[资料] UG NX二次开发全部开发库,直接加入依赖项
2014-11-30 13:24:29 4535 0
发表于 2014-11-30 13:24:29 | 显示全部楼层 |阅读模式
; _" P7 h# }4 [% K( G' W
) ]: f2 M' g$ u# g& a8 \; t% P
" D4 R3 u7 J7 _
% K$ J6 g- b( E; _( u0 v8 h, Z通常我们加入 4个基础的,但是对于不同的模块开发,可能需要其他的,直接复制下面的内容,就全部ok了!& N# D1 Q4 v2 K8 {, n/ m
1 e/ f) c. |* @
二次开发全部开发库
二次开发全部开发库
$ J& g9 O6 d" O5 c8 B8 e- Z* R' X1 a0 |0 `# J  ]
8 c& m/ P2 G# X/ K9 y$ c. y
! l9 E7 [1 b4 H' x& E; R. J' P
. b1 U4 u8 R* R3 F libNXopencpp_motion.lib
1 B% `& d$ R1 l- b3 A8 e7 z" h" G- ] libvmathpp.lib
: P2 W4 A7 P7 g- j' B6 x; E9 k4 D- \ libugopenint_cae.lib% D4 u/ _4 h. Z: d, c6 b
libugopenint.lib; n8 n$ m! U% I9 d# C
libufun_cae.lib, P: T% j3 i/ P. a
libufun.lib
  U$ M) t. o9 v0 J1 @( Q% f libopenpp.lib$ O3 ^- F6 l: ^7 B
libnxopencpp.lib
" Y2 y: \, l$ `" \1 h& U libnxopencpp_annotations.lib( A/ w0 `% _$ }* q
libopenintpp.lib
3 f, V& J# C1 [1 g3 ^( C% w$ ]4 \ libnxopencpp_assemblies.lib. S5 l- _  l" ]
libnxopencpp_bodydes.lib
) H- C& x! ]8 r. d2 Q3 N libnxopencpp_cae.lib
1 |4 j4 u: p2 { libnxopencpp_cam.lib# u, i  C6 J& q* ?$ u1 [
libnxopencpp_die.lib
! d$ b3 R7 Y+ }! b libnxopenuicpp.lib8 n% A- _- }7 `$ R" E  y
libnxopencpp_display.lib; O4 C( F& m/ w/ `# L  K
libnxopencpp_weld.lib
$ I/ X& M3 S) K% v8 ]1 P libnxopencpp_visualreporting.lib
1 e0 C5 C& u% G5 r- I8 Z  }- H libnxopencpp_drafting.lib
' P/ ~# z6 j3 H+ K5 K& N libnxopencpp_drawings.lib
% y7 l4 z8 K' M libnxopencpp_facet.lib
, _: e8 d; ]. Y+ J1 q libnxopencpp_features.lib
1 P! ~+ @" C2 l, a) f) } libnxopencpp_fields.lib
8 E: P) \8 k; V1 g! S3 l; _ libnxopencpp_formboard.lib! W, g% T& m1 }" O" {
libnxopencpp_gateway.lib7 G+ S5 p) X+ ~, J  q
libnxopencpp_geometricanalysis.lib+ a# i& z# ?6 J! s
libnxopencpp_geometricutilities.lib
- w% h# L8 Z- W' Y% v libnxopencpp_issue.lib/ F7 h. @) Z0 D
libnxopencpp_layer.lib6 k, j4 r: Q; T: x8 Q
libnxopencpp_layout2d.lib
( P0 ^! L0 C1 I" O1 u0 c libnxopencpp_mechatronics.lib
& K8 ?0 X# ~* }3 u libnxopencpp_modldirect.lib5 }5 T( B( B8 Q' q8 |8 I) H" s6 _
libnxopencpp_validate.lib! E6 y" l8 Q! q3 Q
libnxopencpp_optimization.lib
+ ]; ^7 c$ |' N libnxopencpp_options.lib
  ?0 H+ i' P* n# D6 O$ r5 w2 v, a libnxopencpp_partfamily.lib
9 r, M6 Q+ D) ]. O) U7 y* d libnxopencpp_pdm.lib8 ]! D* W/ m/ k* H- V
libnxopencpp_physmat.lib
; ~# g. T; S  D2 h5 n& _9 y libnxopencpp_positioning.lib0 E  d& v- ]5 T( ^% K8 h- Q# Z
libnxopencpp_preferences.lib3 k9 I/ d% ?4 I" {) l0 j
libnxopencpp_routing.lib& Q1 t2 r) @9 @8 m
libnxopencpp_shapesearch.lib
; y% `1 l# a2 K+ a! A2 }2 S6 U- s libnxopencpp_sheetmetal.lib' k; R: _8 A  g  `3 s- X
libnxopencpp_userdefinedobjects.lib/ J6 V% M+ C" U; `" t
libnxopencpp_sim.lib
( D. Y* r# v6 o: @ libnxopencpp_tooling.lib, M' ?  {, b/ P# L0 J& g* Q
% Q1 [; V* L4 X' y6 f2 w$ j5 f- g9 e$ O0 u
' _& C4 G- V1 k1 O2 @
