, \) c4 j0 Q0 `4 J9 v
( V* s. L( q, N" k+ W) w! \其实主要是Note的类型的定义问题,参考代码如下:
S' y7 w& [: O. i; z$ V+ l8 z9 Z% w5 [# \; v- O2 S
* V: d4 A7 @8 k n
Private Function selectNotes(ByVal prompt As String) As Annotations.Note()
; _! O+ E2 ]5 H# r8 n7 q Dim mask(0) As Selection.MaskTriple7 U9 \5 L( d: _! r& h; s6 X
With mask(0)
, A, c ?5 c8 g; d .Type = UFConstants.UF_drafting_entity_type% J0 `1 r" Z, R+ L
.Subtype = UFConstants.UF_draft_note_subtype; a6 F: E1 x# Y; l
.SolidBodySubtype = 0
/ u0 P" J! R* p) Q! f+ Z End With6 S9 z1 C2 L% e" I# f2 F
Dim cursor As Point3d = Nothing
T. \; z) U+ o4 p2 { Dim theObjects() As TaggedObject = Nothing- v% B, B, m- }
8 n" ] m9 n1 ]7 X% r; a n: p# r7 m- o UI.GetUI().SelectionManager.SelectTaggedObjects("Select Notes", prompt, _' \ \: q5 h. V( ~, E% Z4 w* H
Selection.SelectionScope.AnyInAssembly, _5 ?+ N+ l6 q& j
Selection.SelectionAction.ClearAndEnableSpecific, _ c9 W' J" {1 B/ m- j
False, False, mask, theObjects): ]; C8 i, c4 a
) h5 [& T8 Q# B* ?9 s Dim theNotes(theObjects.Length - 1) As Annotations.Note
+ T5 j0 Z' s6 ~) Z- B For ii As Integer = 0 To theObjects.Length - 1" [! h1 c2 t# p- b7 W3 [2 g9 M
theNotes(ii) = CType(theObjects(ii), Annotations.Note)8 c1 d6 ^$ a5 o! K4 S2 a
Next
a' k% I$ s. b/ X2 `
& K# C5 p8 s6 I, i% c; v Return theNotes! h4 R9 N0 K! R4 Y) a. x4 V
8 ]4 j; X' ^8 f End Function9 T9 {; i/ r K. ~
. W" A' Q9 a( N( u1 N' K |
