uc1600 (view source)
Defined in: uf_ui.h
Obtain the key in of a text string.
Internal
1 = Back
2 = Cancel
3 = OK (Accept default )
5 = Data entered
8 = Disallowed state, unable to bring up dialog
int uc1600
const char * cue,
char str [ 133 ] ,
int * length
| const char * | cue | Input | Menu title (displayed on the cue line, maximum of 80 characters. |
| char | str [ 133 ] | Input / Output | On input the default value of the string, on output the string typed in. This should be declared as char str[133] in the calling program. |
| int * | length | Output | The length of the returned string in ca2. |
uc1601 (view source)
Defined in: uf_ui.h
Display a message box and wait for acknowledgement, if desired
A maximum of 132 characters can be displayed in cp1. An asterisk
may be used to indicate where cp1 should be split to continue on
another line when displaying to a message box. If you use an asterisk
when displaying to the Status Line, the asterisk is replaced by a hyphen.
Please avoid using format escape sequences in the cp1
character string. For example, the newline escape sequence (\n) can
cause an undesirable shift in the displayed text.
Internal
void uc1601
const char * message,
int option
| const char * | message | Input | The message to display. |
| int | option | Input | The display option: 0 = Display text to status line 1 = Display text to message box |
uc1603 (view source)
Defined in: uf_ui.h
This routine displays a selection menu list box. You can have a
maximum of 14 menu items in the list box. You can specify any one
of the list items to be the default by setting the value of parameter
ip2 to the desired list item. If you do not want a default list item, set
ip2 = 0 and the OK button will be greyed out. If you want menu list
item number 5 to be the default, then set ip2 = 5. Then menu item
response values start at 5 and end at 18. If you choose menu item 1,
then 5 is returned. If you select menu item 14, then 18 is returned.
Internal
1 = Back
2 = Cancel Operation
5-18 = The given menu item was selected
19 = Disallowed state, unable to bring up dialog
int uc1603
const char * title,
int default_item,
const char items [ ] [ 38 ] ,
int num_items
| const char * | title | Input | Menu title (displayed on the cue line, 80 characters maximum |
| int | default_item | Input | Specify default menu item, if ip2 = 0 then no default, and the OK button will not be enabled. The range of ip2 is 0..ip4. If you have 14 menu items and set ip2 = 14, then menu item 14 will be highlighted as the default. NOTE: Changing the focused menu item with Tab or Arrow key does not change the default menu item. Pressing the OK button (or MB2) will select the Default item, which may not be the item that has focus. |
| const char | items [ ] [ 38 ] | Input | String array containing the menu items. If you use a hyphen(s) "-", for one of your options, this creates a nonselectable separator line. We do not recommend using the asterisk character "" in menu prompts or menu options. |
| int | num_items | Input | The number of items in the items array. This must be <= 14. |
uc1605 (view source)
Defined in: uf_ui.h
Multiple selection menu
In internal mode, no defaults are set, and ia6 is initialized to zero.
Selecting numeric keypad #I sets ia6[I] to 1. Pressing Back exits the menu.
Internal
1 = Back
3 = OK
4 = Alternate Action
int uc1605
const char * cue,
int ip2,
int num_items,
int selected [ ]
| const char * | cue | Input | Menu title to display on the cue line. This is 80 characters maximum. |
| int | ip2 | Input | Unused. |
| const char | items [ ] [ 38 ] | Input | String array containing the menu items. |
| int | num_items | Input | Number of strings in the cp3 array. This may not exceed 14 menu items. |
| int | selected [ ] | Output | Selection Array, which should be dimensioned to num_items. if ir6[n] == 0, then cp3[n][38] was not selected. if ir6[n] == 1, then cp3[n][38] was selected. |
uc1607 (view source)
Defined in: uf_ui.h
Display keyboard entry menu and gets the integer response.
Internal
1 = Back
3 = OK - No user input
4 = OK with user input
int uc1607
const char * cp1,
const char cp2 [ ] [ 16 ] ,
int ip3,
int ia4 [ ] ,
int * ip5
| const char * | cp1 | Input | The message to display on the cue line, a maximum of 80 characters. |
| const char | cp2 [ ] [ 16 ] | Input | The menu list. |
| int | ip3 | Input | The number of items in the menu list, cp2, this must be less than or equal to 14. |
| int | ia4 [ ] | Input / Output | On input the initial parameter values. On output the modified parameter values. This should be an array with ip3 entries. These will be the values the user can modify. |
| int * | ip5 | Input | Unused. |
uc1608 (view source)
Defined in: uf_ui.h
Display a keyboard entry menu and obtain integer or real data.
This routine displays an entry menu with integers and reals. The two
arrays ia4[ip3] and ra5[ip3] are initialized with the default
parameters that you specify. Both of these arrays as well as array
ip6[ip3] and cp2[ip3][16] must be dimensioned to ip3. For example, if
you decide to use the maximum of 14 parameter values you would
dimension ia4[14], ra5[14], ip6[14], and cp2[14][16].
The array values of ip6[ip3] determine which menu entries are
doubles and which are integers. For example if you set ip6[7] = 1, you
are specifying the 8th menu entry to be double. This also means that
the eighth value of ra5 (ra5[7]) is used as the default value. The index
array value of ip6 maps to the index array values of ia4 and ra5
depending on whether you use an initial integer or double parameter
value. For example, if you specify four integers and then one double
you will get ra[4] as your first double, not ra[0].
The entry menu values always maintain the data type (double or int)
of the initialized default values. Therefore, if you enter a double value
into the entry menu where an integer was the default, the double is
converted to an integer by truncating the decimal portion of the
double. Similiarly, if you enter an integer where the default was a
double, the integer is converted to a double.
Note: If a real number containing more than 12 decimal places is
passed into this function, the underlying code will truncate it to
12 decimal places. This will then pass back a return a value of
4 (OK with user input) instead of the expected 3 (OK - No user input).
By truncating your real parameter to 12 or less decimal places before
calling this function, it will work as expected.
Internal
1 = Back
int uc1608
const char * cp1,
int ip3,
int ia4 [ ] ,
double ra5 [ ] ,
int ip6 [ ]
| const char * | cp1 | Input | Menu title to display on the cue line. This may be a maximum of 80 characters. |
| const char | cp2 [ ] [ 16 ] | Input | This is the array of menu items to display. |
| int | ip3 | Input | This is the number of items in the menu array, cp2. This is also the size of the integer and double arrays. |
| int | ia4 [ ] | Input / Output | On input these are the initial parameter values. On output these are the values as modified by the user. This must be an array dimensioned to [ip3]. |
| double | ra5 [ ] | Input / Output | On input these are the initial parameter values. On output these are the values as modified by the user. This must be an array dimensioned to [ip3]. |
| int | ip6 [ ] | Input | This is the variable type to use for each menu item. if ip6[n] is 0, then the item is an integer. If ip6[n] is 1, then the item is a double. If an item is marked as an integer, its default value comes from ia4, and its return value is in ia4. If an item is marked as a double, its default value comes from ra5, and its return value is in ra5. This parameter must also be dimensioned as [ip3]. |
uc1609 (view source)
Defined in: uf_ui.h
Display keyboard entry menu and obtain a real response.
Internal
1 = Back
int uc1609
const char * cp1,
int ip3,
double ra4 [ ] ,
int * ip5
| const char * | cp1 | Input | Menu title displayed on the cue line. This may be a maximum of 80 characters. |
| int | ip3 | Input | This is the number of items in the menu array, cp2. This is also the size of the double arrays. |
| double | ra4 [ ] | Input / Output | On input these are the initial parameter values. On output these are the values as modified by the user. This must be an array dimensioned to [ip3]. |
| int * | ip5 | Input | Unused |
uc1613 (view source)
Defined in: uf_ui.h
Display keyboard entry menu and obtain an integer, real or string
in response.
The displayed parameters can be any combination of integer, real, or
string values. The type of variable used for displaying the parameter
values are user input in array ip7.
Internal
1 = Back
int uc1613
const char * cp1,
int ip3,
int ia4 [ ] ,
double ra5 [ ] ,
char ca6 [ ] [ 31 ] ,
int ip7 [ ]
| int | ip3 | Input | This is the number of items in the menu array, cp2. This is also the size of the integer, character and double arrays. Must be less than or equal to 14. |
| char | ca6 [ ] [ 31 ] | Input / Output | On input these are the initial parameter values. On output these are the values as modified by the user. This must be an array dimensioned to [ip3][31]. |
| int | ip7 [ ] | Input | An array dimensioned to [ip3] which specifies the value type for each individual menu item. 100-199 - Indicates an integer value, which will be returned in ia4[] 200-299 - Indicates a double value which will be returned in ra5[] 300-399 - Indicates a character string value which will be returned in ca6[] |
uc1615 (view source)
Defined in: uf_ui.h
Display the user message (cue) and returns a screen
position point in parameter point (X,Y,Z) on the WCS plane in
Absolute Coordinates of the Displayed Part. A typical user message
might be "Pick a point."
Response Returned
1 = Back
2 = Cancel
5 = Position Returned
7 = No Active Part
Internal
int uc1615
const char * cue,
double point [ 3 ]
| const char * | cue | Input | User Message (80 char max) |
| double | point [ 3 ] | Output | Point Picked |
uc1616 (view source)
Defined in: uf_ui.h
Display a user message and return a point from the Point
Subfunction in Absolute Coordinates of the current Work Part.
The returned coordinates are always relative to the current work view.
Response Returned
1 = Back
2 = Cancel
7 = No Active Part
Internal
The ia2[0] parameter was modified in V13.0 to
return a value of 12 for a quadrant point.
int uc1616
const char * cue,
int mode [ 2 ] ,
int point_display_mode,
double point [ 3 ]
| const char * | cue | Input | User Message (40 char max) |
| int | mode [ 2 ] | Input / Output | On input the default selection type and offset mode. On output the selection type and offset mode used. [0] Selection Type 0 = Show Menu For User Selection (Inferred) 1 = Cursor Location 2 = This value is ignored. 3 = This value is ignored. 4 = Existing Point 5 = End Point 6 = Control Point 7 = Intersection Point 8 = Arc/Ellipse/Sphere Center 9 = Pos On Arc/Ellipse 10 = This value is ignored. 11 = Intersection Point 12 = Quadrant Point 13 = Point on curve/Edge 14 = Point on Surface 15 = Point Between Points 16 = Cursor Location 17 = This value is ignored. [1] Offset Mode 0 = No Offset 1 = Rect Abs 2 = This value is ignored. 3 = Cylindrical 4 = Spherical 5 = 3D Vector 6 = 3D Vector |
| int | point_display_mode | Input | Temporary Point Display 0 = Display Temporary Points 1 = Do Not Display Temporary Points |
| double | point [ 3 ] | Output | Point Picked (x,y,z). This is only returned if the return code is 5. |
uc1617 (view source)
Defined in: uf_ui.h
uc1617 object select with class selection menu
Use UF_UI_select_with_class_dialog instead.
int uc1617
const char * cp1,
int ip2,
tag_t * nr3,
int * ir4,
double * rr5
| const char * | cp1 | Input | |
| int | ip2 | | |
| tag_t * | nr3 | | |
| int * | ir4 | Input | |
| double * | rr5 | | |
uc1618 (view source)
Defined in: uf_ui.h
uc1618 simple object select. Use UF_UI_select_with_single_dialog instead.
int uc1618
const char * cp1,
int ip2,
tag_t * nr3,
int * ir4,
double * rr5
| int | ip2 | | |
| tag_t * | nr3 | | |
uc1630 (view source)
Defined in: uf_ui.h
Interactively choose a CSYS. Though 40 characters are allowed in the title,
it should be noted that the first option (ORIGIN,X-PT,Y-PT) appends the point
number (PT1, PT2, and PT3) on the end of the message. Thus, only 36
characters are effectively allowed.
Users Response
1 = Back
2 = Cancel
3 = OK
7 = No Active Part
Internal
int uc1630
const char * title,
int * option,
double csys_matrix [ 9 ] ,
double origin [ 3 ]
| const char * | title | Input | Menu Title (40 char max) |
| int * | option | Input / Output | On input the default CSYS Option. On output the CSYS option used. 0 = Origin, X-pt, Y-pt 1 = X-axis, Y-axis 2 = X-pt, Z-axis 3 = CSYS Of Arc/Conic 4 = WCS 5 = Offset CSYS 6 = Absolute CSYS 7 = Current View 8 = Drafting Object 9 = X-axis, Y-axis, Origin 10 = Point, Perpendicular Curve 11 = WCS 12 = Plane and Vector 13 = Three Planes 14 = Origin, X-pt, Y-pt 15 = Dynamic |
| double | csys_matrix [ 9 ] | Output | CSYS Matrix (9 element array) - relative to Absolute CSYS of Displayed Part |
| double | origin [ 3 ] | Output | Origin Of CSYS (3 element array) - relative to Absolute CSYS of Displayed Part |
uc1652 (view source)
Defined in: uf_ui.h
Selects a view.
For modeling views only. If the current layout is a drafting layout,
the dialog will not come up and the return code will be 8.
Return Code
0 = OK, View Selected
1 = Back
2 = Cancel
3 = OK, No View Selected
Internal
int uc1652
const char * title,
char view_name [ UF_OBJ_NAME_BUFSIZE ]
| const char * | title | Input | Menu Title (122 char max) |
| char | view_name [ UF_OBJ_NAME_BUFSIZE ] | Output | View Name (UF_OBJ_NAME_NCHARS char max) |
uc1653 (view source)
Defined in: uf_ui.h
Returns the name of view in which the last screen pick occurred
(either Interactive NX or Internal Open C API - uc1615, uc1616,
uc1617, uc1618 or GRIP). If the view of the last position indication
was removed from the current layout, the work view is returned.
Using the matrix from the view (uc6433 - Read View Matrix) can
help the determine which end of a curve was picked, etc.
Internal
int uc1653
UF_UI_add_to_class_sel (view source)
Defined in: uf_ui_ugopen.h
Adds the friendly name associated with the class name of a User
Defined Object (UDO) to the Type list of the class selection dialog.
The class becomes selectable.
int UF_UI_add_to_class_sel
unsigned int class_id
| unsigned int | class_id | Input | The identifier of the class. |
UF_UI_add_to_sel_list (view source)
Defined in: uf_ui.h
Add objects to the selection list.
Any objects already in the selection list are ignored.
You can use this function with UIStyler dialogs and with the
UF_UI_select_with_class_dialog function. You can call
UF_UI_add_to_sel_list from the constructor callback/selection
initialization procedure to begin the dialog with objects already
selected. The user can then review these objects, and if desired,
deselect them.
The application selection callback can also call this function to add
other objects to the selection list based on the objects(s) just selected.
The selection filter procedure cannot call this function. You cannot
use this function with UF_UI_select_with_single_dialog.
Based on the object(s) just selected, other objects may need to be
selected. For example, all edges of the selected face or all faces
tangent to the selected face.
Internal
Original release was in V13.0.
int UF_UI_add_to_sel_list
UF_UI_selection_p_t select_,
int num,
tag_t * objs,
logical highlight_flag
| UF_UI_selection_p_t | select_ | Input | Selection pointer |
| int | num | Input | Number of objects to add to selection |
| tag_t * | objs | Input | Array of object tags. |
| logical | highlight_flag | Input | if true, highlight objects |
UF_UI_allow_non_work_part_feature_selection (view source)
Defined in: uf_ui.h
Allows selection of features belonging to any fully loaded part. By default,
only features belonging to the Work Part are selectable.
For UIStyler dialogs, this function should be called from the initialize_cb.
For use with UF_UI_select_with_class_dialog or UF_UI_select_with_single_dialog,
this function should be called from the init_proc (UF_UI_sel_init_fn_t).
Note that features not belonging to the Work Part can be queried, but should
not be edited in any way.
Internal
int UF_UI_allow_non_work_part_feature_selection
void* select_,
logical allow
| void* | select_ | Input | selection pointer |
| logical | allow | | |
UF_UI_append_menubar_menu (view source)
Defined in: uf_ui.h
Appends a menu item to the NX menu bar. Once a menu is
defined as an array of UF_UI_menubar_item_t, the custom
application should call UF_UI_append_menubar_menu() from the
user exit ufsta().
Once this routine is called, an Open C API license is captured and
not released until NX is exited.
A program which uses UF_UI_append_menubar_menu should not
use the option to unload an Open C API image. Additionally, if
your code which defines UF_UI_append_menubar_menu itself
loads a shared library, this code should not attempt to unload the
library. NX always makes a strong attempt to prevent
unloading a library which was loaded by using UF_UI_append_menubar_menu.
The USER_STARTUP (ufsta) user_exit was developed exclusively
to work in conjunction with UF_UI_append_menubar_menu to
define menus. If you use this routine it must be called early (i.e.
prior to complete initialization of NX).
This requirement makes the use of the USER_STARTUP exit
inappropriate for any purpose other than calling
UF_UI_append_to_menubar. In particular, running a GRIP
program, opening a part file, etc. from the shared library pointed to
by the USER_STARTUP environment variable does not work
because NX initialization has not yet completed at the
time this library is loaded.
NOTE: This function is only available on Unix. Please look at
menuscript for this functionality on Windows.
Internal
int UF_UI_append_menubar_menu
UF_UI_menubar_item_t * menu,
UF_UI_change_state_fn_t change_state,
char * application_name
| UF_UI_menubar_item_t * | menu | Input | Array of UF_UI_menubar_item_t structures. This array defines the menu item, its pulldown and cascade pulldown to be appended to the NX menu bar. |
| UF_UI_change_state_fn_t | change_state | Input | Custom supplied change state function to be registered for the application. If change_state is NULL then a change state function can be registered later using UF_UI_register_change_state_fn. |
| char * | application_name | Input | Application name that pairs with the registered change state function. |
UF_UI_ask_create_part_filename (view source)
Defined in: uf_ui.h
Displays the File-->New File Selection Dialog.
Internal
int UF_UI_ask_create_part_filename
char file_name [ MAX_FSPEC_BUFSIZE ] ,
int * units,
int * response
| char | file_name [ MAX_FSPEC_BUFSIZE ] | Input / Output | On input default file name to use for part creation dialog. On output the filename actually used. |
| int * | units | Input / Output | On input part units to use for part creation dialog. On output the units actually used. UF_PART_METRIC UF_PART_ENGLISH NONE = uses default |
| int * | response | Output | User response from dialog: UF_UI_OK UF_UI_CANCEL |
UF_UI_ask_cursor_view (view source)
Defined in: uf_ui.h
Reads the current mask for selection within views. Object selection can
be made in the work view on a drawing layout only or any view, and this
routine returns the current value.
In drafting, the default is the work view so use UF_UI_set_cursor_view
if you want to select in any view.
Internal
int UF_UI_ask_cursor_view
int * cursor_view
| int * | cursor_view | Output | The current cursor view: 0 = Any view 1 = Work view |
UF_UI_ask_dialog_directory (view source)
Defined in: uf_ui.h
Reads the directory path of a given dialog.
Internal
int UF_UI_ask_dialog_directory
UF_UI_dialog_dir_id_t dir_index,
char * * dir_name
| UF_UI_dialog_dir_id_t | dir_index | Input | Enumeration constant of the dialog. |
| char * * | dir_name | Output to UF_*free* | Directory path of the dialog. This must be freed by calling UF_free. |
UF_UI_ask_dialog_filter (view source)
Defined in: uf_ui.h
Reads the filter extension of the current dialog.
Internal
int UF_UI_ask_dialog_filter
UF_UI_dialog_filter_id_t dir_index,
char * * fltr_name
| UF_UI_dialog_filter_id_t | dir_index | Input | Enumeration constant of the dialog. |
| char * * | fltr_name | Output to UF_*free* | Filter extension of the dialog. |
UF_UI_ask_global_sel_object_list (view source)
Defined in: uf_ui.h
This function will ask for the objects that are on the global selection list
Internal
Added in NX2
int UF_UI_ask_global_sel_object_list
int * num_objects,
tag_t * * objects
| int * | num_objects | Output | |
| tag_t * * | objects | Output to UF_*free* | Array of tags containing the selected objects. This array must be freed by calling UF_free. |
UF_UI_ask_info_units (view source)
Defined in: uf_ui.h
Inquires what units the user would like information displayed in.
These are the units used to display results in the Info functions.
The units are only used for displaying results in Info and do not
necessarily correspond to the part units or the units used in other
Open C API functions.
int UF_UI_ask_info_units
int * units
| int * | units | Output | Current units: UF_UI_POUNDS_INCHES UF_UI_POUNDS_FEET UF_UI_GRAMS_MILLIMETERS UF_UI_GRAMS_CENTIMETERS UF_UI_KILOS_METERS UF_UI_KILOS_MILLIMETERS UF_UI_DEFAULT_UNITS (same as the default units for data entry) |
UF_UI_ask_iw_decimal_places (view source)
Defined in: uf_ui.h
Inquires the information window (listing window) real number display
preference and number of decimal places to display.
UF_UI_SYSTEM_DECIMAL_PLACES means the user has
requested the system precision to be used for formatting real numbers
for the information window. In this case, the number of decimal
places varies based on each real value, such that the sum of the
number of places before and after the decimal point equals the
number of significant digits of double precision floating point accuracy
that can be represented on the client machine. The decimal_places
parameter should not be used when this mode is set.
UF_UI_USER_DECIMAL_PLACES means the user has asked for a
specific number of decimal places. The decimal_places parameter is
only valid with this mode.
int UF_UI_ask_iw_decimal_places
int * mode,
int * decimal_places
| int * | mode | Output | Current preference: UF_UI_SYSTEM_DECIMAL_PLACES UF_UI_USER_DECIMAL_PLACES |
| int * | decimal_places | Output | Number of user defined decimal places. |
UF_UI_ask_lock_status (view source)
Defined in: uf_ui.h
Query NX lock status.
This function is useful when dismissing a custom dialog and you want
to determine whether or not a lock has been set. If a lock has been set
then you know you need to call UF_UI_cancel_uf_dialog in order to
cancel the currently displayed Open dialog or UIStyler dialog.
NOTE: If an NX's owned DA2 is currently displayed when this
check is done then UF_UI_ask_lock_status returns UF_UI_LOCK.
When your custom application attempts to cancel this dialog,
UF_UI_cancel_uf_dialog returns an error. This failure does not cause
any problems, and you should continue using this method in order to
cancel any potential Open dialogs that are currently displayed.
UF_UI_LOCK when NX is in lock status.
UF_UI_UNLOCK when NX is in unlock status.
Internal
int UF_UI_ask_lock_status
UF_UI_ask_minimal_graphics_window (view source)
Defined in: uf_ui.h
This function return information if NX graphics window special minimal mode is on or off
Privileged
Added in NX7.5.2
int UF_UI_ask_minimal_graphics_window
logical* is_set
UF_UI_ask_open_part_filename (view source)
Defined in: uf_ui.h
Displays the File-->Open File Selection Dialog.
Internal
NX1 - "use_disp_file" parameter is obsolete; left in interface
for forward compatibility and changed name to "unused"
int UF_UI_ask_open_part_filename
logical * unused,
int * response
| char | file_name [ MAX_FSPEC_BUFSIZE ] | Input / Output | On input default part name to use for part open dialog. On output the name of the part to open. |
| logical * | unused | Input | Parameter no longer used; left for forward compatibility |
UF_UI_ask_ribbon_vis (view source)
Defined in: uf_ui.h
This routine returns the current visibility of the given ribbon tab. This function
only applies to ribbon tabs; for groups, galleries, cascades, and dropdowns the
result is undefined.
Internal
Originally released in NX9.0
int UF_UI_ask_ribbon_vis
UF_UI_ribbon_id_t ribbon_id,
int* show
| UF_UI_ribbon_id_t | ribbon_id | Input | Valid Ribbon id from a call to UF_UI_create_ribbon |
| int* | show | Output | 1 = show; 0 = hide |
UF_UI_ask_sel_cursor_pos (view source)
Defined in: uf_ui.h
Returns the view and absolute coordinates of the cursor position for
the associated selection.
If an object was selected, the view returned is the view in which the
object was selected. For single position, the view is the view of the
cursor.
If the object was selected by name, view = NULL_TAG and the
cursor position are undefined.
Internal
int UF_UI_ask_sel_cursor_pos
tag_t * view,
double abs_cursor_pos [ 3 ]
| tag_t * | view | Output | View |
| double | abs_cursor_pos [ 3 ] | Output | absolute coordinates of the cursor position |
UF_UI_ask_sel_descriptor (view source)
Defined in: uf_ui.h
Returns a bitmask of information describing the selection that was just
performed.
The valid bits which can be examined are defined in this header file.
UF_UI_SEL_DESC_SELECTION
UF_UI_SEL_DESC_DESELECTION
UF_UI_SEL_RESELECTION
UF_UI_SEL_DESC_SINGLE
UF_UI_SEL_DESC_MULTIPLE
UF_UI_SEL_DESC_SINGLE_POSITION
UF_UI_SEL_DESC_RECTANGLE_POSITION
UF_UI_SEL_DESC_NAME_SELECTION
Multiple bits may be set. For example, for a rectangle deselection, the
DESELECTION, MULTIPLE, and RECTANGLE bits would be set.
For a name selection which selected one object, the SELECTION,
SINGLE, and NAME_SELECTION bits would be set.
If a reselect was done (an object is selected and the previous object
selected is deselected), only the RESELECTION bit is set.
The SINGLE and MULTIPLE bits are not set for position.
The RECTANGLE bit is set for rectangle selection, rectangle
deselection, and rectangle position.
You use this function with UIStyler dialogs and
UF_UI_select_by_class and can be called from either the selection
filter procedure or the selection callback.
Internal
int UF_UI_ask_sel_descriptor
int * descriptor
| int * | descriptor | Output | bit mask describing the selection |
UF_UI_ask_sel_list_count (view source)
Defined in: uf_ui.h
Returns the number of objects currently selected.
UF_UI_select_with_class_dialog.
Internal
int UF_UI_ask_sel_list_count
int * count
UF_UI_ask_sel_object_list (view source)
Defined in: uf_ui.h
Returns the number of objects selected and a pointer to an array of
tags of the objects selected.
You can use this function with the UIStyler dialogs and with
Internal
int UF_UI_ask_sel_object_list
int * count,
tag_p_t * objs
| int * | count | Output | Count of objects selected |
| tag_p_t * | objs | Output to UF_*free* | Allocated array of the tags of the selected objects. Must be freed with UF_free after use. |
UF_UI_ask_sel_rectangle_pos (view source)
Defined in: uf_ui.h
Returns the absolute coordinates of the rectangle cursor positions.
The view that returns is the view of the button down position.
button down position - is the position where you press and hold mouse button 1.
button up position - is the position where you release mouse button 1.
Pos1 and Pos2 are the absolute coordinates of the button down and
button up positions respectively. Pos3 is the absolute coordinates of
the rectangle corner which, as viewed on the screen, is horizontal with
pos1. Pos4 is the absolute coordinates of the rectangle corner which,
as viewed on the screen, is horizontal with pos2.
Returns an error if the last gesture was not rectangle.
Internal
int UF_UI_ask_sel_rectangle_pos
tag_t * view,
double pos1 [ 3 ] ,
double pos2 [ 3 ] ,
double pos3 [ 3 ] ,
double pos4 [ 3 ]
| tag_t * | view | Output | View of button down position |
| double | pos1 [ 3 ] | Output | Absolute coordinates of the button down position |
| double | pos2 [ 3 ] | Output | Absolute coordinates of the button up position |
| double | pos3 [ 3 ] | Output | Absolute coordinates of corner of screen rectangle which is horizontal with button down position |
| double | pos4 [ 3 ] | Output | Absolute coordinates of corner of screen rectangle which is horizontal with button up position |
UF_UI_ask_toolbar_vis (view source)
Defined in: uf_ui.h
This routine returns the current visibility of the given toolbar.
Internal
Originally released in V16.0
int UF_UI_ask_toolbar_vis
UF_UI_toolbar_id_t tool_id,
int* show
| UF_UI_toolbar_id_t | tool_id | Input | Valid Toolbar id from a call to UF_UI_create_toolbar |
UF_UI_cancel_uf_dialog (view source)
Defined in: uf_ui.h
Cancels the existing custom application dialog area 2 by sending a
cancel message.
UF_UI_SUCCESS when dialog area 2 is cancelled successfully or there
is not DA2 displayed
UF_UI_FAILURE when dialog area 2 is not cancelled.
Dialog area 2 is not cancelled when the current dialog area 2 is not
an interactive Open C API dialog.
The custom application can only bring up a new interactive Open C
API dialog when UF_UI_cancel_uf_dialog returns a
UF_UI_SUCCESS. The new interactive Open C API must be
brought up with an XtAppAddTimeOut call. Failure to follow the
above guideline can give unpredictable results.
Use UF_UI_cancel_uf_dialog for action buttons which are always
available and that call interactive Open C API (i.e. the action
button is not greyed out or ungreyed in the custom supplied state
change function).
Internal
int UF_UI_cancel_uf_dialog
int from_where
| int | from_where | Input | Predefined constant used to support error checking. This should always be UF_UI_FROM_CUSTOM for custom applications. |
UF_UI_close_listing_window (view source)
Closes the listing window. If in internal Open API, the window is
closed. If in external Open API, then the device is set to closed.
For V15.0, this function was modified so that it closes the window but
does not clear the windows contents. Prior to V15.0, this function
closed and cleared the window in Internal Open API.
int UF_UI_close_listing_window
UF_UI_create_filebox (view source)
Defined in: uf_ui.h
Create an File Selection Box dialog.
Internal
int UF_UI_create_filebox
char * prompt_string,
char * title_string,
char filter_string [ MAX_FSPEC_BUFSIZE ] ,
char * default_name,
char filename [ MAX_FSPEC_BUFSIZE ] ,
int * response
| char * | prompt_string | Input | Text for standard prompt. |
| char * | title_string | Input | The dialog title. |
| char | filter_string [ MAX_FSPEC_BUFSIZE ] | Input / Output | The initial value of filter_string is used to initialize the Filter list and text field. If it contains only the pattern and not the path, then "/current_dir/pattern" is used for the filter. If it contains only the path and not the pattern, then "\path\" is used for the filter. If the path doesn't exist,"\current_dir\" is used for the filter. On Unix when OK is selected from the FSB dialog, the filter_string is the complete path+pattern of the filter. On NT, the FSB dialog doesn't have a filter edit box. Therefore, when OK is selected, the returned filter_string is always set to the folder + '' + extension of the selected file. The user must allocate a buffer big enough to hold the maximum possible file filter_string, which is MAX_FSPEC_BUFSIZE bytes. This function does not support multiple patterns. |
| char * | default_name | Input | The default name is used to initialize the Selection text field. If it's an empty string or NULL string, the Selection text field is set to the current directory. |
| char | filename [ MAX_FSPEC_BUFSIZE ] | Output | When OK is selected from the FSB dialog, filename is whatever was typed into the Selection field. Usually, it is a complete path+name if the string is automatically set by clicking on one of the files in the filter list. Note: An error message displays if no filename is entered; even if there is a directory path in the selection field. It is caller's responsibility to allocate enough memory for the filename string. |
| int * | response | Output | UF_UI_OK: OK was selected UF_UI_CANCEL: CANCEL was selected |
UF_UI_create_filebox_with_multiple_filters (view source)
Defined in: uf_ui.h
This will creates a File Selection Box dialog which also supports multiple file selection filters.
0 = No error
!= 0 = Error code
Internal
int UF_UI_create_filebox_with_multiple_filters
char* prompt_string,
char* title_string,
char* * file_extensions,
int num_extensions,
int* response
| char* | prompt_string | Input | Text for standard prompt. |
| char* | title_string | Input | The dialog title. |
| char* * | file_extensions | Input | Caller has to supply the list of file extension strings. The elements of the list will decide which type of files need to be displayed in the selection dialog box for selection. The file extensions should be in the format ".XXX". E.g ".prt", ".sim", ".dat" etc. |
| int | num_extensions | Input | The variable will provide the size of the file extensions list. It should not be more than 32. |
| int* | response | Output | UF_UI_OK: OK was selected UF_UI_CANCEL: CANCEL was selected |
UF_UI_create_part (view source)
Defined in: uf_ui.h
Creates a part and makes it the work part using the File-->New File
Selection Dialog.
Note: This function will not work when using TCIN (NXManager). To create a new
part for for that mode, call UF_UI_ugmgr_ask_create_part_name followed by
UF_UGMGR_new_part_from_template.
Internal
int UF_UI_create_part
const UF_UI_err_p_t error_fn,
int * units,
tag_t * part,
int * response
| const UF_UI_err_p_t | error_fn | Input | Pointer to data structure and user-defined error handling function. |
| char | file_name [ MAX_FSPEC_BUFSIZE ] | Input / Output | On input the default part name to use for the part open dialog. On output the name of the part to open |
| int * | units | Input / Output | On input the part units to use for part creation dialog, UF_PART_METRIC or UF_PART_ENGLISH. On output the units of the newly created part. |
| tag_t * | part | Output | Pointer to tag of newly created part (only valid if response = UF_UI_OK) |
UF_UI_create_ribbon (view source)
Defined in: uf_ui.h
Creates a ribbon from the given .rtb/.gly/.grb file. The file name should not have
any hard coded path and should exist in one of the Open application
directories. The show parameter is only used to show or hide the ribbon
when it is loaded for the first time. On all subsequent loads, the show/hide
value as recorded in the users registry is used.
In order to be successfully loaded, the .rtb/.gly/.grb file must be located in the
application subdirectory of one of the directories listed in the file
pointed to by UGII_CUSTOM_DIRECTORY_FILE, which defaults to
$UGII_BASE_DIR/ugii/menus/custom_dirs.dat.
Example:
UF_UI_ribbon_id_t id = NULL;
error = UF_UI_create_ribbon("my.rtb", 1, &id);
Internal
int UF_UI_create_ribbon
char* file_name,
int show,
UF_UI_ribbon_id_t * ribbon_id
| char* | file_name | Input | The .rtb/.gly/.grb file name without any hard coded path |
| int | show | Input | Initial visibility of the ribbon (1 = show; 0 = hide) |
| UF_UI_ribbon_id_t * | ribbon_id | Output to UF_*free* | ribbon id if creation is successful |
UF_UI_create_toolbar (view source)
Defined in: uf_ui.h
Creates a toolbar from the given .tbr file. The file name should not have
directories. The show parameter is only used to show or hide the toolbar
In order to be successfully loaded, the .tbr file must be located in the
Example:
UF_UI_toolbar_id_t id = NULL;
error = UF_UI_create_toolbar("my.tbr", 1, &id);
Internal
int UF_UI_create_toolbar
char* file_name,
int show,
UF_UI_toolbar_id_t * tool_id
| char* | file_name | Input | The .tbr file name without any hard coded path |
| int | show | Input | Initial visibility of the toolbar (1 = show; 0 = hide) |
| UF_UI_toolbar_id_t * | tool_id | Output to UF_*free* | Toolbar id if creation is successful |
UF_UI_create_usertool (view source)
Defined in: uf_ui.h
Loads a User Tool dialog. This function replaces previously loaded definitions.
Information on user tools can be found in the NX documentation under
System administration -> Customizing the NX installation.
Internal
int UF_UI_create_usertool
int tool_num,
char * filename,
logical map_flag,
logical * read_flag
| int | tool_num | Input | Number of tool to load |
| char * | filename | Input | Pointer to tool definition file specification name (132 char max) |
| logical | map_flag | Input | String defined flag: UF_UI_SHOW = Display tool UF_UI_HIDE = Do not display tool |
| logical * | read_flag | Output | Syntax error flag: TRUE = Syntax error FALSE = No syntax error for file read |
UF_UI_delete_from_class_sel (view source)
Defined in: uf_ui.h
Removes the friendly name associated with the class name of a User
Defined Object (UDO) from the Type list of the class selection dialog.
The class becomes nonselectable.
Internal
int UF_UI_delete_from_class_sel
UF_UI_disable_quick_access (view source)
Defined in: uf_ui.h
Quick Access Menus, provides for enabling global functions and special
functions in many instances where they were previously greyed out.
This is done by
providing an automatic cancel feature when these menu items are chosen.
The two most common cases are:
- with a special function dialog open, Quick Access Menus will allow
a different special function to be chosen. The original special
function is canceled and replace by the new one.
- With a tool palette open in DA1 and one of its dialogs in DA2,
you can now choose another tool palette or global function from the
menubar. The DA2 will be canceled, and the DA1 wll be replaced by the
the new DA1.
The Quick Access Menus feature may not work correctly with some
applications written that directly use Motif dialogs, use certain
User Function dialogs or which provide a confirmation step when
a dialog is canceled.
To disable Quick Access Menus in your application, call
UF_UI_disable_quick_access in your application's enter routine
and UF_UI_enable_quick_access in your application's exit
routine.
Internal
V12
int UF_UI_disable_quick_access
UF_UI_dismiss_dialog_area_2 (view source)
Defined in: uf_ui.h
Dismisses the interactive Open C API dialog after you select
cancel.
You use this routine after a call to any Open C dialog if it is not wrappered
with UF_UI_lock_ug_access and UF_UI_unlock_ug_access. This call guarantees that
the Open dialog is dismissed when the user select's one of its navigation
buttons.
Calling this function after an Open dialog has been displayed when it is not
needed should not cause any negative side affects.
This function is not needed after a UIStyler dialog has been displayed.
Below is an example of UF_UI_dismiss_dialog_area_2. This creates a
custom dialog via UF_UI_run_dialog that only has a pulldown item in
it called File. File has two pulldown items: Selection and Quit. The
Selection item launches UF_UI_select_by_class. The lock wrappers
are used to wrapper the start of the custom dialog and the end.
Because of this location of the lock wrappers it is necessary to call
This function
Returns
UF_UI_SUCCESS when dialog area 2 is dismissed successfully.
UF_UI_FAILURE when dialog area 2 is not dismissed. Dialog
area 2 is not dismissed when the current dialog area 2 is not
an interactive Open C API dialog or there is no DA2 displayed.
Internal
int UF_UI_dismiss_dialog_area_2
UF_UI_display_nonmodal_msg (view source)
Defined in: uf_ui.h
Displays a nonmodal Message Dialog with an OK button. A message
box displays with the character string inputted through the message
argument. The character string message is written to the syslog. You
can call this routine multiple times to display more than one message
dialog. While the message dialog displays, your Open C API
program continues to execute. You can dismiss the dialog box by
clicking the OK button only after your program finishes its execution.
Internal
int UF_UI_display_nonmodal_msg
char * message,
int pos_method
| char * | title_string | Input | Dialog title string |
| char * | message | Input | The message string to be displayed in the Message Dialog. Use "\n" within the string if multiple lines are desired. |
| int | pos_method | Input | Position method: UF_UI_MSG_POS_CURSOR = the dialog's OK button will be under the mouse cursor. UF_UI_MSG_POS_CASCADE = the dialog will be positioned diagonally accross the screen relative to other non-modal message dialogs. UF_UI_MSG_POS_BOTTOM_RIGHT = the dialog will be positioned at the bottom right corner of the graphics window. UF_UI_MSG_POS_TOP_LEFT = the dialog will be positioned at the top left corner of the screen. |
UF_UI_display_url (view source)
Defined in: uf_ui.h
Displays the specified URL in the NX internal web browser if it is available,
or otherwise in the user's defined default web browser.
Internal
Originally added in v19.0
int UF_UI_display_url
const char * url
| const char * | url | Input | Pointer to URL to display. |
UF_UI_display_url_and_activate (view source)
Defined in: uf_ui.h
Displays the specified URL in the NX internal web browser, bringing it to the
front if it is available. Otherwise displays in the user's defined default
web browser.
Internal
Originally added in NX 8.5
int UF_UI_display_url_and_activate
const char * url
UF_UI_display_usertool (view source)
Defined in: uf_ui.h
Displays or removes the specified User Tool dialog from the screen.
The only valid tool_num is 0. Closes and clears the listing window.
Internal
This function was originally released in V15.0.
int UF_UI_display_usertool
int tool_num,
logical map_flag
| int | tool_num | Input | Number of tool to display or remove |
| logical | map_flag | Input | String defined flag: UF_UI_SHOW = Display tool UF_UI_HIDE = Remove display of tool |
UF_UI_enable_quick_access (view source)
Defined in: uf_ui.h
Quick Access Menus, provides for enabling global functions and special functions
in many instances where they were previously greyed out. This is done by
the new DA1.
routine.
Internal
V12
int UF_UI_enable_quick_access
UF_UI_exit_listing_window (view source)
Closes and clears the listing window. If in internal Open API,
the window is closed and cleared. If in external Open API, the
int UF_UI_exit_listing_window
UF_UI_get_DA1_coords (view source)
Defined in: uf_ui.h
Retrieves the coordinates of the Dialog Area 1 window.
This function retrieves the current position of DA1.
Therefore, if the user has moved the DA1 dialog then these new
coordinates are the ones retrieved.
Internal
int UF_UI_get_DA1_coords
short * x,
short * y
| short * | x | Output | DA1 x-coordinate |
| short * | y | Output | DA1 y-coordinate |
UF_UI_get_DA2_coords (view source)
Defined in: uf_ui.h
Retrieves the coordinates of the Dialog Area 2 window. This API
returns UF_UI_SUCCESS if everything goes fine, otherwise, use
UF_get_fail_message to determine the exact cause of the failure.
NOTE: This function retrieves the current position of DA2.
Therefore, if the user has moved the DA2 dialog then these new
Internal
int UF_UI_get_DA2_coords
short * x,
short * y
| short * | x | Output | DA2 x-coordinate |
| short * | y | Output | DA2 y-coordinate |
UF_UI_get_default_parent (view source)
Defined in: uf_ui.h
Retrieves the window to be used as the parent of any user defined dialogs in
NX. This way the user defined dialog physically behaves as though
it is one of NX's dialog. For example it is not able to hide behind
the graphics window and it iconifies when NX is iconified.
This routine returns a void pointer which is the
Window to be used as the parent of user defined dialogs.
On Unix you must type cast this to a Widget. On NT you
must type cast this to an HWND.
Internal
This is a
code fragment showing the essence of how to use this function on Unix.
void * UF_UI_get_default_parent
UF_UI_init_attachments (view source)
Defined in: uf_ui.h
Initialize the attachments structure.
Internal
int UF_UI_init_attachments
UF_UI_attachment_p_t attach
UF_UI_is_listing_window_open (view source)
Queries whether the Information window is open or closed. This
function returns a value of FALSE if the Information window:
has never been opened, has been closed with File-->Exit, File-->Close,
has been closed by a call to UF_UI_close_listing_window or by selecting
the Information button.
int UF_UI_is_listing_window_open
logical * response
| logical * | response | Output | Response flag: TRUE = Window is open FALSE = Window is closed |
UF_UI_is_object_in_sel_list (view source)
Defined in: uf_ui.h
Inquires if object is selected.
You use this function with dialogs created with the UIStyler and with
the UF_UI_select_with_class_dialog function.
Internal
int UF_UI_is_object_in_sel_list
tag_t object,
logical * in_list
UF_UI_lock_ug_access (view source)
Defined in: uf_ui.h
Inhibits access to NX dialog area 1 and the appropriate
menu items before an Interactive Open C API dialog is brought up.
Both the menubar and the dialog area 1 are greyed out during the
lock. UF_UI_lock_ug_access
Returns
UF_UI_LOCK_EXISTS when dialog area 1 and the NX menu bar
is already inhibited.
UF_UI_LOCK_SET when dialog area 1 and the NX menu bar is
inhibited successfully.
UF_UI_LOCK_ERROR when another application or NX owns the DA2
It is very important to always check your return status of
UF_UI_lock_ug_access. If it is not UF_UI_LOCK_SET then you do
not want to continue with attempting to bring up a dialog. You should
also only call UF_UI_unlock_ug_access when a successful lock has
been made.
UF_UI_lock_ug_access() and UF_UI_unlock_ug_access() must be
used to surround a sequence of one or more Interactive Open C
API calls, when called from a custom dialog.
NOTE: This function does not have to be used by any UIStyler dialogs
that launch other type of Presentation APIs.
See the return values in the description section.
Internal
int UF_UI_lock_ug_access
int from_where
UF_UI_message_dialog (view source)
Defined in: uf_ui.h
This routine will display a modal message dialog which supports the following
dialog types: Question, Information, Error and Warning.
Multiple strings may be provided using message and num_messages. These strings
will be placed on individual lines within the dialog.
If the buttons argument is set to NULL, the dialog will display the OK button
only. Otherwise, you may customize the label and the return value of
at most 3 buttons on the dialog. Note that return values must be within the range
of 1 thru 100.
The translate flag will attempt to locate the strings within the NX Native
Language Database. If it cannot locate the string, it will simply display
the provided string.
0 = No error
not 0 = Error code
Internal
Originally released in v18.0
int UF_UI_message_dialog
UF_UI_MESSAGE_DIALOG_TYPE dialog_type,
char * * messages,
int num_messages,
logical translate,
UF_UI_message_buttons_t * buttons,
int * response
| char * | title_string | Input | Dialog title displayed in title bar |
| UF_UI_MESSAGE_DIALOG_TYPE | dialog_type | Input | Indicates the type of dialog type |
| char * * | messages | Input | Messages to display in dialog |
| int | num_messages | Input | Number of messages associated with messages. |
| logical | translate | Input | Flag to translate messages. |
| UF_UI_message_buttons_t * | buttons | Input | Definitions of buttons to display within the dialog. The response field must be within 1-100. |
| int * | response | Output | Response from the dialog |
UF_UI_open_listing_window (view source)
Opens and manages (displays) a motif style Information
window if in internal Open API mode. The first time
this window is opened it will be empty. Further calls will
display the information previously displayed in the window.
If in external Open API mode, sets the listing window
flag to open.
int UF_UI_open_listing_window
UF_UI_open_part (view source)
Defined in: uf_ui.h
Opens a part and makes it the work part using the File-->Open File
Selection Dialog.
Internal
int UF_UI_open_part
logical * unused,
tag_t * part,
int * response,
UF_PART_load_status_t * error_status
| logical * | unused | Input | Parameter is no longer used; left for forward compatibility |
| tag_t * | part | Output | Pointer to tag of part that was just opened (only valid if response = UF_UI_OK). |
| UF_PART_load_status_t * | error_status | Output to UF_*free* | The user allocated structure <error_status> is filled with the names and associated error codes of any parts that did not load correctly. The allocated arrays must be freed with UF_free_string_array and UF_free(). For details see the definition of UF_PART_load_status_t. |
UF_UI_point_construct (view source)
Defined in: uf_ui.h
Main entry point for the associative point constructor dialog.
Creates an associative point in the work part and returns the point and coordinates of the
point in terms of the absolute work part coordinate system.
The dialog will create a non-associative point in certain cases, depending upon the setting
of the Reference menu in the Coordinates area of the dialog:
- If the Reference menu is set to WCS or Absolute Display Part and the work part is different
from the display part and coordinates are typed into the Coordinates input fields,
a non-associative point will be created.
from the display part and offsets are typed into any of the Offset input fields,
Internal
int UF_UI_point_construct
char * cue,
UF_UI_POINT_base_method_t * base_method,
tag_t * point_tag,
double base_pt [ 3 ] ,
int * response
| char * | cue | Input | Displays a message in the cue line. |
| UF_UI_POINT_base_method_t * | base_method | Input / Output | Use this method as the default method. Returns the method used to create the point. |
| tag_t * | point_tag | Output | Constructed point. The point is an associative (SO) point that is invisible by default. Use UF_SO_set_visibility_option to make it visible. Use functions in uf_so.h to query the parents. See information above in the description about circumstances that will cause a non-associative point to be returned. NULL_TAG is returned if dialog is terminated with CANCEL. |
| double | base_pt [ 3 ] | Output | Coordinates of created point, in absolute work part coordinates. |
| int * | response | Output | One of the following: UF_UI_OK UF_UI_BACK UF_UI_CANCEL. |
UF_UI_register_change_state_fn (view source)
Defined in: uf_ui.h
Registers or unregisters the state change callback for a persistent
dialog. Your state change callback can manage the greying and
ungreying of the action buttons in its persistent Motif dialogs. Call
UF_UI_register_state_fn with the address of the change state callback
registers the function. Calling UF_UI_register_state_fn with a NULL
first argument unregisters the state change callback. NX
activates the registered state change function at the appropriate times
to grey or ungrey the custom persistent action button. You must
unregister your change state function when your custom dialog is
exiting.
NOTE: A state change is the locking and unlocking of NX
main menu bar. If you are in your own custom application that has
launched an Open dialog and the user goes into an all purpose
function dialog (such as Layer-->Settings or Info-->Object), then this is
still considered a lock state so the function in
UF_UI_register_change_state_fn does not get called.
Returns one of the following values:
UF_UI_FAILURE = failure
UF_UI_SUCCESS = success
Internal
int UF_UI_register_change_state_fn
| UF_UI_change_state_fn_t | change_state | Input | Custom supplied change state function to be registered for the application. NX unregisters the this function when UF_UI_register_change_state_fn is called with a NULL parameter. |
UF_UI_remove_all_from_sel_list (view source)
Defined in: uf_ui.h
Removes all the objects from the selection list and optionally
unhighlights them.
Internal
int UF_UI_remove_all_from_sel_list
logical unhighlight
UF_UI_remove_from_sel_list (view source)
Defined in: uf_ui.h
Removes objects from the selection list.
This function is to be used with dialogs created with the UIStyler and
with the UF_UI_select_with_class_dialog function. It can be called
from the selection callback. It cannot be called from the selection
filter procedure.
If any of the objects are not in the list, an error is returned and NO
objects are removed from the list.
It could be called by the selection callback to remove
objects from the selection list. For example, based on objects just
deselected, the application may need to remove other associated
Internal
int UF_UI_remove_from_sel_list
int num,
tag_t * objs,
logical unhighlight
| int | num | Input | Number of objects to remove |
| logical | unhighlight | Input | If true, unhighlight the objects |
UF_UI_remove_ribbon (view source)
Defined in: uf_ui.h
Removes the ribbon with the given id. Once the ribbon is removed the ribbon
id should not be used.
Example:
if (id)
UF_UI_remove_ribbon(id);
id = NULL;
Internal
int UF_UI_remove_ribbon
| UF_UI_ribbon_id_t | ribbon_id | Input | ribbon id of the ribbon to be removed |
UF_UI_remove_toolbar (view source)
Defined in: uf_ui.h
Removes the toolbar with the given id. Once the toolbar is removed the toolbar
Example:
if (id)
UF_UI_remove_toolbar(id);
id = NULL;
Internal
int UF_UI_remove_toolbar
| UF_UI_toolbar_id_t | tool_id | Input | Toolbar id of the toolbar to be removed |
UF_UI_resume_create_toolbar (view source)
Defined in: uf_ui.h
This routine must be used to wrapper the creation of multiple toolbars.
The use of this function helps with the positioning of the toolbars when
they are docked.
Example:
UF_UI_suspend_create_toolbar();
UF_UI_create_toolbar("file1.tbr",1, &id1);
UF_UI_create_toolbar("file2.tbr",1, &id2);
UF_UI_create_toolbar("file3.tbr",1, &id3);
UF_UI_resume_create_toolbar();
Internal
int UF_UI_resume_create_toolbar
UF_UI_resume_init_appstate (view source)
Defined in: uf_ui.h
they are docked. It restore toolbar state for current application.
Example:
UF_UI_suspend_init_appstate();
UF_UI_resume_init_appstate();
Internal
Originally released in V18.0
int UF_UI_resume_init_appstate
UF_UI_resume_remove_toolbar (view source)
Defined in: uf_ui.h
This routine must be used to wrapper the removing of multiple toolbars.
The use of this function helps with the correct recording of the positions
of the docked toolbars in the registry.
Example:
UF_UI_suspend_remove_toolbar();
if (id1) UF_UI_remove_toolbar(id1);
if (id2) UF_UI_remove_toolbar(id2);
if (id3) UF_UI_remove_toolbar(id3);
UF_UI_resume_remove_toolbar();
id1 = NULL;
id2 = NULL;
id3 = NULL;
Internal
int UF_UI_resume_remove_toolbar
UF_UI_route_invoke_callback (view source)
Defined in: uf_ui_route.h
Execute Routing callback functions(internal\external) on passed in objects.
There must be an active part for this function to be called.
Internal
Original release was in NX404 IP2 MP4
int UF_UI_route_invoke_callback
char * call_back_name,
int num_objects,
tag_t* objects
| char * | call_back_name | Input | Callback Name The list of available callbacks is documented in the ugroute_mech_mm.xml file under the Callbacks section. |
| int | num_objects | Input | Number of objects being passed to the callback |
| tag_t* | objects | Input | Array of objects to pass |
UF_UI_save_listing_window (view source)
Saves the contents of the Information window to the file specified by
the argument.
Note: The saved listing window information is limited to 256 characters
per line. If a line is longer than 256 characters, it will be wrapped to
multiple lines in the saved file.
int UF_UI_save_listing_window
char * filename
| char * | filename | Input | filename to which Information Window contents is written. |
UF_UI_select_by_class (view source)
Defined in: uf_ui.h
NOTE: This function is to be obsoleted in the near future. Please use
the replacement function UF_UI_select_with_class_dialog
Selects multiple objects.
Internal
int UF_UI_select_by_class
char * message,
UF_UI_selection_options_p_t opts,
int * response,
int * count,
tag_p_t * object
| char * | message | Input | Cue line message to display. |
| UF_UI_selection_options_p_t | opts | Input | Selection options. |
| int * | response | Output | response: 1 = Back 2 = Cancel 3 = OK |
| int * | count | Output | Count of objects: 0 = No object selected |
| tag_p_t * | object | Output to UF_*free* | Object identifiers of selected objects. NULL if no object selected. Use UF_free to deallocate memory. |
UF_UI_select_conehead (view source)
Defined in: uf_ui.h
Displays the given coneheads and allows the user to select one of
them. The coneheads are described using the standard conehead attributes.
Each conehead has a selection point. The location of the selection
point is set by the input parameter selection_point. The user is then
prompted for a screen location, and the conehead whose selection
point is closest, is returned to the caller.
The selection_point parameter may be any value in the range 0.0 to
1.0. A value of 0.0 sets the selection point to the base of each
conehead. 1.0 sets the selection point to the tips.
The display_coneheads flag determines if, all the coneheads, none of
the coneheads, or just the selected conehead, is left displayed when
the function ends. The selected coneheads selection point is marked
with a small circle.
The user can choose Back or Cancel without selecting a conehead.
UF_DISP_set_conehead_attrb describes how to set conehead attributes.
Internal
int UF_UI_select_conehead
char * message,
int num,
double origins [ ] ,
double directions [ ] ,
char * * labels,
UF_DISP_conehead_attrb_s * attributes,
double selection_point,
int display_coneheads,
int * selected_num,
int * response
| char * | message | Input | The cue line message. (80 character maximum) |
| int | num | Input | The number of coneheads to display. |
| double | origins [ ] | Input | An array of conehead origin points. Contains num3 entries. |
| double | directions [ ] | Input | An array of conehead directions. Contains num3 entries. |
| char * * | labels | Input | An array of pointers to character string labels to be placed on the coneheads. If no labels are desired this may be passed as NULL. Individual entries may also be set to NULL. Contains num entries. |
| UF_DISP_conehead_attrb_s * | attributes | Input | An array of conehead attribute structures If this is set to NULL, the current conehead attributes are used for all the coneheads. For a description of this structure and how to set the current conehead attributes see UF_DISP_set_conehead_attrb. Contains num entries. |
| double | selection_point | Input | Determines where the selection points are on the coneheads. This is given as a fraction of the total conehead length, 0.0 to 1.0. |
| int | display_coneheads | Input | Which coneheads will remain displayed on Return
UF_UI_DISP_NONE UF_UI_DISP_SELECTED UF_UI_DISP_ALL |
| int * | selected_num | Output | The conehead that was selected. 1 to num. Only valid if response = UF_UI_OK. |
| int * | response | Output | Indication of the users response: UF_UI_OK UF_UI_BACK UF_UI_CANCEL |
UF_UI_select_feature (view source)
Defined in: uf_ui.h
Selects multiple features. Presents a list box of features in the work
part and allows multiple selection of features from the list box or from
the graphical display. If there are no features to be presented, an
empty list box is presented After the user okays the selection, the
features are unhighlighted. There must be a part loaded when this
function is called.
Internal
Note: If filter is NULL, boolean and UDF features will not be presented.
For all booleans to be presented use UF_UI_feat_sel_type_t
int UF_UI_select_feature
char * message,
void * filter,
int * count,
tag_t * * feature_tags,
int * response
| void * | filter | Input | Must be NULL or castable to UF_UI_feat_sel_type_t. |
| int * | count | Output | Count features selected |
| tag_t * * | feature_tags | Output to UF_*free* | Allocated array of selected feature tags. After use must be freed with UF_free |
| int * | response | Output | response: UF_UI_BACK UF_UI_CANCEL UF_UI_OK |
UF_UI_select_parameters (view source)
Defined in: uf_ui.h
Displays a list box of the expressions corresponding to the parameters
of the input feature. You can select multiple expressions from the list
box. Returns an allocated array of expression tags. The expression tag
array must be freed with UF_free after use. There must be a part
loaded when this function is called. The input feature must be in the
work part.
Internal
int UF_UI_select_parameters
char* message,
tag_t feature_tag,
int* count,
tag_t* * exp_tags,
int* response
| char* | message | Input | Cue line message. |
| tag_t | feature_tag | Input | Feature tag. |
| int* | count | Output | Number of feature parameters selected |
| tag_t* * | exp_tags | Output to UF_*free* | The allocated tag array of the corresponding expressions of the selected parameters. This array must be freed by calling UF_free. |
| int* | response | Output | Response UF_UI_BACK (Back) UF_UI_CANCEL (Cancel) UF_UI_OK (Parameters selected) |
UF_UI_select_point_collection (view source)
Defined in: uf_ui.h
Allows you to select a collection of points using the Point
Specification menu (see the NX Gateway manual for details)
Point Specification Method Menu
The logical value determines if coincident points are returned. This
function returns a count of points and an array of structures. You must
free memory using UF_free.
NOTE: object is null_tag if you use the point subfunction. pt[3] is the
location in absolute space.
Internal
int UF_UI_select_point_collection
char * message,
logical coincident_points,
UF_UI_chained_points_p_t * points,
int * count,
int * response
| char * | message | Input | Displays a message (32 character maximum) in the cue line. The message is suffixed with the string "Point Specification Method". |
| logical | coincident_points | Input | TRUE = coincident points can be returned. FALSE = do not return coincident points. not valid with point constructor |
| UF_UI_chained_points_p_t * | points | Output to UF_*free* | Array of data structures containing the points. This array must be freed by calling UF_free. |
| int * | count | Output | Count of points returned. |
| int * | response | Output | A response of Back, Cancel , or OK is specified by one of the following constants: UF_UI_BACK UF_UI_CANCEL UF_UI_OK |
UF_UI_select_routing_objects (view source)
Select Routing objects using the standard Routing selection tool
Internal
Original release was in V18.0.
int UF_UI_select_routing_objects
char * title,
char * message,
int types,
int * method,
int scope,
int * response,
int * count,
tag_p_t * objects
| char * | title | Input | Dialog Title or Null |
| char * | message | Input | Cue line message to display |
| int | types | Input | Selectable Routing types - this should be specified by logically OR-ing the desired types from the list of types defined defined in uf_ui_route.h which have a prefix of UF_UI_ROUTE_SEL. |
| int * | method | Input / Output | Default (starting) Routing selection method. This should be one of the method definitions defined in uf_ui_route.h starting with the prefix: UF_UI_ROUTE_SEL_METHOD This will be set to last selection method used by the interactive user during this invocation. Using this, you can "remember" the user's last method setting for the next call |
| int | scope | Input | Selection scope (include uf_ui.h) UF_UI_SEL_SCOPE_NO_CHANGE UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY UF_UI_SEL_SCOPE_WORK_PART UF_UI_SEL_SCOPE_WORK_PART_AND_OCC |
| int * | response | Output | UF_UI_BACK UF_UI_CANCEL UF_UI_OK |
| int * | count | Output | Count of objects selected. 0 if no objects selected. |
| tag_p_t * | objects | Output to UF_*free* | Array of object identifiers of the selected objects. This must be freed with UF_free. |
UF_UI_select_rpo_dimensions (view source)
Defined in: uf_ui.h
Displays the rpo dimensions of the specified feature in a list box
which shows the corresponding expressions. You can select multiple
expressions from the list box or select the dimensions graphically.
array must be freed with UF_free after use. An error is returned if the
feature has no rpo dimensions. There must be a part loaded when this
function is called. The feature that is input must be in the work part.
Internal
int UF_UI_select_rpo_dimensions
char * message,
tag_t feature_tag,
int * count,
tag_t * * exp_tags,
int * response
| char * | message | Input | Cue line message |
| tag_t | feature_tag | Input | Feature tag |
| int * | count | Output | Number of rpo dimensions selected |
| tag_t * * | exp_tags | Output to UF_*free* | The allocated tag array of the corresponding expressions for the selected rpo dimensions. This must be freed by calling UF_free. |
| int * | response | Output | Response UF_UI_BACK (Back) UF_UI_CANCEL (Cancel) UF_UI_OK (Parameters selected) |
UF_UI_select_single (view source)
Defined in: uf_ui.h
use the replacement routine UF_UI_select_with_single_dialog .
Selects a single object. The view parameter is a pointer view
sequence. This tag provides the view from which the object was
selected.
Internal
int UF_UI_select_single
char * message,
int * response,
tag_p_t object,
double cursor [ 3 ] ,
tag_p_t view
| UF_UI_selection_options_p_t | opts | Input | Selection options. See the Data structures section of this chapter. |
| int * | response | Output | response: 1 = Back 2 = Cancel 4 = Object selected by name 5 = Object selected |
| tag_p_t | object | Output | Object identifier of selected object |
| double | cursor [ 3 ] | Output | Cursor position. This is undefined if response is 4 (object selected by name). |
| tag_p_t | view | Output | View of selection. This is NULL_TAG if response is 4 (object selected by name). |
UF_UI_select_sketch (view source)
Defined in: uf_ui.h
Presents a list box of all sketches in the work part and returns the
sketch selected by the user from either the list box or the graphical
display. After the user okays the selection of the sketch, the sketch is
unhighlighted. There must be a part loaded when this function is
called. If there are no sketches to be selected an error is returned.
NOTE: This function returns old sketches (pre-V13.0) and new
sketches (V13 and beyond). Since new sketches are now features, you
can use UF_UI_select_feature to return new sketches. This function
also provides a list box.. You can also return sketches with general
selection functions like UF_UI_select_with_single_dialog
(or UF_UI_select_single) and UF_UI_select_with_class_dialog
(or UF_UI_select_by_class).
Internal
int UF_UI_select_sketch
char * message,
void * mask,
tag_t * sketch_tag,
int * response
| void * | mask | Input | Reserved for future. Must be set to NULL. |
| tag_t * | sketch_tag | Output | The tag of the selected sketch. |
| int * | response | Output | Response: UF_UI_BACK (Back) UF_UI_CANCEL (Cancel) UF_UI_OK (Sketch Selected) |
UF_UI_select_sketch_dimensions (view source)
Defined in: uf_ui.h
All the dimensions of the specified sketch are displayed if they are
not already displayed. However, only dimension constraints are selectable,
i.e., reference dimensions cannot be selected. The user is presented with a
list box of the correspondng expressions. You can select multiple expressions
from the list box or select the sketch dimensions graphically. There must be
a part loaded when this function is called. The sketch must be in the
work part.
array has to be freed with UF_free after use. If the sketch has no
dimension constraints, an error is returned.
Internal
int UF_UI_select_sketch_dimensions
char* message,
tag_t sketch_tag,
int* count,
tag_t* * exp_tags,
int* response
| tag_t | sketch_tag | Input | Sketch tag. |
| int* | count | Output | Number of sketch dimension constraints selected |
| tag_t* * | exp_tags | Output to UF_*free* | The allocated tag array of the corresponding expressions of the selected sketch dimension constraints. Use UF_free to deallocate memory after use. |
| int* | response | Output | Response: UF_UI_BACK (Back) UF_UI_CANCEL (Cancel) UF_UI_OK (Dimensions selected) |
UF_UI_select_tc_result_file_to_import (view source)
Defined in: uf_ui.h
Create a Result File Selection Box dialog and allows the user to select a named reference file from
Teamcenter CAESolution dataset and passes back the selected Teamcenter file location.
0 = No error
!= 0 = Error code
Internal
int UF_UI_select_tc_result_file_to_import
char * * file_extensions,
int num_extensions,
int * response
| char * * | file_extensions | Input | Caller has to supply the list of file extension strings. The elements of the list will decide which type of the files need to be displayed in the selection dialog box for selection. The string extension of the result file which needs to be displayed should in the format ".XXX". E.g ".prt", ".sim", ".dat" etc. |
| int | num_extensions | Input | The variable will provide the size of the file extensions list. |
| char | filename [ MAX_FSPEC_BUFSIZE ] | Output | Caller has to select the desired result file from the selection dialog to enable the OK button to finish the selection operation. All the filtered result files of the part under investigation will be desplayed for selection. It is caller's responsibility to allocate enough memory for the filename string. |
UF_UI_select_with_class_dialog (view source)
Defined in: uf_ui.h
Select multiple objects with the class selection dialog.
If the response is UF_UI_OK, the selected objects remain
highlighted. The response may be UF_UI_OK but no objects have
been selected. If the response is UF_UI_CANCEL,
all the selected objects are unhighlighted.
The valid selection scopes are defined in uf_ui.h. If the selection
scope is changed, it is restored to its original state when the dialog is
terminated.
The selection initialization procedure is an optional procedure
provided by the user to specify additional selection parameters by
calling other UF_UI selection functions. For more information, see
In the selection initialization procedure UF_UI_set_sel_mask can
be called to specify object type filtering. The default object type
mask is all standard types selectable. UF_UI_set_sel_procs can be
called to specify a filter procedure and/or selection callback.
To begin with objects already selected (which allows them to be
deselected), call UF_UI_add_to_sel_list from the selection
initialization procedure.
Note: In NX5 class selection was converted to Blocked Base Menu. Selection
will now inherit any selected objects from global selection. If inheritance
is not desired then the global selection should be cleared (deselect the objects)
before calling UF_UI_select_with_class_dialog.
The function UF_UI_set_cursor_view is necessary to enable the
selection of objects within drawing member views.
Internal
int UF_UI_select_with_class_dialog
char * message,
char * title,
int scope,
UF_UI_sel_init_fn_t sel_init_proc,
void* user_data,
int * response,
int * count,
tag_p_t* object
| int | scope | Input | Selection scope UF_UI_SEL_SCOPE_NO_CHANGE UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY UF_UI_SEL_SCOPE_WORK_PART UF_UI_SEL_SCOPE_WORK_PART_AND_OCC |
| UF_UI_sel_init_fn_t | sel_init_proc | Input | Selection initialization procedure or NULL |
| void* | user_data | Input | User data for initialization procedure or NULL |
| int * | response | Output | UF_UI_CANCEL UF_UI_OK |
| tag_p_t* | object | Output to UF_*free* | Array of object identifiers of the selected objects. This must be freed with UF_free. |
UF_UI_select_with_single_dialog (view source)
Defined in: uf_ui.h
Selects a single object with the single selection dialog. The object can
be selected with the cursor or by entering a name. The object is
highlighted.
The valid selection scopes are defined in uf_ui.h (e.g
UF_UI_SEL_SCOPE_NO_CHANGE). If the selection scope is changed, it is restored
to its original state when the dialog is terminated.
The selection initialization procedure is a function the Open C API
programmer can optionally provide in order to customize their
selection by calling other UF_UI selection functions. NX calls the
selection initialization procedure, passing the selection pointer and
user data. The selection pointer is only valid during the selection
initialization procedure, and is used as an input argument to the
If the initialization is successful, the procedure should return
UF_UI_SEL_SUCCESS. Otherwise, it should return UF_UI_SEL_FAILURE.
In this case, the single selection dialog is presented and an appropriate
error code is returned. In the selection initialization procedure:
UF_UI_set_sel_mask can be called to specify object type filtering.
The default object type mask is all standard types selectable.
UF_UI_set_sel_procs can be called to specify a filter procedure
You can call UF_UI_select_with_single_dialog in a loop to select
multiple objects. The user indicates they are done selecting by
choosing OK. You must have an active part to call this function.
The function UF_UI_set_cursor_view is necessary to enable the selection
Internal
Original release was in V13.0.
int UF_UI_select_with_single_dialog
char * message,
char * title,
int scope,
UF_UI_sel_init_fn_t init_proc,
void* user_data,
int * response,
tag_t * object,
tag_t * view
| char * | title | Input | Dialog title or NULL |
| UF_UI_sel_init_fn_t | init_proc | Input | Selection initialization procedure or NULL |
| int * | response | Output | UF_UI_BACK UF_UI_CANCEL UF_UI_OK UF_UI_OBJECT_SELECTED UF_UI_OBJECT_SELECTED_BY_NAME |
| tag_t * | object | Output | Selected object or NULL_TAG if no object selected |
| double | cursor [ 3 ] | Output | Absolute coordinates of cursor position. This is undefined if object is selected by name. |
| tag_t * | view | Output | View object was selected in. This is NULL_TAG if object was selected by name. |
UF_UI_set_cursor_view (view source)
Defined in: uf_ui.h
Sets the current mask for selection within views. Object selection can
routine sets the current value.
In drafting, the default is the work view so use this function if you want
to select in any view. It is recommended to call UF_UI_ask_cursor_view and
save the current value so you can set it back after changing.
Internal
int UF_UI_set_cursor_view
int new_cursor_view
| int | new_cursor_view | Input | New cursor view: 0 = Any view 1 = Work view |
UF_UI_set_dialog_directory (view source)
Defined in: uf_ui.h
Sets the directory path of a given dialog.
Internal
int UF_UI_set_dialog_directory
UF_UI_dialog_dir_id_t id,
char * dir_name
| UF_UI_dialog_dir_id_t | id | Input | Enumeration constant of the dialog. |
| char * | dir_name | Input | Directory path of the dialog. |
UF_UI_set_dialog_filter (view source)
Defined in: uf_ui.h
Sets the filter extension of the current dialog.
Internal
int UF_UI_set_dialog_filter
UF_UI_dialog_filter_id_t id,
char * fltr_name
UF_UI_set_force_unlock_flag (view source)
Defined in: uf_ui.h
Sets the unlock flag to unlock NX functions regardless of the
NX state.
The call to UF_UI_set_force_unlock flag must be followed with a call
to UF_UI_unlock_ug_access.
For a complete example demonstrating how to use
this function please refer to the example provided
in the Open kit called ufx_menuscript_ufsta.c.
return code:
UF_UI_SUCCESS when the unlock flag is set.
UF_UI_FAILURE when the unlock flag is not set.
Internal
int UF_UI_set_force_unlock_flag
UF_UI_set_minimal_graphics_window (view source)
Defined in: uf_ui.h
This function will turn on/off NX graphics window special minimal mode
Privileged
Added in NX7.5.2
int UF_UI_set_minimal_graphics_window
logical set
UF_UI_set_minimal_graphics_window_location (view source)
Defined in: uf_ui.h
This function will set NX graphics window position in special minimal mode
If all parameters are zero then NX will be resized to fill whole current screen.
Privileged
Added in NX7.5.2
int UF_UI_set_minimal_graphics_window_location
int left,
int top,
int right,
int bottom
| int | left | Input | x-value at left side of graphics window |
| int | top | Input | y-value at top of graphics window |
| int | right | Input | x-value at right side of graphics window |
| int | bottom | Input | y-value at bottom of graphics window |
UF_UI_set_prompt (view source)
Defined in: uf_ui.h
Displays a line of text in the NX prompt area. You call this routine
after some interactive dialog invokes a change in the status bar. You
can call this routine to prompt the user when a specific interactive
task is required. For example, if your program requires the user to
select a line end point, you could prompt the user to "Pick line end pt1".
Internal
int UF_UI_set_prompt
char * prompt_text
| char * | prompt_text | Input | Pointer to text to display. |
UF_UI_set_ribbon_vis (view source)
Defined in: uf_ui.h
This routine sets the visibility of a ribbon tab. This routine can only be used
on a ribbon tab for which you have a valid ribbon id. This function only applies
to ribbon tabs; for groups, galleries, cascades, and dropdowns it has no effect.
Note: Changing the visibility of the ribbon tab will override any user customization
of the tabs visibility. It is preferable to use UF_UI_create_ribbon and UF_UI_remove_ribbon,
which also works on groups, galleries, dropdowns and cascades.
Internal
int UF_UI_set_ribbon_vis
UF_UI_ribbon_id_t ribbonl_id,
int show
| UF_UI_ribbon_id_t | ribbonl_id | Input | Valid Ribbon id returned from a call to UF_UI_create_ribbon |
| int | show | Input | 1 = show; 0 = hide |
UF_UI_set_sel_mask (view source)
Defined in: uf_ui.h
Sets the types of objects that are selectable. If this function is not
called to set the mask, then the default mask is all standard types.
The following is the current list of standard types.
UF_point_type
UF_line_type
UF_circle_type
UF_conic_type
UF_spline_type
UF_pattern_type
UF_kanji_type
UF_group_type
UF_drafting_entity_type
UF_dimension_type
UF_tabular_note_type
UF_margin_type
UF_coordinate_system_type
UF_plane_type
UF_component_type
UF_datum_axis_type
UF_datum_plane_type
UF_facet_topology_type
UF_view_type
UF_view_set_type
UF_route_control_point_type
UF_route_port_type
UF_route_segment_type
UF_route_part_anchor_type
UF_route_stock_type
UF_analysis_type
UF_traceline_type
UF_constraint_type
UF_solid_type
In this list of standard types, UF_solid_type only specifies solid bodies
and does not include faces or edges. To select faces or edges, you must
specify these object subtypes in mask_triples.
The word ALL in the two symbols UF_UI_SEL_MASK_ENABLE_ALL and
UF_UI_SEL_MASK_ALL_AND_DISABLE_SPECIFIC means all standard types.
Use this function for setting the object type mask for dialogs created
with the UIStyler. The function can be called from any UIStyler
dialog callback or the selection callback to change the object type
mask.
For UF_UI_select_with_single_dialog and UF_UI_select_with_class_dialog,
this function can only be called from the selection initialization procedure.
Calling this function from a selection filter procedure returns an error.
Internal
int UF_UI_set_sel_mask
UF_UI_selection_p_t select_,
UF_UI_sel_mask_action_t action,
int num,
UF_UI_mask_t * mask_triples
| UF_UI_selection_p_t | select_ | Input | selection pointer |
| UF_UI_sel_mask_action_t | action | Input | Mask action UF_UI_SEL_MASK_ENABLE_ALL UF_UI_SEL_MASK_ENABLE_SPECIFIC UF_UI_SEL_MASK_DISABLE_SPECIFIC UF_UI_SEL_MASK_CLEAR_AND_ENABLE_SPECIFIC UF_UI_SEL_MASK_ALL_AND_DISABLE_SPECIFIC |
| int | num | Input | Number of mask triples |
| UF_UI_mask_t * | mask_triples | Input | Array of mask triples. |
UF_UI_set_sel_procs (view source)
Defined in: uf_ui.h
Specify selection filter procedure for additional filtering based on
application specific criteria, and/or selection callback to perform
application specific processing for each selection gesture processed,
and user specific data to be passed to these routines.
This function can be used with UIStyler dialogs and with
UF_UI_select_with_single_dialog and UF_UI_select_with_class_dialog.
The typedef of the filter procedure and selection callback are defined
in this header file as follows:
typedef int (UF_UI_sel_filter_fn_t) (
tag_t object,
int type[3],
void user_data,
UF_UI_selection_p_t select_)
typedef int (UF_UI_sel_cb_fn_t) (
int num_selected,
tag_p_t selected_objects,
int num_deselected,
tag_p_t deselected_objects,
void user_data,
The filter procedure is passed the tag of the candidate object, the
types of the candidate object (object type, object subtype, solid
subtype - see UF_UI_set_sel_mask) , a pointer to the user's data,
and a pointer to selection. The return responses are defined in
uf_ui.h. The filter procedure should return UF_UI_SEL_REJECT if
the object is to be discarded and UF_UI_SEL_ACCEPT if the object
is a valid candidate.
The candidate object passed to the filter procedure is not adjusted
for scope. Therefore, with an assembly part, the object is the
occurrence and not the prototype.
You can get the prototype of the object by calling
UF_ASSEM_ask_prototype_of_occ. However, if the object is to be a
promotion, for example, then the user has to do some inquiries as
in the example below:
if (UF_ASSEM_is_occurrence(object))
proto = UF_ASSEM_ask_prototype_of_occ(object);
UF_MODL_ask_prom_feat_of_solid(proto, &feat));
UF_MODL_prom_map_object_up(proto, feat,
&prom));
status = check_promotion(prom);
The selection callback is different. The objects passed to it are
already adjusted for scope.
The selection callback is passed an allocated array of the objects
selected or deselected with the previous selection. The allocated array
of tags will be freed for the user. The user can force dialog
termination by returning UF_UI_CB_EXIT_DIALOG. To continue
the dialog, the user should return UF_UI_CB_CONTINUE_DIALOG.
When a selection callback is used with UF_UI_select_with_single_dialog,
the return is ignored and the dialog is always terminated.
Both the filter procedure and the selection callback are passed a
pointer to selection which can be used as input to other UF_UI
selection functions to inquire other selection data or modify selection.
This selection pointer is no longer valid after the filter procedure or
selection callback is exited.
Internal
int UF_UI_set_sel_procs
UF_UI_sel_filter_fn_t filter_proc,
UF_UI_sel_cb_fn_t sel_cb,
void * user_data
UF_UI_set_sel_type (view source)
Defined in: uf_ui.h
Sets the selection type.
You use this function with UIStyler dialogs. It can be called from a
callback to change the type of selection associated with the dialog.
Valid types are defined in uf_ui.h.
A type of UF_UI_SEL_TYPE_INACTIVE_SELECTION sets selection inactive until
this function is called again. UF_UI_SEL_TYPE_ROBUST_SELECTION allows
single select, single deselect, reselect last, rectangle select, rectangle
deselect, and chaining. If UF_UI_SEL_TYPE_SINGLE_POSITION and either
UF_UI_SEL_TYPE_SINGLE_SELECTION or UF_UI_SEL_TYPE_ROBUST_SELECTION is
requested, the position is returned if no object is selected with the
single select gesture.
Calling this function for UF_UI_select_with_single_dialog or
UF_UI_select_with_class_dialog returns an error. Calling this
Internal
int UF_UI_set_sel_type
int type
| int | type | Input | UF_UI_SEL_TYPE_INACTIVE_SELECTION or bit mask of selection types: UF_UI_SEL_TYPE_SINGLE_SELECTION UF_UI_SEL_TYPE_SINGLE_DESELECTION UF_UI_SEL_TYPE_ROBUST_SELECTION UF_UI_SEL_TYPE_SINGLE_POSITION UF_UI_SEL_TYPE_RECTANGLE_POSITION |
UF_UI_set_select_mask (view source)
Defined in: uf_ui.h
Determines which object types to mask.
This function modifies a shared filter only used by a few NX commands and
does not modify the global selection filter. To establish a filter to use
for selection, see function UF_UI_set_sel_mask(), which can be used to
establish a filter for a UIStyler dialog, or the dialog launched by either
UF_UI_select_with_class_dialog or UF_UI_select_with_single_dialog; both of
these functions take in a proc of type UF_UI_sel_init_fn_t. In your
implementation of that proc, you can set up the selection filter for the
dialog using UF_UI_set_sel_mask().
Internal
int UF_UI_set_select_mask
int action,
int num_items,
int * items_to_mask
| int | action | Input | Mask action: UF_UI_enable_all UF_UI_disable_all UF_UI_enable_specific UF_UI_disable_specific |
| int | num_items | Input | Number of object types in array |
| int * | items_to_mask | Input | Object types to be masked |
UF_UI_set_status (view source)
Defined in: uf_ui.h
Displays a line of text in the NX status area.
Internal
int UF_UI_set_status
char * status_text
| char * | status_text | Input | Pointer to text to display |
UF_UI_set_toolbar_vis (view source)
Defined in: uf_ui.h
This routine sets the visibility of a toolbar. This routine can only be used
on toolbars that you have valid toolbar id for.
Internal
int UF_UI_set_toolbar_vis
int show
| UF_UI_toolbar_id_t | tool_id | Input | Valid Toolbar id returned from a call to UF_UI_create_toolbar |
UF_UI_set_usertool_menu_entry (view source)
Defined in: uf_ui.h
Replaces the user tool definition file specified by a user tools
menubar option. The option number range starts at one and its
maximum is defined by the original length of the ".utm" file. For
example, if the ".utm" file only includes four entries, it is not possible
to extend the size of the menubar entries by setting the option number to 5.
The replacement for the user tool definition does not take effect until
Reload-->Default is selected. Therefore, hiding and then showing the
tool does not change the definition.
Internal
int UF_UI_set_usertool_menu_entry
int option_number,
char * label,
char * filename
| int | option_number | Input | Menu item number to be replaced. |
| char * | label | Input | Pointer to label text |
| char * | filename | Input | Pointer to new tool definition filename |
UF_UI_specify_csys (view source)
Defined in: uf_ui.h
This function launches a dialog to let the user choose a csys. The csys
specified by the input csys_tag is the default. If the csys_tag input is
NULL_TAG, then the initial CSYS is used as the default. The output csys_tag is
the csys the user specified in the dialog.
Though 40 characters are allowed in the title,
it should be noted that the first option (ORIGIN,X-PT,Y-PT) appends the point
number (PT1, PT2, and PT3) on the end of the message. Thus, only 36
characters are effectively allowed.
Users Response
1 = Back
2 = Cancel
3 = OK
7 = No Active Part
8 = Disallowed state, unable to bring up dialog
Internal
int UF_UI_specify_csys
char * title,
int * option,
double csys_matrix [ 9 ] ,
double origin [ 3 ] ,
tag_t * csys_tag
| char * | title | Input | Menu Title (40 char max) |
| int * | option | Input / Output | On input the default CSYS Option. On output the CSYS option used. 0 = Inferred 1 = Origin, X-pt, Y-pt 2 = X-axis, Y-axis 3 = X-pt, Z-axis 4 = CSYS of Object 5 = WCS (Dynamic) 6 = Offset CSYS 7 = Absolute CSYS 8 = CSYS of Current View 9 = Three Planes 10 = Origin, X-axis, Y-axis 11 = Point, Perpendicular Curve 12 = Plane, Vector 13 = Plane, X-Axis, Point 14 = Origin, Z-Axis, X-Axis 15 = Origin, Z-Axis, Y-Axis |
| double | csys_matrix [ 9 ] | Output | CSYS Matrix (9 element array) - relative to Absolute CSYS of Displayed Part |
| double | origin [ 3 ] | Output | CSYS Origin (3 element array) - relative to Absolute CSYS of Displayed Part |
| tag_t * | csys_tag | Input / Output | CSYS tag - On input the default CSYS. On output the CSYS picked. If csys_tag is not NULL, "option" will reflect the type of the CSYS If csys_tag is a non-associative CSYS, option will be set to Dynamic |
UF_UI_specify_plane (view source)
Defined in: uf_ui.h
Allows you to select the plane subfunction default mode. A temporary
plane is created from the specified subfunction.
Internal
int UF_UI_specify_plane
char * message,
int * mode,
int display,
int * response,
double orientation [ 9 ] ,
tag_t * plane_eid
| char * | message | Input | Cue line message (80 character maximum) |
| int * | mode | Input / Output | On input default plane subfunction. On output the plane subfunction actually used: -1 = Enable ok without default selection 0 = Inhibit default selection 1 = Three Points 2 = Two Lines 3 = Point, Perp Curve 4 = Plane of Arc/Conic 5 = Plane of WCS 6 = Plane of CSYS 7 = Principal Plane 8 = Existing Plane 9 = Two Tangent Faces 10 = Point, Tangent Face 11 = Coefficients 12 = Parallel Thru Pt 13 = Parallel At Dist 14 = Perp, Thru Line |
| int | display | Input | 0 = Display temporary plane in all active views 1 = Do not display temporary plane |
| int * | response | Output | 1 = Back 2 = Cancel 3 = Ok |
| double | orientation [ 9 ] | Input | Plane orientation in absolute coordinate |
| double | origin [ 3 ] | Input | Plane origin in absolute coordinate |
| tag_t * | plane_eid | Output | Object identifier of plane if mode 8 was selected NULL_TAG for other modes. |
UF_UI_specify_screen_position (view source)
Defined in: uf_ui.h
This function allows you to indicate a screen position by pressing MB1
in the graphics window. The screen position and the tag of the view it
is in are returned.
An empty dialog is displayed with only the Back and Cancel buttons enabled.
The function UF_UI_set_cursor_view affects the screen_pos
and view_tag that is returned and passed to the motion callback. This
is particularly true with respect to the display of a drawing view. The
two values for the new_cursor_view parameter of UF_UI_set_cursor_view affect
the view_tag and screen_pos parameters of UF_UI_specify_screen_position as
follows:
. If new_cursor_view is set to "Any View" and the cursor is in a
drawing member view, then the return values for the view_tag and
screen_pos are the tag of the member view and the position in
Absolute Coordinates in that member view.
. If the new_cursor_view is set to "Work View", then regardless of
whether the cursor is in a member view or not, the return values
for the view_tag and screen_pos are the tag of the drawing and the
position in drawing coordinates.
If Grid Snap is presently enabled, the screen position is automatically
snapped. This also applies to the position passed to the motion
callback.
This function accepts a motion callback which will be called in
response to each detected movement (i.e. "motion") of the cursor
within the graphics window. The callback will be passed the current
position and view of the cursor, and the client data pointer.
The typedef for motion callbacks is defined in uf_disp.h as follows:
typedef void (UF_UI_motion_fn_t)(
double screen_pos[3],
UF_UI_motion_cb_data_p_t motion_cb_data,
void data );
All of the above parameters are input parameters to the callback
function:
screen_pos is the current position of the crosshair, given in Work
Part Absolute Coordinates (as described above).
motion_cb_data is a pointer to a data structure; presently, only
the following field of this structure should be referenced:
motion_cb_data->view_tag is the tag of the view of the
current crosshair position.
Finally, the third parameter to the motion callback, data, is the client
data pointer initially passed to UF_UI_specify_screen_position along
with the callback.
In general, a motion callback will generate some graphical feedback
based on the current cursor position, using Overlay Graphics
primitives. Overlay Graphics primitives are defined using the
UF_DISP_display_ogp_ functions. Overlay Graphics primitives
generated from a motion callback will be displayed immediately
following the invocation of the callback, and will be automatically
erased just before the next invocation, and upon the completion of
the call to UF_UI_specify_screen_position.
Please see the Overview of the section on Overlay Graphics primitive
functions in the Display chapter for further information regarding
their behavior and usage.
Keep in mind that your motion callback will be invoked in response to
every detected movement of the cursor (in the graphics window). If
you find that the display of the cursor appears to be "choppy", or that
it doesn't seem to be "keeping up" with your movement of the mouse,
it may be that you are attempting to do too many calculations and/or
define too many primitives from your motion callback.
There must be a part loaded when this function is called.
Internal Only
int UF_UI_specify_screen_position
char * message,
UF_UI_motion_fn_t motion_cb,
void * motion_cb_data,
double screen_pos [ 3 ] ,
tag_t * view_tag,
int * response
| char * | message | Input | Cue line message (132 Character maximum), or NULL |
| UF_UI_motion_fn_t | motion_cb | Input | Motion callback function, or NULL |
| void * | motion_cb_data | Input | Client data pointer, or NULL; will be passed to motion_cb |
| double | screen_pos [ 3 ] | Output | The screen position in Work Part Absolute Coords, projected "through the screen" onto the WCS XY plane. This is given in Work Part Absolute Coordinates. This is only returned if the response returned is UF_UI_PICK_RESPONSE. |
| tag_t * | view_tag | Output | Tag of the view in which the screen position was indicated. This is only returned if the response returned is UF_UI_PICK_RESPONSE. |
| int * | response | Output | One of the following: UF_UI_PICK_RESPONSE UF_UI_BACK UF_UI_CANCEL |
UF_UI_specify_vector (view source)
Defined in: uf_ui.h
Queries the user to specify a vector using the vector subfunction.
Optionally, a temporary conehead is displayed at the vector specified.
Internal
int UF_UI_specify_vector
char * message,
int * mode,
int display_conehead,
double direction [ 3 ] ,
int * response
| int * | mode | Input / Output | On input default vector subfunction mode. On output the subfunction mode actually used: UF_UI_INFERRED UF_UI_TWO_POINTS UF_UI_AT_ANGLE UF_UI_EDGE_CURVE UF_UI_TANGENT_TO_CURVE UF_UI_FACE_NORMAL UF_UI_DATUM_PLANE UF_UI_DATUM_AXIS UF_UI_XC_AXIS UF_UI_NEGATIVE_XC_AXIS UF_UI_YC_AXIS UF_UI_NEGATIVE_YC_AXIS UF_UI_ZC_AXIS UF_UI_NEGATIVE_ZC_AXIS |
| int | display_conehead | Input | Display temporary vector in all active views: UF_UI_DISP_TEMP_VECTOR UF_UI_DISP_NO_VECTOR |
| double | direction [ 3 ] | Output | Vector direction (unitized) |
| double | origin [ 3 ] | Output | Vector origin in absolute coordinate |
| int * | response | Output | User response: UF_UI_OK UF_UI_BACK UF_UI_CANCEL |
UF_UI_suspend_create_toolbar (view source)
Defined in: uf_ui.h
they are docked.
Example:
Internal
Originally released in V16.0
int UF_UI_suspend_create_toolbar
UF_UI_suspend_init_appstate (view source)
Defined in: uf_ui.h
they are docked. It restores toolbar state for current application.
Example:
Internal
int UF_UI_suspend_init_appstate
UF_UI_suspend_remove_toolbar (view source)
Defined in: uf_ui.h
Example:
id1 = NULL;
id2 = NULL;
id3 = NULL;
Internal
int UF_UI_suspend_remove_toolbar
UF_UI_toggle_stoplight (view source)
Defined in: uf_ui.h
Changes the status of the NX stoplight indicator to either busy or not
busy.
Internal
int UF_UI_toggle_stoplight
int toggle_on_off
| int | toggle_on_off | Input | Flag to toggle stoplight. 1 = the stoplight indicates busy (red) 0 = the stoplight indicates not busy (green) |
UF_UI_ugmgr_ask_create_part_file_name (view source)
Defined in: uf_ui.h
This routine just brings up the part selection dialog to prompt
for the new part name. This routine does not actually create the part.
This routine was written to provide the routine that does the
same work which UF_UI_ask_create_part_filename does in native NX. In
NX Manager, UF_UI_ask_create_part_filename creates the specified
part, this routine can be used when you want to get the filename
but not yet create the part.
Internal
Originally released in NX 5.0 and is mandatory if Longer IDs functionality is enabled NX/Manager
int UF_UI_ugmgr_ask_create_part_file_name
char * * filename,
char * * part_type,
char * * template_name,
int * response
| char * * | filename | Output to UF_*free* | The new part name in CLI format |
| char * * | part_type | Output to UF_*free* | The part type of the part |
| char * * | template_name | Output to UF_*free* | The seed part name |
| int * | response | Output | The response from the user |
UF_UI_unlock_ug_access (view source)
Defined in: uf_ui.h
Enables access to NX dialog area 1 and the appropriate
menu items after an Interactive Open C API dialog has been used.
Returns
UF_UI_NO_LOCK_EXISTED when dialog area 1 and NX menu bar
were not locked.
UF_UI_UNLOCK_SET when dialog area 1 and NX menu bar is
enabled successfully.
Internal
int UF_UI_unlock_ug_access
int from_where
| int | from_where | Input | Predefined constant used to support error checking. This should always be UF_UI_FROM_CUSTOM for custom applications. |
UF_UI_update_listing_window (view source)
Defined in: uf_ui.h
This function forces the listing window to redisplay to show all
text that has been written to it. Long operations can use this to show
progress by writing to the listing window and periodically forcing an
update. However the update itself takes time so should only be done when
necessary as otherwise performance can suffer.
Internal
int UF_UI_update_listing_window
UF_UI_write_listing_window (view source)
Defined in: uf_ui_ugopen.h
Writes a character string to the Information window. You should add
your own new line after the string is placed. If in internal Open
API, text is displayed in the Information window. If in external
Open API, text is printed to standard out. The Information
window must be opened before you can write to it.
Once UF_terminate has completed in an external program, you can no
longer write to the console window. It must be reinitialized with system
calls.
Note: When running an internal Open API program (such as a dll with
predefined entry point, not a main executable), the code has no
knowledge of the application or process that launched the user
function program. Therefore all internal API's are treated as an
internal NX program and set the standard output to the listing window.
Any call to UF_UI_write_listing_window will attempt to write to the
listing window.
Consequently, if a GRIP batch program calls an internal Open application
that uses UF_UI_write_listing_window, it will not be able to find the
listing window and will raise an error. In cases where GRIP batch will
be calling an internal program, please use UF_print_syslog to write the
output to the syslog.
int UF_UI_write_listing_window
const char * string
| const char * | string | Input | pointer to character string |
