[资料] UG NX二次开发常用的函数模版--还不错分享下
2015-3-2 10:12:14 3710 0
发表于 2015-3-2 10:12:14 | 显示全部楼层 |阅读模式
1,   uc1600   //获取字符串
头文件:#include <uf_ui.h>
int res = 0;
            int len = 0;
            char string[100]="";
            res = uc1600( "",string , &len );//string:Input / Output
            if ( res == 5 || ( res== 3 && len > 0 ) )
            else
2, uc1603  //
用法1:
          char title [100] ="菜单";
            char items [3] [ 38 ] = { "选项1","选项2","选项3"};
            choice = uc1603(title, 0, items, 3);
            if (choice == 1 || choice == 2)
                  UF_terminate();
            else
                  if (choice == )
. E/ U5 \; E6 P' I7 J* ^
file:///C:/Users/sztl26/AppData/Local/Temp/msohtmlclip1/01/clip_image001.gif
) F- b/ j& z; n% b+ c8 l  ~7 ^* G; W) ~
( V, K0 @" t. Z
用法2:
            response = uc1603( "菜单",0, items, 3 );
            swiTCh ( response )
            case 1:
            case 2:
                  break;
            case 4:
            case 5:
3,选择对话框头文件
头文件1: init_proc_face
static intinit_proc_face( UF_UI_selection_p_t select, void* user_data )
         int nums = 1;
         UF_UI_mask_t masks[] ={
               UF_solid_type,0, UF_UI_SEL_FEATURE_ANY_FACE};
               if((UF_UI_set_sel_mask(select,
                     UF_UI_SEL_MASK_CLEAR_AND_ENABLE_SPECIFIC,
                     nums,masks)) == 0)
                     return(UF_UI_SEL_SUCCESS);
               else
                     return(UF_UI_SEL_FAILURE);
头文件2: init_proc_body
file:///C:/Users/sztl26/AppData/Local/Temp/msohtmlclip1/01/clip_image001.gifstaticint init_proc_body(UF_UI_selection_p_t select, void* user_data)
    int num_triples = 1;
    UF_UI_mask_t mask_triples[] = {UF_solid_type, 0, UF_UI_SEL_FEATURE_BODY};
    /* enable only lines and edges */
    if((UF_CALL(UF_UI_set_sel_mask(select,
            num_triples, mask_triples))) == 0)
        return (UF_UI_SEL_SUCCESS);
    else
        return (UF_UI_SEL_FAILURE);
4,UF_UI_select_with_single_dialog
          char     title[]="";
            char     cue[] ="";
            int     response=0;
            double   cursor[3];
            tag_t    face =NULL;
            tag_t    view =NULL;
         if(!UF_CALL(UF_UI_select_with_single_dialog(cue, title, UF_UI_SEL_SCOPE_NO_CHANGE,      init_proc_face,NULL,
                  &response,&face,cursor ,&view)))
                  if (response == UF_UI_OBJECT_SELECTED ||
                        response == UF_UI_OBJECT_SELECTED_BY_NAME)
                        printf("object tag = %d\n", face);
                  UF_DISP_set_highlight(face, 0);//关高亮
5,UF_UI_select_with_class_dialog
, z. [8 i! i. `) T6 l
0 m3 A6 f. L# I; R: F  o7 e
3 \6 i6 K/ ^5 y6 q3 G- r; w8 y6 B
void class_sel_dlg(int*count,tag_p_t *objects)
      char cue[] = "";
            char title[] = "";
            int response, sel_count, i;
            tag_p_t sel_objects;
            if((UF_CALL(UF_UI_select_with_class_dialog(
                  init_proc_face, NULL, &response,&sel_count, &sel_objects))) == 0)
                  printf("object count = %d\n",sel_count);
                  if (response == UF_UI_OK && sel_count >0)
                        *objects=sel_objects;
                        *count=sel_count;
                        for (i=0; i<sel_count; i++)
                              printf("object tag = %d\n",sel_objects);
                              UF_DISP_set_highlight(sel_objects,0);
                        UF_free(objects);
6,UF_MODL_delete_object_parms//消参
头文件:
#include< uf_modl.h>
#include< uf_modl_utilities.h >
uf_list_p_t obj_list;
            UF_CALL(UF_MODL_create_list(&obj_list));
            UF_CALL(UF_MODL_put_list_item(obj_list, ));
            UF_MODL_delete_object_parms(obj_list);
            UF_MODL_delete_list(&obj_list);
7,UF_CURVE_create_arc//通过圆心,半径画圆
头文件:
#include< uf_csys.h>
#include< uf_curve.h>
      tag_t  arc, wcs_tag;
      UF_CSYS_ask_wcs(&wcs_tag);
      UF_CURVE_arc_t arc_coords;
      UF_CSYS_ask_matrix_of_object(wcs_tag,&wcs_tag);
      arc_coords.matrix_tag=wcs_tag;
      arc_coords.start_angle = 0.0;
      arc_coords.end_angle =360.0 * DEGRA;
      arc_coords.arc_center[0] = center[0];//
      arc_coords.arc_center[1] = center[1];//
      arc_coords.arc_center[2] = center[2];//
      arc_coords.radius = 500;
  UF_CURVE_create_arc(&arc_coords,&arc_id);
8,UF_OBJ_set_name(tag,name); //设置名字
头文件#include <uf_obj.h>
9,name开关
       intname_status ;
            UF_DISP_ask_name_display_status(&name_status);
            if (name_status==UF_DISP_NAME_DISPLAY_OFF )
                  name_status=UF_DISP_NAME_DISPLAY_ON;
            else
                  name_status=UF_DISP_NAME_DISPLAY_OFF;
            UF_DISP_set_name_display_status(name_status);
11,UF_OBJ_set_layer (tag,layer); //设置层
12,UF_CALL
头文件#include <uf.h>
int UF_CALL ( interrorCode )
      if ( errorCode )
            char message [133] = "";
            UF_get_fail_message( errorCode, message );
            uc1601 ( message, 1);
      return (errorCode);
13, UF_PART_ask_display_part
头文件#include <uf_part.h>
tag_t part = UF_PART_ask_display_part( );
            if ( NULL == part )
                  uc1601( "", 1 );
                  return;
14, UF_OPER_create
头文件#include <uf_oper.h>
tag_t Oper_id = NULL;
UF_OPER_create( "mill_contour", "ZLEVEL_PROFILE_YBC", &GZM_Oper_id );
15,UF_MODL_ask_face_data//查询面的信息
tag_t face;//面的ID
      int  type;  //面的类型
    double box[6];//x,y,z向最大,最小值
      double radius;
      double rad_data;
      int  norm_dir ;//法向
      UF_MODL_ask_face_data(face,&type,center,
            dir,box,&radius,&rad_data,&norm_dir);
16,UF_MODL_ask_minimum_dist_2//查询两物体间距离
doubledis,accuracy;// accuracy:准确度
double point1[3 ]={0};
double point2[3 ]={0};
UF_CALL(UF_MODL_ask_minimum_dist_2 ( obj1, obj2, 0, NULL, 0, NULL,
                       & dis, point1, point1,&accuracy ));
; }; J2 N/ ?" o2 l. R
