[资料] 什么是Teamcenter的业务建模器Business Modeler IDE
2014-2-24 10:34:31 6199 0
发表于 2014-2-24 10:34:31 | 显示全部楼层 |阅读模式
The Business Modeler IDE is a tool for adding your own data model objects on top of
  j# _8 X, f4 G5 n" t5 [5 jthe default Teamcenter data model objects. The Business Modeler IDE accomplishes8 {; f6 A0 W! B7 o5 q( s  ^" j
this by separating your data model into its own set of files that are kept apart from
6 d5 V/ j" K( R' y0 kthe standard data model, known as the COTS (commercial off-the-shelf) data model.
' t) d3 f' A; ~4 |1 L" \Data model objects are collected into templates that contain the data model for an
; ]! \; J! c/ V( Wapplication (also known as a solution). For example, the foundation_template.xml, U3 i/ U& d) u/ {+ B% q* e
file contains the data model for the Foundation solution, the base Teamcenter
$ ~6 d9 o2 \' {  x  mapplication. When you use the Business Modeler IDE to create data model, your
  {6 X& E/ `! t7 bdata model is rolled up into its own template.9 F* \# ~# B# j! t
As you develop data model, you can deploy it onto a test server to verify that it
+ O9 D! e/ t9 @% Ybehaves the way you want it to. After you are finished testing, you can package7 z9 ^. r2 }" `  t
the data model into a template that can be installed to a production server using1 x, W6 a- I) d- {) Z
Teamcenter Environment Manager (TEM).
, l3 Z9 h- J! r+ }
