获取部件中所有的表达式,并对表达式进行更改,更新模型2 [1 [9 l' Y0 x/ z$ j
. `; p g* u1 C1 t, A结果:- r% j4 L4 u9 E2 ?3 `- G4 n" y9 k
" V& l$ X# k d- U$ l2 |
Before change the value :
! s( B+ Q( o" q% V7 t- P5 kp0=20
6 S( n/ w; J; r) F( Fp1=h* H& u# Y. D3 S# ^- f
w=100. U* ~& P! q" m. t8 m
h=20, i! x$ h( ?) O& _2 M- A/ y$ T
l=200
& R: k I. i9 WStart to change the expressions :
2 e7 Z# R! C# y+ b- P! v6 f' kp0=20" V3 {# ]- g3 q% _, t$ y0 {
p1=h
% ^: B. _# ?0 a5 s) v( kw=1009 t$ b6 S( y$ Y% B5 ?9 y$ h; }
h=20) }4 [# P: V A3 v
l=200
4 F( c x2 {& e# }& o; p) G, S0 ^% c! a' B/ C5 t
8 Y- O* }0 ^) \! T1 g- <p>( `' U. h) n- c# r
- static void do_UGopen_api(void)
& Z g' _7 P/ K! k - {
5 @9 l6 }7 n2 X6 P - // create block 1
% b0 ?. B3 b! o: b( ~0 E0 D. H - double coner[3] = {0,0,0};# E) l9 }" Q! P& O* N9 e9 i& L4 v
- char *edges[3] = {"l=100","w=100","h=20"};1 h/ Y- n1 b1 ?, W( Y/ p
- tag_t blk_tag;
/ U" W0 s. P: b* G: g4 Z" ?1 T - UF_MODL_create_block1(UF_NULLSIGN,coner,edges,&blk_tag);1 u7 C6 O5 h5 [9 H& \* a
- // create a hole
, d; z8 I4 b* J7 X5 v% L - double dir[3] = {0,0,1};
5 q, I% k* r) n; l" C' A - double coner1[3] = {50,50,0};. m5 Q+ [) O1 J0 b
- tag_t cyl_tag;. Z+ A0 h/ z# X# M; _( D6 P
- UF_MODL_create_cyl1(UF_NEGATIVE,coner1,"h","20",dir,&cyl_tag);</p><p> // get the expressions
/ W( X/ ?4 B) j$ Y$ ^9 _; i3 T' |7 A - tag_t part=UF_PART_ask_display_part();. O& y2 ]: {4 S4 N; ^+ a
- int number_of_exps = 0;# i& n2 s9 s0 x( u/ v# s
- tag_t *exps;
7 E& N7 j% v8 Z$ C% u @2 o, K - char *str;
1 D/ t ]; O' {6 p' s - char expStr[133];
6 Q# y# Y8 @6 g" L - UF_UI_open_listing_window();
( f$ n& \, r" A2 ^+ V' U - UF_MODL_ask_exps_of_part(part,&number_of_exps,&exps);
# h( w$ j1 W: d - UF_UI_write_listing_window("Before change the value : \n");
7 h& }8 u" O: ~& x - for(int i = 0 ; i < number_of_exps;i++)& u. c. J6 y- c& x
- {7 \, m. G/ { L+ v; @% B
! _# {0 e% H$ _, y" R3 ^- \ - UF_MODL_ask_exp_tag_string(exps[i],&str);
: l$ e2 P. O% s1 K R- `7 r - UF_UI_write_listing_window(str);' z" \8 B; T4 S3 z. j
- UF_UI_write_listing_window("\n");
r( }; n& d$ T& I' y - UF_free(str);
- A7 U1 a, u X' X - }/ J+ T4 k: F7 n O2 G
) V8 M- _6 `( y" o/ e; _; z$ Q - UF_free(exps);2 s+ W4 M+ W, C1 l. B6 u) u: ^
- //Start to change the expressions; |: c0 f G0 Y( b) H& R
- UF_UI_write_listing_window("Start to change the expressions : \n");1 K) M* O0 M. e6 j9 \) o! h
- char *exp_str = "l = 200";
6 U, [! l' F0 k6 j [ - UF_MODL_edit_exp(exp_str);& E: I1 b% o8 [% P* e2 t2 y# Q8 c
- UF_MODL_update();
; T1 G$ _4 c$ K6 h! f) U - exp_str = "\0";1 V2 V- D) N3 ^' f( l
- //get the new exps
4 e1 A$ ~7 l5 M) @) G3 H+ C - UF_MODL_ask_exps_of_part(part,&number_of_exps,&exps);' i8 f! ^2 R! O' c1 N+ Y
- for(int i = 0 ; i < number_of_exps;i++)6 H9 p4 T! b& @2 d3 H. S
) I! p" ^4 V1 |1 s9 M, M8 r - UF_MODL_ask_exp_tag_string(exps[i],&str);
; t0 H0 U5 ~4 W2 \- r$ S3 V - UF_UI_write_listing_window(str);
5 b( G, ]0 d7 f: }( A3 V9 E - UF_UI_write_listing_window("\n");
6 l9 T/ m1 L0 {4 ? - UF_free(str);
# w8 J2 L9 x8 v - }% t! N( J7 ?% n0 c% @7 ], h" J, d# N
- UF_free(exps);
1 A& A$ h( v, J8 q4 v - }</p><p> </p>
复制代码 # ?8 }( D1 X' {9 q6 X% W# p
