[新功能] NX9.0.2新功能官方文档 what's new
2014-6-1 20:37:16 5453 0
发表于 2014-6-1 20:37:16 | 显示全部楼层 |阅读模式
- b, S& s+ Z& ^6 Q, {
1 U* T/ }5 z3 t# R9 A7 Z& y
# o# G* m: Z- }( Z8 x; J2 ~
NX9.0.2新功能官方文档 what's new 2 ?* k: N- s7 i- [
  z# Y) Y; e1 W; T; f
& b% |1 T$ o) x0 D1 h/ X/ x$ tNX9.0.2新功能官方文档 (1.67M)
9 v: X3 E  o% l3 U7 h
' b) R6 u; ?7 B* P
2 u0 ^/ P# h' U5 B! w7 K1 H5 j2 A7 q! f! N3 X6 B/ o# f
7 e+ V1 h1 _2 {
1 X9 h/ h; _6 u/ f; [, `# r
% p- Y* Q6 g9 k+ N( U# h0 c
1 W' ?$ k! Q3 L
; V) l* R7 |  h) q* n) p    What's New in NX 902    iii 2 B+ M) m9 L9 p$ x0 I5 }7 m
7 F/ ?# u  j/ g  ?5 s8 F; B) c
; ]% C) G( M) X) wContents
. C9 e% O4 Y) j" oChapter 1:  Fundamentals  1
9 l7 M  N2 F( t7 uLicensing Options enhancements  1
( I1 G* y) `8 A) h1 yChapter 2:  Manufacturing  3 " u4 J- m! c2 ~( u, p
Displaying cutter paths  3
6 f- z  `* \% I3 d, S2 @9 bTrimming tool paths in the Tool Path Editor  6 4 T2 u' d; y  Y. z) k# a
Cut region control for Flowcut Reference Tool  8 & c0 ^+ k! n0 M' A. w
Corner smoothing  11 - [' B& Z1 G1 A5 j# X5 ^
Automatic follow periphery pattern direction in cavity milling  12 ' T$ D, L! R$ ~# F. }
Using a boundary with the Area Milling drive method  14 ( [6 N% u2 S; r1 p
Contact tool position on Area Milling boundaries  18
( z. t8 J/ G3 w  ~Tracking points for drilling tools  20
4 q+ C4 v5 z/ uMachining holes with fewer operations  23
7 Q& C- t, m8 L: T  EEnhancements to control drilling depth  26 , D6 p4 C  I/ T6 H; d
Enhancements to optimize drill sequencing  32
2 w$ h1 B  j! [Milling hole chamfers  37
( z; o5 ]  C8 x% a/ C" cGoUGe reports for authorized penetrations  39 ! r+ w: q+ _+ o/ Y3 @
Verification settings and playback enhancements  41
, g) [; g+ G  t0 \8 V# PBoundary dialog box enhancements  43
6 c4 u' {" W% l0 c9 ]7 P3 \& X9 iFinishing enhancements for Curve/Point drive method  45
: o, H* ], W* Q) DPerformance enhancements for Floor Wall operations using a 3D IPW  48 ; p7 S% j" |- Z1 z) g3 z) v& o% |% b
Support for MoriAPT CLSF output  49 , V# V7 f6 L1 d. j
Chapter 3:  Advanced Simulation  51
& C6 l: }& _+ x# WImporting layup files  51 8 C/ F2 s" z( H: `+ E
Show Critical Layer ID  52 % C7 o' E4 {8 m' p  s7 ~( p
Chapter 4:  Shipbuilding  53
6 f3 S! W, T3 gAssign names to basic design objects  53 9 r% E1 l6 H. O0 h/ o, i
Profile Transition enhancements  55
% U1 g" K+ O2 bAdd knuckles to flared end cuts  57 * n1 o6 x" Q$ j1 f& w+ i9 Z
Excess Material enhancements  59   i$ q( r3 o* B
Manufacturing XML Output enhancements  61 0 p! S( }; W0 o. _
Profile SkeTCh enhancements  62
. a% }. K4 N5 [+ T7 i$ G8 YChapter 5:  Tooling Design  65
2 E/ Z: E3 k5 x. q. U1 ^0 `Morphing objects using OmniCAD  65
4 s0 Q! r; q. B% o0 f5 NChapter 6:  CMM Inspection Programming  67
% H" |( P9 C% W' q1 o: g* E, x! eGeneral enhancements  67 - j! K; [* r3 e, {6 J. z
Creating plane and cylinder features from multiple faces 68
3 K, Q: Y4 D9 x0 u# |  ISpecifying user-defined events (UDEs)  69
: l1 A* R& e; ~+ oChapter 7:  Data translation  71 7 |6 c' s& e8 _* d: G( N
Support for ESKD standard entities using DXF/DWG and 2D Exchange translators  71
: c0 j+ Y- U4 e# ?# }5 C7 V9 t8 hCATIA V5 translator enhancement  71  ) F( p: u1 _  ^3 [  Z; i1 Z$ D4 x
: I7 [1 P7 e/ a$ N$ B! `( ]' a, i
    What's New in NX 902    iv
5 m; j- a7 b5 G2 b2 n5 u, z8 H
( F9 W: r; ?2 ^3 i5 Z . H5 q# N& t4 Z( C$ H) \' x; A! G1 v, E
NX 902 ! P9 C2 {3 F; D
Chapter 8:  Routing  73 & T5 }  W$ U0 f* z7 _
Convert Splines  73
* n, P, i/ @# YCut elbow placement enhancements  74
3 g( @% C9 A9 V& JAssign Corner enhancement  77
5 |- T. K! |  b1 [) [- HUnify Path enhancement  77 % S$ B! W+ n# y8 d. [
Chapter 9:  Facet Body Preparation  79
7 r4 v! T( f! i5 q" j: w9 ?Create Box  79 , u# ^/ c4 s0 ~/ l9 i
Snap Point enhancement  81
4 ~! |) {8 X* E' {* i9 d- PExtrude Facet Body  82 7 B' f- D3 Z' B$ ^4 k
Extrude Profile  83
9 \5 b" ~& S+ [8 z5 E) \5 MMerge Disjoint Facet Bodies  84 . m8 Q& O6 D9 @7 _  O
Merge Overlapping Facet Bodies  85
# `; I. Z# c7 |% `Merge Touching Facet Bodies  86   Q, t9 x6 q' h
Rough Offset enhancement  87 9 W9 R* E+ F  r2 I
Chapter 10:  Active Workspace  89 # `  o" d! @3 D9 ]
% Y" @, L* n' A1 O5 ]9 w
, [$ Z& P8 K( g* e4 T, V* [5 @9 R9 `
1 r6 \' V. I2 v  ?  D4 p3 C
( K& h; l4 r$ a  F# P- E8 |
! T  M: L4 J  m8 \. c, m9 Y" f" [* `3 G3 Y$ t/ ^2 C% Q9 Q, d2 Z
