NX二次开发源码分享: 通过命令行的方式写外部命令的方法) i w; D& r7 b; `0 \5 C3 r
" L7 y }- f f对于批量并行运行的命令,可能需要用到调用exe的方式去处理,我们可以通过NX提供的开发函数,快速完成带有参数的命令行方式开发。3 [# p! r& d7 Q( I6 I# I- c' R
8 x* G' a% c8 m* juc4624/uc4620 是含有名称的方式比如 , helloplmhome.exe -p=xxx -u=xxx -g=xxx# s8 E A. x E+ Y) r, b0 _
uc4624/uc4621 是直接的方式,如果一个参数可以,多个的话不是太灵活,helloplmhome.ext xxx xxx xxx K5 f0 x I) `' K0 F
0 d* b6 X8 L' q
+ d( m$ m+ f8 |2 b4 V( ^[mw_shl_code=cpp,true]void ECHOUsage()
" K# D: F; v& y{
G$ O% |+ E8 w! C7 {3 @
( p5 n- ]1 v$ q& O# R# ], {2 p ECHO("Usage: exportAssemblyUtility [-part=<part path>]\t - Specify the input part \n");, ^( X0 t* o t2 g7 Z2 p2 G. d
ECHO("[-prefix=<prefix name>] \t - Specify the prefix name \n");: A2 m" v' P" H$ g H0 f
ECHO("[-postfix=<postfix name>] \t - Specify the postfix name \n");% N5 s' ~ M6 z5 S5 c3 I
ECHO("[-exportoption=<export option name>] \t - Specify the output option \n");( ?$ ^8 b4 F4 g
ECHO("[-exportfolder=<output folder name>] \t - Specify the export folder Path \n");
. N3 t5 V- M2 e3 ~, Q: Z ECHO("[-h=<help>] \t - print the help usage \n");; Y+ U1 ^7 b& w" h
ECHO("\n");
8 m0 j& M/ w& ^2 g& J& ^}* N) b- N- Y) w/ B0 d
, N, V" _" O5 {+ v" H3 Zint main( int argc, char *argv[] )* t) O: A- T* G( h
6 A* v/ a9 K( D, O5 S0 ^' m5 | tag_t part;2 N5 a# b6 @" x7 ]& T% P
char part_name[MAX_FSPEC_SIZE+1] = {0};
2 H- P- {( `/ v: e2 x7 Q2 x char prefix[MAX_FSPEC_SIZE+1] = {0};
- `* q8 {2 }0 G% j! {7 Z9 S char postfix[MAX_FSPEC_SIZE+1] = {0};4 Z3 `4 k1 N8 N2 b9 |! E' L
char exportOption[133] = {0};
% G# A! y4 a3 q' \% p# u" g) G7 A char exportPath[UF_CFI_MAX_PATH_NAME_SIZE] = {0};
( Y/ P/ y" B+ o) J: ~ char helpStr[] = {0};3 ?# [) o" I3 K' X2 F4 C2 |
logical
, |" |1 W% w, F nxmanager_mode;8 L6 o4 L$ m: O0 H& q$ Q* n. z
char msg[1024];- |4 \: J) Z3 T3 s4 _7 z" k
UF_PART_load_status_t/ y6 y% W0 K3 n F( X
status;
# ?$ @4 g$ K. _0 W9 l4 \* s" b8 |) c4 Z bool ispartok,isprefixok,ispostfixok,isoptionok,isfolderok = false;
. T/ F+ q3 Q+ D0 f* F/ d6 O$ t. ~/ c; F
if (!UF_CALL(UF_initialize()))
! Q% W: `( F7 Y6 I9 ~% e {7 b+ g# k( \% Q7 v
UF_CALL(uc4624(0, argc, argv));! L! G- ]6 w2 f$ ^. y
UF_CALL(UF_TEXT_init_native_lang_support());) g: ^, Y& |! [$ G9 ^0 a: n# _
UF_CALL(UF_is_UGmanager_active(&nxmanager_mode));4 B7 F- K* b1 P- Q: F
if (nxmanager_mode == true)
" F5 Z, v' S- x6 w {/ b: I1 e H5 A9 R! I. Y
ECHO("*** You are in NX Integration Environment ***\n ");
0 o2 a- j. z3 p. f% a2 l }
9 W! e' _7 P8 }5 U" @. L else
. L6 q( G7 a# R8 s4 _ {
! ^9 h# \3 w% X: w ECHO("*** You are in Local NX Environment ***\n ");) r3 l! M( D' }6 Z: I( g' [
2 q! }: ]7 m( s$ F
; q% l* z4 C( G8 H- ` " D& z- W# |# L- f. A4 i+ l6 R
/* for (int i = 0; i<argc;i++)) m* v3 P2 y- x2 g! |/ w* w! p
{ J# Q* q s ]$ y, I# x& M' l F
printf("argv[%d] = %s\n",i, argv);
4 e0 u1 z- @* Y0 t* u- ~$ }: p }*/5 o1 z- N6 L/ h+ {$ a+ h
/*uc4621(prefix) == 1 is OPTIONAL */& M( A. f# S e6 y( K1 ^" ^
* W8 b& w8 O& w. X1 F/ c/ o( {
5 ] D* u! q* T if (uc4620("part",part_name) == 3)
! N0 S0 J. k$ |( A2 ^. U- I {2 N3 z$ l% |4 J1 S5 h# y$ \% H
ispartok = true;
7 j4 d1 k4 |5 F& H }1 \ R% V. |# r( P$ I
if (uc4620("prefix",prefix) == 3)
7 g% X3 A# p# H {
! w! M- b* U O. ? isprefixok = true;
: Y2 o y5 f$ C) e9 I }$ w3 p6 w6 u* a7 Y: t% ~- x; ]
if (uc4620("postfix",postfix) == 3)
, v2 [! A/ J* r7 u! r {
! \8 \# Z! x" e' X ispostfixok = true;% ]4 i& F; W5 ]
}: a6 l2 B! S3 m% J* D( R
if (uc4620("exportfolder",exportPath) == 3)
1 Y6 ]) k0 n1 I3 M {
* L4 n3 R) A. v4 h" x. j isfolderok = true;
) s8 |0 q3 t/ N; U }
1 C u4 S0 c6 o( m. z5 c0 N if (uc4620("exportoption",exportOption) == 3)
2 ~2 e- T" X! ?6 D5 I {
# z/ H5 Z7 P8 U isoptionok = true;0 t3 a& F8 G' s- V: S( V* y9 B
( C0 C( a! R( e/ V/ `$ T if (uc4620("h",helpStr) != 0) ; |; r. @- b' } Q
{! D5 z# d- h s
ECHOUsage();
6 E* Z: x- B W, V& \4 X return 0;8 R9 H8 M. K2 g6 v+ O
( }7 q8 E5 x8 H1 h8 P6 _
0 y: h9 {5 \4 t' t m7 ]. J1 Q+ I, P" S: J# u {5 x" D& {
if ( ispartok == true ): t) ?1 n8 R, t! O: r, O w
{4 y8 |' O- w8 g, i
ECHO("===== The part exported and renamed as belows: =====\n ");# I9 Z/ ~9 E8 s# C6 g
// your code
5 T$ P' p B1 A
& T) g, O) f) h5 ]3 |}0 ?/ D) F; S7 l) R" `
" ?+ |( T) n5 ^1 R
[/mw_shl_code]5 x' f5 @* X- l7 g O: k! J2 N4 A
/ c" J7 I1 {# G1 |0 ~ |
