查看: 16682|回复: 29
[PLM之家Teamcenter官方教程] teamcenter 共享内存最佳实践Shared_Memory_Best_Practices
 火... [复制链接]
2477
发表于 2015-3-30 07:36:14 | 显示全部楼层 |阅读模式
; B0 v. h9 e( b) Y) Z1 L0 q
Shared_Memory_Best_Practices_Guide_V1.0  E0 A1 V! {  f* {3 ^: U
) B( H5 w8 X7 H4 W. D
7 I: k  ?# `3 r; J7 t7 {1 {2 b6 f
) i1 Y5 w( a5 o, R7 S+ g6 }Disable Shared Memory and RAC Metadata Cache
# P; m! c8 V; O# _$ }7 \If the shared memory population fails, or if a runtime error is suspected to be related to shared memory, you can
9 F' m+ S$ u# h, edisable shared memory functionality and set Teamcenter process back to its in-process memory mode by setting the
+ z2 {) M* M% l; }3 ^following env variables at server machines except for TC_SKIP_CLIENT_CACHE
! o0 ]3 e3 Z4 L- ^7 Q+ B- q( _* y6 V0 b! H9 P2 x$ G
1.  TC_NO_TEXTSRV_SHARED_MEMORY  / o, \: B7 I2 _. f6 p5 R9 O( V* s3 T
Set it to TRUE to disable shared memory for text server data.
5 u* Z. S5 M7 P( p7 i- b0 M" i9 q' t: k/ @" x: f! S; [
In Teamcenter release 11.2,  7 N/ j* K; d: {
TC_USE_TEXTSRV_SHARED_MEMORY
6 l* t( x* R; N, x8 ESet it to FALSE to disable shared memory for text server data.
0 z+ m% f4 x. j9 ?6 P3 r4 m( c7 V
2.  TC_USE_PREFS_SHARED_MEMORY  2 W+ [9 F9 X$ O
Set it to FALSE to disable shared memory for site preference data  : i: m) S9 o0 ?- |! T
! N1 r9 G- `5 W( d2 w* d0 J3.  TC_USE_LOV_SHARED_MEMORY  3 K9 f& l; j& c/ ^  @. E
Set it to FALSE to disable shared memory for localized LOV data  & K% c" Q& A  }7 W
/ |+ R. v% ]1 r4 s2 T  h9 O
4.  TC_USE_METADATA_SHARED_MEMORY
- Z( r( a3 W5 y" ]Set it to FALSE to disable shared memory for metadata  9 P8 ~  V" n& q* o  s6 F. |* r! R( @, _
If no metadata cache is pre-generated, the system will also disable shared memory for metadata. Therefore,
0 ]' q# ?6 ~1 C( p' H9 gto disable shared memory for metadata, you may run the utility: generate_metadata_cache –delete to delete " R, t: X( \% A. K$ M( {9 A
the metadata cache.
. E3 b; q9 Y8 f$ X% I
$ a/ J4 C$ x3 M5.  TC_SKIP_CLIENT_CACHE ) L5 d1 W2 X+ {/ d- R1 m
At RAC machine, set TC_SKIP_CLIENT_CACHE=TRUE to turn off Client Metadata Cache for RAC so that * Z* ?) l; K+ S) E* o+ s
RAC will always retrieve metadata from server.
! ?, c. C  ^( U( o9 N1 ?# H
3 v7 o& P) a3 z
发表于 2015-4-1 21:48:34 | 显示全部楼层
这个必须要学习一下!
发表于 2015-4-2 08:39:09 | 显示全部楼层
11.2楼主都开始研究了?官方没公布11啊
发表于 2015-5-11 19:17:40 | 显示全部楼层
看看,学习一下!
发表于 2015-6-22 09:14:39 | 显示全部楼层
谢谢!学习学习!
发表于 2015-9-3 02:12:59 | 显示全部楼层
xuexiyixia
发表于 2015-9-15 15:47:56 | 显示全部楼层
预览 [PLM之家Teamcenter官方教程] teamcenter 共享内存最佳实践Shared_Memory_Best_Practices
发表于 2015-9-29 10:11:35 | 显示全部楼层
这个好,就是英文的得慢慢看
