[二次开发源码] NX二次开发源码分享:创建一个临时的prt文件
2018-3-4 09:15:06 2235 0
发表于 2018-3-4 09:15:06 | 显示全部楼层 |阅读模式
% _; ?% [: |' `3 r) ?/ J: Q
主要是一个函数在CFI的头文件下,创建随机文件名* \' n; b, a% }, m. h" I
* H" _' I; i# }. y3 s
. o2 O4 _8 o) Z1 O5 w
  P9 ?# }" a/ l4 O: p2 K
6 i5 [& W% I* ], n[mw_shl_code=c,true]Function CreateNewTemporaryPartQuietly() As Part
4 p* D. T3 Q2 l+ j    Dim theUFSession As UFSession = UFSession.GetUFSession()/ n2 [& O5 d" }3 B: C* j
    Dim NXMan As Boolean = Nothing
5 A" i) v, x/ _; |% E    theUFSession.UF.IsUGmanagerActive(nxMan)
4 h# {* g! ]' Z" P' ]- H* C# [. @! b  X6 e& D  f4 F* H# v& C; f
    Dim fileNew1 As FileNew = theSession.Parts.FileNew()( C  d, U" r& b9 F& A
    fileNew1.Application = FileNewApplication.Gateway& _* x, q2 i+ Q
    fileNew1.Units = theSession.Parts.Work.PartUnits( S, V1 k" u1 t
    Dim tpn As String = Nothing
' G% k& t3 H0 O4 O+ y    theUFSession.Cfi.GetUniqueFilename(tpn)* x" P" j. _0 V/ Q& W$ h! Z" H
    If (nxMan) Then% F: g% O  l- C" N3 j+ ]1 l
        fileNew1.NewFileName = "@DB/" & tpn & "/A"8 M' y2 C) }& t
    Else
8 s5 X, `/ n2 n& E  L: G9 `. K  Q        Dim tmp_dir As String = Nothing( m* R0 f  B" E4 ]
        theUFSession.UF.TranslateVariable("UGII_TMP_DIR", tmp_dir)9 l/ C7 L$ d  h( z" J! B/ J- @/ T
        fileNew1.NewFileName = tmp_dir & "\" & tpn9 y- h3 e# q# Z4 c. Y
    End If8 d: e8 K8 Q& L
    fileNew1.UseBlankTemplate = True
  s( Y6 u5 o0 i' J1 f  r8 B& ^2 m    fileNew1.MakeDisplayedPart = False
, u- G: }- K8 g% J* Q    CreateNewTemporaryPartQuietly = fileNew1.Commit()
) l7 N1 @& {2 P* L" P    fileNew1.Destroy()
) O% r' J7 {: a3 q( w8 Z
2 c/ j. j- \8 }End Function[/mw_shl_code]
1 j' m" e& |+ i; j2 R7 l5 a# e2 h9 S1 J
