" L' z7 Q+ w* G6 b
/ J* g1 K2 e, g B# ~[mw_shl_code=c,true]static int ask_all_drf_objects(tag_t **objects)
2 |' u0 N9 O2 L! D{
, Q! D. G+ s0 k+ G$ G2 z int
9 U$ l( i- `7 a% Z3 b& N, o subtype,' j, h' r5 B- ~( {+ C
type;
/ u# v% B8 |) f1 T& e tag_t
: I+ h* p; l# [7 H" y0 h' h- s% [5 K object = NULL_TAG;
. g8 u I8 d6 `# v/ p5 m uf_list_p_t
$ Q4 {- {9 v5 G, O# D1 \ M7 G3 F" d list;3 E: y. G- P" y6 @ y
4 |8 v( u0 n9 f+ e$ R6 Q# I1 ^ UF_CALL(UF_MODL_create_list(&list));
; w! g$ G4 r' S0 m8 [9 f+ p. q1 X2 J: D( d( B! H$ w5 D! d+ |, O
while (!UF_CALL(UF_LAYER_cycle_by_layer(0, &object)). l3 K k/ j, T% z7 H. z- J5 l: U
&& (object != NULL_TAG))8 P' I7 X8 a0 j, w
{! m1 i" i* |2 ?2 A
UF_CALL(UF_OBJ_ask_type_and_subtype(object, &type, &subtype));
' o+ l0 c+ @# w if ((type == UF_drafting_entity_type) ||( x8 d1 E; s: Y& I* ^
(type == UF_dimension_type) || J& {: r% A$ t8 D" r0 ?/ A
(type == UF_note_type) ||) j6 `, R& ?, S4 M
(type == UF_tol_feature_instance_type) ||& @0 v+ Z0 D9 c% [, @+ {8 R, ~
((type == UF_tabular_note_type) &&
6 n! D, q( V/ a9 S (subtype == UF_tabular_note_section_subtype)) ||0 D" N, i2 K/ H: l+ T+ m4 C
(type == UF_smart_model_instance_type) ||! w/ s9 d; `" V: E# i. t2 Z3 Z
(type == UF_pmi_filter_type)): V* ]7 Q4 z& t9 E; w
UF_CALL(UF_MODL_put_list_item(list, object));
7 q1 ]4 ?- Y( }& K3 c; w! A# {# n9 W }
1 i* }0 `' K2 `* a4 ?5 e
, c. @# t, z& v, @. b0 B7 z- s/ r return make_an_array(&list, objects);! H7 q' D( ^$ D8 }9 W5 X G- P
3 r& J4 x) @, @( d6 @# n# ^[/mw_shl_code]- R# g: P9 l8 n- t, i
