[二次开发源码] 循环查找所有打开零件的特征并输出特征列表
2013-11-26 15:12:52 3443 0
发表于 2013-11-26 15:12:52 | 显示全部楼层 |阅读模式
' ~! L+ j+ `; j( g
循环查找所有打开零件的特征并输出特征列表5 Y3 ^+ [# ]$ w1 R% C( A
  1. 9 v! y" J7 |* K, w$ N# p
  2. <p>static void do_UGopen_api(void)
    ' O3 Q, T% V9 q& Z
  3. {3 @  C( E! l" K
  4. // create block 1( Q( o+ Y6 Y5 B
  5. double coner[3] = {0,0,0};
    & a! ^" F8 @; T3 B: P, i; u2 J
  6. char *edges[3] = {"l=100","w=100","h=20"};
    6 s+ c' ~' J' u, A* I+ ]8 z
  7. tag_t blk_tag;% e9 \- i/ ?. e! v8 B- d
  8. UF_MODL_create_block1(UF_NULLSIGN,coner,edges,&blk_tag);" P# Z0 W) {6 j
  9. // create a hole
    9 u9 D! R1 m, a, t- E5 z
  10. double dir[3] = {0,0,1};
    + Y( V  K: ~: _
  11. double coner1[3] = {50,50,0};
    9 N- `, w6 u) q
  12. tag_t cyl_tag;, q' \8 u0 w8 Z: U. A
  13. UF_MODL_create_cyl1(UF_NEGATIVE,coner1,"h","20",dir,&cyl_tag);
    ; q) y1 B, i3 L2 j
  14. tag_t part;
    1 d  M5 D1 A( N2 z' o5 p
  15. char msg[132],msg1[132];
    2 G. }$ c/ ~' q) I( u5 M) g  E
  16. char part_fspec[MAX_FSPEC_SIZE+1];
    ! W. C& H, r$ o
  17. int num = UF_PART_ask_num_parts();
    5 ~: `  d$ a: m6 ~9 i. n9 `
  18. sprintf(msg,"the part num is %d",num);
    + j6 s" C0 v, D( A$ `0 U
  19. uc1601(msg,1);( O( r( i' Y; Z/ b/ c% E
  20. for(int num_part=0;num_part<num;num_part++), ?! B2 N( s. x4 W/ x( s! ]
  21. {+ h: ^4 `0 F! n, u9 s1 L
  22.   part = UF_PART_ask_nth_part(num_part);% s$ Q& G: u0 |3 Q% f
  23.   UF_PART_ask_part_name(part,part_fspec);& ?9 H2 @; j' Y# R
  24.   uc1601(part_fspec,1);
    . S. r5 O0 I& M% r/ Z1 y, W& y
  25.   int count = 0;
    * x. W, ?) M$ H4 N+ L6 Z" j
  26.   int type = UF_feature_type;1 ?: c. T9 |: b1 G
  27.   tag_t feature = NULL_TAG;
    2 z) h( y! P* W9 p" p, }
  28.   UF_OBJ_cycle_objs_in_part(part,type,&feature);
    6 D' ~/ q4 d$ {- V8 g
  29.   char *name;$ l2 u: B/ W2 M0 W2 r% w" B- d
  30.   while(feature!= NULL_TAG)
    ) Z! I! w( l; j  U; m7 X/ R
  31.   { $ ?: i0 I" V. F9 B* y7 J& c
  32.     count++;9 ^( v* Y1 \/ l$ M# ^
  33.     UF_MODL_ask_feat_display_name(feature,&name);) |: N3 q' l1 G. e' _: J" `
  34.     UF_OBJ_cycle_objs_in_part(part,type,&feature);+ _4 H. P3 u5 g# `+ ], H
  35.     sprintf(msg1,"the cyle result is the %d feature : %s",count,name);3 d$ V( i% @3 L6 Y2 M7 R' I) E
  36.     uc1601(msg1,1);3 o, L' W" x8 S$ Q
  37.   }  ) l$ n9 l8 y- q- D7 V' T, I
  38.   * b6 s, f+ ?; m4 K
  39. }
    3 q) d7 Y) o: d
  40.
    2 ?6 e  c( b4 B( L6 d- }! z
  41. }</p>
" \% ?2 p" o: k* _) J* c
