uc6400 (view source)
Defined in: uf_view.h
Erases an object from a view.
Flag
0 = OK
1 = View Does Not Exist
2 = Invalid Character In View Name
3 = Invalid Object Type
int uc6400
const char * cp1,
tag_t np2
| const char * | cp1 | Input | Name Of View (UF_OBJ_NAME_NCHARS character max) ""= Work View |
| tag_t | np2 | Input | Object identifier Of Object |
uc6401 (view source)
Convert a view dependent object to model
NOTE: An individual ordinate dimension cannot be converted to a
model object by itself. You may however convert an ordinate origin
and all its associated ordinate dimensions to model objects by setting
np2 = object identifier of the ordinate origin.
This user function will convert more object types to model dependent objects than
UF_VIEW_convert_to_model().
Flag
0 = OK
3 = Object Not View Dependent
4 = Ordinate Dimension cannot be converted
to a model object.
int uc6401
const char * cp1,
tag_t np2
| tag_t | np2 | Input | Object identifier Of Object To Convert To Model |
uc6402 (view source)
Convert model object to view dependent
view dependent object by itself. You may however convert an
ordinate origin and all its associated ordinate dimensions to view
dependent objects by setting np2 = object identifier of the ordinate
origin.
This user function will convert more object types to view dependent objects than
UF_VIEW_convert_to_view().
Flag
0 = OK
3 = Object Already View Dependent
4 = Object Not Eligible For View Dependence
5 = Operation not available when work part
and display part are different
6 = Ordinate Dimension cannot be converted
to a view dependent object.
int uc6402
const char * cp1,
tag_t np2
| tag_t | np2 | Input | Object ID Of The Object To Convert To View Dependent |
uc6403 (view source)
Removes the view dependent edits from an object.
Flag
0 = OK
3 = Object Not View Modified
int uc6403
const char * cp1,
tag_t np2
| const char * | cp1 | Input | Name of View (UF_OBJ_NAME_NCHARS character max) "" = Work View |
| tag_t | np2 | Input | Object identifier of the object |
uc6404 (view source)
Converts all view dependent objects to model.
Note: This user function uses the same object filter as that of the view
dependent edit functionality in interactive NX.
Flag
0 = OK
int uc6404
const char * cp1
uc6405 (view source)
Removes all view dependent edits from a view.
Flag
0 = OK
3 = No View Modifications Exist
int uc6405
const char * cp1
| const char * | cp1 | Input | Name Of View (UF_OBJ_NAME_NCHARS character max) "" = Work View |
uc6406 (view source)
Modify the COLOR/FONT/WIDTH of a curve in a view.
RP3 is the normalized start and stop parameters for the curve along
the normalized curve from 0.0 (beginning) to 1.0 (end). The curve
display is modified between the two specified limits.
Flag
0 = OK
3 = Invalid Color Number
4 = Invalid Font Number
5 = Invalid Width Number
6 = Invalid Object Type
7 = Data Base Limit ForObject View Mods Full
8 = Attempt To Erase Curve On Full Parameter - Use uc6400
int uc6406
const char * cp1,
tag_t np2,
double * rp3,
int ip4,
int ip5,
int ip6
| const char * | cp1 | Input | Name of the view (UF_OBJ_NAME_NCHARS character max) "" = Work View |
| tag_t | np2 | Input | Object ID of The object to be modified |
| double * | rp3 | Input | Start and end parameters of the modification 0.0 <= RP3[0 ..1] <= 1.0 |
| int | ip4 | Input | Modification color -1 = Do not change color 1-15 = Color number as defined in uf_obj.h |
| int | ip5 | Input | Modification font -1 = Do not change font 0 = Invisible 1-4 = Font number as defined in uf_obj.h |
| int | ip6 | Input | Modification width -1 = Do not change width 0-2 = Width Number as defined in uf_obj.h |
uc6408 (view source)
Returns view dependent edit data for an object.
Please use UF_VIEW_ask_vde_data rather than uc6408
int uc6408
tag_t np1,
int ip2,
char cr3 [ UF_OBJ_NAME_BUFSIZE ] ,
double * rr4,
int * ir5,
int * ir6,
int * ir7
| tag_t | np1 | Input | Object ID of view dependent object |
| int | ip2 | Input | Record number of modification |
| char | cr3 [ UF_OBJ_NAME_BUFSIZE ] | Output | View name |
| double * | rr4 | Output | Parameter Range Of Modification - Range (0.0,1.0) returns two doubles rr4[2] |
| int * | ir5 | Output | Color value, see uf_obj.h for values |
| int * | ir6 | Output | Font value, see uf_obj.h for values |
| int * | ir7 | Output | Width value, see uf_obj.h for values |
uc6409 (view source)
Returns view dependent status of an object and the associated view name when
the object is view dependent.
Drafting views will have a @0 appended to the end of the name (ViewName@0).
Modeling views will just conatin the name (ViewName).
Error Code
0 = Success
1 = Invalid Object Type
int uc6409
tag_t np1,
int * ir2,
| tag_t | np1 | Input | Object Identifier for view dependent status check |
| int * | ir2 | Output | Status for the object 0 = Not view dependent 1 = View dependent |
| char | cr3 [ UF_OBJ_NAME_BUFSIZE ] | Output | View name. This must be a buffer allocated to contain at least UF_OBJ_NAME_BUFSIZE bytes. |
uc6430 (view source)
Read View Center and Scale
If cp1 is blank, the work view is used.
Return Code
0 = OK
2 = Invalid View Name
int uc6430
const char * cp1,
double * rr2,
double * rr3
| const char * | cp1 | Input | View Name (UF_OBJ_NAME_NCHARS character max) "" = Work View |
| double * | rr2 | Output | View Center (Absolute CSYS) x,y and z coordinates. |
| double * | rr3 | Output | View Scale |
uc6431 (view source)
Set View Center and Scale
If cp1 is blank, the work view is updated. The scale must be greater
than 0.0. An invalid scale is an error and does not change the view
center. uc6431 can edit a non-active view.
Return Code
0 = OK
31 = Invalid Scale
int uc6431
const char * cp1,
double * rp2,
double rp3
| double * | rp2 | Input | View Center (Absolute CSYS), in x,y, and z coordinates |
| double | rp3 | Input | View Scale 0.0 = Use Existing Scale |
uc6432 (view source)
Fit the View(s)
If cp1 is blank and ip2=1, the work view is updated. If ip2=2, the
value in cp1 is ignored.
Return Code
0 = OK
9 = View Not Active
int uc6432
const char * cp1,
int ip2
| const char * | cp1 | Input | View name (UF_OBJ_NAME_NCHARS character max) "" = Work view |
| int | ip2 | Input | Fit option 1 = View named in cp1 2 = All active views |
uc6433 (view source)
Read View Matrix
Return Code
0 = OK
int uc6433
const char * cp1,
double * rr2
| double * | rr2 | Output | View matrix (Nine element array) |
uc6434 (view source)
Set View Matrix
If cp1 is blank, the work view is updated. The object Identifier in np3
must reference an object that has a coordinate system associated with
it, such as an arc, conic, drafting object, CSYS, etc.
Return Code
0 = OK
3 = View is a Drawing View or Drawing Member View
9 = View Not Active
31 = Invalid Type Object In np3
32 = Invalid Matrix In rp4
33 = Invalid Matrix Option
int uc6434
const char * cp1,
int ip2,
tag_t np3,
double rp4 [ 6 ]
| int | ip2 | Input | Matrix option 1 = Absolute csys 2 = WCS 3 = Use CSYS of object in np3 4 = Use matrix in rp4 |
| tag_t | np3 | Input | Object identifier (If ip2=3) |
| double | rp4 [ 6 ] | Input | This argument is used when ip2 is 4. In this case, this will be the X-axis and Y-axis of the matrix (6 element array). rp4[0..2] will be the X-axis values and rp4[3..5] will be the Y-Axis values. The Z axis of the view matrix will be internally calculated by taking the cross product of the two input axis. |
uc6435 (view source)
Rotate View Point around View Center
If cp1 is blank, the work view is updated. A compound rotation can be
accomplished by setting several values of rp2 to non-zero. Negative
angles are valid. The rotations are executed in the order of rp2[0],
rp2[1], rp2[2].
Return Code
0 = OK
9 = View Not Active
int uc6435
const char * cp1,
double * rp2
| double * | rp2 | Input | Rotation angles in degrees. [0] Down [1] Right [2] Counter-clockwise |
uc6436 (view source)
Read View Clipping Planes
If cp1 is blank, the work view is used. The values of rr3 are not
returned if the corresponding values of IR2 = 1.
NOTE: "Clipping Enabled by System" means NX
automatically detects that clipping planes are required and turns them on.
Return Code
0 = OK
int uc6436
const char * cp1,
int * ir2,
double * rr3
| int * | ir2 | Output | Clipping Plane Status ir[2] [0] Front 1 = Clipping Disabled 2 = Clipping Enabled by User 3 = Clipping Enabled by System [1] Back 1 = Clipping Disabled 2 = Clipping Enabled by User 3 = Clipping Enabled by System |
| double * | rr3 | Output | Clipping Plane Distance from the view origin [0] Front [1] Back |
uc6437 (view source)
Set View Clipping Planes
If cp1 is blank, the work view is updated. The values of rp3 are
ignored if the corresponding clipping plane is disabled (ip2) or
auto-set. Using auto-set calculates the plane to be the minimum (for
front plane) or maximum (for back plane) distance that displays all
objects.
You cannot disable clipping planes in a view that has 3D vectors (see
Uc6440 - Read view display type), and you cannot disable the front
clipping plane in perspective views (see uc6439 - Set view
perspective).
If the projection type is "PERSPECTIVE" and the front Z clipping
plane is in front of the EYE POINT (see uc6438 - Read view
perspective), the front Z clipping plane moves to the EYE POINT.
Return Codes of 33 and 34 are warnings only.
Return Code
0 = OK
3 = View Has 3D Vectors - Can Not
Remove Clipping Planes
9 = View Not Active
31 = Front Plane Behind Back Plane
33 = Perspective View - Can Not Remove
Front Plane
34 = Perspective View - Front Plane Moved
To Eye Point
int uc6437
const char * cp1,
int * ip2,
double * rp3
| int * | ip2 | Input | Clipping plane status [0] Front [1] Back 0 = Do not change status/distance 1 = Disable clipping 2 = Enable clipping 3 = Auto-set distance |
| double * | rp3 | Input | Clipping plane distance (If ip2[x] = 2) (From view origin) [0] Front [1] Back |
uc6438 (view source)
Read View Perspective
If cp1 is blank, the work view is used. rr3 is modified only if the
projection type is "perspective" (ir2=2).
Return Code
0 = OK
int uc6438
const char * cp1,
int * ir2,
double * rr3
| const char * | cp1 | Input | View name (UF_OBJ_NAME_NCHARS character max) "" = Work View |
| int * | ir2 | Output | Projection type 1 = Parallel 2 = Perspective |
| double * | rr3 | Output | Perspective distance (If ir2 = 2) |
uc6439 (view source)
Set View Perspective
If cp1 is blank, the work view is updated. The value of rp3 is used only
if ip2=2. The value of rp4 is used only if ip2=3.
If projection type is "PERSPECTIVE" and the EYE POINT is set to
be behind the current front Z clipping plane, the front Z clipping
plane is moved equal to the EYE POINT.
Return Code
0 = OK
3 = Drafting View Not Valid
9 = View Not Active
31 = Invalid Distance
32 = Invalid Projection Option
int uc6439
const char * cp1,
int ip2,
double rp3,
double * rp4
| int | ip2 | Input | Projection Option 1 = Make view parallel 2 = Make view perspective 3 = Change eye point |
| double | rp3 | Input | Perspective distance (If ip2=2) |
| double * | rp4 | Input | X, Y and Z coordinates of the Eye Point (Absolute CSYS) (If ip2=3) |
uc6440 (view source)
Return Code
0 = OK
int uc6440
const char * cp1,
int * ir2
| int * | ir2 | Output | Display type 2 = 2D display vectors 3 = 3D display vectors |
uc6442 (view source)
Read View Drawing Parameters
Return Code
0 = OK
3 = View Is A Drawing
int uc6442
const char * cp1,
double rr2 [ 3 ] ,
double * rr3
| double | rr2 [ 3 ] | Output | X, Y and Z of drawing reference point, (Absolute CSYS) |
| double * | rr3 | Output | Drawing scale |
uc6443 (view source)
Set view drawing parameters
If cp1 is blank, the work view is updated. The reference point and
scale are used to place a view on a drawing. The scale must be
greater than 0.0. UF6443 can edit a non-active view.
Return Code
0 = OK
4 = Not allowed in "Work in member view"
mode
31 = Invalid Scale
int uc6443
const char * cp1,
double * rp2,
double rp3
| double * | rp2 | Input | X, Y and Z coordinates of the drawing reference point in absolute coordinates. |
| double | rp3 | Input | Drawing scale 0.0 = No change |
uc6444 (view source)
Return Code
0 = OK
int uc6444
const char * cp1,
int * ir2,
int * ir3,
int * ir4,
int * ir5,
int * ir6,
int * ir7
| int * | ir2 | Output | Surface/Solid Face Display 1 = Grid Lines 2 = Solid Fill 3 = Flat Shading 4 = Gouraud Shading 5 = Phong Shading 6 = Hidden Surface |
| int * | ir3 | Output | Depth Cueing 1 = Off 2 = On |
| int * | ir4 | Output | Solid Unfixed Blends 1 = Visible 2 = Invisible |
| int * | ir5 | Output | Solid Smooth Edges 1 = Visible 2 = Invisible |
| int * | ir6 | Output | Solid Silhouettes 1 = Visible 2 = Invisible |
| int * | ir7 | Output | Solid Hidden Edges 1 = Visible 2 = Invisible 3 = Dashed |
uc6445 (view source)
Return Code
0 = OK
31 = Invalid Parameter
int uc6445
const char * cp1,
int ip2,
int ip3,
int ip4,
int ip5,
int ip6,
int ip7
| int | ip2 | Input | Surface/Solid Face Display 0 = Use Current Mode 1 = Grid Lines 2 = Solid Fill 3 = Flat Shading 4 = Gouraud Shading 5 = Phong Shading 6 = Hidden Surface |
| int | ip3 | Input | Depth Cueing 0 = Use Current Mode 1 = Off 2 = On |
| int | ip4 | Input | Solid Unfixed Blends 0 = Use Current Mode 1 = Visible 2 = Invisible |
| int | ip5 | Input | Solid Smooth Edges 0 = Use Current Mode 1 = Visible 2 = Invisible |
| int | ip6 | Input | Solid Silhouettes 0 = Use Current Mode 1 = Visible 2 = Invisible |
| int | ip7 | Input | Solid Hidden Edges 0 = Use Current Mode 1 = Visible 2 = Invisible 3 = Dashed |
uc6446 (view source)
Read View Layer Visibility Mask
If cp1 is blank, the work view is used. ir3 is returned only if ir2=2. For
example, if an individual layer visibility mask exists for this view.
NOTE: This routine does not read the global layer mask.
Return Code
0 = OK
int uc6446
const char * cp1,
int * ir2,
int * ir3
| int * | ir2 | Output | Mask Status 1 = Global 2 = Individual |
| int * | ir3 | Output | 256 word layer mask, indexed by layer number +1. So ir3[0] has the status of layer 1, ir3[1] has the status of layer 2 and so on. Each element of the array can have one of the following two values. 0 = Invisible In View 1 = Visible In View |
uc6447 (view source)
Set View Layer Visibility Mask
If cp1 is blank, the work view is used. If ip2=1, any existing view layer
visibility mask is deleted for this view. If ip2=2, a new layer visibility
mask is created if none exists. ip3 is used only if ip2=2. For example,
if an individual layer visibility mask is to be used for this view.
UF6447 can edit a non-active view.
NOTE: This routine does not affect the global layer mask (see
routines UF500x).
Return Code
0 = OK
31 = Invalid Mask Status
int uc6447
const char * cp1,
int ip2,
int * ip3
| int | ip2 | Input | Mask Status 1 = Global 2 = Individual |
| int * | ip3 | Input | 256 word layer mask, indexed by layer number +1. So ip3[0] has the status of layer 1, ip3[1] has the status of layer 2 and so on. Each element of the array can have one of the following two values. 0 = Invisible In View 1 = Visible In View |
uc6448 (view source)
Read Work View Name
Please use UF_VIEW_ask_work_view rather than uc6448.
work view name.
void uc6448
char cr1 [ UF_OBJ_NAME_BUFSIZE ]
| char | cr1 [ UF_OBJ_NAME_BUFSIZE ] | Output | View Name |
uc6449 (view source)
Change Work View
This function has no effect if a drawing is current.
Return Code
0 = OK
9 = View Not Active
int uc6449
const char * cp1
| const char * | cp1 | Input | View Name (UF_OBJ_NAME_NCHARS character max) |
uc6450 (view source)
Save View
cp1 is the name of the view to save. If cp1 is blank, the work view is
saved.
cp2 is the name to save the view as. If cp2 is blank, the view is saved
with the same name. If cp2 is not blank and a view of that name does
not exist, a new view is created. If cp2 is not blank and a view of that
name already exists, an error is returned.
ip3 and ip4 are used only if the view is saved with a new name (i.e.,
cp2 <>"" and cp2<> cp1).
NOTE: The view orientation is not changed for a "canned" view.
Return Code
0 = OK
4 = View Already Exists
9 = View Not Active
10 = Operation Not Allowed in "Work in
member View" mode
11 = Can't Save View because drawing is
currently displayed
23 = Can't Save Drawing View With New
Name
int uc6450
const char * cp1,
const char * cp2,
const int ip3,
const int ip4
| const char * | cp2 | Input | Name To Save View As (UF_OBJ_NAME_NCHARS character max) "" = Current Name |
| const int | ip3 | Input | Copy View Modifications 0 = No 1 = Yes |
| const int | ip4 | Input | Move View Dependent Objects 0 = No 1 = Move |
uc6454 (view source)
Delete View
Many views cannot be deleted. Among them are the "canned" views
and work view. If a view contains a drawing, it cannot be deleted. In
addition, any view that belongs to a layout cannot be deleted.
Return Code
0 = OK
3 = Cannot Delete Canned View
4 = Cannot Delete Work View
5 = Cannot Delete Drawing View
6 = Cannot delete view. View belongs to at
least one layout.
8 = Cannot delete view. View belongs to at
least one layout.
int uc6454
const char * cp1
uc6455 (view source)
Rename View
Please use UF_VIEW_rename rather than uc6455.
If cp1 is blank, the work view is renamed. The "canned" views cannot
be renamed. In addition, modeling views cannot be renamed as
drawing view names and vice versa.
Return Code
0 = OK
1 = Old View Does Not Exist
3 = Can Not Rename Canned View
4 = New View Already Exists
5 = Can Not Rename Drawing View
int uc6455
const char * cp1,
const char * cp2
| const char * | cp1 | Input | Old View Name (UF_OBJ_NAME_NCHARS character max) ""= Work View |
| const char * | cp2 | Input | New View Name (UF_OBJ_NAME_NCHARS character max) |
uc6456 (view source)
Cycle Views in Part
Please use UF_OBJ_cycle_objs_in_part with type UF_view_type rather than uc6456
This routine cycles the part and returns one view name per cycle. To
start the cycle, set CA1 to an empty string (""). The first
view name is returned in CA1. The next call returns the second view
name in CA1. When CA1 is returned with an empty string (ca1 returns ""),
all view names have been returned. View or drawing names that are
28 characters or less are appended with an "@n" string (where n is
any positive integer including zero). If your view name is more than 28
characters, the "@n" string is truncated.
NOTE: The cycle can be continued even if the view named in CA1 is
deleted.
Return Code
0 = OK
int uc6456
char ca1 [ UF_OBJ_NAME_BUFSIZE ] ,
int * ir2
| char | ca1 [ UF_OBJ_NAME_BUFSIZE ] | Input / Output | On input this is the view name returned by the last call to this routine. Pass in an empty string, "", to start cycling. On output this is the next view name. When all view names have been cycled, and empty string, "", will be returned. The calling program must allocate a UF_OBJ_NAME_BUFSIZE buffer to hold the view name. |
| int * | ir2 | Output | Active View Flag 0 = View Inactive 1 = View Active |
uc6457 (view source)
Cycle Objects in View
Please use UF_VIEW_cycle_objects rather than uc6457
If cp1 is blank, the work view is used. ip2=1 returns all objects which
are visible in the view. Objects which are out of the view bounds are
not returned.
Different types of cycles can be intermingled. For instance, while
cycling view dependent objects, you can also cycle objects erased in a
view. You cannot delete or un-erase objects or view modifications
during a cycle.
Warning: This function will return curves that are used to display a
solid silhouette in a drawing member view. Use UF_DRAW_ask_group_of_curve
on any curve returned to determine if the curve belongs to a
UF_solid_silhouette_type group.
NOTE: return/IR4=9 is valid only if ip2=1.
Return Code
0 = OK
9 = View Not Active
31 = Invalid Selection Option
int uc6457
const char * cp1,
int ip2,
tag_t * na3
| const char * | cp1 | Input | View Name (UF_OBJ_NAME_NCHARS character max) "" Work View |
| int | ip2 | Input | Object Selection 1 = Visible Objects 2 = View Dependent Objects 3 = Objects Erased In View 4 = Objects Modified In View |
| tag_t * | na3 | Input / Output | On input, the last object found by this routine. Pass in a NULL_TAG to start the cycle. On output the next object. A NULL_TAG is returned when the cycle is complete. |
UF_VIEW_add_to_view_set (view source)
Routine -
Description -
Add an orthographic view to view set
Return Codes -
ERROR_OK
UF_VIEW_INVALID_OBJECT
UF_VIEW_INVALID_VIEW_TAG
UF_VIEW_INVALID_ORIENTATION_TYPE
See Also -
UF_VIEW_create_view_set
UF_VIEW_remove_from_view_set
UF_VIEW_ask_view_set_by_name
UF_VIEW_ask_base_view_of_view_set
UF_VIEW_set_base_view_of_view_set
UF_VIEW_ask_views_of_view_set
UF_VIEW_delete_view_set
This routine is originally created in release NX3.0
int UF_VIEW_add_to_view_set
tag_t view_set_tag,
UF_VIEW_standard_orientation_t type
UF_VIEW_ask_base_view_of_view_set (view source)
Routine -
Description -
Query the base view of the given a view set
Return Codes -
ERROR_OK
See Also -
int UF_VIEW_ask_base_view_of_view_set
tag_t view_set_tag,
tag_t * base_view_tag
| tag_t | view_set_tag | Input | The view set |
| tag_t * | base_view_tag | Output | The base view of the view set |
UF_VIEW_ask_center (view source)
Ask View Center
If view is NULL_TAG, the work view is used.
The view center returned by this function is a point on the view plane at the
center of the viewing volume. If the viewing volume is symmetric (as it usually
is), then this point is also the view origin.
Return Code
0 = OK
2 = Invalid View Tag - can not find view object from given view tag
3 = center pointer is NULL
int UF_VIEW_ask_center
tag_t tag,
double center [ 3 ]
| tag_t | tag | Input | view tag |
| double | center [ 3 ] | Output | View Center (Absolute CSYS) x,y and z coordinates. |
UF_VIEW_ask_current_xy_clip (view source)
Returns the current X and Y clip boundaries of the given view. The clip
boundaries define a rectangle on the Z = 0 plane of View Space.
Please note the following:
The clip boundary returned is different to the one returned by
UF_VIEW_ask_xy_clip. UF_VIEW_ask_xy_clip return the boundary saved
in the data base for the view. UF_VIEW_ask_current_xy_clip return the
current boundary.
If the view is in the current layout, has been changed in
the layout (by, for example, a Zoom), and has not been saved since
it was changed, then the clip boundaries returned by this function
will reflect the changes.
This function is unusual in that, unlike most Open API
functions, the coordinate space is View Space. View Space is
parallel to the screen, with the center of the view at (0,0,0). The
view center is mapped from Absolute Space to View Space by
applying first the view rotation, then the view translation to it. The
scale in View Space is the same as in Absolute Space.
Internal
Original release was in NX5.0.
int UF_VIEW_ask_current_xy_clip
tag_t view_tag,
double xy_clip_bounds [ 4 ]
| tag_t | view_tag | Input | Tag of the view whose X-Y clip bounds are needed |
| double | xy_clip_bounds [ 4 ] | Output | Array of the bounds of the view, in view space (Minimum_X, Maximum_X, Minimum_Y, Maximum_Y) |
UF_VIEW_ask_fog_options (view source)
Returns the fog options of the specified view. The view must have type
UF_VIEW_MODEL_TYPE.
Originally released in NX4.0.
int UF_VIEW_ask_fog_options
tag_t view_tag,
UF_VIEW_fog_options_p_t fog_options
UF_VIEW_ask_perspective (view source)
Ask View Perspective
If view is NULL_TAG, the work view is used. distance is modified only if the
projection type is "perspective" (type = 2).
Return Code
0 = OK
3 = Either type or distance pointer is NULL
int UF_VIEW_ask_perspective
tag_t tag,
int * type,
double * distance
| int * | type | Output | Projection type 1 = Parallel 2 = Perspective |
| double * | distance | Output | Perspective distance (If type = 2) |
UF_VIEW_ask_rotation (view source)
Ask View matrix
Return Code
0 = OK
3 = matrix pointer is NULL
int UF_VIEW_ask_rotation
tag_t tag,
double matrix [ 9 ]
| double | matrix [ 9 ] | Output | View rotation matrix (nine element array) matrix[0..2] will be the X-axis of the view matrix[3. 5] will be the Y-axis matrix[6..8] will be the Z-axis |
UF_VIEW_ask_shaded_edge_options (view source)
Returns the shaded edge options of the specified view. The view
must have type UF_VIEW_MODEL_TYPE.
int UF_VIEW_ask_shaded_edge_options
tag_t view_tag,
UF_VIEW_shaded_edge_options_p_t shaded_edge_options
UF_VIEW_ask_surface_display_options (view source)
Returns the rendering style and the Edge display options of
the specified view. The view must have type UF_VIEW_MODEL_TYPE.
int UF_VIEW_ask_surface_display_options
tag_t view_tag,
UF_VIEW_rendering_style_p_t rendering_style,
UF_VIEW_edge_display_options_p_t edge_display_options
UF_VIEW_ask_tag_of_view_name (view source)
Gets the tag of an existing view that you specify by name.
int UF_VIEW_ask_tag_of_view_name
const char * view_name,
tag_t * view_tag
| const char * | view_name | Input | The view name (UF_OBJ_NAME_NCHARS character max); if blank, work view is used. |
| tag_t * | view_tag | Output | The corresponding view tag |
UF_VIEW_ask_type (view source)
This routine retrieves the type of the specified view.
int UF_VIEW_ask_type
tag_t view_tag,
UF_VIEW_type_t * type,
UF_VIEW_subtype_t * subtype
| tag_t | view_tag | Input | The specified view tag. |
| UF_VIEW_type_t * | type | Output | The view type. UF_VIEW_MODEL_TYPE = 0, UF_VIEW_DRAWING_MEMBER_TYPE = 1, UF_VIEW_DRAWING_SHEET_TYPE = 2 |
| UF_VIEW_subtype_t * | subtype | Output | The view subtype - drawing member views only. UF_VIEW_INVALID_SUBTYPE = -1, UF_VIEW_SECTION_SUBTYPE = 0, UF_VIEW_IMPORTED_SUBTYPE = 1, UF_VIEW_BASE_MEMBER_SUBTYPE = 2, UF_VIEW_ORTHOGONAL_SUBTYPE = 3, UF_VIEW_AUXILIARY_SUBTYPE = 4, UF_VIEW_DETAIL_SUBTYPE = 5, UF_VIEW_BREAK_SUBTYPE = 6 |
UF_VIEW_ask_vde_data (view source)
Retrieves the number of view dependent edits for an object, and the
corresponding data for each modification.
For example please refer to the
example
int UF_VIEW_ask_vde_data
tag_t object,
int * number_edits,
UF_VIEW_vde_data_p_t * vde_data
| tag_t | object | Input | Tag of object |
| int * | number_edits | Output | Number of view dependent edits for the object. |
| UF_VIEW_vde_data_p_t * | vde_data | Output to UF_*free* | Array of vde structures containing the view, color, font, width, and range of each of the view dependent edits. Use UF_free() to free the memory. |
UF_VIEW_ask_vde_data_with_type (view source)
Retrieve the number of view dependent edits for an object and the
corresponding edit types
int UF_VIEW_ask_vde_data_with_type
tag_t object,
int * number_edits,
UF_VIEW_vde_data_and_type_p_t * vde_data
| int * | number_edits | Output | Number of view dependent edits for object |
| UF_VIEW_vde_data_and_type_p_t * | vde_data | Output to UF_*free* | Array of vde type of each of the view dependent edits; use UF_free () to free memory |
UF_VIEW_ask_view_light (view source)
This function returns the lighting attributes of a single specified view.
Each view can have different lights assigned to it. The lights are now
shared between the NX hardware shading and Photo shading.
If no lights were found with the part, the following 2 default lights are
turned on in each view to ensure that shaded display is lit:
1. Light name: Default 1 Ambient
Light type: UF_VIEW_AMBIENT_LIGHT
2. Light name : Default 2 Up-Front Dist
Light type: UF_VIEW_DISTANT_LIGHT
Light mode: UF_VIEW_FIXED_TO_OBSERVER
Light Location: 0.8, 0.0, 0.4
Light to: 0.0, 0.0, 0.0
int UF_VIEW_ask_view_light
tag_t view,
UF_VIEW_lighting_t * view_light
UF_VIEW_ask_view_set_by_name (view source)
Routine -
Description -
Query the view set by the given name
Note -
The query is only against the current displayed part. If there is
no view set with the given name, a NULL_TAG is returned.
Return Codes -
ERROR_OK
UF_VIEW_INVALID_NAME
See Also -
int UF_VIEW_ask_view_set_by_name
const char * name,
tag_t * view_set
| const char * | name | Input | The view set name |
| tag_t * | view_set | Output | The view set match the name |
UF_VIEW_ask_views_of_view_set (view source)
Routine -
Description -
Query the list of views in a view set
Return Codes -
ERROR_OK
int UF_VIEW_ask_views_of_view_set
tag_t view_set_tag,
int * num_views,
tag_p_t * views_in_set
| int * | num_views | Output | The number of views in the set |
| tag_p_t * | views_in_set | Output to UF_*free* | The list of views in the set |
UF_VIEW_ask_visible_objects (view source)
Returns visible objects in a view broken down by those which are entirely
visible within the view and those which are visible but clipped by the view
boundary (i.e those which cross the view boundary).
Note that this function is primarily designed to work with drafting member
views. While it may be used with model views or drawing sheet views, the bounds
of those latter views are not considered in the outcome. The bounds of drafting
member views, including those with non-rectangular borders are considered.
Warning: When run in external mode, this function will return solids as visible
which are occluded by other solids in the specified view. For a drafting member
view, extracted edges may be used to force occlusion to be considered.
Originally released in V19.0
int UF_VIEW_ask_visible_objects
tag_t view,
int * n_visible,
tag_t * * visible,
int * n_clipped,
tag_t * * clipped
| tag_t | view | Input | The view to cycle in - if NULL_TAG, the work view is used |
| int * | n_visible | Output | The number of entirely visible objects |
| tag_t * * | visible | Output to UF_*free* | The list of entirely visible objects |
| int * | n_clipped | Output | The number of objects which cross the view boundary, yet some portion is visible |
| tag_t * * | clipped | Output to UF_*free* | The list of clipped objects |
UF_VIEW_ask_visualization (view source)
In the V15.0 release, new fields were added to the
UF_VIEW_visualization_t data structure.
In NX4.0, this function is superceded by
UF_VIEW_ask_surface_display_options and UF_VIEW_ask_fog_options.
int UF_VIEW_ask_visualization
tag_t view,
UF_VIEW_visualization_t * view_data
UF_VIEW_ask_work_view (view source)
This routine retrieves the work view tag.
This function was originally released in V16.0.
int UF_VIEW_ask_work_view
tag_t * work_view
| tag_t * | work_view | Output | Tag of work view |
UF_VIEW_ask_xy_clip (view source)
Returns the X and Y clip boundaries of the given view. The clip
This function is primarily intended for use by specialized
applications such as Translators. Please note the following:
The clip boundaries returned are those saved in the data base for
the view. If the view is in the current layout, has been changed in
do NOT reflect the changes.
If this is not what you need, consider using uc6431 (Read View
Center and Scale), which returns the current data for the view in
the layout, if it is in the layout, or otherwise returns the data for the
view from the data base.
int UF_VIEW_ask_xy_clip
tag_t view_tag,
UF_VIEW_ask_Z_clip (view source)
Ask View Z-Clipping Planes
The values of distance are not returned if the corresponding values of status = 1.
NOTE: "Clipping Enabled by System" means NX automatically detects that clipping
Return Code
0 = OK
3 = Either status or distance pointer is NULL
int UF_VIEW_ask_Z_clip
tag_t tag,
int status [ 2 ] ,
double distances [ 2 ]
| int | status [ 2 ] | Output | Clipping Plane Status status[2] [0] Front 1 = Clipping Disabled 2 = Clipping Enabled by User 3 = Clipping Enabled by System [1] Back 1 = Clipping Disabled 2 = Clipping Enabled by User 3 = Clipping Enabled by System |
| double | distances [ 2 ] | Output | Clipping Plane Distance from the view origin [0] Front [1] Back |
UF_VIEW_ask_zoom_scale (view source)
Defined in: uf_view_ugopenint.h
Retrieves the zoom scale of the specified view. This is the value
displayed on the Zoom View menu which is the current scale at which
the view is displayed. If there are multiple occurrences of the view in
the layout, only one arbitrary occurrence is retrieved.
The view must be on the current layout. On a drawing layout, the view
must be a drawing view or a member work view.
Internal
int UF_VIEW_ask_zoom_scale
tag_t view_tag,
double * scale
| tag_t | view_tag | Input | The view tag; if NULL_TAG, work view is used |
| double * | scale | Output | The scale for the view |
UF_VIEW_convert_to_model (view source)
This routine converts a view dependent object in the specified view
to the model.
dependent edit functionality in interactive NX; you cannot change it.
example
This function was originally released in V15.0.
int UF_VIEW_convert_to_model
tag_t view_tag,
tag_t object_tag
| tag_t | view_tag | Input | The tag of the view |
| tag_t | object_tag | Input | Tag of the view dependent object |
UF_VIEW_convert_to_view (view source)
Converts a model object to the view dependent object in the
specified view.
example
int UF_VIEW_convert_to_view
tag_t view_tag,
tag_t object_tag
| tag_t | object_tag | Input | The object tag. |
UF_VIEW_copy_view (view source)
Makes a copy of the given view, creating a new view.
The view_to_copy may or may not be currently displayed. The
new_view is NOT displayed by UF_VIEW_copy_view, but you can later
replace the new view into the layout, using uc6464.
The data for the copy is taken from the "saved" parameters of the
view, which are not necessarily the view parameters currently being
used for the view. For example, if UF_VIEW_rotate_view has been
used since the view was displayed, and the view has not been saved
since the call to UF_VIEW_rotate_view, then the saved parameters do
not include the effect of the rotation. If this is not what you want, you
might call uc6450 first, but note that uc6450 does not save a change to
the rotation of one of the eight "canned" views.
This function does not copy any view modifications made to objects in
view_to_copy to new_view. Any view-dependent objects defined in
view_to_copy are not moved to new_view but remain defined in
view_to_copy.
int UF_VIEW_copy_view
tag_t view_to_copy,
const char * name_of_new_view,
tag_p_t new_view
| tag_t | view_to_copy | Input | The tag of the view which you want to copy. This view may not be a drawing view, nor may it be a view on a drawing. |
| const char * | name_of_new_view | Input | The name of the new view. Must contain valid characters, must have no more than UF_OBJ_NAME_LEN characters. There must not already be a view of this name in the Displayed part. |
| tag_p_t | new_view | Output | The tag of the newly created view |
UF_VIEW_create_view_set (view source)
Routine -
Description -
Create a view set from a base view and a list of orthographic view types.
The view set created will reside in the same part as the base view does.
The view set contains a list of orthographic user defined modeling views
with one of the view as base view. All the other view's orientation are
determined by the base view. When base view changes its orientation, all
the other view's orientation will update accordingly.
Note -
The base_view_tag must be a user defined modeling view, it can not
be any canned views. The base_view_type and other_view_types must
be any one within UF_VIEW_standard_orientation_t
Return Codes -
ERROR_OK
UF_VIEW_CONFLICT_ORIENTATION_TYPE
UF_VIEW_NOT_IN_DISPLAYED_PART
See Also -
int UF_VIEW_create_view_set
const char * name,
tag_t base_view_tag,
UF_VIEW_standard_orientation_t base_view_type,
int num_other_views,
UF_VIEW_standard_orientation_p_t other_view_types,
tag_t * view_set_tag
| tag_t | base_view_tag | Input | The Base View in the Set |
| UF_VIEW_standard_orientation_t | base_view_type | Input | The Base View orthographic type |
| int | num_other_views | Input | The number of other views to add to the set |
| UF_VIEW_standard_orientation_p_t | other_view_types | Input | A list of other view types to add in the set |
| tag_t * | view_set_tag | Output | the view set object created |
UF_VIEW_cycle_objects (view source)
Cycle objects within a view.
A cycle type of UF_VIEW_VISIBLE_OBJECTS returns all objects which are
visible in the view; when using a cycle type of UF_VIEW_VISIBLE_OBJECTS,
objects which are outside of the view bounds are not returned. However,
non-rectangular boundaries of drafting member views are not considered
by UF_VIEW_cycle_objects. UF_VIEW_cycle_objects only works on the
rectangular boundary of the view - as though the breakline/detail
boundary was removed. If the desire is to obtain visible objects within a
drafting member view with non-rectangular borders and with respect to the
non-rectangular border itself, please refer to UF_VIEW_ask_visible_objects.
You must not delete, or un-erase objects, or add or remove view
modifications during a cycle as the resulting changes will cause the
outcome of the cycle to be unpredictable.
Do not attempt to delete objects when cycling the database in a loop. Problems
can occur when trying to read the next object when the current object has been
deleted. To delete objects, save an array with the objects in it, and then
when you have completed cycling, use UF_OBJ_delete_array_of_objects to delete
the saved array of objects.
Warning: This function can return objects which are visible within the specified view
but which are on layers other than the user-accessible layers of 1 - 256 inclusive.
Warning: For drafting member views with extracted edges on (Exact, Smart Lightweight, or Exact (Pre-NX 8.5)
with Extracted Edges toggle on) this function will not return solid
faces and edges because they are not visible.
Originally released in V18.0
int UF_VIEW_cycle_objects
tag_t view,
UF_VIEW_cycle_objects_t type,
tag_t * object
| UF_VIEW_cycle_objects_t | type | Input | Object Selection - one of: UF_VIEW_VISIBLE_OBJECTS UF_VIEW_DEPENDENT_OBJECTS UF_VIEW_ERASED_OBJECTS UF_VIEW_MODIFIED_OBJECTS |
| tag_t * | object | Input / Output | On input, the last object found by this routine. Pass in a NULL_TAG to start the cycle. On output, is set to the next object. A NULL_TAG is returned when the cycle is complete. |
UF_VIEW_delete (view source)
Deletes a view or returns an error code stating why view could not be
deleted.
void UF_VIEW_delete
tag_t view_obj_id,
int * error_flag
| tag_t | view_obj_id | Input | Object ID of view to delete |
| int * | error_flag | Output | Status code: 0 = Success 1 = Can not delete canned view 2 = Can not delete work view 3 = Can not delete drawing view 4 = Can not delete last view in canned lay. 5 = Can not delete sketch view 6 = Can not delete view, view belongs to at least one layout |
UF_VIEW_delete_view_set (view source)
Routine -
Description -
Delete the view set
Return Codes -
ERROR_OK
int UF_VIEW_delete_view_set
tag_t view_set_tag
UF_VIEW_edit_view_light (view source)
Sets the lighting attributes of a single specified light.
You cannot change the light type, light mode, or direction of the light with
this function.
This routine is originally created in release NX3.0.3
int UF_VIEW_edit_view_light
const UF_VIEW_light_name_t light_name,
UF_VIEW_light_attributes_p_t light_attrs
| const UF_VIEW_light_name_t | light_name | Input | Name of light to edit |
| UF_VIEW_light_attributes_p_t | light_attrs | Input | Data structure containing light attributes |
UF_VIEW_expand_view (view source)
Makes the specified view the work view then expands the view. If the
view is already expanded or if the current layout is a single view, then
the request is ignored. An active layout must exist. The view may be a
member view in a drawing layout. Expanding a drawing member view
is equivalent to entering the Work In Member View mode.
Internal
example
int UF_VIEW_expand_view
tag_t view_tag
UF_VIEW_expand_work_view (view source)
Expands the current work view. If the view was already expanded or if
the current layout is a single view, then the request is ignored. An
active layout must already exist. The layout cannot be a layout with a
drawing.
Internal
int UF_VIEW_expand_work_view
UF_VIEW_fit_view (view source)
Fits the geometry to the view by the specified fraction. A 1.00 fraction
means all geometry is fitted to the whole view (There is a small
fraction for padding). A 0.50 fraction is approximately a 1.00 fraction
fit plus a half scale. This is equivalent to changing the percentage on
the Display Preferences menu and doing a fit except the value is
specified differently. If there are multiple occurrences of the view in
the layout, only one arbitrary occurrence is changed.
Internal
int UF_VIEW_fit_view
tag_t view_tag,
double fraction
| double | fraction | Input | The fraction of the view from 0.0 to 1.0 |
UF_VIEW_is_expanded (view source)
Checks the expand state of the work view. If the current layout is a
single view, the returned value for expanded is false. An active layout
must currently exist. The expanded view may be a drawing member
view. Checking the expanded state of a drawing member view is
equivalent to checking the Work In Member View mode.
Internal
int UF_VIEW_is_expanded
logical * expanded
| logical * | expanded | Output | True if the work view is expanded, else false |
UF_VIEW_map_drawing_to_model (view source)
Maps a point in drawing space to absolute coordinates. Vectors cannot
be mapped using this function. This function maps from drawing member views
to model coordinates only. If the units of the part file and drawing are
different and the input point is in part units then scale the point to
the drawing units before calling this function.
Originally released in V16.0
int UF_VIEW_map_drawing_to_model
tag_t member_view,
double drawing_pt [ 2 ] ,
double model_pt [ 3 ]
| tag_t | member_view | Input | A Member View on drawing |
| double | drawing_pt [ 2 ] | Input | 2-D point on the drawing member view |
| double | model_pt [ 3 ] | Output | Point in absolute space |
UF_VIEW_map_model_to_drawing (view source)
Maps a point in absolute space to drawing coordinates. Vectors cannot
only. If the units of the part file and drawing are different then scale
the mapped point to the units of the part file where required.
int UF_VIEW_map_model_to_drawing
tag_t member_view,
double model_pt [ 3 ] ,
double map_pt [ 2 ]
| double | model_pt [ 3 ] | Input | Point in absolute space |
| double | map_pt [ 2 ] | Output | 2-D point on the drawing |
UF_VIEW_pan_view (view source)
Translates the specified view to the specified center. This has the
effect of changing the view origin with the View pull down menu and
does not trigger a regen. If there are multiple occurrences of the view
in the layout, only one arbitrary occurrence is translated.
Internal
int UF_VIEW_pan_view
tag_t view_tag,
double center [ 3 ]
| double | center [ 3 ] | Input | Coordinates in absolute space of the new center |
UF_VIEW_remove_from_view_set (view source)
Routine -
Description -
Remove an orthographic view from the view set
Return Codes -
ERROR_OK
See Also -
int UF_VIEW_remove_from_view_set
tag_t view_set_tag,
UF_VIEW_rename (view source)
Renames a view.
Originally released in V17.0
int UF_VIEW_rename
tag_t view,
const char * name
| tag_t | view | Input | The view that is to be renamed. |
| const char * | name | Input | The new name for the view. (UF_OBJ_NAME_NCHARS character max) |
UF_VIEW_restore_view (view source)
Restores the specified view to the parameters (original scale,
translation, and rotation) that were in effect at either the last reset of
restore data, the last view regen, the last fit, or view save operation.
This is the same as the restore option on the View menu. If there is
nothing to restore, the function is ignored. If there are multiple
occurrences of the view in the layout, only one arbitrary occurrence is
restored.
Internal
int UF_VIEW_restore_view
tag_t view_tag
UF_VIEW_rotate_view (view source)
Rotates the specified view using the view center as the origin of
rotation and about the axis specified in the view space.
It does not trigger a regen. Negative angle means clockwise direction.
If there are multiple occurrences of the view in the layout, only one
arbitrary occurrence is rotated. The view must be on the current layout.
The layout cannot be a layout with drawing.
Internal
int UF_VIEW_rotate_view
tag_t view_tag,
double axis [ 3 ] ,
double delta_angle,
int count
| tag_t | view_tag | Input | The view tag; if NULL_TAG, the work view is used |
| double | axis [ 3 ] | Input | X,Y,Z axis components in view space |
| double | delta_angle | Input | The angle in degrees |
| int | count | Input | The number of times to rotate |
UF_VIEW_rotate_view_abs_csys (view source)
Rotate the specified view using the specified center as origin of
rotation and about the specified axis. The center and the axis are
specified in absolute coordinates. This is the similar to
UF_VIEW_rotate_view but the user can specify the center in absolute
coordinates and the axis is in absolute coordinates. It does not trigger
a regen. A negative angle means rotation in the clockwise direction. If
The view must be on the current layout. The layout cannot be a layout
with drawing.
Internal
int UF_VIEW_rotate_view_abs_csys
tag_t view_tag,
double center [ 3 ] ,
double axis [ 3 ] ,
double delta_angle,
int count
| tag_t | view_tag | Input | The view tag; if NULL_TAG, the work view is used. |
| double | center [ 3 ] | Input | point in abs space |
| double | axis [ 3 ] | Input | X,Y,Z axis components in abs space |
UF_VIEW_save_all_active_views (view source)
Saves all "active" views (those in the current layout) and retains their
current names.
Original release was in V14.0.
int UF_VIEW_save_all_active_views
UF_VIEW_set_base_view_of_view_set (view source)
Routine -
Description -
Set a new base view in the set.
Return Codes -
ERROR_OK
int UF_VIEW_set_base_view_of_view_set
tag_t view_set_tag,
UF_VIEW_set_center (view source)
Set View Center
Return Code
0 = OK
int UF_VIEW_set_center
tag_t tag,
double center [ 3 ]
| double | center [ 3 ] | Input | View Center (Absolute CSYS) x,y and z coordinates. |
UF_VIEW_set_fog_options (view source)
Sets the fog options of the specified view. The view must have type
UF_VIEW_MODEL_TYPE.
int UF_VIEW_set_fog_options
tag_t view_tag,
UF_VIEW_set_perspective (view source)
If view is NULL_TAG, the work view is used. The value of distance is used only
if option = 2. The value of eye_point is used only if option = 3.
If the eye point is changed (option = 3), then the rotation matrix
of the view will also be changed.
Return Code
0 = OK
9 = View Not Active
32 = Invalid Projection Option (not equal to 1, 2, or 3)
int UF_VIEW_set_perspective
tag_t tag,
int option,
double distance,
double * eye
| tag_t | tag | Input | View tag |
| int | option | Input | Projection Option 1 = Make view parallel 2 = Make view perspective 3 = Change eye point |
| double | distance | Input | Perspective distance (If option=2) |
| double * | eye | Input | X, Y and Z coordinates of the Eye Point (Absolute CSYS) (If option =3) |
UF_VIEW_set_rotation (view source)
Set View matrix
The input axes do not have to be unit vectors. If the vectors are not
perpendicular, they will be made so by adjusting the Y-axis. An error
code = 32 will result if either of the input vectors is zero or if they
are parallel.
Return Code
0 = OK
9 = View Not Active
32 = Cross product of input X and Y axes is zero
int UF_VIEW_set_rotation
tag_t tag,
double axes [ 6 ]
| double | axes [ 6 ] | Input | View x and y axes (six element array) view_matrix[0..2] will be the X-axis values and view_matrix[3..5] will be the Y-Axis values. The Z axis of the view matrix will be internally calculated by taking the cross product of the two input axes. |
UF_VIEW_set_scale (view source)
Set View scale
Scales the specified view by the specified scale factor. This is the same
as changing the scale on the Zoom View menu and does not trigger a
re-gen. If there are multiple occurrences of the view in the layout, then
only one arbitrary occurrence is affected.
Return Code
0 = OK
1 = View does not exist
2 = Invalid view tag -- cannot find view object from given view tag
31 = Input scale value is less than or equal to zero
Internal
int UF_VIEW_set_scale
tag_t tag,
double scale
| tag_t | tag | Input | The view tag; if NULL_TAG, work view is used |
| double | scale | Input | A positive absolute scale factor |
UF_VIEW_set_shaded_edge_options (view source)
Sets the shaded edge options of the specified view. The view must
int UF_VIEW_set_shaded_edge_options
tag_t view_tag,
UF_VIEW_set_surface_display_options (view source)
Sets the rendering style and the edge display options of the
int UF_VIEW_set_surface_display_options
tag_t view_tag,
UF_VIEW_rendering_style_t rendering_style,
UF_VIEW_set_view_light (view source)
Sets the lighting attributes for a single specified view. The lights are now
automatically turned on in each view to ensure shaded display
becomes lit:
int UF_VIEW_set_view_light
tag_t view_tag,
| tag_t | view_tag | Input | Tag of view. NULL_TAG = Work View |
| UF_VIEW_lighting_t * | view_light | Input | Data structure containing view lighting parameters |
UF_VIEW_set_visualization (view source)
Sets all of the visualization data. If you pass a NULL_TAG to the view
argument, then the work view is used. This is not intended to work
for drawing member views. For drawing member views use UF_DRAW_set_view_display
Please use
UF_VIEW_set_surface_display_options and
UF_VIEW_set_fog_options instead.
UF_VIEW_visualization_s data structure.
UF_VIEW_set_surface_display_options and UF_VIEW_set_fog_options.
int UF_VIEW_set_visualization
tag_t view,
UF_VIEW_set_xy_clip (view source)
Sets the X and Y clip boundaries of the given view. The clip boundaries
define a rectangle in on the Z = 0 rectangle of View Space.
This function is primarily intended for use by specialized applications such
as Translators. It is a low-level access function which only modifies the
view's data base setting for the XY clip boundaries.
If the view is currently displayed, the display of the view is not modified by
this function, and if the view is later saved, the clip boundaries given to
this function are overwritten. If this is not what you need, consider using
uc6431 (Set View Center and Scale), which, for displayed views, modifies the
displayed parameters of the view (and not the data base parameters), and for
non-displayed views modifies the data base parameters of the view. Or,
consider using UF_VIEW_pan_view and/or UF_VIEW_zoom_view, which work only on
displayed views, without regenerating the display of the view.
This function is unusual in that, unlike most Open API functions, the
coordinate space is View Space. View Space is parallel to the screen, with
the center of the view at (0,0,0). The view center is mapped from Absolute
Space to View Space by applying first the view rotation, then the view
translation to it. The scale in View Space is the same as in Absolute Space.
int UF_VIEW_set_xy_clip
tag_t view_tag,
| tag_t | view_tag | Input | Tag of the view whose X-Y clip bounds are to be set |
| double | xy_clip_bounds [ 4 ] | Input | Array of the bounds of the view, in view space (Minimum_X, Maximum_X, Minimum_Y, Maximum_Y) |
UF_VIEW_set_Z_clip (view source)
Set View Z-Clipping Planes
If view is NULL_TAG, the work view is used. The values of distance are
ignored if the corresponding clipping plane is disabled (status) or
objects.
perspective).
Return Code
0 = OK
4 = Either status or distance pointer is NULL
9 = View Not Active
Front Plane
To Eye Point
int UF_VIEW_set_Z_clip
tag_t tag,
int status [ 2 ] ,
| int | status [ 2 ] | Input | Clipping plane status [0] Front [1] Back 0 = Do not change status/distance 1 = Disable clipping 2 = Enable clipping 3 = Auto-set distance |
| double | distances [ 2 ] | Input | Clipping plane distance (If status[i] = 2) (From view origin) [0] Front [1] Back |
UF_VIEW_unexpand_work_view (view source)
Unexpands the current work view. If the view is already unexpanded
or if the current layout is a single view then the request is ignored. An
active layout must currently exist. The layout can contain a drawing.
If the expanded view is a drawing member view, then the drawing is
restored. Unexpanding a drawing member view is equivalent to
exiting the Work In Member View mode.
Internal
int UF_VIEW_unexpand_work_view
UF_VIEW_update_view (view source)
Updates the display of the specified view when losses in resolution
occur due to zooming or any incorrect operations that may affect the
display. This is the same as the update option on the View menu. If
there is nothing to update, the function is ignored. If there are
multiple occurrences of the view in the layout, then only one arbitrary
occurrence is updated. The view must be on the current layout.
Internal
int UF_VIEW_update_view
tag_t view_tag
UF_VIEW_zoom_view (view source)
regen. If there are multiple occurrences of the view in the layout, then
Internal
int UF_VIEW_zoom_view
tag_t view_tag,
double scale
