1,查找刀具属性" i! G2 @% w7 D0 e- O
tag_t tool_id=NULL;5 E$ J! }5 M' ^ V$ y2 h' n
double tool_diam=0;* ~7 `0 A! j" k) [! V [
UF_OPER_ask_cutter_group(oper_tag,&tool_id);
5 Z$ R/ ~4 U9 d
0 a" S' {0 r, O7 [4 DUF_PARAM_ask_double_value(tool_id,UF_PARAM_TL_DIAMETER,&tool_diam);//查找直径 F- \) a' P# w: ~
1 T! h* E+ R9 H! P) b3 ^char tool_text[133];
. J9 ~: r% J5 E6 e: j% Schar ch_s[10]="", ch_f[10]="",*ch_p=NULL;
& w# a! B5 H9 ]# _double tool_s=0 ,tool_f=0;//主轴转速,进给: d3 Q9 z2 w% P! a) m% |
% C+ _; ?! z- l/ z0 Z. y# @+ x
5 \, L/ i+ t9 j+ m2 j$ [if(UF_CALL(UF_PARAM_ask_str_value(tool_id,1158,tool_text))==0)//属性文本# A2 s1 t4 r$ v! ]+ `! x
{ , i1 ~6 N3 U1 o3 g% R( z
ch_p=strstr(tool_text,"S=");
# v0 K0 C" m" [( d
# n' s5 ?; V* ?$ @) N8 M if (ch_p!=NULL)- D2 T+ S7 s: s) v! K; O
{0 P3 B/ @' D% A* v j3 Q6 k9 c
int i=0;8 Y) |* I! g& H1 v& c% w
ch_p=ch_p+2;
+ _3 V/ t+ r. Q9 W# ?& Q while((48<=*ch_p&&*ch_p<=57)||46==*ch_p)//当指针指向为数字或者小数点9 H, u) d# F# s
{ o( o# k; m7 ?2 B6 x. v
ch_s[i]=*ch_p;5 ` Q! k+ P5 B& [ e
i++;
$ w( b" G5 `6 n! F- t7 C8 i; e ch_p++;, x* }6 v' B/ a8 f9 O* @+ e3 g7 G) q
}( S* p8 }; J R6 B% H6 ~, C P% ]
, S3 `4 T# x1 g- A9 f ch_s[i]='\0';8 R6 C4 i/ M) l/ z, p* Q
if(i!=0)
: D# t1 w3 e* {1 I4 I {4 ~: w6 Y* |7 V( p5 h
tool_s=atof(ch_s);) L9 C! F% A0 {# k
}$ J5 C q7 I8 O) s5 G: v
// uc1601(ch_s,1);' ^; h, W2 x* q
5 B$ Q2 r$ q9 y& f/ L$ p6 c$ _
5 z# W W; R. l ch_p=NULL;1 y$ B$ G" p; i( F7 r
ch_p=strstr(tool_text,"F=");& ~ e9 l2 _7 a% h. i( p5 f
( n2 J0 ]* J/ R* d5 w* c if (ch_p!=NULL)0 Y9 y) h, N3 r6 T8 P
7 z! S. q) t( n6 S/ q int i=0;9 ]$ |' U, k5 |) @) i" K* Y
ch_p=ch_p+2;, q. K1 p4 B! A: M ~; |2 _# K
while((48<=*ch_p&&*ch_p<=57)||46==*ch_p)//当指针指向为数字或者小数点; G+ u0 [" Y! c% ]; }0 a% X
$ @: p" p. m% h3 Y7 }* w" ~
{1 `# |: l+ D8 Y# v
ch_f[i]=*ch_p;7 Q5 A: I0 |# l9 I% @' q
i++;/ }1 B. m2 Y' N5 U. t
ch_p++;! v- j* i$ o- u- I3 n: k; u, N, A
}, j2 {' v- l5 e6 }; O3 F
ch_f[i]='\0';
: ^$ l7 b6 b' o* l* R if(i!=0)# V1 q) m8 m; ?1 A& F0 f
1 J9 `3 ^. E0 S- [* y7 e" k7 c tool_f=atof(ch_f);
0 J* e" L% ~: H$ z) a2 B7 i }3 c- h" t) B) l6 W8 f/ W7 n
// uc1601(ch_f,1);+ L% b; _; J1 ^" a2 @! C1 ?
}- p$ n d. ?8 P, u( _4 f9 P
/ h$ a! ]9 H6 v+ o9 V \
: s2 s$ Z( k+ a$ [! O2 N$ [- Y1 g' M9 S0 M7 d. Z
2, , F' f; g0 { n. f" I& d9 g
//主轴开/ D0 f% C. Z/ Z. ^7 A! }. y
UF_PATH_spindle_on_t spindle_data;
4 ~( `5 ^* p9 r9 S8 ~" r, qspindle_data.speed = tool_s;
" ~/ Y. z# e: q G( |spindle_data.maxrpm = 10000.0;/ ^# e! a9 M' ]( Y$ U. U
spindle_data.mode = UF_PATH_SPINDLE_MODE_RPM;
% L$ O' E% o& ~4 ?spindle_data.direction = UF_PATH_DIRECTION_CLOCKWISE;
5 l5 N4 k0 S* ^. nspindle_data.speed_flag = TRUE;; h5 m! o: e$ }
spindle_data.maxrpm_flag = TRUE;7 g% ]" @' h' x
spindle_data.range_flag = FALSE;
- h5 i: m: A" uUF_PATH_create_spindle_on( path_id, &spindle_data, NULL );+ i$ s! f( T' a( l' B# Y
//主轴关& q w3 a0 ]% ]& Y& _% e* i* }
UF_PATH_create_spindle_off( path_id, NULL );
~; Q: ], F+ E3 i, [$ x* R1 ~+ j5 z4 e: r
+ i" B6 i$ i: N5 O
3,//打开刀具补偿
9 e* m+ B" {# b: HUF_PATH_cuTCom_t cutcom_data;
% q" g2 q, ]/ W% b: r8 }cutcom_data.cutcom_mode = UF_PATH_CUTCOM_LEFT;4 ^+ Z3 e2 d' f
cutcom_data.plane_type = UF_PATH_PLANE_TYPE_NONE;
( |3 A4 T x2 _2 Y( I$ @$ K7 vcutcom_data.cutcom_on_status = UF_PATH_CUTCOM_ON_BEFORE_ENGAGE;
; ` R% }# @2 t& b2 Scutcom_data.cutcom_off_status = UF_PATH_CUTCOM_OFF_AFTER_RETRACT;
5 n/ a4 U- M% l8 ~$ d4 H [cutcom_data.adjust_register = 1;
+ \/ C- |5 |- U' N& b( d# Qcutcom_data.full_cutcom_output = TRUE;
) c5 k5 K" U, x% V, G0 Icutcom_data.adjust_flag = TRUE;* [0 e0 `6 h- g3 A
UF_PATH_create_cutcom( path_id, &cutcom_data, NULL );
3 c8 f2 k7 C; a7 v$ o
8 q% J/ e) e& ]. n j" s! g//关闭刀具补偿# O7 f1 i, B3 t( c, \1 m2 @: c* G" e
cutcom_data.cutcom_mode = UF_PATH_CUTCOM_OFF;
- [/ O' {$ e% K7 [UF_PATH_create_cutcom( path_id, &cutcom_data, NULL );
3 i% U# ?7 p$ o, ^+ I2 P: Y9 V. e% n# f+ }* Z) N
" i! a1 @# |5 L# ^0 u
