NX二次开发源码分享:获取装配树上所有的组件名字
G2 N6 ]0 _* i( l4 C. C! J
, O1 _$ ?5 ~% r7 b, m这里使用了递归的方法,进行查询!8 t7 Z, ?6 a0 ^1 j; a' ]
: r) j5 l) ~" D# o' v: q. p0 Q/ G
4 k5 F" d6 d7 i7 J, x c' z4 \/ U
7 Z4 D$ L8 X/ P; R/ G- <p># {% E$ \8 M6 r* H. U2 X& N( e
- static void findallparts(tag_t part_tag)+ n3 J9 v5 C) w2 v5 k: E
# `: O' s. p* q2 Z7 _' m8 y! W - char part_fspec[257];
/ S3 W2 f5 l% x. `8 I2 y - char msg[133];8 Y2 I: d6 @6 m% H$ w( S6 d
- tag_t *child_part_occs;9 {) m- J! Z0 d- B. F
- char part_name[ MAX_FSPEC_BUFSIZE ];4 q. ?* |9 C- t
- char refset_name[UF_OBJ_NAME_BUFSIZE] ;$ a4 _7 ?) I$ x5 B4 ~
- char instance_name[ UF_CFI_MAX_FILE_NAME_BUFSIZE ] ;4 A& d" Z6 V0 u8 T
- double origin[3] ;
+ Y0 B% R o2 ^ - double csys_matrix[9] ;+ f& g1 n' o; }4 T, Y3 s
- double transform[4][4] ;; f. R3 o5 {3 S/ ~
- UF_UI_open_listing_window();3 K m- w B+ S8 \! V
- int count_occs = UF_ASSEM_ask_part_occ_children(part_tag,&child_part_occs);
6 r; d' \1 |# F - //if want to get the suppressed components
' r" W8 M7 ^; H8 H - // use UF_ASSEM_ask_all_part_occ_children% Z& f% D. H: P7 I9 l
- for (int i = 0 ; i < count_occs ; i++)
# {' z6 G, p- n' d6 d( B. M - {
" F+ `: h+ p0 o( J2 _ - UF_ASSEM_ask_component_data(child_part_occs[i],part_name,refset_name,instance_name,origin,csys_matrix,transform);
" s" G/ Q; m7 _; l& C7 B - sprintf(msg,"occ tag : %d \t part_name:%s\t instance_name:%s\t reference name : %s\t\n",
E: Z2 N5 P* B4 S3 {- O ~! ^ - count_occs,part_name,instance_name,refset_name);
1 ]* ~& s. p7 U - UF_UI_write_listing_window(msg);
2 G8 n# W9 A9 i- D& `1 m7 |0 B - findallparts(child_part_occs[i]);
8 P5 y4 G8 [0 H, E2 q. L* B - }
7 [' Y: Y! J3 z* ] - UF_free(child_part_occs);
! _3 d* X% J# |& [! ~2 }5 G - }</p><p> </p><p>( ^# t5 U4 L# F: P7 W% f# L
- static void do_UGopenapi()
- n* Y, I$ l5 b! q7 \% l - {
" A: V0 F. n9 I9 k0 P: i - tag_t part_tag = UF_ASSEM_ask_work_part();1 j" ?6 E) C4 r1 A$ V! L- l
- if(part_tag!=NULL_TAG)! G' F4 B1 Y- P) v; H0 b% G( |
9 ^5 I) ~8 X1 N - tag_t occ_tag = UF_ASSEM_ask_root_part_occ(part_tag);
2 a0 Y3 m( N9 |; Z* v3 ^: N - findallparts(occ_tag);
6 S Q+ {( U$ [1 {* Z/ P( C+ H - }
+ h8 c) C) g, [ A$ Z - }" H" Y0 a2 j8 Z; t
- </p>
3 x4 c, _9 n5 \3 T' O( A |
