uc5530 (view source)
Defined in: uf_drf.h
uc5530 create a horizontal, vertical, parallel, or
void uc5530
int ip1,
tag_t np2,
int ip3,
int ip4,
tag_t np5,
int ip6,
int ip7,
const char * cp8,
int ip9,
const UF_DRF_one_apptext_line_t cp10 [ ] ,
double * rp11,
tag_t * nr12
| int | ip1 | | |
| tag_t | np2 | | |
| int | ip3 | | |
| int | ip4 | | |
| tag_t | np5 | | |
| int | ip6 | | |
| int | ip7 | | |
| const char * | cp8 | | |
| int | ip9 | Input | |
| const UF_DRF_one_apptext_line_t | cp10 [ ] | | |
| double * | rp11 | Input | |
| tag_t * | nr12 | | |
uc5531 (view source)
uc5531 create a perpendicular dimension
void uc5531
tag_t np1,
tag_t np2,
int ip3,
int ip4,
const char * cp5,
int ip6,
const UF_DRF_one_apptext_line_t cp7 [ ] ,
double * rp8,
tag_t * nr9
| tag_t | np1 | | |
| tag_t | np2 | | |
| int | ip3 | | |
| int | ip4 | | |
| const char * | cp5 | | |
| int | ip6 | Input | |
| const UF_DRF_one_apptext_line_t | cp7 [ ] | | |
| double * | rp8 | Input | |
| tag_t * | nr9 | | |
uc5532 (view source)
uc5532 create angular dimension
void uc5532
int ip1,
tag_t np2,
int ip3,
tag_t np4,
int ip5,
const char * cp6,
int ip7,
const UF_DRF_one_apptext_line_t cp8 [ ] ,
double * rp9,
tag_t * nr10
| int | ip1 | | |
| tag_t | np2 | | |
| int | ip3 | | |
| tag_t | np4 | | |
| int | ip5 | | |
| const char * | cp6 | | |
| int | ip7 | Input | |
| const UF_DRF_one_apptext_line_t | cp8 [ ] | | |
| double * | rp9 | Input | |
| tag_t * | nr10 | | |
uc5533 (view source)
uc5533 create an arc length, radius, diameter, or hole
void uc5533
int ip1,
tag_t np2,
const char * cp3,
int ip4,
const UF_DRF_one_apptext_line_t cp5 [ ] ,
double * rp6,
tag_t * nr7
| int | ip1 | | |
| tag_t | np2 | | |
| const char * | cp3 | | |
| int | ip4 | Input | |
| const UF_DRF_one_apptext_line_t | cp5 [ ] | | |
| double * | rp6 | Input | |
| tag_t * | nr7 | | |
uc5534 (view source)
uc5534 create a concentric circle dimension
void uc5534
tag_t np1,
tag_t np2,
const char * cp3,
int ip4,
double * rp6,
tag_t * nr7
| tag_t | np1 | | |
| tag_t | np2 | | |
| tag_t * | nr7 | | |
uc5540 (view source)
Create a drafting aid note. The line length of the note string cannot
exceed 132 characters (in C this is 133 characters which includes the
null character terminator `\0'). You can limit the number of lines that
display from a character string array by specifying the number of lines
(ip1). For example, if you make the following declarations:
int ip1=6;
char cp2[10][133];
then only the first 6 lines of the 10 line note will display.
void uc5540
int ip1,
const UF_DRF_one_apptext_line_t cp2 [ ] ,
double * rp3,
tag_t * nr4
| int | ip1 | Input | Number Of Lines Of Text |
| const UF_DRF_one_apptext_line_t | cp2 [ ] | Input | Text Array Of ip1 Strings. |
| double * | rp3 | Input | 3D Object Origin (In WCS Coordinates) |
| tag_t * | nr4 | Output | Object Identifier Of Created Drafting Aid |
uc5541 (view source)
uc5541 create a label
void uc5541
int ip1,
double * rp3,
int ip4,
tag_t np5,
double * rp6,
tag_t * nr7
| int | ip1 | Input | |
| const UF_DRF_one_apptext_line_t | cp2 [ ] | | |
| double * | rp3 | | |
| int | ip4 | | |
| tag_t | np5 | | |
| tag_t * | nr7 | | |
uc5542 (view source)
uc5542 create an id symbol
drafting
int uc5542
int ip1,
const char * cp2,
const char * cp3,
double * rp4,
int ip5,
int ip6,
tag_t np7,
double * rp8,
tag_t * nr9
| const char * | cp2 | | |
| const char * | cp3 | Input | |
| double * | rp4 | | |
| int | ip5 | | |
| int | ip6 | | |
| tag_t | np7 | | |
| tag_t * | nr9 | | |
uc5543 (view source)
uc5543 create a form and positional
void uc5543
int ip1,
double * rp3,
int ip4,
int ip5,
tag_t np6,
double * rp7,
int ip8,
tag_t * nr9
| int | ip4 | | |
| int | ip5 | | |
| tag_t | np6 | | |
| double * | rp7 | | |
| int | ip8 | Input | |
| tag_t * | nr9 | | |
uc5550 (view source)
uc5550 read the drafting object creation - replaced by
UF_DRF_ask_object_preferences
void uc5550
tag_t np1,
int * ir2,
double * rr3,
char cr4 [ 27 ] ,
char cr5 [ 27 ]
| tag_t | np1 | | |
| int * | ir2 | | |
| double * | rr3 | Output | |
| char | cr4 [ 27 ] | | |
| char | cr5 [ 27 ] | Output | |
uc5551 (view source)
uc5551 regenerate a drafting object with - replaced by
UF_DRF_set_object_preferences
drafting
int uc5551
tag_t np1,
int * ip2,
double * rp3,
const char * cp4,
const char * cp5
| tag_t | np1 | | |
| int * | ip2 | | |
| double * | rp3 | Input | |
| const char * | cp4 | | |
| const char * | cp5 | Input | |
uc5563 (view source)
Add Text to an Assorted Parts Annotation (dimensions by parts)
Routine UF_DRF_create_assortpart_dim or UF_DRF_create_assortpart_aid
must be called first to initialize Open API for
dimension/drafting aid creation by parts. This routine, along with
uf5561, uf5562, and uf5564, can then be called to add lines, arcs, text,
and arrows to the dimension/drafting aid. Routine uf5565 must be
called to close the definition of the object.
void uc5563
int num_lines,
const UF_DRF_one_apptext_line_t text [ ] ,
const double text_origin [ 2 ]
| int | num_lines | Input | Number Of lines of text |
| const UF_DRF_one_apptext_line_t | text [ ] | Input | Array of text strings |
| const double | text_origin [ 2 ] | Input | 2d origin of text string in coordinates of annotation |
uc5566 (view source)
Edit Drafting Object Text. Replaces existing text in an existing
dimension/drafting aid. Can not be used to add text.
If the dimension text (dimensions) or main text (drafting aids) is
changed, the object is changed to indicate manual text.
Return code:
1 = Success
2 = Failure
3 = Zero Object Identifier passed in
4 = Text string in a line is too long
5 = Too many text string words
drafting
int uc5566
tag_t np1,
int ip2,
int ip3,
const UF_DRF_one_apptext_line_t cp4 [ ]
| tag_t | np1 | Input | Drafting Object Identifier |
| int | ip2 | Input | Text Type To Edit 1 = Dimension/Main Text 2 = Dual Dimension Text 3 = Tolerance Text 4 = Dual Tolerance Text 5 = Diameter/Radius Symbol Text 6 = Text Appended During Creation 7 = Text Appended During Editing 8 = Second Appended Text |
| int | ip3 | Input | Number Of Lines Of Text |
| const UF_DRF_one_apptext_line_t | cp4 [ ] | Input | Array Of ip3 Text Strings. |
uf5505 (view source)
Create Kanji Note
The 23.ugf file must be accessible to the program calling this
subroutine. The maximum number of characters per row is 132. The
maximum number of rows is 50. Subject to the above, the maximum
number of characters in the note is 650.
void uf5505
int * ia1,
int * ip2,
double * rp3,
double * rp4,
double * ra5,
int * ip6,
double * rp7,
double * rp8,
double * rp9,
tag_t * nr10
| int * | ia1 | Input | Kanji Codes (1) = Count Of Characters In First Row (2..N) = Codes For First Row (N+1) = Count Of Characters In Second Row (N+2..M)= Codes For Second Row (Z) = 0 (End Of Data) |
| int * | ip2 | Input | Density: 0 = Use Kanji Default 1 = Normal 2 = Heavy 3 = Thin |
| double * | rp3 | Input | Character Size 0 = Use Kanji Default |
| double * | rp4 | Input | Text Angle (In Radians) |
| double * | ra5 | Input | Origin (X,Y in Work Coordinates) |
| int * | ip6 | Input | Orientation: 0 = Use Kanji Default 1 = Left To Right 2 = Top To Bottom |
| double * | rp7 | Input | Character Height |
| double * | rp8 | Input | Character Width |
| double * | rp9 | Input | Character Spacing |
| tag_t * | nr10 | Output | Kanji Note Object Identifier |
uf5506 (view source)
Read Kanji Note
The 23.ugf file must be accessible to the program calling that
The origin that returns is in units relative to the creation matrix of the
Kanji entity. To convert these coordinates to WCS space, you can use
the following code:
UF_CSYS_ask_matrix_of_object(entity_tag[inx1], &matrix_id);
UF_CSYS_ask_matrix_values(matrix_id, matrix);
UF_MTX3_transpose(matrix, matrix_transpose);
UF_MTX3_vec_multiply(origin, matrix_transpose, model_origin)
void uf5506
tag_t * np1,
int * iar2,
int * ir3,
double * rr4,
double * rr5,
double * rar6,
int * ir7,
double * rr8,
double * rr9,
double * rr10
| tag_t * | np1 | Input | Kanji Note Object Identifier |
| int * | iar2 | Output | Kanji Codes (1) = Count Of Characters In First Row (2..N) = Codes For First Row (N+1) = Count Of Characters In Second Row (N+2..M)= Codes For Second Row (Z) = 0 (End Of Data) |
| int * | ir3 | Output | Density: 1 = Normal 2 = Heavy 3 = Thin |
| double * | rr4 | Output | Character Size |
| double * | rr5 | Output | Text Angle (In Radians) |
| double * | rar6 | Output | Origin (X,Y,Z). See description above. |
| int * | ir7 | Output | Orientation: 1 = Left To Right 2 = Top To Bottom |
| double * | rr8 | Output | Character Height |
| double * | rr9 | Output | Character Width |
| double * | rr10 | Output | Character Spacing |
uf5522 (view source)
Set the drafting parameters to the same values as an object.
void uf5522
tag_t * np1,
int * ir2
| tag_t * | np1 | Input | The object that we want the drafting parameters to be set from. |
| int * | ir2 | Output | The error code from the operation. 0 is success, 1 is failure |
uf5523 (view source)
Read the current drafting display parameters.
void uf5523
int * ir1,
double * rr2
| int * | ir1 | Output | A 10 element array that will be filled with the drafting display parameters. The elements of the arrary are defined as: (0) MARGIN DISPLAY 1 = DISPLAY MARGINS 2 = DO NOT DISPLAY MARGINS (1) FAST FONT 1 = FAST FONT ON 2 = FAST FONT OFF (2) TEXT BOX MODE 1 = TEXT BOX MODE ON 2 = TEXT BOX MODE OFF (3) INDICATOR SITE 1 = DISPLAY INDICATOR SITE 2 = DO NOT DISPLAY INDICATOR SITE (4) TEXT SCALING FOR PART MERGE AND TRANSFORMATIONS 1 = SCALE TEXT 2 = DO NOT SCALE TEXT (5) FILLED ARROWHEAD DISPLAY 1 = DISPLAY FILLED ARROWHEAD 2 = DO NOT DISPLAY FILLED ARROWHEAD (6) - (9) RESERVED FOR FUTURE USE |
| double * | rr2 | Output | A 5 element array that will be filled with the drafting display parameters. Currently only the first parameter rr2[0] is used. rr2[0] holds the character slant (in degrees). |
uf5524 (view source)
Set the current drafting display parameters.
void uf5524
int * ip1,
double * rp2
| int * | ip1 | Input | A 10 element array that contains the new drafting display parameters. |
| double * | rp2 | Output | A 5 element array that contains the new drafting display parameters. |
uf5547 (view source)
uf5547 create a area fill
void uf5547
int * ip1,
int * ip2,
tag_t * np3,
tag_t * nr4,
int * ir5
uf554a (view source)
Validates that selected object (entity) for creation of centerline is
either an arc or a point. If the entity is an arc or a point, a
drafting point is output.
void uf554a
tag_t * np1,
tag_t * nr2
| tag_t * | np1 | Input | EID of selected entity |
| tag_t * | nr2 | Output | EID of drafting point NULL_TAG = Invalid entity selected (Not an arc or point) if not NULL_TAG = drafting point |
uf554b (view source)
Validates that selected object (entity) is either an arc or a point.
If the entity is an arc or a point, the coordinates of the point or
arc center point are output.
void uf554b
tag_t * np1,
double * rr2,
int * ir3
| tag_t * | np1 | Input | EID of point or arc |
| double * | rr2 | Output | Coordinates of point or arc center point |
| int * | ir3 | Output | Return Code: 0 = Successful 1 = Invalid entity object selected (Not a point or an arc) |
uf554c (view source)
Ufunc program for creation of centerlines
void uf554c
const int * ip1,
const int * ip2,
const tag_t * np3,
const tag_t * np4,
const double * rp5,
tag_t * nr6,
int * ir7
| const int * | ip1 | Input | TYPE OF CENTERLINE TO CREATE 1 = LINEAR 2 = FULL CIRCULAR --- CENTER POINT METHOD 3 = PARTIAL CIRCULAR --- CENTER POINT METHOD 4 = FULL BOLT CIRCLE --- CENTER POINT METHOD 5 = PARTIAL BOLT CIRCLE --- CENTER POINT METHOD 6 = FULL CIRCULAR --- THRU 3 POINTS METHOD 7 = PARTIAL CIRCULAR --- THRU 3 POINTS METHOD 8 = FULL BOLT CIRCLE --- THRU 3 POINTS METHOD 9 = PARTIAL BOLT CIRCLE --- THRU 3 POINTS METHOD 10 = OFFSET CYLINDRICAL --- KEYIN OFFSET DISTANCE METHOD 11 = OFFSET CYLINDRICAL --- CALCULATE OFFSET DISTANCE METHOD 12 = SYMMETRICAL 13 = OFFSET CENTER POINT --- XC-AXIS, DISTANCE FROM ARC NORMAL METHOD 14 = OFFSET CENTER POINT --- XC-AXIS, DISTANCE FROM ARC CENTER METHOD 15 = OFFSET CENTER POINT --- XC-AXIS, DISTANCE CALCULATED METHOD 16 = OFFSET CENTER POINT --- YC-AXIS, DISTANCE FROM ARC NORMAL METHOD 17 = OFFSET CENTER POINT --- YC-AXIS, DISTANCE FROM ARC CENTER METHOD 18 = OFFSET CENTER POINT --- YC-AXIS, DISTANCE CALCULATED METHOD |
| const int * | ip2 | Input | NUMBER OF ENTITIES IN ARRAY |
| const tag_t * | np3 | Input | ARRAY OF ENTITY IDs THAT ARE TO BE ASSOCIATED TO THE CENTERLINE |
| const tag_t * | np4 | Input | ENTITY ID IF "IP1" IS 1 ................. NOT USED IF "IP1" IS 2 - 5 ............. ENTITY SELECTED FOR CENTERLINE CENTER POINT IF "IP1" IS 6 - 9 ............. NOT USED IF "IP1" IS 10, 11 ............ ENTITY SELECTED FOR CALCULATING THE OFFSET DISTANCE IF "IP1" IS 12 - 14, 16, 17 ... NOT USED IF "IP1" IS 15, 18 ............ ENTITY SELECTED FOR CALCULATING DISTANCE TO BE USED IN PLACEMENT OF THE OFFSET CENTER POINT |
| const double * | rp5 | Input | DISTANCE VALUE IF "IP1" IS 1 - 9 ............. NOT USED IF "IP1" IS 10 ................ OFFSET DISTANCE IF "IP1" IS 11, 12, 15, 18 .... NOT USED IF "IP1" IS 13, 16 ............ DISTANCE FROM ARC NORMAL IF "IP1" IS 14, 17 ............ DISTANCE FROM ARC CENTER |
| tag_t * | nr6 | Output | ENTITY ID OF CENTERLINE |
| int * | ir7 | Output | RETURN CODE: = 0 SUCCESSFUL COMPLETION = 1 NO ENTITIES SUPPLIED = 2 MORE THAN 100 ENTITIES SUPPLIED = 3 CENTERLINE TYPE REQUIRES 3 OR MORE ENTITIES = 4 CENTERLINE TYPE REQUIRES 2 ENTITIES = 5 CENTERLINE TYPE REQUIRES 1 ENTITY = 6 INVALID ENTITY TYPE FOR CENTERLINE = 7 POINTS ARE COINCIDENT = 8 POINT IS NOT ON CENTERLINE = 9 INVALID ENTITY TYPE FOR CENTER POINT = 10 POINT IS COINCIDENT WITH CENTER = 11 POINTS ARE COLLINEAR = 12 INVALID ENTITY TYPE FOR OFFSET POINT = 13 INVALID CENTERLINE TYPE = 14 OFFSET CENTER POINT CENTERLINE REQUIRES AN ARC = 15 MODEL ENTITIES WERE SUPPLIED ON A DRAWING (NOT SUPPORTED) |
uf5552 (view source)
Read drafting object origin.
void uf5552
tag_t * np1,
double * rr2,
int * ir3
| tag_t * | np1 | Input | Drafting object identifier. |
| double * | rr2 | Output | 3D object origin in model space coordinates. |
| int * | ir3 | Output | Return code. 0 = success, 1 = failure. |
uf5553 (view source)
Edits the drafting object origin.
void uf5553
tag_t * np1,
double * rp2,
int * ir3
| tag_t * | np1 | Input | Drafting Object Identifier |
| double * | rp2 | Input | 3-D Object Origin (In model space coordinates) |
| int * | ir3 | Output | Return code: 1 = Success 2 = Failure |
uf5554 (view source)
Returns the number of objects that are associated to a drafting object.
void uf5554
tag_t * np1,
int * ir2
| tag_t * | np1 | Input | Object Identifier Of Drafting Object |
| int * | ir2 | Output | Number Of Associated Objects |
uf5555 (view source)
Returns the n-th associated object of a drafting object.
void uf5555
tag_t * np1,
int * ip2,
tag_t * nr3
| int * | ip2 | Input | Index Number Of The Associated Object |
| tag_t * | nr3 | Output | Object Identifier Of N-th Associated Object |
uf5561 (view source)
Add Lines to an Assorted Parts Annotation (dimensions by parts)
uf5562, uf5563, and uf5564 can then be called to add lines, arcs, text,
void uf5561
int * num_lines,
double * line_coords
| int * | num_lines | Input | Number Of Lines. This must not exceed MAX_LINES. |
| double * | line_coords | Input | Array Of Line Points [0]Line 1, End 1, X Pos [1]Line 1, End 1, Y Pos [2]Line 1, End 2, X Pos [3]Line 1, End 2, Y Pos [4]Line 2, End 1, X Pos . . . Line IP1, End 2, Y Pos |
uf5562 (view source)
Add Arcs to an Assorted Parts Annotation (dimensions by parts)
uf5561, uf5563, and uf5564 can then be called to add lines, arcs, text,
void uf5562
int * num_arcs,
double * arc_data
| int * | num_arcs | Input | Number Of Arc segments (not to exceed MAX_ARC_SEGMENTS) |
| double * | arc_data | Input | Arc data [0,1] 2D Arc center In Coordinates Of annotation [2] Arc Radius [3,4] Start and End Angles (In Radians) . . . [2num_arcs+1,2num_arcs+2] segment angles |
uf5564 (view source)
Add an Arrow to an Assorted Parts Annotation (dimensions by parts)
uf5561, uf5562, and uf5563, can then be called to add lines, arcs, text,
and arrows to the dimension/ drafting aid. Routine uf5565 must be
void uf5564
int * arrowhead_subtype,
double * arrow_origin,
double * arrow_angle
| int * | arrowhead_subtype | Input | Arrowhead Of Subtype 1 = Closed 2 = Open 3 = Arch Cross 4 = Dot 5 = Origin Symbol 6 = None |
| double * | arrow_origin | Input | 2d arrow origin in coordinates of annotation |
| double * | arrow_angle | Input | Arrow Angle (Radians) |
uf5565 (view source)
Close an Assorted Parts Annotation (dimensions by parts)
This routine closes the definition by parts and creates the
dimension/drafting aid. This routine is called after
routine UF_DRF_create_assortpart_dim or UF_DRF_create_assortpart_aid has
been called to initialize the definition and routines uf5561 through uf5564
have been called to add lines, arcs, text, and arrows.
void uf5565
tag_t * annotation_tag
| tag_t * | annotation_tag | Output | Annotation tag |
uf5575 (view source)
Obtain Coordinates of Dimension Area Box
Returns the lower left and upper right coordinates of a dimension
area box.
void uf5575
tag_t * np1,
double * rar2,
double * rar3,
int * ir4
| double * | rar2 | Output | Lower Left Coordinate |
| double * | rar3 | Output | Upper Right Coordinate |
| int * | ir4 | Output | Return code: 0 = Success 1 = Error - NP1 Not A Drafting Object |
UF_DRF_add_assortpart_to_ann (view source)
Adds Assorted Parts to an Annotation.
drafting
int UF_DRF_add_assortpart_to_ann
tag_t annotation_tag,
int number_of_objects,
tag_t * list_of_objects
| tag_t | annotation_tag | Input | annotation tag to add assorted parts |
| int | number_of_objects | Input | number of objects to add |
| tag_t * | list_of_objects | Input | number_of_objects list of object tags to add |
UF_DRF_add_compound_weld_symbol (view source)
Add compound weld symbol
Return code:
0 = No error
not 0 = Error code
Possible return codes can include the following
UF_DRF_NO_ERRORS - No error
UF_err_program_not_initialized - Open C API has not been
initialized
UF_DRF_null_object_structure
UF_DRF_ weld_symbols_t
UF_DRF_object_t
Originally released in v18.0
drafting
int UF_DRF_add_compound_weld_symbol
tag_t weld_symbol,
UF_DRF_weld_sym_info_t * top_info,
UF_DRF_weld_sym_info_t * bottom_info
UF_DRF_add_controlling_exp (view source)
Link drafting object to the controlling expression
Originally released in V16.0
drafting
int UF_DRF_add_controlling_exp
tag_t object,
tag_t exp_id
| tag_t | object | Input | Drafting object |
| tag_t | exp_id | Input | Controlling expression |
UF_DRF_add_symbol_to_object (view source)
Adds a symbol to a drafting object.
drafting
int UF_DRF_add_symbol_to_object
UF_DRF_symbol_create_data_t * symbol_data,
tag_t object_tag
UF_DRF_add_to_dimension (view source)
Append text, form-position tolerance, or ID symbol to a dimension.
drafting
int UF_DRF_add_to_dimension
unsigned int * entity_id,
int * segment_num,
int ann_data [ 10 ] ,
int * text_type,
int * text_position,
int * relative_just,
int * line_space,
int * number_lines,
const UF_DRF_one_apptext_line_t text_array [ ]
| unsigned int * | entity_id | Input | Object identifier of the dimension object to be added to. |
| int * | segment_num | Input | Segment number to add to. UF_DRF_ask_ann_data can be called to find out the number of segments in a dimension. |
| int | ann_data [ 10 ] | Input | The annotation data for this dimension, returned from UF_DRF_ask_ann_data. |
| int * | text_type | Input | The type of appended text: 18 = Pure text 19 = circle ID SYMBOL text 20 = divided circle ID SYMBOL 21 = square ID SYMBOL 22 = divided square ID SYMBOL 23 = hexagon ID SYMBOL 24 = divided hexagon ID SYMBOL 25 = triangle pointed up ID SYMBOL 26 = triangle pointed down ID SYMBOL 27 = datum target ID SYMBOL 28 = rounded box ID SYMBOL 29 = Form and positional tolerance text 44 = Multi-type text |
| int * | text_position | Input | Position of the appended text: 1 = below 2 = after 3 = above 4 = before |
| int * | relative_just | Input | Relative text justification: 1 = left 2 = center 3 = right |
| int * | line_space | Input | Flag for line spacing: 0 = No line spacing, this is the default. 1 = Use a line spacing adjustment when adding text blocks above or below. |
| int * | number_lines | Input | Number of lines of text to append. |
| const UF_DRF_one_apptext_line_t | text_array [ ] | Input | number_lines Array of text strings to be appended to the dimension. |
UF_DRF_are_draft_objects_const (view source)
This function will determine if the current drafting objects in the system
match a set of given drafting objects previously recorded with the
UF_DRF_record_draft_objects function.
Returns
UF_DRF_NO_ERRORS
UF_DRF_OBJECTS_ARE_NOT_CONSTANT
Internal & External
Created in NX4.0
drafting
int UF_DRF_are_draft_objects_const
void * objs,
logical check_view_data
| void * | objs | Input | Drafting object data from UF_DRF_record_draft_objects |
| logical | check_view_data | Input | Should view data be compared |
UF_DRF_ask_ang_obj_suppress_zeros (view source)
Determines if the suppress zeros option for an angular dimension is set.
Suppress zero option: display zero,
suppress leading zeros,
suppress any zeros
suppress trailing zeros.
This function originally released in V17.0
int UF_DRF_ask_ang_obj_suppress_zeros
tag_t object,
UF_DRF_angular_suppress_zeros_t * option
UF_DRF_ask_ang_obj_units_format (view source)
Queries the nominal and tolerance units format for an angular dimension.
int UF_DRF_ask_ang_obj_units_format
tag_t object,
UF_DRF_angular_units_t * nominal_format,
UF_DRF_angular_units_t * tolerance_format
UF_DRF_ask_ann_arc_seg_angles (view source)
Ask start and end Angles of an Annotation Object Arc Segment.
int UF_DRF_ask_ann_arc_seg_angles
int * arc_segment,
int * ann_data,
double arc_angles [ 2 ]
| int * | arc_segment | Input | arc segment number |
| int * | ann_data | Input / Output | annotation data |
| double | arc_angles [ 2 ] | Output | start and end angles of arc segment |
UF_DRF_ask_ann_data (view source)
Ask data of an Annotation Object. The text data for the annotation
can be read by passing the ann_data array to UF_DRF_ask_text_data
This method will not work for the annotations having new leaders i.e.
leaders created in or after NX7.5. For such case, below methods can be used:
1. NXOpen::Annotations::ComponentData::GetLineComponents
2. NXOpen::Annotations::ComponentData::GetArcComponents
3. NXOpen::Annotations::ComponentData::GetTextComponents
4. NXOpen::Annotations::ComponentData::GetArrowComponents
In V17.0 Appended Text was enhanced to allow any combination of
the 4 appended text locations. 6 and 30 are no longer returned for
the text type for 1st and 2nd appended text. Instead the following values
are returned:
50 - above appended text
51 - below appended text
52 - before appended text
53 - after appended text
int UF_DRF_ask_ann_data
tag_t * annotation_tag,
int search_mask [ 4 ] ,
int * cycle_flag,
int * ann_data_type,
int * ann_data_form,
int * num_segments,
double ann_origin [ 2 ] ,
double * radius_angle
| tag_t * | annotation_tag | Input | tag of annotation object |
| int | search_mask [ 4 ] | Input | array of data types to search [0] != 0, line data [1] != 0, arc data [2] != 0, text data [3] != 0, arrow data |
| int * | cycle_flag | Input / Output | cycle flag must be set to zero on first call incremented to show the current number of the call 0 = no more data found |
| int | ann_data [ 10 ] | Input / Output | Array of annotation data. The user must declare this as int ann_data[10], and it will then be filled in by this routine. |
| int * | ann_data_type | Output | annotation data type 0 = no more data of requested types 1 = line 2 = arc 3 = text 4 = arrow |
| int * | ann_data_form | Output | annotation data type form if ann_data_type = 1 1 = RESERVED 2 = RESERVED 3 = EXTENSION LINE 4 = DIMENSION LINE 5 = STUB 6 = DUAL BRACKET 7 = BASIC TOLERANCE LINE 8 = ISO LINE 9 = ADDED LINE if ann_data_type = 2 not used if ann_data_type = 3 1 = DIM TEXT OR MAIN TEXT 2 = DUAL DIM TEXT 3 = TOLERANCE TEXT 4 = DUAL TOLERANCE TEXT 5 = RAD/DIA TEXT 6 = OBSOLETE 7 = TEXT APP AT EDITING ID SYM TEXT INPUT AT CREATION: 8 = CIRCLE 9 = DIVIDED CIRCLE 10 = SQUARE 11 = DIVIDED CIRCLE 12 = HEXAGON 13 = DIVIDED HEXAGON 14 = TRIANGLE, POINT UP 15 = TRIANGLE, POINT DOWN 16 = DATUM TARGET 17 = ROUNDED BOX 18 = F&P TOL TEXT INP AT CREATION ID SYM TEXT APPENDED AT EDITING: 19 = CIRCLE 20 = DIVIDED CIRCLE 21 = SQUARE 22 = DIVIDED CIRCLE 23 = HEXAGON 24 = DIVIDED HEXAGON 25 = TRIANGLE, POINT UP 26 = TRIANGLE, POINT DOWN 27 = DATUM TARGET 28 = ROUNDED BOX 29 = F&P TOL TEXT APP AT EDITING 30 = OBSOLETE SECOND ID SYM TEXT INPUT AT CREATION: 31 = CIRCLE 32 = DIVIDED CIRCLE 33 = SQUARE 34 = DIVIDED CIRCLE 35 = HEXAGON 36 = DIVIDED HEXAGON 37 = TRIANGLE, POINT UP 38 = TRIANGLE, POINT DOWN 39 = DATUM TARGET 40 = ROUNDED BOX 41 = SECOND F&P TOL TEXT INP AT CREATION 42 = MULTI-TYPE TEXT INP AT CREATION 43 = 2ND MULTI-TYPE TEXT APP AT CREATION 44 = MULTI-TYPE TEXT APP AT 50 = ABOVE APPENDED TEXT 51 = BELOW APPENDED TEXT 52 = BEFORE APPENDED TEXT 53 = AFTER APPENDED TEXT EDITING if ann_data_type = 4 1 = CLOSED ARROW 2 = OPEN ARROW 3 = ARCH CROSS 4 = DOT |
| int * | num_segments | Output | number of data segments if ann_data_type = 1, line segments = 2, arc segments = 3, lines of text = 4, not used |
| double | ann_origin [ 2 ] | Output | annotation data origin if ann_data_type = 1, not used = 2, arc origin = 3, text origin = 4, arrow origin |
| double * | radius_angle | Output | annotation radius or angle if ann_data_type = 1, not used = 2, arc radius = 3, not used = 4, arrow angle |
UF_DRF_ask_ann_line_seg_ends (view source)
Ask end points of an Annotation Object Line Segment.
int UF_DRF_ask_ann_line_seg_ends
int * line_segment,
double line_endpoints [ 4 ]
| int * | line_segment | Input | line segment number |
| int | ann_data [ 10 ] | Input / Output | annotation data |
| double | line_endpoints [ 4 ] | Output | 2D coordinates of line segment |
UF_DRF_ask_annotation_template (view source)
Ask for the name of the template part which is to be used to be used in
UF_DRF_inherit_feature_data.
UF_DRF_inherit_type_t
UF_DRF_ask_callout_of_annotation
UF_DRF_ask_controlling_member_of_callout
UF_DRF_ask_number_of_rows_in_callout
UF_DRF_ask_callout_row_members
UF_DRF_set_annotation_template
Originally released in v19.0
int UF_DRF_ask_annotation_template
char * * annotation_template_name
| char * * | annotation_template_name | Output to UF_*free* | the name of the annotation template part which is used by UF_DRF_inherit_feature_data. The name is the same as the name appearing in the Feature Parameters dialog and does not contain the directory in which the part resides or the extension .atp.prt, for example, ansi or iso_din |
UF_DRF_ask_annotation_text_box (view source)
Description -
Ask the text box of an annotation object. The text box information
returned is in the format of:
upper_left - this is the upper left location point of the box
length - this is the length of the box
height - this is the height of the box
0 = No error
not 0 = Error code
int UF_DRF_ask_annotation_text_box
tag_t annotation,
double upper_left [ 3 ] ,
double * length,
double * height
| tag_t | annotation | Input | Tag of the annotation |
| double | upper_left [ 3 ] | Output | Upper left point |
| double * | length | Output | Length of box |
| double * | height | Output | Height of box |
UF_DRF_ask_appended_text (view source)
The following function will query all the appended text for a dimension.
Internal & External
Created in V17.0
int UF_DRF_ask_appended_text
tag_t dimension,
int * num_text,
UF_DRF_appended_text_p_t * appended_text
| tag_t | dimension | Input | Dimension object to query |
| int * | num_text | Output | Number of appended text |
| UF_DRF_appended_text_p_t * | appended_text | Output to UF_*free* | Appended text. Please use UF_DRF_free_appended_ text to free the data returned. |
UF_DRF_ask_areafill_data (view source)
Finds the area fill data for the specified area fill object. The data is
contained in the area fill structure.
Internal & External
int UF_DRF_ask_areafill_data
tag_t areafill_id,
UF_DRF_areafill_t * areafill_data
UF_DRF_ask_arrow_data (view source)
Gets drafting arrow block parameter data.
0 = OK
1 = ERROR (a NULL entity found)
2 = ERROR (not a drafting aid nor a dimension entity)
3 = ERROR (no arrow data for this entity)
4 = ERROR (record instance is greater than total count)
5 = ERROR (included angle is 180 degree)
Other = Standard Error code
int UF_DRF_ask_arrow_data
int data_block [ 10 ] ,
int * arrow_type,
int * filled,
double origin [ 2 ] ,
double * arrow_angle,
double * include_angle,
double * arrow_height,
double * arrow_length
| int | data_block [ 10 ] | Input | Only the following array elements are used: [0] = drafting object identifier [4] = record instance - If a label had 4 leaders, it would then have 4 arrows thus possible record instance values of 1, 2, 3 and 4. |
| int * | arrow_type | Output | 1 = Closed Arrow 2 = Open Arrow 3 = Arch Cross 4 = Dot 5 = Origin symbol 6 = None |
| int * | filled | Output | The arrow head is either filled or open: 0 = open 1 = filled |
| double | origin [ 2 ] | Output | The x and y coordinates of the arrowhead: [0] = x-coordinate [1] = y-coordinate |
| double * | arrow_angle | Output | The angle of the arrow line (degrees) |
| double * | include_angle | Output | The arrowhead included angle (degrees) |
| double * | arrow_height | Output | The height of the arrowhead. If the arrowhead type is 4 (dot), then this is the diameter of the dot. |
| double * | arrow_length | Output | The length of the arrowhead |
UF_DRF_ask_assoc_exp (view source)
Gets the expression, if it exists, associated to the specified dimension.
If there is an expression associated with the specified dimension, this
function returns its tag. If there is no expression associated with the
specified dimension, a NULL_TAG is returned.
Return code:
0 = No error
not 0 = Error code
Possible return codes can include the following:
UF_DRF_null_object - The object tag is NULL.
UF_DRF_invalid_object - The object is invalid for this function.
UF_err_program_not_initialized - Open API has not been initialized.
int UF_DRF_ask_assoc_exp
tag_t object_tag,
tag_t * exp_tag
| tag_t | object_tag | Input | The tag of a dimension. |
| tag_t * | exp_tag | Output | The tag of the expression associated to the specified input object tag. |
UF_DRF_ask_associative_origin (view source)
The following function will query the associative origin information for the
annotation.
Created in V17.0
int UF_DRF_ask_associative_origin
tag_t drafting_entity,
UF_DRF_associative_origin_p_t * origin_data,
double origin [ 3 ]
| tag_t | drafting_entity | Input | Dimension or drafting object to query. |
| UF_DRF_associative_origin_p_t * | origin_data | Output to UF_*free* | Data used to define the associative origin. To free this allocated data, please use UF_free. |
| double | origin [ 3 ] | Output | Origin of the annotation in absolute coords. |
UF_DRF_ask_associativity_data (view source)
The following function queries all of the associativities for the annotation
object.
Internal or External
Originally released in V19.0
int UF_DRF_ask_associativity_data
tag_t object,
int * num_associativities,
UF_DRF_object_assoc_data_p_t * associativity_data
| tag_t | object | Input | Dimension or drafting object in which to query the associativity information. Valid objects include: all dimension types, labels, id symbols, centerlines (linear, symmetrical, cylindrical, bolt hole, etc.), intersection symbols, and GD&T symbols (with leaders). |
| int * | num_associativities | Output | The number of associativities on the object. |
| UF_DRF_object_assoc_data_p_t * | associativity_data | Output to UF_*free* | An array containing the information for each associativity for that object. Use UF_free to free this array of allocated memory. |
UF_DRF_ask_boundaries (view source)
Returns the number of boundaries, and the tags associated with the
boundaries given the specified input tag.
int UF_DRF_ask_boundaries
tag_t draft_aid_tag,
int * num_boundaries,
tag_p_t * boundary_tags
| tag_t | draft_aid_tag | Input | Tag of the area fill or crosshatch object |
| int * | num_boundaries | Output | The number of boundaries |
| tag_p_t * | boundary_tags | Output to UF_*free* | The array which contains the tags of the boundaries. This array must be freed by calling UF_free. |
UF_DRF_ask_callout_of_annotation (view source)
Get the callout that contains a specified annotation
Internal & External
Created in V18.0
int UF_DRF_ask_callout_of_annotation
tag_t annotation,
tag_t * callout
| tag_t | annotation | Input | Tag of annotation |
| tag_t * | callout | Output | Tag of callout or NULL_TAG if annotation is not part of callout |
UF_DRF_ask_callout_row_members (view source)
Get the feature annotation members of a callout row
Internal & External
Created in V18.0
int UF_DRF_ask_callout_row_members
tag_t callout,
int row,
int * num_members,
tag_t * * members
| tag_t | callout | Input | Tag of callout |
| int | row | Input | Row in callout (starting at zero) |
| int * | num_members | Output | Number of members in row |
| tag_t * * | members | Output to UF_*free* | Callout members |
UF_DRF_ask_centerline_info (view source)
Returns the centerline type, the number of centerline objects, and the
data of the centerline given the specified centerline tag. For circular
and bolt circle centerlines, the centerpoint method is always returned
for centerline_type. For offset cylindrical centerlines,
UF_DRF_offcyl_cline is always returned for centerline_type.
Use UF_DRF_ask_associativity_data to query the centerline's associativity
data including coordinates of the associated position(s).
int UF_DRF_ask_centerline_info
tag_t centerline_tag,
UF_DRF_valid_cline_form_t * centerline_type,
double centerline_origin [ 3 ] ,
UF_DRF_centerline_info_p_t * centerline_info
| tag_t | centerline_tag | Input | Tag of the centerline |
| UF_DRF_valid_cline_form_t * | centerline_type | Output | Type of centerline (see uf_drf_types.h) |
| double | centerline_origin [ 3 ] | Output | Centerline origin |
| UF_DRF_centerline_info_p_t * | centerline_info | Output to UF_*free* | Centerline information. This must be freed by calling UF_DRF_free_centerline. |
UF_DRF_ask_chamfer_dimension_data (view source)
Description -
ask chamfer dimension preferences
PARAMETERS -
cham_dim_tag, - <I> tag of cham dim
cham_dim_data - <O> cham dim prefs
return - <O> return code:
0 = OK
if not 0 = error code
As of NX4 this function will allocate the symbol_name in the
UF_DRF_chamfer_dimension_data structure. It will be up to the user
to free the symbol_name.
int UF_DRF_ask_chamfer_dimension_data
tag_t cham_dim_tag,
UF_DRF_chamfer_dimension_data_p_t cham_dim_data
UF_DRF_ask_controlling_exp (view source)
Get the controlling expression of the drafting object
int UF_DRF_ask_controlling_exp
tag_t object,
tag_t * exp_id
| tag_t | object | Input | drafting object |
| tag_t * | exp_id | Output | Controlling expression of the object |
UF_DRF_ask_controlling_member_of_callout (view source)
Get the controlling member of a callout. This member is used for
positioning the entire callout and, if deleted, causes the entire
callout to be deleted.
Internal & External
Created in V18.0
int UF_DRF_ask_controlling_member_of_callout
tag_t callout,
tag_t * controlling_member
| tag_t * | controlling_member | Output | Controlling member |
UF_DRF_ask_custom_symbol_angle (view source)
Ask the angle for a custom symbol instance.
int UF_DRF_ask_custom_symbol_angle
tag_t symbol_tag,
double * angle
| tag_t | symbol_tag | Input | tag of a custom symbol instance |
| double * | angle | Output | double value of the angle |
UF_DRF_ask_custom_symbol_attach_locations (view source)
This function will query the leader attachment locations for a custom
symbol. The array indices are as follows:
locations[0] = left leader attachment location
locations[1] = right leader attachment location
If there is no leader on a given side, then the tag will be NULL_TAG.
Returns
UF_DRF_NO_ERRORS
Internal & External
Created in NX3.0.2
int UF_DRF_ask_custom_symbol_attach_locations
tag_t symbol,
tag_t locations [ 2 ]
| tag_t | symbol | Input | The tag of the custom symbol |
| tag_t | locations [ 2 ] | Output | An array of 2 tags corresponding to the left and right leader attachment locations |
UF_DRF_ask_custom_symbol_leader (view source)
The following function will query the leader of a custom symbol. If the
symbol has no leader, the input variable will be set to NULL. The caller of
the function is responsible for freeing the memory for the leader by using
UF_DRF_free_leader_data.
NOTE: Since this function exposes components of the custom symbol
that are otherwise hidden, this function should only be called by internal
NX callers which need the Open API (e.g. translators)
Returns
UF_DRF_NO_ERRORS
UF_DRF_NOT_DRAFTING_OBJECT
UF_DRF_INVALID_SYMBOL_TYPE
UF_err_bad_parameter_number_2
Internal & External
Created in NX3.0.2
int UF_DRF_ask_custom_symbol_leader
tag_t symbol,
UF_DRF_leader_data_p_t * leader_data
UF_DRF_ask_custom_symbol_name (view source)
This function returns the name of custom symbol.
Returns
UF_DRF_NO_ERRORS
Internal & External
Created in NX5.0.3
int UF_DRF_ask_custom_symbol_name
tag_t custom_symbol,
char* * symbol_name
| tag_t | custom_symbol | Input | Custom symbol |
| char* * | symbol_name | Output to UF_*free* | Custom symbol name Must be freed by calling UF_free |
UF_DRF_ask_custom_symbol_scale (view source)
Ask the symbol scale for a custom symbol instance.
int UF_DRF_ask_custom_symbol_scale
tag_t symbol_tag,
double * scale
| double * | scale | Output | double value of the symbol scale |
UF_DRF_ask_diameter_radius_preferences (view source)
Returns preferences for the display of radial dimensions.
Internal & External
int UF_DRF_ask_diameter_radius_preferences
UF_DRF_diameter_radius_preferences_t * diameter_radius_preferences
UF_DRF_ask_dim_appended_text_space_factor (view source)
Ask the factor for the space between the dimension and the appended text for the specified dimension.
This factor controls the spacing between the before appended text and the next piece of dimension text to its right,
and the spacing between the after appended text and the next piece of dimension text to its left.
This factor is applied to the appended text character size to determine the spacing.
NX 2.0 release.
int UF_DRF_ask_dim_appended_text_space_factor
tag_t dimension,
double * space_factor
| tag_t | dimension | Input | dimension tag |
| double * | space_factor | Output | factor for spacing between dimension and appended text |
UF_DRF_ask_dim_dim_line_space_factor (view source)
Ask the space factor for the space between the dimension and the dimension line for the specified dimension.
This factor controls the spacing between the bottom most piece of dimension text and the dimension line only
when the text orientation is UF_DRF_DIMENSION_TEXT_OVER_DIMENSION_LINE.
This factor is applied to the dimension text character size to determine the spacing.
NX 2.0 release.
int UF_DRF_ask_dim_dim_line_space_factor
tag_t dimension,
| double * | space_factor | Output | factor for spacing between dimension and dimension line |
UF_DRF_ask_dim_info (view source)
Returns the dimension subtype, number of objects, data of objects,
associated text, and dimension origin given the specified dimension tag.
The origin returned will be associated with the WCS plane when the
annotation was created. Use UF_DRF_ask_origin to get the origin in absolute
space.
Use UF_DRF_ask_associativity_data to query the dimension's associativity
int UF_DRF_ask_dim_info
tag_t dim_tag,
int * dim_subtype,
double dim_origin [ 3 ] ,
UF_DRF_dim_info_p_t * dim_info
| tag_t | dim_tag | Input | Tag of the dimension |
| int * | dim_subtype | Output | Dimension subtype |
| double | dim_origin [ 3 ] | Output | Dimension origin |
| UF_DRF_dim_info_p_t * | dim_info | Output to UF_*free* | Dimension information. This must be freed by calling UF_DRF_free_dimension. |
UF_DRF_ask_dim_inspection_type (view source)
Routine -
Description -
Ask dimension inspection type preference.
Input - Dimension tag.
Output -
UF_DRF_inspection_type_t inspection_type
Return -
0 = No error
Error code if not zero.
UF_DRF_invalid_object - if the dimension is invalid
int UF_DRF_ask_dim_inspection_type
tag_t dim_tag,
UF_DRF_inspection_type_t * inspection_type
UF_DRF_ask_dim_reference_type (view source)
Routine -
Description -
Ask dimension reference type preference.
Output -
UF_DRF_text_above_leader_t option
Return -
0 = No error
Error code if not zero. ( including if given object is not dimension)
int UF_DRF_ask_dim_reference_type
tag_t dim_tag,
UF_DRF_reference_symbol_type_t * ref_type
UF_DRF_ask_dim_tolerance_text_space_factor (view source)
Ask the factor for the space between the dimension and the tolerance text for the specified dimension.
This factor controls the spacing between the dimension text and the after tolerance text.
This factor is applied to the tolerance text character size to determine the spacing.
NX 2.0 release.
int UF_DRF_ask_dim_tolerance_text_space_factor
tag_t dimension,
| double * | space_factor | Output | factor for spacing between dimension and tolerance text |
UF_DRF_ask_dimension_preferences (view source)
Returns dimension preferences for arrow and line formatting, type of
placement, tolerance and precision, and text orientation.
Internal & External
int UF_DRF_ask_dimension_preferences
UF_DRF_dimension_preferences_t * dimension_preferences
UF_DRF_ask_dimension_preferences1 (view source)
In order to provide appropriate .NET binding for UF_DRF_ask_dimension_preferences,
UF_DRF_ask_dimension_preferences1 is introduced.
Note: C/C++ users can continue to use UF_DRF_ask_dimension_preferences.
For docuementation, refer to documentation of UF_DRF_ask_dimension_preferences.
Originally released in NX7.5
int UF_DRF_ask_dimension_preferences1
UF_DRF_dimension_preferences1_t * * dimension_preferences
| UF_DRF_dimension_preferences1_t * * | dimension_preferences | Output to UF_*free* | pointer to preferences structure to be populated with the dimension preferences Must be freed using UF_DRF_free_dimension_preferences1 |
UF_DRF_ask_dimension_set_offset (view source)
Return the offset of the dimension in a dimension set. If a dimension set tag
is given, the offset of the first dimension in the set is returned.
Return code:
0 = No error
not 0 = Error code
UF_err_bad_parameter_number_1 - if the dimension tag is invalid.
int UF_DRF_ask_dimension_set_offset
tag_t dimension,
double * offset
| tag_t | dimension | Input | Tag of the given dimension. |
| double * | offset | Output | Dimension set offset of the given dimension. |
UF_DRF_ask_dimension_text (view source)
This function returns the dimension text - both the main text and the dual
text. The returned text may contain just the computed dimension value or
manual text including the control characters.
Note that the text doesn't contain the tolerance text, appended text or text
for flags like inspection/reference.
Returns
UF_DRF_NO_ERRORS
Internal & External
Created in NX5.0.3
drafting
int UF_DRF_ask_dimension_text
tag_t dimension,
int* num_main_text,
char* * * main_text,
int* num_dual_text,
char* * * dual_text
| tag_t | dimension | Input | Dimension |
| int* | num_main_text | Output | Number of main dimension text lines |
| char* * * | main_text | Output to UF_*free* | Main dimension text lines |
| int* | num_dual_text | Output | Number of dual dimension text lines |
| char* * * | dual_text | Output to UF_*free* | Dual dimension text lines |
UF_DRF_ask_dimensions_of_set (view source)
Return the dimensions in a dimension set.
Return code:
0 = No error
not 0 = Error code
UF_DRF_null_object - if the dimension set is null
UF_DRF_invalid_object - if the dimension set is invalid
int UF_DRF_ask_dimensions_of_set
tag_t dimension_set,
tag_t * * sub_dimensions,
int * num
| tag_t | dimension_set | Input | Tag of the given dimension set. |
| tag_t * * | sub_dimensions | Output to UF_*free* | Point to the tag array of the dimensions in a given set. |
| int * | num | Output | number of dimensions in the array. |
UF_DRF_ask_dogleg_info (view source)
Returns the dogleg type, distance in WCS coordinates, and angle in
degrees given the specified ordinate dimension tag.
int UF_DRF_ask_dogleg_info
tag_t orddim_tag,
UF_DRF_dogleg_info_t * dogleg_info
| tag_t | orddim_tag | Input | Tag of ordinate origin |
| UF_DRF_dogleg_info_t * | dogleg_info | Output | Ordinate dimension dog leg information. The calling program must allocate a UF_DRF_dogleg_info_t structure and pass in the pointer to that structure. |
UF_DRF_ask_draft_aid_text_info (view source)
Returns character size, text angle, origin, length, height, and distance
from the origin to the top of a given text block and text strings given
the specified drafting aid tag.
V17.0 Add full_string and full_num_char to UF_DRF_draft_aid_text_t
to provide access to all of the full drafting aid text
int UF_DRF_ask_draft_aid_text_info
int * num_text,
UF_DRF_draft_aid_text_info_t * * text_info
| tag_t | draft_aid_tag | Input | Tag of drafting aid object |
| int * | num_text | Output | Number of text strings |
| UF_DRF_draft_aid_text_info_t * * | text_info | Output to UF_*free* | Pointer to data structure which contains drafting aid text information (see uf_drf_types.h) of the drafting aid object. This must be freed by calling UF_DRF_free_text. |
UF_DRF_ask_embedded_uds_font_info (view source)
This function will return the embedded User Defined Symbol font name and
stroke data. "stroke_info" can be freed by making a call to "UF_free".
NOTE: The pen_status from returned stroke_info can be either - draw or move.
UF_DRF_UD_SYMBOL_DRAW means start drawing a new stroke from this position.
UF_DRF_UD_SYMBOL_MOVE means draw the stroke till this position.
Return code:
0 = No error
not 0 = Error code
Created in V16.0
int UF_DRF_ask_embedded_uds_font_info
tag_t symbol_font_tag,
char symbol_name [ 9 ] ,
int * num_of_strokes,
UF_DRF_stroke_info_t * * stroke_info
| tag_t | symbol_font_tag | Input | Tag of Symbol Font |
| char | symbol_name [ 9 ] | Output | Name of Symbol Font |
| int * | num_of_strokes | Output | Total number of stroke |
| UF_DRF_stroke_info_t * * | stroke_info | Output to UF_*free* | Stroke Data |
UF_DRF_ask_folded_radius_info (view source)
Returns the fold location in WCS coordinates and the fold angle in
degrees given the specified folded radius tag.
int UF_DRF_ask_folded_radius_info
tag_t frdim_tag,
UF_DRF_foldedradius_dim_info_t * frdim_info
UF_DRF_ask_gdt_symbol_info (view source)
Given the GD&T Symbol tag, the function returns the associated text
string, object origin, leader type and attachment type, and data of
object to attach leader.
int UF_DRF_ask_gdt_symbol_info
tag_t gdt_symbol_tag,
double gdt_symbol_origin [ 3 ] ,
UF_DRF_gdt_symbol_info_p_t * gdt_symbol_info
| tag_t | gdt_symbol_tag | Input | Tag of GD&T Symbol |
| double | gdt_symbol_origin [ 3 ] | Output | GD&T Symbol origin |
| UF_DRF_gdt_symbol_info_p_t * | gdt_symbol_info | Output to UF_*free* | GD&T Symbol information. This must be freed by calling UF_DRF_free_gdtsymbol. |
UF_DRF_ask_hatch_fill_preferences (view source)
Returns the preferences for crosshatching and area fill
Internal & External
int UF_DRF_ask_hatch_fill_preferences
UF_DRF_hatch_fill_preferences_t * hatch_fill_preferences
UF_DRF_ask_id_symbol_geometry (view source)
Return the geometry for an id symbol.
Returns the geometry for an id symbol.
int UF_DRF_ask_id_symbol_geometry
tag_t id_symbol,
int * num_lines,
double * * lines,
int * num_arcs,
UF_DRF_arc_info_p_t * arcs
| tag_t | id_symbol | Input | The ID symbol to query |
| int * | num_lines | Output | The number of lines in the ID symbol |
| double * * | lines | Output to UF_*free* | Array of lines - 3d start, 3d end, the first line is lines[0] - lines[5] the second line is lines[6] - lines[11] ... the nth line (n counting from 1) is lines[6 (n - 1)] - lines[6 n - 1]. Line end points are in the coordinate system of the id symbol, as are other coordinates returned by UF_DRF routines. If the idysmbol is not on a drawing, the coordinates in absolute can be obtained by multiplying by the transpose of the matrix returned by the function UF_CSYS_ask_matrix_values for the matrix returned by UF_CSYS_ask_matrix_of_object. This array must be freed by calling UF_free. |
| int * | num_arcs | Output | the number of arcs in the ID symbol |
| UF_DRF_arc_info_p_t * | arcs | Output to UF_*free* | array of arcs (center is in coordinate system of the id symbol). This array must be freed by calling UF_free. |
UF_DRF_ask_id_symbol_info (view source)
Given the ID Symbol tag, this function returns the ID Symbol
subtype, text and leader information, and the data of object to attach
leader.
int UF_DRF_ask_id_symbol_info
tag_t id_symbol_tag,
UF_DRF_id_symbol_type_t * id_symbol_type,
double id_symbol_origin [ 3 ] ,
UF_DRF_id_symbol_info_p_t * id_symbol_info
| tag_t | id_symbol_tag | Input | Tag of ID Symbol |
| UF_DRF_id_symbol_type_t * | id_symbol_type | Output | ID Symbol type |
| double | id_symbol_origin [ 3 ] | Output | ID Symbol origin |
| UF_DRF_id_symbol_info_p_t * | id_symbol_info | Output to UF_*free* | ID Symbol information. This must be freed by calling UF_DRF_free_idsymbol. |
UF_DRF_ask_id_symbol_type (view source)
Given the ID Symbol tag, this function returns the ID Symbol type.
int UF_DRF_ask_id_symbol_type
UF_DRF_ask_image_data (view source)
Get the image data
Returns
UF_DRF_NO_ERRORS if the image query was successful
This function was originally released in NX2.0.
int UF_DRF_ask_image_data
tag_t image,
UF_DRF_image_data_t * data
| tag_t | image | Input | Image to query |
| UF_DRF_image_data_t * | data | Output to UF_*free* | Image data (see uf_drf_types.h) The image data will need to be freed using UF_DRF_free_image_data |
UF_DRF_ask_label_info (view source)
Given the label tag, this function returns the number of lines of text,
associated text string, object origin, leader type, and data of object to
attach leader.
int UF_DRF_ask_label_info
tag_t label_tag,
double label_origin [ 3 ] ,
UF_DRF_label_info_p_t * label_info
| tag_t | label_tag | Input | Tag of label |
| double | label_origin [ 3 ] | Output | Label origin in the coordinate system of the drafting object. |
| UF_DRF_label_info_p_t * | label_info | Output to UF_*free* | Label information. This must be freed by calling UF_DRF_free_label. |
UF_DRF_ask_lettering_preferences (view source)
Returns the lettering preferences for dimension, appended, tolerance
and general (notes, id symbols, etc,) text.
Internal & External
Horizontal text justification preference and GD&T frame height
factor preference added in V17.0.
Dimension/Appended Text Spacing Factor,
Dimension /Tolerance Text Spacing Factor, and
Dimension/Dimension Line Spacing Factor added in NX 2.0.
int UF_DRF_ask_lettering_preferences
UF_DRF_lettering_preferences_t * lettering_preferences
UF_DRF_ask_line_arrow_preferences (view source)
Returns preferences that apply to leaders, arrows and extension lines for
both dimensions and other annotations
Internal & External
int UF_DRF_ask_line_arrow_preferences
UF_DRF_line_arrow_preferences_t * line_arrow_preferences
UF_DRF_ask_narrow_dimension_data (view source)
Ask narrow dimension parameters.
Return code:
0 = No error
not 0 = Error code
UF_DRF_invalid_linear_dim_form - if the dimension given is not linear dimension.
int UF_DRF_ask_narrow_dimension_data
tag_t dimension_tag,
UF_DRF_narrow_dimension_info_p_t narrow_data
UF_DRF_ask_number_blocks (view source)
Given the drafting aid object tag, this function returns the number of
blocks for this drafting aid.
int UF_DRF_ask_number_blocks
int num_block [ 5 ]
| tag_t | annotation_tag | Input | Tag of the drafting aid object |
| int | num_block [ 5 ] | Output | Five integer array: UF_DRF_ASSOCIATIVITY_BLOCK num_block[UF_DRF_LINE_BLOCK] is number of line blocks num_block[UF_DRF_ARCS_BLOCK] is number of arc blocks num_block[UF_DRF_TEXT_BLOCK] is number of text blocks num_block[UF_DRF_ARROWS_BLOCK] is number of arrow blocks num_block[ UF_DRF_ASSOCIATIVITY_BLOCK] is number of associativity blocks |
UF_DRF_ask_number_rows_in_callout (view source)
Get the number of rows in a callout
Internal & External
Created in V18.0
int UF_DRF_ask_number_rows_in_callout
tag_t callout,
int * num_rows
| int * | num_rows | Output | Number of rows in callout |
UF_DRF_ask_obj_suppress_pre_zeros (view source)
Determines if the suppress preceding zeros option for an angular
dimension is set.
This function was originally released in V15.0.
int UF_DRF_ask_obj_suppress_pre_zeros
tag_t object,
logical * option
| tag_t | object | Input | Tag id of angular dimension object |
| logical * | option | Output | Suppress preceding zeros mode |
UF_DRF_ask_obj_text_above_ldr (view source)
Returns the text above leader attribute for a label or dimension.
If a value of UF_DRF_NO_TEXT_ABOVE_LEADER is returned, the text is
NOT displayed above the leader stub. The placement of the leader stub
relative to the text is controlled by the vertical text justification.
This can be queried with UF_DRF_ask_object_preferences.
int UF_DRF_ask_obj_text_above_ldr
tag_t object,
UF_DRF_text_above_leader_t * option
UF_DRF_ask_object_preferences (view source)
Given the annotation tag, this function retrieves and checks drafting
parameters from an existing annotation.
Return code:
0 = No error
not 0 = Error code
UF_DRF_crosshatch_file_not_found
Original release was in V13.0. This function replaces uc/uf5550.
In V15.0, the maximum byte length for both radius_value and
diameter_value was increased from 6 to 27 to accomodate
internationalized text.
Updated in V16.0 to return UF_get_fail_message error codes and
if the input object is not a crosshatch object,
returns mpi[31] = -999 for the material index.
If UF_DRF_set_preferences is called with a value of -999 for the
material index, the material preferences will not be changed.
mpr[51], area fill tolerance, is now obsolete; use mpr[13] instead.
In V17.0 flexible appended text locations were implemented for
dimensions. If the appended text is located at one of these
enhanced locations, -999 will be returned. Use the new
UF_DRF_ask_appended_text to query the appended text.
In V17.0, a separate preference controls the angular nominal and
tolerance units format. This routine will return only the nominal
angular format when queried.
In NX2.0, occurrence support was added.
int UF_DRF_ask_object_preferences
tag_t drf_object_tag,
int mpi [ 100 ] ,
double mpr [ 70 ] ,
char radius_val [ 27 ] ,
char diameter_val [ 27 ]
| tag_t | drf_object_tag | Input | Drafting object Identifier |
| int | mpi [ 100 ] | Output | MPI Array [100 elements] The size of this array is defined by NUM_INT_PARAMS |
| double | mpr [ 70 ] | Output | MPR Array [70 elements] The size of this array is defined by NUM_REAL_PARAMS |
| char | radius_val [ 27 ] | Output | Radius Symbol String. This can be at most six characters, however due to internal requirements, the buffer must be allocated as char radius_val[27]; |
| char | diameter_val [ 27 ] | Output | Diameter Symbol String. This can be at most six characters, however due to internal requirements, the buffer must be allocated as char diameter_val[27]; |
UF_DRF_ask_objects_controlled_by_exp (view source)
Defined in: uf_drf.h
Find all drafting objects which are controlled by a given expression
int UF_DRF_ask_objects_controlled_by_exp
tag_t exp_id,
int * num_objs,
tag_p_t * objects
| tag_t | exp_id | Input | Object identifier of the expression. |
| int * | num_objs | Output | Number of objects controlled by the expression. |
| tag_p_t * | objects | Output to UF_*free* | Array of objects controlled by the expression. The caller is responsible for freeing this array by calling UF_free. |
UF_DRF_ask_ordorigin_info (view source)
Returns the data of the associated object, arrow and dimension line
display status, origin symbol display status, and user supplied object
name given the specified ordinate origin tag.
int UF_DRF_ask_ordorigin_info
tag_t ordorigin_tag,
UF_DRF_orddisp_info_t * origin_disp,
int * num_assoc,
UF_DRF_assoc_info_t * * assoc_objects
| tag_t | ordorigin_tag | Input | Tag of ordinate origin |
| UF_DRF_orddisp_info_t * | origin_disp | Output | Ordinate dimension origin display in formation (see UF_DRF_orddisp_info_t) |
| int * | num_assoc | Output | Number of associated objects |
| UF_DRF_assoc_info_t * * | assoc_objects | Output to UF_*free* | Array of associated object information. This array must be freed by calling UF_free. |
UF_DRF_ask_origin (view source)
Return the origin of the annotation object.
Return code:
0 = No error
not 0 = Error code
Written in V16.0
int UF_DRF_ask_origin
tag_t annotation,
double origin [ 3 ]
| tag_t | annotation | Input | Tag of the annotation. |
| double | origin [ 3 ] | Output | Origin for the annotation. If the annotation is on the drawing, the origin is with respect to drawing coordinates. Otherwise, the origin is with respect to model coordinates. |
UF_DRF_ask_parent_of_inherited_pmi (view source)
This function returns the parent of the given inherited PMI. The parent is
the PMI Display Instance in modeling.
Returns
UF_DRF_NO_ERRORS
Internal & External
Created in NX5.0
drafting
int UF_DRF_ask_parent_of_inherited_pmi
tag_t inherited_pmi,
tag_p_t parent
| tag_t | inherited_pmi | Input | The tag of the inherited PMI |
| tag_p_t | parent | Output | Parent of the inherited PMI |
UF_DRF_ask_plot_drawing_images (view source)
Ask whether or not the raster images on the drawing sheets will be plotted when drawing sheets are plotted.
Returns
UF_DRF_NO_ERRORS if the preference query was successful
This function was originally released in NX3.0.
int UF_DRF_ask_plot_drawing_images
logical * plot_images
| logical * | plot_images | Output | TRUE if set to plot raster images on drawing sheets FALSE if set to not plot raster images on drawing sheets |
UF_DRF_ask_preferences (view source)
Sets arrays and character strings to the current settings of the drafting
parameters.
Return code:
0 = No error
not 0 = Error code
UF_DRF_INVALID_CROSSHATCH_FILE_FORMAT
Original release was in V13.0. This function replaces uc5520.
Updated in V15 to increase the size of the character strings.
Updated in V16.0 to return UF_get_fail_message error codes.
In V16.0, there are separate text angle preferences for dimension
text and drafting aid text. This function returns the dimension
text angle. Use UF_DRF_ask_lettering_preferences to get the
drafting aid text angle.
In V17.0, a separate preference control the angular nominal and tolerance
units format. This routine will return the only the nominal angular
int UF_DRF_ask_preferences
int mpi [ 100 ] ,
double mpr [ 70 ] ,
char radius_value [ 27 ] ,
char diameter_value [ 27 ]
| char | radius_value [ 27 ] | Output | Radius Symbol String. This can be at most six characters, however due to internal requirements, the buffer must be allocated as char radius_value[27]; |
| char | diameter_value [ 27 ] | Output | Diameter Symbol String. This can be at most six characters, however due to internal requirements, the buffer must be allocated as char diameter_value[27]; |
UF_DRF_ask_retain_color_font_width (view source)
Gets the color, font and widths used for retained annotations.
Return code:
0 = No error
not 0 = Error code
int UF_DRF_ask_retain_color_font_width
int * color,
int * font,
int * width
| int * | color | Output | Color used for retained annotations |
| int * | font | Output | Font used for retained annotations |
| int * | width | Output | Line width used for retained annotations |
UF_DRF_ask_retained_state (view source)
Gets the retained state for annotations whose dependencies have expired.
If UF_DRF_KEEP_RETAINED_ANNOTATIONS is returned, annotations are retained.
If UF_DRF_DELETE_RETAINED_ANNOTATIONS is returned, annotations are deleted.
Return code:
0 = No error
not 0 = Error code
int UF_DRF_ask_retained_state
UF_DRF_retained_state_t * state
| UF_DRF_retained_state_t * | state | Output | Behavior state for retained annotations. Either 'UF_DRF_KEEP_RETAINED_ANNOTATIONS' or 'UF_DRF_DELETE_RETAINED_ANNOTATIONS' |
UF_DRF_ask_sbf_file (view source)
Returns the current symbol font definition file name.
int UF_DRF_ask_sbf_file
char sbf_name [ UF_CFI_MAX_FILE_NAME_BUFSIZE ]
| char | sbf_name [ UF_CFI_MAX_FILE_NAME_BUFSIZE ] | Output | current symbol font definition name (blank if none) |
UF_DRF_ask_set_of_dimension (view source)
Return the dimension set which the given dimension belongs to.
Return code:
0 = No error
not 0 = Error code
UF_DRF_null_object - if the dimension is null
int UF_DRF_ask_set_of_dimension
tag_t dimension,
tag_t * dimension_set
| tag_t * | dimension_set | Output | Tag of the dimension set which the given dimension belongs to. |
UF_DRF_ask_suppress_pre_zeros (view source)
Determines if the global preference for suppress preceding zeros is
set.
int UF_DRF_ask_suppress_pre_zeros
logical * option
UF_DRF_ask_suppress_view_update (view source)
Query the current value of the Suppress View Update preference. This
preference is an environment setting and is not specific to a part. If the
preference is TRUE, then functions which perform implicit drawing updates,
will not update the drawing member views.
Internal & External:
int UF_DRF_ask_suppress_view_update
logical * suppress_view_update
| logical * | suppress_view_update | Output | the current setting of view update suppression |
UF_DRF_ask_symbol_data (view source)
Returns standalone symbol object data.
int UF_DRF_ask_symbol_data
tag_t symbol_tag,
UF_DRF_symbol_data_t * symbol_data
UF_DRF_ask_symbol_data_from_name (view source)
Return the User Defined Symbol factor, length, height, left, and right
connecting point, the count of strokes, and stroke data given the
specified user defined symbol name
int UF_DRF_ask_symbol_data_from_name
const char * sbf_name,
char * * * symbol_names,
int * num_symbols,
UF_DRF_ud_symbol_font_info_p_t * symbol_info
| const char * | sbf_name | Input | Name of the sbf file |
| char * * * | symbol_names | Output to UF_*free* | List of symbol names in sbf |
| int * | num_symbols | Output | Number of symbols in the sbf file |
| UF_DRF_ud_symbol_font_info_p_t * | symbol_info | Output to UF_*free* | Symbol data (see uf_drf_types.h) use UF_free () to free memory |
UF_DRF_ask_symbol_mirror_and_flip (view source)
Description -
This function ask standalone symbol create mask
PARAMETERS -
symbol_tag <I> Tag of symbol to inquire
mirrored <O> Symbol has mirrored
flip <O> Symbol has flip
return <O> return code:
0 = OK
int UF_DRF_ask_symbol_mirror_and_flip
tag_t symbol_tag,
logical * mirrored,
logical * flip
| tag_t | symbol_tag | Input | standalone symbol object tag |
| logical * | mirrored | Output | TRUE symbol is mirrored |
| logical * | flip | Output | TRUE symbol is flip |
UF_DRF_ask_symbol_preferences (view source)
Returns preferences that apply to ID, User Define, Centerline, Intersection,
Target and GD&T symbols.
Internal & External
int UF_DRF_ask_symbol_preferences
UF_DRF_symbol_preferences_t * symbol_preferences
UF_DRF_ask_symbols_used (view source)
Returns symbols used in a drafting object.
int UF_DRF_ask_symbols_used
tag_t object_tag,
int * num_symbol_fonts,
tag_t * symbol_font_tags
| tag_t | object_tag | Input | drafting object tag |
| int * | num_symbol_fonts | Output | number of symbol fonts used |
| tag_t * | symbol_font_tags | Output | tags of the symbol font objects. The caller is responsible for passing in an array large enough to receive all of the symbol font tags. |
UF_DRF_ask_text_above_leader (view source)
Inquires the current global setting for the text above leader attribute.
This attribute controls displaying text above the leader stub when
creating labels and radial type dimensions.
If the value is UF_DRF_NO_TEXT_ABOVE_LEADER, then the text is NOT
The placement of the leader stub is controlled by the vertical text
justification preference which can be queried with UF_DRF_ask_preferences.
int UF_DRF_ask_text_above_leader
| UF_DRF_text_above_leader_t * | option | Output | text above leader option this option controls displaying text above the leader stub. this option applies to Labels and radial type dimensions (hole, radius, diameter, concentric circle and folded radius) when the Text Alignment is Horizontal or By Angle. |
UF_DRF_ask_text_data (view source)
Read Drafting Object Text Data:
This routine deciphers the ann_data returned from UF_DRF_ask_ann_data and
returns just one text string. This routine can be called once for each
text string (or segment) in the data block. The number of segments
is returned by UF_DRF_ask_ann_data.
This user function replaces uc5574.
drafting
int UF_DRF_ask_text_data
int ip1,
char* * cr3,
int * ir4,
int * ir5
| int | ip1 | Input | Segment Number 1 < ip1 < = num_segments returned by UF_DRF_ask_ann_data |
| int | ann_data [ 10 ] | Input / Output | Array of ann_data returned by UF_DRF_ask_ann_data |
| char* * | cr3 | Output to UF_*free* | Text String Must be freed by calling UF_free |
| int * | ir4 | Output | Length of Line in 1/64th's Character Size, Expressed in Integers |
| int * | ir5 | Output | Number of Characters in String |
UF_DRF_ask_ud_symbol_font_info (view source)
Returns the User Defined Symbol factor, length, height, left and right
specified user defined symbol tag.
int UF_DRF_ask_ud_symbol_font_info
tag_t ud_symbol_tag,
int * num_symbols,
UF_DRF_ud_symbol_font_info_p_t * font_info
| tag_t | ud_symbol_tag | Input | Tag of User Defined Symbol |
| int * | num_symbols | Output | Number of User Defined Symbol |
| UF_DRF_ud_symbol_font_info_p_t * | font_info | Output to UF_*free* | Data structure which contains the User Defined Symbol font number, left and right connection points, factor, length, height and the count of strokes and stoke data. Use UF_DRF_free_font to deallocate memory when done. |
UF_DRF_ask_uds_object_size (view source)
The following function returns the user defined symbol length / height or
scale / aspect ratio.
int UF_DRF_ask_uds_object_size
tag_t object,
UF_DRF_uds_size_p_t uds_size
| tag_t | object | Input | User defined symbols, or annotation with an embedded user defined symbol object (such as a note, label, or GD&T symbol). |
| UF_DRF_uds_size_p_t | uds_size | Output | User defined symbol scale / aspect ratio or length / height parameters. |
UF_DRF_ask_units_format_preferences (view source)
Returns preferences for the display of linear and angular dimensions values
as well as dual dimension format.
Internal & External
Originally released in V16.0. In v17.0, the data structure has changed.
An element controlling the units of the tolerance of angular dimension and
an element controlling the zero suppression for angular dimension have been added.
The display leading zeros option has been removed.
int UF_DRF_ask_units_format_preferences
UF_DRF_units_format_preferences_t * units_format_preferences
UF_DRF_ask_vertical_note (view source)
This function will return the orientation of a note. A note can be
either horizontal or vertical.
Created in V16.0
int UF_DRF_ask_vertical_note
tag_t note,
logical * is_vertical
| tag_t | note | Input | Tag of the note. |
| logical * | is_vertical | Output | Orientation of the note: True if the note is vertical False if the note is horizontal If the object is not a note, False is returned. |
UF_DRF_ask_weld_symbol (view source)
Given the weld symbol tag, this function will get the information regarding
the weld symbol.
Returns
0 = No Error
Not 0 = Error
Possible Error Return Code:
UF_DRF_OBJECT_IS_NOT_A_WELD_SYMBOL - Object is not a weld symbol
UF_DRF_weld_symbols_t
UF_DRF_label_info_t
UF_DRF_create_weld_symbol
int UF_DRF_ask_weld_symbol
tag_t weld_symbol_tag,
UF_DRF_label_info_p_t * label_info,
UF_DRF_weld_symbols_p_t symbol_data
| tag_t | weld_symbol_tag | Input | tag of the weld symbol for which information is required |
| double | label_origin [ 3 ] | Output | label origin |
| UF_DRF_label_info_p_t * | label_info | Output to UF_*free* | Label information. This must be freed by UF_DRF_free_label |
| UF_DRF_weld_symbols_p_t | symbol_data | Output | weld symbol data for the given weld symbol tag |
UF_DRF_count_text_substring (view source)
Find the number of substrings of the given text. A substring is defined as:
A continuous set of characters with similar characteristics
A single symbol e.g. <&1>
drafting
int UF_DRF_count_text_substring
int * segment_number,
int * ann_data,
int * number_of_substring
| int * | segment_number | Input | The requested text segment on the drafting object. |
| int * | ann_data | Input | The data defining the drafting object. See UF_DRF_ask_ann_data. |
| int * | number_of_substring | Output | The number of substrings in this segment of the drafting object. |
UF_DRF_cre_text_block (view source)
Create a text block on a drafting aid.
drafting
int UF_DRF_cre_text_block
int * entity_id,
int * text_type,
double text_origin [ 2 ] ,
int * number_lines,
| int * | entity_id | Input | Object identifier of the drafting aid to add text to |
| int * | text_type | Input | The type of the text to add. 6 = Appended text 17 = Form and positional tolerance text |
| double | text_origin [ 2 ] | Input | X and Y coordinates of the origin of the text string. |
| int * | number_lines | Input | The number of lines to add to the drafting aid. |
| const UF_DRF_one_apptext_line_t | text_array [ ] | Input | number_lines An array of the text strings to add. |
UF_DRF_create_3pt_cline_fbolt (view source)
Creates and displays a full bolt circle centerline using the 3 point
method (centerline type UF_DRF_3pt_cline_fbolt).
Return code:
0 = No error
not 0 = Error code
UF_DRF_invalid_centerline_form
UF_DRF_no_objects
UF_DRF_too_many_objects
UF_DRF_form_requires_3_or_more_objects
UF_DRF_invalid_object_type_centerline
UF_DRF_model_objects_on_drawing
UF_DRF_coincident_points
UF_DRF_point_not_on_centerline
UF_DRF_collinear_points
See the
example
This example creates a full bolt circle centerline using the 3
point method.
drafting
int UF_DRF_create_3pt_cline_fbolt
const int num_cline_objs,
UF_DRF_object_t* cline_obj_list,
tag_t* centerline_tag
| const int | num_cline_objs | Input | Number of centerline objects in cline_obj_list Maximum is MAX_CENTERLINE_OBJECTS, currently 100 |
| UF_DRF_object_t* | cline_obj_list | Input | Array of objects that are to be associated to the centerline (see uf_drf_types.h) Valid object types: point, arc, solid curve |
| tag_t* | centerline_tag | Output | Object tag of created centerline |
UF_DRF_create_3pt_cline_fcir (view source)
Creates and displays a full circular centerline using the 3 point
method (centerline type UF_DRF_3pt_cline_fcir).
Return code:
0 = No error
not 0 = Error code
UF_DRF_no_objects
drafting
int UF_DRF_create_3pt_cline_fcir
UF_DRF_create_3pt_cline_pbolt (view source)
Creates and displays a partial bolt circle centerline using the 3 point
method (centerline type UF_DRF_3pt_cline_pbolt).
Return code:
0 = No error
not 0 = Error code
UF_DRF_no_objects
See the
example
point method.
drafting
int UF_DRF_create_3pt_cline_pbolt
UF_DRF_create_3pt_cline_pcir (view source)
Creates and displays a partial circular centerline using the 3 point
method (centerline type UF_DRF_3pt_cline_pcir).
Return code:
0 = No error
not 0 = Error code
UF_DRF_no_objects
drafting
int UF_DRF_create_3pt_cline_pcir
UF_DRF_create_angular_dim (view source)
Creates and displays an angular dimension.
drafting
int UF_DRF_create_angular_dim
int dimension_form,
UF_DRF_object_p_t object1,
UF_DRF_object_p_t object2,
UF_DRF_text_t* drf_text,
double dimension_3d_origin [ 3 ] ,
tag_t* dimension_tag
| int | dimension_form | Input | Angular dimension form 1 = minor angle 2 = major angle |
| UF_DRF_object_p_t | object1 | Input | Data of first (line) object (see uf_drf_types.h) Valid object types: line, straight solid curve, planar face, cylindrical face |
| UF_DRF_object_p_t | object2 | Input | Data of second (line) object |
| UF_DRF_text_t* | drf_text | Input | Associated text (see uf_drf_types.h) |
| double | dimension_3d_origin [ 3 ] | Input | 3d dimension origin in wcs coordinates |
| tag_t* | dimension_tag | Output | Object tag of created dimension initialized to NULL_TAG because legacy programs processed returned NULL_TAG as an error. |
UF_DRF_create_arclength_dim (view source)
Creates and displays an arc length dimension.
drafting
int UF_DRF_create_arclength_dim
UF_DRF_object_p_t object,
| UF_DRF_object_p_t | object | Input | Data of arc object (see uf_drf_types.h) Valid object types: arc, circle solid curve |
| tag_t* | dimension_tag | Output | Object tag of created arc length dimension |
UF_DRF_create_areafill (view source)
Creates and displays an area fill or solid fill.
drafting
int UF_DRF_create_areafill
int num_bounds,
int* num_obj_bnd,
tag_t object_list [ ] ,
tag_t view_tag,
tag_t* areafill_tag
| int | num_bounds | Input | Number of area fill or solid fill boundaries |
| int* | num_obj_bnd | Input | List of integer values containing the number of objects in each boundary. The sum of all values in this list should equal the number of boundary objects in object_list. |
| tag_t | object_list [ ] | Input | List of curve tags or point tags or both that comprise each of the boundaries; a boundary object tag may be included in the list. |
| tag_t | view_tag | Input | Member view tag |
| tag_t* | areafill_tag | Output | Object tag of created area fill or solid fill. |
UF_DRF_create_assortpart_aid (view source)
Creates and displays an assorted parts Drafting Aid.
drafting
int UF_DRF_create_assortpart_aid
UF_DRF_assortpart_arc_p_t arc,
UF_DRF_assortpart_arrow_p_t arrow,
UF_DRF_assortpart_line_p_t line,
UF_DRF_assortpart_text_p_t text,
tag_t * assorted_parts_tag
UF_DRF_create_assortpart_dim (view source)
Creates and displays an Assorted Parts Dimension.
drafting
int UF_DRF_create_assortpart_dim
UF_DRF_create_block_cline (view source)
Creates and displays a block centerline.
(centerline type UF_DRF_block_cline)
Return-
Return Codes -
0 = No error
not 0 = Error code
UF_DRF_no_objects
drafting
int UF_DRF_create_block_cline
UF_DRF_object_p_t defining_obj_list,
UF_DRF_object_p_t limiting_obj_list,
tag_t * centerline_tag
| UF_DRF_object_p_t | defining_obj_list | Input | objects that define the block centerline (see uf_drf_types.h). Valid object types: linear edges and linear curves. This should be an array of two. |
| UF_DRF_object_p_t | limiting_obj_list | Input | objects that specify the extents of the block centerline. If NULL is passed, the system will calculate the limits. If an array is passed, it should be of the size two. Valid object types: edges and curves |
| tag_t * | centerline_tag | Output | object tag of the block centerline |
UF_DRF_create_chamfer_dim (view source)
Description -
create a chamfer dimension and display it
PARAMETERS -
object1 - <I> data of first object (see uf_drf_types.h)
valid object types: line, solid curve, planar face
object2 - <I> data of second object
dim_text - <I> manual dimension text
dim_3d_origin - <I> 3d dim origin in wcs coords
dim_tag - <O> tag of created cham dim
0 = OK
drafting
int UF_DRF_create_chamfer_dim
UF_DRF_text_t * dim_text,
double dim_3d_origin [ 3 ] ,
tag_t * dim_tag
| UF_DRF_object_p_t | object1 | Input | data of first object valid object types: line, solid curve |
| UF_DRF_object_p_t | object2 | Input | data of second object |
| UF_DRF_text_t * | dim_text | Input | manual dimension text |
| double | dim_3d_origin [ 3 ] | Input | 3d dim origin in wcs coords |
| tag_t * | dim_tag | Output | tag of created cham dim |
UF_DRF_create_concir_dim (view source)
Creates and displays a concentric circle dimension.
drafting
int UF_DRF_create_concir_dim
| UF_DRF_object_p_t | object1 | Input | Data of first arc object (see uf_drf_types.h) Valid object types: arc, circle solid curve, cylindrical face |
| UF_DRF_object_p_t | object2 | Input | Data of second arc object (see uf_drf_types.h) |
| tag_t* | dimension_tag | Output | Object tag of created circular dimension initialized to NULL_TAG because legacy programs processed returned NULL_TAG as an error. |
UF_DRF_create_cpt_cline_fbolt (view source)
n
Creates and displays a full bolt circle centerline using the centerpoint
method (centerline type UF_DRF_cpt_cline_fbolt).
Return code:
0 = No error
not 0 = Error code
UF_DRF_no_objects
UF_DRF_invalid_object_type_center_point
UF_DRF_point_coincident_with_center
drafting
int UF_DRF_create_cpt_cline_fbolt
UF_DRF_object_p_t center_point,
| UF_DRF_object_t* | cline_obj_list | Input | Array of objects that are to be associated to the centerline (see uf_drf_types.h) |
| UF_DRF_object_p_t | center_point | Input | Data of object selected for centerline center point (see uf_drf_types.h) |
UF_DRF_create_cpt_cline_fcir (view source)
Creates and displays a full circular centerline using the center point
method (centerline type UF_DRF_cpt_cline_fcir).
Return code:
0 = No error
not 0 = Error code
UF_DRF_no_objects
drafting
int UF_DRF_create_cpt_cline_fcir
UF_DRF_create_cpt_cline_pbolt (view source)
Creates and displays a partial bolt circle centerline using the center
point method (centerline type UF_DRF_cpt_cline_pbolt).
Return code:
0 = No error
not 0 = Error code
UF_DRF_no_objects
drafting
int UF_DRF_create_cpt_cline_pbolt
UF_DRF_create_cpt_cline_pcir (view source)
n
Creates and displays a partial circular centerline using the center
point method (centerline type UF_DRF_cpt_cline_pcir).
Return code:
0 = No error
not 0 = Error code
UF_DRF_no_objects
drafting
int UF_DRF_create_cpt_cline_pcir
| const int | num_cline_objs | Input | number of centerline objects in cline_obj_list Maximum is MAX_CENTERLINE_OBJECTS, currently 100 |
UF_DRF_create_crosshatch (view source)
Creates and displays a crosshatch.
b1 b5 b9
b2 | | b4 b6 | | b8 b10 | | b13
b3 b7 b11 b12
Loop1 Loop2 Loop3
Input -
num_bounds - Number of loops = 3
{ Loop1, Loop2, Loop3 }
num_obj_bnd - Array of int which contains number of
curve in each boundary
{ 4, 4, 5 }
object_list - tags of curve which forms loop
{ b1, b2, b3, b4, b5, b6
b7, b8, b9, 10, b11,b12, b13 }
drafting
int UF_DRF_create_crosshatch
int num_bounds,
int* num_obj_bnd,
tag_t view_tag,
tag_t* crosshatch_tag
| int | num_bounds | Input | Number of crosshatch boundaries |
| int* | num_obj_bnd | Input | List of integer values containing the number of objects in each boundary. The sum of all values in this list should equal the number of boundary objects in object_list |
| tag_t | object_list [ ] | Input | List of curve tags or point tags or both that comprise each of the boundaries; a boundary object tag may be included in the list |
| tag_t* | crosshatch_tag | Output | Object tag of created crosshatch. |
UF_DRF_create_custom_symbol_instance (view source)
This function will create and display a new custom symbol. This function
uses existing objects of the following types to form the symbol: lines,
arcs, splines, parabolas, hyperbolas, B-curves, crosshatch, area fill, and
notes. All objects which are passed into this routine via the data structure
are consumed by the function call (they are not available for use as
individual objects after this function returns).
The symbol scale and angle may be edited, as well as its color, font, and
width. However, all other edits (such as text-specific edits, or display
edits of symbol pieces) must be performed interactively at this time.
Return values include the following:
UF_DRF_invalid_custom_symbol_piece
UF_DRF_default_text_out_of_bounds
UF_DRF_objects_not_in_same_view
UF_DRF_NO_ERRORS
UF_DRF_is_sbf_symbol, UF_DRF_initialize_custom_symbol_data,
UF_DRF_ask_custom_symbol_scale, UF_DRF_set_custom_symbol_scale,
UF_DRF_ask_custom_symbol_angle, UF_DRF_set_custom_symbol_angle
Refer to the
example
Created in V18.0.3
drafting
int UF_DRF_create_custom_symbol_instance
const UF_DRF_custom_symbol_t * symbol_definition,
tag_t * new_symbol_tag
| const UF_DRF_custom_symbol_t * | symbol_definition | Input | Structure containing data necessary for custom symbol definition |
| tag_t * | new_symbol_tag | Output | The tag of the new custom symbol instance |
UF_DRF_create_cylindrical_dim (view source)
n
Creates and displays a cylindrical dimension.
drafting
int UF_DRF_create_cylindrical_dim
| UF_DRF_object_p_t | object1 | Input | Data of first object (see uf_drf_types.h) Valid object types: point, line, arc, conic, cubic spline, B curve, pattern, solid curve, utility symbol (centerline), or cylindrical face(if one associative object is a cylindrical face, both associative objects must be the same face. If the face is perpendicular to WCS X-Y plane the associative type must be tangency type). |
| UF_DRF_object_p_t | object2 | Input | Data of second object |
| tag_t* | dimension_tag | Output | Object tag of created cylindrical dimension |
UF_DRF_create_diameter_dim (view source)
Creates and displays a diameter dimension.
drafting
int UF_DRF_create_diameter_dim
| UF_DRF_object_p_t | object | Input | Data of arc object (see uf_drf_types.h) Valid object types: arc, circle solid curve, cylindrical face |
| tag_t* | dimension_tag | Output | Object tag of created diameter dimension |
UF_DRF_create_foldedradius_dim (view source)
Creates and displays a folded radius dimension.
drafting
int UF_DRF_create_foldedradius_dim
double fold_location [ 3 ] ,
double fold_angle,
| UF_DRF_object_p_t | object1 | Input | Data of first object (see uf_drf_types.h) Valid object types: arc, bolt circle, circular centerline, cylindrical face |
| UF_DRF_object_p_t | object2 | Input | Data of second object: offset center point Valid object types: point, line, arc, conic, B curve, solid curve, offset center point, cylindrical, symmetrical center line, target point, intersection point |
| double | fold_location [ 3 ] | Input | Fold location in wcs coordinates |
| double | fold_angle | Input | Fold angle in degrees |
| tag_t* | dimension_tag | Output | Object tag of created linear dimension initialized to NULL_TAG because legacy programs processed returned NULL_TAG as an error. |
UF_DRF_create_gdt_symbol (view source)
n
Creates and displays a GD&T symbol.
V17 - Added the ability to attach datums to annotations or leader stubs.
drafting
int UF_DRF_create_gdt_symbol
int num_lines_text,
char text_string [ ] [ MAX_LINE_BUFSIZE ] ,
double origin_3d [ 3 ] ,
UF_DRF_leader_type_t leader_type,
UF_DRF_leader_attach_type_t leader_attach_type,
double model_pos_3d [ 3 ] ,
UF_DRF_frame_corner_t frame_corner,
tag_t* gdt_symbol_tag
| int | num_lines_text | Input | Number of lines of text |
| char | text_string [ ] [ MAX_LINE_BUFSIZE ] | Input | Associated text string |
| double | origin_3d [ 3 ] | Input | 3d object origin in wcs coordinates |
| UF_DRF_leader_type_t | leader_type | Input | Leader type UF_DRF_leader_type_none = none UF_DRF_leader_type_line = leader line UF_DRF_leader_type_ext_line = extension line |
| UF_DRF_leader_attach_type_t | leader_attach_type | Input | Leader attachment type If leader_type = UF_DRF_leader_type_line, UF_DRF_leader_attach_object = attached to object UF_DRF_leader_attach_screen = screen position |
| UF_DRF_object_p_t | object | Input | Data of object to attach leader see uf_drf_types.h If leader_type = UF_DRF_leader_type_line and leader_attach_type = UF_DRF_leader_attach_object, Valid object types: point, line, arc, conic, cubic spline, B curve, and solid curve. If leader_type = UF_DRF_leader_type_ext_line Valid object types: line, straight solid curve. If the leader_attach_type is UF_DRF_leader_attach_screen, then object = NULL. |
| double | model_pos_3d [ 3 ] | Input | 3d model space position If leader_attach_type = UF_DRF_leader_attach_object This position is used as an approximate point on the object to attach the leader If leader_attach_type = UF_DRF_leader_attach_screen This position is the endpoint of the leader |
| UF_DRF_frame_corner_t | frame_corner | Input | Frame corner If leader_type = UF_DRF_leader_type_ext_line UF_DRF_frame_upper_left = upper left UF_DRF_frame_upper_right = upper right UF_DRF_frame_lower_left = lower left UF_DRF_frame_lower_right = lower right |
| tag_t* | gdt_symbol_tag | Output | Object tag of created gdt symbol. |
UF_DRF_create_gdt_symbol_with_multiple_leaders (view source)
Description -
Create a Geometric Dimensioning and Tolerancing symbol with multiple
leader lines. With this routine, you can also create leaders with
intermediate points.
Input -
num_lines_text The number of lines of text in the GD&T symbol.
text_string The lines of text. This should be declared before
calling this routine. For example:
text_string[][MAX_LINE_BUFSIZE]
origin The origin in WCS coordinates.
leader The leader line information.
frame_corner The frame corner to use if the leader_type is
UF_DRF_leader_type_ext_line.
Output -
gdt_symbol_tag The tag of GD&T Symbol
Return Codes -
UF_DRF_NO_ERRORS
otherwise
UF_DRF_no_text
UF_DRF_invalid_leader_type
UF_DRF_too_many_objects More than UF_DRF_LEADER_MAX_LEADERS leaders.
UF_DRF_INVALID_LEADER_LOCATION Leader side is neither left nor right.
UF_DRF_invalid_leader_mode Datum leader requires an object.
UF_err_program_not_initialized
Original release was in NX 1.0.3.2 and NX 2
drafting
int UF_DRF_create_gdt_symbol_with_multiple_leaders
const int num_lines_text,
const char text_string [ ] [ MAX_LINE_BUFSIZE ] ,
const double gdt_symbol_origin [ 3 ] ,
const UF_DRF_gdt_leader_t * leader,
const UF_DRF_frame_corner_t frame_corner,
tag_t * const gdt_symbol_tag
| const int | num_lines_text | Input | The number of lines of text in the GD&T. |
| const char | text_string [ ] [ MAX_LINE_BUFSIZE ] | Input | The lines of text. |
| const double | gdt_symbol_origin [ 3 ] | Input | The GD&T symbol's origin. |
| const UF_DRF_gdt_leader_t * | leader | Input | The GD&T symbol's leader line information. |
| const UF_DRF_frame_corner_t | frame_corner | Input | Valid when leader_type is UF_DRF_leader_type_ext_line |
| tag_t * const | gdt_symbol_tag | Output | Object tag of created GD&T symbol. |
UF_DRF_create_hole_dim (view source)
Creates and displays a hole dimension.
drafting
int UF_DRF_create_hole_dim
| tag_t* | dimension_tag | Output | Object tag of created hole dimension |
UF_DRF_create_horizontal_baseline_dimension (view source)
Creates and displays a horizontal baseline dimension.
Return code:
0 = No error
not 0 = Error code
Possible return codes can include the following
UF_DRF_null_object_structure - if any object in the object set has null object structure
UF_DRF_null_object - if any object in the object set is null
UF_DRF_invalid_number_of_objects - if num_of_objects is less than 3
Originally released in v18.0
drafting
int UF_DRF_create_horizontal_baseline_dimension
UF_DRF_object_t * object_set,
int num_of_objects,
tag_t * dimension_tag
| UF_DRF_object_t * | object_set | Input | Array of associated objects to be dimensioned. |
| int | num_of_objects | Input | Number of associated objects in array. |
| double | dimension_3d_origin [ 3 ] | Input | 3d dimension set origin in absolute coordinates. |
| tag_t * | dimension_tag | Output | Object tag of created dimension set. |
UF_DRF_create_horizontal_chain_dimension (view source)
Creates and displays a horizontal chain dimension.
Return code:
0 = No error
not 0 = Error code
drafting
int UF_DRF_create_horizontal_chain_dimension
int num_of_objects,
UF_DRF_create_horizontal_dim (view source)
Creates and displays a horizontal dimension.
drafting
int UF_DRF_create_horizontal_dim
| UF_DRF_object_p_t | object1 | Input | Data of first object (see uf_drf_types.h) Valid object types: point, line, arc, conic, cubic spline, B curve, pattern, solid curve, utility symbol (centerline), planar face, or cylindrical face |
| tag_t* | dimension_tag | Output | Object tag of created horizontal dimension |
UF_DRF_create_id_symbol (view source)
Creates and displays an ID symbol.
drafting
int UF_DRF_create_id_symbol
UF_DRF_id_symbol_type_t id_symbol_type,
const char* upper_text_string,
const char* lower_text_string,
UF_DRF_leader_mode_t leader_mode,
tag_t* id_symbol_tag
| UF_DRF_id_symbol_type_t | id_symbol_type | Input | id symbol type UF_DRF_sym_circle = circle UF_DRF_sym_divcir = divided circle UF_DRF_sym_square = square UF_DRF_sym_divsqr = divided square UF_DRF_sym_hexagon = hexagon UF_DRF_sym_divhex = divided hexagon UF_DRF_sym_triup = triangle, point up UF_DRF_sym_tridown = triangle, point down UF_DRF_sym_datum = datum target UF_DRF_sym_roundbox = rounded box |
| const char* | upper_text_string | Input | Upper text string (maximum MAX_ID_SYM_TEXT_LENGTH characters) |
| const char* | lower_text_string | Input | Lower text string (maximum MAX_ID_SYM_TEXT_LENGTH characters) |
| UF_DRF_leader_mode_t | leader_mode | Input | Leader mode UF_DRF_without_leader = without leader UF_DRF_with_leader = with leader |
| UF_DRF_leader_attach_type_t | leader_attach_type | Input | Leader attachment type UF_DRF_leader_attach_object = attached to object UF_DRF_leader_attach_screen = screen position |
| UF_DRF_object_p_t | object | Input | Data of object to attach leader (see uf_drf_types.h) valid object types: point, line, arc, conic, cubic spline, B curve, and solid curve. If the leader_attach_type is UF_DRF_leader_attach_screen, then object = NULL. |
| double | model_pos_3d [ 3 ] | Input | 3d model space position If leader_attach_type = UF_DRF_leader_attach_object, This position is used as an approximate point on the object to attach the leader If leader_attach_type = UF_DRF_leader_attach_screen, This position is the endpoint of the leader |
| tag_t* | id_symbol_tag | Output | Object tag of created id symbol. |
UF_DRF_create_image (view source)
Create an image from an existing image in the part
Returns
UF_DRF_NO_ERRORS if the image was created
drafting
int UF_DRF_create_image
char * image_name,
tag_t drawing_sheet,
double origin [ 3 ] ,
tag_t * image
| char * | image_name | Input | Name of image in part file |
| tag_t | drawing_sheet | Input | The drawing sheet on which to create the image or NULL_TAG to create the image on the current drawing sheet. |
| double | origin [ 3 ] | Input | Origin of new image in drawing sheet units |
| tag_t * | image | Output | Image tag if successful or NULL_TAG if creation failed |
UF_DRF_create_image_from_file (view source)
Create an image from a jpg, png or tif file
Returns
drafting
int UF_DRF_create_image_from_file
char * file_name,
tag_t * image
| char * | file_name | Input | Name of jpg, png or tif file to use to create image |
UF_DRF_create_label (view source)
Creates and displays a label.
drafting
int UF_DRF_create_label
int num_lines_text,
tag_t* label_tag
| UF_DRF_object_p_t | object | Input | Data of object to attach leader (see uf_drf_types.h) Valid object types: point, line, arc, conic, cubic spline, B curve, and solid curve. If the leader_attach_type is UF_DRF_leader_attach_screen, then object = NULL. If object->object_tag is NULL_TAG then UF_DRF_leader_attach_screen should be used as leader_attach_type so object should also be NULL for this case. NOTE: UF_DRF_object_t is a general purpose structure used by several functions. The input fields object_assoc_type and object_assoc_modifier are not supported by UF_DRF_create_label. For example, Attaching the leader to an arc center is not supported, nor is it supported for interactive creation of a label in NX. |
| double | model_pos_3d [ 3 ] | Input | 3d model space position if leader_attach_type = UF_DRF_leader_attach_object This position is used as an approximate point on the object to attach the leader if leader_attach_type = UF_DRF_leader_attach_screen, This position is the endpoint of the leader |
| tag_t* | label_tag | Output | Object tag of created label. |
UF_DRF_create_linear_cline (view source)
Creates and displays a linear centerline (centerline type UF_DRF_linear_cline).
Return code:
0 = No error
not 0 = Error code
UF_DRF_no_objects
In NX4, the centerline angle is inherited from the auxiliary view
hinge line when the session setting has that option enabled.
drafting
int UF_DRF_create_linear_cline
UF_DRF_create_non_assoc_hatch (view source)
Create a non-associative crosshatch. Useful for translating data from
other system or forms, e.g. IGES, that do not support associative
crosshatching.
Returns standard error codes, with success == UF_DRF_NO_ERRORS.
drafting
int UF_DRF_create_non_assoc_hatch
int num_lines,
double * hatch_lines,
tag_t matrix,
tag_t view,
int color,
int line_width,
tag_p_t new_hatch
| int | num_lines | Input | number of hatch lines = sizeof(hatch_lines)/4 |
| double * | hatch_lines | Input | num_lines crosshatch lines ([x1, y1, x2, y2]) quadruples As with all annotations the coordinates are in the coordinater system of the matrix |
| tag_t | matrix | Input | matrix for crosshatch if NULL_TAG then the matrix of the WCS is used |
| tag_t | view | Input | view of crosshatch if NULL_TAG then the crosshatch is not view dependent |
| int | color | Input | color |
| int | line_width | Input | line width |
| tag_p_t | new_hatch | Output | crosshatch created or NULL_TAG if error |
UF_DRF_create_note (view source)
Creates either a horizontal or vertical note and displays it.
Return Codes
UF_DRF_no_text
UF_DRF_null_object
This function was originally released in V14.0.1
drafting
int UF_DRF_create_note
int num_lines_text,
char* text_string [ ] ,
int orientation,
tag_t* note_tag
| char* | text_string [ ] | Input | associated text strings |
| double | origin_3d [ 3 ] | Input | 3d object origin in WCS coordinates |
| int | orientation | Input | Orientation of the note: 0 - Horizontal 1 - Vertical |
| tag_t* | note_tag | Output | Object tag of created note. Initialized to NULL_TAG. |
UF_DRF_create_offctrpt_cx (view source)
n
Creates and displays an offset center point on the x-axis at a
specified distance from the arc center ("centerline" type
UF_DRF_offctrpt_cx).
Return code:
0 = No error
not 0 = Error code
UF_DRF_no_objects
UF_DRF_form_requires_1_object
UF_DRF_offset_center_point_requires_arc
See the
example
This example creates an offset centerpoint on the x-axis a specified
distance from the arc center.
drafting
int UF_DRF_create_offctrpt_cx
UF_DRF_object_p_t cline_object,
const double distance,
tag_t* offctrpt_tag
| UF_DRF_object_p_t | cline_object | Input | Object associated to the centerline (see uf_drf_types.h) Valid object types: arc, curved solid curve |
| const double | distance | Input | Distance value from arc center |
| tag_t* | offctrpt_tag | Output | Object tag of created offset center point |
UF_DRF_create_offctrpt_cy (view source)
Creates and displays an offset center point on the y-axis at a
specified distance from the arc center ("centerline" type UF_DRF_offctrpt_cy).
Return code:
0 = No error
not 0 = Error code
UF_DRF_no_objects
See the
example
This example creates an offset centerpoint on the y-axis at a
specified distance from the arc center.
drafting
int UF_DRF_create_offctrpt_cy
tag_t* offctrpt_tag
UF_DRF_create_offctrpt_fx (view source)
Creates and displays an offset center point on the x-axis and
calculates the offset distance ("centerline" type
UF_DRF_offctrpt_fx).
Return code:
0 = No error
not 0 = Error code
UF_DRF_no_objects
UF_DRF_invalid_object_type_offset_point
See the
example
This example creates an offset centerpoint on the x-axis and
calculates the offset distance.
drafting
int UF_DRF_create_offctrpt_fx
tag_t* offctrpt_tag
| UF_DRF_object_p_t | center_point | Input | Data of object selected for calculating distance to be used in placing offset center point (see uf_drf_types.h) |
UF_DRF_create_offctrpt_fy (view source)
Creates and displays an offset center point on the y-axis and
calculates the offset distance ("centerline" type UF_DRF_offctrpt_fy).
Return code:
0 = No error
not 0 = Error code
UF_DRF_no_objects
See the
example
This example creates an offset centerpoint on the y-axis and
drafting
int UF_DRF_create_offctrpt_fy
tag_t* offctrpt_tag
UF_DRF_create_offctrpt_nx (view source)
specified distance from the arc normal ("centerline" type UF_DRF_offctrpt_nx).
Return code:
0 = No error
not 0 = Error code
UF_DRF_no_objects
drafting
int UF_DRF_create_offctrpt_nx
tag_t* offctrpt_tag
| const double | distance | Input | Distance value from arc normal |
UF_DRF_create_offctrpt_ny (view source)
specified distance from the arc normal ("centerline" type UF_DRF_offctrpt_ny).
Return code:
0 = No error
not 0 = Error code
UF_DRF_no_objects
See the
example
specified distance from the arc normal.
drafting
int UF_DRF_create_offctrpt_ny
tag_t* offctrpt_tag
UF_DRF_create_offcyl_cline_obj (view source)
Creates and displays an offset cylindrical centerline and calculates the
offset distance from the object (centerline type UF_DRF_offcyl_cline_obj).
When you create a cylindrical centerline with an offset, it does not appear
any different than the one created without an offset distance.
However, when you dimension to the cylindrical centerline, the dimension
reflects this distance by adding the offset distance value.
Return code:
0 = No error
not 0 = Error code
UF_DRF_no_objects
UF_DRF_form_requires_2_objects
See the
example
This example creates an offset cylindrical centerline and
calculates the offset distance from an object.
drafting
int UF_DRF_create_offcyl_cline_obj
| UF_DRF_object_p_t | object1 | Input | First object associated to the centerline (see uf_drf_types.h) Valid object types: point, arc, solid curve |
| UF_DRF_object_p_t | object2 | Input | Second object associated to the centerline |
| UF_DRF_object_p_t | center_point | Input | Data of object selected for calculating offset distance (see uf_drf_types.h) |
UF_DRF_create_offcyl_cline_off (view source)
Creates and displays an offset cylindrical centerline with a keyed-in
offset distance (centerline type UF_DRF_offcyl_cline_off).
Return code:
0 = No error
not 0 = Error code
UF_DRF_no_objects
drafting
int UF_DRF_create_offcyl_cline_off
| const double | distance | Input | Offset distance value |
UF_DRF_create_orddimension (view source)
Creates and displays an ordinate dimension.
drafting
int UF_DRF_create_orddimension
tag_t margin_origin_tag,
int dimension_type,
double dogleg_angle,
double dogleg_distance,
int text_origin_flag,
| tag_t | margin_origin_tag | Input | Margin or origin tag |
| int | dimension_type | Input | Type of dimension (required when margin_origin_tag is origin, ignored otherwise) 1 = horizontal 2 = vertical |
| UF_DRF_object_p_t | object | Input | Data of object (see uf_drf_types.h) valid object types: point, line, arc, conic, cubic spline, B curve, pattern, solid curve, offset center point, cylindrical, symmetrical centerline, intersection symbol, target point |
| double | dogleg_angle | Input | Dogleg angle in degrees (0.0 for no dogleg) |
| double | dogleg_distance | Input | Dogleg distance from dim point in wcs coordinates |
| int | text_origin_flag | Input | Text origin flag 1 = center of total text box 2 = center of dimension text box |
| double | origin_3d [ 3 ] | Input | 3d dimension origin in wcs coordinates |
| tag_t* | dimension_tag | Output | Object tag of created ordinate dimension. |
UF_DRF_create_ordinate_dim (view source)
Create a horizontal or vertical ordinate dimension
drafting
int UF_DRF_create_ordinate_dim
tag_t np1,
int ip2,
tag_t np3,
int ip4,
int ip5,
double rp6,
double rp7,
char * cp8,
int ip9,
char cp10 [ ] [ 133 ] ,
int ip11,
double rp12 [ 3 ] ,
tag_t * nr13
| tag_t | np1 | Input | Object identifier of the margin or ordinate origin. |
| int | ip2 | Input | Type of dimension if object is an origin: 1 = Horizontal 2 = Vertical |
| tag_t | np3 | Input | Object to be dimensioned. |
| int | ip4 | Input | Type of associativity to the object 1 = Endpoint 2 = Arc center 3 = Tangency 4 = Utility symbol |
| int | ip5 | Input | Associativity modifier. For endpoint associativity: 1 = First endpoint 2 = Second endpoint For a tangency associativity: 0-100 = parameter percent along the arc to identify the point used to pick the arc side to dimension. For a utility symbol: 1-100 centerline segment number |
| double | rp6 | Input | Dogleg angle in degrees ( 0.0 for no dogleg). |
| double | rp7 | Input | Dogleg distance from the dimension point in WCS units. |
| char * | cp8 | Input | Dimension text string. |
| int | ip9 | Input | Number of lines of appended text. |
| char | cp10 [ ] [ 133 ] | Input | Array of appended text strings. |
| int | ip11 | Input | Text origin flag: 1 = Center of total text box. 2 = Center of dimension text box |
| double | rp12 [ 3 ] | Input | X, Y and Z of origin in WCS coordinates. |
| tag_t * | nr13 | Output | Object identifier of created dimension |
UF_DRF_create_ordinate_margin (view source)
Create an ordinate margin
drafting
int UF_DRF_create_ordinate_margin
int ip1,
tag_t np2,
tag_t np3,
double rp4 [ 2 ] ,
double rp5 [ 2 ] ,
double rp6,
tag_t * nr7
| int | ip1 | Input | Type of margin: 1 = Horizontal 2 = Vertical |
| tag_t | np2 | Input | Object identifier of the ordinate origin. |
| tag_t | np3 | Input | Object identifier of the line or a NULL_TAG. |
| double | rp4 [ 2 ] | Input | X, Y point on the margin, only used if no line object is passed in. |
| double | rp5 [ 2 ] | Input | X, Y direction of the margin, only used if no line object is passed in. |
| double | rp6 | Input | Offset distance. |
| tag_t * | nr7 | Output | Object identifier of the created margin. |
UF_DRF_create_ordinate_origin (view source)
Create an ordinate origin dimension
drafting
int UF_DRF_create_ordinate_origin
tag_t np1,
int ip2,
int ip3,
int ip4,
int ip5,
int ip6,
char * cp7,
tag_t * nr8
| tag_t | np1 | Input | Tag of the associated object. |
| int | ip2 | Input | Type of associativity to the associated object: 1 = endpoint 2 = arc center 3 = Utility symbol |
| int | ip3 | Input | Associativity modifier. For an endpoint associativity: 1 = Associate to the first endpoint 2 = Associate to the second endpoint For an Utility symbol associativity: 1-100 Centerline segment number |
| int | ip4 | Input | Positive quadrant identifier, determines the signs of the dimensions: 1 = Upper right 2 = Upper left 3 = Lower right 4 = Lower left 5 = all quadrants |
| int | ip5 | Input | Arrow and dimension line display for the ordinate origin: 1 = Don't display 2 = Display |
| int | ip6 | Input | Origin symbol display 1 = Display origin name 2 = No display |
| char * | cp7 | Input | Entity name. |
| tag_t * | nr8 | Output | Tag of the created dimension. |
UF_DRF_create_ordmargin (view source)
Creates and displays an ordinate margin.
drafting
int UF_DRF_create_ordmargin
int margin_type,
tag_t ordinate_origin_tag,
double margin_xy_point [ 3 ] ,
double margin_xy_direction [ 2 ] ,
double offset_distance,
tag_t* margin_tag
| int | margin_type | Input | Margin type 1 = horizontal 2 = vertical |
| tag_t | ordinate_origin_tag | Input | Ordinate origin tag |
| UF_DRF_object_p_t | object | Input | Data of line object (see uf_drf_types.h) |
| double | margin_xy_point [ 3 ] | Input | x,y point on margin (required if the object_tag in the object structure is null, ignored otherwise) |
| double | margin_xy_direction [ 2 ] | Input | x,y direction of margin (required if the object_tag in the object structure is null, ignored otherwise) |
| double | offset_distance | Input | Offset distance |
| tag_t* | margin_tag | Output | Object tag of created ordinate margin. |
UF_DRF_create_ordorigin (view source)
Creates and displays an ordinate origin.
drafting
int UF_DRF_create_ordorigin
int positive_quad_id,
int arr_dim_line_display,
int origin_symbol_display,
char* user_object_name,
tag_t* origin_tag
| UF_DRF_object_p_t | object | Input | Data of object (see uf_drf_types.h) Valid object types: point, line, arc, conic, cubic spline, B curve, pattern, solid curve, offset center point, cylindrical, symmetrical centerline, intersection symbol, drafting point |
| int | positive_quad_id | Input | Positive quadrant identifier determines signs of dimensions 1 = upper right 2 = upper left 3 = lower right 4 = lower left 5 = all quadrants |
| int | arr_dim_line_display | Input | Arrow and dimension line display 1 = no 2 = yes |
| int | origin_symbol_display | Input | Origin symbol display 1 = origin name 2 = no display |
| char* | user_object_name | Input | User supplied object name |
| tag_t* | origin_tag | Output | Object tag of created ordinate origin. |
UF_DRF_create_parallel_dim (view source)
Creates and displays a parallel dimension.
drafting
int UF_DRF_create_parallel_dim
| UF_DRF_object_p_t | object1 | Input | Data of first object (see uf_drf_types.h) Valid object types: point, line, arc, conic, cubic spline, B curve, pattern, solid curve, utility symbol (centerline), or cylindrical face |
| tag_t* | dimension_tag | Output | Object tag of created parallel dimension |
UF_DRF_create_perpendicular_dim (view source)
Creates and displays a perpendicular dimension.
drafting
int UF_DRF_create_perpendicular_dim
| UF_DRF_object_p_t | object1 | Input | Data of base (line) object (see uf_drf_types.h) Valid object types: line, linear, cylindrical, symmetrical centerline, straight solid curve, planar face, cylindrical face |
| UF_DRF_object_p_t | object2 | Input | Data of second object valid object types: point, line, arc, conic, cubic spline, B curve, pattern, solid curve, planar face, cylindrical face |
| tag_t* | dimension_tag | Output | Object tag of created dimension. |
UF_DRF_create_radius_dim (view source)
n
Creates and displays a radius dimension.
drafting
int UF_DRF_create_radius_dim
| tag_t* | dimension_tag | Output | Object tag of created radius dimension |
UF_DRF_create_sbf_file (view source)
Creates a Symbol Font Definition File and sets it as current.
via the Release Letter.
drafting
int UF_DRF_create_sbf_file
const char sbf_name [ UF_CFI_MAX_FILE_NAME_BUFSIZE ]
| const char | sbf_name [ UF_CFI_MAX_FILE_NAME_BUFSIZE ] | Input | name of file to be created (30 characters maximum) |
UF_DRF_create_side_seam (view source)
This function creates the side seam representation for the weld symbol
drafting
int UF_DRF_create_side_seam
tag_t view_tag,
tag_t object,
double point [ 3 ] ,
UF_DRF_weld_symbols_p_t weld_symbol_data
| tag_t | weld_symbol_tag | Input | tag of the weld symbol for which side seam has to be created |
| tag_t | view_tag | Input | tag of the view for which side seam has to be created |
| tag_t | object | Input | object used as guide curve for creating side seam. These can be any curve or a solid edge. |
| double | point [ 3 ] | Input | absolute co-ordinates of the point at which the side seam has to be created |
| UF_DRF_weld_symbols_p_t | weld_symbol_data | Input | pointer to weld symbol data which defines the shape and size of the side seam |
UF_DRF_create_sym_cline (view source)
Creates and displays a symmetrical centerline (centerline type
UF_DRF_symmetrical_cline).
Return code:
0 = No error
not 0 = Error code
UF_DRF_no_objects
drafting
int UF_DRF_create_sym_cline
UF_DRF_create_symbol_font (view source)
Creates a symbol font object and saves it in the current SBF file.
drafting
int UF_DRF_create_symbol_font
const char symbol_name [ UF_CFI_MAX_FILE_NAME_BUFSIZE ] ,
double symbol_factor,
const double symbol_anchor [ 3 ] ,
const double symbol_orient [ 3 ] ,
int num_objects,
tag_t object [ ]
| const char | symbol_name [ UF_CFI_MAX_FILE_NAME_BUFSIZE ] | Input | symbol name |
| double | symbol_factor | Input | symbol factor |
| const double | symbol_anchor [ 3 ] | Input | model space x,y,z of anchor point |
| const double | symbol_orient [ 3 ] | Input | model space x,y,z of orientation point |
| int | num_objects | Input | number of objects composing this symbol Maximum allowed is 512 |
| tag_t | object [ ] | Input | num_objects list of object tags |
UF_DRF_create_top_seam (view source)
This function creates the top seam representation for the weld symbol
drafting
int UF_DRF_create_top_seam
tag_t view_tag,
int num_objects,
tag_p_t objects,
logical flip,
| tag_t | weld_symbol_tag | Input | tag of the weld symbol for which top seam has to be created |
| tag_t | view_tag | Input | tag of the view for which top seam has to be created |
| int | num_objects | Input | number of objects to be used for creating the top seam |
| tag_p_t | objects | Input | num_objects objects used as guide curves for creating top seam. For plug/slot and spot, these have to be points. For others these can be any curve or a solid edge |
| logical | flip | Input | flag for direction reversal 0 = no 1 = yes |
| UF_DRF_weld_symbols_p_t | weld_symbol_data | Input | pointer to weld symbol data which defines the shape and size of the top seam |
UF_DRF_create_vertical_baseline_dimension (view source)
Creates and displays a vertical baseline dimension.
Return code:
0 = No error
not 0 = Error code
UF_DRF_invalid_linear_dim_form
drafting
int UF_DRF_create_vertical_baseline_dimension
int num_of_objects,
UF_DRF_create_vertical_chain_dimension (view source)
Creates and displays a vertical chain dimension.
Return code:
0 = No error
not 0 = Error code
drafting
int UF_DRF_create_vertical_chain_dimension
int num_of_objects,
UF_DRF_create_vertical_dim (view source)
Creates and displays a vertical dimension.
drafting
int UF_DRF_create_vertical_dim
| tag_t* | dimension_tag | Output | Object tag of created vertical dimension |
UF_DRF_create_weld_symbol (view source)
Creates the weld symbol.
Return code:
0 = No error
not 0 = Error code
UF_DRF_NO_ERRORS - No error
UF_DRF_ERR_WELD_SYM_STD_NOT_SUPPORTED - The specified Weld Symbol
Standard is not supported
UF_DRF_ERR_INVALID_EXTENSION - The specified Extension type is not
supported
UF_err_program_not_initialized - Open API has not been
initialized
UF_DRF_INVALID_WELD_TYPE The specified weld type
is not supported in UF
UF_DRF_ weld_symbols_t
UF_DRF_object_t
drafting
int UF_DRF_create_weld_symbol
UF_DRF_weld_symbols_p_t weld_symbol_data,
tag_p_t weld_symbol_tag
| double | origin_3d [ 3 ] | Input | 3d object origin in absolute coordinates |
| UF_DRF_object_p_t | object | Input | Data of object to attach leader (see uf_drf_types.h). Valid object types: point, line, arc, conic, cubic spline, B curve, and solid curve. |
| UF_DRF_weld_symbols_p_t | weld_symbol_data | Input | pointer to the weld symbol structure |
| tag_p_t | weld_symbol_tag | Output | tag of the weld symbol created |
UF_DRF_create_xhatch (view source)
Create a crosshatching
Void
drafting
void UF_DRF_create_xhatch
int * op_type,
int * nmbnds,
int * numels,
tag_t * elems,
tag_t * xhat_eid,
int * rtc
| int * | op_type | Input | The type of operation: 1 = Cross hatching 2 = Area fill 3 = Solid fill |
| int * | nmbnds | Input | The number of crosshatch boundaries. |
| int * | numels | Input | An array of integer values, containing the number of objects in each boundary. The sum of all of the values in this array should equal the number of boundary objects passed in. The number of elements in this array is equal to the number of crosshatch boundaries above. |
| tag_t * | elems | Input | Array of curve or point tags the make up each of the boundaries. A boundary object tag may be included in the array. |
| tag_t * | xhat_eid | Output | The object identifier of the created crosshatch. |
| int * | rtc | Output | The return code from the operation. |
UF_DRF_edit_dim_assoc (view source)
Defined in: uf_drf.h
Edits the associativity of a selected dimension. This is applicable to
changing a retained dimension by reassociating the dimension to
up-to-date geometry.
drafting
int UF_DRF_edit_dim_assoc
tag_t dimension_tag,
double old_leader_position [ 3 ] ,
double new_leader_position [ 3 ] ,
int new_assoc_type,
UF_DRF_object_p_t new_assoc_object
| tag_t | dimension_tag | Input | Tag of dimension whose associativity is being edited. |
| double | old_leader_position [ 3 ] | Input | Position on associated object to be replaced (arrow location). - drawing coordinates if on drawing - model space coordinates if in model |
| double | new_leader_position [ 3 ] | Input | Position on new associated object to attach to. |
| int | new_assoc_type | Input | Type of new associativity horizontal, vertical, parallel, perpendicular, cylindrical, and folded radius: 1 = end point 2 = arc center point 3 = arc tangent point 9 = centerline horizontal and vertical ordinate, and ordinate origin dimensions: 0 = none 1 = end point 2 = arc center point 3 = arc tangent point 9 = centerline angular dimensions: 1 = dimension to line 2 = dimension to extension line 5 = dimension to centerline arc length, radius, diameter, hole, and concentric circle dimensions: does not apply |
| UF_DRF_object_p_t | new_assoc_object | Input | Data of new object (see uf_drf_types.h) to associate to. Note that the only fields used are object_tag and object_view_tag. Valid object_tag types: point, line, arc, conic, cubic spline, B curve, pattern, and solid curve. |
UF_DRF_edit_weld_symbol (view source)
Given the symbol tag and the new symbol data, this function will edit the
weld symbol. Note that the change in weld symbol standard during editing is
not supported. This means that the current weld symbol standard and the new
symbol standard should be the same.
UF_DRF_object_t
drafting
int UF_DRF_edit_weld_symbol
UF_DRF_flip_image_about_height (view source)
Flip the image about the direction of its height.
Returns
UF_DRF_NO_ERRORS if the image edit was successful
This function was originally released in NX2.0.
drafting
int UF_DRF_flip_image_about_height
tag_t image
| tag_t | image | Input | Image to edit |
UF_DRF_flip_image_about_width (view source)
Flip the image about the direction of its width.
Returns
drafting
int UF_DRF_flip_image_about_width
tag_t image
UF_DRF_frdim (view source)
Create a folded radius
Void
drafting
void UF_DRF_frdim
tag_t np1,
tag_t np2,
int ip3,
int ip4,
double * rp5,
double rp6,
const char * cp7,
int ip8,
const UF_DRF_one_apptext_line_t cp9 [ ] ,
double rp10 [ 3 ] ,
tag_t * nr11,
int * error
| tag_t | np1 | Input | Object identifier of an Arc, bolt circle or circular CLINE. |
| tag_t | np2 | Input | Object identifier of offset center point (point, line, solid edge, offse center point, cylindrical center line, symmetrical center line, target point or intersection point. |
| int | ip3 | Input | Type of associativity: 1 = endpoint 2 = Arc center 3 = Tangency |
| int | ip4 | Input | Associativity modifier, if the type of associativity is an endpoint: 1 = Associate to first endpoint 2 = Associate to second endpoint If the type of associativity is a tangency: 0-100 is the parameter percent to be used to compute the approximate tangency point. |
| double * | rp5 | Input | Fold location in WCS coordinates. |
| double | rp6 | Input | Fold angle in degrees. |
| const char * | cp7 | Input | Dimension text string. |
| int | ip8 | Input | Number of lines of appended text. |
| const UF_DRF_one_apptext_line_t | cp9 [ ] | Input | Array of appended text strings. |
| double | rp10 [ 3 ] | Input | X, Y and Z of object origin in WCS coordinates. |
| tag_t * | nr11 | Output | Object identifier of the created folded radius dimension. |
| int * | error | Output | Error return, 0 for success. |
UF_DRF_free_appended_text (view source)
The following function will free the appended text data returned from
UF_DRF_ask_appended_text
Internal & External
Created in V17.0
drafting
int UF_DRF_free_appended_text
int num_text,
UF_DRF_appended_text_p_t appended_text
UF_DRF_free_centerline (view source)
Frees the memory used for storing centerline data.
Original release was in V13.0.
drafting
int UF_DRF_free_centerline
UF_DRF_centerline_info_t * * centerline_info
UF_DRF_free_comp_data (view source)
This function will free the data returned from UF_DRF_record_draft_objects.
Returns
UF_DRF_NO_ERRORS
Internal & External
Created in NX4.0
drafting
int UF_DRF_free_comp_data
void * objs
| void * | objs | Input | Drafting object data from UF_DRF_record_draft_objects |
UF_DRF_free_dimension (view source)
Frees the memory used for storing the dimension information of the
data object.
drafting
int UF_DRF_free_dimension
UF_DRF_dim_info_t * * dim_info
UF_DRF_free_dimension_preferences1 (view source)
The following function will free the dimension preferences data returned from
UF_DRF_ask_dimension_preferences1
Originally released in NX7.5
int UF_DRF_free_dimension_preferences1
UF_DRF_dimension_preferences1_p_t dimension_preferences
UF_DRF_free_font (view source)
Frees the memory used for storing user symbol font information.
drafting
int UF_DRF_free_font
int num_fonts,
UF_DRF_ud_symbol_font_info_t * * font_info
| int | num_fonts | Input | Number of User Defined Symbol blocks |
| UF_DRF_ud_symbol_font_info_t * * | font_info | Input | Data structure which contains the User Defined Symbol font number, left and right connection points, factor, length, height and the count of strokes and stoke data |
UF_DRF_free_gdtsymbol (view source)
Frees the memory used for storing the GD & T symbol information.
See the
example code for UF_DRF_ask_gdt_symbol_info.
The code in the example queries the GD&T Symbol information and frees the
memory after usage.
drafting
int UF_DRF_free_gdtsymbol
UF_DRF_gdt_symbol_info_t * * gdt_symbol_info
UF_DRF_free_idsymbol (view source)
Frees the memory used for storing the ID symbol information.
drafting
int UF_DRF_free_idsymbol
UF_DRF_id_symbol_info_t * * id_symbol_info
UF_DRF_free_image_data (view source)
Free the image data
Returns
UF_DRF_NO_ERRORS if the image data free was successful
drafting
int UF_DRF_free_image_data
UF_DRF_image_data_t * data
UF_DRF_free_label (view source)
Frees label information memory.
See the
example code for UF_DRF_ask_label
The code in the example queries the label information, and frees the label
information memory after usage.
drafting
int UF_DRF_free_label
UF_DRF_label_info_t * * label_info
UF_DRF_free_leader_data (view source)
This function will free a UF_DRF_leader_data_p_t
Returns
UF_DRF_NO_ERRORS
Internal & External
Created in NX3.0.2
int UF_DRF_free_leader_data
UF_DRF_leader_data_p_t * leader_data
UF_DRF_free_text (view source)
Frees the memory used for storing text data information.
drafting
int UF_DRF_free_text
int num_text,
UF_DRF_draft_aid_text_info_t * * text_info
| int | num_text | Input | Number of text strings |
| UF_DRF_draft_aid_text_info_t * * | text_info | Input | Pointer to data structure which contains drafting aid text information (see uf_drf_types.h) |
UF_DRF_get_symbol_divider (view source)
Find the location of a symbol inside of a drafting text.
drafting
int UF_DRF_get_symbol_divider
int * ann_data,
int * divider_instance,
double start_point [ 2 ] ,
double end_point [ 2 ]
| int * | segment_number | Input | The segment of the text to get. |
| int * | divider_instance | Input | Count to the substring that is to be used. |
| double | start_point [ 2 ] | Output | X and Y coordinates of the start point. |
| double | end_point [ 2 ] | Output | X and Y coordinates of the end point. |
UF_DRF_get_text_bars (view source)
Return the location where a fraction bar or underline bar or
overline bar should be drawn for text.
drafting
int UF_DRF_get_text_bars
int * ann_data,
int * number_of_bars,
int * bar_type,
int * offset_to_bar,
double bar_position [ 4 ]
| int * | segment_number | Input | The text segment number to work on. |
| int * | number_of_bars | Output | The number of text bars in this drafting object. |
| int * | bar_type | Output | An array of types of text bars, one for each text bar. 1 = Under line 2 = Over line |
| int * | offset_to_bar | Output | An array of offsets to the text in the string where the bar text ends. |
| double | bar_position [ 4 ] | Output | An array of positions for the text bar. There are four elements for each text bar, the X, Y of the start of the text bar, and the X, Y of the end of the bar. |
UF_DRF_get_text_substring (view source)
Return the requested text substring of the drafting object.
drafting
int UF_DRF_get_text_substring
int * ann_data,
int * substring_instance,
int * text_type,
int * number_of_substring,
char * substring,
double substring_position [ 2 ] ,
double substring_characteristic [ 6 ]
| int * | substring_instance | Input | The substring number that we want to find. |
| int * | text_type | Output | The type of the substring: 0 = string 1 = superscript 2 = subscript 3 = symbol |
| int * | number_of_substring | Output | The number of bytes in the returned substring. |
| char * | substring | Output | The substring found. |
| double | substring_position [ 2 ] | Output | The x and y coordinates for the start of this substring. |
| double | substring_characteristic [ 6 ] | Output | Six word array of characteristics of this substring: [0] = The character size [1] = The physical length of the substring [2] = The scale from the original character size of the string. [3] = The scale from the original character gap. [4] = The character slant angle. [5] = The text angle. |
UF_DRF_get_xhatch_parms (view source)
Gets the crosshatch parameters.
drafting
void UF_DRF_get_xhatch_parms
tag_t * xhat_eid,
char mat_name [ UF_OBJ_NAME_BUFSIZE ] ,
int int_parms [ 9 ] ,
double real_parms [ 13 ] ,
int * rtc
| tag_t * | xhat_eid | Input | Object identifier of the desired crosshatch |
| char | mat_name [ UF_OBJ_NAME_BUFSIZE ] | Output | Material name of the crosshatch |
| int | int_parms [ 9 ] | Output | Integer parameters of the crosshatch. This an array of nine elements (int_parms[9]) [0] = entity site [1] = line density [2] = filled arrowhead control [3] = crosshatch symbol color [4] = section validity flag [5-8] = number of crosshatch lines in each of 4 directions |
| double | real_parms [ 13 ] | Output | Real parameters of the crosshatch. This is an array of 13 elements (real_parms[13]). [0] = Arrow size [1-4] = Crosshatch distance for each of 4 directions [5-8] = Crosshatch angle for each of 4 directions [9] = Crosshatch tolerance [10] = Arrowhead filled distance [11] = Arrowhead included angle [12] = Dot arrowhead diameter |
| int * | rtc | Output | Return code: 1 = xhat_eid is not a hatch. |
UF_DRF_has_associative_origin (view source)
The following function will query the associative origin information for the
annotation.
Created in V17.0
drafting
int UF_DRF_has_associative_origin
tag_t drafting_entity,
logical * has_associative_origin
| tag_t | drafting_entity | Input | Dimension or drafting object to query. |
| logical * | has_associative_origin | Output | Result of query |
UF_DRF_inherit_feature_data (view source)
This routine inherits feature annotation into user specified views on
a drawing.
UF_DRF_inherit_type_t
UF_DRF_ask_callout_of_annotation
UF_DRF_ask_controlling_member_of_callout
UF_DRF_ask_number_of_rows_in_callout
UF_DRF_ask_callout_row_members
drafting
int UF_DRF_inherit_feature_data
int feature_pre_v13_sketch_count,
tag_p_t features_pre_v13_sketches,
tag_p_t part_occs,
int view_count,
tag_p_t views,
UF_DRF_inherit_type_t inherit_type
| int | feature_pre_v13_sketch_count | Input | number of features and pre-v13 sketches to be annotated |
| tag_p_t | features_pre_v13_sketches | Input | feature_pre_v13_sketch_count the features and pre-v13 sketches to be annotated. A pre-v13 sketch tag is the tag in the part of the sketch, not in the part occurrence of the sketch. |
| tag_p_t | part_occs | Input | feature_pre_v13_sketch_count the i-th feature or sketch to be annotated occurs in the occurence of the part given by part_occs[i]. NULL_TAG is valid. |
| int | view_count | Input | number of views to be annotated |
| tag_p_t | views | Input | views to be annotated |
| UF_DRF_inherit_type_t | inherit_type | Input | the types of annotation to be inherited Currently only UF_DRF_inherit_feature_parameters is supported |
UF_DRF_init_associativity_data (view source)
The following function initialized the associativity structure on the
annotation object.
Internal or External
Originally released in V19.0
drafting
int UF_DRF_init_associativity_data
UF_DRF_object_assoc_data_p_t associativity_data
UF_DRF_init_assortpart_arc (view source)
Initialize an Assorted Parts Arc Data Structure.
drafting
int UF_DRF_init_assortpart_arc
UF_DRF_assortpart_arc_t * assortpart_arc
UF_DRF_init_assortpart_arrow (view source)
Initializes an Assorted Parts Arrow Data Structure.
drafting
int UF_DRF_init_assortpart_arrow
UF_DRF_assortpart_arrow_t * assortpart_arrow
UF_DRF_init_assortpart_line (view source)
Initializes an Assorted Parts Line Data Structure.
drafting
int UF_DRF_init_assortpart_line
UF_DRF_assortpart_line_t * assortpart_line
UF_DRF_init_assortpart_text (view source)
Initializes an Assorted Parts Text Data Structure.
drafting
int UF_DRF_init_assortpart_text
UF_DRF_assortpart_text_t * assortpart_text
UF_DRF_init_image_data (view source)
Initialize the image data
Returns
UF_DRF_NO_ERRORS if the image data initialization was successful
drafting
int UF_DRF_init_image_data
UF_DRF_init_line_object (view source)
Initializes a line object structure.
Original release was in V14.0.
drafting
int UF_DRF_init_line_object
UF_DRF_line_object_t * line_object
| UF_DRF_line_object_t * | line_object | Output | Line object initialized as follows: line_object->line_assoc_type = UF_DRF_ASSOC_LINE_TYPE_NONE line_object->object1 line_object->object2 initialized by UF_DRF_init_object_structure |
UF_DRF_init_object_structure (view source)
Initialize an UF_DRF_object_t structure (see uf_drf_types.h).
drafting
int UF_DRF_init_object_structure
| UF_DRF_object_t * | object | Input / Output | Object structure to be initialized. (Input) object - initialized object structure (Output) object.object_tag = NULL_TAG object.object_view_tag = NULL_TAG object.object_assoc_type = UF_DRF_end_point object.object_assoc_modifier = UF_DRF_first_end_point object.object2_tag = NULL_TAG object.assoc_dwg_pos[0] = 0.0 object.assoc_dwg_pos[1] = 0.0 |
UF_DRF_init_symbol_create_data (view source)
Initializes a symbol data structure for creation.
drafting
int UF_DRF_init_symbol_create_data
UF_DRF_symbol_create_data_t * symbol_data
UF_DRF_initialize_custom_symbol_data (view source)
This function will initialize the UF_DRF_custom_symbol_t structure. This
routine should be called prior to filling this structure with valid data.
Calling this routine will guarantee that the data structure does not
contain garbage values. Calling this routine WILL NOT guarantee that the
structure will contain valid values which can be processed by
UF_DRF_create_custom_symbol_instance. Do not call this routine on a
structure with valid pointers to allocated memory. Doing that will cause
the pointers to be reset, causing the allocated memory to become inaccessible.
Please free any dynamically allocated memory in this structure before
overwriting the pointers with new data.
UF_DRF_NO_ERRORS
Other UF error codes
UF_DRF_is_sbf_symbol, UF_DRF_create_custom_symbol_instance
Created in V18.0.3
drafting
int UF_DRF_initialize_custom_symbol_data
UF_DRF_custom_symbol_p_t symbol_definition
UF_DRF_initialize_custom_symbol_text_data (view source)
This function will initialize the UF_DRF_custom_symbol_text_t structure.
This routine should be called prior to filling this structure with valid
data. Calling this routine will guarantee that the data structure does not
UF_DRF_create_custom_symbol_instance. Note that calling this routine on a
valid structure that points to allocated memory may result in memory leaks.
To prevent this, please free any dynamically allocated memory before reusing
pointer variables.
UF_DRF_NO_ERRORS
UF_DRF_create_custom_symbol_instance,
Created in V18.0.3
drafting
int UF_DRF_initialize_custom_symbol_text_data
UF_DRF_custom_symbol_text_p_t symbol_text
UF_DRF_initialize_leader_data (view source)
This function will initialize the UF_DRF_leader_t structure. This routine
should be called prior to filling this structure with valid data. Calling
this routine will guarantee that the data structure does not contain
structure will contain valid values. Note that calling this routine on a
If you are reusing an existing structure, please free your dynamically
allocated memory first.
Return values include:
UF_DRF_NO_ERRORS
Created in V18.0.3
drafting
int UF_DRF_initialize_leader_data
UF_DRF_leader_p_t leader
UF_DRF_is_annotation_retained (view source)
Gets a logical indicating whether the specified annotation is retained or not.
Return code:
0 = No error
not 0 = Error code
UF_DRF_null_object
UF_err_bad_parameter_number_1
int UF_DRF_is_annotation_retained
tag_t annotation,
logical * is_retained
| tag_t | annotation | Input | Tag of the annotation |
| logical * | is_retained | Output | Retained state of the annotation, TRUE if the annotation is retained |
UF_DRF_is_block_centerline (view source)
Checks if the input tag is a block centerline.
Originally released in v19.0
int UF_DRF_is_block_centerline
tag_t object_tag,
logical * is_block_cline
| tag_t | object_tag | Input | tag of the centerline |
| logical * | is_block_cline | Output | a logical value. This is true if object_tag is block centerline. This is false if object_tag is not block centerline |
UF_DRF_is_chamfer_dimension (view source)
Description -
ask if dimension is a chamfer dimension
PARAMETERS -
dim_tag, - <I> tag of object
is_cham_dim - <O> TRUE if object is cham dim
return - <O> return code:
0 = OK
if not 0 = error code
int UF_DRF_is_chamfer_dimension
tag_t dim_tag,
logical * is_cham_dim
| tag_t | dim_tag | Input | tag of object |
| logical * | is_cham_dim | Output | TRUE if object is cham dim |
UF_DRF_is_inherited_pmi (view source)
This function will return TRUE if the given annotation is an inherited PMI
on a drawing sheet/member view.
Inherited PMI is the associative copy of the PMI display instance in modeling.
Input parameter annotation must be an Annotation object. Annotation object
occurrences are not supported.
Use UF_ASSEM_is_occurrence and UF_ASSEM_ask_prototype_of_occ as appropriate
to get the Annotation object from its occurrence.
Returns
UF_DRF_NO_ERRORS
Internal & External
Created in NX5.0
drafting
int UF_DRF_is_inherited_pmi
tag_t annotation,
logical * inherited
| tag_t | annotation | Input | The tag of the annotation object |
| logical * | inherited | Output | TRUE if the tag is an inherited PMI |
UF_DRF_is_narrow_dimension (view source)
Ask if a dimension is narrow dimension
Return code:
0 = No error
not 0 = Error code
int UF_DRF_is_narrow_dimension
logical * is_narrow_dimension
| tag_t | dimension_tag | Input | Object tag of any object |
| logical * | is_narrow_dimension | Output | True if the dimension is narrow dimension |
UF_DRF_is_object_out_of_date (view source)
Queries the up-to-date status of an object. Currently, only two types
of objects are valid: views and drawings.
Internal & External:
int UF_DRF_is_object_out_of_date
tag_t object,
logical * out_of_date
| tag_t | object | Input | The view or drawing to query |
| logical * | out_of_date | Output | The status of the object, TRUE if the object is out of date. |
UF_DRF_is_pmi_display_instance (view source)
This function will return TRUE if the given annotation is a PMI display
instance.
PMI display instances are those objects that are created from the PMI
menu pulldown. It's important to note that the type and subtype of
PMI display instances may coincide with other drafting annotations.
Input parameter object must be an Annotation object. Annotation object
Returns
UF_DRF_NO_ERRORS
Internal & External
Created in NX4.0
int UF_DRF_is_pmi_display_instance
tag_t object,
logical * is_display_instance
| tag_t | object | Input | The tag of the annotation object |
| logical * | is_display_instance | Output | TRUE if the tag is a display instance |
UF_DRF_is_sbf_symbol (view source)
The following function will return TRUE if the input symbol is a user defined
symbol based on the SBF file format. If the input symbol is a custom
symbol with a standard part file format, this function will return FALSE.
Internal & External
Created in V18.0
int UF_DRF_is_sbf_symbol
tag_t symbol,
logical * is_sbf
| tag_t | symbol | Input | A user defined symbol tag |
| logical * | is_sbf | Output | A logical value indicating TRUE if this symbol uses the SBF definition, or FALSE if the symbol is a custom symbol |
UF_DRF_margin_to_cline (view source)
Convert all V9 margin objects to centerline objects
drafting
int UF_DRF_margin_to_cline
tag_t part_tag
| tag_t | part_tag | Input | The tag of an open part |
UF_DRF_place_symbol (view source)
Places a standalone symbol.
drafting
int UF_DRF_place_symbol
UF_DRF_symbol_create_data_t * symbol_data,
logical is_inverted,
logical is_mirrored,
tag_t * symbol_tag
UF_DRF_record_draft_objects (view source)
This function will query drafting objects and store associated data. The
data stored includes:
origin, text box lenght and width, text, terminator locations, line and
arc data, retain state
Returns
UF_DRF_NO_ERRORS
Internal & External
Created in NX4.0
drafting
int UF_DRF_record_draft_objects
void * * objs,
logical record_view_data
| void * * | objs | Output to UF_*free* | Drafting objects Must be freed by calling UF_DRF_free_comp_data |
| logical | record_view_data | Input | Should view data be recorded? |
UF_DRF_remove_controlling_exp (view source)
Remove the link between drafting object and controlling expression
Originally released in V16.0
drafting
int UF_DRF_remove_controlling_exp
tag_t object
| tag_t | object | Input | Drafting object |
UF_DRF_render_arrowhead (view source)
Calls the supplied "rendering functions for each line or arc of the arrowhead.
Useful for functionality such as translation to other systems.
No NULL function pointers are permitted in the render table.
Return code:
0 = No error
not 0 = Error code
Written in V16.0
drafting
int UF_DRF_render_arrowhead
tag_t part,
tag_t ann,
UF_DRF_arrow_info_p_t arrow_info,
logical use_arrow_z,
UF_DRF_render_table_p_t render_table,
void * client
| tag_t | part | Input | part for text |
| tag_t | ann | Input | CANNOT be NULL_TAG |
| UF_DRF_arrow_info_p_t | arrow_info | Input | arrowhead information |
| logical | use_arrow_z | Input | If TRUE then use the input z. Should only be used for GD&T arrows obtained from UF_GDT_ask_leader |
| UF_DRF_render_table_p_t | render_table | Input | table of rendering functions |
| void * | client | Input | application client data passed through to each function in the render table |
UF_DRF_render_text (view source)
Traverses lines of drafting text and calls the supplied "rendering"
functions. Useful for functionality such as translation to other
systems.
NOTE: The draw_char and draw_uds functions are not yet implemented.
Text is always output as lines and arcs and user defined symbols
are always output as lines.
Return code:
0 = No error
not 0 = Error code
Written in V16.0
drafting
int UF_DRF_render_text
tag_t part,
tag_t ann,
int num_lines,
char * * text,
UF_DRF_draft_aid_text_info_p_t text_info,
void * client
| tag_t | ann | Input | can be NULL_TAG |
| int | num_lines | Input | number of lines of text |
| char * * | text | Input | text to "render" |
| UF_DRF_draft_aid_text_info_p_t | text_info | Input | parameters to be used for text |
| void * | client | Input | application client data, passed through to each function in the render table |
UF_DRF_rotate_image (view source)
Rotate the image
The angle that the image can be rotated is limited to 90-degree increments.
Returns
drafting
int UF_DRF_rotate_image
tag_t image,
double angle
| double | angle | Input | Angle in degrees to rotate image by Must be in increments of 90-degrees |
UF_DRF_set_annotation_template (view source)
Set the template name which is to be used in UF_DRF_inherit_feature_data.
UF_DRF_ask_annotation_template
drafting
int UF_DRF_set_annotation_template
char * annotation_template_name
| char * | annotation_template_name | Input | the name of the annotation template part which will be used by UF_DRF_inherit_feature_data. The name is the same as the name appearing in the Feature Parameters dialog and does not contain the directory in which the part resides or the extension .atp.prt, for example, ansi or iso_din |
UF_DRF_set_appended_text (view source)
The following function will set the appended text for a dimension.
The appended text will only be changed for those locations specified.
If num_lines is input as 0,
the appended text for that location will be deleted.
Internal & External
Created in V17.0
In NX2.0.1 this function was enhanced to support appended text
for horizontal and vertical ordinate dimensions. However,
for ordinate dimensions, appended text is currently limited to
1 location or before and after or above and below.
drafting
int UF_DRF_set_appended_text
tag_t dimension,
int num_text,
UF_DRF_set_areafill_angle (view source)
Sets the area fill angle for the specified area fill object.
drafting
int UF_DRF_set_areafill_angle
tag_t areafill_id,
double angle
| tag_t | areafill_id | Input | Area fill object identifier |
| double | angle | Input | Area fill angle in radians |
UF_DRF_set_areafill_material (view source)
Sets the area fill material for the specified area fill object. The area
fill material type structure,
UF_DRF_valid_material_t defines the type of material.
drafting
int UF_DRF_set_areafill_material
tag_t areafill_id,
UF_DRF_valid_material_t material
UF_DRF_set_areafill_scale (view source)
Sets the area fill scale for the specified area fill object.
drafting
int UF_DRF_set_areafill_scale
tag_t areafill_id,
double scale
| double | scale | Input | Area fill scale |
UF_DRF_set_associative_origin (view source)
The following function will set the associative origin information for the
annotation.
Note that UF_DRF_ORIGIN_ALIGNED_WITH_ARROWS is not supported by this function.
Created in V17.0
drafting
int UF_DRF_set_associative_origin
UF_DRF_associative_origin_p_t origin_data,
double origin [ 3 ]
| UF_DRF_associative_origin_p_t | origin_data | Input | Data used to define the associative origin. |
| double | origin [ 3 ] | Input | Origin of the annotation in absolute coords. |
UF_DRF_set_associativity_data (view source)
The following function edit all of the associativities for the annotation
object.
drafting
int UF_DRF_set_associativity_data
tag_t object,
int num_associativities,
| tag_t | object | Input | Drafting object or dimension to edit for this operation. |
| int | num_associativities | Input | The number of associativities on the object in which to edit for this operation. |
| UF_DRF_object_assoc_data_p_t | associativity_data | Input | Array of new associativity information. |
UF_DRF_set_chamfer_dimension_data (view source)
Description -
set chamfer dimension preferences
PARAMETERS -
cham_dim_tag, - <I> tag of cham dim
cham_dim_data - <I> cham dim prefs
0 = OK
drafting
int UF_DRF_set_chamfer_dimension_data
tag_t cham_dim_tag,
UF_DRF_chamfer_dimension_data_t cham_dim_data
UF_DRF_set_custom_symbol_angle (view source)
Set the angle for a custom symbol instance.
drafting
int UF_DRF_set_custom_symbol_angle
tag_t symbol_tag,
double angle
| tag_t | symbol_tag | Input | tag of a custom symbol instance |
| double | angle | Input | double representing the new angle for this instance |
UF_DRF_set_custom_symbol_scale (view source)
Set the symbol scale for a custom symbol instance.
drafting
int UF_DRF_set_custom_symbol_scale
tag_t symbol_tag,
double scale
| double | scale | Input | double value of the symbol scale |
UF_DRF_set_customer_sbf_file (view source)
Sets as current the customer default symbol font definition file.
drafting
int UF_DRF_set_customer_sbf_file
UF_DRF_set_cyl_dim (view source)
Changes the double flag of a cylindrical dimension. Any cylindrical
dimension may be modified with this function. It is up to the user to
determine which dimensions to modify.
drafting
int UF_DRF_set_cyl_dim
tag_t dim_obj,
int double_flag,
int * status
| tag_t | dim_obj | Input | Target cylindrical dimension object identifier. |
| int | double_flag | Input | Double flag to be used on the dimension 0 = sets dimension value to be the distance between the two associated objects. 1 = sets dimension value to be twice the value between associated objects. |
| int * | status | Output | Return status: 0 = Cylindrical dimension changed accordingly. 1 = Cylindrical dimension was not changed since the new double flag is the same as the one it has. 2 = dimension was not changed since it is not a cylindrical dimension. |
UF_DRF_set_diameter_radius_preferences (view source)
Sets preferences for the display of radial dimensions.
Internal & External
drafting
int UF_DRF_set_diameter_radius_preferences
UF_DRF_diameter_radius_preferences_p_t diameter_radius_preferences
UF_DRF_set_dim_appended_text_space_factor (view source)
Set the factor for the space between the dimension and the appended text for the specified dimension.
This factor controls the spacing between the before appended text and the next piece of dimension text to its right,
and the spacing between the after appended text and the next piece of dimension text to its left.
This factor is applied to the appended text character size to determine the spacing.
NX 2.0 release.
drafting
int UF_DRF_set_dim_appended_text_space_factor
tag_t dimension,
double space_factor
| tag_t | dimension | Input | dimension tag |
| double | space_factor | Input | factor for spacing between dimension and appended text |
UF_DRF_set_dim_dim_line_space_factor (view source)
Set the factor for the space between the dimension and the dimension line for the specified dimension.
This factor controls the spacing between the bottom most piece of dimension text and the dimension line
only when the text orientation is UF_DRF_DIMENSION_TEXT_OVER_DIMENSION_LINE.
This factor is applied to the dimension text character size to determine the spacing.
NX 2.0 release.
drafting
int UF_DRF_set_dim_dim_line_space_factor
tag_t dimension,
double space_factor
| double | space_factor | Input | factor for spacing between dimension and dimension line |
UF_DRF_set_dim_inspection_type (view source)
Description -
Set the inspection preference for the given dimension object.
Input -
inspection_type - inspection type for the given dimension object.
Output - None
Return -
= 0 UF_DRF_NO_ERRORS
Error code if not zero.
UF_DRF_invalid_object -- if given tag is invalid.
drafting
int UF_DRF_set_dim_inspection_type
tag_t dim_tag,
UF_DRF_inspection_type_t inspection_type
UF_DRF_set_dim_reference_type (view source)
Description -
Set the reference preference for the given dimension object.
Input -
ref_type - reference type for the given dimension object.
Output - None
Return -
drafting
int UF_DRF_set_dim_reference_type
tag_t dim_tag,
UF_DRF_reference_symbol_type_t ref_type
UF_DRF_set_dim_tolerance_text_space_factor (view source)
Set the factor for the space between the dimension and the tolerance text for the specified dimension.
This factor controls the spacing between the dimension text and the after tolerance text.
This factor is applied to the tolerance text character size to determine the spacing.
NX 2.0 release.
drafting
int UF_DRF_set_dim_tolerance_text_space_factor
tag_t dimension,
double space_factor
| double | space_factor | Input | factor for spacing between dimension and tolerance text |
UF_DRF_set_dimension_preferences (view source)
Sets dimension preferences for arrow and line formatting, type of
placement, tolerance and precision, and text orientation.
Internal & External
drafting
int UF_DRF_set_dimension_preferences
UF_DRF_dimension_preferences_p_t dimension_preferences
UF_DRF_set_dimension_preferences1 (view source)
Internal & External
Originally released in V8.0.1
drafting
int UF_DRF_set_dimension_preferences1
UF_DRF_set_dimension_set_offset (view source)
Set the offset of the dimension in a dimension set or the offset of all dimensions in the dimension set.
Return code:
0 = No error
not 0 = Error code
Possible return codes can include the following
UF_err_bad_parameter_number_1 - if the dimension tag is invalid
Originally released in v18.0
drafting
int UF_DRF_set_dimension_set_offset
tag_t dimension,
double offset
| tag_t | dimension | Input | Tag of the given dimension. If this tag is a tag of dimension set, it will set offset for all dimensions in the set. |
| double | offset | Input | Dimension set offset of the given dimension. |
UF_DRF_set_draft_common (view source)
Set the drafting common values for a particular drafting object.
This is used to initialize prior to calling UF_DRF_count_text_substring,
UF_DRF_get_symbol_divider and UF_DRF_get_text_substring
drafting
int UF_DRF_set_draft_common
tag_t * object
| tag_t * | object | Input | Tag of the object to set the drafting common for. |
UF_DRF_set_hatch_fill_preferences (view source)
Sets the preferences for crosshatching and area fill
Internal & External
drafting
int UF_DRF_set_hatch_fill_preferences
UF_DRF_hatch_fill_preferences_p_t hatch_fill_preferences
UF_DRF_set_image_align_position (view source)
Edit the image alignment position
The image alignment position controls the placement of the image's origin
with respect to the box created by the image width and height.
The image angle is limited to 90 degree increments.
Returns
drafting
int UF_DRF_set_image_align_position
tag_t image,
UF_DRF_align_position_t align_position
UF_DRF_set_image_aspect_ratio_lock (view source)
Edit the image's aspect ratio locked status.
The aspect ratio locked status controls whether or not the ratio of the
image's width to its height can change when the image size changes.
Returns
drafting
int UF_DRF_set_image_aspect_ratio_lock
tag_t image,
logical lock_aspect_ratio
| logical | lock_aspect_ratio | Input | TRUE to not allow the image's aspect ratio to change |
UF_DRF_set_image_height (view source)
Edit the image height
Returns
drafting
int UF_DRF_set_image_height
tag_t image,
double height
| double | height | Input | New image height in drawing sheet units |
UF_DRF_set_image_width (view source)
Edit the image width
Returns
drafting
int UF_DRF_set_image_width
tag_t image,
double width
| double | width | Input | New image width in drawing sheet units |
UF_DRF_set_lettering_preferences (view source)
Sets the lettering preferences for dimension, appended, tolerance and
general (notes, id symbols, etc,) text.
Internal & External
Horizontal text justification preference and GD&T frame height
factor preference added in V17.0.
Dimension /Appended Text Space Factor,
Dimension/ Tolerance Text Space Factor, and
Dimension/Dimension Line Space Factor added in NX 2.0.
drafting
int UF_DRF_set_lettering_preferences
UF_DRF_lettering_preferences_p_t lettering_preferences
UF_DRF_set_line_arrow_preferences (view source)
Sets preferences that apply to leaders, arrows and extension lines for both
dimensions and other annotations
Internal & External
drafting
int UF_DRF_set_line_arrow_preferences
UF_DRF_line_arrow_preferences_t * line_arrow_preferences
UF_DRF_set_narrow_dimension_data (view source)
Set narrow dimension parameters for a linear dimension.
Return code:
0 = No error
not 0 = Error code
UF_DRF_invalid_linear_dim_form - if the dimension given is not linear dimension.
UF_DRF_INVALID_NARROW_DIMENSION_DISPLAY_TYPE - if dimension display type is not correct.
UF_DRF_INVALID_NARROW_DIMENSION_LEADER_ANGLE - if leader angle is not greater than 0.0 or not less than 180.0
UF_DRF_INVALID_NARROW_DIMENSION_TEXT_ORIENTATION - if text orientation is not valid.
drafting
int UF_DRF_set_narrow_dimension_data
UF_DRF_narrow_dimension_info_p_t narrow_data
UF_DRF_set_object_preferences (view source)
Sets the object preferences for a specified annotation.
Return code:
0 = No error
not 0 = Error code
Possible return codes can include the following:
UF_DRF_NOT_DRAFTING_OBJECT
UF_DRF_crosshatch_file_not_found
UF_DRF_material_definition_not_found
UF_DRF_unable_to_create_crosshatching
Original release was in V13.0. This function replaces uc5551.
Updated in V15 to increase the size of the character strings.
Updated in V16.0 to return UF_get_fail_message error codes
mpr[51], area fill tolerance, is now obsolete; use mpr[13] instead.
In V17.0, a separate preference controls the angular nominal and tolerance
units format. This routine will set both nominal and tolerance format with
nominal format value when angular nominal format gets changed by user.
drafting
int UF_DRF_set_object_preferences
tag_t drf_object_tag,
int mpi [ 100 ] ,
double mpr [ 70 ] ,
const char * radius_val,
const char * diameter_val
| tag_t | drf_object_tag | Input | Drafting object Identifier |
| int | mpi [ 100 ] | Input | MPI Array [100 elements] The size of this array is defined by NUM_INT_PARAMS |
| double | mpr [ 70 ] | Input | MPR Array [70 elements] The size of this array is defined by NUM_REAL_PARAMS |
| const char * | radius_val | Input | Radius Symbol String. This can be at most six characters, however due to internal requirements, the buffer must be allocated as char radius_val[27]; |
| const char * | diameter_val | Input | Diameter Symbol String. This can be at most six characters, however due to internal requirements, the buffer must be allocated as char diameter_val[27]; |
UF_DRF_set_origin (view source)
Set the new origin of the annotation object.
Return code:
0 = No error
not 0 = Error code
Written in V16.0
drafting
int UF_DRF_set_origin
tag_t annotation,
double new_origin [ 3 ]
| tag_t | annotation | Input | Tag of the annotation to modify. |
| double | new_origin [ 3 ] | Input | New origin in model coordinates for the annotation. |
UF_DRF_set_plot_drawing_images (view source)
Indicate whether or not to plot raster images on drawing sheets when drawing sheets are plotted.
Returns
UF_DRF_NO_ERRORS if the preference edit was successful
This function was originally released in NX3.0.
drafting
int UF_DRF_set_plot_drawing_images
logical plot_images
| logical | plot_images | Input | TRUE to plot raster images on drawing sheets FALSE to not plot raster images on drawing sheets |
UF_DRF_set_preferences (view source)
Uses the arrays and character strings to set the drafting parameters.
Return code:
0 = No error
not 0 = Error code
UF_DRF_INVALID_CROSSHATCH_FILE_FORMAT
Before NX5 there was only one preference for dimension text orientation. In NX5, a
separate preference for Ordinate dimension text orientation was added. The Open C API
was not enhanced. UF_DRF_set_preferences will set both the general text orientation
and the ordinate text orientation with the same value. This was done so legacy programs
would continue to work.
Original release was in V13.0. This function replaces uc/uf5521.
Updated in V16.0 to return UF_get_fail_message error codes.
In V16.0, there are separate text angle preferences for dimensions
and drafting aid. UF_DRF_set_preferences sets both text angle
preferences.
If the input material index (mpi[31]) is input as -999, the
crosshatch material preferences will not be changed.
drafting
int UF_DRF_set_preferences
int mpi [ 100 ] ,
double mpr [ 70 ] ,
UF_DRF_set_retain_color_font_width (view source)
Sets the color, font and widths used for retained annotations.
Return code:
0 = No error
not 0 = Error code
UF_err_bad_parameter_number_2
UF_err_bad_parameter_number_3
drafting
int UF_DRF_set_retain_color_font_width
int color,
int font,
int width
| int | color | Input | Color to use for retained annotations |
| int | font | Input | Font to use for retained annotations |
| int | width | Input | Line width to use for retained annotations |
UF_DRF_set_retained_state (view source)
Sets the retained state for annotations whose dependencies have expired.
If UF_DRF_KEEP_RETAINED_ANNOTATIONS, annotations are retained.
If UF_DRF_DELETE_RETAINED_ANNOTATIONS, annotations are deleted.
Return code:
0 = No error
not 0 = Error code
drafting
int UF_DRF_set_retained_state
UF_DRF_retained_state_t state
| UF_DRF_retained_state_t | state | Input | Behavior state for retained annotations. Either 'UF_DRF_KEEP_RETAINED_ANNOTATIONS' or 'UF_DRF_DELETE_RETAINED_ANNOTATIONS' |
UF_DRF_set_specified_sbf_file (view source)
Sets as current the specified symbol font definition file.
drafting
int UF_DRF_set_specified_sbf_file
| const char | sbf_name [ UF_CFI_MAX_FILE_NAME_BUFSIZE ] | Input | file to be set |
UF_DRF_set_suppress_pre_zeros (view source)
Sets the global preference for suppress preceding zeros.
This function was originally released in V15.0.
drafting
int UF_DRF_set_suppress_pre_zeros
logical option
| logical | option | Input | Suppress preceding zeros mode |
UF_DRF_set_suppress_view_update (view source)
Change the value of the Suppress View Update preference. This preference is
an environment setting and is not specific to a part. If the preference is
TRUE, then functions which perform implicit drawing updates, will not update
the drawing member views.
drafting
int UF_DRF_set_suppress_view_update
logical suppress_view_update
| logical | suppress_view_update | Input | the new setting of view update suppression |
UF_DRF_set_symbol_preferences (view source)
Sets preferences that apply to ID, User Defined, Centerline, Intersection,
Target and GD&T symbols.
Internal & External
drafting
int UF_DRF_set_symbol_preferences
UF_DRF_symbol_preferences_p_t symbol_preferences
UF_DRF_set_text_above_leader (view source)
Sets the global value for the text above the leader attribute. This
attribute controls displaying text above the leader stub when creating
labels and some dimensions.
If the attribute is set to UF_DRF_NO_TEXT_ABOVE_LEADER,
the text will not be displayed above the leader stub. The vertical text
justification of Top, Middle or Bottom applies.
For all the other options, the text will be displayed above the leader
stub. The BOTTOM options display the leader stub under the
bottom line of the text. The TOP options display the leader stub
under the top line of the text. The UNDERLINE options will
underline all other lines of text. The MAX options will extend the
stub and optional underlines to the maximum text length. Without
MAX, the stub and optional underlines will extend to the length of the
individual text line it is under.
For dimensions, the text above leader attribute only applies to radial
type dimensions (hole, diameter, radius, concentric circle, and folded
radius) and only applies if the text alignment is Horizontal or Angle.
Currently, for dimensions, only the option
UF_DRF_LEADER_BOTTOM_TEXT_MAX is supported.
drafting
int UF_DRF_set_text_above_leader
UF_DRF_text_above_leader_t option
| UF_DRF_text_above_leader_t | option | Input | Text above leader attribute UF_DRF_NO_TEXT_ABOVE_LEADER UF_DRF_LEADER_BOTTOM_TEXT_MAX UF_DRF_LEADER_BOTTOM_TEXT_MAX_UNDERLINE UF_DRF_LEADER_BOTTOM_TEXT UF_DRF_LEADER_BOTTOM_TEXT_UNDERLINE UF_DRF_LEADER_TOP_TEXT_MAX UF_DRF_LEADER_TOP_TEXT_MAX_UNDERLINE UF_DRF_LEADER_TOP_TEXT UF_DRF_LEADER_TOP_TEXT_UNDERLINE |
UF_DRF_set_tolerance (view source)
This function will set the tolerance used when compare the real data values
of two drafting entities whose data was recorded using the
UF_DRF_record_draft_objects function
Returns
UF_DRF_NO_ERRORS
Internal & External
Created in NX4.0
drafting
int UF_DRF_set_tolerance
float tolerance
| float | tolerance | Input | Tolerance to use when comparing real data |
UF_DRF_set_uds_size (view source)
The following function will set the global preferences for the user defined
symbol length / height or scale / aspect ratio.
drafting
int UF_DRF_set_uds_size
UF_DRF_uds_size_p_t uds_size
| UF_DRF_uds_size_p_t | uds_size | Input | User defined symbol scale / aspect ratio or length / height parameters. |
UF_DRF_set_ugdefault_sbf_file (view source)
Sets as current the NX default symbol font
definition file.
drafting
int UF_DRF_set_ugdefault_sbf_file
UF_DRF_set_units_format_preferences (view source)
Sets preferences for the display of linear and angular dimensions values
as well as dual dimension format.
Internal & External
Originally released in V16.0. In v17.0, the data structure has changed.
An element controlling the units of the tolerance of angular dimension and
an element controlling the zero suppression for angular dimension have been added.
The display leading zeros option has been removed.
drafting
int UF_DRF_set_units_format_preferences
UF_DRF_units_format_preferences_p_t units_format_preferences
UF_DRF_set_vertical_note (view source)
This function will set a note to be either horizontal or vertical.
Created in V16.0
drafting
int UF_DRF_set_vertical_note
tag_t note,
logical is_vertical
| tag_t | note | Input | Tag of the note. |
| logical | is_vertical | Input | If TRUE, set the note to be vertical, if FALSE set the note horizontal. If the object is not a note, no action is taken, and the return code will be zero. |
UF_DRF_set_weld_symbol_standard (view source)
Set the weld symbol standard
Return code:
0 = No error
not 0 = Error code
UF_err_program_not_initialized - Open C API has not been
initialized
Originally released in vNX1.0.2
drafting
int UF_DRF_set_weld_symbol_standard
char * standard
| char * | standard | Input | standard of the weld symbol |
UF_DRF_set_xhatch_mat (view source)
Sets the crosshatch material using the given name.
drafting
void UF_DRF_set_xhatch_mat
const char * file_name,
const char * material_name,
int * util,
int * error
| const char * | file_name | Input | The crosshatch definition file name |
| const char * | material_name | Input | The desired crosshatch material name |
| int * | util | Input | Flag indicating whether to search the utility directory first or the user's working directory. 1 = Search utility directory first. 2 = Search home directory first then utility directory. |
| int * | error | Output | Error flag. Value > 0 indicates an error has occurred. |
UF_DRF_transfer_to_drawing (view source)
This function will transfer an annotation view dependent in a drawing member
view or a model view to the drawing sheet specified.
Return code:
0 = No error
not 0 = Error code
Created in V16.0
drafting
int UF_DRF_transfer_to_drawing
tag_t annotation,
tag_t member_view,
tag_t drawing,
logical in_drawing_plane
| tag_t | annotation | Input | Annotation to transfer |
| tag_t | member_view | Input | Tag of the member view in which the associativities should be related. |
| tag_t | drawing | Input | Tag of the drawing on which the annotation should now lie. |
| logical | in_drawing_plane | Input | If TRUE, the annotation will lie in the drawing plane, otherwise, the orientation will be retained. |
UF_DRF_update_views (view source)
Update one or more drawing member views on a drawing. The view update
process includes resectioning section views, regenerating silhouettes, and,
if applicable, updating hidden line display. This routine will:
1) force update one view (method == UF_DRF_UPDATE_NAMED & view_name),
2) update all automatic views (method == UF_DRF_UPDATE_AUTO) on the specified drawing,
3) update all out-of-date views (method == UF_DRF_UPDATE_ALL) on the specified drawing, or
4) force update all views (method == UF_DRF_UPDATE_FORCE) on the specified drawing.
If not current, the specified drawing will be retrieved and made current.
If no drawing is specified, then the current drawing is assumed.
drafting
int UF_DRF_update_views
char * drawing_name,
int method,
char * view_name
| char * | drawing_name | Input | name of drawing whose views are to be updated |
| int | method | Input | one of 'UF_DRF_UPDATE_AUTO', 'UF_DRF_UPDATE_FORCE', 'UF_DRF_UPDATE_ALL', or 'UF_DRF_UPDATE_NAMED' |
| char * | view_name | Input | if method = 'UF_DRF_UPDATE_NAMED', the name of the view to update |
