source)
Defined in: uf_so.h
Create a curvature on curve smart offset object.
int UF_SO_create_offset_curve_cvtr
UF_SO_offset_curve_cvtr_data_p_t offset_curve_cvtr_data,
tag_t * curvature
UF_SO_create_offset_cylindrical (view source)
Defined in: uf_so.h
Creates a smart cylindrical offset. The radius, angle, and zdelta are
the three parameters of cylindrical coordinates.
int UF_SO_create_offset_cylindrical
tag_t radius,
tag_t angle,
tag_t zdelta,
tag_p_t offset
| tag_t | radius | Input | Tag of scalar radius |
| tag_t | angle | Input | Tag of scalar angle in radians |
| tag_t | zdelta | Input | Tag of scalar delta along axis of cylinder. |
| tag_p_t | offset | Output | Pointer to tag of vector offset |
UF_SO_create_offset_dir_dist (view source)
Defined in: uf_so.h
Creates a direction/distance offset.
int UF_SO_create_offset_dir_dist
const tag_t distance,
tag_p_t offset
UF_SO_create_offset_double (view source)
Defined in: uf_so.h
Creates a double offset.
int UF_SO_create_offset_double
const double offset1 [ 3 ] ,
tag_p_t offset2
UF_SO_create_offset_double_pnt (view source)
Defined in: uf_so.h
Create a double offset. The user defined real point of the
double offset is used for display.
int UF_SO_create_offset_double_pnt
tag_p_t offset2
| const tag_t | object_in_part | Input | Object in the part where the double offset will be created. |
| const double | point [ 3 ] | Input | real point of offset |
| const double | offset1 [ 3 ] | Input | real offset vector |
| tag_p_t | offset2 | Output | Tag of the double offset created. |
UF_SO_create_offset_extract (view source)
Defined in: uf_so.h
Creates a smart offset via extract offset with optional transformation.
int UF_SO_create_offset_extract
const tag_t offset1,
const tag_t xform,
tag_p_t offset2
UF_SO_create_offset_spherical (view source)
Defined in: uf_so.h
Creates a smart spherical offset. The radius, angle1, and angle2 are
the three parameters of spherical coordinates (r,q,f) respectively.
int UF_SO_create_offset_spherical
tag_t radius,
tag_t angle1,
tag_t angle2,
tag_p_t offset
| tag_t | radius | Input | Tag of scalar spherical radius |
| tag_t | angle1 | Input | Tag of scalar angle (longitude) in radians |
| tag_t | angle2 | Input | Tag of scalar angle (colatitude) in radians |
UF_SO_create_offset_surf_cvtr (view source)
Defined in: uf_so.h
Create a curvature on surface smart offset object.
int UF_SO_create_offset_surf_cvtr
UF_SO_offset_surf_cvtr_data_p_t offset_surf_cvtr_data,
tag_t * curvature
UF_SO_create_point_3_scalars (view source)
Defined in: uf_so.h
Creates a smart point via three scalars. The smart point update option must
ensure that the parent scalars update before the point.
int UF_SO_create_point_3_scalars
const tag_t xyz [ 3 ] ,
tag_p_t point
UF_SO_create_point_3_scalars_csys (view source)
Defined in: uf_so.h
Creates a smart point at an offset xyz from the given CSYS.
NOTE: If you use UF_SO_update_within_modeling as the update_option, then the
input csys must also have its modeling option set to UF_SO_update_within_modeling.
The original release was in V18.0
int UF_SO_create_point_3_scalars_csys
const tag_t csys_tag,
tag_p_t point
UF_SO_create_point_along_curve (view source)
Defined in: uf_so.h
Creates a smart point along curve using a curve, point, and t (scalar
offset along curve). This point is derived by finding the closest point
on the given curve to the given point and then offsetting this point
along the given curve by the arc length defined by t via absolute
distance or relative percent.
int UF_SO_create_point_along_curve
const tag_t curve,
const tag_t point1,
const tag_t t,
const UF_SO_point_along_curve_option_t option,
const logical flip,
tag_p_t point2
UF_SO_create_point_conic_center (view source)
Defined in: uf_so.h
Creates a smart point via the center of a conic.
int UF_SO_create_point_conic_center
const tag_t conic,
tag_p_t point
UF_SO_create_point_extract (view source)
Defined in: uf_so.h
Creates a smart point via an extract point with optional
transformation.
int UF_SO_create_point_extract
const tag_t point1,
const tag_t xform,
tag_p_t point2
UF_SO_create_point_extract_with_disp_marker (view source)
Defined in: uf_so.h
Creates a smart point via an extract point with a display marker and optional
transformation.
int UF_SO_create_point_extract_with_disp_marker
const tag_t point1,
const tag_t xform,
UF_DISP_poly_marker_t disp_marker,
tag_p_t point2
UF_SO_create_point_offset (view source)
Defined in: uf_so.h
Creates a smart point via a point and an offset.
int UF_SO_create_point_offset
const tag_t base_point,
const tag_t offset,
tag_p_t point
UF_SO_create_point_on_arc_angle (view source)
Defined in: uf_so.h
Creates a smart point using an arc and angle.
int UF_SO_create_point_on_arc_angle
const tag_t arc,
const tag_t angle,
const tag_t xform,
tag_p_t point
UF_SO_create_point_on_axis (view source)
Defined in: uf_so.h
Creates a smart point on the axis of a surface by projecting a reference point
onto the given axis. The axis tag should be that of an already defined axis
smart object. The point tag argument may be that of a point smart object.
Original release was in v17.0
int UF_SO_create_point_on_axis
const tag_t ref_point,
const tag_t axis,
tag_p_t point_on_axis
UF_SO_create_point_on_curve (view source)
Defined in: uf_so.h
Creates a smart point via a curve and scalar value t.
int UF_SO_create_point_on_curve
const tag_t curve,
const tag_t t,
tag_p_t point
UF_SO_create_point_on_surface (view source)
Defined in: uf_so.h
Creates a smart point on a surface via uv scalars for the surface. Call
one of the create scalar routines to obtain the input u and v
parameters. For example, to create a point on the surface at (.25, .50)
call UF_SO_create_scalar_double_dim() twice - once for the u value
and once for the v value.
Note the u,v parameters are normalized from 0 to 1, so if you have read
surface parameters with UF_MODL_ask_face_parms, or UF_MODL_ask_face_uv_minmax,
you will have to normalize the parameters to the range of 0 to 1 prior to
creating the smart point on the surface.
int UF_SO_create_point_on_surface
const tag_t face,
const tag_t u,
const tag_t v,
tag_p_t point
UF_SO_create_point_surface_crv (view source)
Defined in: uf_so.h
Creates a smart point via surface/curve intersection.
int UF_SO_create_point_surface_crv
const tag_t face,
const tag_t curve,
const tag_t help_point1,
const tag_t help_point2,
tag_p_t point
UF_SO_create_point_two_curves (view source)
Defined in: uf_so.h
Creates a smart point via two curve intersection.
int UF_SO_create_point_two_curves
const tag_t curve1,
const tag_t curve2,
tag_p_t point
UF_SO_create_scalar_dist_2_pnts (view source)
Defined in: uf_so.h
Creates a smart scalar via distance between two points.
int UF_SO_create_scalar_dist_2_pnts
tag_p_t scalar
UF_SO_create_scalar_double (view source)
Defined in: uf_so.h
Creates a double scalar.
int UF_SO_create_scalar_double
const double dbl,
tag_p_t scalar
UF_SO_create_scalar_double_dim (view source)
Defined in: uf_so.h
Creates a dimensioned double scalar. A dimensioned double scalar
should be used when the scalar represents a value with units, i.e.
inches or millimeters. The value of the dimension can then be used to
correctly convert the scalar when the part is converted from one unit
to another.
int UF_SO_create_scalar_double_dim
const double dbl,
const UF_SO_scalar_dim_option_t dim,
tag_p_t scalar
UF_SO_create_scalar_exp (view source)
Defined in: uf_so.h
Creates a smart scalar via an expression.
int UF_SO_create_scalar_exp
const tag_t exp,
tag_p_t scalar
UF_SO_create_scalar_exp_dim (view source)
Defined in: uf_so.h
Creates a dimensioned smart scalar via an expression. A dimensioned
smart scalar should be used when the scalar represents a value with
units, i.e. inches or millimeters. The value of the dimension can then
be used to correctly convert the scalar when the part is converted
from one unit to another.
int UF_SO_create_scalar_exp_dim
const tag_t exp,
tag_p_t scalar
UF_SO_create_scalar_extract (view source)
Defined in: uf_so.h
Creates smart scalar via extract scalar with optional scale.
int UF_SO_create_scalar_extract
const tag_t scalar1,
const tag_t scale,
tag_p_t scalar2
UF_SO_create_scalar_extract_dim (view source)
Defined in: uf_so.h
Creates a dimensioned smart scalar via extract scalar with optional
scale. A dimensioned smart scalar should be used when the scalar
represents a value with units, i.e. inches or millimeters. The value of
the dimension can then be used to correctly convert the scalar when
the part is converted from one unit to another.
int UF_SO_create_scalar_extract_dim
const tag_t scale,
tag_p_t scalar2
UF_SO_create_scalar_length_crv (view source)
Defined in: uf_so.h
Creates a smart scalar via the length of a curve or edge.
int UF_SO_create_scalar_length_crv
const tag_t curve,
tag_p_t scalar
UF_SO_create_spline (view source)
Defined in: uf_so.h
Create a general smart spline object.
int UF_SO_create_spline
UF_SO_spline_data_p_t spline_data,
tag_t * spline
UF_SO_create_xform_assy_ctxt (view source)
Defined in: uf_so.h
Create an assy_context smart transform, encapsulating the transform to go
from one part occurrence in an assembly tree to another. Either
from_part_occ or to_part_occ can be NULL_TAG, indicating that the
transform goes to or from the root part occ of the specified part. If
they are both non-NULL, they must be in the same part.
If from_part_occ and to_part_occ are the same, including if they are
both NULL_TAG, then no assy_context_xform is created, and
NULL_TAG is returned in the relevant argument.
If to_part_occ is not NULL_TAG, its prototype part has to be the part
that contains object_in_part.
int UF_SO_create_xform_assy_ctxt
const tag_t from_part_occ,
tag_p_t xform
| const tag_t | from_part_occ | Input | Beginning position for transform |
| const tag_t | to_part_occ | Input | End position for transform |
| tag_p_t | xform | Output | Pointer to tag of transform |
UF_SO_create_xform_doubles (view source)
Defined in: uf_so.h
Creates a dumb double transform.
int UF_SO_create_xform_doubles
const double x_direction [ 3 ] ,
const double y_direction [ 3 ] ,
const double scale,
tag_p_t xform
| const UF_SO_update_option_t | update_option | Input | Unused - set to zero |
| const double | point [ 3 ] | Input | Point |
| const double | x_direction [ 3 ] | Input | X-direction |
| const double | y_direction [ 3 ] | Input | Y-direction |
| const double | scale | Input | Scale value |
| tag_p_t | xform | Output | Pointer to tag of smart transform |
UF_SO_create_xform_extract (view source)
Defined in: uf_so.h
Creates a smart transform via extract transform with optional
transformation.
int UF_SO_create_xform_extract
const tag_t xform1,
const tag_t xform2,
tag_p_t xform
UF_SO_create_xform_offset_xform (view source)
Defined in: uf_so.h
Creates a smart transform given a reference csys, point0, point1, rotational_offsets
(if any) and an optional scale. It will translate then rotate. The csys will be
rotated about the X axis, the Y axis then about the Z axis. Angles should be
specified in degrees.
Original Release was in NX3
int UF_SO_create_xform_offset_xform
const tag_t csys,
const tag_t point0,
const tag_t point1,
const tag_t rot_scalar_tags [ 3 ] ,
const tag_t scale,
const tag_p_t xform
UF_SO_create_xform_pnt_xy_dirs (view source)
Defined in: uf_so.h
Creates a smart transform given a point, x and y directions, and an
optional scale.
int UF_SO_create_xform_pnt_xy_dirs
const tag_t point,
const tag_t x_direction,
const tag_t y_direction,
const tag_t scale,
tag_p_t xform
UF_SO_create_xform_pnt_xz_dirs (view source)
Defined in: uf_so.h
Creates a smart transform given a point, x and z directions, and an
optional scale.
int UF_SO_create_xform_pnt_xz_dirs
const tag_t point,
const tag_t z_direction,
const tag_t scale,
tag_p_t xform
UF_SO_create_xform_pnt_yz_dirs (view source)
Defined in: uf_so.h
Creates a smart transform given a point, y and z directions, and an
optional scale.
int UF_SO_create_xform_pnt_yz_dirs
const tag_t point,
const tag_t scale,
tag_p_t xform
UF_SO_create_xform_three_planes (view source)
Defined in: uf_so.h
Creates a smart transform given a three planes/faces and the scale.
Original Release was in NX301
int UF_SO_create_xform_three_planes
const tag_t plane0,
const tag_t plane1,
const tag_t plane2,
const tag_t scale,
const tag_p_t xform
UF_SO_create_xform_three_points (view source)
Defined in: uf_so.h
Creates a smart transform given a three points and the scale. The three points
used to construct the xform must NOT be collinear. In other words, one point
can't be collinear with the other 2 points.
int UF_SO_create_xform_three_points
const tag_t point0,
const tag_t point1,
const tag_t point2,
const tag_t scale,
const tag_p_t xform
UF_SO_delete_non_deletables (view source)
Defined in: uf_so.h
Delete SO's that are condemned and not sleepy/promoted/occurrenced/referenced.
int UF_SO_delete_non_deletables
tag_t part
| tag_t | part | Input | part to process |
UF_SO_delete_parms (view source)
Defined in: uf_so.h
Delete parms of smart object. All unreferenced
smart object parents are put on the delete list.
int UF_SO_delete_parms
tag_t so
UF_SO_display (view source)
Defined in: uf_so.h
Displays a smart object with the specified options.
int UF_SO_display
const tag_t so,
const int view_option,
const int color_option,
const int color
| const tag_t | so | Input | Tag of smart object to display |
| const int | view_option | Input | view option: UF_DISP_ALL_VIEWS_BUT_DRAWING UF_DISP_VIEW_OF_LAST_CURSOR UF_DISP_ALL_ACTIVE_VIEWS UF_DISP_WORK_VIEW_ONLY |
| const int | color_option | Input | color option: UF_DISP_USE_SYSTEM_COLOR UF_DISP_USE_BACKGROUND_COLOR UF_DISP_USE_ORIGINAL_COLOR UF_DISP_USE_SPECIFIED_COLOR |
| const int | color | Input | color option - used only when color option is UF_DISP_USE_SPECIFIED_COLOR. See uf_obj.h for valid color assignments. |
UF_SO_display_parents (view source)
Defined in: uf_so.h
Displays a smart object's parents with the specified options.
int UF_SO_display_parents
const tag_t so,
const int color
Defined in: uf_so.h
Determines if the given object has become dumb. This means that
the object is no longer associative. For example, a smart point "has
become dumb" after one calls UF_SO_delete_parms() on it.
Originally released in V15.0.
int UF_SO_has_become_dumb
tag_t so,
logical * has_become_dumb
| tag_t | so | Input | smart object to check if has become dumb |
| logical * | has_become_dumb | Output | TRUE if has become dumb, else FALSE |
UF_SO_is_assy_ctxt_xform (view source)
Defined in: uf_so.h
Asks if an transform is an assy_context smart transform. Returns an error if
given a non-transform object.
int UF_SO_is_assy_ctxt_xform
const tag_t xform,
logical * is_assy_xform
| const tag_t | xform | Input | Tag of transform. |
| logical * | is_assy_xform | Output | True if transform is an assy_context transform, false otherwise |
UF_SO_is_out_of_date (view source)
Defined in: uf_so.h
Determines if the given object is out of date. This means that the
object did not update when it needed to. For example, a smart point
"is out of date" after it does not update because some of its parents
are not loaded.
int UF_SO_is_out_of_date
tag_t so,
logical * is_out_of_date
| tag_t | so | Input | smart object to check if is out of date |
| logical * | is_out_of_date | Output | TRUE if is out of date, else FALSE |
UF_SO_is_so (view source)
Defined in: uf_so.h
Queries if an object is a smart object and is parameterized.
These objects are "smart" so they know how they were constructed and
will associatively update.
int UF_SO_is_so
const tag_t candidate,
logical * is_so
| const tag_t | candidate | Input | Tag of object |
| logical * | is_so | Output | TRUE = candidate is a smart object. FALSE = candidate is not a smart object. |
UF_SO_is_subclass (view source)
Defined in: uf_so.h
Queries if an object inherits from the smart object class.
The object may or may not have parameters associated with it, i.e. it may
or may not be smart itself. For that, call UF_SO_is_so.
Example:
logical is_subclass = FALSE;
UF_SO_is_so_subclass ( tag, &is_subclass );
If ( is_subclass )
logical has_become_dumb = FALSE;
UF_SO_has_become_dumb ( tag, &has_become_dumb );
if ( has_become_dumb )
Printf ("Smart Object (tag %u) has lost its associativity\n" tag );
int UF_SO_is_subclass
logical * is_so
| logical * | is_so | Output | TRUE if candidate inherits from class SO FALSE otherwise |
UF_SO_replace_parms (view source)
Defined in: uf_so.h
Replaces the parms of the old smart object with the parms of the new
smart object and then deletes the new smart object.
int UF_SO_replace_parms
tag_t old_so,
tag_t new_so
| tag_t | old_so | Input | Tag of smart object whose parms are to be replaced. |
| tag_t | new_so | Input | Tag of smart object whose parms are to be used as replacement parms. |
UF_SO_set_direction_of_axis (view source)
Defined in: uf_so.h
Sets direction of dumb axis.
int UF_SO_set_direction_of_axis
tag_t axis,
const double new_direction [ 3 ]
| tag_t | axis | Input | Tag of dumb axis |
| const double | new_direction [ 3 ] | Input | Value of axis direction |
UF_SO_set_direction_of_dirr (view source)
Defined in: uf_so.h
Sets value of dumb direction.
int UF_SO_set_direction_of_dirr
tag_t direction,
const double dir [ 3 ]
| tag_t | direction | Input | Tag of dumb direction |
| const double | dir [ 3 ] | Input | Value of direction. |
UF_SO_set_display_marker_of_point (view source)
Defined in: uf_so.h
Sets/changes the display marker type for points created using
UF_SO_create_point_extract_with_disp_marker()
int UF_SO_set_display_marker_of_point
tag_t point,
UF_SO_set_double_of_scalar (view source)
Defined in: uf_so.h
Sets value of a dumb scalar.
int UF_SO_set_double_of_scalar
tag_t scalar,
const double dbl
| tag_t | scalar | Input | Tag of dumb scalar |
| const double | dbl | Input | Value of scalar |
UF_SO_set_offset_of_offset (view source)
Defined in: uf_so.h
Sets offset of dumb offset.
int UF_SO_set_offset_of_offset
tag_t offset,
const double new_offset [ 3 ]
| tag_t | offset | Input | Tag of dumb offset |
| const double | new_offset [ 3 ] | Input | Value of offset |
UF_SO_set_point_of_axis (view source)
Defined in: uf_so.h
Sets point of dumb axis.
int UF_SO_set_point_of_axis
tag_t axis,
const double new_point [ 3 ]
| const double | new_point [ 3 ] | Input | Value of axis point |
UF_SO_set_point_of_xform (view source)
Defined in: uf_so.h
Sets point of dumb transform.
int UF_SO_set_point_of_xform
tag_t xform,
| tag_t | xform | Input | Tag of dumb transform |
| const double | point [ 3 ] | Input | Value of transform point |
UF_SO_set_scale_of_xform (view source)
Defined in: uf_so.h
Sets scale of dumb transform.
int UF_SO_set_scale_of_xform
tag_t xform,
const double scale
| const double | scale | Input | Value of transform scale |
UF_SO_set_visibility_option (view source)
Defined in: uf_so.h
Sets the visibility option for the specified smart object. It is the
responsibility of the calling routine to update the display.
int UF_SO_set_visibility_option
tag_t so,
UF_SO_visibility_option_t visibility_option
UF_SO_set_xy_direction_of_xform (view source)
Defined in: uf_so.h
Sets x and y directions of dumb transform.
int UF_SO_set_xy_direction_of_xform
tag_t xform,
| const double | x_direction [ 3 ] | Input | Value of transform X direction |
| const double | y_direction [ 3 ] | Input | Value of transform Y direction |
