Fixed Problem Reports( w' B3 \ n& x8 G5 f( b
NX 9.0.1
3 }+ y, B5 o/ [9 z" s n6 R ~ 9 M3 w) j8 h! _7 B, c( h5 q
+ y/ q( N: v7 D$ R. W
4 q$ D V- g; A+ z5 u; \0 S6 X9 S+ y
* e; t" A( A0 N: X6 ^ nPR
0 m, z( B( h3 `4 v 8 r) I* O2 t+ e' c
Description" }, M* {6 t9 [2 i- ^
* r8 S ~/ s" `& x. z0 y
1731187
3 y- b. _( g7 ^7 s1 p$ c9 o . O: K. M7 M3 m; f" N7 l
NX 6 assys - add component problem ! k/ q+ x) L5 J0 @+ ~
8 [" `+ p% @0 S, ?% y; v4 e
1785309/ Q: M9 P s% c0 d! g6 k
$ D4 g: P" ]8 s6 _$ `% e9 ]' Z
Wrong call to "MOM_list_user_defined_events" in obj_info_oper.TCl
& n/ s, o2 d' ]% k0 z1 V4 }
# e+ s$ ^0 C( G! a; n17865109 ~% g6 q/ z n1 Q! D9 D) k; Y- \5 i* C) ~
& H R. @+ Z! ~: b3 V
Add Existing Component with Preview OFF does not display Cylindrical CenterLine
1 Z1 ^: i8 N0 }# u' m8 P q- \
7 \0 w: a. y8 t. }1818129
$ E" j j8 X9 u2 P5 X$ e1 E
' F5 \1 {* ^ yNX Structure does not update Teamcenter CadBom when using custom item types " e+ i7 {: n9 ]9 j1 G2 b
2 P& M ?$ C8 C! Z* l& m& [* ]1822374
0 ` H( h! H) s( s& a% c
5 ?4 H' D% L4 T& x6 ICenterline invisible for preview component in main window during constraint pick
# k: H2 K2 ^4 U4 g6 A- O5 T& r: f! g
( n5 P& S* K2 e% C; ]) D4 _/ s1 ]1853289" O* ^, h8 B' m! X) P# ]
: f; q* a7 N6 E. ?0 T! ?; QPMI Balloons not displayed correctly when dimension is flipped
3 _9 U' w7 l, _# s$ z
- j( o& }4 b, g+ V8 C6 k4 d3 j' G8 U1853294) x6 H7 R6 `# M7 ~1 l
1 T& H% s, o/ J
Balloon Note PMI is displayed incorrectly in JT file ; J9 O3 z# p2 u4 J ]9 j) Y* _
7 R$ Q% b5 {; ] u( m18621518 W# f/ c/ A* T3 d. Z1 B
8 F) A3 X+ }( c1 V% B; dUG_opt_wizard license feature is not getting checked in
* N5 ]. X" @8 z% f( f6 _
+ w! C6 l! [/ V) q1877035$ | j2 t; \* y
0 r# B. E5 ^2 b9 y6 c1 ESurface finish symbol using the "din" font behaves incorrectly
# e4 d8 N6 K6 [( N" p! K# Y & e. r8 p" k- J- u
1877181
" u2 G0 Z2 t n+ n* w1 f( h ( N. x+ s' P1 x, T, H1 c
PS26.0.193: Performance of Project Along Face Normal is slow # F- l' C) Q* B- _
. d9 c9 h6 z. S! j# m- d2 A. U% G1883711
0 F0 L) U8 K% q- q) M }5 h2 x( Y3 I* Q$ M, |
(Better msg) SOA errors when a nx_integration license is not available
; j6 s- e; q; Z
6 W, z9 L( ~( W) V5 }+ b1885095
; l3 G, T3 }9 O7 Z6 J- R9 O * P: M) @3 A7 r2 y
OV NX8 CAM miss the "Display Direction Vectors" Toggle in Customer Defaults
$ \* [( F- m4 b5 K' ^* Q
: [! l, a3 [6 _& j( A18854245 e9 G8 p, c& A) E5 b) }% K
1 b) i4 _1 q4 o9 a& F
Error initializing pdi_corba_client library in SOA IIOP mode ! a* A; v) n# r C$ O
6 Y7 K R% F+ X1 ^; J1891074
+ g* ~7 H/ m9 I7 i6 m / }8 g/ L) M2 D, X1 I
ER: add ability to export CAM tools through NXOpen API
$ I4 G: q# b" u: k" z- f; D
5 K' H6 \; G! b- ]18963133 W' N. k a: T$ h0 y
: h* l" l4 b% s+ F4 n! [
Assembly Constraints: can't select temporary component centerline in main window# ^2 ? [0 S2 i' q, r
/ H) t3 E9 ?) m7 A
18963278 l6 u. w; J8 d: C
! m( { g6 s' {9 Z* Z# a F3 h/ U
$ p) _; N0 B5 n7 o# ~3 Q " l' `. z6 W% m$ {0 G) M. R
19045320 Y8 l# s0 v* _3 O* F; o' Z
4 X4 R) `9 X, r9 l- I7 m5 K; lReference "APPUID-OBJ" is missing when altrep is created in TC
6 @6 y$ J/ o% s8 c : [+ [, F1 K A% e
1905424
) p- `' x+ J9 h9 ~5 f % h$ I _( B! k) X$ l
Recognized Features are not valid after changing the Angle of a Datum Plane / ?* m" J, b: C
# K7 Y/ y5 H5 M& @( a
1906029
/ G4 @- O7 D: J N6 n# }2 F' A 7 L; @7 o, b' h3 [( ?% P8 z$ k
Radial dimensions in a sketch don't scale properly when zooming in and out
' C, j/ Y" a& @+ p" i ; `0 y: W: v9 o, h3 V
1906858
1 b0 ?+ ]9 S7 o& [& c
* D& b' j& x- P5 L, I R0 A2 OTurning : Stop position Point are Ignored in NX 7.5.5 and NX8.0.25 g3 Z# `8 l3 }7 M. u$ k, f
, } j$ u" ]4 P! ^+ [19070592 l3 C4 W T" ~8 w" r$ d s
( R! V3 _1 ]: B' O W: L
Dimensions loses associatively after "update views" p. r6 A' j2 m& T7 M
0 J8 M1 w: k+ A6 _9 i0 H2 s6 [1909482
- Q5 f* y9 Y! c3 Y, W6 b
$ V; f0 N+ E6 q) X' sCopy_Paste: Mapping Method - Create New creates dimensions with __ Used By...
3 u* ^ y0 C2 ?2 u# r8 y# T
' o8 t0 ]( @( |! l( ?1909813
0 E9 F; O, s! u0 [4 |" q 0 z: B' c% {' V( {/ l
NX 8.0.1, Crash when updating from NX 6 drawings opened as a Lightweight 6 W9 b# l, o( @- s
7 Q! Z. O0 E( ^: l8 l( G. h
1909938
) L9 r% r) h5 `& ~- l
7 T9 M+ T, [& } |Move + copy on mutually constrained components indicate constraint failure : S+ f4 `3 f) T$ u6 m/ ?; f
% W0 F3 y1 f4 d6 B1910505
& M# [/ v3 x! x5 E2 d! J6 A$ I * w8 J1 _: U7 r6 |+ \) {, N
Un-handled UG exception caught while importing STEP file % _0 ~" w$ X3 r2 Q' w% d+ T
, K% F0 p% U' j
19119740 W" k% W8 s9 a9 u r
: F4 r" B; H: Q, K$ IInherit PMI with all Geometry in the Reverence set still pops up message / K, [6 \) ^. B# p4 a% t e8 F. y
: i! u0 M% T* U. G4 E$ i4 J C
1912033" q; }4 j' n X1 l" c5 G
' H! W6 {9 f7 N B$ i ~
Editing an Associative Offset Datum CSYS gives wrong result 0 |; E. T! o' u, B- K. z
# b: F9 } p% D6 ~
1912478$ m9 i( w$ T* l& O1 s: S
# e0 H, [) O H8 O7 U, m. i5 o& W
Different style of PMI dimension in Modeling and Drafting 5 B3 f, }# O( k% Z$ Y- @
( E. T( t2 l5 `! j19157544 F9 M2 K4 G) g1 r2 {' R: J
2 u3 n% I4 {6 E( ?! v3 c; ?% r; {
Retained note: line width is changed
1 q8 i3 y) {5 y* [ |2 Z$ a 1 l, K$ w( W: A) }1 G/ ~6 ~3 W
19171445 c% J( z# h. a j, F: [. X3 L' K
' a( U% |" Q4 p C* S- h* IUse Common in Non Cutting Move doesn't Work as Expected
( h: ^8 P# S5 } 1 H7 g" I+ ?0 ]+ U; Q, V
1918722! K& J M: m7 \# U, z7 o
, H$ ~, G: q, p3 q4 a. d
Part family using linked body, create_update member does not update link * L: `( E( @+ j; f
, B* B3 e! l$ @1920506
. m5 A' H6 c' k8 M8 {
4 t9 C U, E$ p4 p" q; cRefit Face sets back Tolerance on Edit 8 W! z0 N1 z8 i' N4 n0 |+ J
7 D3 o1 Y( \% }$ P# O, \. Q
19209120 G) Z! x7 y+ s# Y9 @
# j* z# u! \3 R/ Q8 I
STEP file import fails and gives Error number: 1 5 F2 _5 a; p, U8 N9 z, |
. ^) F' t+ e+ D. ], Z6 Q# |
19229602 f8 D) g% V4 [1 ]! H
% M7 I, }* _/ f& ?8 `
Make Offset - Step function in View Section dialog work with Handle Dragging % @. W* V$ i1 O; W
! z# F5 A( c0 `; b2 Y( [1926270& I4 [1 u; F8 @/ y" c& Z% V
1 i7 E+ n$ S6 N1 _2 C4 T2 gEmpty mapped TC Date Attribute displays incorrectly as 00.01.00 in Pattern
: }# q1 b/ ~8 G2 j" g' L! Q + r( I; ^+ A: _; ]7 ~1 Z! Z
1926519
4 ?6 G2 l) ~! o/ E / Y/ @' h3 R1 R" m( D
Creating 1 weld point using the Weld Point-command with the Option Guide Curve ) k1 L0 g1 t; g9 c* ]+ y
/ @1 Y/ ]/ h4 ]* O4 ]+ Q1 N: U6 O
1927010
3 `- l" r$ E' D9 V* u ' c Y) ?5 a. d3 @) M
Read values for mom_feed_rate and mom_nxt_feed_rate are wrong
7 n0 M$ Z' k; E2 b
: t1 y9 _2 n, L4 ~ L19283524 X- p5 K8 t1 }0 U" s
9 o! d/ C2 i) f+ j1 r* ~8 ]2 F
Shipbuilding - unable to create ini file from flat pattern
+ r- x3 F7 M# c# Q, i
& l) H% |( r' e4 A0 o1 L1928560
& |: Q* J c% l# e 0 [' |: K( p; f! V$ ]1 O3 G
Many Alerts when testing migration of parts from NX 7.5 to NX 8.5
O# a1 Z0 S1 b+ r! I; k' z 5 |. u3 [6 O/ O7 c( v
19290774 k. a% G9 d; H
" v3 Q& e+ Y* e# VDRA: arrow out placement failed on arcs and circles
5 C6 ?- _) v; _$ |
- X# w B' l) b L1929181" s* T+ j" ], f+ W
7 W: M$ H! @, `6 n& w
New Function "Remove Machine" does not work as Customer expect
1 @" v5 S. m. _6 W. V b
* { l& @( B; |: K' W4 R" H% y1930768& R9 r9 y; F" Y' Q$ x# b0 g
* v9 _, i" D) c0 v/ s! \
Features.GetChildren() doesn't return a BOOLEAN child for both parents % M* b! V3 }" I6 L" P& F
! I. L5 r% Z# X/ i4 O- l% u" B
1932213
/ `5 G" X) \7 X0 `$ j% b ! [. Y, F2 p6 p9 p: G3 j4 @& u
NX 6 model in NX 8.5: Deleting tagged Feature does not delete the Face attributes
, N0 ^$ \& g( C+ L( j1 H
0 [1 f4 ^( W ^! W' x1932413
5 r/ k1 C8 X7 @0 w! C * T: |4 W8 f$ E0 x6 H
Invalid Result at API Feature. GetChildren() ! k5 h4 H( D: E+ P* l
5 K9 N: a; f. H4 b
1933295* f: H9 X8 y: O1 F# x/ C
) q: C0 O# p: F* ~0 K3 b0 Z
Performing a structure_update fails with Error: 515177 - An attempt was made to
G6 f1 n/ {/ S+ q' g1 T
1 K( q: {# o5 a* m; q1934148
) ^+ s4 v8 D1 W+ m ]! y+ s- T3 m. D" z
Part Attributes are not updating automatically in tabular note
% |' \9 r# p2 V' O3 [- E ) ]& `. y* N( c3 \# J
1934615* ]& y% e+ f) p; u, J
: { a5 f% |7 Y, E/ v, x- Q
Update of attributes in the mirrored part is not done if the mirrored part is
/ I' S# q' U6 }9 b " t( E2 \: c2 T' }* C7 ^
1936242
- D2 I3 q; a- U
$ F6 c9 N4 Q2 o0 q, HRNI Option 4 _ Native MultiCAD: WAVE Links "Out of Date" without modification
' A: q7 {% }1 M) } 4 J, j) w5 v ]- p8 l6 |3 a) f' r
19363159 X+ Y# p+ d* c" U9 i
7 b% l' i x7 i5 g/ BCAM NX 8.5 - Floor_Wall Mill - Tool Overhang Warning
- {8 N! x, p/ L; a0 a9 I ' R$ E3 l( l) H8 n) g1 @) Z1 J
1936844
% N( Y" r3 @3 @, A# i3 J8 {6 W0 F 3 S w- h( L8 X+ {
UF_MODL_create_symb_thread fails with Datum CSYS plane as start face & Z. ^5 U+ p' g2 L5 q+ _
/ F$ H2 w6 Z! C9 y1937056. Z% b! K) b' R, L( {$ l! f2 X' K
* U. v$ @( [% y8 h2 ?* d* uInternal Error when constraining assembly containing component arrays
/ l( u# N7 Z1 Q. a) W! m+ ]0 R % {$ P. h8 q3 p$ p' V7 ~
1937475- L- m& a" h# f- E1 W' t2 j% t3 z+ M
0 Z, p- z* J7 S2 a* s* V
Fail to open part, get message "Attribute units are invalid (not known in this phase)1 G9 e& ? u$ O- M3 B$ v9 \2 f
3 _$ ]- L/ v0 h: ~! M. _) P1937524
$ b% ~9 t6 M0 W% _% R3 Y
@, K# d4 K7 g/ LPS26.0.188::BodyDraft - Misaligned Faces
/ ~2 E; s2 ]2 Z) c& ` - ]3 }" F# A9 t0 g9 @: i9 R9 E
1937928
0 e0 K1 ~, x1 Y0 g0 ?+ c a, L+ g* W+ Z, E$ c
Feature lost in space after Make Current Feature # j0 \& ^+ F. r* b+ l2 U3 A+ G
" M% O! F! q$ e" c$ C1938523, H; d( S1 t& b, G4 w, u6 S& ~; T
1 ~, J* r% p% X, ~NX Motion Recurdyn Solver does not take friction into account " B" b: O4 U& A$ B( ~- `* T# W: M) w
+ g% W! Y. t' ^- r _! C1939317
& _# {: k K; B( ~
. Z. G) I5 B8 I/ q: ~( O1 wDisplay of material orientation vector directions is incorrect ( J/ d/ S+ a& p$ Y* N( T h4 X
& X7 k$ q7 _" X3 t+ J- i* G
19394309 }/ r3 {6 b# x. f3 X+ G
# h) r2 f% F0 K' Z
Stress results incorrect when plotted with respect to the material CSYS8 K) ^ T% C& k- |: Z
: w+ A z# P$ U. W3 E# u# m
1940021
7 V- T* o E$ x2 g( O8 G6 r 5 d0 F4 r/ r+ V9 O- b2 Y% p
Electrical Routing: Defect Sweeps II
" D# p8 C+ B. L9 C
$ i' P! o& r0 g& e; t1940261# ?4 ~4 ^6 Z! o* B- J% a. T6 u
7 c( X6 I; v* t& M8 b* v
JT ReferenceSet assignment not working
# e+ {' l8 ~' T S, `
0 t) f& E* J' y% o6 M, Z3 n1940267: J& M# Q- Y+ Z4 D" g2 L& E/ q
0 A3 m6 P7 D4 j0 l) w/ K& D
UFAssem.SetInstanceIntent() fails with 1530004 "Family attribute tag is invalid"
: @. T$ Y" @$ Z$ o9 V " A" ~6 g% T. P c) T) q* q! k
1940480$ K% W9 o1 x2 X5 S& |; U
& |' y( P' ?+ XNX 8.5 Save assembly omits partname of newer component part in error message
7 V! z0 f) n2 ^8 n. e7 q - ^ J, O3 Q- d F
1940561
* K4 b. ]; W5 i/ M# h9 W( ?
6 e9 c. z/ L$ p. l/ eCAM NX85 - Loss Of Warning Dialogue - Regression 6 R/ x# P, g7 P9 A
0 \, M( S. N1 C1 A
1940712% B9 O) w6 R/ {4 D3 _ Q( g4 v
/ m3 G! A$ D8 |; Y5 _' _Assembly Navigator position column show wrong symbol after adding std.comp
" ?1 _+ x6 F2 e& x* f6 p8 s
2 f4 G9 j5 R- |* A; C4 Q1940955
1 S7 q* [- x6 w# E! m 6 q2 R. W1 d+ S U, x2 {. h0 x
No output of transition profiles, notched profile, bend option in profile list % E& [+ ?3 J$ m( L9 b4 u5 a
* K H4 p, y2 e
1940975
. O6 z: K. c7 @0 B
$ {6 Q# u( Z. |6 UMemoryAccessViolation during Harness load operation
( U1 c% _: P; b) h8 s9 K9 H' c " D, u' V0 t, `, f$ n" q
19410100 b3 v. K4 d3 k) n2 c i
+ T' n( T7 M7 X6 ?; w4 {
RNI Option 4 _ Native MultiCAD: Lightweight Bodies of JTs shine through in Dra : p$ K; ]/ p# B4 i
9 g9 ]* V. s8 K0 V4 X1 N" K6 f
1941113
/ C3 K' ]9 X9 W: W
: S* J- }" _2 l) x) HView update removes manually added text in section line label as of NX 8
0 R" N2 k$ J+ t& }( A ( {% E$ C( \- k- ?/ T
1941263
9 r( O+ {. E! N4 m 4 a5 W7 T( N! g
Arc dimensioning flipping outside of graphic area
5 u: L" p) Q/ E& U+ o/ _8 O - h Z( n& k" s
1941363
" M( m6 D" }6 D 9 v# W5 A2 m% |( I8 f
Radial dimension not orientate as user defines , t6 ^( M; y2 y: G6 C6 t7 j- j4 J9 Z
. t; n% `- m# N5 D5 w
19417647 \7 f. M% N3 w
c# k M8 T- W+ f6 KCannot open old file under newer version NX 8
1 t3 e- ^$ {) M4 g. T" v
! G i5 e& ]. n ^9 `; H1942445
+ s8 f, P- a! D& ? $ X/ x9 I: u. ]8 h
NX stalls after trying to generate a Contour Profile Operation 0 c( m8 q' m0 x, Q
9 u: ?+ H0 j, M3 z$ r3 _" g7 \* b8 u1942600! c5 {6 B) V# K% E8 }
% E0 o5 T6 V. c3 z
UF_DRF_create_label() fails in NX 8.5 when using a face as attached object
& B% i1 d) L1 }# K5 z ! N% z% d6 Y3 t1 }& B4 s
1942607$ B( k, f8 l: j- x1 C0 l
+ L- D3 p" l! i; r$ Q. MExisting manually created material attributes " f5 ~; z5 T; p6 u% @; k+ R& g2 ~
$ M9 P: N" ]6 y! r! k# X& B! _1942701& E) _4 d& I b( e7 J y
' x! h( X/ S7 c! r) _ RPattern Feature with Variational Method
' G- o* T1 R( H6 Z2 r+ G% o 7 w$ L' Y! w0 l
1943260
/ J6 p- b3 B4 K 9 K+ C6 ~8 b: q, e+ }5 U
The Parser NUM doesn't work as expected |/ r9 g' H ]+ u- m
6 g; q- M5 S/ h& H3 N
1943610
) {: I7 Y. u- `8 R2 g! c$ f
% U6 G3 D) ]8 x. _/ z! \" iCAM Toolpaths regression on part TCH01000056454_A_MOD_AT_STAGE_D q" A% O, L. c$ F! n
# w" G( W% K4 {1 a: ~6 ]1943630
7 q$ s4 \2 I8 e
, Q3 ]( Q7 D' U; q7 c" F$ o& v" G% lCAM Toolpath regression on part TCH01000056454_A_MOD_AT_STAGE_I_NX75
7 Y( @# b8 A2 B3 u. s$ b
" y8 h5 ]( c; _* F; O5 k1943640- Q+ {# z- e- E0 j
) ^9 c% s$ y4 i, b: k5 I( [- Y) q
CAM Toolpath regression on part TCH01000056454_A_MOD_AT_STAGE_I_NX75 - l+ _8 {) g) h: j- R
- w7 Q, B% a3 R1 l4 v1943655
6 Y3 ]$ k) b: r$ d: h 8 z) {2 B6 V: e* y/ e C
CAM Toolpath regression on part TCH01000056454_A_MOD_AT_STAGE_I_NX9-trim_point.p3 r5 z9 ^5 Q* {0 Y- I
4 h) [: T% V( I& W6 M% X8 \3 q1943662/ u T+ w9 d" D8 ?8 Z) F. \
7 P2 b r$ w2 k( T( u5 a6 Q9 q) SWrong Attribute Notes value
6 v K' {" j; i( t1 Z
( n4 P/ L% k7 _2 ~# s+ m1944121
% h) v& ~0 O+ r# [# b { + V7 x/ U8 n8 l$ Z3 M
Place a base view results in modeler error
+ W( |% u z5 @
2 B2 e6 d( P8 h1944240# B) t* v8 ^: D
9 {, n% C; w8 s) FCannot get referenced object from associative text by NXOpen as of NX 8 ) X& T. u% A) r2 r. w$ f) o( o
" T3 V* x; C% Z1 ^' J) I& x
1944780
" p( A5 Z* H2 L7 i+ g9 Z
8 H) G9 @2 S- C# p z+ F2 ~Disappearing titleblock after a certain sequence of clicks 7 D+ W9 S' P+ {! u* J& `; T
' Q1 R4 a- I$ v3 \9 q8 @7 M5 H19449451 Q4 A. F1 r- N, v( O/ V6 p* [. `
. A1 G# K7 X+ c+ k" P) p% Q% `% O
Update very time-consuming if there are suppressed features
& `. H H" E- H3 C6 `2 l - a/ H1 W" x! Y& q2 Y, A
1945187
0 V9 W5 D( \; F7 [5 l
2 D) _! `; L4 ~Performance of Measurements during Motion
% w: f5 f; f) ~3 w! R0 J0 Q' u$ J
2 A3 J1 t# Q$ h S i6 i- }1945567, I9 n: S- | C9 s5 `1 y
/ o) [# P/ f5 ]' z# JPart fails to open, error - View type is invalid or unknown / |- R& u4 J* q' q- `
8 ~$ `0 v' h# p+ M19456827 x( }2 S' q4 { x0 t
2 y, L0 r/ O' r5 a4 z5 J
Original deformable component is maintained 1 Y+ w; ~+ @5 \& z9 h# ^% H
! D) n8 K0 S5 b/ A3 ]8 u1945695
) ~7 b' j* ]% _2 U8 g & f5 C6 c6 Z/ U: Y: D" J+ q
Internal error with electrical routing part - M- e2 a7 x# J5 d" p0 p! i& X
$ x6 {# s5 n+ L
1945708; m( P) Y; n% m y
. O: V9 p, S4 o3 v' Q3 B/ V# E: k% ` B
Dimensions are not updating correctly in exact view after replacing component 3 M* u5 ^% w: k4 R( O
# i1 | v6 {! L+ X) K
1945883( ^( i2 R$ E5 Q8 C) U
; f, P) r# @+ Z( {5 f: B4 U, R: pDuring replacing boundary face, the system ask to all wave links
, s! L% j; }1 U' h$ G / w: s* H+ @' B1 J% h
1945893
0 x7 d9 l& M* m; _' x / Q0 @6 e1 d- {1 [" f1 q/ j5 a& h
Up to Date Status is not correct especially when features reference Broken Links
6 P4 U) v# {5 q* \( i9 }0 l
9 b+ W2 w5 F) \" x1945903
5 z% D2 c8 J6 \/ p ( ~# _/ \. u; G6 o$ N$ Z7 D: w+ O
Wrong Result after Replacing one of 5 Instances within assembly . U7 K8 b: S5 F; V5 X, i8 d
$ q0 m0 u# K; `" L1 ]1945906
; E+ H! L$ h. j% b0 r) }& m; u/ t 6 m! l1 U. |3 e# Q9 }
Penetration direction not like TC Vis
+ P2 o0 s" r; \8 B - |. [/ E/ x: U& a9 ~/ j
1945924
* g5 s' ~. D8 P: k
7 L6 v) a/ r' F) f& h1 bPenetration depth fails when Entire Part used and MODEL ref set empty ) P+ f# O3 b$ y1 k3 o' `" O! j
Y1 ^$ D' L7 W3 n
1945936
1 U% m; s3 o' U8 K
3 P) u- k1 t: }, |Inserting new points into existing spline can cause spline to twist_knot
7 x4 k$ U7 t" l1 o1 W# Y) M % }8 B/ _4 t$ X' ~9 C& G3 l
1945938, a2 {* ]9 u1 \. A- b9 o" H
# @* y9 [3 `0 y. ]9 ^
Spline Path dialog always resets Selection bar to turn Point on Curve off
4 F4 X: H. O$ C) d, y% [2 ]# o7 S
9 g! x1 x5 |" J# I. l: y' ]1945945
% p+ {4 i' a0 J3 \- }
, k: q2 w# |- ]0 h9 w/ ZCGM Overlay cause NX to hang
( u2 T% o3 V9 F6 d6 S
' J2 C" i- z" J2 a% M1945958: h+ U( G6 t; a
5 ~+ J6 c( p7 Z7 {0 N
Axle Development - Performance of Measurements during Simulation 1 C# X- \! ]# n( s* v5 n- @. Z. P
9 O+ s, s' L/ c, g/ @! e- {1945995
- {! R; u9 `2 v& C- o: x
' f3 e1 l! i8 S! rReplace Component for component pattern master does not replace instances
" D! ?7 K6 Z7 I+ l L9 p5 x5 y2 K# Q$ ]+ C
1946035
& e `8 b! }9 q
; \- q" _' O% j" @9 n6 {4 bWarning on Model View Node is poorly worded
7 z% c) {" F# N: n ]0 P) t
8 e0 g( Y% R# L+ i. H( P19460762 j7 w0 s0 |( U2 c3 Q6 w7 b
D* S K/ P! _! Q7 FCannot name expression Product Interface ' G1 b5 ~8 a$ j) g% U* O
- y7 M3 M" a- @" I ^2 ?8 L+ K6 p7 O
1946091
. P6 p) q; i4 `( G7 ~: I8 X0 d1 Q ( q" X1 e2 R p2 ~8 Q% U
Interpart Expression Replace with Product Interface not possible
6 H9 a; j' [7 _" O. m/ ?) D2 D* A 8 Y4 Z& `3 l8 y, m" j6 O
1946125' O5 a9 M8 |7 G7 D
& M" t2 G: M# o
NX 8.5 Resource Bar windows flicker a lot, NX unworkable 0 z7 S( c2 o0 ~0 D4 J
2 b5 `* g; ~6 K i
1946230
# _4 E) F" x+ B0 k. {) C
4 Z9 Q' C* W8 t, zModify Angle of several selected Joint Marks changes only one
5 v) o) ~8 e- y0 W L1 ?2 n0 q+ Z0 r+ Z
19462442 A( g5 p$ y ~4 U" N N
! j! [& y+ {* {4 L% d
Deletion of one element from Joint Marks produces an error
& r5 i0 y; g& N2 x . s5 K$ Q% W# ~# |8 I6 R
19462851 Y. j9 [8 T& z3 e0 M% h% C7 f
( g" A" `7 Z' O; j4 B- jElements of Jointmarks FSET not in same Feature Group as Jointmarks itself
( O' p( L+ d& O9 ^( q
4 o! F' w/ P' \2 c2 D n+ w7 B2 Q5 O% c1946287) A J5 }' M D% U; S
" B, B: Q0 W$ d7 B9 F# D
Keep Selection Scope in Sketch Constraints inside Part Modules & M2 a, h! r) F) s$ l
& X- y' Q1 T6 o4 R1 r1 s
1946294/ X' G: T \! t9 X' y% _% A
" X X. y! G$ N- ]- SElements of Jointmarks FSET not in same Feature Group as Jointmarks itself 6 B( U* R# i. s$ V5 A
, F8 m9 F$ H: s4 F! `$ M# I8 \9 ]
1946305& l( }+ C" T& k
6 |6 y" ]0 O5 E2 m
Replay of NX 8.5 Face Blend fails 7 F8 c# z6 A# E
# |& n7 L# P4 {$ B" ^) h6 j
1946314. m3 Y* O) n: i7 S9 l5 @
3 O# G$ ?1 \, n3 d$ p; r
The performance of dragging Spline Paths is slower in NX 9 vs NX 8.5
/ f7 C5 Y5 @- u7 I4 l / H6 r" ^, h8 C3 F9 E6 W% y3 H* Q: J
1946319 D2 ]2 i5 t+ Z" |2 v
: g9 |& t X- y3 k6 Z4 ^8 B, H( sPlace Part using Absolute Origin causes Unexpected Null Pointer error2 |" w7 {7 r; N& S$ Y7 \, R% Y, ?7 [& q' u
& W8 a2 g3 C3 i) x1946357: j5 ]5 d8 K! K& _, O) A/ q
3 t# Z) U6 e$ a w% E4 k0 ^Joint Mark Mirror-Options does not show Face-finder option ! A" O# Z4 l2 T
2 \6 S, z. O6 q K1946370
, l8 }, h2 S, P6 ^ [ E$ L8 _) l4 H- V6 V$ L
It is not possible to change the symbol during edit a mark joint feature . [0 `' ~& C% x- m$ n
1 K/ z; b: {& N, @' O0 U
1946383
9 o8 o5 u" H0 d0 b * ?2 i( v3 p, r$ K
Not Possible to finish a Feature Playback % D/ u2 V, z% B7 @6 M
: A* Q% @" d' M6 t/ t1946435. Y ?1 {% Q4 {6 q1 ?. z
/ T/ L1 r2 V8 i, Y0 y
Laser profile operation gives modeler error when Verifying Toolpath
- x: r. T9 s& t. t1 F( f " [5 |/ ~: {, H n5 h
19465214 i2 `' q& W2 D' \7 a5 L/ }. F, `. u
# h& ?% |) T$ x, B4 o
Editing parameters for a Sketch, doesn't update the model
& e( g1 a+ l; Q& o1 w) N
7 _0 J# u8 c/ J h' P19466523 f* W% P0 b# I7 T7 S# P
4 p$ K6 ^# |1 Z% ]* ~# U; sCAM Toolpath regression on part TCH01000089177_E, missing dwell
% b8 T/ D+ N5 G, J # N$ M+ B( S. V/ k# D& i; t
1946839
, x( @9 k3 |. f; O* K3 ?8 x
' P# Z; ?& M) B$ z6 wAutomatic Spun-Outline for Partgeometry does not work
7 b* |" D4 H; D # B g; L b7 P" p1 l9 d$ k$ j9 F1 o
1946865
& t2 a$ h2 x2 X) Y / O- P8 a- `5 T$ }. ?
PS26.00.173 Fix: Bad unite in NX 9
8 u4 |1 t7 R: U, l% [, `: @, @+ n
% e" W5 B/ {( C1 m$ W1 A4 H1946988
" N l) C! {2 x # Q2 O/ m1 v& Q/ M8 o
Fillet Weld "First leg" parameter got inconsistent decimal separator when listed5 B. ?% [, }# e" L( v
' W- _. z8 V6 ]5 D4 E: A$ }& A
19470929 p3 y. |- y- q- D
8 U! R6 u# \( z9 |/ L
Polygon body does not update
' f) J' ~/ E% m; [- }2 Q. g( o * l' Y' ^, V3 F' |& P/ z3 j
1947198
7 q. @% i6 m! f2 w4 r& h' j ) u5 E' r$ [2 \$ [: w. ], R
Bei Baugruppen wird kein neues Model Reference Set beim Speichern erzeugt . l8 v1 H5 X* Z3 ~
! E5 n1 J: n! U9 t( v6 M1947342( w1 X$ S: p$ E
: w4 }1 Z9 K- b. [& q
Fillet Limits does not allow expressions# Q3 ]$ Q* A5 p
9 H9 [$ P" N; ? W1 U7 ~1947633/ J) `% B# m- t) P9 d7 w. s
9 N# _/ _9 ?' g& x, @$ p" n: k
Running ugtopv.exe does not report INFO 3110 and 3180 messages
% r" f* u# A+ o9 E. R7 U. [ ( c- j% @- a5 h3 ]5 M* r4 l" b% ?9 S
1947706
- u" p+ U4 u$ U # q2 B( X! T7 l! D9 c
Non assigned mapped date attribute evaluates to "00-Jan-0" in NX pattern
s7 m% [2 i- X. C+ _, b$ U
- u3 w6 j# n+ w4 M1947952
" n0 X" q# Q% w - d( E. V9 z- }
NX inaccurate view representation
6 p! T7 ]& {$ ~+ Y2 j0 t$ V" [- [( g
8 D4 @! i. P$ p4 p' v% d1948060
# s" n w/ n4 E( V 2 v/ G* D% d% ]8 y6 ]3 Q/ t ]1 }
In section view also non-visible elements can be selected
* Y( v- C$ e' Y2 z+ \8 [( U
, e* _) I9 ]% i1948111$ Z0 |9 M/ o0 O6 B. p; _$ P
$ |5 N! a" b/ K* G$ Q1 |
Unexpected behavior of Diameter Dimensions when zooming in 2 x0 r: Y" W+ \8 [/ c% \
& W2 ~! I+ [1 k7 d w! t' l: t- e
1948478
' C6 \# O" ]% i. q8 E
& V* C7 C: G/ Q; @+ I) |3 pNX load_options.def causes dxfdwg.exe to crash
9 ?& K2 T4 s* g& P1 ?0 ]' }- z
8 }: L9 ~+ Q- t$ X1948482# @" g3 V7 j h
. |$ C2 V! s0 l9 P# ]: Z6 H! vInternal error: memory access violation updating views $ J# z3 m( e4 R) A. _! j; }9 Q
N2 r5 h8 K$ c" ^1948582
8 d h% I z0 [$ L+ l
# H/ e4 _3 [" |6 T# L3 @+ _NX motion export - wrong IDs in vfm result + ~$ H9 m3 r: f
! b6 Q5 \4 `) B$ m n; v' I8 T1948590
3 e$ W" R/ O" C' ]+ m7 Q' | , J- j0 X( d7 t/ w2 U
Floor_Wall milling not honour exact positioning when unilateral in_out tol used
/ o1 \$ u7 x5 O6 J 5 R& @2 ?5 ]0 \% J: X7 r2 B6 K
1948660& I4 L2 g7 N3 U6 ^
% S2 f1 T$ E. v% \2 w- [" p _6 N5 V1 TInternal NX crashes when creating drafting views : b- j. i5 [+ D% X
p$ j. H0 p* i! n9 ^6 S1948717* ]: V/ G3 a4 E. u/ W' s
! V- P7 E2 ^8 W, [) N+ _1 V2 CWeld Solid Attribute deleted on Update ( j- ` g- N+ N+ @. l+ h
, _' _% e: h8 c7 [; q0 v7 w! j
1948763
! J, I/ B e& }- N, G
; v7 Y+ a5 g* _$ D6 \- KDXF DWG: export from existing part to 2D -> Encountered unexpected NULL pointer
0 C$ H* E& n( w. L' p 1 v9 F7 h H1 e+ F. B8 r4 R+ z0 D
1948809" q* T) g6 c2 b. ]* f' V
2 }( a2 r( q$ \) |3 H
Appended dimension text moved to wrong position in exported dwg
7 }- s* _' x+ y% B 6 X$ n+ e8 v7 {/ s7 O
1948870
2 p. }6 q4 }# V. C# i 1 Z) O! U; n/ V4 m+ z
Shape of law extension face is not correct
! g; k- X, L% B3 Z; Q9 v4 A5 S % h5 Z+ J. P' b: |9 R- k
19488890 F' F# v1 `- {2 a( x
. y: t1 J5 P# P# K: EWrong dimension value after opening part with GRIP FETCH_PART
) H* `5 w: m1 C1 m* ~6 q
/ _7 `; t9 \2 e5 v7 m5 I1948977
% D7 a9 ~5 g( B+ P9 `
# G8 o! d) Y$ e7 v% W6 Y1 M7 {4 S! RFormulas in Base Data (Vehicle architecture) input are lost % E7 O$ N1 ^/ A
$ y' U/ v) H& P+ F* Z9 j1949013$ H" D: ~/ z# d- G
, w9 z# ~* s9 _
RNI Option 4 _ Native MultiCAD: Position Dependent WAVE Link to Body breaks
8 s! h, {% S$ v& ]1 k1 H; U0 @ . g$ L6 K! d& T" y+ ?8 z# d, O
1949061/ d6 ]! [/ x: ~: Q9 v
# y9 v2 R0 j) w& K* EAbaqusExport - ELSET and NSET name are not admitted in Abaqus 3 z* x5 _, g6 {0 }
# g$ W( l. V8 c" f* h
1949146
h7 H) ?8 r/ R7 \ ; W6 T8 | Q( a: ~5 `" ?- J1 c
LOV does not show in the NX Manager Portal from the Pulldown * C/ b% [" n4 x- Y( [" R
6 o+ v/ j# F' K
1949246
H$ w2 F1 s$ j
0 q1 K3 \; `5 @2 jError message during deriving of a Model View to a drawing
D! @/ k5 n4 |+ s% N( f/ i5 i0 } ; O; w$ f) V; U m8 t7 V& s
1949257
9 Q9 c. e; p$ A6 |( l) c * H* L" _9 w, _) f' X- S. `2 b( w
External Spreadsheet Functions ug_list_hlookup and ug_list_vlookup do not work * z: s" W- m: I& B1 `+ U0 P
9 j# T. Z9 l- i2 ~1949279
, `$ F! H) z# x9 C ( b1 e' b$ m% [' B1 D) K0 i( J
Neutral factor is not grayed out when global value is used 6 H3 G8 V* H% v( E. z% S5 g
5 Y! ~# ?9 O C5 _8 {- A S
19492952 `+ ?5 o$ o2 n/ D+ @" m
! i9 Y( s' I0 {: F+ I. UNX crashes while exporting a JT File with "3" character Text feature in Osifont & w- ~7 C' [ ~ v" `9 [
" Q9 `; _' o3 w3 A7 V8 N$ X
1949324
* m4 \# M) u& Z! |7 X6 t! i ] & H; p# r4 c$ m2 S1 p/ | H
ClassificationAdmin GraphicBuilder don't update geometrical STRING Attributes & S1 u, v+ K5 x2 N
# G$ R Z6 _& Z# K; ~# S2 R4 \1949339* t0 ~$ F; l [+ h. J# e& w- o
9 b* n6 D4 r; n& Q* w
Display of section line letters changes when updating view
t* ?7 q$ `9 _& H . _ w( E4 e3 m; H& @* W" a7 }
1949343
) B, V8 t" `. P0 V- Y * d. W, o, V. e4 T& q0 v/ H
Time consuming update of Expressions with access to EXCEL
9 m1 W& ^. G: s) g/ \0 l c! _" }* `9 [. N3 }- q7 t: t
1949409
. o/ g; G5 @6 u V" f% s) s6 D) \ X R; u& z# i2 x4 x
Insert reusable part on a face removed midpoint constraints in sketch
+ J# y' p! }6 Y
; R2 }0 s+ D, q9 E+ e! L1 ~6 S1949441
- ], E0 v# _5 {. X0 w+ R
* _- Z# r( d( y, ]* wTracking Point changes its position after generate operation under a new tool 3 ]. a6 C' y9 ^# h: E. b& u& g) Q
5 o- A1 G2 F& [7 z
1949499% w4 o$ c, A" l( m1 w
3 N- E: w: K# Y @5 _: o
Electrode Drawing fails with "Incorrect object for this operation" & o, K7 _# i% D! t
1 M2 k, @) h) V& ^7 H, U0 X1949564: r- f0 f6 A! i2 ^
# I( h6 o4 }. K+ t
Point, Offset Along Curve, Associativity lost after edit 0 ^2 T8 y. c" i. F8 p: J0 b& p
5 F: w9 C3 V0 p/ U5 z0 P( o" q- K# [
1949760
5 u' \4 K& C! q7 c* Z% w" z( e 3 c1 m0 N& H& X: ^5 N& k, X
Parallel generate Causing Teamcenter to Crash 9 Z* l' p, X7 _2 l+ t, Y
+ R7 D. `! A1 C2 |" A, {$ {- Q
19497771 ]% L3 _" f; l
# x+ h+ C1 ?' ^8 H1 JEVENT CUTCOM CUT3DC - Incorrect move
: i6 h7 O) ^7 {1 D& a U# G- {+ W* W0 P 0 i; A% n, Y5 a" E. }' _
1949801+ n5 f. u, P" r. H( A" A( c
3 A3 m* E( m" ^" gNX 8.5 crashes when editing an existing circular pattern
: c# [; ]" _! f# V6 ~
4 T+ |8 W) J/ E4 P1949811; o6 Z8 T6 p7 i! }0 u1 J
0 `0 e3 {( n& ~, ~( e3 e( A
5 Z8 a( s' P# J! M2 [0 X4 s3 O
, k& p& D9 r) S: C O1 R2 M1949829; [$ ` c2 X% o$ j; ?. c
! i2 K. ~* w* [" _2 w7 x0 yDimensioning to a center mark takes a long time
. U f F9 ^( P- v
4 j7 _- j# ^9 B7 L+ o0 C1949863
' i! _! \& S/ c' Q+ g! u8 a
0 [% A" Z3 m4 X3 y& hPS26.00.179 - Edge Blend does not work on tiny faces
7 g; y) \* a1 t C# U 3 O% C* p v; A. A/ C0 H+ q- `
1949865' m- J- {1 g4 p# v$ I5 t1 z J/ a
s {' v# G8 t+ N" v2 h* R$ S& p( wNX unable to define vector after interruption of the Project Curve 9 c1 {5 F4 h( D, e, }& V
$ h7 T9 ~( P) w5 ]5 h- z
1949870
: _$ A1 O& p' t- w ! G; a4 l8 J6 v, ?
Update with feature playback causes file size increase , e6 H6 K+ \3 B3 I/ O& x- w0 f
' y) m: C6 b0 x$ A- r- \1950043
& R0 T/ {% z9 p0 B: Y ; |, M O: A& t0 T/ I; a7 Y
REGRESSION: NX 8.5 load parent problem r1 N) T/ n3 k* t. g
% M" U% P0 E8 N+ O' b1950104$ Y4 X. Z" ` Q5 ]( W( ?5 [
7 Y T6 Q/ ^: GPDW: Cannot clone Die Base from TC to TC in NX 8.5 " l( k: _8 g' o% r/ }, W
: Q5 v4 w. p! Z( r4 v2 B2 i
1950193- x/ n; B3 ~% ~
% G& _8 p- Q' W: d! L$ g. J, V
CAM NX 8.5 - ZLevel Profile Violating Check Geometry0 h! L6 w9 t, K: B. d
a( s: G) X- L! H: X* W
1950238
* y0 e) l* O4 o& U+ U# _; [
, o% T" s+ x6 z0 e( JCylindrical Dimension value switch by positioning + |! X) z! t9 O& j
, X2 A% Q% Z, [1950243+ a( q7 U1 J( \0 w, v8 U5 l) p
+ j \' I4 k- o/ j+ g1 d1 OThe process cannot access the file because it is being used by another process # l6 R& |5 v* X
: T. `1 L% @! K
1950303
& z2 k1 \1 I/ p2 r" G ^ l" b+ {: Y/ m/ G& s
Inconsistent DraftBody Behavior
( ~8 M+ i7 X* V. g. D - [1 f2 ]; S& o! B
1950306
+ A, b s3 o7 n. z8 `( a* n. F
0 f0 G* c% z& J) c4 zAngle Dimension on 2D Centerline , e0 c( o3 S' c) |
: N3 k1 d( ~7 e
19503077 U. v, g. `) |9 v4 d. ?/ Y9 d5 F6 [9 V
& G( E. B" g" j+ }% w# oWrong visualization of Smooth edges 1 m1 i( m Y- A5 j; e
5 E7 B2 N: D8 o6 }! ~( V1950389
3 n1 N* b- N0 x, G9 m$ I# x% ?4 v7 e 7 A) e. a. D) R) i- v
Incorrect interior Cutout after creating Flat Pattern of a Drawn Cutout , a S! X; Q7 Z$ M
8 m5 e1 E0 a; z7 Y# C4 s+ |! {
1950443% I& q8 f; B1 n$ t
2 a3 R0 A3 \7 F
Dimensions loose associativity after Replace Component / d! V" \% {9 ^: V0 d/ Q
+ z: s: N4 v$ U- W$ O1950508( R; j- [* k5 }
4 r K- ^5 M5 k
Beta NX 9: Subdivision Modeling Show and Hide Body * d1 J) b4 ]7 l$ J g3 `
. L/ t- ?+ L0 n! q/ w/ t19506170 x" X+ X2 y+ q4 P
: ^8 l1 S; A7 a; c0 B2 l3 C% p
Weld ID not unique on import
7 _ ?) Y- c8 k/ A& _2 a ; R1 ?9 S* S, T& O
1950730
& [4 s" w& B" b& X- I$ d 6 B9 V" ]) L" d+ \0 p8 S
Drawing from Wireframe very slow using new exact view -> Working not possible
% Z% P0 C B8 s: J
9 V/ t6 q" J- J; ]1950745
5 t; s1 H( D5 a" n2 f R
1 P H, x s9 D3 l. LNX 8.5 exports part attributes only to the parts parent assembly
' x8 G1 a6 Z+ p# @* {1 M# E; B : V& W& V' w# Z2 o4 c( [/ s( W
1950991) a" F# _3 X! M! q t1 F9 N% M
~3 z% ]! r7 c$ p! j" b
Electrode Design "Trim Solid" always assigns 50% Translucency to body faces
1 ]$ u% [5 w- J/ [/ C4 t% P0 b
, b! B5 |6 d3 O- K! r# j1951151" |3 [1 ~7 P* u
& K% f6 H4 o7 {! ~& H& f5 U( bLaw Extension deviation
$ S0 D. u9 w3 e5 k I( `+ I! _* k ( e# `) t+ t; Y2 k, X, ]' X
1951248: a% N$ h9 C& M3 S7 t' N" w
$ \. E8 F7 l+ u) W: H" L
Drilling to Model Depth is gouging the model . G: ^0 A: D# s, }6 h; t; `
* M, I+ U B. R
1951286+ Z3 p% W! ^5 l. z
0 d S+ l2 e# }" K& W" Y7 |6 A
DB_PART_DESC cannot be set to blank for Non-Master PART in managed mode , G9 E( [9 T) X8 U Q
]4 p# e1 n* ]: u. }( _
1951338
4 P6 L1 X6 o$ {: q
- X4 X! m O0 ^" y4 k) YInherit PMI to drawing view do not work % _" U: o8 l( ?* T7 p9 V
! o4 l6 @8 p+ z: J
1951365' s+ h8 T4 \+ N/ \ j3 c/ ~
. o' [5 l9 z$ m, D: w, E8 J) A3 Q
ZLevel Operation with missing _ inconsistent tool path $ [2 y6 }0 q, G6 m& F2 ]6 S
2 t* w( W8 l9 j3 [- ^+ z5 Q
1951414% k) P% F7 K p
. S: O! z# k. U2 F
Exact View fails to update - There are no curves in the boundary
' E" |4 i0 X3 G# s& S6 p ) j9 U! R# W/ t5 \$ f2 {
1951463
6 z6 j4 b( D& a" j 3 @$ R2 T% F1 X) W
General Relinker tries to relink also all non-interpart expressions / Y2 u" |; K. F* _% Z* s) N3 C K
% C1 {+ I! X' G5 @" |0 g- H/ s
1951557
5 j: W6 p, D8 w9 S$ m6 K% u' m
, `0 O# I* @8 D3 @Incorrect collision between head and blank 4 a8 y+ d: z% v( |( P- \+ i! t0 l
6 s* |' h0 L% p7 B# g" K1951685
5 B: ^, X& ^2 C# c4 {
* f( p/ f [5 p& t; N TCAM: New Drilling - Highlight of Groups remains : c+ P' Z4 J, }4 D' n- d& h) q
3 ~% {8 F" p0 C" n) N$ @, \1951730
" N) n/ V+ p L6 b/ ~9 s+ P5 i) |1 M8 k- X
% _4 O+ z7 f ^, `6 lFitting Overstock placed incorrectly if overstock faces not it active ref set 4 n/ A* K: t5 V* q. {5 v3 W
1 m" P( D% G5 m1951751
4 e6 @, j* f9 B9 d 6 M; D7 C( `& q+ g# }
NX Sheet Metal - Customer Defaults do not react
2 U2 c3 w2 O5 h& [ 8 o, y; e" x$ d
1951762' I8 R/ d5 r" z. u6 ]) ^& V
( ]- r" l, d# h9 }' Y7 Q, S
Parasolid export is very slow in NX 8.5 compared to NX 7.5 ' r# a: D$ K! p) K, b
7 a2 d. a6 M( U# |# P" o19518422 [1 i: B" m/ g+ M8 Q
7 ]; I% K+ N( G+ d- n) ^
CSE, BoschRexrothMTX controller, getting parse error on 'D1' word
1 m5 B3 H8 K P( d& s
+ x1 V) w2 J: ^1951929
6 A, w- d# i% `6 `/ ~8 g 8 [! Q/ r+ A( e) i
PS26.00.190 Fix: NX 8.5.2.3 fails on Unite(450) 2 G% X2 P& x3 K% f9 J
1 J$ m0 }- r1 O" N0 d& J) H# o9 |4 \19519585 m' D& b& y9 p4 A
. t5 |" ]3 j, B; i; t; dCannot get referenced object from associative text by NXOpen as of NX 8 8 |% S5 X, T# d. f. O
0 B5 h: a- P$ H' z1 U; P+ u9 H
1952081# v/ b7 j* r$ d3 v
q [1 o+ y0 N0 ]/ E
Mapped attributes in drawing templates do not work anymore
/ O# n, _ J1 n$ l3 Z' v " }, t% T4 T( ^* S
1952133, I; R- Y- S6 k& y" Z- o% q
, p. ^/ g5 s8 S; z+ OElectrode Blank command doesn't create extension body
4 t& r, d. P- j. I- i' `
+ V2 Q' L0 _0 O$ Q: t8 Y$ m9 d( H9 _9 X1952335: ~& v( j" z6 ]/ s( K
. ~3 r5 \9 B6 B( ~+ v
Array attribute with same title, OWNING_SITE, as the given non-array attribute " a: }" R7 L4 {5 Y4 U
' `# s, j! w/ U. `9 j1952410- x$ F% S# z3 H8 @5 }8 v; G, a, U
9 z, `* q5 P( o8 R
Nastran deck was generated on another machine 5 y+ L4 `; ^! y" [* y
0 [3 @/ C4 q/ D, j: k- S6 ]+ K. J
1952678
$ @, N# Y2 c/ | : X: L& C- s/ M' _% E/ F
Divide Face(227) fails in NX 8.5.2.3 MP1 & K3 i* w' w* Q2 S4 A2 a
* ?/ g. Z$ N6 p2 c. ?
1952702
& a( K4 I" L, u/ s0 P
4 W0 A: J* n1 C8 ASave Warning no write access message too vague 4 e( {' O# q6 u( v. }. S. W
2 A. G% x1 @4 m* e3 _, i
1952902
1 R6 @7 X- x% M) g, t+ w
, m- ` |# X$ e+ c0 vMirror feature and Pattern feature are missing Blends
5 V R, s5 m9 g' l$ d & `1 h |% K; Y0 F% K
19529337 ?. t9 E% j( R1 T0 O3 X# n3 l
3 e% t, n- `* e# {& J' a. t8 N- {
Smokeless-parabool_Sketch(15) fails in NX 8.5.2.3 MP1
6 J4 v) U3 a+ H5 H. a 0 i( A5 Z+ N8 s
1953196
$ E3 d# `& _- {+ B- R1 |+ r: V
! X& s) Y$ h2 b# d, ?' I" PNX VDA 4955Compliance; G-SU-FO fines Errors outside of Face-Area
0 j( C8 [ q5 M y; M * b/ k, o5 Q' H2 |4 m5 `1 ^4 x8 }
1953249* h& }2 q3 k9 x W. Y9 J. [
$ f9 P+ V! C( k& g4 G2 l# _
Attribute mapping is not properly updated when used in annotations
1 i3 ^9 G& l' I/ E/ Q: D( K+ U
. `) f( @* t7 G- Y: E9 W1953262+ s$ y a, ~' y4 h
3 i% V; z4 ? j9 z* a# g/ QTC OOTB properties does not update upon save in drafting
, a: R0 p) ?* b) j1 O [. r- ?# { # K. R) P; Y) j
1953279$ J' H: @' c7 M1 l! L/ C! m
3 v6 U2 R) u! C2 B6 DAutomatic Feature Replay fails $ O) A# ]( V" |& D) K- ^
. b) _, n% k4 j6 e
1953335& @6 I! L+ B, a( h5 N
. Q4 I F s6 B
NX VDA 4955Compliance; Save in Config-File does not work2 M7 R/ X" Y, b
# z7 b% \1 Z2 z; W+ E: W1953452* E' T" A8 y3 E1 P& s& I% M
& C; {# z, O7 s$ Q
Offset Curve in Face can not create curve
5 _+ L2 j" ~# I$ j1 K( J
. }$ }5 x2 G" m4 x1953453
4 A: G' E4 Q- l* Q: v
" J2 |4 y( X- O6 E4 w( k1 G1 m3 GWave Update Iteration Fault Message & u4 a2 h) {( D
5 ? w$ g4 t7 a, i1 U; F; e' q19534601 e2 W: V6 W/ W9 P/ U
' z, y' {" B m t( h# oThe crosshatch becomes retained after opening the drawing ! Z. L$ e- S+ \' F- }& w$ c$ x' f
& x/ v; _# @" k% _( a, Y, v1 B* `' v6 ]
1953474
0 H a* ~5 Y* Z) X( ^+ ] 6 I- S7 c. y% @ v8 L0 } A
Solid of Split Body looses its custom color on feature update
' R7 d" W" G' `: y$ M5 d8 c! ^: p 5 W! R: V5 P5 F9 s* j( _, _# s
19534837 L6 x! v9 X! `" L$ a( r
# f+ D' M5 Z/ D4 mUpdate IPW from Source does not work inside a Master Model Assembly 0 b9 e* |5 B( ?2 I
E. `6 S" C* l6 a8 T4 e9 y1953600+ x! A5 p& Y& Y' F
X) X$ A$ X6 v/ a* a, Q
4xis post processor issue - Negative Z
6 t8 W. X( S/ h
g/ }) A }/ C1953731
& A6 U2 |5 o2 [6 p6 ?& u# Q ! D1 W' N J+ h) q% |. c0 O
Fonts not mapped as defined in user interface 9 E# G. ?- `7 x2 s8 o# a! ~
" _' Y, D" P* ?3 ^5 B19537714 L1 G/ n) l3 f) z
# r5 v- g/ j+ w: f( @% D+ A3 YTool path simulation with Collision Detection and IPW gives signal 11
U8 I9 m+ [3 l0 {! \# f
9 s1 i6 v/ l! W' {5 M8 b1953879* U- `- _- r( H. i. _
9 }4 C2 Z: A0 J. Z. E) _'Edit Reusable Component' does not appear in Teamcenter for imported reuse comps4 z7 x* U8 S. F- g) d6 h# R7 M
( s, p! o7 L/ F( i
1953973- F# b& `9 f) V+ o% L9 J/ @
8 x/ C l+ M& eProduct Interface message after closing 1 l! |, k# C6 ^3 u& ]
& T% y. I" g: t$ z
1953974: o7 V5 Q2 [1 R, o) }; y8 r
" b5 b1 m x: H# Q. sFilter being disabled when Geometry is in Product Interface
; y9 b8 u4 w0 y+ Q- L! _6 @
6 u+ m ]( [" ~% K3 [1953979
* O( V) I: B3 x 0 z- R+ r5 [* K0 g2 I7 i- o: y
Product Interface change Plane Normal sometimes not possible
. E3 s0 R. l1 A6 R9 g
* c- b! B, i4 o, ]. G; g- x1 R1954001
; z u2 H$ S! o# v3 s1 G* a4 [ 8 E B& R6 x+ `5 B$ G. s
Overriding PI-elements not on purpose possible % c6 j2 C; l9 u& L
* ?/ S. N: i7 t3 I- y4 f6 i
1954003
( n" l4 l8 e; A) t4 i% k) c9 C- D9 P A* E6 J" p; k$ }" W
Inconsistency of hightlight the feature group with the parent element / g ?' K& J: m- I2 z$ e
5 M; Y( b& N# M" P Y( O, e4 U, s4 _
1954026
5 @* Q5 y+ ~$ p" v1 W 3 _# |5 A" B }7 J0 c/ |
Part Navigator not showing feature out of date
* H$ r0 h) N# B3 s$ a 2 u: u/ ~0 Z7 J" r e% t
1954041
3 C- Q+ U' u, j8 C' M
/ k' e8 s* h1 C% c$ jNX 9 "expand all" not always available for FGs ) K) R1 c1 I) ~, L6 o* l( x# ~
/ Q( s+ V% _2 `: u
19540430 P# `2 x1 }; r2 I# _7 b. c
* x% u; s! o4 U* o" D5 J l' eWrong naming of linked elements4 n; h# a( G& b |2 G
& _% P* |3 M$ G" n. [
1954044
, L# M' ?. }* ?9 e& K; J * v: j7 E/ \' P
Inconsistence of hightlight product interface
1 {7 Q4 H( F- f: J8 K. i8 D- T# ^ " ^/ c$ L* X3 O. t; U; ]. d) }
1954045; G% z, k" |- t! T, b% N
( u! v: v% M5 T* {/ b. q# Z
A linked element should never get the feature name of the source element
6 b1 I; O2 H" l% M+ }3 m' {, y & V: q* j6 p& u2 N
1954055
( E) n0 Q( m8 j/ }
, g- z7 R0 @ n" W+ W8 d5 @Inconsistency of hightlight in Part Navigator and Product Interface ) i& J5 P, |5 b+ X$ a5 {) o
P8 Z' h6 L c; M" f7 g
19540811 u- |/ k1 Z4 j7 N! D ]
3 j& o3 f7 [4 F
User-interface Product Interface for expressions # D5 r2 u4 t8 \4 g: |! f
& F" } v3 s4 c2 c
1954091
1 R) b* |7 f* V# j/ q
! X, ^! e E* y( qBad cgm overlay performance for CMM translated drawing * [7 p1 D J# `: t0 o
% i2 y; `1 D) z1954103
: E6 d: j0 P4 G* |
$ m8 [( y# S3 S! ^/ qPoint listed as Curve Feature in Product Interface
4 h/ I9 n$ j% A' Y# F8 q& H
* a; V) D& B8 D$ U8 _) c1954128
4 d) m& [( ?* `: p3 {) S* [$ {
/ j) n3 Q2 x, Z8 xLaw extension flips direction when symmetric is set
% ^1 @# L- {' `8 H" Y- X! \ % s/ A3 B1 M2 J7 o8 c+ A1 C8 @
1954129
" F$ C5 v+ r; I6 i& S3 V' \
4 e/ b& L* t' y0 YLW Section View Crosshatch is incorrect
8 ^5 J1 B0 O8 }, u1 D! R
$ v6 B- J' H+ E( [5 ]" S1 c% m* _1954139, Q+ d- V# E& t' _
0 A6 d4 i* b% }% z7 YSort Method setting for Part Navigator is not in the right place : q/ U( N; K; {- ?, S+ N+ A! W
2 I3 E$ g& G# w N1954143
" p2 u, U& P1 ~* O+ g3 G 6 v6 B6 S/ \, L
Ordinate dimensions are changing their associativity to different geometry
2 G: `* k5 g1 q% B * ^( b; e' L+ G
1954163/ W" K3 ~, r( z5 U3 i
. D, v. ~0 c4 v. CNX crashes when attempting to Edit a Spring Connection in CAE Motion app / N, R8 f0 X8 P
' G+ ~5 ~0 j4 @. b6 C3 m( Z8 T1954208, N7 e+ e6 S% I H+ ~
# p9 C6 J8 t) {, v/ c
No interference found when lightweight bodies are not in Model Reference Set
% e+ m7 V; Q0 l7 T% e, J
3 E! ^1 ?& i" ?) H4 c* i1 S1954214
' Y$ {' h0 T { K9 W+ U
0 ] \) D6 B2 G- K) K/ Z5 Q7 ^6 QSave an Altrep don't overwrite JT data
% {0 o) `, [( x7 [
2 E$ |! [* S9 C) B) r19542383 a- M' `/ e1 M6 M3 [0 Y
7 V" I+ S7 t. D) b# G I" qNo Standard Driven crash barrier can be created , v p% v( q! I' c
) ?; G; T% p( k: D' }3 f8 @
19542410 d" V& \" J. s# n5 Q2 ~
: u4 \* Y: s; ~7 PUnable to Use Manipulators when Box associated to plane
% P% j) W; Q3 j: O$ S* j . ]/ L& S3 @6 q1 v" r1 J- M: k
1954250
9 Z) o9 y7 n4 ?' t 3 }4 t( k; I, K/ t& Q
Regression, impossible to create motion envelope by step selection
2 k1 z7 d# c/ [: h & K" b0 p; a3 q% c& k$ ?
1954257
# _ `5 _% N1 o. W( F( Q 0 g2 g& m9 Y, {2 Q
NX crash during jt tessellation6 Y+ V# @7 S: J
7 J4 {' p, z6 y5 N0 M! r: N# y
19542742 w! u0 i; f: W' v; s9 Q
P _! W3 v7 C
Unable to specify axis of circular pattern by selecting cylindrical face
0 E4 d& |+ f+ R) s, z 5 }% f' W1 r1 r
1954283
@' {# u4 K" N T7 y% `5 ]2 O1 o5 {
8 V! e5 _# l- m; [Creating_1_weld_point_using_the_Weld_Point-command_with_the_Option_Guide_Curve . B' M$ Q, c% o& ?7 s2 u
5 b) P1 c/ ~, Q8 ?" Q+ p5 K1954299
) w# d8 S% ^7 R i9 e* J& n 6 d3 e1 u2 s5 Z, t; s
Wave Update Fault message appears 7 Z6 Y8 W7 f k- k* l: | _* I3 L2 v
# Z: Z0 i' O0 C) c9 C6 o0 e! W
1954308
" g0 h: }$ ^7 }( p1 Z# J
" R) K0 ~# L# MUndo after LW Section plane modification not correct
0 E# o7 h. D6 Y {( t8 Q% x
$ C4 t% Z$ T! U/ P1954315
# L5 H4 J1 {8 ^4 B2 j) k* e
( g1 J& Y$ l! q5 }Hole Tables - Shift select not un-highlighting holes 6 i5 \" ~1 N: y; M, X( V
9 J( U4 K" [! _8 Q1954322
( a! P e2 k; I' \7 M 0 T2 H- {+ `7 k; Q$ B4 P
It is not possible to use the Connected face finder in most cases 7 u( y; s; x6 k% V# O- d
: @/ C4 j& f' O+ K$ M- r8 G6 v4 ]; Z
1954358/ N9 X- b3 v1 @0 W: X7 z7 u2 z4 N
2 ]) L+ Q+ V9 t& RNX 8.5 Changing Tool Number Makes Operation Out Of Date ) U+ x y7 Z2 U2 C @
2 l$ L: H( h9 D& w; X% x1954372
) y* W% w" y2 u 4 z$ s3 n; h7 [5 I
Error on EDIT_FEATURE_REPLAY with Update Error Face Blend (1082) & M7 i' `: I$ ~1 t
8 g2 N+ {0 P$ D4 H% O8 d
1954379' s% u- t. K8 F# j' b7 e" q9 J
- B1 M7 x% Z( q2 s) {, aThe API "UF_DRAW_ask_face_of_sil" doesnt't work when Exact View is Used
2 {& D9 v$ j. m: ~) I. M & q" s" j: S. U
1954440
& V0 K3 J7 F* P5 W Q0 m- D
3 w+ i; S8 H! @% O% N& j1 KSelection Filter in Rapid Dimension resets after Selection ! n }7 `+ R3 _4 Y! q
8 {9 \2 q% O* M& M1954443/ X" p* C' l2 _: b$ S
! g) b4 o7 ? B0 S! W
De-select All doesn't work in Rapid Dimension UI 7 N5 H2 f! I( y' c
' b( Q2 r' `1 ~ O3 ~# T
1954445
/ \# |% X8 o' j5 h c
; k' {6 X" S$ TDe-select Geometry with Shift-Key doesn't work in Rapid Dimension UI 3 v+ P# A, ]: X7 e+ g
& S+ u2 i# e, x& h) O% [# ]19544505 R# ?% P$ _6 N( s m3 i
/ L* V, D, H0 |; ?4 h \9 }: b, z
Chamfer should deliver a warning message at approximate results
# ]& o: g" x1 G) F' D' V
" j$ u& a4 M4 E4 l( |1954477
- K" U: g* d6 `. i" p/ \/ f; q $ O- N/ \: {. b9 Z' M
Independent change in source causes out of date part with missing references 1 N4 C7 s3 q5 k, f( i
, D5 @6 t: m J/ \& s! n. R
1954490
# q% s$ ~( x% o" N 6 ?% F5 E* _2 V
Repeated WAVE link creation not possible
Z7 X" |5 ]' P$ V+ E3 y" I ( h" S1 Q; p1 Y0 D( O) t
1954509
: V* {) F- v+ t) ~ \ _0 s2 t! I2 ^4 T
Product Interface objects from NX 8.x not visible in WAVE Interface Linker
) C/ ?' e$ V) z% e3 I& K% O . C& a' ]: ]( Q- T( t; K5 v
19545158 Y$ r0 ]1 r% n: P% X
4 o6 O3 `! D' D9 T( D& oNo name transfer of linked objects
3 M' M j& p# g
2 ^: g/ Z/ \' s$ R, E19545203 R) q9 W# D9 y# H- v
% J$ p6 ~/ S. ?Hole Callout Dimension not following settings
% [$ @7 _4 p5 Q5 k6 r ` " P: p6 q: y/ t7 b, `5 D
1954522: H- C, H i) a$ n$ g% I# b
! i$ h* X( Y" {& {" P4 A1 gInsert UDF is significantly slower in NX 9 (compared with NX 8.5) " y Q0 O, f. G/ F- c+ ]' S, U
- P9 \& E8 c/ z
1954528
, P9 c1 N% F+ G
3 B: u: \0 Z# J. T; g) e0 QProblem with Part Navigator and attribute columns names with underscores
/ ]8 q( p. |" h/ Y" _6 G! q. u% Z! r
5 D9 C! @6 [: n* f5 D) v$ [; @1954548
U) u) i0 m. S . S8 r4 T# A1 A) A
No affect - Active element in pnt : L( e, C, k8 J7 C) t" C, B/ T+ F
( w) ^( ]! c" o3 s
1954550' s- ? C, N) p& ` h/ X
# ]1 f' v- I) _8 A1 B4 o& ?1 UInternal Error caused by WeldPointBuilder 7 P1 j/ s# h1 `4 `: ^6 Y" h
8 g* q$ B7 \3 P3 p6 [ ~3 A% T1954552
+ a! p; L. f! u3 _ # U" c1 z9 I3 m0 X* a
Error message during wave interface linker ( m: G+ Q1 b3 [3 S' E) w4 \
% K4 |& j1 v- j/ O1954564; t- S7 {! s3 V! R) I
) Z6 _1 a5 L: U1 a8 ~, G% MError number: 1 when opening Step214 file
1 P H( I4 g S; ^% V, X2 S ( f" N/ [" m( G; J
1954568
3 ]( J, M/ v5 m6 o [ # I' n8 T, q: L
Product Interface - Wave Links corrupt after update of source # V" I/ m2 S' |1 N; i
! U& x# ?8 [" [4 G+ h
19545834 L+ \8 b# K7 @) V p; N0 V- R& M/ z
0 c" H3 b6 l3 O6 hExpression change causes out of date of not linked part
' {' C' M) L& `+ I$ f" ^5 w 5 j. d2 l. Z+ Y$ E' i/ N2 K: R1 K
1954588& C+ j- W4 ?; F% d/ S6 j7 ^
6 v" ^) w& G5 t9 u, v1 W+ ^6 x7 o
Editing spline paths of a harness created in NX 9 is very slow
) `+ x: v1 X, V! f2 v ' A+ |6 d1 Z1 v" g& t
19545995 `, H2 k( {* @# N
% e R3 k( J" o3 `+ d
PS26.0.195::BodyDraft fails after flipping DraftDirection , I7 l: `: ~- m( t
; z9 f. J$ k ?2 w C2 `1954610
% @/ [/ a; x% B- ^
* |9 J$ C8 \$ L" z* w' B- t- JCreated Joint marks are not added to reference set
* `' |9 y b1 Y' v- b; Q2 l) a; x
% w! v" E, R, }1 {1 r, [1954649! o q2 l$ m5 R- ?. i K# d( b
B/ H2 `' ]2 v! r% W- tDe-select All Button Enabled and not working for dimensions 7 C) v& t9 o( q) q. u7 x) k
: |' n# x# k2 z% {; t% K- j2 k
1954668
1 r; X" a/ T; W* a 5 |2 r" R! @ H% A, U8 h
Performance Improvements are not good enough with PN open
* N' H1 h$ G# d7 N0 \
: u8 x% x1 h8 i- K& k1954696
; e H, x' X+ Q! }8 J8 ? " S; d/ E( K: _# t! s
Export Part generates an invalid Section Surface0 t5 Q* _+ x; o. g1 U. J L) U
, k$ U) N8 a% K1954715( N( D7 h: _$ P# G8 V# m
% e8 h) W. X9 _! NConverting NX drawing to DXF_DWG file cause datum extension line go missing # f: c0 u* w$ N/ E
. n3 u2 b( P/ m7 I
19548048 F4 l5 _( p& x- T+ ^
* _( Z5 ~. r" B0 P7 wReplaceComponentBuilder.commit() cause Internal error: memory access violation q) z0 U; m/ N3 {0 R
; y$ G6 L" @" O, ~' }1954832
( ^/ G q4 S( S! W; f
4 ]) n8 R. r! B6 GCreate a Detail View hides border zones labels # f, f8 H/ a. ^/ C3 b" u
% a9 @( z4 E: |19549270 m, I8 Z7 n/ j: k* r" i
! k: C& u' S0 l% \3 C4 D; y
Poor performance editing laminate global lay-ups and with 'compute zones' command
% o2 a& m# _( P& N
! z0 G. {+ r" e" P' ~1954959
6 @3 {5 p% X, @4 A( Q) A) ? 4 g5 M! A. e5 p7 t$ l
Tilt tool axis automatically the when used clearance Option Bounding Box
1 o1 ]9 x5 T6 g4 o $ U" q% L* x0 V& ~) ~: Y
1955042$ @4 q! V) p4 T$ Y2 r( x
* J, Y- ]/ D& ?: R3 B' X( s1 Y! fGouge check is very slow, when the tool axis isn't in Absolute CSYS Axis
' A5 B6 { l! o) e7 ^
2 P- T( Y. j4 J4 l2 s: q1955371
5 u: `# e$ S; [- d- u+ O
& m. Q4 E4 r/ k6 L2 P# K6 n, N, aStorevalue fails with hostpointer after typechange in NX 8.5.2 8 d$ ^+ d; V5 I( o4 p
6 {+ z" A" I: F9 j2 I: o- g& X& K1955588
, T* n3 F2 {) u% w7 k - D/ Y& m; u C0 m
Update mirror part after material change of original part is not ok
7 n9 y, ~9 f3 n0 X: F ' k" R, c3 P* u) m) Y3 k4 ?
19557075 @; @; M5 j+ @5 U0 ]5 a
) H: C: N) e9 K# uExport Assembly with load option As Saved but the log file shows Latest Working
4 x$ V7 t, e0 _/ X) }6 |
$ H3 i5 F1 b! F# k6 ~1955746; x! x% I% ~3 U1 P
5 J9 Z2 V+ G8 ?, Y
PLOAD4 arrow display: wrong direction on Hexa element free face
4 j; K+ {2 A+ M! s
$ v U) c$ _+ L. w7 b1955833% ?% l7 p- o( {- E) E$ h
$ z+ T) @4 _# R3 vNX Sheet metal Closed Corner incorrect result 2 D3 T- ]7 W3 T/ {( ? k7 d
/ B: M( W$ l9 d( N6 B0 K
1955893
) K Q4 @) Y. ~ ( G, k7 @! z& o1 L) m$ I
BlockStyler Tree: Drop problem, DropType AFTER never passed to onDropCallback()
' k4 A9 Z, Q% b# F& m3 ~3 p8 Z 3 S$ R2 w6 c" X$ s
1956150
# @2 I' Z: _& f9 n" w + V7 Y: x; G4 E
CAM: KF function "ug_param_hasBlankGeometry" detect no blank geometry ( B+ F% R+ y7 b+ {
0 m7 l A# ^* M7 R& n
1956224
" d4 G; Y! C& l6 B. d# q# l # D, b) P; ]' t( M% U. S
Encountered unexpected NULL pointer when clicking retained extension on path
1 _' e! O2 k" K$ d; d* @% D& m
; o( ?" K* L% E, Q1956557
. J: @2 N b: b5 u) o% {4 R$ R
4 ?. G9 n& c7 @( f! i6 GTitle block disappears after Show Only in Assy Navigator is done in modeling
/ }3 S' r( [' k9 @ 9 `$ O! Y/ J! g1 L2 l) m* M/ z
1956609
8 ^: j E( M, a' r8 [) E + h: P; H* t5 O0 }. Q$ w0 |
Save Assembly -> which component are failed to save # y6 F; \, M* a0 o2 L9 ]2 {
j1 @; D$ e. a2 s6 v# P: F3 o1956686
0 ]3 E* e6 ~% x | w2 y! y
1 z. P, y. S4 l7 r2 [* rFix at Current Timestamp is set automatically after a wave link is broken " n& _6 ^4 c h' l
5 ?' h+ u7 E! N9 _" \- Q2 Q1956688
# T( \& F9 ^# V e7 g
2 i: }" F0 f, |! C5 C" yMissing UF_terminate() in Ufunc leads nastran.exe be called with prog=desk 7 K* f$ U7 c) w6 k$ V3 o- D; ` G
/ z! }/ C: b/ L3 \1956747
6 j3 F3 W" D) T K$ `% b2 ?$ Z9 Z& F , \9 i, I8 w( n o
Problem to import STEP214 assembly % x ]( e8 z+ n% n' I9 e
' _+ p% {" S& I6 u6 x6 o1956822
3 |; \% h+ U8 {" E 1 M- Q$ M% X% f4 B
Drill Operation disconnected from Geometry Group
$ x) Y# Z, \# y # b) ]% y4 |! @( Y& }
1956911) s5 J! N# S8 p' j' k3 m- B
$ a% R+ A1 o+ \
Internal error: memory access violation after element copy & translate / t- _$ ]. R, q2 F
8 U9 c5 _- }- G5 y* b4 c1956937. F' F! F& x6 X K
; ]. p# h' W! e- Q/ mEdit->Selection ->Tob Selection Priority - Face use nx_visual_reporting license4 H; F8 n' N, Z/ a
8 o8 L9 ~8 P( ~' H/ o4 q: b/ i
1956955) W# o! M/ P4 @' u, V2 x
* C! F$ K0 ~; p9 m, T3 C/ sEditing control type a styled blend to Tube Radius changes shape of blend + b( S& e4 |! \$ R+ f, Z
* n: K9 q" [, z, _
1957001
' t5 Q1 B8 F3 X; N: z
0 r1 y# A& ~0 j$ Q/ g* x3D Dynamic animation in NX 9 works extremely slow' E% O! d- d6 d ?; s7 i m0 y
5 u! ~+ b, ?$ z! }# L
19570322 M# n) D2 G0 A6 P% z! t
: h! S% O/ S7 Z7 ^& B2 tCorrupted_part _ Failed to load part when trying to load object on demand
. ~3 l. b4 N: u* P( ~. f. ~
. N; L$ g& j V" O N1957069
$ y3 I; r1 n6 h4 k' ]1 v& ? : `; s. G4 H7 k B+ ~+ h7 }
Import of UNV results causes NX to stop working correctly
8 F, E1 c9 z' Z# C$ X* [ 9 C+ j! ~0 k j. {0 W* X
1957116/ @( o' j! x' ]" v
4 ?7 x. Z: J2 r$ Q' JLOV assigned to object_name for custom item type not visible in NX , c0 Z7 q* ^7 q" D* p& {2 z
# U1 {3 |- } o9 G" ^+ C+ y
1957299
* R6 d, b8 ]9 f# s( {+ A
$ D8 z3 k9 I) s% BAttribute mapping does not appear directly after creating a new drawing (UGPart)
5 S; A% y* C& w ( r2 G v& W5 z) i
1957326
7 ]9 [7 V. f% |8 B' b, E4 K9 E$ b4 H 0 f2 }# ~7 k3 U
Internal error while dragging a WinRAR file over NX graphics screen
% b* H& z. G$ l7 L' Y
4 ~, z. R' q9 E7 c1957333
7 }, S1 S. b4 @% |% l
# \: M) x5 A+ t( O; u! q, GSelecting several part lists runs into a loop
. Z; ^# p) h2 z
8 S1 G7 z2 i9 d2 n9 u1957361
& f' |7 N6 V* H1 L8 Y) l 9 }8 r2 o% H6 ]: U8 g4 w% |$ {/ d
Local Un-trim and Extend - Bounding box * R4 X) }6 f! W- Z8 P
) q: D& R: J( A: ~
1957513
5 P9 L; g! T0 L2 i& s2 k / c& `9 ]& i u' n2 ]0 X; u
Associative angle measurement can't be deleted by user , J8 k0 s \% P5 [
# j& D0 V, v! P& ]# t2 n
1957791" R* U$ |) Q' z# p, R) c
1 \2 q) x/ Q( h' U! Y2 \4 @CMM 755 drawing overlay tool is not working
8 l0 I i! F9 h, F' l1 Y4 x
+ T; b U3 ~: z, p19578043 L3 B- l8 v( Q6 ~9 N
% d: x$ f9 n! a7 L4 c, X4 [Usability regression in NX 9 drafting dimension , P; c& V. i+ j
0 Q% d2 ]( E# A3 A( i8 s19580785 u+ }5 Z7 F# o) L# L
1 S: @/ p/ [$ IAnnotations_Crosshatching Losing Associativity in Drawings after NX 8.5 Upgrade , N7 a6 X2 H- B# ~
( y6 E4 X* |2 ~6 u; x4 D, i5 m! T
19582056 A x% q& ~3 M1 g7 a( o
( Y" u( q9 X& n' t* a- kMoldwizard is not able to load the object "Standard Langer" # u1 u& h7 }/ h4 K6 C
+ d- W7 H: W. V, {# z: b
19582176 O- V6 _; j" g) n% \; x
# U w* S! W1 l* r0 b o, n! M
Incorrect 2d mesh with "project node to CAD geometry" option9 _, L! b' H: V- A
$ Z; b) A( ?% d
19584855 R! D( p7 m7 }' f- A/ h
" E7 a/ P$ q% i( m/ C d* ]
Deviation after playback 0 J# N- w( B2 I8 B
6 w( c6 Y" b! P1958643
4 a Q& L/ `; } ! a5 z- q. @/ p& \0 [7 G1 E
NX 9 sketch limits & fit tolerance show empty deviation & grade fields upon edit : M. K" f$ L! F
$ S2 K/ r; T1 F4 J5 F
19587258 \2 F* O5 X$ c v, `5 |3 _! O
+ X0 B/ _+ ~2 _. u9 G# p: ], i
NX Visual Reporting license required to edit 'Pattern Geometry' feature in NX 9
/ N) U' W5 V; V; Y+ ^
' g$ Q1 ]% p* b" J" A1958864
% j. y q. Q+ P& m
; @; @( h! ^0 _# ]' qSTEP fails to import into NX 3 [7 x; q0 ^* n) Q( f; R
6 e. e1 l4 ~& F7 m l" y# R# V7 N
19589613 A) d, X7 K/ G3 m
4 j( w( R% Z( N* BGroups below a Section are copied into "Groups"
( f5 I" s" t% H( O2 w/ P
9 U* _' J; K. `2 e$ e* \1959063
( q1 {8 y# u2 D5 }# H5 q% }4 L! R& y
g! C5 I) z" G5 G3 jCustom Toolbars, missing Icons in NX 9
5 R# t6 }- c9 {. v5 b. E 2 |& ~# O. W9 T: g1 `
1959116
( N% ]4 M$ k0 F3 `: {+ O
4 a) {6 |% I! V# {Cutcom Output Contact_Tracking Data in Thread Milling operations
2 w/ U" h$ v. }+ L 4 z8 r2 L* q% c9 r
1959493
' |6 t# }* A7 B* e F# r/ [9 H
5 R L) s6 ]9 s* }; G! P# g! H) a- TUF_DRF_ask_label_info returns unpredictable num_assoc_objs for leader in NX 9 0 ~/ _4 X! ~8 F
; C4 a9 `' G! s" l" l
1959522, Z8 ]6 f/ E2 t5 o( L6 ~2 r2 n
6 i5 X! }$ J- O& X1 ~% K! ]4 V* l/ \Translating UGPART with asynchronous mode create empty jt for UGPART * P9 X e0 }& P
5 x" n# z4 p j" ?8 w
1959574
- n0 Y% F2 v5 _0 j0 g* }$ K, K4 B: R
( i9 ?# v, k4 h. m; H* q7 yVDA Check need more than 32 GB Memory for a curve with 31 elements 9 M0 |" t- T' G9 m) U0 I1 z- `
, t! e) L9 }4 P p
1959574
% U! O& {# {+ B5 T4 f0 s k9 M8 V% Z! {0 p0 o3 N8 ]/ ]
VDA Check need more than 32 GB Memory for a curve with 31 elements ! }, c+ z/ R: x$ T; Y5 v7 a3 J1 q
& U* W0 G1 B: I9 S% C) ?1959577
3 C9 D4 \7 H' s G/ K & r. G( _! H, N/ O; {
License error when trying to select a face in NX 9
. m& E2 G+ ^* G, r* a0 k; q
; o _8 s) c$ d9 N1959692; Y" ]* G; `. ~- K) W; x5 U
% B. H+ X/ ~: d& H( V( x* c' z
Beam offset not correctly displayed from .sim (Abaqus environment) 5 D4 r9 T* K% Y4 M! g& N
$ ~6 ^6 l k8 ~
1959715
- r5 V6 \& a# v" r! m& V 5 F/ @/ q+ C4 R- g- l( ]( u
Invisible thread lines are displayed incorrectly in projected view ' ]5 P5 c3 }. u9 p; k+ B. h
7 T, o+ K2 ^% Y& |
1959731
4 h" F, J, B) u9 ~/ w1 g ^ T ) X7 {, S- `( o
NX Visual Reporting license error to edit 'Mirror Geometry' feature in NX 9 " O, h5 D; l. E% H) x, j" a
Z7 \9 z( s$ T. D1959736
: U6 g8 V1 J4 D; h- }; t - D4 k8 b8 D( r1 m- g7 ~
No preview images in Reuse Library shown for PDW standard parts from TC 0 D- G& j L" N
( w7 \" u; I( M c, J* n3 p" @1959786& E8 k% e4 A7 l$ V1 E; i
* [# U4 {: _: `' y+ ]# P
Unable to change the number of dimension decimal places of sketch 4 K9 p0 X5 R3 {
' V& \; d8 d, U) _: @
1959815
$ u9 [( U4 [9 w ?! R 5 y, ]: C6 I% C- n
GetVirtualPorts and UF_ROUTE_ask_multiport_strings fail % R0 }8 \- L& ~: `3 t( |9 f
' a4 n* n% W5 \, f
1959886
+ U6 K5 I- {5 s$ i; S
& D# U) h& C* g' O: ^2 {6 |3 z& cModified Region in Trimmed Sheet after Playback / {! O& o; P: g: J- w) n. n6 c
5 c* O/ k5 V+ D4 Z6 o; o5 r) G+ u# d
1959901: l6 T$ s+ l3 y2 ]3 T0 m
) J. R6 J( k6 a1 r. x8 S
Modeler error occurred when updating hidden line display
' I5 m1 W9 P' _/ a/ |! H
" H* r! K; |6 ^# C; a1959910
, J- l2 Z( x3 I+ F5 @1 U1 c
6 s9 l0 R: Y- D+ ^+ { Error 1770003 comes up after using a Library Tool whith desired Spindle Group
9 }! J: V1 g2 Z# q# W4 ~9 Z1 }3 {+ h 0 q& C# D3 ?! g1 ?" k
1959951
5 G: f& Q( n! `8 J2 Q! h 8 h! D+ h$ n. B& K _8 B* O
NX Hangs during a Part List Update , i: l) \) o" O* e3 Z+ j1 ^! [/ r c' {
3 }! J" T+ r/ ]/ m1959981
4 E7 x& k; {2 a U
$ ?8 G v! q8 C5 r+ M7 q* XBumper and Crash Barrier do not refer to the selected loading in the Base data 5 C' U x6 F% u1 k8 P" B
* |! r; b. |& d' N* y
19601916 {: Y4 S* K* ~% Q d8 \5 u/ a9 v0 Y
( n! ?& U1 [ _/ Y
Display Rules block attribute mappings for specific groups
5 g" K( }+ N. b9 y4 x4 _( `
7 q/ ^5 M. \7 p1 g1 @$ h- `) [- a5 }1960324; j3 P }" Z+ s, |4 }
* w; ?! _/ G4 t4 u8 S9 M! n& e
An NX Visual Reporting license required to edit Pattern Geometry feature in NX 9
* `3 R6 O2 ?5 G 9 L% C6 @# L3 T1 @
1960454. ~9 m2 ~' ]; F J
]9 n: H* H! R. _
License error when selecting geometry using the type filter
. e7 g- O/ T9 I# v! l& E* U3 _
& y( @( Q# t4 P4 n" x8 i1960845- `6 O3 A% M2 H- Y+ e* S
# _/ r D# h# c2 E( sSelection of face_body_feature improperly checks out "nx_visual_reporting" lic.
0 Y( M w7 `9 b* t+ g, B4 M 3 m0 z2 M3 F# F) v, [3 e
1960888 `( l/ g6 v+ Z8 d: O3 ~' O n
) K$ B6 K2 X4 C2 U( WCannot drag a NX 9 Dimension immediately after placing it unless UI is closed 6 I( |+ R1 B7 _) k* @
0 _: \6 N) H; c* n7 R
1961247
u9 O) I: ]; f0 v" M3 l + @$ \+ T; e! A& @% _& k+ c- S
UDE under 'non cutting moves' GUI problem7 a# J* v! L/ @4 C2 W
- W3 B X" o# [7 A8 S; j. i+ A
1961327
. |3 Y# q8 B* [$ C( N2 u# R) V + U6 a/ A2 o5 K9 F$ ~( B) D! [) q# Z
Export Tool to Library returned an Internal Error by using Selecting of Portion3 E& ~/ Y1 i5 b; u8 u6 C, I
M* _6 e. t: w/ a3 Y
1961520
, f: Q8 K h& R, l" Z2 O
- {7 j2 v* t* k* a' HPMI Surface Finish visualization is not correct in drawings
( v8 d! B+ ~8 z3 c% t . X8 t8 G5 q/ R* r4 d E: L& {
1961573
# G! m/ D7 f" }! W2 _% [
0 B9 w1 q4 Y5 `* b8 AThe node " olygon geometry" in the "Simulation navigator" doesn't work: B M0 p7 L3 i3 F6 z: b0 I$ p+ j3 T
- j5 w$ c5 F4 L' Q# o4 Z& f2 i& c1961948
- O3 K( J* ~& l) p* m; G
" D# ^& d/ k4 E: UFeature to be reordered is being referenced : V2 N4 ^' \) E, Z1 g
, W% s% U. @. |5 z6 o' {) G1962171
9 G% U2 J/ L+ `, E. `7 z/ k/ w ; p: q- z& u U! O0 q
MKE rule library cannot adopt vectors from an UDE
: J& `$ L4 b* x+ W0 k# ?; i
+ k; M6 M8 P0 q3 k6 g, Y1962349
% }# C! d5 B: J2 V# `1 |4 `: S/ p
) p5 Z: i5 R6 YAssembly cannot be loaded in NX 8.5.3 anymore
4 O- G4 t& {6 G$ n4 V
, y/ t7 g: I# Q, X @, Q: Z1962616% h- q, Q& K g% A+ e9 n3 W
" X3 a: V7 h l! e& C! [: M+ yNo collision detected between _PART__TOOL and internal error
' t7 [& p, k. q2 R- c- F- A+ }% T" B( B . {/ [1 s+ i) j' k3 Z/ ~( w8 L
1962630- s: I$ z. v) t5 y
0 Z) p- q& j* TNX Motion Export: incorrect VRML animation and missing objects in the vrml file
! F6 W: V4 e! T, f. W 0 l' R/ Q' H) Y
1963372
# |, h* r' c* W$ ^ 9 P( l$ V1 T5 ?6 l7 |5 k9 n
Unable to query simulation results at given locations due to NX9 internal error
/ C9 d1 |# D/ g 5 d% f) T) a, ?# n# Q
1963705
; @+ k/ _& [; n
: M+ v$ @& ^1 O6 q4 GMemory access violation when using FieldEvaluator.Evaluate()
( _7 E% O, T; _" U" m: a* {; |
# |1 N) w! [. O: E) j19637669 L) Q/ Y- H: M3 W* {
: Z$ T2 x$ H( N; @
User Defined Ribbon returns Internal Error% M0 `* o# W, s. @7 {( w
. s7 _4 S/ ^5 t. r1 J& a
1964075; H# x* s; u6 e. ~; l
$ }' y4 s% ^4 K& Y# b, U
Comp will be saved in JT, even though it224s on a layer which won224t be transferred1 u3 \' O& y$ d8 b, H* j
+ F3 v. o. y1 s N" d19642281 ]! c# U; O% h' o( J3 R
$ `3 a5 G9 E$ {! b6 yMove component fails with recent JT files
9 k# U4 Q5 R" C1 |9 W
" {+ H3 t+ x% Y! ~7 U9 S* \1964281' K; L. x& @' G- n4 f4 }
$ P m5 n8 C3 p# u
Turning tool is displayed wrong if MCS_Spindle_Group set to Operation
' M" ?3 i' T2 _& X$ c1 p P( B: G
, \2 [5 J; {5 p: _% E- S5 L19643112 v) a# }& V& r( U$ f% T U
! _2 ]& A9 O8 u( X" c1 M3 @& P0 n4 Z: |Parameter mapping to_from WCS failed
5 d7 x5 R( K) `, Q/ Y' }* D 9 V2 t* m0 v6 o. v4 }
1964421
# F7 m/ o: ?) k8 k1 _% Z
2 `6 z2 R* k3 ^Cannot control PDW Library Part Revisions with Teamcenter
/ G2 r& |. \- Q5 I
: I9 m. x! s; r, y, h1964476
) a g4 m- X z6 k1 R . _. m. `; X' `) @" ]* Y
Feature Playback error in NX 9 # M$ E' J+ H3 W6 w7 Y$ C( H
4 u2 j! w" q' |. K* p1964483; ~/ G/ Z2 T$ S* |- P
3 ?+ J9 c: P. ^' A( S# RFeature Playback error in NX 9 + W% d6 l/ z$ O+ L# q# ]
4 H! c8 i: {1 T5 `3 |: m9 `
1964484
% T! i$ I1 E# o1 L; Y / M1 U- H! N n, x
- K/ P! P: ~4 g. |0 q6 K . F# N! B- L* B
1964489
7 g! K; b; i$ _- O! ^ $ J- _( q+ G% O; [2 D" ~4 n
Feature Playback error in NX 9 4 |& ? n! Q/ V K- X
4 m) A; ?/ d8 B8 V( p
19644943 @6 U6 C% m+ w# a i+ |$ l
" u- ]7 u' I0 M$ u# jFeature Playback error in NX 9
% y {# C7 ~5 f6 e+ [ , O+ S# s# I6 p. v' ?' H" j
1964497
0 P1 H- z) f; }& ^ 6 S9 }, v6 S2 @1 ]8 \( z
4 M: i+ o+ @& D
3 W4 X- O. h. J P4 q1 [19645003 M, X+ d& c; R* T' P; r
3 q. F1 F6 p6 }$ ?8 @" l% U! }8 nFeature Playback error in NX 9
; O Q* S V: @3 G0 I9 M+ q
. B: d3 I% b+ d1 [/ M2 M1964501
. V% K/ k8 O, A9 v; G% c 6 l8 x: B: R6 R- W9 h1 y
- Q; @& q& c6 P! n
8 r( O) ^1 k" k1 v( y% O19645027 b4 h- d3 p1 {1 R- m0 A
9 e. Z I/ ?7 G f( IFeature Playback error in NX 9
; p& E( C; _$ i+ e( i# S6 e
$ H { g5 }/ N+ g1964503" j5 R& T# E U4 l5 W: ^
3 h A: [: U% C, F, w, b; V
% W$ k0 A1 J$ b0 @$ ^9 I " A5 d+ J# H! n9 ~) K1 p, f( I
19645066 n. v' n4 Y: N; Z4 \8 l8 c6 q
% l5 h- t, ^$ R
Feature Playback error in NX 9 ( {8 _! {" e r& u9 E1 S$ q. k
& M/ Q0 S' p$ m# o+ H8 f1964791% B+ d7 S' f, ^7 v% V
J$ S! e# y& O5 o8 b% }Hang appears to occur when creating PMI Dim in a particular view # [) o- G% h+ z% F: c4 F8 Q- n
1 Y* \- L) F) ~! d$ A7 A% ? H4 z1964814
5 o0 D3 y% h* y& Z+ o4 Z # @7 K4 R& t4 B
Feature Playback fails in NX 9.0.1 (part from NX 8.5.2 failure free) e4 t" }6 G: e& I" b
* t: w' }/ n& F% g1964816; L$ w: i7 w# U; |
. A- d4 i$ E& lRegression: System hangs when specifying hole dimension in sketch - y+ h. H! e ^* |4 Y
+ h- ^7 n( Z. O) Y1 o& A
1964850
" z, C0 Q3 s" m5 F: l
/ }. B" j. F7 f/ Y7 zGroove_OD ignores stop position point while profiling
# \: j6 |2 G" |1 I V- m$ x$ G 8 @0 V) o, M9 A2 A
1964960( [ ~5 z3 \6 z8 ~+ g% T
4 F1 F7 i: ~( u% O9 P. f; A1 m" @
Opening Point Function fails to invoke the Selection intent options
- K) g& ^6 s" E9 {7 p) x' B % s k+ l1 e0 D) {
1965056& h6 h9 n6 K5 n+ Q% A( q! ^
0 a# u6 ]& U3 `0 f4 LNX Session crashes while editing Product Interface$ A$ N* }+ A' h% p! U( U
o: {& F' V: ^( T8 I1965106
8 E. r% T+ E2 v% h6 D2 N. O; d
: c; ?2 H2 U q% mMidsurface created without offset1 ?# Z' \7 r5 O' ]; H2 f# _; J, x9 c
8 \+ Y% A9 {5 Q+ Q; k1965125
$ d* L7 C# U( L& y1 V( G) P9 g& @5 G ) M1 r! e' F8 j" ~1 q
Flipping draftdirection after feature playback
, h% B4 r0 W# G) C/ z# x 8 N" r; P8 Z! ~! f: I2 w
1965198
, \$ S+ g3 z5 K8 v
7 ?1 W3 Z' _& o: h' v+ c: zBad display after Create New Parent and Creating LW Section View
% g$ a, z5 ]- {8 S1 _
& B+ r& m! Z7 ]9 \+ k2 w19653283 e7 w+ q! o) C( _
- X- y) O) i* C" r/ D
Time stamp changing and Alert after Creating Linked Mirror Part: Q# B7 v: y1 G' e0 F7 f
* K5 ?% _+ a% _, ^* I( R1965556
+ H$ g/ U/ Q/ X' A6 Y) v4 c/ s D 9 ^ {5 \; r, H; j
Intersect Curve takes longer in NX 9 than NX 8.5.2
, w! H' u/ K1 e: c( i$ V, M
+ ~$ k( b0 V" ~4 y3 t19655678 U; h. {/ X4 W1 ?9 n2 \1 W
* C- v% w/ x* ~' WUnexpected update when activating feature group
7 P- t# ?* b6 |$ q( A W9 f
# b' g0 C+ y& v; A1965605
+ [3 U9 S) W, `" K
1 Y! ^; w$ u4 bSynchronize Links breaks linked elements
: m9 U. x7 h8 X- j% c3 W$ @7 w 5 |4 z$ N$ A% @8 q* S" l
1965775
6 m- @8 A N& R 9 G- s X9 A) v0 n4 C; U' j9 m
Edit parameters of Hole Series feature does not update all parts in assembly
/ n( }8 ?4 w4 m5 D* J9 v% o
$ \ D4 X" _: e( a7 S1965797
6 B9 R% H, ^$ R # W0 ^' y9 I2 R8 F
Limited feature reorder2 D. o8 [, ^8 S( |/ i; G
2 e [6 Q7 _- Q; o% s
19658002 v* ~# Y" ^8 Y) @/ y2 E% u
2 B ]7 E$ `9 Y% q
NX crash - creating a Hole feature 5 e- v; S! x8 q: r2 Z6 Y
$ L1 @7 j% N0 X* Y! J
1965856! P/ D4 X4 D$ X$ `; Y9 l
0 X' y: T, o X4 Z7 W' ^
No name transfer of interpart expressions linked by WAVE Interface Linker
. v# `; ]8 r+ d4 U/ O+ h) E
+ { U& Y+ H0 z4 R& L2 q4 ~4 y1965867, H; _6 n4 Q0 E
- r. ]( a& w- yDynamic measure in Assembly sequence does not work (is not shown) 8 b; H( \# X: L' W5 u; z9 T
0 p4 {) ~3 c, f7 g8 H+ M4 F
1965876
) x1 h$ B1 f3 Y - j* G. _2 h: k& j. Q! d( c8 M
NX Session hangs while creating PMI -- Radial Dimension with static wireframe 3 E# V' ]7 j/ y0 w
5 Y1 O4 ?4 N8 ^) ?5 x
1965897
( l; D. O9 h! O
1 u# z9 u, E) P- R( g' P( w) M3 ^7 LUpdate to End takes longer than in NX 8.5.2
" @7 |7 \+ {: g: t u. F/ j& k* p, v
6 w9 D" h% I) L( k1 @/ `3 I3 D1966018* X( }4 @, T R: k+ d4 n
7 Y1 V0 i- X4 i2 L; u* e. I
Pedestrian protection feature is not created
- O3 ~! i: L! C
. F. M6 } C0 j c1966080- b! A8 v% |' G5 Z- W
4 @3 L7 d& U) BUsing the phys_material.dat NX allocated memory space
. } R' B7 W3 I' A A2 \- A
/ k6 O4 l$ D1 o5 z& K5 E1966188
* Q3 r4 ` J9 k% U / d p! o$ R, G! l$ @# o' c4 ~
NX allocate memory after closing all parts: m; b8 e) S7 q& i- p
( w7 x! y0 @2 k1 j. u6 B& g$ {2 a1966283/ @0 X/ m! W7 |, S+ Y( @# |
G5 s- M' W% S- }4 _0 C4 CCSE crash with C++ error due to wrong variable format in siemens840d.ccf0 O4 {3 j; Q$ G
6 P& o& I {5 ]
1966505, C6 t1 V# _/ |5 e0 H8 h0 H/ O+ n
$ l- ` N+ U$ z) G2 I1 x' R/ j
MULTICAD Performance Issue
$ a/ i6 B) @! t# G
1 ^" Z+ ^5 z& p1967169
: i3 N5 C7 V( F. e; }! e6 v
i- h1 p8 \; o9 e0 E' [Problem with call of CYCLE800 and different kinematic chains6 `! k9 n/ B# J, J) c1 P" W6 K
, A/ g; p4 e3 Y% c: \1967970
" l# W1 J- I& V/ w: p 9 O2 |9 \ j o4 d% e' |3 h. b
AttriMapping does not work for Item types not available from Display Rules
" C8 e/ E- Q; t; [( i$ i! u 0 ~$ Q& \, V. }+ ?
1968036
# f8 H0 U. Q$ A" T' m 4 c% i9 [; n8 `* H* p! F
MaterialMissingAssignments is not updating when material is assigned to solid
' V, T- `! I/ D) K0 w
3 T7 ^0 t# t4 x5 ~2103147
4 G8 S! q$ Y# O; J# p6 O 9 U1 ~' E( Q' j- M1 D! P' u! ~0 m/ F
Information window doesn't appear in working with new part file:Blank ) F) H" u3 X5 d
) _- l) ?( | a/ Y2146943
; v- j7 O' ^5 _) e ) f( s/ k# ?$ ]4 ^
Journal playback will not create the patch with "Mold Wizard Face Patch" 8 L- ?) e+ W j7 A/ B2 G+ J
! k5 F) L' M. B# L( l4 p
21478572 v/ M( J9 R, s* t& {1 x
. b* U. ?1 e( Y$ ]- n. E$ uModify Part Preview option does not change Modified Status of part 2 g9 T- @! V" x# x% U7 A3 t
8 q0 t+ A/ G% p; z8 V21594684 Q# A1 b" N% \0 t+ Q7 ?9 p' |; g
7 q% J+ L& [7 ^3 u- k# r( `
CPJ: A leader breaks off ! A0 t( ]3 a! G
/ ]0 Z0 E- `, o6 Z2 x; f g
2162891
' V- o3 U: F0 {5 [" u# D. d 3 `' v9 T$ `; a' u' H+ C
Circle in Custom Symbol can not be translate to JT at correct position ! d3 p! M" o9 [- _( f% J0 }3 q% \6 y' O+ I
0 p2 h+ \5 y! d- o% q- h
2164866( t- j" e5 Z+ u4 M" I0 g1 G
/ T* A. d$ [+ p0 |1 H
Circle in Custom Symbol goes away when I rotate view: Q! R, i0 `+ |3 `! U
/ f+ {# ?& y4 x2 G( S& Z3 s2165740 C1 R$ D$ ?* N2 m% g' s# q: O
1 U* l2 T, h4 E1 l4 n& S" s
Patch Opening can not be updated automatically after "Edit with Rollback"
' a; i" G& s+ V" F4 y7 x0 q
6 N- r. Q o+ u' D5 {5 ~6 v7 O21717252 h$ y3 m5 r3 [% P& L
# ~" G' `" D4 R7 V H5 RThe display of suppression_non-geometric is not correct in ANT * q3 `" K) u: Q/ }- a
8 g, T7 x. ?* H; y6 \ o9 E* D7 b2172807
7 t$ K* G+ J: f& y' }; F
+ P9 `# ?) W. M4 rAbout using "Suppression Components" for NGC in NX 7.5
8 j; [9 k/ P! a8 x4 I: Q
0 `( \1 k% M2 `9 B! g$ V2176652# ?9 y! S; x4 f' J! _
$ u5 ~; l/ q9 d. Z9 b
UG Part attributes sync does not happen for Items hidden using display rules
4 M! x+ P/ L, r9 M 8 |1 j2 x; r. }9 {
2178538
+ o4 b$ `- O# x! E1 w
3 @# S) Z* F' }4 N6 @) GPatch Opening creates surface which contains unselected edges
- y* G: e$ L" [: R C4 N
( z$ A: P- B4 W" M+ `$ k: x2179412
X8 f0 d$ t5 J8 }. n ' R/ e2 Q' C7 H. X/ M
Drawing is shown up-to-date in Part Navigator when it is not
3 I2 I) u# f, D
9 O8 u; a1 K6 |7 z' Z- [$ W21809866 N9 K/ x$ @! K$ i
, A) R9 {. S# f2 F' E
NX print does not inherit the printing properties " @$ L0 X7 W! [( L. y4 N
- h- n/ @4 ^( z4 Q) W2182954
. x4 E1 t& z" c% ~9 U
% a- Y6 \4 c4 xDeformable part does not update correctly when component is moved 7 H6 | @; P, x+ }" k! a
) ^; y5 u' V7 Z" d2 Q4 f2186588
K' R3 y2 ?% I' ?6 ?, @) E ' l7 r0 K/ O) V' x; H4 Y7 ]
SST CSW: NX Crash when de-selecting a section curve during edit Extrude Feature
# k0 V/ v) ~1 a" y' J6 i; Z) g1 z 5 Z5 }- n& H6 L2 @
2186647; X. s+ [( a N' f& z
! g5 v0 U& _8 X( P2 p) E
CPJ:Incorrect location placing PMI dimension using Datum plane and Solid Edge & u' F2 ^, u% K/ b1 O' h
8 ~6 T9 b. x, n$ o. @
2187291* v$ C7 h3 [& @9 z0 k, w
: H% n h$ @$ {" `0 a
Unnecessary description is added to Feature name in PNT 6 T0 V* }5 `1 l3 ?" R+ {
+ S5 l1 T" } J% K6 {& p21904488 T ]7 Q3 T/ C0 b5 r' y
2 ? }1 G0 x' C
3D's arrangement view is not reflected in drawing view
! N/ p& G" ^/ H! W* w % E# E, p7 m6 F) T- E M0 a' ^- I
2191429) v- Y+ }4 J% m' z, a% W1 c
8 `0 g# a& E; }( |8 YAbout the behavior of Patch Opening
& H0 U: Y/ }! M! x
6 R( b7 e2 s! k4 R( T$ l2196229% t, q7 K! Y! c. f1 s
9 R7 f2 [& R8 t% H- G$ gITEST: "Routing BOM" functionality is not available
8 v* x- }1 g4 O' p- n2 L $ G5 g' R& ?0 g5 g$ w g
21967058 S9 I Z" w) X' r1 `
, g) z( y/ M4 I% R7 x! [- Y
Custom symbol is broken after rotating the custom symbol
7 d. t" K" `7 [5 i% M, w% P
: O$ J2 ~/ P C1 h# Y' L2196858' k5 j: _; u& K, m7 T) Q( _
, G- U7 j$ v* dIncorrect mark for 'Fullyconstrainted' in ANT when partfamily values are applied% B1 ~. p6 f* q( g
) r% Q' _- U' ]( j- p2 i3 {21974310 c: H& E' y4 S }5 w+ ?' s/ s
3 [4 x+ k; ?( _% ~) S$ VCPJ:If a Spline Path is edited, "Lock Length" will turn off
5 m9 q5 A$ \' F# F
8 h3 B" v4 _9 f" `2198637" N" p: j" D6 p# H8 U4 ]7 e, \8 t
$ v$ G- J5 ~: p; a4 U4 C" v) t
Ordinate Dimensions text jumps to the different position
4 X& s1 K5 i5 ~, G) S9 ^
0 F' `- l3 t# w6 L+ {2199083
2 Q- d0 F. o6 d. f# {/ q: }9 O 3 Z' q* }) U: f0 S1 x/ `! u. ^, z
MR : UF_VIEW_ask_visible_objects() is returning the invisible objects" M" Y* Q) ]7 F1 K2 Q7 r1 y8 c5 U
# `( ~) b1 [( ]2199790. r: K' f% P5 ~1 R' I
( W3 S" \& ^3 ~9 T6 W0 ]; H2 r3 nCPJ:Can not run "Stock Fold" in particular case 5 D# p6 s- I6 Z4 i
0 O% Q* o+ t5 _" k% j
2200008
' V, z9 u: {: W( Y% u
* a4 N! L3 S- x gAttempt to free already free memory in Storage Manager error appears when PMI no
; S" h, u! k* U 2 J, c. @4 j Q+ x S5 c
2200025' g3 O+ t* Y9 Y' y1 x
3 M: `: E1 n t2 e9 X4 ~. S
CPJ:When you convert a 2D Exchange,change in "dimensions" 3 o) ^( g! k. r' ?$ K! n
0 B0 j, Z3 m/ C% P2201630
& A& n, G! m: W: p" b 1 t1 `! o1 O, m3 h- B
Routing: Deformable part is not able to move in Z direction by Transform path
# }* @- f+ G* p: C- S3 g
~/ X4 c s b0 W* p' z2201852
; R) a, @$ h- k% x6 y
* b- M( J* }1 i8 ~! kCreate Spline path-Selecting Interpart edge for point on curve gives Int. error & r, }) \8 V# `- R0 l2 F; r
9 R% y8 F1 U I4 k; f* e! q2202611& c% o$ I7 e4 c2 s
8 m9 w7 d2 V1 I3 v
About the feature error by upgrade of NX
M% b" d& E- e; b
- M7 h4 _+ Q2 A: @" M, g1 C2202821- L0 V: u1 B0 e& W) ]. X7 ^ q
2 v9 g3 C/ w4 p) x' d$ Z. N- v [
When representation changes, view become Out of Date" s: J2 K" E/ a3 f9 A/ H! V
. ^6 S3 M' c* \" ^6 e1 L2208776
, n# `, Z1 r; @1 p 5 ]; D0 a/ j% S' k
Playback of a Journal which contains Traceline will fail
8 ^- ^3 t# {6 {7 n2 R" @2 c: N 2 c; E+ Z& |5 d& |
2209481
8 i4 X' j8 A4 B( k% C+ f # E! ?* x. K! k9 K& i, ?
Snap value is not remembered in Move Object
2 w# k$ G% T/ U" m L" ] : v2 d- N2 ?# F5 V% L
2209823
. U, B+ e# G& p( H: p) Q ' c, F: _- H6 F: d8 S
CPJ:Starting of a Feature Edit Dialog is very slow / I/ K [# m- L, J# J% c2 O2 p
. G4 T/ ?7 p6 y# S! E# j. [* a, ^- ~2211023
/ `( j! T8 D* l0 R5 A! X, a- G 2 X# k" V. ]& F5 v
A single sweep feature is split to three features after Playback or Suppress 1 m2 K+ x' k' x$ |3 ]& ^2 Y2 H
3 k/ `% o: [& S" ^% K
2211464 U1 @2 E6 }( u% Z# y8 d( \
0 V R8 o0 Y8 c4 u/ \: r. T9 ]* LReturn Point is not output into CLSF in HOLE_MILL created by FBM , m' m X% g7 m0 X" T4 K
1 X% Y4 A' g9 F# H/ o; i, b9 e2211721
$ r. l [% D1 B- m1 S- A ) E: _( r3 K) s! W; i2 D; Y: _
Setting "Return Point" causes the collision tool path, I' U K! G# x: W: N0 O8 m
: u1 {" N# Y0 z) ^- j+ A2 u5 I* q2211773! F j+ G/ S) N5 G$ ~( @+ E
5 ?7 H7 G& n+ k% ^Segment of Spline curve cannot be projected 5 U$ c( k+ {* u. {5 s
! ]/ D$ r. k! M3 f' p
2213373
: n& z. t( O# y i/ j
6 {! ? }7 E$ V4 [1 M2 x; B* JAttribute added to Bend using the Attribute Templates is not displayed in proper# ?( q( ^+ k3 p/ U6 S# T& v
; n' J h) d* }" |0 n8 i
22134504 B1 `% u+ f6 l! a3 Y) G
$ n. T* |, N6 P7 U9 eCPJ:After export "2D Exchange", Angular Dimension changes
$ q* O3 Z3 ]9 d) c' }
+ X+ q3 L- M# d/ r2213918. }' z7 J0 |3 p {
2 W6 E! }2 U5 q8 {" UThe point separates from the curve 0 P3 ]6 ?1 B0 a+ }! @
+ Z8 w4 @" t6 N: m- r& f
2214655
5 A8 x* M* q1 F7 [. { Y- g 1 ] o% [0 z( `( v X' t
[Sketcher]A position of "Radius Dimension" displayed unexpectedly after zoo-out
* L! ~5 b K/ y$ Z/ u$ S2 s: F
) Q3 _& g( S! A# T2214767
5 m5 g% h. {; F# m # ~2 f/ _ [9 @& |9 E
CPJ : After performing "Insert Sheet", "Read-Only Part" dialog is displayed ! X! M+ F {6 R+ z/ D
- g: ]2 a$ C6 x+ m& @5 d+ z; A7 w
2215785* V$ [. E& S$ w5 G0 k; A
- P$ Z* E% u: |4 ~# O0 u3 e) q8 ?* T
NX 8.5.2 iTest : Internal error occurs in [Lock Part] / R# c1 \9 W6 L
/ j2 V; n$ r( _4 n0 A/ Z2216228
V% N% S3 B( \5 _9 K " N( X6 _/ `) x
The line under text of surface finish symbol is reversed
, ?+ n4 z0 n; C; j - K1 j/ V7 C7 X' a7 i; x
2216461
( s. G( t6 w2 J5 z" y! U
9 M7 S+ W1 O3 h5 z7 CColor of a "label on parent" changes partially after exporting to DXF 5 F' V: ~6 J: ~1 u O) O
: p' B4 U3 g( n" V% \2 S2216500' w. p9 l. g' M2 E- M$ \* t$ q
0 D2 T9 y" L5 V: P( j
NX 8.5.2 iTest: Internal Error occurs when we select "Make Constant" in Transform 1 |; F, E3 t7 F! {4 {5 ?
* v7 d9 e! K% q1 k! x. a2216970$ S5 q" ~- a1 I7 `/ l8 }
: B* a+ w0 N+ s8 O; M- I6 N
Attribute units are invalid (not known in this part) 5 e i2 \& C, `" m
* A9 _6 K( r# I+ z5 ?- G! D# G2 I8 S22171079 \! V S8 L3 x! a) k
9 @; K ]5 r! J9 }NX 8.5.2 iTest : We cannot select another component faces ! \/ G7 R% \# s5 H; G
( Z3 C* m) c/ B* z. K7 ~% `22171259 J3 o5 y( H4 j" D6 F
& k9 Y( q- u+ L1 Q9 q. K, h[ps26.0.146fix]Extrude is unable to draft if playback the data of NX 7.5 in NX.8.5
4 u" [4 i3 W0 L) l4 _
# j& M& n/ ~1 D, W: Q5 q5 Z4 m2217133
& l% e Z; [5 y3 Z3 ]; f; T7 c# c
; P: G7 C% a- m' oPS26.0.171 Error of Face Blend when playback the data of NX 7.5 in NX 8.5
. k% `' Q5 Y" ~$ B& s G3 f R( D' z1 K. Z7 [; G
2217347
1 i- v) P( Z' Y/ E9 p, R ( S0 t7 s+ T3 h9 j6 k8 j) }
X-form operation takes more time after [Apply] and [OK] compared to NX 8# D6 l0 x- D# R0 ~
2 ?' m. ?, e" X% ? U& R2217396
0 R1 [ P. z9 `) L E0 K1 \' D1 A" M& m: j
Creating Trim Steel fails
# y8 L4 v. G4 K- u
; n/ n) A) J+ Y( a' F' Z/ l. c4 S2217437; ]. D7 ]' f1 v7 L5 B4 _
- g! U% v+ E/ ]: w- e7 N4 M
Setting UGII_UIFW_SAVE_MEMORY_ON_CANCEL, X-form dialog closing takes more time
% n p) x9 I7 [9 n' u4 z5 `( z
. }8 I* S, q8 O& h: P2217620: a$ m. f2 a6 z8 c8 g
5 _( c) D/ [$ O8 }& b% h9 d" s. M<QUESTION> MI assembly filter applied to view doesn't display PMIs correctly
/ W7 k1 e( v7 r6 U, z
0 ~2 d- }# n. C; ]% R) J1 L6 O22176302 q+ ?; Y, _. ?, U( v
9 R" V; E+ K" Q: M" s/ } f
Unable to open NX 6 files in NX 8.0.3, the following circular update was detected
* a2 G* F! @2 J; ^
# E. X& Y6 Y8 [. B# X2217789
N5 q( M: R% Y0 o* H4 c
+ i5 w; a" r, i& Y& a$ \) @5 uPosition of dimension text shifted when export to DXF
8 s, F8 S4 q$ U* d
$ Y2 z% J- j; n$ C2217790
/ A W, s% L. W$ f# j# O$ X $ G. \+ t" S9 ^3 c" b
) c5 Q. l) C5 U/ |2 n & B8 ]/ a+ y& n( \ q
22180717 v7 O! ~# h) x* d- K
9 a5 Z" X. Y4 m g H8 O
Export_Part command does not operate correctly s s. _) I* a- }# Y6 s! e
9 L8 l) c- C* j+ Y9 z) a# Q6 f2218318/ M2 Z Z4 S+ S5 J" d9 H. w
% S! @; O# R, yPMIs specified by By Model View Name are not displayed in NX 9 Japanese mode( h' H) r6 ~2 f5 o: K
) \# X5 Y$ c# i7 W
2218655# H, A" V+ x. ~& U- L) O
8 y. P/ w% v8 E# l Q# O% l# }Unable to open the part file - Internal error : memory access violation2 P1 t W9 H5 R. M% w
8 q7 K7 ]2 b7 K7 l+ v6 I
2219088
6 L+ e, D' @$ G; G: W+ _+ T
# v3 O( J( n9 m+ E- R! O8 wNXOpen.BlockStyler.Group.Members() property fails to get members of Group UIBloc
, H7 \* l0 o! h0 r , f# t: B4 Z! `. b
22192808 ~0 R# O2 z& {) k. W
. ?/ n) G7 g2 @
Deformation settings differ by results of the output
1 Y- U5 G! g6 V- t- P# V + o* ]; B" a; M
2219781( t- B$ u+ f; |4 u' j' t
7 ?/ p1 }; K5 C# _9 }! I6 g
[CAD]Unable to get the information of stock segment in assembly context
9 b9 D- H. z9 F& F- n $ Z& | T* }" T! U/ w
2220089. U+ X. N9 `" z) N- R$ }. n n
2 t( f9 E- T' j( q/ N% u _$ STransform path moves routing objects partially if other command is used in b_w ( d5 Q7 K) q5 W
; e* d* `3 O& F" T+ y; w. c2220234/ ^; V( q" T, D6 Z) n7 X0 {6 {
1 j" _) K% I0 D' a, ^
After creating and placing the text, It does not re-highlight in Note dialog " C1 `% f5 d0 f! j F3 O" t9 Y
0 N; q$ p* H) Q' ?$ |; _$ Z
22203199 ?$ X" F; }- [" r- T/ t
: \: z& d! L# n3 B8 ^
Error is raised when using Contact Force Function with Recurdyn
% v0 X9 ]- k# L" g0 |8 d
; q0 P$ Q# H( j1 C+ u2220385
. p C0 X, D$ O M6 P) H
+ e: i9 a6 e7 P$ g4 L" XProcessing speed of "select object " is getting worse in NX 9.0
; B i; L* T( Z0 N) \) k' j
' ~/ @9 p' v- c2220513
# _ o! X. P$ o ; k( _6 }% r7 r, Y3 b' [$ T
FLOOR_WALL operation is making layers visible that shouldn't be
6 z. O5 y; G s( c- A0 m
2 {2 Z2 F, Y0 Y' f2220533, R; i0 {7 [. f( n
+ \& H# E. @+ ]0 K- h8 B
Broken View not be displayed correctly 3 P! [6 A1 j8 s9 o4 x8 r6 \
2 T' y# f; j! W/ e% G& c E
2220622
6 [ w7 |8 m+ n) `# l9 }( H 0 V: N- o { a+ N
Setting dimension style returns to original 1 e% }. e$ B/ G. X
( V4 a0 h$ `8 [' p$ c22207171 ?) S, [7 I9 Z! f- M- E% N5 }
0 j4 m' O1 v" ~
Extract Curve cannot created in Exact Representation
, q; H: j3 ?' F) {: f ' c Z, R4 |% m6 h
22207415 X( d B% M M* l4 @
% H. _4 x3 b# Q( Q; p7 s% D
There is a problem with the layout of the new part created window
8 s0 Y; G" X+ }$ r c" ` ) e, O ]5 U/ H5 q \/ `' f
2220756
3 p$ E4 J% M# v; B% m! ~6 Q
( @$ a [# [+ L/ \6 ~CPJ atabaseAttributeManager.SetAttribute fails to set database attribute value
/ n n$ A- T O: e- K4 O . b& {# D" m2 V2 A7 z0 b8 j
2221000& E% n- ~5 `: S, G! z2 E7 n+ ?
/ o; w0 ]. h( u* I4 Q% b6 W% t
Not become the state where the display content is intended
+ g$ H' L, t8 u' w1 J / `8 c* L( P3 J2 N
2221012
" A8 ~( H) |0 F. b" d+ i! ^# d + u3 [! b+ v- A' u
The "By Model View Name" does not work in Japanese NX f' n! n; d/ k9 \
2 [, J6 P( X! I( v2221024& i& j, A- Y8 b! n _2 [* p
9 [% J- T3 M1 {( p& Y+ tEdge attribute is deleted after placing UDF
k* \5 E1 \% w0 i
2 J4 ~: V8 f8 H3 T2221073
2 I! M$ A. I) p z9 Z' b2 Z0 h
/ m9 l/ X0 U v4 e. ?. l: u6 MWhen you remove material from the local mesh is waiting to update . q5 [2 W2 ^& I# ~: v z6 f
* A, C4 K' m6 ~2221085
: l# z; I5 T8 Z6 s! N A
9 V6 w- A5 x7 W, _About the indication reshuffling of the ribbon bar + _5 F0 O% g% I7 M8 X2 {
4 `1 B; h) T$ T: q/ o% Q" _
2221097, a( i+ K! U* |; f) u
& t l3 C( F6 K9 G9 ]2 r
[Problem]When the user opens UGPART, "Read Only" is not displayed 9 y4 A6 B! G- j# Y. M
. {6 Z$ ^/ w: f j# s1 X2221216
% a, K( F1 o: K1 a
% e5 m, j- c7 @, _9 c& ROrdinate dimensions of legacy data disappearing after updating drawing view ( F& X1 ? E5 k \' i4 C V/ A
2 {# c+ k1 o. z. l' W" j
2221220
5 j. ?, b' K( e+ S
" C2 x! Z5 \( ?0 g% e& VShape of model changes in NX 7.5 and NX 9(5)
$ ^; t2 P( M9 M$ d
: L9 H# v% k- E/ |% _. O6 C22212216 b( w' j6 D. [+ L9 Y
3 K$ V# b( a8 g$ M3 X
Shape of model changes in NX 7.5 and NX 9(6) . ~1 s8 J0 V& Z# \* B
: l1 R5 k1 ]5 y3 k2221222
% @$ [& U4 } y. [ {0 m C" p7 t3 C
Shape of model changes in NX 7.5 and NX 9(7) ( s6 \0 R4 w& C0 Y
& k+ D/ j6 Z' A- h* _2221245
1 i$ ?2 r: x. Y; R1 M . g3 e. l5 ^) m7 b8 K5 c
Shape of model changes in NX 7.5 and NX 9(10)
6 |, u) u: d+ k0 \0 A2 e 9 F" I$ I# F4 W" d
2221446
$ q& T) h: o, B* [ \$ N
4 _7 ~/ E5 r) t j f% g. q+ U7 g/ F3 lWhen the drawing is updated, the dimensions gets retained
1 T: o' Z- M% \! ]
5 {+ Y# T" j4 u5 {$ a- w# g" ^% g2221534; z0 ^/ X) _ b0 P9 x! D
7 O, y0 ~, W5 K/ f/ t0 k9 _UF_ROUTE_is_part_occ_route_part() does not work well
- X: ?& E+ p- y. J6 [# t0 A- ^5 d, ] 4 s" @6 ?& U, B5 ~+ K$ t
2221539
0 Y) m$ L4 C9 w$ p) h3 D* G: r 3 s( A- O5 z( ^+ l
Cannot export Datum feature symbol (type flag ) to DWG g9 ~ p# Z+ K" h1 g5 c
% t. X. a1 _" x8 Y. o2222100: f' @$ k7 h0 y* p1 }: ^
' `' X$ D9 g; y8 X. r3 yInconsistency behavior of " roject Curve" command dialog box
. ~& k. t6 ^4 C+ P9 A! c S
5 a+ C! ^6 N4 f* ]2 R. L7 l2222180) O5 S7 i6 w6 `# o. y- f! i1 s
1 v, m, @( w3 e9 e0 e3 W
Hole milling - stock value inside the operation is not displayed in ONT & O2 o) h0 _+ N( t
3 T- y' Y0 i* t+ w
2222322, ?( [" K8 H$ d4 `: t
9 F0 x% [* C6 d* |6 D, ICPJ: "Open by Proximity" does not open some components in a file
6 H# g' q+ K' C* _
% w9 l$ b. X6 {) ^: b: w% y* o# ^2222342
4 F: k: C6 A, }" `9 Q3 r8 q
: y! ^/ o8 O. p% V6 ?4 yCPJ: DB ATT remains locked even after changing ownership of the component
' ~% i. _+ S) f0 \9 T% [# l9 s
7 a8 T3 f9 ]5 J" J& Q8 ]1 u22224975 y8 P" e8 g! I1 ~5 W
& a i) S! x) b: Q; W4 tCPJ: NX803-SST#03-Reverse Direction is not shown in the dialogue
1 F1 N* S; G& W4 z" v( M* V$ d1 v # y; F; c; z2 N, r$ l' P4 J# e
2222500
( C3 e/ v7 x) [0 R. D
( D5 q3 r K) B, a0 KColors in Step file are not mapped to NX " k3 D/ C( n' m+ O" }' i) d$ \/ o" |
2 m1 C7 Q) Y2 A' ~( N) Z
2222557; w" E% d% J' @
9 o5 S9 F6 w0 R: o$ N3 w6 k
CPJ: Dimension's position is changed in sketch when Zoom out: V3 S5 E; T q
6 [, k U! m$ k) d- J2222558! u$ ?5 `' B/ f. q4 W+ I& J. y
" o% z- L7 o3 v( l! c1 C& ^
CPJ:Unable to place radial dimension to the specified position
% a u/ z( v) G! L/ x1 s; y 6 e Z$ J9 U1 O c
2222623% L: L7 C: B# i0 x! {
9 x4 S$ g- ]9 J2 V8 w
<Q>Information window for update doesn't show depending on template
' J) ~/ K9 J) D) w( j! ?1 i
( q$ p$ j2 l( ]" D1 |8 N$ v* I( X0 [2222652
. m5 I6 |7 c2 v% q: M7 y" [$ c - l/ U0 u8 D/ a1 a, k3 S/ M/ X
STEP import fails from within NX ' G1 R' V/ @5 [ w
; z6 F; {7 q# u+ @- O* N4 H; e
2222685
6 x7 ~( I0 O- y3 S . H( d6 a& d% o7 N9 y
The profile of channel-section GB707-1988 is wrong
# ]. U2 h3 r6 h+ ~7 f
" j2 c. h1 T' K- J# J3 k/ W2222777+ Q7 Q! J8 l' a2 Y: v/ h% x; e, s
4 m: [0 a' Y- N% W8 `( [+ _The Preview of the Routing Part Library is not visible in NX 8.5.2.3
% a! N5 R" B; ]( w0 }5 e) J- N$ C1 H, s
* B4 |6 Q/ a6 E4 h! ~2222906
' `# C$ o. Q S; Q
& \! ?* U) D' E: n- N: c- M: nWhen AFEM has many 1D elements, performance of NX gets worse
b" G8 [) ~5 O
# h( `' E2 E( d% ^" p' h7 B2223076& N+ J4 J5 `) I: C. s, p9 q
3 P$ ~" L3 d0 u! N5 f6 H( E) m+ ^; z
The toolpath changes when regenerate the NX operation in NX 8.5 , x/ A9 e R' ]2 j! E4 a
$ W* g3 O+ k' n% y9 j
2223104
+ p% x6 X7 Z( W+ t- m" d 7 Z4 a2 k8 Q+ x: b) J
CPJ: RefreshAttributes() does not work for non-work part
) w. ?, W) J; h8 A% v$ [7 o 1 z4 y: j: k: j* H* n6 j) Y
2223120# }& ^) I' G. t' Q
. B; f3 y& B' k6 u" L( S5 ^( ZInternal Error appears during save operation
$ h, ~- x: A% x8 \: ^4 Q& e7 o + x9 F# M; z3 P; B1 v
2223129
% A$ L, R) s' \! G
! M; o) W- C( x" W8 ^NC: Editing drafting views raises "Internal error:Memory access violation" error. v/ [! g# I3 b5 C& k7 {0 y
2 V( C) k0 j& Q8 C, H3 N; w
2223249
6 ^5 N; y2 v4 s
" N) ^4 c! }" \. U' o9 K) }6 _+ c ~A portion of feature created by the [pattern feature] is missing 0 E' ], u3 u- I H" H5 U3 S
) p1 z5 d# r) U2 R% Y
22232771 Z' N9 U) y8 x" X- Y4 b7 j! w2 X
5 i/ Y5 b: ]6 m$ G* m# Y3 I) `Trim Boundaries does not work with "Follow Cut" in Floor and Wall3 |; k5 `; h5 X1 T% n9 d9 [
2 R+ y H% z! L' U% V2 i2223413" B2 y' D. _: w: Z. {5 M; \* u
1 z) k1 k5 H U/ r/ Y, U. d
Translation issue on dimension setting dialog
8 ?4 C5 K; w4 ], h1 S
, [" |5 l M) P8 S2223445
0 P9 c6 q2 ?# W+ F" T) ?% X $ ^/ Y' \2 H7 {9 n k
Chamfer Dim Preview is displayed as different text alignment from specified style' _, Y& N) o; t
7 ~- f% _0 j- ]$ f8 }. j/ D9 [" t! N
22234637 u( O" ^, f% Y) o- E5 j1 h
9 U% }. X2 ?; K$ Z6 i5 Q* H
Horizontal dimension will flip to vertical dimension when placing the dimension / s2 m, W) V; l! N
# d1 Z6 r7 c$ H- ^6 _4 U$ Q22234653 g) j D% I* Z# P8 T) W
, ^6 s( N% ~6 Q
Dialog memory in Radial dimension does not work correctly
2 s* w& O( F6 l! k5 h% s, J : W% S8 p8 V5 z7 Q" p; f
2223468$ E4 v$ l6 k: y
7 H3 }! ~: m5 l( |The setting of Radial dimension UI is not inherited
& Z6 }0 T& L* E$ h& W, Z8 u
" W5 Y# G5 a" _1 f; A! O! `2223471( B4 c- K! |# n* v" y8 G
5 w8 ?6 x# w7 hInconsistent behavior of Rapid dimension
9 ^4 |% L& p4 }; u! d % r. d0 m: x0 r. _
2223478
9 U7 ~8 c, E& d2 [+ x& [
& a7 z8 L$ U& K. BInternal error occurred when changing role e6 z8 w5 K! B+ [& M
! V# W$ q8 C5 M5 `* b2223480
8 y- \! m* T7 E" m9 F! p
1 n+ G: x; ]7 i4 [; H& p* y* XUnable to copy body of Flexible Cable feature & p" Z) m! P; l7 I. P1 e: a! z* M) J
) }' z6 ^# _; { I# b2223484
0 o6 |: [+ s& f! K0 A
) O7 _% E. n: b$ i# \: P% SType(Graduated) in Visual Effects does not work to Background& F0 e: E% b% _7 K+ S4 A
& b" |) ]) [9 s* p& d+ Z22235264 c# Y% {8 R) o
9 r) d; k7 S5 S4 Z3 Q1 H, L
Cannot change the selected path point to another
, d* R8 m2 W U; a 3 r( L- `8 a; C# X& g: }
2223533; a2 _- D7 T) r/ F: k3 T5 {, p. `/ a
& J, A! m+ H% Q) K
What is the cause of having both attribute * f! Z( B+ i8 K# ?
& o7 j% \( `& n8 x$ r1 @) f7 {
2223549
, h# O: K3 ^: C W5 a* K. ^% ]
" k, G+ ]* T& U- v+ o X: i3 xWhen create a shared body, it takes much time to update features
a" E" x% l& Q7 |/ M
( J* H3 b! _% c4 \# ~4 T2223570
& W* G0 T- P. g- R" c+ @4 a, _
! d0 ]" ~3 b- e7 @0 b. T7 nCannot measure other part's face when activating Part Module - D: s) u" q! C, B2 g- G
+ t; Z5 d4 w/ h
2223595
9 \6 r% X* r7 K6 S2 U j4 R
' s# g, B Q W9 @1 D- \We want to create linear dimension between 2D centerlines by inferred * B! N, Y8 H: m$ @
" u3 ]3 l$ U2 @, L g$ M22236002 d: {: \+ n ^5 ]
7 r9 ?6 D$ F5 X) l! _; P2 a/ N nCSW : Large drawing file does not open in NX 8
8 r% Y9 v9 Q% f; E6 v7 J* R . i& G9 C8 Y, o7 J6 q8 P
2223603
5 m- O8 Z4 c' `5 C * [% \4 Y+ }" T1 }5 T
An angular dimension is given by inferred
" K% g* o6 D, B* |
. g" q4 v6 c7 Z' I: S9 m5 c; c+ L2223605- M2 r' E7 _9 V( M. n2 a9 [8 r' Y
. E/ v- S' w1 l8 I/ J$ ?Fit Curve command having inconsistency behavior + q, _. n9 D5 }. B( @1 R
( b4 S4 t1 o: ~" }) s" Q2223620
0 \& \0 n. `$ y+ P* a& { ! j5 R0 J/ R3 `3 J
[TCIN] Unable to overwrite attribute value as instance attribute
3 A# ?+ w. P l 5 c( H2 K" M5 o4 p# e' y
2223651
k+ K) z% }( g) ^' s
2 q; d, Z% M+ P& ~9 Y, `From View edit, the component on a graphic window cannot be selected. h8 Z8 ^) z5 V: E
0 x; F6 q2 L4 R4 v
2223692
$ R2 }6 E6 N. m7 Y3 v) O9 y2 u( n1 s
) B0 n( V, @2 O5 H# a4 GTwo dimension with same value get created for adding a point to Ordinate dim
; N& ]1 X& |. w6 q* f# o# A
+ l3 H4 B0 d( k* I2223713
/ }% N: z0 ]2 d) Q6 y3 T
8 f0 o9 \5 `; X2 y% f" `$ k- bSeveral features are Out of Date when editing a feature in Linked Part Module * z3 l' W( d1 m: A
2 ]0 T5 D8 e# M T- O" p& [
2223727
( A' i0 W S/ X% S# f
1 \/ f8 Q+ [# }CPJ: Cannot un-highlight the associative face of PMI dimension for Section View
4 i$ U8 R# G6 q1 X" Q! P" X' V1 P5 ~
; S( n- O0 m8 q5 g% J22237483 T9 T3 g. D" R0 d+ h
1 O4 ?) u+ ]/ A2 ~9 I/ U" z* H3 zCannot edit Ordinate dimension that created in NX 8.0 $ v- w4 Z7 B4 b% H# D' D
5 C4 w+ R( o% P/ P( O9 U/ {
2223824
9 z# L" N7 g+ U
* h7 o( w& f5 s) L- }Failed to create Electroed blank in NX 8 and NX 8.5 other than default blank material 1 Q& s% o4 x; C
' b5 x! ]; L* v: |
22238709 Z( L5 R3 U4 @1 o( m% T! v
& V C; N$ c" Y. Vtdf.exe has stopped Error is displayed on Modal Test data on loading unv files
6 P" S a, E: R# L! F
) j% D1 p) B5 P& U: {' k2223980
( P2 ]2 ?: ?% a8 s7 {8 d8 i - y- e5 d0 v7 D5 z! H' L
JT exporting is failed when "Extrude:Until Next" is used# d2 \, f3 H0 x# ?8 n' |
8 b; K) B5 L5 @$ i/ k2224254
: ]& P, i: ]7 O 3 [9 W t) t: J+ [4 h2 c
AskMembersInReferenceSet() does not return reference set members correctly
4 h+ b% s8 W7 j* X" E 9 ~# D! {+ ]0 p$ A& H. Y% t
2224301
6 m# a s# N* A6 C' a9 u 8 K9 o. W' p: W" i. q) S t' c
NX 9.0 iTest: The suppressed feature disappears from PNT / h/ _5 n0 q( U/ \) C
B% Q* r a5 }0 k
2224305' }8 @% [+ O( n8 o
1 {8 \3 Z, R* K, i2 {NX9.0 iTest: "Details" in PNT does not retain contents . b3 v7 W, Z0 v) B
6 G" X& Q9 X+ u6 Z5 J
2224320
. ]4 ^( t, p4 z B
# L) ~( R. b" A4 }3 oNX9.0 iTest: Part Cleanup causes IE 7 ^! K5 n+ v# y7 m9 k* B/ ^
, W5 _4 o6 X a6 g: l1 c
2224322
$ Q0 J9 C) {- O) e( d9 t
+ Z4 t: S0 [+ T" m4 m' \ FNX 9.0 iTest: "Work in Progress" is shown every viewing operation3 Y! |+ {2 ?1 m7 i! S
( |. S+ R4 g t3 U2 ^2 z: ~2224436) X7 Q& j' u$ V$ s6 k( Q1 R
" B- j0 @$ N1 h/ d
CPJ:NX803-SST#11- Server error occurred creating R dimension by custom command
' b. t% a( v* _# E# S$ h! u. i H+ s
8 }3 g; G1 p$ X; _2224589
. @7 a/ c: L0 t 0 X | ]9 N" }( J3 n
Face Mill preview, it will automatically display the object in other layers
" Z* o( K* y* l4 n8 G
2 g1 S2 |# E T! S9 E9 v, U2224639
; C1 V9 f" t" C: C 7 P M. z% j6 S2 h# f) B3 L
The analysis result of "UNITS (mm (kilogram f))" is not imported correctly
: C- }' R% x' H$ c! b5 Y* A+ @0 K
& e N+ {' |8 @; j5 D7 a2224651
5 [8 f4 l( l0 E o. s# H8 ]# H. i* ]
Flow cut reference tool operation results Internal Error and More Calculation time
& m8 d: z% {* A" k ! q- x; ~' h( [1 Q
2224846
" M2 h% O W) U' `$ L & y! D! H- B2 H, K$ x+ c, Z
NX 8.5 Changing Tool Number Makes Operation Out Of Date , z+ s5 A7 a1 W2 q( v
* V7 o0 D( F$ ?22248887 K; _# W: Y& b! C _
0 _3 g/ V T* W5 `& WThe crosshatch becomes retained after opening the drawing
3 M, S6 o( F7 s
7 f* V& x% N& x- n' x2225036
2 g/ B" f1 r" U0 Z) \# D
. n ^9 H/ s3 M$ q2 I+ |Unable to Paste message displayed while pasting the copied features
& n% V% E+ E: ?' p9 [3 q$ i
2 T& v# Q) {( {, M$ h/ ]0 \; K2225089
6 v, J, g9 C' R7 U ! u. ^3 B- @! J- U0 ~- T& v
Assemblies open in NX 8.5 is slower than in NX 7.5) b: ], |# j. V$ D a9 j( p6 t
/ @2 o9 E) o7 B22251077 H p2 {1 ]' S* w1 T6 {" I$ P
0 H1 C0 |9 o( ]' d
Japanese characters are garbled when running Gouge Check with non-uniform stock
: k( v+ ?! N# o- Z1 @! r - I& p; |' |8 J. t( Y/ g# w2 ]
2225177
5 t+ x! t7 T! G: N$ S1 B: i 7 {& Q1 \- Z5 ~5 A: \2 ^
The legacy UI of standard part in NX 8 display is wrong
7 k# l" _- U$ R9 E3 [: X
+ [( C0 w/ Q; D/ h5 ^, G7 x22252064 v: r# x% R$ v' O I
Z& |1 n1 N8 Z* d3 X/ ]6 g
About the behavior of Parts List and Auto Balloon # a% B7 n9 U2 `$ v' @, C
! K; O/ U @0 Q/ V. M( P
2225244
2 o c# @- o* U, u 7 t- j A2 D. e8 u2 C1 M
CSW: broken a midpoint constraints in sketch application
! K/ `( @" z9 z8 {2 N8 C, A: A
h3 z# Q1 R' }2225355( T5 a+ }0 y1 Z8 n2 i& D* q) v: {
$ `# f6 l" l! j. `6 n/ Q
CPJ : NX803-SST#08-Cannot load Assy with structure only in NX 8
; Y5 W4 y2 [. P) r/ F * @- H$ `: x: a* k8 P
2225434( U% f0 Y& p! N$ Q4 M
5 C2 h# w2 T O- k O+ @
The dimension of standard part is wrong $ _, p0 ~8 {8 d* p1 T
2 z3 N v4 y$ ~$ t+ Y
2225465! @- n7 L7 x: Q1 B5 n% X
. g* K: o2 @9 H2 RJournal replay fails for 0D mesh
5 c B F' |7 `% c' @" o
, l" H* u" X% a3 N2 Q3 Z- \2225520
; x- |& i3 k6 c6 A7 D7 I' D- }/ _ ' T0 z& y4 a; B8 x. J# |0 u: B
MW standard library create the standard part with wrong size
( R2 y0 f5 N" t2 g# a. |1 F f& O ' y! K( v! l! p1 L# f: |
22255279 o( _+ }9 ^3 {
: T% X7 Y4 M9 y4 `2 f! w- Z0 LAn operation was attempted on an invalid or unsuitable OM object 9 c8 u0 R. e( D4 K2 \
- g, o9 ]$ t% j4 ~: g2225537
9 R6 h. ^1 i8 |9 |2 u2 W5 Z , F) O9 Q7 J o$ ?
The parts cannot be opened with an error as "Rules already exists" 9 T3 Y1 w. V" g- o' o, V/ l
+ I4 P8 u# ]# [, p3 T' e/ B
2225543
7 J( t4 K- b* \7 c3 x: [. P 0 j# x! ^1 F0 ^8 I7 p9 V2 t
CPJ: [Move (Component)] causes Internal Error H: ]& X ]+ Y l1 l/ R Y0 j
9 {* _. x$ H) s# |; g
2225558
& P3 J4 [+ J& P0 D4 l9 f3 ?5 i0 f
" I i3 U; T2 z% gCPJ: Wrong preview is displayed
2 e1 r8 U7 b4 u: _ X
f; y6 C2 F4 n$ W' d8 W- v3 L0 c- H2225729% b/ |6 n) p0 t: b8 ~- r/ T6 ~
7 ]1 v# H- f }3 I: w* A
CPJ : Ordinate dimension moves after view update
2 F9 j& L' Q. Q6 b) o9 R
) `: Y4 H1 T( y0 u" Y2 y2225867
# L1 w& ^' m% l _) K
. b' O! ~, P1 @6 I7 hPlug_Slot Weld cannot be created 9 n( E5 X$ y M
% T/ u% T! i+ k9 s
2225888
/ U; Q- \% U8 L' r7 q o 0 C9 t. n- F+ z" g
When sheet is copied before save, part attribute note is broken, n: A3 Z. L2 u7 `( `6 m
6 D; g& l7 q1 [* h0 D! }7 G: V2225897 C" M; X2 s, B- |
& Q* i* O4 n X8 L* p v2 d
CPJ: NX803-SST#01-Unable to load a exploded component by incorrect object error
7 U, m) u* ]' \, C; e . X6 W: R" G& I. a# T- l2 {$ E
2225945
1 ~/ S4 \7 b3 a% K
$ H4 q/ d4 m0 _! fCPJ:Angular dimension changes after drawing update1 [5 D8 x- P+ R z1 H ~3 n
2 |. Z; a& P8 }% W1 o
2225978
, \6 b) W2 j; {7 K T. n1 M , x5 Q7 v9 j. a/ Q! C* \9 S
Internal error occur when subAssy's PMI is displayed to topAssy v! ]! @4 X7 g D) R2 d2 `
0 a. q0 ]$ e- j2226110
( ]4 v/ @& P& |* w/ x U $ O1 Y8 u- c+ e( ^8 n6 J8 {
Cannot edit the stock size in NX 8.5.2, and NX 7.5 works fine
* I6 u; H5 E) p- q" p8 m h/ q$ G4 |! A
2226128
4 G; t7 n5 }$ [, I9 O; g+ ^ 3 J7 x0 \( N8 p6 `4 i: m
NC path is not considered the boundaries specified in Ignore Loops in Cut Area 1 }3 e) P8 Y$ u
9 V# w3 M$ @3 D3 ?
22261772 ^: u+ K( }/ j8 t3 T2 g
7 R) N% V; G: x9 `When setting Cut Pattern to "Trochoidal Pattern", over-cutting occurs ) t/ H, o! r) @" O; {9 j0 f
; i6 B" N5 t: d( K3 R! S! b
2226239
- S9 G5 ^9 h! H' H" G * v3 w0 N& k% h" f7 q& _5 a
If Feature attribute title contains '_', title name is lost when restart NX
! y% ~+ U1 M; H4 W ; W2 q# S+ _% e; l+ b
2226344. q n, I0 T6 V; i5 u
$ R7 v, d0 Q/ f0 ?" [1 V# JURG:Error occurs in "Simulate Piercing" of " rogressive Die Wizard" 0 `" v8 ~/ R! s7 G) O) N/ G# E M, A
9 [3 W' K# F4 C- {" O
2226411
8 M: @5 N, Z1 W8 B8 A
. Z w9 {; @0 GNX takes too long time to change the 'Rendering Style' from "Static Wireframe"! I" n+ ?5 V* b. Y* o& ]
0 i w) Y! ?, O
2226455
: T% r# \" h) J. J2 X# s R* o" Z 3 b4 O# s3 O- K
An alert occurs "Target body completely inside tool body" when Unite : ], [# D, k. ~7 G( Z
5 \! I& c3 j. o' y3 p* B! Z2226733
, u9 z2 ]/ L3 V9 r6 E7 E * h: q* W& L; i* S. e! ?
Internal error in the creation of the dimension
# C! q5 \) P; ?
6 A" q+ Z7 w; d: _! [ A22267711 P4 s0 e1 I/ d7 d5 h: Y2 m
: E7 J9 {& {. w( [Spot weld mesh not created on the selected edge & also duplicate element created
$ B5 O% \$ ^' K9 W: Z4 z8 @
$ Y4 {. L3 A! ~$ c' U% b( w: w22267726 f1 r$ N( f: t! Y8 C; s8 Q
8 T0 H) ]# A, a- CUnable to update the blank . i2 m: s/ s" H$ Y3 f3 z' I; s
" H$ ]# }1 F8 V3 z$ {) j) q2226927
. C( g0 A' l* }. b* d9 I3 X: a
/ \# B: B0 b# q, zNX freezes when OOTB "MILLTURN" post file is run2 Y% Z) U, ` c/ f0 c! a0 G
, ^/ b0 u. K+ C6 h/ f8 ~8 P
2226996
3 f( W }+ N# r& Q" q; n! l
1 K" i; ^. R9 X2 _1 O; bEdge blend behavior is changing while changing edge selection
" \1 P, [) `1 n 0 p Z) g* G) z' l1 j
2227110( T7 v& g1 S; L
$ a* L* b( ?& N P5 c
Iif part has very large size, the truncated error will cause problem
. T9 m% b5 G- ^, G" H- u" ~' P& |0 ?' z . J6 x5 y! k! V( B2 U" {9 t
2227142- h$ u# }' B" i& M
* c9 m& }! g9 v, Z) I+ zWarning occurs in GROOVE_MILLING with "Center Alternate, Floor first" level seq
% T# k+ q) |3 N7 b) j
2 t% W' s$ y" M) h: E4 S2 @2227296
& H& m k7 O2 ~ 8 v9 G/ d" |; _7 U1 Q6 Z
NX900-EAP2:Selection of a face checks out "nx_visual_reporting" license feature
) C1 ^: t& N3 Q
& D- J" b( P/ S! @7 |2227389# X- {0 \0 m8 Y( _/ t
. N% E4 I+ d; V# t8 z/ {: }
CPJ : Extrude section are lost the project curve of associativity after edit par
# B8 m; A9 h9 k$ u, y $ [; x$ }6 y# l& |0 q6 P
2227411( L* }/ M G1 E! i% p. q& S
" ^2 K3 \, b, h E# a! {0 R8 t
NX900-EAP2:Rapid dimension command falls 3 J- F7 U! W0 R, \2 ^
2 ^4 _' @4 z* J2227447
: @& h/ ~0 F, C* J2 o8 W" U4 Y
. e% D/ p! i7 Y, [( kNX900-EAP2:The angular dimension using "Inferred" method is not created
. [( w" h, x6 l7 ^& D4 V: r ) c* d% p, p% Z( O' K/ i
2227520# ?/ ~! ~% l* `; {
& g) A1 I4 \6 K& W! f8 G0 u% lThe origin tool of a Ordinate dimension cannot be used
. X3 w+ T- F4 M. q* N2 s9 B' I
) A2 I6 m& u, ~& @- B" d/ D22275626 f! T l) u# z
0 S* b2 V! I3 M% k7 S
NX terminates when 0 is set in "Cutt Between Levels" and generates the tool path
* R1 q8 Q5 S9 O2 J7 u + m, J2 Q, `* s' k! c. Q( B W
22275650 A2 K6 m( Q: h1 d2 r
$ R7 I- X5 p$ \( _* M
Created Slug Holes have not been placed under right parent automatically
7 ?1 K' _- b2 {0 F8 n , ]/ j! K4 ^: c5 B; U1 q- }
2227880- q2 e0 F" g1 X
" [+ K' N1 T6 w) O1 a
NX 9 - NX Visual Reporting license required to RMB a Mirror Geometry feature 9 k* d5 o2 U9 h5 u/ M
9 |! n$ K3 U! d! F3 {2227979
7 _( Q0 [! m/ J" F, N4 c5 C
( h {7 h4 [6 x2 V8 _, ^; m- L1 s7 {* KCPJ: regionBuilder.Commit() throws unsuitable OM object exception
: d9 x* C S! x. G# O# o% h4 y2 y
2 K2 ~/ @ A3 D% o; R2228109
' L. o' ^4 n9 F* J
7 W) k0 H' s5 `) x* ]: \If Break Corner exists, JT exporting is failed
4 F6 g0 c, T1 s; m5 ?% ]6 m" y8 y7 o/ D : `9 v( @0 O7 C) k4 W3 Y
2228139# I8 j; ^ Z: z3 G4 T/ M
, \7 E5 ]; A3 v. ^8 ]8 y. S
What's new of NX 9 wrongly includes the information of "Face selection enhancement
2 I/ T j' l3 H& A8 ~( q3 R: d
* u Q9 F& c" F: k2228163
' \: r/ c+ D7 H/ g+ k. Z
S* d4 F" Q1 v* W9 t. t. MFailed to select the font with Chinese name when add the technical note to NX
+ h3 ~, @7 |6 a: Z J9 A5 w
- F0 v+ v# O9 y" R, s: j/ E22281718 x) ^$ C; k" N. B! }
" m+ ]$ I- N: J& V4 m/ V9 k4 a
There is Minimum objects in the view
+ f7 i2 d5 n, n5 K7 d1 l* \ + V+ Z% W1 x9 F3 ?- z! e
22283743 W% q z2 \+ x) l, T+ ]/ h' K
, Y! t8 b$ r, m0 l5 l4 n/ r0 d[CAD]Unable to open part file9 [! l+ _/ ?! u. f5 W. P
. e. ]0 x% r4 i7 m6 [8 O3 [! \/ @3 h
2228515
! d) x( v; }9 |1 H' x
1 U# F; I5 k( F6 t% {8 u; R* d3 D" [5 ZIf edit Angle measurement which link is broken, internal error occurs
% y- P: `, [) K) a
" A8 z! E0 s) w0 r2228520
; z0 ]6 f0 n1 N8 {2 H , d- F" r7 H4 c8 c- c: e8 ?
An alert appears in COUNTERBORE operation created by FBM5 J& A; u. {0 }/ ^% _
& T0 u3 A& J+ K9 K% L
2228807
5 K6 X5 m7 e5 I5 R; v: j$ `- d. m 2 x9 _5 C! Z/ W/ |$ X
DPMItpBuilder.GetExtendValues() throws an internal error" h0 G) v2 Q/ V5 U/ H
) C# b1 y; \' _; N9 k2228819
9 \8 G/ F. T; [; ~; [& b 5 h3 j4 ~( R3 }" C1 h* V% M
ISZ_VUP oading of a component(UGALTREP) is impossible
4 ]/ M4 R( a }1 n 6 v7 Y7 E- h' c& b8 c
2229021
. ~3 h- W/ s) u+ G
* y- L* ~) I6 u9 eCPJ-VUP: UAF (NX9.0.1.1) Feature update error occurs in Break Corner(14) t8 t9 I: [' k
. A B! @" `0 L
2229022
: A. R% u5 n9 k" z( w8 J0 j6 i( T
/ f' A: i: B/ \CPJ-VUP: UAF (NX9.0.1.1) Feature update error occurs in Break Corner(135) / U; `7 _% ~2 e& Y& K
W3 f# W) a6 x. y' S: H _) ^
2229039
/ j/ E) g1 g5 U) D 2 s, I6 l0 ~# x P+ q1 o* H" ^3 I3 k
CPJ-VUP: UAF (NX9.0.1.1) Feature update is causing SB_TAB section sketch changed( M6 ~$ N3 ]$ g/ ?" L' x" X
" `0 c' @) t9 T3 s: M- L! C& ?) k
2229042% [1 ?/ b: I# ~' r: @
1 { B) F0 |1 Z6 p; B0 V
CPJ-VUP: UAD (NX9.0.1.1) Update drawing view causes Linear dimension changed ! _% w' Y/ n: N1 Y4 P. \
2 z& A9 V& [0 L) c& x2229047
% Z9 G% A6 }8 v4 W 1 i9 a1 R0 B5 g- J( a% B2 L* {9 C+ j
CPJ-VUP: UAD (NX9.0.1.1) Drawing Update causes Ordinate Dim origin is moved
& c3 l' P0 z7 f% V' N z6 p- ]" O0 D) ^5 M
2229185
$ ]- ~3 W2 f7 W L5 H1 N3 q4 J , N" B8 @5 o* [2 ]/ v& m
CPJ-VUP: UAD (NX9.0.1.1) Drawing Update causes dimension associativity lost 1 ?3 Q* q! K7 \/ _% n
4 s9 [! {0 T% G# j6 A" l* i3 o
2229223
; l' P9 a; Y2 s. d0 x+ j% _( _9 X3 P6 z8 J + ]6 N3 [/ F, [% @; P. D u
CPJ-VUP: UAD (NX9.0.1.1) Drawing Update causes Ordinate dimension Origin moved. ! G% c( C f: U
5 T; ?4 t2 K1 `' I% P6 `3 M
2229224+ \+ w% v" y O2 R$ P
7 q0 o( S: L$ lCPJ-VUP: UAD (NX9.0.1.1) Drawing Update causes Dimension lost its associativity.
3 R: l" E* D4 E9 @6 `1 B: S0 [ * W* f3 x/ `) `7 p1 W
2229244
' R2 D( Q) K* \: d& v$ _3 J 0 `* f" J( a. e
NX crashes displaying AFU functions after changing display Unit
( p& t6 b; y. l! {( d ~+ C$ B
- X7 X- i) _1 r& m& T22293352 W% I4 w& B* R* E/ F
' \3 t: o- v7 _/ QNX freezes when creating sketch dimension with selecting point of datum CSYS # k: w! w+ q/ t2 `
5 w0 v: P0 s) ?5 v5 Y% m2229364
' |2 Y+ D$ f% _. S0 d z) O# `# B/ ]+ {/ g2 \
The measure result disappears by view align (F8)
) ]- T& R' V1 z2 A" |6 y ' @ }5 S( e) F8 U0 j. g: L
2229411
6 }& R, o0 A3 N7 w
* M, x) Y& B, o: Q( sAn internal error occurs when Shop Doc in Batch Process is run by Foreground( E% i/ I8 U2 I9 Y* ?# `- n6 T: f
' i1 e' H. F+ n3 V( d6 S2229431
9 b0 w# t3 H* h9 b" X& Y" [
, \2 E# |& ]* ZUnsupported 2byte 3D Laminate Mesh collector name is defined automatically, T" h5 l- ]5 s/ l& @0 C. `
/ L$ E) y% f, F: G7 s9 K22294327 Q; x, p& j# d
! c, ]! n6 q! K7 |+ p+ k: c- X, FUnsupported 2byte Laminate Solid Physical Property Name is defined automatically
2 G& x3 X& z0 e- u
# N- T3 [( |! `* ~2229436
1 }& u5 L8 G$ E L+ y' e1 N: j 0 V9 S7 j) V: m" C, }5 }
Internal sketch of the dimple is not selected # m- b9 x/ I" n1 P7 L" {) D. ?
9 r# m7 |) d& q
2229771
4 p( O5 w! f$ ?# J* q8 ~
6 k+ j9 U4 _# n T4 T! ^8 oA double byte character displays on the "name" of BC dialog. And error occurs' i5 j4 T( y- J) v
1 n9 b% u' ?* b, N2229776
- o( ~- P& Q* s6 s7 ^( s
, a. e- U' g- o0 D$ p% d1 OPerformance is bad when we select objects by the rectangular selection in "link"
/ z% k+ B& z6 w6 u0 m U2 I& z) S8 u2 E8 u! M+ H
2229857
3 Z2 ?7 z4 z) z+ z8 r
. B8 o8 h( _ M+ K) CMeasure distance value is not display while on assembly sequence play
& y6 M0 ~1 ?. N+ ^) t1 S9 } . m; m+ u& A0 d
22304173 X" P- D8 `& ^/ u$ Q8 R" ]
, ~" B. P) H3 y
ISZ_VUP : Loading of UGALTREP referred to from UGPART is impossible
, J R& ]8 a7 p
( q0 J6 J+ k, F1 }; {7 K22305912 Q+ d3 l& s: D4 T7 }
& V* c7 z) y5 `: m3 [iTest: Association of drafting dimension and symbol has been lost
L2 v/ H, L3 c2 E & `' |. y! A! }7 f0 \& Z+ d& R& J
2230700
' }9 M. z8 Q s4 _ 9 Y) e' K Q1 @ E+ E
The problem by which value is 1000 times when multiplied by Function Multi Mat
7 x' P- w/ f8 y+ w
$ L1 S: W' Z3 {# E) e2231577
9 N+ ~& \/ g/ e8 n) I2 j9 v / I% Q, [5 n9 v, _
ISZ_VUP: Unable to load file as Invalid file name
, n, m( X$ C4 K( K: k% s! a
. ~$ l- M1 _0 M# g4 A22315918 w- l$ r/ ]* R! R6 k
7 X8 z" f2 I& H* b# _; C/ ~
ISZ_VUP:SIM cannot be created from a template on RevJ
( O8 {4 g8 S6 h: e
4 h! K6 H3 b/ L6 a/ I2804381
% t5 D% u/ a I) p: U0 d / I* o1 P" R7 C$ U# z4 T) ^/ k2 `
Title block disappears after Show Only in Assy Navigator is done in modeling 3 R2 q5 Y& [( x
+ Q) {+ \5 u7 ]0 i, u# V2 N3051259- w' j5 |5 ^$ s: ^5 n
0 t- p4 N/ v" _/ }
Parse error: PCALL cmd not implemented in parser DLL
/ l2 |% u1 ~5 w2 f; `6 x ! B, V# {4 R* [9 t: i6 J3 F, \& I. k
5875663
/ K- ~. L. `! I! d, D( ` ; ^. x1 J' }" W+ F7 \6 ?
Add Existing Component with Preview OFF does not display Cylindrical CenterLine ; |4 O" U1 R2 u" j( ]1 T) s
) ]' {4 i1 w* o ]0 W' h4 t6035215
) w$ |+ Z& Y9 q* N/ N* G+ O
/ @6 ~) N! F, X3 fMissing information for UF_MODL_ask_feat_direction
# c5 g, Q1 B: h5 |+ c v" L7 r" ?# q2 Z g* ]" I
61631436 U `3 Y% T y
! V1 m# p4 ~- a5 o2 z5 C% T
When re-associate PMI note, it rotated 90 degrees , j$ J) ^( Q8 ^8 a
# P. b; \& F8 u1 X3 x6450532
& @& U5 t6 r; J2 U
$ z( C+ ?( W* S% I; g# xAPI to export Holder to library
" U5 [: T0 d+ B9 d! d" g - |. t- Y8 A d
6506002& O) P" Z, m7 M0 W n' H
. L0 q" J$ ^' {( P$ P! {' n: j
Approach_Departure not using Common Clearance value . w5 C c+ Y* r( Q0 d
- J4 h+ _% y: |
6562745
8 c; _ y# X$ A. I, j/ \# c$ p2 `' w
5 S& v. `$ g L( M9 ]' _9 N; ~* a[OK] or [Apply] is not selected with [CMB] in Spline Path dialog
- }8 n, N0 V, [2 a# b/ h
! [( M: z `3 r" g6562807
0 t; T' g6 H- q& S% a . l. c7 G# b7 O' }8 }+ I
Edit Stock Offset option cause Internal Error
9 ~& X& E: j# R7 k7 F- @
, d t$ S, u, B/ O8 N6572702
' P: H" B7 i3 Z# ` 3 d* G4 j* Z ^
When Moving a component, the Snap parameters are not retained as expected
% ?4 Y9 u. l! \* ] " a2 B+ d7 {9 v
6593479
# F8 @8 Y5 p: x4 c' \ ( u! y8 B. H# L4 ? v" L/ `% N6 J
Would like ability to stop process when previewing a Streamline path
0 v# B" M1 ?! ^8 g, m % k$ t4 g. X( M- x
6600226
- M& Z/ I: W4 T x2 Y 4 [ U" Q/ e! @$ L
Synchronize Links does include CSYS elements : F% {. F( c# c7 L8 v
+ U# G/ S2 }8 w9 c
6615149
) w y0 @6 d$ y/ r: x
5 F8 H2 d* E- ~Linked body not updating from swapping component in part family spreadsheet * X# {2 q/ |* p
e9 d# C/ ?$ t* v+ X3 T6627773, f7 v I0 E O7 N7 |* v
$ a( D6 b$ y9 w9 t4 p1 S- r+ Z: eSurface Contour Transfer Rapid Common Clearance Plane set to Between Regions
1 C9 b8 Z$ M+ T- ^4 M+ J# d1 X
1 B( Z+ U5 S5 ?6633591$ z7 i, t4 i S& ~: |( R, s
: J( v" ]& Q! S9 ~" t6 `
Pre-defined views move when defined in the template as "Automatic Rectangle
* _: z! ^' U2 U' ]2 D& q; a4 ^6 w % E* r8 E/ d8 p( n! q8 `1 P8 x
6653681& E, y1 s& l0 t5 [( F7 V+ s
6 {9 ]% |8 R8 O8 i
4th axis (C) is adding 180 to position after tool chg even when set back to zero
9 t0 b8 W* ^% q( A 9 v w4 {! R$ m
6656632& a& ^6 k3 H6 p* @" `' p1 T7 Q
' r k# n; {: w7 K' b: tZlevel Profile ingores check body if cut between level is on- y5 e; U6 g* D% g+ q7 s
" S/ o' k( L0 G* D! [2 X% ?
6661839* F4 @2 D+ b8 R, Y$ t0 p7 D
# N+ n8 U% b3 X& P
WAVE target part updates when Delay Interpart _ Delay Geometry.. is set
" e- g& Z6 n1 \6 m
( }" V$ O6 n7 Y3 i6 y9 v2 G% u/ {6704098. L- e1 ?8 J+ O( e
* z2 I: B$ `- D. [7 i+ ~Incorrect Dimension value when placed between centerlines in detailed view
0 t$ X3 S/ U3 t# p ( N! ]7 A& S- R& M ~! k- l
6713949# i+ [, `$ g% ?6 l
$ w0 k7 M/ g2 k8 ] A8 Z1 Y
When creating new part Information window doesnt appear after modifying shape! v& `/ | v2 c. B2 J$ b
! n5 Y8 z8 S( ?! I* t& m( ~; `6717050
& o" Z0 S' Y" z) W % j. W/ y+ W. h8 B) C/ D0 z: `
Interpart linked port is not created when Drag and drop from Reuse library * p% K% Y7 k3 w! j1 T/ i+ m; E
! \" P) ?9 ?3 U- O4 \
6726817
$ F6 K G, l9 J) Q2 l
6 P! \4 B$ P+ ?0 D2 U% g7 rInterpolate tool axis option not working. Defined vectors not maintained ! E- e8 S/ v# Q
) C( U2 F% G* X5 c& `( }
67282166 B# h3 S0 B3 ?- L
6 ~5 Y5 p# u: M3 {, ?! _" c0 r
Initial Approach move is omitted in Flow Cut operation 0 O7 b/ C7 b( C/ G) P
& k. R/ K$ v& z9 C
6740811
& A) @7 K6 a* e3 C2 }) v
1 i6 {( o; ^ w* V2 OER: determining attribute associativity from drafting note string
7 W: x# _/ ~( t! a# S) ^2 | 3 h# [0 n, u! R8 M
6744342
* c/ p1 E% Y/ F 5 k1 Q. L, u! N( k+ |! o2 t% x7 W
Got license error : ~0 |7 m6 |8 Z' p9 k h
: k$ o* @8 f- x, h J6755376
! }* O( C) }( k$ B! @, x2 I: t2 Z3 h4 Q3 m # y8 y0 y6 N$ ]1 ?- d& m$ A, H
TC Items without NX datasets causes NX to show assembly out-of-date
+ f6 y7 ^1 N% |/ I$ Q! X
5 v2 P. g- p8 A/ @& b67570693 F1 G2 H% b8 B3 D0 G, U
6 _% d* u" r+ O# d( cSystem created MATERIAL attribute is not read in drawing templates
( U+ U q" I. B& i, U6 s) a# X. D ; f* H+ I% r8 p3 `1 ]" v
6760589
7 w6 f. V& k8 [# @$ W
: Y' [ I' n$ b! J' E; HHole creation fails if body is hidden but not with layer is off
( c5 Y( f/ C( \, `6 m 3 k1 f6 U: U3 ~0 L3 U# B7 G
6765647( g. R9 Q; a# P& W8 ~- D7 a0 r
9 U: t6 T- S# t5 s2 I# e' l3 m
Z-Level gouges Check Stock when Smoothing and Cut Between Levels is enabled, ]) f- L/ p, d ]% s
, \( B/ h g6 L" z5 x6 }% r6781404' F) A' a; Q! I q5 v! S [0 v
+ O4 z6 d: Z% M; B0 U. _. n
NX Created Exploded Views not positioned correctly in TcVis
: W6 Z: i+ `& r! [; D ; y; S1 @% h9 Y1 `1 x4 ]
67870921 p9 j- w9 P% \$ K4 @
7 I; K. E2 U2 B6 S5 k/ u1 `9 i
Step file fails to open error number: 1
" b+ f4 g+ e6 H+ h: j" X
5 M% _+ J; V# I/ w4 p8 b! g1 _6788080! U1 G. Q0 f, m0 ^4 m' k9 q
7 b X: s; Z7 W: J
Projected Curve (Along Face Normal) has continuous result until edited
- b/ u- w+ D2 l5 n" Z" A9 B5 s
2 H r6 \9 z+ E6 F N( l+ f6799680
" R z5 k# f( |4 N. C- A & k: [$ A6 J$ ^! Y
On-Machine-Probing module, incorrect or unsigned angle ouput when posted
4 _+ `! r( o. o+ {7 q ) _; z2 c1 f6 Y7 E2 Y/ [9 t
6806366
' V" K U' l7 Q) d# N
: [. d$ b2 f8 XSection Lables text string changes when section view is moved in NX 8
: m& m- M0 ~1 ^" s; v
* Z" ` I5 i+ V) Y: v9 n+ T6806448* T7 W- C; W, W% j: a. E5 `. x) e! H* P
* g8 x, R$ {5 X9 c2 Q; R6 b5 \
GetParameter(string) method for Start_End UDEs that are on Machine Control ops G+ I- k9 D( }/ ?: |3 Y
1 E3 u9 z% a A }6808397' ^4 C& u. H* }% m5 K
9 X2 [) ?4 Z, X+ k3 X
Custom Symbol Library Installation Guide missing pre-requisited for TCIN install . ~ _6 ]4 z( `# C4 I5 G. p
) u9 n$ V7 B) a6 F. i6 R6810816+ W/ r/ R `3 H( d
, J) i! z0 I0 ^& i" z) s. B
Trying to swarf cone with contour profile and the system locks up & K7 c3 c7 [( ^* \/ X& P) y7 U ^, h
! x% Z. H- B. b# p7 P
68120988 q1 q$ ]$ ?9 B3 _. M- k; O+ |
: F8 C3 w6 A; g: z. i/ SVASC-problem with surface area drive operation, q: E1 i' E4 e$ C+ _0 C3 }
( c( K. ~9 ~; B N/ a0 m6819084
4 m; g+ A3 ~" ^& Y$ J, \$ m& N
6 O$ t: }4 R: {' z( I$ LBIW LOCATOR when moving a Pin with only 1 direction toggle 2nd is added back
7 J5 @6 N6 g: ^* _! a: o2 I
) V8 v0 o: L/ @, ~" x5 T. e) u7 j6828502
% S% S- _- }; i
/ U9 ]" h& `5 `1 j8 w; KError messages not displayed when using UF_UI_PARAM_edit_object function 6 j, l( j! l9 o h
* C) _. E- _: o3 n; n
6829744
( ^* P2 X* ~5 g' G
, ?3 I1 |& i; c9 k& }' P8 TThe CG coordinates do not appear to be based on the selected CSYS 5 A2 Z8 U, M* d6 y$ B
) O9 [1 P; N, ~3 j
68413242 f* S6 R* T. K, D% [9 y5 K i" L4 [
7 Q+ H: I- j( b9 U. W1 b$ C
Sketch radial dimensions move when I zoom out
3 k0 _" Y# @' g3 l; q- a6 M 2 |1 A( r% d* Y" V% z3 e1 [4 j* Y
6843255
# G9 d2 n7 U5 a0 f& i - X& e9 Y5 m& A8 h
NX routing does not remember last selection in "Bend Radius table"
; D, ]% i. _ M; L c6 C2 \
" X5 y; l8 y, S6850499
& ^' k& y: K9 |4 A$ \4 c
8 {4 L) I" }8 R+ nEditing tool number in Lib tool causes operation to need to be regenerated
2 m' m: t5 d" |% S/ Q2 D 4 Z8 O' n$ x/ g3 M
68550443 }1 q; d) Q2 p3 s. D- c" J% t: H
) |& T5 z& Y, q9 i1 U
No NXOpen Java Wrapper for UF_WELD_ask_connected_parts 1 `7 T1 _1 B( ^. o5 N/ h
: c7 p$ q5 m5 a- c7 r
6864143) N; l- Y; Q' `6 i: Q, x- T
1 W# z1 M; ?, D9 K) f
Teamcenter Web flyout not looking at correct address $ J3 h$ [" L' C6 Y7 E# y$ ~. C
0 h8 J0 c: V/ _4 `
68653833 d+ D/ D; f0 Q8 s1 g7 d K8 ^- C
! c8 i- V z5 ?7 {8 iFile->Interoperate bookmark > wrong server URL when UGII_UGMGR_WEB_SERVER set ! I7 N1 m% R' m% {+ _: q& L1 O1 |
; X$ z% r E( d9 t$ e# l& ?
6867832& x! Q$ P4 f0 l, ], _4 I7 m
7 S4 l# p- A* g2 N1 S0 d
CAVITY MILL- operation cuts only part of specified cut area regenerated NX 8.5
" C+ |7 B/ m7 |4 A P
. H& |9 o: R5 e0 U+ A6877437
) d( |; }' {3 K }5 r
* ?7 X( V9 r( ]2 H* ~$ E; J7 lNo bend table to select from the preference dialog, no automatic bend created . `& g! p( p- G {# W
* E! K+ L* k% g7 S) C" V( G6886055
* M5 U3 g* n. Q4 W. x; l ! N' c" F _ `
Excessive time to WAVE link a body or point in this assembly
# B' x- n& L$ I- u5 o / c3 z2 y2 {7 A$ [
6886681# H8 a: t- t; J# ^- l
+ S m& m/ ]! h6 c% Y3 }Check Mate Report Conneciton Validity shows too many ports # s2 m9 m/ ]' A# A
6 p5 H' Z7 X5 z4 W68869406 X8 Q$ g- M# r5 E6 X
0 L. {6 i8 w* lMOM_list_user_defined_events fails to create list of UDE's list * D& J" F: T# y
9 Q( r. z* l$ Z/ h' { E
6889228; Y3 ^ k8 z4 R7 j/ N6 H- e" n# `
& b1 j4 j0 J; B* C3 F0 G# yProbing operation can be overwritten when operation is locked $ J' L: J( G- W- P7 s( V# P3 q+ A
% e( h" ? r; |/ G6 o% b$ k# ^7 ~( }
6891696: `' `( Y) Z: ~. D2 z: F
3 Y1 V1 V, w! M6 k5 K2 n
Mechanical Router cannot load Bend Radius Table
H7 r- p3 ?, _7 R ! x% P$ X" M; b7 P$ t J
6891901
6 i4 Q0 e O" {
4 }" G1 e0 M% j- z, `After creating text and placing it, text does not re-highlight in Note dialog 0 [; n r2 \6 |6 v# x9 c: D3 l8 V
5 K L+ y9 g4 w- ?. g& O6893323# w6 E" o! @# V6 D, t7 R; T
8 B3 y1 p( \7 r; F* E2 ^Can't change color of assembly cut face + C9 f5 {! k7 k8 w3 g+ i
% M& X2 g1 ^" E- y68940069 O* p/ g+ M; l: I0 A
: s. n0 {3 }, r8 ]
Adding PTS Template Part causes an update of all structural comps 9 q1 R3 A( z) O1 y
$ ]# C3 e, w8 g6894568
4 R. d1 u# |$ E& p5 \ . Y- u7 d( F4 b3 B1 R& W
NX Freezes adding an attribute that references expression with units lbf_in^2
& X% D' e, I: W" C, j& u
7 x) D) h# M* U# ]& J6895012$ y8 y! H3 X& c7 p" o7 A
( e7 @3 F7 S6 W+ v6 a) q, w* S0 F
Unable to delete Expressions that were once referenced by Attributes
/ A! U& b& y* r- i
4 }4 j! S0 K$ f/ H+ t2 Y6896623
8 Z1 ^. _9 [% I/ C; [
. F' u: W) R3 m& N* Z2 k% V! ZUnable to fetch faces created by assembly cut in NXOpen
1 }# z: M! V% M7 e 6 I; z0 B: H8 N8 m' ?- q( @% |
6896656
& j4 u i0 ~* g3 l
% l* i8 k% e3 W9 H1 r, }2 f6 X+ kRouting customer defaults are set as default for all applications "not good"
: B, u5 H: @- o: z/ W7 Z 4 P( A d5 F/ {' m3 z# x" I
6896744- C" b$ v' D: U. s" d' p
' m# ^- y1 Z3 m7 gSheet metal material not supplying correct neutral factor value 6 N$ Z! L: u' }
9 Z# z* n# U3 p! |. S
6897410
/ O" ~4 K+ m- b, V4 A* E+ n0 r: {4 [ * |5 u, [1 N8 H# h# P, m
Routing Electrical - Internal Error, memory access violation
+ K# |, K; ]$ h; V8 E- b
/ S, u& z9 J+ e, y0 b6897505
) ]/ H/ D. e% W* U ; V. B' ? X. t$ i
Unable to import stp due to runtime error with the translator ) N/ ?* f3 I+ G$ S) t! J
2 f" n+ W) f/ }6898636; n! f# e6 f' a" N. I8 V
$ S$ P4 ^7 F( Z) eTitleblock does not get exported to PDF after Hide All and Show All
, B% Z: ]# M* H1 j: g7 P8 q ; O8 ~. A0 Z' p! x K! t. P
6900608! K' w P$ C1 Q% ~/ g/ z. v, n* k {
9 U0 w* j! R5 v( ~8 n9 `6 \
Getting same error as PR #6611229 - M' F4 P- }- M$ X3 \6 W
' n! |+ P- q- b
6901302
0 b3 B0 W3 J5 g' \! a- ]
3 ?) \; w' e# z: M4 Z5 [Attribute units invalid error opening an assembly
& g3 }! x' u6 O 5 O, d7 f/ y+ I- e' z
6901354, s5 x9 R- d4 L7 T+ E& s, {
4 ~ y* D+ [: q+ G: a) N
Not getting a retract on 1 of 4 boundaries if stock = zero
1 \# ?# z* T. F8 M+ c $ g1 f9 e2 E5 O# s4 T; A
69029201 C7 }" M$ ]3 O% V
" m$ l+ z0 u5 z# G6 f
Creating custom commands 9 n/ e/ A# k5 V2 U$ D
6 C/ [) ^$ C9 c4 ^3 a1 G6903049+ t% n# W1 u& ^' l+ R
, |) |5 n* F, I4 \ p4GD: NX Load Option Structure Only Causes Subordinates To Display Below ReUse DE' V# V( j% {2 q
& E3 i n8 K# u8 T" e3 \# m3 f
6904912
, K" y2 h7 G8 v6 R( u# F 9 o9 m# n" \8 N% f6 {- d ?; l+ ]
Visualization on Angle from PMI Ordinate Incorrect
! {! q/ m3 x: V1 I2 E( n' B/ W 2 J' J4 o5 T u0 k# D+ ^5 c
6905239% k3 s2 C& r# X# M+ H' M# D
# i# y5 |. r! @" b( Q! b3 ~7 }Filename must be unique within a data manager is raised opening new Revision
& S+ V& z; [1 {3 [) |' D4 ] % C/ p# n# G5 M( o1 [0 v4 h4 _1 |
6906005+ ^# T- h. }" v% g- u( y
* E8 u$ v+ e; q" z4 l
Cannot use PropertyPage on UIStyler dialog with C++ , y# ]: ]: m5 n2 }
, o9 c7 K: x( }/ v" a3 J6906421
. _ z6 t9 J6 m# M+ p7 p
, ^% }: e0 P+ X7 d$ SUnable to open assy
+ { { M c# S' x- M3 V ( b! z" k/ s# y
6907815
+ ~$ S' |' a# L 4 w9 Z4 y4 s l2 ^- O* F3 v) g
Assy's fail to open in NX 8.5.2 that open in NX 8.0.3m5
1 c& n- R- _3 E- C$ k; J, w
+ } j# [$ |+ U8 S( K8 U3 n6907831( ^% Q# d) b+ M: |- y" A1 e
& a! ~7 }0 }- h0 bToo many engage retracts. % b: C* f1 _) ? @( C' B- L& W
`9 O' n% ~4 l8 R' O1 N, L1 y
6908062
2 j1 z7 W) O/ N' d/ a 5 B& k) m) _7 I# S5 \$ M2 {
_inst# translation issue is happening in NX 8.0.3 & NX 8.5 - PR 6611229
5 f: |1 R; [+ x
8 m* u7 q j$ \' k0 p6909389
3 x+ t0 t' ~! y* W8 S' h & I1 W, C B- U1 T$ u* |+ c
PRODUCTION WAVE 2: SDF Feature Update Errors 2 U% |" I& t( T0 u" ~
/ t, j8 u( M' S- D. e! u6909390
) @6 M9 P7 w* h& g/ L
9 l3 T% Y- C: V+ Q9 DPRODUCTION WAVE 2: SDF Feature Update Errors - Trim Body feature fails update 0 S3 f3 j( J- P* |/ ]+ t# v7 E
$ U! S6 {. ^( x4 F: c
6910090
! E) J% q* C) z' t & d1 K7 W0 G* e) p1 Z1 j
Universal File import for SST does not import mat orientations correctly
/ E, w" K2 K/ v" L
0 w3 B+ v8 O6 J2 J" T6910694- Y$ l7 D' h& z$ n# d
- C4 r! ^) X8 X* }' Z8 fTransform path does not dynamically update paths % x9 p+ U6 V2 Q& ?
0 r& `* N( r0 A
6911835
7 M% I# N: M+ \* ^+ y1 W( C3 ^+ W 0 g% [7 q! z+ Z! y5 F& h& I0 N
Attributes to support penetration management breaks stock as component 6 }7 U4 B7 i5 M6 A
- s* X3 k- m4 ~/ \6911843( U% e' N$ N6 {$ |" Y
. u# V" ?3 l) ^- H5 m+ B+ z7 mTCID getting replaced with rts# or rto# when loading into NX 5 g! i0 |8 L( x9 B
9 s c2 b! m! Z
6912880
! x0 p* q% f2 M
+ p/ B" W# _% K! G( v, y+ ZUDF not building correctly on use copy_paste "unable to paste" ( t. q, V% ?2 I3 R# \7 U
! t# x* g; F( D6 E
6913393
. F* C" I9 k8 J4 {* d " M( e* e9 V7 M$ G$ k7 |
Problems with GRIP EDAs &NATTR and &ATTALL
5 Q0 w/ D; S: u- ] r
6 }1 X( r1 J2 @; {69147271 g8 B) I0 M2 ~" S d$ }1 ]5 ^
% O. E" F( m3 m( M0 t
Electrode Checking is failing & l7 X" G1 C: e8 W$ }7 X0 W9 c
$ R8 C! s3 ?+ s; q8 m6915556) @ S% ?8 p8 z+ Q+ z# |% E
: X7 l; W$ D( e E; E
Transform path - slow performance loading dialog and making changes
9 x7 Y+ |1 k* |
4 E& s3 @- F0 r& W6916155% D) ^' m: u3 K0 n, I) j( x2 |) l
9 v" E8 c4 J/ a- ?6 a) n. V! w2 p
NX Routing attributes not working as they did previously 9 [8 b, {; {; b: }
/ c: _5 M5 H7 U7 A3 i6916490
0 |/ d, F9 Q" T: D1 Q. W ' b0 I( p* X1 t: ^% A! N. ^; R
UF_MODL_ask_minimum_dist provides wrong result
( k6 y) l* l2 Y/ o- w/ A3 m, \7 K + e& H8 P9 T4 c7 |0 m. L
6917852; C1 A7 m0 C( g7 r
( @% f; O* w$ b- g. O& _& z
PMI Associated Objects button disabled on second Custom Symbol instance
, }6 p$ p( A) W! `& R) N . B0 H9 `3 y4 E1 k9 Q
6917970! q+ g+ g) S* z- k1 u: n* C
5 |! D3 o# {, K1 M: c
Attribute units are invalid (not known in this part- error when opening assembly
: A: B; v9 L0 M7 E2 C2 j
4 |2 b# }1 L: @' v( ]1 E: @/ N6917986
4 {$ s9 h1 w1 @+ a 4 m: k- i$ }6 W8 H! ] i* s
Attribute units are invalid to open assy file
0 \$ @4 E1 W0 w
: C1 Y) [1 G3 _% {5 Y9 C69183673 F; ]: V3 Z# `2 Y K/ W: a
8 r; a5 N2 Q3 S" C, v0 S; d% J# z) SNX: Save operation fails in the modeling application when saving pattern data
# K% M1 t5 r, E: R! S7 k% d5 Y7 t/ a 7 F9 j7 D) G# ^) q2 E
6919486
0 ^" A1 h! d; f5 |
/ \% T: ]$ v* S! nNX hangup on updating features - H; B* T2 g; F, p& R6 R5 _
# j: W. F% u# I# \: W+ F- t. Z1 y6920074
3 k ?1 O% K, U3 J4 w% K - ~' a5 P8 u6 u
Weld Assistant: Patch F took longer to run CFF than Production (QC3540)
* [4 E7 h/ a4 T. \6 P 7 t( b5 Q/ W* L. L
6920147
) f1 b) o: l- z$ o" ?: Y
- i" D: o8 S* g) a" c2 YWeld Issue - Connect Face Finder not finding surfaces (QC3539) 6 A/ }2 K* t" W. c' U
& R$ ]/ r# [7 E* j" ]& w4 k2 K W
6920704% S7 W' f' o8 s$ D+ z
, E, D% X& }! P3 R- b8 r, L m
Misleading error message on failed save $ O2 ` V O. j' p- [
8 L4 {9 c$ R: g, o9 z! W& ^
6920758) f$ Z: j2 A7 W; t& O* L6 Z
7 z; D* m/ h, r
DUPLICATE OF 6860427 - Bad Law Extension result from Intersection Curve selection
* g5 t, D9 v% Y9 q8 a. {1 N 4 i7 ?/ }5 J# H9 @( P5 [9 q* K, I
6920760* ~1 g D' y7 G$ G7 B! {: n: C5 P9 }
: h( }" l+ j$ f' |/ N5 ~# k
DUPLICATE OF 6875511 - Intersection curve flips after inputs move
* V1 h: A$ T3 ^
H, x1 b9 S6 P7 Q6921233' ]3 F1 S: }% f# G
6 F5 G% q2 K* x" `4 gWelds show fixed in Part Navigator, but CFF shows errors (QC 3541)
$ v. ~' F' H) U4 J3 u; X; [
" y) V% f$ c) @/ f6921640# c! d# j: m- e# h# Z
) ?& _& c( y( V- d. _0 {( vCannot find the welded components of a WeldJoint using NXOpen
. y2 u% h4 N0 B- c
* ?0 ?. j( T" u- x) s0 _6921846
9 d$ _$ j! S+ E& V& J
( H/ g2 Q' g& iInternal errors on editing pre-NX 8.5 detail view
+ q: k% |9 f0 O3 { . ~8 F* ~' Y3 Z5 e0 s9 \ j
6921928. F) _: T4 f ?( Q% }
6 l: V! u9 Y) q$ G+ s: w
Post Builder mom_coolant_mode does not get set with Coolant ON UDE option 'ON'
+ J7 z' n: w' ]" S: j
' v$ n2 o F: P+ @$ e6 T+ _6922089 j. n8 p# `3 d: K
1 E1 N1 T1 a: N5 d4 n6 X
Create Line, Start Option POINT, End Option NORMAL
' J$ G- O& A+ Y+ w! m
$ {* Y3 u, C6 u* l; T1 I' x& ~3 r2 G& G6922187
( s$ _' R/ ^2 d: K
. o7 B; d( J- mDistance tolerance is incorrect when using dxf translator $ Y* t' t, K! r! G+ @4 I+ x. ]" o
, ?" N/ [6 |& H& O2 Z) j6 X6922242
9 O& h0 J. F+ _& D0 y9 m4 } 1 J/ _+ j1 J% F0 s/ z+ l3 o. o5 k
Clone import fails with an unexpected error
7 [; o2 b, H" d % f/ o" b' B$ ^% U+ J+ e7 }+ o
6923268
* \. a/ |7 d# f: C
5 ?5 ?! f$ K1 n# Y0 X. vIssue deleting_assigning attributes on occurrence objects ; ]. s5 W4 q. S( [
( H1 O7 a) P9 m: b* S# ^ g) ]" P
69233121 m3 b7 ^8 H- d: J( J
1 K) A+ P* k. x& `0 K
Part Navigator Does Not Maintain Attribute Names With Underscores
$ t% z4 i" d. I8 {
8 o8 L3 w, f! h6923336: w7 J% e$ `; `$ S/ U, F
) q7 \+ ]$ ^- q1 l Q9 BInstalling custom symbol with utility wizard TC10
% G' H5 Y& s/ @7 ?$ \, D 5 Z; U$ J7 p. V1 R- ~" ?' r; l$ P1 B
6923504
4 \( `4 |* e) X4 F
; t' q% @% X8 l! SHole Making: Between holes transfer not working
! e) y: w/ g. C, N# v1 c - ]8 p3 R& v. P) g& _) x4 _) S D& S. Y
6923987
6 F: {- E. d3 y1 E1 @3 }9 g$ F
" P0 F' c8 m0 j& |Part does not load in NX 8.5.2
$ b' W9 S; H% [- }( s( s( Z
5 [0 J8 {9 E2 b `# t8 f$ i6924197
: x3 g# P c8 Z
: \( h* E7 S! e& @ M6 sSOL601,106: RCONSM is written incorrectly in a Inch unit sim file
3 O/ c9 B2 m6 \ 4 A8 F" ]8 o6 f0 u0 H% _
69245650 S$ W* D/ Y, l! T" X
- {' J8 U& l& |( @
Layer mapping Rules for Importing DWG files
3 ^( f1 i0 f0 |
! I4 w# @& g5 a# @6924642
( \: n+ x6 K+ c/ ~8 ?5 z
) } F7 m% H# h0 \$ U: Y[v1] Deleting a component, a piece wiring is "deleted or hidden" and connection & ^& ?) w# |+ y( J6 A5 S. t
3 j/ `5 ?. p2 Q; d/ i- @
6924672( q/ @0 O g& m
( d7 ?' T5 C( S4 j4 y* {
[V1] moving a RCP that connects two paths one path doesn't move & lose is ending
& `5 D0 k) Q! k& x2 Z ; R( ^0 ]- }) r
6924796
3 P" l! a8 o- \. f: p4 @5 {5 x
$ u1 |" c1 l+ \Attributes of an intersected body are overwritten when played back
1 X" [) R6 e6 f7 U% |0 B3 j1 h7 B 2 [. N( y$ u; H
6925101
: F3 x! y& f9 H/ H
% K% J3 O, M4 F. f- @Getting 'Error occurred during display of part...' when switching from one part
7 ~& N, a9 \. S$ P* z7 @. n( D
; c2 O9 E3 |/ [* q+ W1 w6925321
! `% z1 i' Q5 A & m% x6 z+ ~; f4 E# O
Column removed from lifter database spreadsheet - type no longer recognized / u9 C. n+ r5 [" a
" i% G5 d$ z, k$ X) r) i9 S69253908 q! X* c4 b& D2 [" N, [" g. l" O
$ e2 e& j& ~8 U4 @Title block disappears from Sheet and cannot be displayed ) n6 j1 A! [8 L6 i. t
! n. q9 h. N: I0 r* y4 X! ?3 E69253945 r5 \* L$ }6 L2 X
- Z$ Q) v. x/ e" u u: o0 ?1 cDocumentation is missing for UGII_UPDATE_FAIL_OPTION
: G5 j, M0 p- G/ I+ {& G6 U
& e2 K8 o) R9 y- O; J, z6925401
$ K0 S4 f# H* U5 X) w # b: L) B* H9 v: w0 z
Endless loop when selecting multiple moldwizard standard parts in ANT * ~3 [, @, C3 f3 t$ z* @1 A! ~
" z" Z/ F$ a& y! d O9 Q( w" I4 H
69261999 T W6 I$ S9 G* S
3 L9 j3 O+ h' o/ k* a1 E' F' uSevere error encountered when running Check-Mate "Spell Check on Part Attributes
' i' ]% c6 r9 m. O
! _. I' Q! K; u6926552
; i5 ^2 b3 K: k& K
5 T( S$ {$ Z, j" R; q" [Importing part with CAM objects results in Invalid Record Number Error
; k( y2 A4 _& _ E, G2 X, s: A 3 J) {: x- |" z- w* B3 H; i
6926584
& R5 a, B; I: h5 A. I/ |* o
8 l5 M% ~% _8 `Object depends on itself error and part will not open
: G' q; D5 |' O: ] % P) M% y$ b! x
6926741
8 e6 R) L8 C# Q
6 Y: b( }- A# `& zNXOpen: Unable to obtain the components used to build a Weld Joint feature
8 `5 J5 H* J0 k0 ~* i" n- z 9 ]' u7 A/ G- @8 z
6926747, M* L" Y! Z3 _$ y
$ ]5 Z' w' z5 _* V0 Q: ]) S. I7 U& iCan no longer get the object w_the attribute from a note's associative text & n- t- K7 X, l z. t
: u6 c! v/ g1 Y0 z! y5 }( V$ I
6927130
# J& [; a7 r Y: r& ]1 T; ]4 ` " i) Q; |5 b# }% V$ \. ~0 n
NX: UDF creation fails in NX 8.5, worked in NX 7.5
9 D5 G1 }4 \: S / S6 e! K( t2 C
6927279
5 g+ f# q& p2 {( ^( d* V- B . @) v2 L2 D$ F5 L* V9 W
Unable to force C axis rotation when machining pockets around a circular pattern* a3 c6 \! V+ g- f
! a1 e" V! @. a' q) @6 t
6927639
% W8 f5 ?& D8 |# v0 ?4 C 6 b9 K* x* d9 b' b* h; G7 ]
Show Connected Lines Incorrect in Structure Manager Across Different Assemblies
( g* |" w e( e
- i( Q1 z' @- V8 \& y3 s5 H! ?6 L6928996/ S5 a) Z+ B! l) |6 u" J
5 o$ ~! d2 _6 i) P, N" RNX: Mirror feature difference in NX 8.5 and NX 7.5
, E/ v& ^2 A6 e' X7 Q7 r
- A7 M6 G1 i3 }3 @6929212' u$ ~0 k/ U* v0 F9 n% O
) @' Z! c/ d5 I& }
Created welds do not show up at the right places
( U. |' v- G$ M }1 ~ ! W* ?6 j0 _$ B- q
6929941
- G) U3 k* y0 ?; a 2 V& T: O5 ~8 c# J& W" |4 ?
Welds to not get revised properly 5 x5 |4 K: k* }2 H: h# { ~( _5 o& P
- W& `" E: e# |6930147
$ ~: w# x$ F: \8 ]) K' @ " w/ }) x& K' x% l
2Dexchange produces undesirable results
' S) m; E! B- J; G& n2 k; M
9 ~: u$ N2 R( T3 m X% g! Q6930260
5 X/ r4 C6 l. y4 I1 S4 `$ a& ]
' O* ~0 }- d" h: xUser is unable to get desired results in global shaping tool ( k9 U+ K! K, [, g, {8 r
3 Z$ h4 @1 ]7 a" O6930609* ~/ Y' O* C4 }& a: c N; ?( ]
/ e) @+ n* h/ T+ D/ Y6 h
Line width changes during creation of a second dart
) R$ ]/ N8 \; \$ f; D + D* C' v9 L3 ~. T. B0 Y; ?- P
6930920& [, B- F |$ U- H: o U
$ a2 d( i! X: r% |, F( u! c5 N
Tool and holder curves created on layer 254 after generating operation
/ @2 q% Z2 J: `& ~5 F
) u. z! G7 W& Y x9 w. B6930927$ l$ i) E8 i* `6 c a0 }
$ b- H- Q4 s r& U. p. ]3 ?
%ui_comp_double value getting converted from mm to inches
4 S+ \4 V0 _9 z ) C4 L0 O: c. n& x* Y- [
6931678
3 |3 [7 j. N& C
1 S$ \5 F/ c1 |9 j/ MOutput group is corrupt in fem file $ e5 v( u) T. v0 b) B2 @8 |
+ f% Z$ }* ~8 V1 n
6931905
3 Z8 q: |7 ?4 N" @6 Y ' @* j; I6 ]9 D* R
Issue importing drawings from CGMs, we are getting all lines as solid lines # r4 u ~3 c! j- `& O2 [: D
1 `- V0 N+ f) i6932100; n' F* f+ z" [; `8 O) c
0 x8 h! F# N$ PGRIP &CRDATE not returning all characters when &FULLDT=0 4 E# E& J2 G0 N( x- [( |. _
; a7 o5 E5 ?# K, M6 q
6932893
- L w H/ m# v% J 7 W. |1 F8 |1 V
Insert Process Station After_ Strip Layout creates incorrect station
* M* d9 M' n' j3 U# [! K5 T3 P
9 Y5 }. }* G( r( z% k6933130* ^* R7 M9 X- m2 S
9 m& u$ b" Z, w1 j [; P* e4 E
Replacement Assistant Slow ; N4 P: ?& ~ u" p; l/ c( W
! A5 R G, b9 [0 ~6933428
) h% f, K- o% k' [" E 3 Y# g h! c% ]2 I3 y4 i$ v2 u
Moldwizard attribute problem - CATALOG contains "-Hide" appended to value ( r' ^) F& P6 x% G* S0 E3 @
# O5 C' I! g/ j. A6934311
& I7 H0 k8 ~0 y0 v' r# ?/ ?
8 \, I! M' S9 D1 _Getting "An attempt was made to associate an object with a second other object"
: y' f. e Q6 E7 k ; ~2 P; j! f1 X$ L0 J/ m
6934724" I$ {3 ?& T- }2 q7 M
5 A- i6 E2 V0 P4 A; |3 H; f
Make next feature current causes objects to move to the work layer
; ~& a! X3 o6 J) g# l8 M+ V* e3 _. Y & D5 b7 N7 R' O" H7 |- R
6934908
2 G% ^! Q# d7 `6 l5 _ 8 ]3 ~+ t; c T
Stock As Components does not manage discontinuity correctly
0 B# j7 B) g* a+ t |
9 r( y; _+ z `, o' }# f6935450
& [) I2 \* z) Z
* G J2 l! L5 }; b3 W4 d# p& VFACE MILLING- specify boundary will not generate
9 e+ T* r7 Z# g
: _9 L4 x( ^$ U( d- ?; H) d8 P6935541
: S- f) j9 g' J- |5 w# z # d$ l8 F& S; s+ G( T9 F+ P
4GD-Info on wave linked feature incomplete, only shows source object info " j" {+ w6 U0 C" e" _' F
* P6 u' Q( Y( o6 R6 F% i$ X3 H6935883
' k8 I: Q, [3 [& u ; K4 B; B- t t# o$ O$ C$ B
Part will not play back in NX 8 that would in NX 7.5
; |- N9 w+ h2 ~- ^1 g" T- y. Y
' `* n K) n. y; T8 D& v3 v4 Y6935901
. X7 r5 J( j& g. O1 S2 y
+ |8 j2 y5 e- O7 w& W! oPart will not play back in NX 8 that would in NX 7.5 - c' t4 V* Y4 o7 \/ P
7 E. ]8 @8 l( E, v6935942" g* F. G- l$ i
& E; D* C( ? \! uPart fails play back in NX 8 that would in NX 7.5
8 d- b' N+ H( I
3 l: S& Y# p, n6935964
% c9 ?0 @$ D% h0 w( |& |7 u h5 | + c* O- d6 A+ v% ]! J8 i
PS26.1.135 fix Part will not play back in NX 8 that would in NX 7.5
1 e* E2 E: G. O* q5 n
& w7 I4 Y& O* Y1 q2 m3 m( H, V5 ?6935968
% y4 s! x {1 T- [) C/ G2 N 5 ]8 c3 k2 o/ m0 b+ I
Part will not play back in NX 8 that would in NX 7.5 2 O: G: F/ B3 @ x. o4 D) X
5 K2 c5 Z3 z% s- x' ]2 |9 ^6935986: d" n" c3 L+ D$ @4 ?
& e* v" }0 s: N1 V; w7 GPart will not play back in NX 8 that would in NX 7.5
# h L6 b- [$ F2 i# o" i* X$ y
, u: t+ c- f. |6 T/ N, E. ?0 X6935987
3 p( H* I6 g# f$ b* g$ Z0 J& H 0 T+ O- D, I& Z' E1 R* u. L0 P
VTK10.06.003 fix Part will not play back in NX 8 that would in NX 7.5
) D6 \9 U* G# i( ~ 2 P2 [! c, ^5 |( w9 d
69360238 H+ s+ z% q! v& x+ o
8 [( b4 N) I* j4 e# ~& o
PSv26.00.193 Part will not play back in NX 8 that would in NX 7.5
+ E% R2 F8 W) F% C* ^8 L" ?
0 S4 r1 e1 M1 Z+ o# D7 s. E" z6936072" \% k! l5 t- \! o) [' v/ v3 G
* z: }4 F2 X# ]
NX: "Deleted or invalid class id was used" when saving* \( \, ?2 i$ a+ Q& B' l: P
" ^, ^6 L* m/ l3 R8 h7 ~6936614
/ \0 k( c$ K6 U `4 M * w; b! D, Z: M
Parts will not play back in NX 8 that would in NX 7.5:Variational Sweep
6 @6 d1 g( C' d& q0 J4 ^. v
/ G1 J# b! h8 U% |8 [7 R) @. X6937054
8 ?+ ]; ~6 Z: C! U: A $ E1 b. p+ {* b0 b) e
Regions Exclude Option Bug 6 z6 l$ H+ O2 J+ f* c M
# ]2 @3 t; d( `$ ^" @! X
69371445 h/ l) [; r% ~/ z4 A
R3 T$ B- a( F( D3 d; oInternal error: memory access violation, opening file6 @. H/ x* t: f. [) Z
7 u8 f" i0 V' y! M$ }6 _9 ?5 i6937534, M0 y" e9 h( e. e8 W# G! \
+ f/ |, u5 O9 o8 _4 |0 d
Disassociated drawings of standard parts 3 F5 \9 `( ]! _# C+ l7 W! ]! [* x
2 L/ J7 K% w9 J- Z; g3 J! z
6937547- X! G, n! }! c0 ?
3 t: M% h$ O: ]
NX Routing Move Part does not repair missing constraints in NX 8.5 like NX 8.0 $ K/ J2 B2 d- Q( Z& b9 Z
$ _) D$ E: e2 k
6938097
5 P* O5 n0 M* u3 d ( u9 O, Y7 E. P9 N
Variable Axis operation from NX 7.5.3 generates no tool path in NX 7.5.5
% W& J6 ~6 M: K }* x ! u" o% q/ E* \
6938152
8 v5 A0 E7 v% v- ~# A9 r3 B+ l : Q( D% v8 p: v. ^0 x8 l
Mirror Weld,Defaulting to Plane for first prompt
1 C: H* z0 r0 i3 j2 Y - r# ~7 D) S8 i! A
6938242
1 _9 G7 z, Q' k/ k+ G/ e
7 D4 S8 m6 j3 X, \4 KWeld Issue-CFF Grouping features from separate locations (QC3585)
5 m& b) h& p' e2 ` - d G0 R% P- t' @6 l8 c: V
69382967 I* ~$ g% n1 z. Y) s$ i- n
+ L" H5 T+ L2 E o' B, VWeld Connected Face Finder fails to find surfaces (QC3586)
, q6 ]% K& f6 e# P% E5 m; I |# r' } " ^/ q. x9 \8 {
6938625( Q- L/ ]( U9 ~! l. w' O
$ }% H" f% D1 t- |- J4 t& vUpgrade to NX 8.5.2MP1 and not able to expand reuse library folders
' Z' Q: y5 `2 a+ p! @6 T " Q& T, v5 [ S1 U2 X: c3 E
6939092( b- l0 y( Z, Q& R6 {
6 O# I- `5 t+ K! Z1 X7 r: _* hUpdate Groove weld, cause the other 3 Groove welds to disappear
' S/ M# P- \0 g( K
+ l/ Y" `1 p. G# c% w( A& a, A. W$ s6939291# m* o! k f/ M0 A, K9 @
; r } P4 [# R" T. LNeed to have .net coverage to be able to Export tools to library # W: Z# d, J3 p& _) T$ ~# V
7 a# {2 e# \3 l8 ]+ J6 r
6939350- \9 \8 o( @: a) q. }+ r4 X! w
( [ o# o: z$ n+ a' i( c2D Centerline used to dimension Flange radius sends leader endpoint into space
9 u3 j" ]- \6 q, H5 ]
( p9 h6 e# `7 n! I6939659
" ~, {! I! p* ]+ B' U( T2 _) o - Q, g) k. I* E% d5 U
Creating angular dimension in NX 8 and later fails to work like earlier releases" R% S1 W5 d) P' L9 @: H
3 @+ D0 ^5 r6 O& L9 H
6939669
7 ^) h' ?. ^6 }) k! E" q/ s! ?
8 Y& \6 o( ?7 _& P. RNX270138 Internal Error attempting to create Face Blend
& i% A' Y+ m8 N, i# G$ c4 R" G
3 p" t, y ?$ x3 Q( \ \0 ^& }* T6940132# p) e% R, X% \' b9 A
# y) }' r( X' f2 F% p* n
Law Extension Normal flips after change to asymmetric mode
; v( R$ O/ y# Q- S+ l. O w * f# ?4 D7 F7 C% Y
69402056 C ^2 ~5 d* N- y
& `/ T4 @; a' J t: ?
Problem with opening fem - signal 11 , m: _( x6 [# [$ a- ]: I! C
; `- q: c% ~( a ]. x+ l% `) D1 x
6940309; p0 X. E+ p8 F; ^" l' _- |
: c9 `% V: a( f) a. e( nNX 8.5 Performance Issue unhiding when Sections are on
8 f4 m6 j+ z/ r ) h, }) c0 l3 W
6940349
# ^: m% I$ d( L4 N7 c
! F; L- Z1 D: T: Y& w" e#NAME?
$ Q/ Z1 L8 W& T: N/ y" C ! K$ c3 y+ j+ i7 L) u% q: f2 F
6940456
: {5 c ?9 N% H 0 O4 w8 ]2 D) B* W; X' a
Offset curve in face: inconsistant_wrong result w_trim to each other on
2 Q* ]) [, @1 z+ C1 ?# { # N. d, e @; |0 _. X, t
6940772+ E" s- ~* T5 X/ d2 V
' Z5 C4 ~6 w8 N
Step file unable to open in NX 1 v# k- S4 g& s' Y* k& m: O9 }+ l
* c0 U( G3 o, Y: d% u, q6940819
+ j) X; B5 K" q6 p& u
; c, u, _4 y' J# r! iParts not highlighting or center_fitting when navigating Violation Objects 1 a8 P/ ~9 K- M% T& f
5 a. L# s$ T1 R6 z5 R5 S6940822) L/ n; B& r @, e$ z8 ~$ o& }
7 s+ D7 q ^* Z5 \. A# W2 }0 yComponents not centering or fitting to screen when navigating Violation Objects
5 _# ?3 K% x/ Q, T4 z* e- I# b( j
1 P1 l s5 Y3 i; O( k6940861
: V3 z! ^ `8 Q
% s e1 z5 B5 o- `; p0 o' R gFloor wall milling sets component level to visible only when picking cut area
( t9 n7 |6 I' b# s- ] ( [+ r) j: R. m' s
6941361
0 H, @$ p9 J7 h6 { 5 G3 v/ B A* F7 x- X ^; ]2 r0 o
Floor Wall operation does not warn user if floors are not at the same tool axis o+ o' h% u$ ]" h; g) W
K) d9 \4 }% x, W# m! Y69414041 V# V% y1 B+ x. J4 s
# s5 }% C$ B& p+ b. `! D8 nPart attributes deleted during Initiate Project in Progressive Die Wizard # Q' \0 O( i/ D
1 ~/ U7 {# m( X/ s8 ?1 ~; {6941621# V' F5 z3 r0 v B5 @
g, i! t8 A' K8 E& r/ C
NX: Gap remains unchanged after a resize : w3 w' d% M* K3 c4 B% o: V
1 [3 o7 ~7 _( x: q
6941709' F" Z) j {3 o9 t/ I! Z5 W
: c( V5 \1 @: ^. JNX 9 Fatal Error when using Custom Filter Procedure with SetSelProcs , q1 `1 y" d$ w8 X, z
, o+ c+ T* u3 q; C! A) m6 i
6941819
0 v% J$ F% Q( _5 |- A
5 B7 O0 e5 [* rCurves flip after feature replacement
8 w& X# v- V% x# \
+ q) X3 F) y4 p0 G/ k) y. Y7 M, G6941865
1 W: p. F% Z- C5 c9 Y0 C
& d7 f+ `1 H0 Y1 c) a3 C; Z vIntermediate tapered beams written incorrectly / ]( E' e! p: l* Q2 G: [
" Z/ X8 q0 ^; d$ B) P6941980( X1 }0 M- D1 b, X
' h9 b, h* t: g# u2 K$ z
Specific Project Curve HANGS NX
5 x$ g+ J4 z# k' O3 Y6 @; _; w7 e
; {! P7 R8 ?: g, a- [; {, c6942093$ p) m0 ~0 e1 m5 w
" \1 H7 n8 e, E) D, c8 p2 E
NX terminates when interrupting processing of Contour Profile operation 8 r7 X, l+ r j' V' w* B3 m5 U
2 K8 M) y5 S( H0 t' @. y, _; J$ x" Z' p
6942434' F( z' k. p3 O" W, B+ g
! s' k; X3 j, |, |5 sUpdate multi-cad JT in Displayed part properties
{9 z+ ~* F7 k I: g
9 }- X8 ?2 R# U c- T# n! |6942468% ~5 a3 }/ m8 x4 S! w) L
0 x$ C- M4 I" v0 GDrawing Booklet creation in 4GD throws Internal Error: Memory Access Violation
9 F- e8 i+ s; T. M6 V: A/ L2 R: g
4 t2 ?% g1 ]% e! T2 V6942987
# \+ p/ N ]# i9 }: S
$ }5 Y, ?8 M* g5 Z: {' j9 OPaste feature does not honor original selection intent
% N- a! d( D/ u# _" g2 [ ( }! W$ U: ~" x5 z3 M
6943094
% _* c* d: F: D) x( \
& n& B8 J) D# vFeature Groups do not highlight plane parents if collapsed
: }# S& S8 j6 [5 I) ~) A0 P
5 x6 f& D4 ~4 l0 e. x6 I5 E9 H6943576. H) |, b' P3 ?2 w' M% D9 B% R; e
/ t3 S `% n" C5 x' HMIL98C formatted bend data does not meet Mill-D-9898C requirements
1 m9 c& k4 |0 ]4 R) H9 q4 K; g
6 o3 T4 R/ v% g: N" C. Q/ ~ m2 }69437500 A, w& a) F- f3 }! s: U
4 W5 C; m. a' b; Q
Intersection curve direction cannot be relied upon to be consistent
0 c6 b( [( A; Q# U+ }$ |7 z4 X& ~2 o
, k z" |$ Y7 t* U" ~ L6944004* C# R& s0 r1 m2 { Z8 R" G! f1 V. l4 k
- T" H8 ^/ s. j3 U2 }( W b- ^
Associative copy mirror feature position incorrect 3 J1 F i: m" H5 D P$ b# J6 s
3 t4 v) J y' ], j$ a6944081& D" w3 L! L; z/ g4 X' [7 v
/ b) j1 Z' s# V0 [
Weld issue - Edit Parameters not working on spot welds. (QC3588)
" o) @% D7 w9 ^- q; f: {0 e$ U" H $ `; y* p( P* j/ P0 v! S2 f: @8 G
6944144( N: [: O, f R
4 t$ `3 P+ o: O% N! Y5 H+ nDon't see sub-folders in TC Reuse Library & B" h! k2 j; H) _
+ p$ c5 l$ J" O% B5 h- A3 P
6944879
# O4 b+ a+ t$ K* E9 j3 e $ W- I# \) k; w# z1 u8 Z0 a
Unable to save assembly (work part only) with unsaved components
# M% ^' F) r2 B/ R3 V
& @0 F' W! p) D1 U' n1 \6945122
, C }" `6 P* w- F" x
# r4 T% h1 ?' X+ D0 eTemplates with Annotation Relationships are not loading " y: ~0 Z: d. m3 _/ ~ M3 q: Y
9 W( S: a/ n( g+ g- c: R) f6947028/ E. h/ K7 X2 c. t0 d5 D6 C, w3 |
$ }& ~* y. h; P
Open part fails with "Filename must be unique within data manager" error 2 ^) L; b7 G9 K8 c- m" v
2 e* [: a1 J, J8 |! L1 {+ f& I, [
69473993 O# }% O4 n! L& q
1 a6 A. k2 X2 H* I2 zError shuts down NX {& M' ?2 |; A1 w+ B9 d1 U3 w
6 t" @1 C. L/ j( @7 j- d6947911: q3 L, E5 W: u' i
3 [: \. n% \$ R9 p& b1 Z- X
Intersection curve flips after feature replacement
4 l9 n y0 g' K* f- q3 j0 s ) Y- M! D& L- p2 n( h5 |
6947926/ r: D0 l6 T" S- _- Y
- u1 _7 R$ @9 g- ~" HOffset Curve in Face produces tiny sliver w_Trim to each other ON 7 f4 I2 D# U( e# w
8 U0 F& K2 `5 z4 Z3 k
6948564) a A4 _' u3 i% c+ C
2 m& d( v! ?6 {+ Z' MIntersection curve_studio surface flip after repointing extracted body 6 A( E* l/ M4 x& u- u4 F7 @$ i4 U
+ t3 H( C$ O4 S$ Q3 x
6948583
8 G/ u0 M& h4 a r
; q' E6 Z. B8 N% ZIntersection Curve flips after features are replaced
f; L6 Y h/ J& j; R 2 }2 m$ C3 ^) b. [8 R
6948932+ f' A5 u6 ~' z& K5 f" {
/ M( I8 g5 c; L$ p" r
2D centerline not behaving as expected
u7 b! @8 Q8 C3 R6 W( n5 Z) D' e/ E
# o; ?5 E& @9 n) @2 h6949516
, f, h+ c3 U5 `! ^* O
( \. W- J8 Y2 B! X9 [5 CAttempt to set a two way reference; Part Cleanup > Clean Manu Objects message 7 r! P/ j% O: G- ^( E9 F, N b. j- O
) K# G; u% V, o
69497919 Z' L7 v9 U- \4 i+ ^- P( {
, S3 w+ m# j! C; H k/ X, @6 F" ~2 t. B
UGMGR: Filename must be unique within a data manager : E4 o7 G/ J/ F. f w* O
3 H4 t, d v6 ]6950174
( C$ Q* ]. p& e! a : v/ l2 u+ r/ H
Intersection Curve Flips normal after Feature Replacement % n6 W; T& V3 w' q2 T
! Q' t# j+ a, d' f6950332( o4 Z. n J1 L
" K) E0 J/ D+ u$ T+ I+ O* {# v' k+ d
Find feature causes signal 11 error 0 A2 _/ N) S! O. K
, o5 z( J* C, Y, x) ]# L
69507974 T0 d0 i* D& k! ^8 [0 E8 m0 Z0 I
& n! B1 W% F) K1 R
NX crashes when generating PDF for a specific
; `& `9 L1 X" I6 B6 p6 }
2 d0 |# y9 `, a2 _: r$ v6950917; `, K& ^3 E0 t3 B: ?! R2 \2 z7 o
# `/ Q+ {9 h4 i
Intersection Curve flips after feature replacement
3 v+ h5 e- u2 O6 i% X/ o
( ?4 @" D- p3 J69509312 U% w i3 s* `3 {
4 x' @2 D1 _! w
Intersection Curve Flips after feature replace 9 s7 \" q- E2 C+ C" F) V
: P4 j- x7 @4 y) e9 d6 L; \6951384' _0 y7 X+ o# M( X: o8 c
/ r+ S& U& t- G# Y( V
Using Retract Auto in the new Hole Making operation type 1 X. B$ U o: A2 u: k) b# ?0 ?: J
9 \1 `( o3 y) A. b0 X. S0 C/ @69519540 s1 o9 F; }. ?# r* O$ v0 p+ f
0 X! K+ o" g1 u) b0 j; c9 |$ w
Hole_boss operation drills same Solid Edge ST6 threaded holes to differnt depths
9 z b2 k ?4 G6 V. G) K
6 D9 S3 P D) K# W# q69526386 V3 k: f$ X3 }1 Y' N0 P! a' O
1 i( N6 h5 o/ h9 g; L3 n- iHolemaking creates a new G8x cycle output for every single hole
: c5 A, Y9 h) A5 K2 y
2 [" L( m r/ g9 v6952935" L$ P3 z9 {) u$ o9 I
+ l: J3 ]+ q2 K
Save All fails message for assembly containing read only parts * L4 b( |: Y3 O" {+ N( e, u. j
: @7 G: Y d; F- S. K! o+ E6 F
69534063 u5 _' }# f( q0 J& i% l% e# c9 s
w8 k4 b- F4 J; H" t4 VDouble_quote in name caused ugtopv to fail
8 a7 X& C3 o' f# X, u' ~+ |7 L/ P
/ I: _" G6 J2 k& {) p3 M( t w, Z6953750
2 f- V& w( `* k/ X
, h2 O# C- C5 k4 [" o l' |Can't create plate feature using single curve when defining boundaries
3 J7 F. q( v; B1 |( ~+ I5 C) M 5 R) F$ v' p1 F7 f& m
6954125
& W5 D L9 j) \& Y [: g; L3 _$ [- E3 ` 9 \% Q- |( {( i. A+ Q0 }! K5 r. A7 b
Weight is not updating in Part Family Members
: t/ d @4 N+ S( X2 D: _ P, V" k3 N6 i: w. X
6954638. y$ a7 C% O; D9 F8 d1 i
- D* ]9 m) x7 d0 j! ]# D. cWeld Issue - WELD ID SWAP & h, C7 ^4 G8 ?6 Z
F- \/ O7 g/ D0 J" u7 l
6954723% c* T, u. y2 _8 X% U' E
: E5 V- ^6 ^& M! g l. S
Licence Error is raised when setting Type Filter to Solid and using MB3
7 C4 k* U/ o# V" ]7 L2 q/ O% ~2 U
6 ~# f% `- C1 T1 t. j* }6955744$ z" i* z# p5 \7 N
6 s* V& s2 z* h9 UIntersection curves flip after feature replacement
4 {4 m- O8 h( y1 ~9 q 4 Z: T, ~9 W. a6 c0 I
6956960
4 ~8 j0 u; Q" \5 j* ]' B
5 p$ b9 c( V9 S5 i- cIntersection Curve direction flips every other time when datum location changes ! T- k! I$ i7 C9 k) L4 w# ]7 m" U
9 I4 [2 }* |$ m, r7 w
6957137
D& V: }" Y& H( y3 z
* X8 c7 v9 k0 g5 _8 {NX 9 Displays "License Server System Does Not Support This Feature (-18)" error # x" c/ P) O+ d1 {/ A/ F& c7 E
: D& g" v# V0 p; [ X" |
6957486, b$ f$ _0 N" e$ C# C( W- m
7 y' A. n% ~9 p1 e% B# d/ s' H- m2 ]Dimension shifts when loading 3d model in modeling application : Y6 h& [. h8 d6 y
0 c1 b+ h- q$ U: Q! P6 p! ]% P
6957758
. d z% ]! G$ I2 v ( I& R- t" c- p4 V+ B
Send to NX: "File name must be unique" w4 Y K: c% I0 k
' q9 E( W9 D- j7 g1 O8 p0 @, v% O3 ~
6958479+ Y7 ?. [3 h( \& H9 \
! B1 {. { D2 T9 Nug_check_part.exe utility stopped response randomly while running NX checker
! E0 w& k- E2 ?' A# L; h
( |7 \5 c! x" k* y; r5 p8 \! B3 T6959273/ g' K5 [2 y) n5 ~( R2 M1 I, j- c
, u* ]7 {1 c, _3 I1 }: x3 J
Reuse library members no longer working in NX 8.5.3 ; X. u" p! Q' u; e2 g
7 o0 O3 V. A8 {& O; r% v
6959369; G8 m, a. d3 T3 k M
i3 x5 Q1 n; C
License error when selecting a face 4 k }; ]# H9 z5 v0 D" _. l
7 H9 m. i- Z5 ~ J* I' W- R6959652+ s2 V) @, c3 p0 m# S
: J2 z9 N# s) \0 S0 U3 C9 `
NX License Error 1 A" }. [8 D. x9 |2 I9 K
4 h' t- |& M( E# ^* s6959654
) q4 x7 c% M: a+ D! K' S* i
, X/ t# p) r8 l0 ~NX License Error , X' r( B9 r5 F" u5 C# F) U6 q! O+ R, ~
* u# n- p6 s# c' S: D1 w/ ^
6960614$ d0 r8 H- c9 y6 A U8 D1 v
' X" i/ L: c5 a6 Y& _
CAM open sided hole cannot be selected as Hole Milling geometry ' ?6 S$ a: q& S) j# r
3 E/ P4 q2 }# b' i/ Q& c3 T8 p, N' A
6962625
1 C1 V5 _5 ]" t0 T& \0 k
% h4 K. s0 U' ]8 m E+ k9 \Select a blank geometry in turning operation when one IS defined (again)
* C8 x. f0 b1 F4 V% {; a6 Y! Q 2 O: Z* y5 W' X/ [% Z$ B
6962741
& k1 ]: R0 c7 ?! b& A# ]9 i9 P, [ + Y; a% h4 [1 @$ H4 ]4 i' b
Setting UGII_OPTION truncates the ribbon bar display
& P* b; h Q/ ?# A6 I# K* g5 J 3 u4 M% e! U2 q! B! |+ ^5 i
69637243 L* A# F6 e/ w2 T9 L, l7 S
: u. S; A. _5 J# i! s5 B
NX 8.5 Assembly corrupted, cannot open in NX 9.0
# w. _- @/ I7 F! N# J 2 u" \; Y+ b7 j- U' _4 O% x
6968251; S! R3 R* U* @, q% z, S% l" [' k! Y
8 O7 ?" S+ N7 P. i7 B/ z
Dynamic datum CSYS origin will not locate to point on face( u/ {" q# Z: e+ M1 \+ ^
$ R% a( ^4 }# D# d6968767
- W0 o4 B$ w, Q# s
, p- N% ]/ Q, l; c: L; B6 FREGR: Cannot paste in NX 9, Ok in NX 8
! G1 _; b5 }% D6 {
! T4 {4 w- J5 u& Z6968863* K0 g1 k5 ?4 ~% `; n
' V. A+ h6 u% t8 K; QWCS Orient Point, Perpendicular Curve not working# {6 Z: Z# B9 r! j
9 G9 |1 l( @) ~% e. A' u5 a6969812
- A2 X' M z! B' {2 C' c' H$ g ( T% l. j, U- J5 ^
Editing and saving a part shows "Attempt to save bad pointer, save aborted" error
" h' u7 W% B" j4 E# G
: G- K; y' z3 R/ `# w' K6971055
4 L' \" }) l& ?0 e( d/ M
4 q# g* }& l. @8 a4 d- c; i; S+ E1 PProbe Cylinder operation doesn't work for 'External' ' J4 p) }& E$ P* { `: [ P
, w: N+ e. f7 I1 R9 j2 r
6975862+ g9 ^+ a7 D3 w
9 Y' c% j4 ^1 c4 ?4 u S( z, u& D7 Y
'Verify -> 2D Dynamic -> Play -> Compare' does not report gouges in red NX 9
* P; g/ u8 V0 X/ A ' P# M' w1 w0 L" m
6978542
" q# u4 e) }$ N q7 @ 7 \& ^( H" y3 @6 C
NX 9; Generic and Solid tools do not migrate from NX 8.5! ?% ]% p( h/ m( N& b7 v x% t1 e
# x+ }% b' F) ?+ B8 S( w6978591
1 M+ ?1 ]6 H4 R% {
9 K7 k! Z6 k! ^6 P3 jNX crashes to OS when accessing Piercing Insert Design 6 v. |$ _5 m* W5 {+ c$ N2 u. J
0 c; u! e$ w5 q& h- e % y* | d& [7 S; z
5 _* e |5 j+ B# o/ q# ~5 z1 r! a' e: x0 V) l
