UF_UDOBJ_add_areas (view source)
Defined in: uf_udobj.h
Adds area data to the convertible data area. Any number of doubles
can be added to the areas array. Each double represents a unit of
area. These calls are cumulative, if you make one call to add two
areas, and then a second call to add three areas, you will end up
with 5 areas on the UDO, and UF_UDOBJ_edit_areas would expect you
to pass in 5 elements.
int UF_UDOBJ_add_areas
tag_t udo_tag,
unsigned int num_areas,
double * areas
| tag_t | udo_tag | Input | The tag for the UDO |
| unsigned int | num_areas | Input | The number of areas to add. |
| double * | areas | Input | The area data to add to the UDO. |
UF_UDOBJ_add_doubles (view source)
Adds doubles to the free form data area of an UDO. Any number of
valid double elements can be added. These calls are cumulative, if you
make one call to add two doubles, and then a second call to add three
doubles, you will end up with 5 doubles on the UDO, and UF_UDOBJ_edit_doubles
would expect you to pass in 5 elements.
int UF_UDOBJ_add_doubles
tag_t udo_tag,
unsigned int num_doubles,
double * doubles
| unsigned int | num_doubles | Input | The number of doubles to add. |
| double * | doubles | Input | The doubles to add to the UDO. |
UF_UDOBJ_add_integers (view source)
Adds integers to the free form data area of an UDO. Any number of
valid integer elements can be added. These calls are cumulative, if you
make one call to add two integers, and then a second call to add three
integers, you will end up with 5 integers on the UDO, and UF_UDOBJ_edit_integers
int UF_UDOBJ_add_integers
tag_t udo_tag,
unsigned int num_ints,
int * ints
| unsigned int | num_ints | Input | The number of integers to add. |
| int * | ints | Input | The integers to add to the UDO. |
UF_UDOBJ_add_lengths (view source)
Adds length data to the convertible data area. Any number of doubles
can be added to the lengths array. Each double represents a unit of
length. These calls are cumulative, if you make one call to add two
lengths, and then a second call to add three lengths, you will end up
with 5 lengths on the UDO, and UF_UDOBJ_edit_lengths would expect you
int UF_UDOBJ_add_lengths
tag_t udo_tag,
unsigned int num_lengths,
double * lengths
| unsigned int | num_lengths | Input | The number of lengths to add. |
| double * | lengths | Input | The length data to add to the UDO. |
UF_UDOBJ_add_links (view source)
Adds a link to the specified NX objects defined by the
link_defs[ ] array.
Links cannot be cyclical. Also, a type 2 link cannot be used to link
UDOs to features, solid faces, or solid edges. You can only link to
objects found in uf_object_types.h. These calls are cumulative, if
you make one call to add two links, and then a second call to add three
links, you will end up with 5 links on the UDO, and UF_UDOBJ_edit_links
The order in which NX objects are passed into this routine is NOT preserved.
So, no assumptions should be made in this regard.
int UF_UDOBJ_add_links
tag_t udo_tag,
unsigned int num_links,
UF_UDOBJ_link_t link_defs [ ]
| unsigned int | num_links | Input | The number of objects to link to the UDO. |
| UF_UDOBJ_link_t | link_defs [ ] | Input | The link types and the associated NX objects to link to. |
UF_UDOBJ_add_owning_links (view source)
Adds objects by owning links to a UDO. These calls are cumulative, if
links, you will end up with 5 links on the UDO.
If the udo_tag is a UDO Feature, then the array of input tags can not include
any solids, faces, edges, sheets or features. The array of tags should only
be wireframe data.
int UF_UDOBJ_add_owning_links
tag_t udo_tag,
tag_t ug_objs [ ]
| tag_t | udo_tag | Input | The tag of the UDO to which to add owning links. |
| unsigned int | num_links | Input | The number of objects to link to the UDO by owning links. |
| tag_t | ug_objs [ ] | Input | An array of tags of objects to link to the UDO by owning links. |
UF_UDOBJ_add_strings (view source)
Adds strings to the free form data area of an UDO. Any number of
valid null terminated string elements can be added. These calls are cumulative,
if you make one call to add two strings, and then a second call to add three
strings, you will end up with 5 strings on the UDO, and UF_UDOBJ_edit_strings
int UF_UDOBJ_add_strings
tag_t udo_tag,
unsigned int num_strings,
char * strings [ ]
| unsigned int | num_strings | Input | The number of strings to add. |
| char * | strings [ ] | Input | The strings to add to the UDO. |
UF_UDOBJ_add_volumes (view source)
Adds volume data to the convertible data area. Any number of
doubles can be added to the volumes array. Each double represents a
unit of volume. These calls are cumulative, if you make one call to add two
volumes, and then a second call to add three volumes, you will end up
with 5 volumes on the UDO, and UF_UDOBJ_edit_areas would expect you
int UF_UDOBJ_add_volumes
tag_t udo_tag,
unsigned int num_volumes,
double * volumes
| unsigned int | num_volumes | Input | The number of volumes to add. |
| double * | volumes | Input | The volume data to add to the UDO. |
UF_UDOBJ_ask_class_data (view source)
Finds both the class name and the user friendly name for the specified
class identifier. The friendly_name appears in the class selection dialog
if it is enabled.
int UF_UDOBJ_ask_class_data
UF_UDOBJ_class_t class_id,
char * * class_name,
char * * friendly_name
| UF_UDOBJ_class_t | class_id | Input | The class identifier from a previously created class. |
| char * * | class_name | Output to UF_*free* | The name of the class of UDOs. Use UF_free to deallocate memory when done. |
| char * * | friendly_name | Output to UF_*free* | The user-friendly class name. Use UF_free to deallocate memory when done. |
UF_UDOBJ_ask_class_id_of_name (view source)
Finds the class id associated with the given class name.
int UF_UDOBJ_ask_class_id_of_name
const char * class_name,
UF_UDOBJ_class_t * class_id
| const char * | class_name | Input | Name of a udo class - NOTE: do not use the "friendly" class name |
| UF_UDOBJ_class_t * | class_id | Output | Class id associated with the given class name |
UF_UDOBJ_ask_owned_objects (view source)
Queries the number of associated NX objects that have owning links
to the specified UDO.
int UF_UDOBJ_ask_owned_objects
tag_t udo_tag,
int* num_owned_objects,
tag_t* * owned_objects
| tag_t | udo_tag | Input | The tag of the UDO to query |
| int* | num_owned_objects | Output | The number of NX objects linked to the UDO by owning links. |
| tag_t* * | owned_objects | Output to UF_*free* | An array of tags of NX objects linked to the UDO by owning links. |
UF_UDOBJ_ask_owning_udo (view source)
Queries if the specified NX object is linked to a UDO by an owning
link. Returns the tag of the UDO with the owning link. Returns
NULL_TAG if there is no UDO with an owning link to the specified
NX object.
int UF_UDOBJ_ask_owning_udo
tag_t obj_tag,
tag_t* udo_tag
| tag_t | obj_tag | Input | The tag of the NX object to query |
| tag_t* | udo_tag | Output | The tag of the UDO which has an owning link to the specified NX object. |
UF_UDOBJ_ask_udo_class_name (view source)
Finds the class name associated with the UDO.
int UF_UDOBJ_ask_udo_class_name
tag_t udo_tag,
char * * udo_class_name
| tag_t | udo_tag | Input | Tag for the UDO. |
| char * * | udo_class_name | Output to UF_*free* | The class name assigned to the UDO. Ensure the memory is freed using UF_free once the information is no longer needed. |
UF_UDOBJ_ask_udo_data (view source)
Finds all of the data associated with an UDO and returns it in the
data structure UF_UDOBJ_all_data_s. The order of the links returned by this
routine need not match with the order in which they are created through
UF_UDOBJ_add_links or UF_UDOBJ_add_owning_links. No assumptions should be made
in this regard.
int UF_UDOBJ_ask_udo_data
tag_t udo_tag,
UF_UDOBJ_all_data_t * all_data
| UF_UDOBJ_all_data_t * | all_data | Output to UF_*free* | All of the data associated with the UDO. The structure that this points to becomes fully populated following this call. Certain structure members must be freed when no longer needed. This can be freed by calling UF_UDOBJ_free_udo_data |
UF_UDOBJ_ask_udo_feature_of_udo (view source)
Inquires the UDO feature tag of the input UDO object. A UDO
object may have only one UDO feature associated to it.
Internal & External
This function was originally released in V15.0.
int UF_UDOBJ_ask_udo_feature_of_udo
tag_t udo_tag,
tag_t * udo_feature_tag
| tag_t | udo_tag | Input | The tag of the UDO object whose feature we are returning. |
| tag_t * | udo_feature_tag | Output | The tag of the UDO feature of the input object. NULL_TAG will be returned if there is no UDO feature for the input object. |
UF_UDOBJ_ask_udo_links_to_obj (view source)
Finds all of the UDO links to a particular NX object.
int UF_UDOBJ_ask_udo_links_to_obj
tag_t ug_tag,
int * num_links,
UF_UDOBJ_link_t * * udo_links
| tag_t | ug_tag | Input | The tag of the NX object for which to retrieve the UDO links. |
| int * | num_links | Output | The number of UDO links associated with the NX object. |
| UF_UDOBJ_link_t * * | udo_links | Output to UF_*free* | The links between UDOs and the NX object. Note that the member element udo_links[i].assoc_ug_tag will be the tag of the i+1 UDO that links to this object. When done, use UF_free to deallocate memory for these links. |
UF_UDOBJ_ask_udo_of_udo_feature (view source)
Inquires the tag of the UDO object that is associated to the input
UDO feature
Internal & External
int UF_UDOBJ_ask_udo_of_udo_feature
tag_t udo_feature_tag,
tag_t * udo_tag
| tag_t | udo_feature_tag | Input | The tag of the UDO feature whose UDO object we are returning. |
| tag_t * | udo_tag | Output | The tag of the UDO object of the input object. |
UF_UDOBJ_clear_link_status (view source)
Clears the link status of a UDO.
int UF_UDOBJ_clear_link_status
tag_t udo_tag,
UF_UDOBJ_link_p_t link_to_clear
| tag_t | udo_tag | Input | The tag of the UDO whose link's status is to be cleared. |
| UF_UDOBJ_link_p_t | link_to_clear | Input | The link whose status is to be cleared. |
UF_UDOBJ_clear_udo_status (view source)
Clears the out-of-date indicator of an UDO.
int UF_UDOBJ_clear_udo_status
tag_t udo_tag
| tag_t | udo_tag | Input | Tag for the UDO whose out-of-date indicator is to be cleared. |
UF_UDOBJ_create_class (view source)
Creates the class, given a class name, and friendly name for a
particular type of UDO. Returns a class identifier which is used by
UF_UDOBJ_create_udo to create the UDO and return its tag.
UF_UI_add_to_class_sel can be used to enable the friendly name on the
class selection dialog.
int UF_UDOBJ_create_class
const char * friendly_name,
| const char * | class_name | Input | The class name for the particular type of User Defined Object. |
| const char * | friendly_name | Input | A user-friendly name that appears in the class selection dialog (if enabled) and in other locations where a name is useful. |
| UF_UDOBJ_class_t * | class_id | Output | The class identifier. This identifier is not persistent across NX sessions nor is it stored in NX part files. |
UF_UDOBJ_create_udo (view source)
Creates a UDO of the class specified by the input class identifier. This
creates a UDO "template" with a name and status. Note that creating a UDO
will not display the UDO. This is so that you can add data that your display
routines may need prior to the UDO being displayed. When the UDO has been
fully created, call UF_DISP_add_item_to_display to actually display the UDO.
int UF_UDOBJ_create_udo
tag_t * udo_tag
| tag_t * | udo_tag | Output | The tag for the UDO |
UF_UDOBJ_create_udo_feature (view source)
Creates both a UDO object and a UDO feature from an existing
class identifier. Note that UF_MODL_update() must be called to complete the
creation of the UDO feature and have it appear in the Model Navigation Tool.
Internal & External
int UF_UDOBJ_create_udo_feature
tag_t * udo_tag,
| UF_UDOBJ_class_t | class_id | Input | The class identifier from a previously created class |
| tag_t * | udo_feature_tag | Output | The tag for the UDO feature |
UF_UDOBJ_create_udo_feature_from_udo (view source)
Creates a UDO feature associated with a UDO object and returns
the tag of the newly created feature. This function returns an error if
you attempt to create a UDO feature for a UDO object which is
already associated to a UDO feature.
Internal & External
int UF_UDOBJ_create_udo_feature_from_udo
tag_t udo_tag,
| tag_t | udo_tag | Input | The UDO to create the UDO feature from |
| tag_t * | udo_feature_tag | Output | The newly created UDO feature |
UF_UDOBJ_cycle_udos_by_class (view source)
Cycles the UDOs in the part with the specified input tag. Input a
NULL_TAG to start the cycle. The cycle ends when a NULL_TAG
is returned.
Do not attempt to delete objects when cycling the database in a loop. Problems
can occur when trying to read the next object when the current object has been
deleted. To delete objects, save an array with the objects in it, and then
when you have completed cycling, use UF_OBJ_delete_array_of_objects to delete
the saved array of objects.
int UF_UDOBJ_cycle_udos_by_class
tag_t part_tag,
tag_t * udo_tag
| tag_t | part_tag | Input | The part in which to cycle UDOs. |
| UF_UDOBJ_class_t | class_id | Input | The UDO class to cycle. |
| tag_t * | udo_tag | Input / Output | The UDO found. The cycle starts and ends with a NULL_TAG. The tag from the previous cycle should be input for the next cycle. |
UF_UDOBJ_delete_areas (view source)
Deletes the convertible areas area of a UDO starting at the
designated location and concluding with the specified numbers of
areas to delete.
int UF_UDOBJ_delete_areas
tag_t udo_tag,
unsigned int start_loc,
unsigned int num_to_delete
| tag_t | udo_tag | Input | The tag of the UDO whose areas are to be deleted. |
| unsigned int | start_loc | Input | The location within the UDO area values to start deleting from. Valid values are 1 through the number of areas in the UDO. |
| unsigned int | num_to_delete | Input | The numbers of areas to delete. |
UF_UDOBJ_delete_doubles (view source)
Deletes the free form doubles area of a UDO starting at the
doubles to delete.
int UF_UDOBJ_delete_doubles
tag_t udo_tag,
| tag_t | udo_tag | Input | The tag of the UDO whose doubles are to be deleted. |
| unsigned int | start_loc | Input | The location within the UDO double area to start deleting from. Valid values are 1 through the number of doubles in the UDO. |
| unsigned int | num_to_delete | Input | The numbers of doubles to delete. |
UF_UDOBJ_delete_integers (view source)
Deletes the free form integer area of a UDO starting at the
integers to delete.
int UF_UDOBJ_delete_integers
tag_t udo_tag,
| tag_t | udo_tag | Input | The tag of the UDO whose integers are to be deleted. |
| unsigned int | start_loc | Input | The location within the UDO integer area to start deleting from. Valid values are 1 through the number of integers in the UDO. |
| unsigned int | num_to_delete | Input | The numbers of integers to delete. |
UF_UDOBJ_delete_lengths (view source)
Deletes the convertible lengths area of a UDO starting at the
lengths to delete.
int UF_UDOBJ_delete_lengths
tag_t udo_tag,
| tag_t | udo_tag | Input | The tag of the UDO whose lengths are to be deleted. |
| unsigned int | start_loc | Input | The location within the UDO length area to start deleting from. Valid values are 1 through the number of lengths in the UDO. |
| unsigned int | num_to_delete | Input | The numbers of lengths to delete. |
UF_UDOBJ_delete_link (view source)
Deletes a UDO's link.
int UF_UDOBJ_delete_link
tag_t udo_tag,
UF_UDOBJ_link_p_t link_to_delete
| tag_t | udo_tag | Input | The tag of the UDO whose link is to be deleted. |
| UF_UDOBJ_link_p_t | link_to_delete | Input | The link to delete from the UDO. |
UF_UDOBJ_delete_owning_link (view source)
Deletes the owning link between a UDO and its associated NX
object.
int UF_UDOBJ_delete_owning_link
tag_t udo_tag,
tag_t ug_tag
| tag_t | udo_tag | Input | The tag UDO whose owning link is to be deleted. |
| tag_t | ug_tag | Input | The tag of the NX object whose UDO owning link is to be deleted. |
UF_UDOBJ_delete_strings (view source)
Deletes the free form strings area of a UDO starting at the designated
location and concluding with the specified numbers of strings to
delete.
int UF_UDOBJ_delete_strings
tag_t udo_tag,
| tag_t | udo_tag | Input | The tag of the UDO whose strings are to be deleted. |
| unsigned int | start_loc | Input | The location within the UDO string area to start deleting from. Valid values are 1 through the number of strings in the UDO. |
| unsigned int | num_to_delete | Input | The numbers of strings to delete. |
UF_UDOBJ_delete_volumes (view source)
Deletes the convertible volumes area of a UDO starting at the
volumes to delete.
int UF_UDOBJ_delete_volumes
tag_t udo_tag,
| tag_t | udo_tag | Input | The tag of the UDO whose volumes are to be deleted. |
| unsigned int | start_loc | Input | The location within the UDO volume area to start deleting from. Valid values are 1 through the number of volumes in the UDO. |
| unsigned int | num_to_delete | Input | The numbers of volumes to delete. |
UF_UDOBJ_edit_areas (view source)
Edits the areas convertible data area of a UDO. The input array must have
elements for all of the areas currently on the UDO. You should know the data
model for your UDO, but if you are unsure of the number of areas on a UDO,
UF_UDOBJ_ask_udo_data will return this information.
int UF_UDOBJ_edit_areas
tag_t udo_tag,
double areas [ ]
| tag_t | udo_tag | Input | The tag of the UDO whose areas are to be edited. |
| double | areas [ ] | Input | The new areas for the UDO. |
UF_UDOBJ_edit_doubles (view source)
Edits the free form double area of a UDO. The input array must have elements
for all of the doubles currently on the UDO. You should know the data model
for your UDO, but if you are unsure of the number of doubles on a UDO,
int UF_UDOBJ_edit_doubles
tag_t udo_tag,
double doubles [ ]
| tag_t | udo_tag | Input | The tag of the UDO whose doubles are to be edited. |
| double | doubles [ ] | Input | The new doubles for the UDO. |
UF_UDOBJ_edit_integers (view source)
Edits the free form integer area of a UDO. The input array must have elements
for all of the integers currently on the UDO. You should know the data model
for your UDO, but if you are unsure of the number of integers on a UDO,
int UF_UDOBJ_edit_integers
tag_t udo_tag,
int integers [ ]
| tag_t | udo_tag | Input | The tag of the UDO whose integers are to be edited. |
| int | integers [ ] | Input | The new integers for the UDO. |
UF_UDOBJ_edit_lengths (view source)
Edits the lengths convertible data area of a UDO. The input array must have
elements for all of the lengths currently on the UDO. You should know the data
model for your UDO, but if you are unsure of the number of lengths on a UDO,
int UF_UDOBJ_edit_lengths
tag_t udo_tag,
double lengths [ ]
| tag_t | udo_tag | Input | The tag of the UDO whose lengths are to be edited. |
| double | lengths [ ] | Input | The new lengths for the UDO. |
UF_UDOBJ_edit_link (view source)
Edits a UDO's link with the following edit features:
Replaces all the links for a specific link type within a UDO for a
particular NX object with another NX object.
Only affects a single link type at a time. Therefore, if there are
multiple links within a UDO to the same object, each with separate
link types, this function must be used once for each link type.
If there are multiple links to the same NX object with the same
link type, all the links are affected.
int UF_UDOBJ_edit_link
tag_t udo_tag,
UF_UDOBJ_link_p_t link_to_edit,
tag_t new_assoc_ug_tag
| tag_t | udo_tag | Input | The tag of the UDO whose link is to be edited. |
| UF_UDOBJ_link_p_t | link_to_edit | Input | The link within the UDO whose reference is to be changed. |
| tag_t | new_assoc_ug_tag | Input | The tag to insert into the link in place of the tag currently in use. |
UF_UDOBJ_edit_links (view source)
Edit the link records of a UDO. The input array should contain all of
the link records of the UDO. The edit will start at location
link_defs[start_location] and continue for count elements of the array.
int UF_UDOBJ_edit_links
tag_t udo_tag,
const UF_UDOBJ_link_t * link_def,
unsigned int start_location,
unsigned int count
| tag_t | udo_tag | Input | The tag of the UDO whose links are to be edited |
| const UF_UDOBJ_link_t * | link_def | Input | The new links for the UDO |
| unsigned int | start_location | Input | The location in the link_defs array where editing is to begin (This should be a "C" based array index.) |
| unsigned int | count | Input | The count of links to be edited from start_location |
UF_UDOBJ_edit_strings (view source)
Edits the free form string area of a UDO. The input array must have elements
for all of the strings currently on the UDO. You should know the data model
for your UDO, but if you are unsure of the number of strings on a UDO,
int UF_UDOBJ_edit_strings
tag_t udo_tag,
char * strings [ ]
| tag_t | udo_tag | Input | The tag of the UDO whose strings are to be edited. |
| char * | strings [ ] | Input | The new strings for the UDO. |
UF_UDOBJ_edit_udo_of_udo_feature (view source)
Edits a UDO feature by replacing the existing tag of the UDO object
with the input tag of the UDO object. The old UDO object is no
longer associated to a UDO feature and may be associated to
another UDO feature. If the input UDO object is associated to
another UDO feature, the editing is not done and this routine
returns an error.
Internal & External
int UF_UDOBJ_edit_udo_of_udo_feature
tag_t udo_tag
| tag_t | udo_feature_tag | Input | The UDO feature to edit. |
| tag_t | udo_tag | Input | The UDO to edit the UDO feature with |
UF_UDOBJ_edit_volumes (view source)
Edits the volumes convertible data area of a UDO. The input array must have
elements for all of the volumes currently on the UDO. You should know the data
model for your UDO, but if you are unsure of the number of volumes on a UDO,
int UF_UDOBJ_edit_volumes
tag_t udo_tag,
double volumes [ ]
| tag_t | udo_tag | Input | The tag of the UDO whose volumes are to be edited. |
| double | volumes [ ] | Input | The new volumes for the UDO. |
UF_UDOBJ_free_udo_data (view source)
Frees all of the data that was dynamically allocated to the address of
the UF_UDOBJ_all_data_s structure. This structure is populated with
data after a call by UF_UDOBJ_ask_udo_data .
int UF_UDOBJ_free_udo_data
UF_UDOBJ_all_data_p_t all_data
| UF_UDOBJ_all_data_p_t | all_data | Input | A structure previously populated by UF_UDOBJ_ask_udo_data. This function frees all the data dynamically allocated by that function. |
UF_UDOBJ_is_obj_linked_to_udo (view source)
Queries whether UDOs reference the specified NX object.
int UF_UDOBJ_is_obj_linked_to_udo
tag_t ug_tag,
logical * linked
| tag_t | ug_tag | Input | The tag of the NX object to query as to whether UDOs reference it or not. |
| logical * | linked | Output | TRUE = UDOs reference NX object FALSE = UDOs do not reference NX object. |
UF_UDOBJ_is_owned (view source)
Queries if an NX object has an owning link by a UDO.
int UF_UDOBJ_is_owned
tag_t obj_tag,
logical * owned
| logical * | owned | Output | TRUE = NX Object has an owning link to a UDO. FALSE = No owning link |
UF_UDOBJ_is_udo_feature (view source)
Inquires whether a feature is a UDO feature.
Internal & External
int UF_UDOBJ_is_udo_feature
tag_t feature_tag,
logical * is_udo_feature
| tag_t | feature_tag | Input | the feature to check |
| logical * | is_udo_feature | Output | TRUE if a UDO feature else FALSE |
UF_UDOBJ_log_udo_feature_for_update (view source)
Explicitly log the UDO feature for update. This may be called for edits that
do not implicitly log the UDO feature. UF_UDOBJ_edit_integers(), for example,
does not cause the UDO feature to be logged for update. If you consider the
UDO to be out of date, call this routine and then call UF_MODL_update().
Originally released in V16.0
int UF_UDOBJ_log_udo_feature_for_update
| tag_t | udo_feature_tag | Input | The UDO feature to log for update |
UF_UDOBJ_register_attn_pt_cb (view source)
Registers the attention point function (method) to call when the
UDOs with the input class identifier pass through the attention point
computation event. The attention point is a temporary display point
near an object that is used during particular NX events. For
example, during Info-->Object a temporary number is placed near the
object. NX calculates the location for the attention point
based on the primitives used in constructing the UDO.
int UF_UDOBJ_register_attn_pt_cb
UF_UDOBJ_attn_pt_f_t attn_pt_func
| UF_UDOBJ_attn_pt_f_t | attn_pt_func | Input | The function to invoke when UDOs for this class pass through attention point computations. |
UF_UDOBJ_register_delete_cb (view source)
Register's the delete function (method) to call when a UDO with a
type 2 or 3 linked object associated to the UDO passes through
delete. Objects associated to the UDO with a type 1 link do not
invoke the method because the UDO is deleted when its associated
object is deleted. Objects associated to a UDO with a UDO owning
link do not cause the method to be invoked because the associated
object can not be deleted directly.
The following restrictions apply:
. The callback routine must not call UF_MODL_update.
. No Features may be deleted from this callback.
. The work part must not be changed.
This callback should not call any functions that change the work or displayed
part. This includes functions that change the work part as part of their
operation, such as UF_PART_import.
int UF_UDOBJ_register_delete_cb
UF_UDOBJ_delete_f_t delete_func
| UF_UDOBJ_delete_f_t | delete_func | Input | The function to invoke when objects associated to UDOs in this class pass through delete. |
UF_UDOBJ_register_display_cb (view source)
Registers the display function (method) to call when the UDOs with
the input class identifier pass through the display event.
int UF_UDOBJ_register_display_cb
UF_UDOBJ_display_f_t display_func
| UF_UDOBJ_display_f_t | display_func | Input | The function to invoke when UDOs for this class pass through the display. |
UF_UDOBJ_register_edit_cb (view source)
Registers the function (method) which is invoked when editing this UDO.
int UF_UDOBJ_register_edit_cb
UF_UDOBJ_edit_f_t edit_func
UF_UDOBJ_register_fit_cb (view source)
Registers the fit function (method) to call when the UDOs with the
input class identifier pass through the fit into view event. NX
calculates the extents of clipping required based on the primitives
used in the UDO's construction.
int UF_UDOBJ_register_fit_cb
UF_UDOBJ_fit_f_t fit_func
| UF_UDOBJ_fit_f_t | fit_func | Input | The function to invoke when UDOs for this class pass through fit to the view display code. |
UF_UDOBJ_register_info_obj_cb (view source)
Registers the Info-->Object method to call when the UDOs with the
input class identifier are queried interactively in NX with the
Info-->Object menu option. It is safe to register a method in external
mode, but Info-->Object functionality is only available in internal
mode.
int UF_UDOBJ_register_info_obj_cb
UF_UDOBJ_info_obj_f_t info_object_method
| UF_UDOBJ_class_t | class_id | Input | The class identifier for which to register the Info-->Object method. |
| UF_UDOBJ_info_obj_f_t | info_object_method | Input | The method to use in interactive NX when you invoke Info-->Object on a UDO of this class. |
UF_UDOBJ_register_is_occurrenceable_cb (view source)
Registers the function (method) which determines if this UDO is occurrenceable.
int UF_UDOBJ_register_is_occurrenceable_cb
UF_UDOBJ_is_occurrenceable_f_t is_occurrenceable_func
UF_UDOBJ_register_screen_size_fit_cb (view source)
Registers the screen size fit function (method) to call when the UDOs with the
input class identifier pass through the add screen size objects to fit into view event.
"Screen Size Fit" applies to primitives whose size remains the same on the screen
regardless of the scale of the view. The size of other primitives on the screen
changes as the view scale changes. NX calculates the extents of clipping required
based on the screen size primitives used in the UDO's construction.
You should only call this function if your UDO contains geometry which can
participate in "Screen Size Fit." As of NX 8.0, this is only ScreenStandardText
and AbsoluteRotationScreenSizeText, which are available in class NX/Open class
UserDefinedObjects::UserDefinedObjectDisplayContext.
NX 8.0
int UF_UDOBJ_register_screen_size_fit_cb
UF_UDOBJ_screen_size_fit_f_t screen_size_fit_func
| UF_UDOBJ_screen_size_fit_f_t | screen_size_fit_func | Input | The function to invoke when UDOs for this class pass through add screen size objects to fit to the view display code. |
UF_UDOBJ_register_select_cb (view source)
Registers the select function (method) to call when the UDOs with
the input class identifier pass through the selection event. This UDO
callback informs NX of the extents of the UDO via the
display primitives, then NX's internal algorithms decide to
select the UDO or not. UF_UI_add_to_class_sel can be used to enable
the friendly name on the class selection dialog.
int UF_UDOBJ_register_select_cb
UF_UDOBJ_select_f_t select_func
| UF_UDOBJ_select_f_t | select_func | Input | The function to invoke when UDOs for this class pass through selection. |
UF_UDOBJ_register_suppress_cb (view source)
Registers the function (method) which is invoked when suppressing this UDO feature.
Note this method is not called unless you have a UDO FEATURE. Also it may not
get called when the system automatically suppresses the feature during update.
Also note the user should call UF_MODL_ask_suppress_feature() in their callback to
see if the input udo feature is currently getting suppressed or unsuppressed.
int UF_UDOBJ_register_suppress_cb
UF_UDOBJ_suppress_f_t suppress_func
| UF_UDOBJ_suppress_f_t | suppress_func | Input | The function to invoke when suppressing or unsuppressing the UDO feature. |
UF_UDOBJ_register_update_cb (view source)
Registers the update function (method) to call when the UDOs with
the input class identifier pass through the update event. The method is
called when a UDO with either a link type 1 or a link type 3
association to it passes through update. Link type 2 and the UDO
owning link do not invoke the method because objects associated to
UDOs with link type 2 and UDO owning links do not add the UDOs
to the update list, by definition.
While within the update callback, you may freely query the data
model. You may also edit the free form data areas in the UDO.
Additionally, you may display a dialog (in internal Open API) to
inform the NX user of the affect the edit may have on the
UDO.
Note that if an object you are linked to (with a type 1 or a type 3 link) is
deleted, the UDO update method will be called. If your update method does
nothing, you will remain linked to a condemned object, and you must take that
into account when you try to use the linked object. If you want, your update
method can loop over all linked objects, calling UF_OBJ_ask_status, if you
are linked to an object that has a status of UF_OBJ_CONDEMNED, then the update
method can decide what is the appropriate action to take.
. The update process must not be explicitly invoked again with UF_MODL_update.
int UF_UDOBJ_register_update_cb
UF_UDOBJ_update_f_t update_func
| UF_UDOBJ_update_f_t | update_func | Input | The function to invoke when UDOs for this class pass through update. |
UF_UDOBJ_set_owned_object_selection (view source)
Set the behavior of selection of owned objects for the UDO class. The
default selection mode is UF_UDOBJ_DONT_ALLOW_SELECTION. This means that an
owned object can not be selected independently.
Setting the selection of owned objects to UF_UDOBJ_ALLOW_SELECTION means that
if an owned object and the UDO are both selectable, selecting the owned object
will result in the owned NX Object being selected and Up One Level button
activated, in interactive selection. If the UDO is not selectable selection of
the owned object would still be possible.
You may want to set UF_UDOBJ_ALLOW_SELECTION when your UDO contains only one
owned object, and you want to inherit the characteristics of that object. For
instance if your owned object is a spline, which your UDO computes the knot
points for, you may want the spline to be selectable by modeling operations,
such as extrude. In this case you would set your UDO class to allow selection
of the owned object.
Even if UF_UDOBJ_ALLOW_SELECTION is set, the owned object is not eligible
to be selected interactively for deletion.
Originally released in V16.0.2
int UF_UDOBJ_set_owned_object_selection
UF_UDOBJ_owned_object_selection_t value
UF_UDOBJ_set_query_class_id (view source)
Set the behavior of querying the class id given the class name. The default
mode is UF_UDOBJ_DONT_ALLOW_QUERY_CLASS_ID. This means that if you call
UF_UDOBJ_ask_class_id_of_name with the UDO's class name, an error code will be
returned, and the class id returned will be 0. This mechanism is used to
help protect the integrity of a proprietary UDO.
Setting the query to UF_UDOBJ_ALLOW_QUERY_CLASS_ID means that given a class name,
you can find the class id. This mechanism is used to pass the class id
across multiple shared libraries.
int UF_UDOBJ_set_query_class_id
UF_UDOBJ_query_class_id_t value
UF_UDOBJ_set_user_warn_flag (view source)
Set the behavior of warning the user if a UDO of the given class is found
in a part, but the code implementing the methods for the UDO is not loaded.
The default action is to not warn the user. If the UDO author sets this flag
to TRUE, all UDO's of this class that are created will be marked so that the
user will be warned if the UDO methods have not been loaded, but a UDO of the
class is in the part. This warning will be issued to the listing window,
when the first object of the given class is retrieved. This warning will
only be given once per session.
This flag is set on every UDO object. Therefore for any part,
there may be a mixture UDO objects of a given class, some having this flag
set to TRUE and some objects having the flag set to FALSE. This is
particularly true since all UDO objects created before NX 3.0 will have this
flag set to FALSE. If the UDO methods for a class are not loaded, any one
UDO with this flag set to TRUE in a part is enough for the warning to be
issued to the listing window.
Originally released in NX 3.0
int UF_UDOBJ_set_user_warn_flag
logical value
| UF_UDOBJ_class_t | class_id | Input | The class of the UDO which is being set. |
| logical | value | Input | Should the user be warned if the UDO methods are not loaded? TRUE - the user will be warned FALSE - the user will not be warned. Note that the default if this routine is not called is FALSE. |
UF_UDOBJ_version_udo (view source)
Assigns an existing UDO to a new class id so that it can adopt the
callback/behaviors of the new class.
int UF_UDOBJ_version_udo
tag_t udo_tag,
| tag_t | udo_tag | Input | Tag of the UDO whose class you wish to change. |
| UF_UDOBJ_class_t | class_id | Input | The udo will now belong in this class. |
