[二次开发源码] NX二次开发源码分享:测量两个对象之间最短距离
2019-3-2 15:10:05 2264 0
发表于 2019-3-2 15:10:05 | 显示全部楼层 |阅读模式
% c: A3 A# o; K8 ]- R0 _) FNX二次开发源码分享:测量两个对象之间最短距离# E4 u: L2 f1 P- q. S9 \3 J) W) b. j7 X
5 e8 g" N& l2 X# \
[mw_shl_code=csharp,true] Dim theSession As Session = Session.GetSession()
) X3 t& ?# U: p' j) i! d5 O        Dim workPart As Part = theSession.Parts.Work
# i1 Y5 }7 y* c! f. \2 Y/ {& \9 A. L9 h0 |0 f
        Dim object1 As DisplayableObject = SelectAnObject("First Object")
  B( w# {( P* J# R, S        Dim object2 As DisplayableObject = SelectAnObject("Second Object")! }1 y+ k$ S  \7 ]+ C! z1 N9 v
/ V" P: u# K; g9 P2 m
) [: A, T- ^+ \; P
        Dim unitMM As Unit = CType(workPart.UniTCollection.FindObject("MilliMeter"), Unit)4 k2 T% F  l7 j( @# B
        Dim nullUnit As Unit = Nothing
! p9 r6 ~$ g% P) @# J8 w2 ?        Dim measureDistance1 As MeasureDistance
2 l0 W/ r8 z2 R& @* W3 K! V, Z" N  k) ]3 s: p. B/ M( L* n! E" x
        measureDistance1 = workPart.MeasureManager.NewDistance(nullUnit,  r( p  H7 n+ c0 E
            MeasureManager.MeasureType.Maximum, object1, object2)5 G) u2 a% O7 E  n* k
1 k( h! G& V8 r. s' @
        Dim theLW As ListingWindow = theSession.ListingWindow+ [7 r. P1 L' F7 [# M
        theLW.Open()
; a: Q7 h6 K/ u3 F9 X7 U        theLW.WriteLine("Maximum distance = " & measureDistance1.Value.ToString("F6"))
2 j( [- Z5 h) `3 y5 u
! P9 C) w5 l0 E" n  K2 H& {8 [
& Q! l$ x9 o# D        measureDistance1.Dispose()[/mw_shl_code]' c2 }& ^- \: x
