[交作业] 第二节课交作业呵呵,
2014-11-24 16:13:29 3465 3
发表于 2014-11-24 14:56:48 | 显示全部楼层 |阅读模式
#include <uf.h>
3 ~4 O& ]! J" w' R! c4 N#include <uf_ui.h>
) k3 U6 u3 S6 _  q3 V( k% W) X$ M& R#include <uf_exit.h>
/ ]' t) s9 z. K( G#include <uf_part.h>
) a& d8 Y, ~4 m; P, T" ]9 s#include <uf_modl.h>! l9 ?/ I  c& ?/ G
#include <stdio.h>
. W4 I- {9 z- ~, [* O#include <stdlib.h>1 T) @, X. W( S$ _9 J# ^7 p! p
! W$ P; L3 K+ o7 Sextern DllExport void ufusr( char *parm, int *returnCode, int rlen )/ O' X1 Y2 B7 q1 Y9 q/ K
{& w! i8 q& Z* c+ y
    UF_initialize(); 0 ?7 g9 q8 T4 V/ i: F
2 L5 o, U/ O: @# p' v$ D. x
                char path[256] = "D:\\new.prt";9 S* i5 g; y: L& }. c" V3 [1 H5 x! z
                tag_t newPart;1 \' T  N: V9 b1 p- c0 }& r: R$ c
                UF_PART_new(path,1,&newPart);- w. c- W( o! A. X+ N$ z9 {
: I/ ~. ~7 ?3 x( a
                double cyl_origin1[3] = {10,0,0};/ }) ~7 e. A' X
                char *cyl_height1 = "30";' ~! N- h" S& t$ X0 J
                char *cyl_diam1 = "10";
0 j% x, e$ B: B, F% F' J* r                double cyl_direction1[3] = {0,0,1};) ~* l2 W$ l8 _2 X( u/ P  \
                tag_t cyl_tag1;
. U7 }+ s$ s! r9 F# F: h- e6 ]                tag_t line1;
( i8 J+ T8 o8 L                UF_MODL_create_cyl1(UF_NULLSIGN,cyl_origin1,cyl_height1,cyl_diam1,cyl_direction1,&cyl_tag1);9 q6 W! y1 r- Y0 |1 w9 L# n
* R2 f" n' _" P5 X; i, [% k                UF_CURVE_line_t lineP;! M: H" Z4 O8 M% l! T/ c+ ]& @) }# A
                lineP.start_point[0] = cyl_origin1[0];
, X1 g# `& {! o1 `                lineP.start_point[1] = cyl_origin1[1];
% b" n( k/ f  c7 {                double D_cyl_height1 = 0.0;
& A/ h2 V& T- z# H8 S                sscanf(cyl_height1,"%lf",&D_cyl_height1);
! l6 m4 r2 X. ?* v9 q2 |7 v0 f                lineP.start_point[2] = cyl_origin1[2]+D_cyl_height1;
, C3 J6 u$ _- ?  H7 Y" g# T- O/ a
/ n; _! Z3 P. q, t                lineP.end_point[0] = cyl_origin1[0];
" h' V2 r) N; ^' I2 B0 \2 E0 K                lineP.end_point[1] = cyl_origin1[1];/ F8 @# b8 e5 U: H5 T4 {- L
                lineP.end_point[2] = cyl_origin1[2];
0 c! I# ^4 n5 o9 S                UF_CURVE_create_line(&lineP,&line1);) k- t% i* t# h/ s
: x! f9 r0 h6 B" R& ?- G9 v1 H                UF_CURVE_line_t o_lineP;9 |6 ~; v1 ]) l( z( a
                UF_CURVE_ask_line_data(line1,&o_lineP);' ]' U3 J' L1 \" D. G
; F5 h1 h& x1 y% c% B                char start_msg[256];
4 h' W3 o# P8 d% V3 ^" Y% k                sprintf(start_msg,"直线起始点(X,Y,Z):%f,%f,%f\n",o_lineP.start_point[0],o_lineP.start_point[1],o_lineP.start_point[2]);
( S0 I+ r$ L. h3 q% g& S9 u                char end_msg[256];
# l7 ^. O: n, F3 T! j8 {                sprintf(end_msg,"直线起终点(X,Y,Z):%f,%f,%f\n",o_lineP.end_point[0],o_lineP.end_point[1],o_lineP.end_point[2]);
. F  u/ t2 |; o3 ~" L0 l4 v
; I: M- j3 c% @# S4 {4 X: f                UF_UI_open_listing_window();  Z4 {7 ^4 L) {) z  b7 }
                UF_UI_write_listing_window(start_msg);, g3 [$ f" h& ~0 N3 a5 o
                UF_UI_write_listing_window(end_msg);
( s+ y3 A1 I' m- I5 K" e! g. y- _. @4 W. x% d6 a
        /*        uc1601("点击--确定--后保存并关闭",1);
7 h+ d/ K' _/ G( Z% p: u* y7 _                UF_UI_exit_listing_window();
+ ~0 F. O* D0 y' r+ O% t2 ~, M        */
% X" ]& |4 X' K6 D. B& ]% j/ q- R; I                UF_PART_save();
* p7 G0 `5 E; x# K                UF_PART_close_all();
  B6 G, e! G% p- H' q) F4 b0 J5 @    UF_terminate();' t/ m0 _/ z- V$ r3 P4 a
& c  j, ]/ X& E% A: E+ S# V2 ]2 o1 u) v2 ~
extern int ufusr_ask_unload( void )
2 p* r( D, L& ?) V" p( D{
2 \' ^" F) O$ N* n, _    return( UF_UNLOAD_IMMEDIATELY );% D* |8 c' ~# @, c
9 t$ L$ b) H6 L( N* l$ E
! u2 V4 X: s( L, Q9 ~" P9 d$ Q$ @+ h  ]6 }" w
评分
参与人数 1PLM币 +5 收起 理由
admin + 5 很给力!
查看全部评分
发表于 2014-11-24 15:16:27 | 显示全部楼层
做的不错 !
: f" U, l8 i4 Y% Q7 e0 b# _: ]还可以提高:
1 s- c2 B$ P- K, d/ S. g+ P9 l
2 V5 p3 c# u8 u如果 圆柱 不是 Z轴的方向,你这个中心线是否还正确!  可以自己测试下!: l& C0 e) x1 B: B
3 c, U3 Y( h+ ?( u; R( X看看这个功能是不是可以增强下!
发表于 2014-11-24 15:16:29 | 显示全部楼层
做的不错 !
. t$ l% k; M; c6 H0 J1 M还可以提高:
' J  G% R( y# B7 [' w+ s) I# X/ Y. W# ~! B
如果 圆柱 不是 Z轴的方向,你这个中心线是否还正确!  可以自己测试下!3 t* h+ R+ l/ e. v4 A) x  m9 M
6 |6 t8 H. b3 L( r  P看看这个功能是不是可以增强下!
 楼主| 发表于 2014-11-24 16:13:29 | 显示全部楼层
恩,我再试试
