Catia二次开发源码分享:创建零件设计表
2022-2-13 11:25:14 3751 2
发表于 2018-2-22 13:21:35 | 显示全部楼层 |阅读模式
创建零件设计表8 z6 w+ y& e' o7 _1 Z" q
" |: P/ d' y/ D" {& W+ }1 N
//初始化CATICkeParmFactory 工厂
6 {* @  l/ D% v' ~/ N# eCATICkeParmFactory_var spParmFactory = spContainer;
# q& c: w3 ]; _0 f) x) |4 I" H//创建设计表的函数如下
4 R) Q8 R& W" _; k+ cCATIDesignTable_var CreateDesignTable( const CATUnicodeString& iRelationName,
6 B: ~4 T4 O) w% }0 p$ x3 V& g% oconst CATUnicodeString& iComment,
. Q! F/ i) S$ K. mconst CATUnicodeString& iFilePath,
1 [: U/ X7 M3 S1 [int orientation = 1,
; V" _. x6 B1 w" m# {6 eint sheetWithoutFile = 0 );
; l9 O  `" L% D7 O. ~! h函数说明:iRelationName 为设计表的名字,iComment 为设计表的说明,iFilePath 为创建
# }2 L; E% J6 U: C表的路径。
7 x+ \0 I/ n4 d创建零件族的步骤如下:4 E2 V0 R9 K9 H2 q0 R
1.创建参数
. ^: Q4 T% a2 D$ f4 \CATICkeParm_var spPp1 = spFact->CreateInteger ("Column1",0);
! U& @# E5 M; m6 eCATICkeParm_var spPp2 = spFact->CreateReal ("r",0.0);# O4 Q5 Z0 \# x
CATICkeParm_var spPp3 = spFact->CreateString ("s","");# N% F4 r; O2 v; I
CATICkeParm_var spPp4 = spFact->CreateBoolean ("b",CATCke::True);4 x. d8 k8 \# L5 G+ t) b
CATICkeParm_var spPp5 = spFact->CreateLength ("l",0);
5 k3 N; K' ^* q' D/ @$ Q& J, WCATICkeParm_var spPp6 = spFact->CreateAngle ("a",0);) f8 Q! C0 X8 g0 W7 M8 F% ^
2.将参数显示在结构树上5 K& ~/ S$ o$ Q
CATIPrtContainer_var spPrtCont = spContainer;' h8 J" h/ z* m# V# h
CATIParmPublisher_var spPubroot = spPrtCont->GetPart();
* O6 a/ q* n. H2 Y! X3 _CATICkeFunctionFactory_var fact = CATCkeGlobalFunctions::GetFunctionFactory();! }, n* O+ s! T
CATISpecObject_var spParameterSet = NULL_var;+ D' I# B2 }' i! g. o  k% v
spParameterSet=" M* I: t2 N/ k+ o
fact->GetCurrentSet(CATICkeFunctionFactory::Parameter,spPubroot,CATCke::True);
' ?  @" U' b, D7 I$ P8 z1 y! ?CATIParmPublisher_var spParmPublisher = spParameterSet;7 b3 \- q( Z# _4 t1 A. F% f* k$ U: J  K
spParmPublisher->Append(spPp1);
* K# \# W. Y8 j# }
* i" Y3 z9 T0 J$ {$ Q. d9 G: j& cspParmPublisher->Append(spPp2);
4 H# ]! d; d! C; m* kspParmPublisher->Append(spPp3);
$ U& p: y4 G7 k* ]- lspParmPublisher->Append(spPp4);
1 h' a1 M7 O9 I& q- y0 U2 Z. \. lspParmPublisher->Append(spPp5);
8 n7 k$ u! W, q' D+ b: |spParmPublisher->Append(spPp6);
5 o/ o. @$ A! L3 @+ V3.创建设计表
! C2 l' O" J* b6 T# WCATIDesignTable_var spDesignTable = spFact->CreateDesignTable();  q& ^: e- n! t# s. ]+ [" v7 v
4.将设计表显示在结构树上8 W) W. s) ]' d0 W  I' L2 R
CATISpecObject_var spRelationSet = fact ->GetCurrentSet(
5 d  c  z2 V  B- v& V7 VCATICkeFunctionFactory::Relation,spPubroot,CATCke::True);2 X. M6 \/ s$ L3 }# H
spParmPublisher = spRelationSet;
. o+ a! p3 r; N: P+ K5 _spParmPublisher->Append(spDesign);+ w) f; p, Q" n
5.将参数与设计表关联,注意参数名字与设计表的列参数名字一定要相同
# r2 u6 M" ^6 P: t7 q& d( B! b- I2 j// 参数列表
  ^  w, |- a  O: p+ Z% z/ ^4 }+ tCATLISTV(CATBaseUnknown_var) list;; v: P$ _8 H5 w% F
list.Append(spPp1);8 l' q6 X8 a- K
spDesign->AutomaticAssociations(spContainer, NULL_var, &list);
& Z; l) ~8 W; G. d9 }// 添加关联, S8 ^2 q: w! `, V' y+ o( ^0 L
spDesign->AddAssociation("Column2", spPp2);/ S" ?. Z1 k3 p6 z
spDesign->AddAssociation("Column3", spPp3);3 R* v4 S  i. [8 W# D8 x
spDesign->AddAssociation("Column4", spPp4);, C6 m) v0 [0 X8 ~) A9 k
spDesign->AddAssociation("Column5", spPp5);
! ]' G& Q" y  s- g$ v6.设置配置/ D" G7 K$ z$ H
spDesign->SetCurrentConfiguration(1);
6 ~, ~4 l2 C, F4 j
5 W  E  f: V% h* ^1 W4 A3 U9 W
发表于 2021-9-2 13:38:15 | 显示全部楼层
学习学习 ,后面希望自己也能学会
