[求助] uf_ui_select_with_class_dialog 对话框有时候弹不出来
2016-1-4 17:13:38 3003 0
发表于 2016-1-4 17:13:38 | 显示全部楼层 |阅读模式
  1. int selectSingle(int user_data,int *num, tag_p_t *object)
    ' |, R' q- W; c+ D
  2. {
    ' K* y4 w* Z- e* ?* u! z" R0 }$ v( T
  3.   v; ^3 H+ {0 x) O  X/ K) z
  4.         int num_obj = 0;) |+ C6 t+ j3 S7 S! k
  5.         tag_p_t obj_sel = nullptr;# z' p2 I1 D- J; w+ I$ ]- |) h6 u( _
  6.         UF_UI_ask_global_sel_object_list(&num_obj,&obj_sel);4 {8 i3 H- ?+ h0 P6 u4 J
  7.         if (num_obj > 0)
    ( V7 }( a2 w* w* [
  8.         {
    , {! Z# _$ |1 [2 N+ A
  9.                 //UF_DISP_set_highlights(num_obj,obj_sel,0);
    , u7 t/ @3 ^( F# I/ C/ L
  10.                 for(int i = 0; i < num_obj; i++)
    - U4 A5 C: R) G
  11.                 {
    ; m: d! O" _8 h7 K$ C- Y7 B4 K
  12.                         UF_DISP_set_highlight(obj_sel[i],0);9 d5 Z( ^; E: ~7 ^' p0 ~5 |
  13.                 }
    $ J7 T" m- {, {( X; J# F- z
  14.                 UF_free(obj_sel);& `" h' D* a, ]) K
  15.         }% v0 ~1 R$ s' @! P( q. c$ L
  16.         ) H: i3 w- @/ m% L: ~
  17.         UF_UI_set_cursor_view(0);" A9 F7 Q# O; y) t
  18.         UF_UI_lock_UG_access(UF_UI_FROM_CUSTOM);+ t  v# l' e8 M2 u5 l
  19.         char cue[] = "cue message";$ t: E" V8 t5 ]5 N
  20.         char title[] = "选择元素";( r& r  ^3 i( i0 l6 [0 D% J
  21.         int response;5 M6 c% l1 d/ J1 w1 t! F
  22.         if(UF_CALL(UF_UI_select_with_class_dialog(cue,title,
    - T4 G  \5 E5 q+ M1 E
  23.                 UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY, init_proc, &user_data,
    3 [8 z* ], k, i4 {. L+ y# b' F
  24.                 &response, num ,object)) == 0)
    1 i5 z1 f& ~( ]' F+ `
  25.         {
    ) c% E2 x* D6 @) ?
  26.                 if (response == UF_UI_OK)
    0 B& P6 j3 C' Q$ \; u( O7 r% o
  27.                 {" m3 d3 {. }: E; a' i* o8 l
  28.                         UF_UI_unlock_ug_access(UF_UI_FROM_CUSTOM);) p0 G# X3 s& z9 d5 _
  29.                         return 1;1 h* Q0 l4 w. W, \0 `3 p4 _
  30.                 }! ~1 i( f0 l. H/ B2 C
  31.         }6 V( }2 k, l% M; i% [
  32.         UF_UI_unlock_ug_access(UF_UI_FROM_CUSTOM);+ O8 L; Z: B/ ^" N; g" V; c
  33. : V, R  G) Q7 V7 U
  34.         return 0;
      Y- o$ E! ]9 r9 c7 `
  35. }
/ R8 r  H6 t; p; R( {  W# z& y! P对象选择对话框有时候不能弹出来,但点击鼠标中间还是能够选中的,能帮忙分析下原因吗?
