关于NX二次开发,经典界面到RIbbon界面转换的菜单开发技巧
2015-1-9 10:40| 发布者: admin| 查看: 6667| 评论: 0|原作者: admin
摘要: 关于NX二次开发,经典界面到RIbbon界面转换的菜单开发技巧 在经典界面下,需要的文件 customer_men.mencustomer_toolbar.tbr 在ribbon界面下你可能需要的文件 customer_men.mencustomer_tab.rtbcustomer_toolbar.t ...
经典界面到RIbbon界面转换
在经典界面下,需要的文件
  • customer_men.men
  • customer_toolbar.tbr
在ribbon界面下你可能需要的文件
  • customer_men.men
  • customer_tab.rtb
  • customer_toolbar_alternate.tbr
  • customer_group.grb
举例如下:
customer_men.men
!  Customer menu file
!  Contains button definitions to be used in
!  toolbars and Ribbon files
VERSION 120
EDIT UG_GATEWAY_MAIN_MENUBAR
TOP_MENU
    CASCADE_BUTTON CUSTOMER_MENU
    LABEL Customer Menu
END_OF_TOP_MENU
MENU CUSTOMER_MENU
    BUTTON CUSTOMER_BUTTON_1
    LABEL Menu Button1
        RIBBON_LABEL Ribbon Button1
        TOOLBAR_LABEL Toolbar Button1
    BITMAP fileopen
    BUTTON CUSTOMER_BUTTON_2
    LABEL Menu Button2
        RIBBON_LABEL Ribbon Button2
        TOOLBAR_LABEL Toolbar Button2
    BITMAP filesave
    BUTTON CUSTOMER_BUTTON_3
    LABEL Menu Button3
        RIBBON_LABEL Ribbon Button3
        TOOLBAR_LABEL Toolbar Button3
    BITMAP current_feature
    BUTTON CUSTOMER_BUTTON_4
    LABEL Menu Button4
        RIBBON_LABEL Ribbon Button4
        TOOLBAR_LABEL Toolbar Button4
    BITMAP block
    BUTTON CUSTOMER_BUTTON_5
    LABEL Menu Button5
        RIBBON_LABEL Ribbon Button5
        TOOLBAR_LABEL Toolbar Button5
    BITMAP checkgreen
END_OF_MENU
customer_ribbon_tab.rtb
!  Customer Ribbon Tab
!  This file will create a new customer tab containing three groups and
!  one top level button.
TITLE  Customer Tab
VERSION 170
!  The first group represents a Ribbon group that references an existing
!  toolbar with no Ribbon style changes.
!  This is the quickest way to add existing toolbar content into Ribbon mode.
GROUP  customer_toolbar.tbr
!  The second group represents a Ribbon group that references an existing
!  toolbar with Ribbon specific style changes added to it.  There is no difference
!  in how this toolbar is referenced in the .rtb file compared to the first
!  toolbar as a group.  The only differences from the first group exist within
!  the .tbr file itself.
!  This approach has advantages for customers that will deploy both Ribbon and
!  Classic Mode customizations since all the content is defined in the .tbr
!  file and it will stay synchronized in both modes.  Only one set of customizations
!  will need to be maintained while still making use of RIBBON_STYLE to
!  control the presentation of the buttons on the Ribbon.
GROUP  customer_toolbar_alternate.tbr
!  The third group represents a Ribbon group that has been created explicitly
!  as a Ribbon group and will not exist in Classic Toolbar mode.  This is the
!  preferred option since the user will be able to take advantage of all the
!  layout styles and containers offered by the Ribbon.
!  For customers that will deploy both Ribbon and Classic Mode customizations,
!  this approach will result in no synchronization and two sets of customizations
!  will need to be maintained.
!  A group can alternatively be defined directly inside the .rtb file by using the
!  keywords BEGIN_GROUP and END_GROUP.
GROUP  customer_group.grb
!  Example of a button that is placed directly on the Ribbon without being
!  contained in a group.  This is a simple way to add a button to a tab
!  but is not recommended for many buttons since groups have advantages.
!  A few advantages of groups:
!     1. Easier to move many buttons around together in quick customization.
!        For example, MB3 on a group and choose "Add to Left Border Bar".
!        This will move the whole group to a new location.  If buttons are
!        not in a group, they need to be moved one at a time.
!     2. Provide a label to describe its contents.
LABEL Button1 Directly on Tab
!  Customer Toolbar File
!  This is similar to an existing toolbar file containing
!  no Ribbon changes.
!  In Classic Toolbars mode - This toolbar will still show up in the
!     toolbars list.
!  In Ribbon mode - This toolbar will be automatically converted to a
!     Ribbon group and will appear in the "Classic Toolbars as Groups"
!     section in the Customize dialog.
TITLE Toolbar
VERSION 170
!  Customer Toolbar File (Alternate)
!  This is similar to an existing toolbar file with new
!  Ribbon styles added.
!  The RIBBON_STYLE will be honored when the toolbar is loaded
!  in Ribbon mode as a group but will be ignored when the toolbar
!  is displayed in Classic Toolbars mode.
!     toolbars list.
TITLE Toolbar (Alternate)
VERSION 170
LABEL Toolbar(Alt) Button1
RIBBON_STYLE LARGE_IMAGE
LABEL Toolbar(Alt) Button2
LABEL Toolbar(Alt) Button3
RIBBON_STYLE SMALL_IMAGE_AND_TEXT
LABEL Toolbar(Alt) Button4
LABEL Toolbar(Alt) Button5
customer_group.grb
!  Customer Ribbon Group File
!  In Classic Toolbars mode - This group will be unavailable
!  In Ribbon mode - This group will show up in the "All Groups" list
!     in the Customize dialog.
!  The labels of the buttons are defined using the RIBBON_LABEL token in the MEN files
TITLE Group
VERSION 170
!  No LABEL defined, using RIBBON_LABEL defined in customer_men.men
!  Example of a gallery defined in a GRB file.
!  If this gallery is to be used in other places, then it could be
!  defined in its own gallery (GLY) file and referenced here
!  Example:
!    GALLERY customer_gallery.gly
BEGIN_GALLERY  CUSTOMER_GALLERY
COLUMN_IN_RIBBON 2
COLUMN_IN_POPUP 2
LABEL Gallery
GALLERY_STYLE MEDIUM_IMAGE_AND_TEXT
END_GALLERY
