[资料] CATIA二次开发入门教程---19 创建一条线
2017-12-22 11:06:27 3912 1
发表于 2017-12-22 11:05:33 | 显示全部楼层 |阅读模式
CATIA二次开发入门教程---19 创建一条线" F2 P8 ^% x6 c" V1 Q
; s# C( R* g! }, k- i
[mw_shl_code=c,true]/ J) r6 I$ }9 g$ l  X1 g; N3 _
        CATFrmEditor *pEditor = CATFrmEditor::GeTCurrentEditor();2 ~$ q7 a3 {% Z6 V$ Z, a; q
        CATDocument *pDoc = pEditor->GetDocument();
6 ^3 C, f" g# G- U: A4 [( {5 a  u# W% y        CATIContainerOfDocument_var spConOfDoc = pDoc;
7 t8 ]: ~  X, P% U        if (spConOfDoc == NULL_var)2 g( v$ ^% ~* A
        {$ H$ N2 b! Q% p/ c
                popUpNotifyDialog("No spConainer of document");
1 c' a$ ^- |" h8 t  H        }6 H1 P, v% g' |" O1 g: Z
        CATIContainer *pCon = NULL;
& }4 e. I  q# }9 P6 u* {6 L8 f3 |% }        HRESULT hr = spConOfDoc->GetSpecContainer(pCon);
9 U, g5 Y" d5 B3 [9 e" f+ t
9 H1 u  q# b* k* X( _/ C! Y        //get GSM factory3 _* u+ b0 b8 i; u
; f* a% L" {& g4 `
    CATMathPoint p1,p2;
5 D% n- Z; V" v$ z, \) v3 ^; D        p1.SetCoord(0,0,0);! o& B$ |; |/ f/ K$ e/ u% s/ T9 ?
        p2.SetCoord(10,10,10);
' k  _+ z2 K- J) l- T+ A        - y" x$ D. j- L+ y$ a: X0 h6 e2 m
! w; E, o3 n8 t* ~% x4 K
     CATIGSMFactory_var spGSMFactory = pCon;* i9 s) Z2 j- `& g- y: i) J7 |0 q
  & l6 W/ @  b. O" t% F9 K0 k% s
         CATIGSMPoint_var  spP1 = spGSMFactory->CreatePoint(p1,"");2 ^. P3 j+ [* t$ o/ M. r5 D
         CATIGSMPoint_var  spP2 = spGSMFactory->CreatePoint(p2,"");
& V& h, D+ Q; Z0 [) M" r
; E( [8 h6 E; h4 C# B& W  CATIGSMLinePtPt_var spLine =  spGSMFactory->CreateLine(spP1,spP2,NULL_var);
& x. e2 ~3 {. ?" W; l
' w$ C& _. ^% r) y7 v. E  CATISpecObject_var spSpecObject = spLine;8 u. i* d; @9 [& J
  CATIGSMProceduralView_var spGSMProceduralView = spSpecObject;
& l& f9 Q& X% C) E( f% c' E5 ^
6 D. T. W$ L+ n0 P* U( V" r  spGSMProceduralView->InsertInProceduralView();# w1 u9 f2 e/ c% N# v  u5 m
! f6 ^3 a. {/ s
  spSpecObject->Update();[/mw_shl_code]
 楼主| 发表于 2017-12-22 11:06:27 | 显示全部楼层
在此基础上,创建线的步骤如下:
1)创建两个点并将其转换为CATISpecObjects。
double Coords[3];
Coords[0] = 0;
Coords[1] = 0;
Coords[2] = 0;
CATIGSMPoint_var spPoint1 = spGSMFactory->CreatePoint(Coords); CATISpecObject_var spSpecPoint1 = spPoint1;
Coords[0] = 8;
Coords[1] = 6;
Coords[2] = 7;
CATIGSMPoint_var spPoint2 = spGSMFactory->CreatePoint(Coords);
CATISpecObject_var spSpecPoint2 = spPoint2;
2) 利用创建的点创建一条线,并将其转换为CATISpecObject
CATISpecObject_var  spSupport = NULL_var;
CATIGSMLinePtPt_var spLine1 = spGSMFactory->CreateLine(spSpecPoint1, spSpecPoint2, spSupport);
CATISpecObject_var spSpecLine1 = spLine1;
3) 更新创建的线,并将其添加到视图中。
spSpecLine1->Update();
CATIGSMProceduralView_var spCurObj = spLine1;
spCurObj->InsertInProceduralView();
* U0 \& z4 }4 W0 C
