[求助] 螺杆的螺纹代码始终不对,求大神帮忙
2015-7-13 14:59:43 2967 1
发表于 2015-7-13 12:28:41 | 显示全部楼层 |阅读模式
#include <stdlib.h>( I" k: G: Y" C0 x/ g9 N4 W
#include <uf.h>; o' C% |6 f  Z7 g5 f5 A
#include <uf_part.h>/ P. Y7 }+ M4 L% y) [
#include <uf_modl.h>
9 n" S- ^6 s4 t1 f( }' s: g0 l#include <uf_view.h>. n. p, e9 Y9 s0 A8 y9 c
#include <uf_layer.h>; M4 t  s7 O4 ^* f, u* r
#include <uf_obj.h>+ W  Y+ N" a' g9 f! e4 S% H8 X
//#include <uf_modl_types>8 `$ `6 ?( a: Y. D. K' c
) P1 M+ r# K. i1 u* t9 ~; R/ iextern void ufusr( char * param, int * reTCod, int param_len )
6 i6 f0 [; Y8 E1 \{
5 P( G. r1 i/ n. U8 e3 u7 ~& A/ k' O" E0 A, B# V# Y
        " T4 X; Z9 e  r. F9 D( `
if (!UF_initialize())$ l+ g4 h$ q* K; r
* c( N6 d: \/ \2 z        UF_FEATURE_SIGN sign = UF_NULLSIGN;' v1 G2 t' ]+ I7 ^/ h
        double cyl_orig[3] = {0.0,7.5,0.0};; K% u; Y  B- R# B7 o: C! Y
        char *cyl_height="26";2 ], g6 M' R* N1 O7 H- N! W
        char *cyl_diam="18";" G) Z2 C4 E; F" a7 o0 j9 e
        double direction[3]={0,0,-1}; * ^1 G, R& w3 u5 E2 [
    tag_t cyl_obj;+ S' t, m8 A5 g. K; r* w' e
$ f6 q. v0 X. e' E' o2 b        //圆柱1的变量声明区  @7 y6 V$ ]9 u" }9 I! X: G; G0 ?
- g: ^' |7 z/ d! h, a        double block_orig[3] = {-7.5,0.0,-26.0};, a) d$ ]  g' c" W3 x7 k; w) M4 V
        char *block_len[3] = {"15","15","26"};
( Z0 d; t' \8 ]# G3 n    tag_t blk_obj;
0 D/ F4 z$ f3 |. V$ d        //块的变量声明区
0 f+ m' b2 ]% J0 b1 e) [0 k' S" {) |/ V) {0 `5 \! M, O/ g
   double cyl_orig1[3] = {0,7.5,-26.0};
" }" _9 ^. @( g3 z        char *cyl_height1="8";
1 u; h; M0 Z2 F        char *cyl_diam1="18";( z( _; T. d: i" r
        double direction1[3]={0,0,-1};9 ?& U  v2 e8 p9 ?$ r0 q
        tag_t cyl_obj1;
! U4 t% j( @% s5 }5 V. w8 Q        //圆柱2的变量声明区
. g7 ?* R& h1 X
7 ]3 u- }! E7 y+ R- d, `3 _* x        double cyl_orig2[3] = {0,7.5,-34.0};
2 G' {, q8 Z4 N$ _        char *cyl_height2="12";
* R$ D" u8 c5 d! A1 S; w6 K        char *cyl_diam2="22";
+ J0 [$ j- v) E& k# S6 l$ [        double direction2[3]={0,0,-1};  \% F9 t- S+ f6 V: I
        tag_t cyl_obj2;: a: S+ E7 w# O: \% v9 I" K
        //圆柱3的变量声明区
# g* L4 g* r- m  `0 j/ _7 ?) E) ?1 d4 h* e  M) a
        double cyl_orig3[3] = {0,7.5,-46.0};5 n' n$ ^% k  I8 Z5 T/ _3 k
        char *cyl_height3="32";! z. }  s; h. I0 {8 U' a- n1 }% ^, Y* ]
        char *cyl_diam3="18";
: B4 {& k, W# H) Q1 ?6 U        double direction3[3]={0,0,-1};
5 f! z8 v; H! k  |        tag_t cyl_obj3;
5 t. q; T! e( n* k        //圆柱4的变量声明区
$ A& \6 o+ z. I8 F! J; d        5 N$ k' y% O+ Y) ^. [# h* P
        double cyl_orig4[3] = {0,7.5,-78.0};
6 j4 w$ T- u' T$ o8 g5 q" t        char *cyl_height4="7";
2 p/ U* L8 e7 a, F6 \        char *cyl_diam4="14";
3 {/ m  R5 g8 R( C# j1 j* e6 j2 }        double direction4[3]={0,0,-1};
3 V; C. e3 b# }/ H9 u3 `. K" _        tag_t cyl_obj4;
1 J, L5 _# X1 O9 @& Z0 q        //圆柱5的变量声明区
/ n0 ]; ^! d% E8 ~+ s/ |# w4 L- @0 R. j# }1 k( a- l& R2 \7 C$ F5 I
        double cyl_orig5[3] = {0,7.5,-85.0};) [" Z! Z2 _: s/ t
        char *cyl_height5="95";
. Q8 t( P& {7 a. J- |        char *cyl_diam5="18";
- H+ {) A+ L- C% g. [- {        double direction5[3]={0,0,-1};
, o7 M' ]2 z  H0 e        tag_t cyl_obj5;
; r9 u) o0 i" f/ J( ]. c. q        //圆柱6的变量声明区
: Q$ g) ~/ z7 w8 m) O9 M4 ~, v9 k/ n6 k
- ?8 N, Y! H) p& d
) k2 |4 Y/ j6 [4 _; c! g6 `6 v: u        double cyl_orig6[3] = {0,7.5,-180.0};
- \+ W, ^' C* d/ q        char *cyl_height6="18";# I8 P9 g3 E$ E' e$ @, z
        char *cyl_diam6="12";  j9 C; g9 \5 |6 R. n( [+ i+ T$ h
        double direction6[3]={0,0,-1};
5 e  Q0 ~% u  t, _! {8 b        tag_t cyl_obj6;. e% T) X( c" J* r# r
        //圆柱7的变量声明区+ g5 R+ l8 o/ ^9 U8 P( X8 D
, v8 Q9 @( Y$ |) l6 @4 @$ H        double cyl_orig7[3] = {0,7.5,-198.0};
  c; s* X0 u8 J7 d, j) ]        char *cyl_height7="20";7 ?) E) b# |$ ^9 {  K' L, }  u) E
        char *cyl_diam7="10";
6 b! ]- i9 e- P: ~        double direction7[3]={0,0,-1};
6 ]# |; ^( ]* D3 h% ]        tag_t cyl_obj7;
8 y) {0 A% a3 r        //圆柱8的变量声明区
9 w4 u. ~4 x) Q" M) ~9 U" e
( ~% w+ j, [9 G% n) h# C        double cyl_orig8[3] = {0,2.5,-210.0};1 P. [8 g0 @% k: a& @
        char *cyl_height8="20";
- \9 [0 D( \* O+ n: \        char *cyl_diam8="3";8 l+ |6 [" X% H
        double direction8[3]={0,1,0};8 j# m. `: y+ D/ p# L
        tag_t cyl_obj8;* {0 M, i5 Z6 H2 D: L: D, K
        //孔的变量声明区' G! L2 j, q3 B/ x
" B/ V9 e% y* `( d' X; \+ t' {5 m    tag_t gasket_cyl_obj,gasket_blk_obj;$ G; @% U* Q! U% I0 r" t
        //创建圆柱的: u9 n, [2 d$ {  s& S) K  D
" ~! Z; I, r1 |3 k  d; _* }: X5 e        UF_MODL_create_cyl1(sign, cyl_orig, cyl_height,cyl_diam,direction, &cyl_obj);
2 _- m) J. ~2 ~  F9 ~2 P6 d        UF_MODL_create_block1(sign,block_orig,block_len,&blk_obj);
7 ]+ s: c% k( s7 L; A3 k        UF_MODL_create_cyl1(sign, cyl_orig1, cyl_height1,cyl_diam1,direction1, &cyl_obj1);) l, W6 c/ N* {1 n+ ]' t2 \8 S
        UF_MODL_create_cyl1(sign, cyl_orig2, cyl_height2,cyl_diam2,direction2, &cyl_obj2);
7 T8 l9 q7 x: |. y7 `5 N1 Z        UF_MODL_create_cyl1(sign, cyl_orig3, cyl_height3,cyl_diam3,direction3, &cyl_obj3);
) i* a1 \  n- d0 h  v2 T, Q        UF_MODL_create_cyl1(sign, cyl_orig4, cyl_height4,cyl_diam4,direction4, &cyl_obj4);
) J, V7 D) \/ N7 L        UF_MODL_create_cyl1(sign, cyl_orig5, cyl_height5,cyl_diam5,direction5, &cyl_obj5);
$ d( }# v1 q* {8 T1 }        UF_MODL_create_cyl1(sign, cyl_orig6, cyl_height6,cyl_diam6,direction6, &cyl_obj6);; h  P+ o. T* ^' T. H" U
        UF_MODL_create_cyl1(sign, cyl_orig7, cyl_height7,cyl_diam7,direction7, &cyl_obj7);
. Z' |6 J, c5 C  m        UF_MODL_create_cyl1(sign, cyl_orig8, cyl_height8,cyl_diam8,direction8, &cyl_obj8);
+ O" w7 L" b' H3 k) |& [
! q* w/ W& |. q- y) a' @        //圆柱和块的建模函数
0 s4 Z- p- B# }, g0 F3 H, E% e; e5 A! y7 \
9 l8 T2 n# L4 }        tag_t cylinder, block,*resulting_bodies = NULL;
. {  v. @; ?9 W8 t- E& l9 u        int num_results;" [; I" f2 V( [  Y9 I- t$ @
        UF_MODL_ask_feat_body(cyl_obj,&cylinder);//目标体
3 p/ z  ^6 ]2 |7 e( i        UF_MODL_ask_feat_body(blk_obj,&block);//工具体
6 n& R( |) j& A5 u8 G8 A        UF_MODL_intersect_bodies(block,cylinder,&num_results,&resulting_bodies);
1 U+ V6 c: c# J        //圆柱和块求交/ z4 `" o2 @- W# t+ |( d2 f
( l' b& a& Z0 Y! `9 S. u  v
        tag_t cylinder7, cylinder8;
* ^  b. J  a0 U5 h5 B3 E        /*int num_results;*/3 d; V0 c5 S# \2 z6 T! t8 E# m6 ^
        UF_MODL_ask_feat_body(cyl_obj7,&cylinder7);
, X4 d2 x7 t9 K4 E& c0 }) o' q        UF_MODL_ask_feat_body(cyl_obj8,&cylinder8);3 Y; ?0 E! V% m" O1 K
        UF_MODL_subtract_bodies(cylinder7,cylinder8,&num_results,&resulting_bodies);
( \+ d6 K# c. q* K" [( M% S) P, D' {        //圆柱求差,打孔/ w2 U; O/ D+ X- N% o
) [* ^' k6 s& T9 I. R
        tag_t cylinder9, cylinder1;" P! H- I3 w. M/ ^: R2 O
        UF_MODL_ask_feat_body(cyl_obj,&cylinder9);7 l7 X- n7 ?4 u
        UF_MODL_ask_feat_body(cyl_obj1,&cylinder1);/ W' B* L; a! P1 y% _+ R
        UF_MODL_unite_bodies(cylinder1,cylinder9);: r, s* I( G9 n, D1 G2 w8 ~; r
        //圆柱求和' x5 u3 p& g$ _" L5 z
' j2 d) g* S# p" n    tag_t cylinder2, cylinder3;
9 j9 q0 ]6 ?, ]. B% ]# E  W9 R6 X        UF_MODL_ask_feat_body(cyl_obj2,&cylinder3);1 v7 p5 D! M) B# H
        UF_MODL_ask_feat_body(cyl_obj1,&cylinder2);
" D2 h& E5 ^( Q; c3 L8 n. f        UF_MODL_unite_bodies(cylinder2,cylinder3);
- i4 ~0 }/ Q/ e. @( k6 S. h
' x! j" G$ A9 ?; L    tag_t cylinder4, cylinder5;
/ L$ W' e* o* ^7 |! [- H        UF_MODL_ask_feat_body(cyl_obj4,&cylinder5);& k7 ^9 W; }; D& R$ Y1 J
        UF_MODL_ask_feat_body(cyl_obj3,&cylinder4);8 E( i+ g( m7 y
        UF_MODL_unite_bodies(cylinder4,cylinder5);& h. b1 W5 o% Q4 U  r1 p
, m8 X& X" J0 }9 }1 g/ q5 J
    }  i9 c7 Y1 G0 b4 _
: C4 S- E0 U; i7 o已经做出螺杆,螺纹不会,求教大神  n! u0 {2 y/ i) B3 [' w1 E
3 A! e$ }2 t' y7 j/ u: v- m
发表于 2015-7-13 14:59:43 | 显示全部楼层
UF_Modl_craete_symb_thread看这个函数,有例子的啊
