[二次开发源码] UG NX二次开发源码分享: 报告所有的表达式信息
2016-3-4 13:45:00 3660 0
发表于 2016-3-4 13:45:00 | 显示全部楼层 |阅读模式
6 a+ S6 d. C! q% w* l8 f
; B" r" N! K2 ^( u1 W2 E
  |2 t% S- u# K) h
' u7 l/ x& E5 u+ x0 ]* s$ l9 w6 C+ `void MyClass::do_it()
  G0 t  ]) N% V, V( ?: K& b. Q1 c6 a{0 J; Z3 m7 }2 c+ q4 i8 u( J
    std::stringstream out;
, a, B6 b- l5 D1 U- B" ^! W    ExpressionCollection *expcol = workPart->Expressions();1 E& s% X& U5 w, y% S6 P. F! f
    for (ExpressionCollection::iterator it = expcol->begin();
7 r3 r  O- U2 W# |$ S3 U! Z        it != expcol->end();
2 ^/ ?; e; U" a. ~        it++)8 i9 R9 P0 N. a) G3 M7 J% \  D
2 K9 n' T) m. h: \6 r! a        Expression *expr = *it;
, m( v' t% G0 O8 l9 D- o8 x: H* m1 p        out.str(""); out.clear();
$ h7 D4 ~4 }4 x  D8 ~        out << "\nExpression: " << expr->Tag() << std::endl;! t/ k& T  s& P3 g4 ^
        out << "Name: " << expr->Name().GetText() << std::endl;* l# q8 J4 c5 ?# ~$ r* [- W
        out << "Type: " << expr->Type().GetText() << std::endl;
4 n( V7 {& D0 U; v2 \/ j& X0 z        out << "Description: " << expr->Description().GetText() << std::endl;: [: z. A, e7 x4 c8 x3 K; Y# I
        out << "Equation: " << expr->Equation().GetText() << std::endl;
7 ~$ K1 d: h8 y7 m+ E
0 w7 H9 Z# O3 L. s5 }9 V        std::string strType(expr->Type().GetText());, Z: P- C% a% i  I. l+ n
& E3 x( _6 s2 A, [2 y        if ( strType.compare("Number") == 0 )5 X; h5 k/ d1 b* J' A, @
3 o# ?0 n* {) d, \6 ~/ r2 a            out << "Units: " << expr->Units()->Name().GetText() << std::endl;
# r& }6 _8 P& ?            out << "Number Value: " << expr->Value() << std::endl;
  U3 Q6 r: a& _* i        }
) Y# i* E7 r1 ?+ r3 V4 F        else if ( strType.compare("Boolean") == 0 ); m3 n, |! t! Z2 q
            out << "Boolean Value: " << expr->BooleanValue() << std::endl;
, O1 a9 k6 \$ m0 s        else if ( strType.compare("Integer") == 0 )
: l/ T' M/ f) _4 R6 S            out << "Integer Value: " << expr->IntegerValue() << std::endl;+ e, b" p* b+ o% F) d3 z$ y
        else if ( strType.compare("String") == 0 )
3 H/ O. Y, e4 A4 }2 s* V            out << "String Value: " << expr->StringValue().GetText() << std::endl;
; {' l' M: {1 N: B' ^% f        else if ( strType.compare("Point") == 0 )
; l8 A- w6 Q4 P( ~! W' \. [' t) X            out << "Point Value: " << expr->PointValue().X << "," << expr->PointValue().Y << "," << expr->PointValue().Z << std::endl;( L9 W5 C! B) Y# c, x7 T( S
        else if ( strType.compare("Vector") == 0 )
9 H  A5 A4 @! y, _# I            out << "Vector Value: " << expr->VectorValue().X << "," << expr->VectorValue().Y << "," << expr->VectorValue().Z << std::endl;$ n, Z) o% _8 Q6 @: J
        else if( strType.compare("List") == 0 ): v! d. E% N! A# @4 j
            out << "List Value: " << expr->RightHandSide().GetText() << std::endl;/ D: W, X8 @$ }- m( F2 L
* @1 w  x9 |1 @2 N  |
        std::string strRHS(expr->RightHandSide().GetText());( z/ o# q7 x' G9 h( r6 z' O3 E6 U
        std::string::size_type nPos = strRHS.find("//");
' }; l1 V: N. H        if( nPos != std::string::npos )
9 G0 Q  [8 j2 ~0 d, S        {
8 d; u" p, `! E% q" E1 {7 @! m- D            std::string strComment = strRHS.substr(nPos+2);# c  S0 @! p3 U, ?
            out << "Comment: " << strComment << std::endl;
5 c3 A6 y' U0 B2 t) F6 [( a7 F- I  i        }' S& F! E) Z- J0 a! \9 j* U
: U& ?4 `& i  z2 _7 n        if(expr->IsInterpartExpression())- ]  b- n& ]9 w! l# U7 u
, K5 F' y0 r: V: [* l; j# V% Z            NXString sPartName("");
0 w, W( m7 J3 V/ O! R+ \, ~0 o% x            NXString sExprName("");
2 v( S" q: w1 M- N* D' N2 D: M            expr->GetInterpartExpressionNames(&sPartName, &sExprName);
- H2 {" S: M4 Y% }            out << "IPE partName: " << sPartName.GetText() << std::endl;
  w- b2 a0 [3 Z. F2 H( p            out << "IPE exprName: " << sExprName.GetText() << std::endl;7 {* d: W7 G$ ~% ^
        }3 B! M+ x0 m3 Q$ D4 u
0 ~  b# m" d3 I$ i; S        print(out.str().c_str());
# v' m( Z0 y6 w5 v; }2 `    }
! s4 {  D' K: Q+ o
$ q1 Y9 x3 K" I; y  p}$ D0 L" [2 C/ ~/ v
# }$ r7 A/ U% x# }8 ?" H
