查看: 2353|回复: 0
[原创] NX 2007系列二次开发增加了新测量方法获取尺寸的API
发表于 2022-6-13 00:05:28 | 显示全部楼层 |阅读模式
Methods to query measure results  r- v  [# r( V4 I4 B
NX新的测量功能引入,但是在进行JA录制发现无法获取测量的结果,这个显然是官方还没有来得及进行更新API发布。在最小的2007版本系类中增加了相关获取结果的API。" N  \9 ~9 w6 N- ?: a6 [
现在很容的获取相关对象和结果。
  • getMeasureElement
    The method is for MeasureMaster and it returns MeasureElement for a master measure feature.
  • getMeasureElementExpressions
    The method is for MeasureElement and it returns an array of expression objects for a measure element of a measure feature.
  • getMeasureElementExpressionsType
    The method is for MeasureElement and it returns an array of strings that corresponds to the expression types for a measure element of a measure feature. You should generally use this method in conjunction with getMeasureElementExpressions() to pass along the same index value to find the expression and expression type associated with a MeasureElement.
    : k! [" j8 {$ P( C# H- i1 k
直接通过录制JA就可以获取相关属性。
  • getProjectedDistanceProperties
  • getFaceProperties
  • getBodyProperties
  • getDistance
  • getAngle
  • getArcAndCurveProperties
  • getPolarAreaProperties
  • getPolarRadiusProperties
  • getPolarAngleProperties
  • geTCenterlineProperties
  • getBoundingBoxProperties
  • getExtremePointProperties
  • getEulerAnglesProperties
  • getPointProperties
      b/ N3 S5 T7 m5 O+ \' {- m4 e
( p5 S, J) n3 N6 N' u
; g& b# n9 x0 v' z0 e% s. o& L
