tag_t part_tag=NULL_TAG;
$ z+ E+ W/ ?" mdouble originPoint[3]={0.0,0.0,0.0};
: w* O! p0 p+ A6 M7 R/ E7 u7 R/ echar* cyHeight="200";
+ x6 N$ _0 }# o8 a8 o ]char* cyDiam="60";
6 f8 [1 C" y" ?$ @2 g) K8 d& fdouble cyDirection[3]={0.0,0.0,1.0};
: W$ ^ y) k; S7 Y# jtag_t cy_tag=NULL_TAG;
4 r6 i# s$ w2 z. C1 t& B/ V% n$ R f
2 m$ |6 x! d+ gUF_CURVE_line_t lineCoords;$ O' x s. u3 o1 [% s3 N# X
tag_t lineTage=NULL_TAG;1 X) E' Y/ X* ^' E8 Y
double endPoint[3]={0.0,0.0,200.0};. i" R& q3 p6 G' }$ K+ @! I2 G
7 M8 D" \8 U# O7 `% _. ^3 Cchar msg[256];, A5 {" E; m, [+ T& O/ ^" g9 e
double lineStartPoint[3];
. ]5 V/ k) m9 ~& S( m, J7 i" ]double lineEndPoint[3];
) ?! [ O/ g. J0 J( O- C7 o% q3 J! ?2 a, z ]2 C/ N7 ?+ u
extern DllExport void ufusr( char *parm, int *returnCode, int rlen )9 W( P: e8 q& |4 y5 L: O2 g5 ?+ |
! _0 v1 D' Z3 U4 @+ T /* Initialize the API environment */8 K* H( P I3 w) q
if( UF_CALL(UF_initialize()) ) , A9 x* g; j3 Q5 J1 R
{( y! l& J! s; P; S# }
9 m# ]# N6 A" K& d2 F
/* Failed to initialize */# P' n2 Y' R( M- l
return;* |: Z7 P1 `) T( w% G; n n% ~
9 m: R& |* Y6 u% r. h8 H5 ?( C$ ]' b" G
$ @8 c( W: V; L e; D! [+ [9 f8 |; A/ r /* TODO: Add your application code here */* B: [& B$ n! J$ _5 y
UF_PART_new("D:\plmpart.prt",1,&part_tag);" ]- {. ?. F; G" G
UF_MODL_create_cyl1(UF_NULLSIGN,originPoint,cyHeight,cyDiam,cyDirection,&cy_tag);/ E1 r6 a, y! y: v( @7 T( E1 L
lineCoords.start_point[0]=originPoint[0];, s. y$ r3 k0 q1 ^" E( ^. @
lineCoords.start_point[1]=originPoint[1];6 Z7 A- r: N, a
lineCoords.start_point[2]=originPoint[2];
5 k; f/ n/ Y4 c, h! y6 ]- E
4 o) G5 K$ ?. R% Q4 I: b lineCoords.end_point[0]=endPoint[0];
6 D, _; x3 }5 @$ h/ D lineCoords.end_point[1]=endPoint[1];+ b! J( |9 J- M
lineCoords.end_point[2]=endPoint[2];
4 r8 L0 v j2 I8 J. m! M) F% y UF_CURVE_create_line(&lineCoords,&lineTage);
+ k( F4 U3 i+ I1 t; n UF_CURVE_ask_line_data(lineTage,&lineCoords);: Y) O! |4 B9 Y& d9 z
lineStartPoint[0]=lineCoords.start_point[0];
% w* b, K! `" l! E lineStartPoint[1]=lineCoords.start_point[1];, b% Z8 ?; u* w5 |
lineStartPoint[2]=lineCoords.start_point[2];
n3 {, z4 `: X- V lineEndPoint[0]=lineCoords.end_point[0];
1 [3 t" J. F; L2 a. ~( \ lineEndPoint[1]=lineCoords.end_point[1];, q* F& p( s# W4 v5 m
lineEndPoint[2]=lineCoords.end_point[2];" d& w' t+ v* I) S
sprintf(msg,"起始点:X:%f,Y:%f,Z:%f",lineStartPoint[0],lineStartPoint[1],lineStartPoint[2]);) e/ a r! |7 z: V/ w: j
uc1601(msg,1);
: @) H$ t! s2 _5 a- c- g sprintf(msg,"终点:X:%f,Y:%f,Z:%f",endPoint[0],endPoint[1],endPoint[2]);( V8 ]7 b- c! f0 j. J4 q
uc1601(msg,1);
2 ~# N' V1 A1 W: r% I UF_PART_save();4 d) y( \( X" m( N8 R6 m
UF_PART_close_all();
3 r4 R- ~" Z, J0 y /* Terminate the API environment */% ]& L/ I4 e- R" v
UF_CALL(UF_terminate());7 m: J: v/ B- C, W9 t
}2 j) U4 G; q2 r. H, Y
+ A4 |, b3 }" h
0 l, S8 L' S0 j9 q1 w, U9 l
( ^" K' N# d( ]1 a |
评分
查看全部评分
